[geos-commits] [SCM] GEOS branch master updated. 2084a8033f1644460bc832b84e3a3d30174658ce
git at osgeo.org
git at osgeo.org
Wed May 29 10:40:57 PDT 2019
the project "GEOS".
via 2084a8033f1644460bc832b84e3a3d30174658ce (commit)
from 5669633c493aff845ad0cd3f5e0d7e61ae9fda74 (commit)
revisions in full, below.
commit 2084a8033f1644460bc832b84e3a3d30174658ce
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed May 29 12:33:22 2019 -0400
[CMake] Add target for doc/example.cpp
Important to make sure example still compiles after C++ API changes.
Resolves #901.
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 91aac43..1f9b71b 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -244,6 +244,11 @@ endif()
add_subdirectory(benchmarks)
+# Documentation/Examples
+add_subdirectory(doc)
# Install and export targets - support 'make install' or equivalent
include(CMakePackageConfigHelpers)
diff --git a/doc/CMakeLists.txt b/doc/CMakeLists.txt
new file mode 100644
index 0000000..f2295fe
--- /dev/null
+++ b/doc/CMakeLists.txt
@@ -0,0 +1,17 @@
+# Part of CMake configuration for GEOS
+# Copyright (C) 2018 Mateusz Loskot <mateusz at loskot.net>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU Lesser General Public Licence as published
+# by the Free Software Foundation.
+# See the COPYING file for more information.
+add_executable(example example.cpp)
+target_link_libraries(example PRIVATE geos)
+target_include_directories(test_geos_unit
+ PRIVATE
+ $<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>)
Summary of changes:
CMakeLists.txt | 5 +++++
{benchmarks => doc}/CMakeLists.txt | 10 ++++++----
2 files changed, 11 insertions(+), 4 deletions(-)
copy {benchmarks => doc}/CMakeLists.txt (71%)
hooks/post-receive
More information about the geos-commits
