[geos-commits] [SCM] GEOS branch master updated. d04e0991c64019c7736d7288983e8f583582ba1c
git at osgeo.org
git at osgeo.org
Thu May 23 17:17:48 PDT 2019
the project "GEOS".
via d04e0991c64019c7736d7288983e8f583582ba1c (commit)
from 3af99a815b30eaac61b9bf234c6677c5e41fcf73 (commit)
revisions in full, below.
commit d04e0991c64019c7736d7288983e8f583582ba1c
Author: Mateusz Ĺoskot <mateusz at loskot.net>
Date: Fri May 24 01:32:36 2019 +0200
Add GEOS_DLL_EXPORT to compile definitions for MSVC
Required to trigger generation of `.lib` archive with
import library for DLL.
diff --git a/CMakeLists.txt b/CMakeLists.txt
index e31590a..2937297 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -191,6 +191,9 @@ add_subdirectory(include)
add_subdirectory(src)
if(BUILD_SHARED_LIBS)
+ target_compile_definitions(geos
+ PRIVATE $<$<CXX_COMPILER_ID:MSVC>:GEOS_DLL_EXPORT>)
set_target_properties(geos PROPERTIES VERSION ${GEOS_VERSION})
if(NOT WIN32)
set_target_properties(geos PROPERTIES SOVERSION ${GEOS_VERSION_MAJOR})
@@ -202,15 +205,19 @@ endif()
add_library(geos_c "")
target_link_libraries(geos_c PRIVATE geos)
-add_subdirectory(capi)
+ target_compile_definitions(geos_c
set_target_properties(geos_c PROPERTIES VERSION ${GEOS_VERSION})
if(NOT WIN32)
set_target_properties(geos_c PROPERTIES SOVERSION ${GEOS_VERSION_MAJOR})
endif()
endif()
+add_subdirectory(capi)
# Tests
Summary of changes:
CMakeLists.txt | 9 ++++++++-
1 file changed, 8 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
