[geos-commits] [SCM] GEOS branch master updated. a00aa60de9f1524fbb656a483b69d1afca7aa46d
git at osgeo.org
git at osgeo.org
Thu May 23 17:22:49 PDT 2019
the project "GEOS".
via a00aa60de9f1524fbb656a483b69d1afca7aa46d (commit)
via 4a6813e0594aa76ef92a765496c76b12066c562e (commit)
from 1ccc019387d4902557396ed2d251efcb477655fa (commit)
revisions in full, below.
commit a00aa60de9f1524fbb656a483b69d1afca7aa46d
Merge: 1ccc019 4a6813e
Author: Daniel Baston <dbaston at gmail.com>
Date: Thu May 23 20:22:35 2019 -0400
Merge branch 'remove-coordseq-to-vector'
commit 4a6813e0594aa76ef92a765496c76b12066c562e
Date: Thu May 23 16:24:23 2019 -0400
Remove CoordinateSequence::toVector()
Deprecated a decade ago, but still used a couple of times within GEOS.
Supports the goal of a smaller CoordinateSequence interface.
diff --git a/include/geos/geom/CoordinateArraySequence.h b/include/geos/geom/CoordinateArraySequence.h
index f25103e..7ce2799 100644
--- a/include/geos/geom/CoordinateArraySequence.h
+++ b/include/geos/geom/CoordinateArraySequence.h
@@ -52,9 +52,6 @@ public:
//int size() const;
size_t getSize() const override;
- // @deprecated
- const std::vector<Coordinate>* toVector() const override;
// See dox in CoordinateSequence.h
void toVector(std::vector<Coordinate>&) const override;
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index f4c5764..70eb4c4 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -120,30 +120,8 @@ public:
return getSize();
- /** \brief
- * Returns a read-only vector with the Coordinates in this collection.
- * Whether or not the Coordinates returned are the actual underlying
- * Coordinates or merely copies depends on the implementation.
- * Note that if this implementation does not store its data as an
- * array of Coordinates, this method will incur a performance penalty
- * because the array needs to be built from scratch.
- * This method is a port of the toCoordinateArray() method of JTS.
- * It is not much used as memory management requires us to
- * know whether we should or not delete the returned object
- * in a consistent way. Our options are: use shared_ptr<Coordinate>
- * or always keep ownership of an eventual newly created vector.
- * We opted for the second, so the returned object is a const, to
- * also ensure that returning an internal pointer doesn't make
- * the object mutable.
- * @deprecated use toVector(std::vector<Coordinate>&) instead
- virtual const std::vector<Coordinate>* toVector() const = 0;
- /// Pushes all Coordinates of this sequence onto the provided vector.
+ /// Pushes all Coordinates of this sequence into the provided vector.
/// This method is a port of the toCoordinateArray() method of JTS.
virtual void toVector(std::vector<Coordinate>& coords) const = 0;
@@ -206,7 +184,7 @@ public:
/// Delete Coordinate at position pos (list will shrink).
virtual void deleteAt(std::size_t pos) = 0;
- /// Get a string rapresentation of CoordinateSequence
+ /// Get a string representation of CoordinateSequence
virtual std::string toString() const = 0;
/// Substitute Coordinate list with a copy of the given vector
diff --git a/src/geom/CoordinateArraySequence.cpp b/src/geom/CoordinateArraySequence.cpp
index f30735f..48f068c 100644
--- a/src/geom/CoordinateArraySequence.cpp
+++ b/src/geom/CoordinateArraySequence.cpp
@@ -85,12 +85,6 @@ CoordinateArraySequence::setPoints(const vector<Coordinate>& v)
vect->assign(v.begin(), v.end());
-const vector<Coordinate>*
-CoordinateArraySequence::toVector() const
- return vect; //new vector<Coordinate>(vect->begin(),vect->end());
std::size_t
CoordinateArraySequence::getDimension() const
diff --git a/src/geom/LinearRing.cpp b/src/geom/LinearRing.cpp
index b6fe05a..c254a4d 100644
--- a/src/geom/LinearRing.cpp
+++ b/src/geom/LinearRing.cpp
@@ -111,9 +111,7 @@ LinearRing::getGeometryType() const
void
LinearRing::setPoints(const CoordinateSequence* cl)
- const vector<Coordinate>* v = cl->toVector();
- points->setPoints(*(v));
- //delete v;
+ points = cl->clone();
GeometryTypeId
diff --git a/src/operation/overlay/snap/GeometrySnapper.cpp b/src/operation/overlay/snap/GeometrySnapper.cpp
index 36b7e6b..87e9e68 100644
--- a/src/operation/overlay/snap/GeometrySnapper.cpp
+++ b/src/operation/overlay/snap/GeometrySnapper.cpp
@@ -59,8 +59,9 @@ private:
using std::unique_ptr;
assert(srcPts);
- assert(srcPts->toVector());
- LineStringSnapper snapper(*(srcPts->toVector()), snapTol);
+ std::vector<Coordinate> coords;
+ srcPts->toVector(coords);
+ LineStringSnapper snapper(coords, snapTol);
unique_ptr<Coordinate::Vect> newPts = snapper.snapTo(snapPts);
const CoordinateSequenceFactory* cfact = factory->getCoordinateSequenceFactory();
diff --git a/src/operation/overlay/validate/OverlayResultValidator.cpp b/src/operation/overlay/validate/OverlayResultValidator.cpp
index 2cee56e..5900cb5 100644
--- a/src/operation/overlay/validate/OverlayResultValidator.cpp
+++ b/src/operation/overlay/validate/OverlayResultValidator.cpp
@@ -146,8 +146,11 @@ OverlayResultValidator::addVertices(const Geometry& g)
// TODO: optimize this by not copying coordinates
// and pre-allocating memory
unique_ptr<CoordinateSequence> cs(g.getCoordinates());
- const vector<Coordinate>* coords = cs->toVector();
- testCoords.insert(testCoords.end(), coords->begin(), coords->end());
+ testCoords.reserve(testCoords.size() + cs->size());
+ for (size_t i = 0; i < cs->size(); i++) {
+ testCoords.push_back(cs->getAt(i));
/*private*/
diff --git a/src/simplify/DouglasPeuckerSimplifier.cpp b/src/simplify/DouglasPeuckerSimplifier.cpp
index d76030f..cad62a1 100644
--- a/src/simplify/DouglasPeuckerSimplifier.cpp
+++ b/src/simplify/DouglasPeuckerSimplifier.cpp
@@ -105,12 +105,11 @@ DPTransformer::transformCoordinates(
::geos::ignore_unused_variable_warning(parent);
- const Coordinate::Vect* inputPts = coords->toVector();
- assert(inputPts);
+ Coordinate::Vect inputPts;
+ coords->toVector(inputPts);
std::unique_ptr<Coordinate::Vect> newPts =
- DouglasPeuckerLineSimplifier::simplify(*inputPts,
- distanceTolerance);
+ DouglasPeuckerLineSimplifier::simplify(inputPts, distanceTolerance);
return CoordinateSequence::Ptr(
factory->getCoordinateSequenceFactory()->create(
Summary of changes:
include/geos/geom/CoordinateArraySequence.h | 3 ---
include/geos/geom/CoordinateSequence.h | 28 +++-------------------
src/geom/CoordinateArraySequence.cpp | 6 -----
src/geom/LinearRing.cpp | 4 +---
src/operation/overlay/snap/GeometrySnapper.cpp | 5 ++--
.../overlay/validate/OverlayResultValidator.cpp | 7 ++++--
src/simplify/DouglasPeuckerSimplifier.cpp | 7 +++---
7 files changed, 15 insertions(+), 45 deletions(-)
hooks/post-receive
More information about the geos-commits
