[geos-commits] [SCM] GEOS branch master updated. 89a3277e7be971352eddfbc53f3050f9296af1a1
Fri May 24 16:15:27 PDT 2019
the project "GEOS".
       via  89a3277e7be971352eddfbc53f3050f9296af1a1 (commit)
      from  3c627561c3f5e3fd18dd69499b32a0e31708ec71 (commit)
revisions in full, below.
commit 89a3277e7be971352eddfbc53f3050f9296af1a1
Author: Regina Obe <lr at pcorp.us>
Date:   Fri May 24 16:15:27 2019 -0700
    Update 'README.md'
    Incorporate windows VS 2019 instructions from Mateusz Loskot - https://github.com/mloskot/mateusz.loskot.net/blob/master/content/post/2019/05/geos-with-cmake-and-vs2019.md
diff --git a/README.md b/README.md
index 224d3df..98bc55e 100644
--- a/README.md
+++ b/README.md
@@ -65,6 +65,47 @@ check`.
 GEOS can be built with Microsoft Visual C++ by opening the `CMakeLists.txt` in
 the project root using `File > Open > CMake`.
+If you prefer the command-line
+#### Build with CMake generator for Ninja (fast)
+In the Visual Studio 2019 command prompt, `x64 Native Tools Command Prompt for VS 2019` or `x64_x86 Cross Tools Command Prompt for VS 2019`:
+cmake -S . -B _build_vs2019_ninja -G Ninja -DCMAKE_BUILD_TYPE=Release
+cmake --build _build_vs2019_ninja -j 16 --verbose
+#### Build with CMake generator for MSBuild (default)
+In the non-specific Command Prompt:
+##### 64-bit
+cmake -S . -B _build_vs2019x64 -G "Visual Studio 16 2019" -A x64 -DCMAKE_GENERATOR_TOOLSET=host=x64
+cmake --build _build_vs2019x64 --config Release -j 16 --verbose
+##### 32-bit
+cmake -S . -B _build_vs2019x32 -G "Visual Studio 16 2019" -A x32 -DCMAKE_GENERATOR_TOOLSET=host=x64
+cmake --build _build_vs2019x32 --config Release -j 16 --verbose
+#### Test using CMake
+cd <build directory>
+ctest --show-only
+ctest
+ctest --output-on-failure
+ctest -V
+ctest -VV
 ## Client applications
 ### Using the C interface
Summary of changes:
 README.md | 41 +++++++++++++++++++++++++++++++++++++++++
 1 file changed, 41 insertions(+)
hooks/post-receive
More information about the geos-commits mailing list
