[geos-commits] [SCM] GEOS branch master updated. 4c5cab618ca09f10ae3684e832084c2c2bcf3867
git at osgeo.org
git at osgeo.org
Wed May 29 13:58:12 PDT 2019
the project "GEOS".
via 4c5cab618ca09f10ae3684e832084c2c2bcf3867 (commit)
via 366cc04962fafa898c43d9b91848d5c7b58fc82f (commit)
via 9b0be18a088a9aa6972919f757488a07e96f32a4 (commit)
from 9f2a3599a2977ea8ce0658395f8f668cfb1c4ca3 (commit)
revisions in full, below.
commit 4c5cab618ca09f10ae3684e832084c2c2bcf3867
Merge: 9f2a359 366cc04
Author: Daniel Baston <dbaston at gmail.com>
Date: Wed May 29 16:57:18 2019 -0400
Merge branch 'coverage'
commit 366cc04962fafa898c43d9b91848d5c7b58fc82f
Date: Wed May 29 16:46:21 2019 -0400
Exclude vendored libs from codecov
diff --git a/.codecov.yml b/.codecov.yml
new file mode 100644
index 0000000..9f7f0f6
--- /dev/null
+++ b/.codecov.yml
@@ -0,0 +1,7 @@
+coverage:
+ precision: 2
+ignore:
+ - "include/geos/algorithm/ttmath"
+ - "tests/unit/tut"
+ - "tests/xmltester/tinyxml2"
commit 9b0be18a088a9aa6972919f757488a07e96f32a4
Date: Wed May 29 15:45:24 2019 -0400
Report code coverage from Travis
[skip appveyor]
diff --git a/.travis.yml b/.travis.yml
index f02b214..c4d7633 100644
--- a/.travis.yml
+++ b/.travis.yml
@@ -29,7 +29,19 @@ matrix:
sources: *sources
packages: ['g++-7','cmake','ccache']
env:
- - E="TOOL=cmake && CXX=g++-7 && ARCH=-m64 && CC=gcc-7"
+ - E="TOOL=cmake && BUILD_TYPE=Release && CXX=g++-7 && ARCH=-m64 && CC=gcc-7"
+ - os: linux
+ cache:
+ apt: true
+ directories:
+ - $HOME/.ccache
+ addons:
+ apt:
+ sources: *sources
+ packages: ['g++-7','cmake','ccache']
+ env:
+ - E="TOOL=cmake && BUILD_TYPE=Coverage && CXX=g++-7 && ARCH=-m64 && CC=gcc-7"
- os: linux
cache:
@@ -53,7 +65,7 @@ matrix:
sources: *sources
packages: ['g++-4.8','cmake','ccache']
env:
- - E="TOOL=cmake && CXX=g++-4.8 && ARCH=-m64 && CC=gcc-4.8"
+ - E="TOOL=cmake && BUILD_TYPE=Release && CXX=g++-4.8 && ARCH=-m64 && CC=gcc-4.8"
- os: linux
cache:
@@ -77,7 +89,7 @@ matrix:
sources: *sources
packages: ['clang-3.9','cmake','ccache']
env:
- - E="TOOL=cmake && CXX=clang++-3.9 && ARCH=-m64 && CC=clang-3.9"
+ - E="TOOL=cmake && BUILD_TYPE=Release && CXX=clang++-3.9 && ARCH=-m64 && CC=clang-3.9"
- os: linux
cache:
@@ -89,13 +101,14 @@ matrix:
sources: *sources
packages: ['clang','cmake','ccache']
env:
- - E="TOOL=cmake && CXX=clang++ && ARCH=-m64 && CC=clang"
+ - E="TOOL=cmake && BUILD_TYPE=Release && CXX=clang++ && ARCH=-m64 && CC=clang"
before_install:
- eval "${E}"
- export CXXFLAGS=${ARCH}
- export CFLAGS=${ARCH}
- export GEOS_BUILD_TOOL=${TOOL}
+ - export BUILD_TYPE=${BUILD_TYPE}
- export CXX="ccache ${CXX}"
- ${CXX} --version
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 1f9b71b..9045f78 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -27,6 +27,8 @@ if(EXISTS ${CMAKE_SOURCE_DIR}/.git/HEAD)
set(GEOS_BUILD_FROM_GIT ON)
endif()
+message(STATUS "GEOS: Build type: ${CMAKE_BUILD_TYPE}")
# Options
@@ -195,6 +197,11 @@ if(WIN32)
endif()
+# Define a coverage build
+set(CMAKE_CXX_FLAGS_COVERAGE "-fprofile-arcs -ftest-coverage")
# Target geos: C++ API library
add_library(geos "")
diff --git a/tools/ci/script_cmake.sh b/tools/ci/script_cmake.sh
index 069d392..583ff6b 100755
--- a/tools/ci/script_cmake.sh
+++ b/tools/ci/script_cmake.sh
@@ -13,6 +13,10 @@ source ${TRAVIS_BUILD_DIR}/tools/ci/common.sh
cmake --version
-cmake ${TRAVIS_BUILD_DIR}
+cmake -DCMAKE_BUILD_TYPE=${BUILD_TYPE} ${TRAVIS_BUILD_DIR}
run_make
ctest --output-on-failure .
+if [ "${BUILD_TYPE}" = "Coverage" ]; then
+ bash <(curl -s https://codecov.io/bash)
+fi
Summary of changes:
.codecov.yml | 7 +++++++
.travis.yml | 21 +++++++++++++++++----
CMakeLists.txt | 7 +++++++
tools/ci/script_cmake.sh | 6 +++++-
4 files changed, 36 insertions(+), 5 deletions(-)
create mode 100644 .codecov.yml
hooks/post-receive
More information about the geos-commits
