[geos-commits] [SCM] GEOS branch master updated. 62a53152ea083e3c6e45db5893a950e97fa3dfd5
git at osgeo.org
git at osgeo.org
Thu May 30 02:23:50 PDT 2019
the project "GEOS".
via 62a53152ea083e3c6e45db5893a950e97fa3dfd5 (commit)
from bfd873e5b7d20f08eaa8be86497daadf6f355359 (commit)
revisions in full, below.
commit 62a53152ea083e3c6e45db5893a950e97fa3dfd5
Author: nila <n_larsson at yahoo.com>
Date: Wed May 22 14:29:59 2019 +0200
Fix inconsistent doxygen documentation
diff --git a/include/geos/algorithm/Distance.h b/include/geos/algorithm/Distance.h
index c9e54a6..68009a4 100644
--- a/include/geos/algorithm/Distance.h
+++ b/include/geos/algorithm/Distance.h
@@ -60,7 +60,7 @@ public:
* @param p
* a point
- * @param line
+ * @param seq
* a sequence of contiguous line segments defined by their vertices
* @return the minimum distance between the point and the line segments
diff --git a/include/geos/algorithm/Length.h b/include/geos/algorithm/Length.h
index 4d1a13f..250b355 100644
--- a/include/geos/algorithm/Length.h
+++ b/include/geos/algorithm/Length.h
@@ -38,7 +38,7 @@ public:
* Computes the length of a linestring specified by a sequence of points.
- * @param pts the points specifying the linestring
+ * @param ring the points specifying the linestring
* @return the length of the linestring
static double ofLine(const geom::CoordinateSequence* ring);
diff --git a/include/geos/algorithm/LineIntersector.h b/include/geos/algorithm/LineIntersector.h
index 8702459..fad89ad 100644
--- a/include/geos/algorithm/LineIntersector.h
+++ b/include/geos/algorithm/LineIntersector.h
@@ -109,7 +109,7 @@ public:
/// No getter is provided, because the precision model is not required
/// to be specified.
- /// @param precisionModel the PrecisionModel to use for rounding
+ /// @param newPM the PrecisionModel to use for rounding
void
setPrecisionModel(const geom::PrecisionModel* newPM)
@@ -251,7 +251,7 @@ public:
* Computes the "edge distance" of an intersection point along the specified
* input line segment.
- * @param segmentIndex is 0 or 1
+ * @param geomIndex is 0 or 1
* @param intIndex is 0 or 1
* @return the edge distance of the intersection point
diff --git a/include/geos/algorithm/MinimumDiameter.h b/include/geos/algorithm/MinimumDiameter.h
index 31ba1bb..7f6bb14 100644
--- a/include/geos/algorithm/MinimumDiameter.h
+++ b/include/geos/algorithm/MinimumDiameter.h
@@ -112,8 +112,8 @@ public:
* (e.g. a convex Polygon or LinearRing,
* or a two-point LineString, or a Point).
- * @param geom a Geometry which is convex
- * @param isConvex <code>true</code> if the input geometry is convex
+ * @param newInputGeom a Geometry which is convex
+ * @param newIsConvex <code>true</code> if the input geometry is convex
MinimumDiameter(const geom::Geometry* newInputGeom,
const bool newIsConvex);
diff --git a/include/geos/geom/CoordinateList.h b/include/geos/geom/CoordinateList.h
index bb2efc7..a6ee5bf 100644
--- a/include/geos/geom/CoordinateList.h
+++ b/include/geos/geom/CoordinateList.h
@@ -123,7 +123,7 @@ public:
* Inserts the specified coordinate at the specified position in this list.
* @param pos the position at which to insert
- * @param coord the coordinate to insert
+ * @param c the coordinate to insert
* @param allowRepeated if set to false, repeated coordinates are collapsed
* @return an iterator to the newly installed coordinate
diff --git a/include/geos/geom/CoordinateSequence.h b/include/geos/geom/CoordinateSequence.h
index 230492a..711f06a 100644
--- a/include/geos/geom/CoordinateSequence.h
+++ b/include/geos/geom/CoordinateSequence.h
@@ -124,38 +124,32 @@ public:
/// This method is a port of the toCoordinateArray() method of JTS.
- virtual void toVector(std::vector<Coordinate>& coords) const = 0;
+ virtual void toVector(std::vector<Coordinate>& coords) const = 0;
* \brief Add an array of coordinates
- * @param vc The coordinates
+ * @param vc the coordinates
- * are collapsed
- * @return true (as by general collection contract)
+ * are collapsed
void add(const std::vector<Coordinate>* vc, bool allowRepeated);
/** \brief
* Add an array of coordinates
- * @param cl The coordinates
+ * @param cl the coordinates
- * if set to false, repeated coordinates are collapsed
+ * if set to false, repeated coordinates are collapsed
* @param direction if false, the array is added in reverse order
void add(const CoordinateSequence* cl, bool allowRepeated,
bool direction);
* \brief Add a coordinate
- * @param c The coordinate to add
+ * @param c the coordinate to add
- * are collapsed
+ * are collapsed
virtual void add(const Coordinate& c, bool allowRepeated);
@@ -173,19 +167,19 @@ public:
virtual void add(std::size_t i, const Coordinate& coord, bool allowRepeated) = 0;
/// Returns <code>true</code> it list contains no coordinates.
- virtual bool isEmpty() const = 0;
+ virtual bool isEmpty() const = 0;
/// Add a Coordinate to the list
- virtual void add(const Coordinate& c) = 0;
+ virtual void add(const Coordinate& c) = 0;
/// Copy Coordinate c to position pos
- virtual void setAt(const Coordinate& c, std::size_t pos) = 0;
+ virtual void setAt(const Coordinate& c, std::size_t pos) = 0;
/// Get a string representation of CoordinateSequence
virtual std::string toString() const = 0;
/// Substitute Coordinate list with a copy of the given vector
- virtual void setPoints(const std::vector<Coordinate>& v) = 0;
+ virtual void setPoints(const std::vector<Coordinate>& v) = 0;
/// Returns true if contains any two consecutive points
bool hasRepeatedPoints() const;
@@ -266,7 +260,7 @@ public:
* @param index the coordinate index in the sequence
* @param ordinateIndex the ordinate index in the coordinate
- * (in range [0, dimension-1])
+ * (in range [0, dimension-1])
virtual double getOrdinate(std::size_t index, std::size_t ordinateIndex) const = 0;
@@ -300,7 +294,7 @@ public:
* @param value the new ordinate value
virtual void setOrdinate(std::size_t index, std::size_t ordinateIndex, double value) = 0;
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index d7de720..27c4d1b 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -292,8 +292,7 @@ public:
* Expands this envelope by a given distance in all directions.
* Both positive and negative distances are supported.
- * @param distance the distance to expand the envelope
- * @return this envelope
+ * @param p_distance the distance to expand the envelope
void
expandBy(double p_distance)
@@ -395,7 +394,7 @@ public:
* Check if the point p
* intersects (lies inside) the region of this Envelope.
- * @param p the Coordinate to be tested
+ * @param p the Coordinate to be tested
* @return true if the point intersects this Envelope
bool intersects(const Coordinate& p) const;
diff --git a/include/geos/geom/Geometry.h b/include/geos/geom/Geometry.h
index f6fa6e3..b7aef91 100644
--- a/include/geos/geom/Geometry.h
+++ b/include/geos/geom/Geometry.h
@@ -396,7 +396,7 @@ public:
* - <code>! g.intersects(this)</code>
* (<code>disjoint</code> is the inverse of <code>intersects</code>)
- * @param g the Geometry with which to compare this Geometry
+ * @param other the Geometry with which to compare this Geometry
* @return true if the two <code>Geometry</code>s are disjoint
* @see Geometry::intersects
diff --git a/include/geos/geom/GeometryFactory.h b/include/geos/geom/GeometryFactory.h
index 8af6aaf..e90cef9 100644
--- a/include/geos/geom/GeometryFactory.h
+++ b/include/geos/geom/GeometryFactory.h
@@ -293,14 +293,13 @@ public:
* and hence if any MultiGeometries are contained in the input a
* GeometryCollection containing them will be returned.
- * @param newGeoms the <code>Geometry</code>s to combine
+ * @param geoms the <code>Geometry</code>s to combine
- * @return
- * A <code>Geometry</code> of the "smallest", "most type-specific"
- * class that can contain the elements of <code>geomList</code>.
+ * @return A <code>Geometry</code> of the "smallest", "most type-specific"
+ * class that can contain the elements of <code>geomList</code>.
* NOTE: the returned Geometry will take ownership of the
- * given vector AND its elements
+ * given vector AND its elements
Geometry* buildGeometry(std::vector<Geometry*>* geoms) const;
diff --git a/include/geos/geom/LineSegment.h b/include/geos/geom/LineSegment.h
index 008d48a..3ef5d9c 100644
--- a/include/geos/geom/LineSegment.h
+++ b/include/geos/geom/LineSegment.h
@@ -104,7 +104,7 @@ public:
* Determines the orientation of a LineSegment relative to this segment.
* The concept of orientation is specified as follows:
* Given two line segments A and L,
- * <ul
+ * <ul>
* <li>A is to the left of a segment L if A lies wholly in the
* closed half-plane lying to the left of L
* <li>A is to the right of a segment L if A lies wholly in the
@@ -119,7 +119,7 @@ public:
* @return 1 if seg is to the left of this segment
* @return -1 if seg is to the right of this segment
* @return 0 if seg has indeterminate orientation relative
- * to this segment
+ * to this segment
int orientationIndex(const LineSegment& seg) const;
@@ -133,7 +133,7 @@ public:
* The orientation index is as defined in
* Orientation::index.
- * @param seg the LineSegment to compare
+ * @param p the Coordinate to compare
* @return 1 if <code>p</code> is to the left of this segment
* @return -1 if <code>p</code> is to the right of this segment
@@ -295,7 +295,7 @@ public:
* Uses the standard lexicographic ordering for the points in the LineSegment.
- * @param o the LineSegment with which this LineSegment
+ * @param other the LineSegment with which this LineSegment
* is being compared
* @return a negative integer, zero, or a positive integer as this
* LineSegment is less than, equal to, or greater than the
@@ -316,7 +316,7 @@ public:
* Computes the closest points on two line segments.
- * @param p the point to find the closest point to
+ * @param line the line segment to find the closest points to
* @return a pair of Coordinates which are the closest points on
* the line segments.
* The returned CoordinateSequence must be deleted by caller
diff --git a/include/geos/geom/Location.h b/include/geos/geom/Location.h
index 24f9a71..359bb9b 100644
--- a/include/geos/geom/Location.h
+++ b/include/geos/geom/Location.h
@@ -24,7 +24,6 @@ namespace geos {
namespace geom { // geos::geom
/** \brief
* Constants representing the location of a point relative to a geometry.
* They can also be thought of as the row or column index of a DE-9IM matrix.
diff --git a/include/geos/geom/PrecisionModel.h b/include/geos/geom/PrecisionModel.h
index d1c39a5..e2ee2fd 100644
--- a/include/geos/geom/PrecisionModel.h
+++ b/include/geos/geom/PrecisionModel.h
@@ -134,11 +134,10 @@ public:
* coordinates, which are rounded to the grid defined by the
* scale factor.
- * @param scale
- * amount by which to multiply a coordinate after subtracting
- * the offset, to obtain a precise coordinate
- * @param offsetX not used.
- * @param offsetY not used.
+ * @param newScale amount by which to multiply a coordinate after
+ * subtracting the offset, to obtain a precise coordinate
+ * @param newOffsetX not used.
+ * @param newOffsetY not used.
* @deprecated offsets are no longer supported, since internal
* representation is rounded floating point
diff --git a/include/geos/geom/prep/BasicPreparedGeometry.h b/include/geos/geom/prep/BasicPreparedGeometry.h
index 7157906..1fcdfdb 100644
--- a/include/geos/geom/prep/BasicPreparedGeometry.h
+++ b/include/geos/geom/prep/BasicPreparedGeometry.h
@@ -115,8 +115,7 @@ public:
* intersects the test geometry.
* This is useful in A/A, A/L, A/P, L/P, and P/P cases.
- * @param geom the test geometry
- * @param repPts the representative points of the target geometry
+ * @param testGeom the test geometry
* @return true if any component intersects the areal test geometry
bool isAnyTargetComponentInTest(const geom::Geometry* testGeom) const;
@@ -129,7 +128,7 @@ public:
* Default implementation.
- bool containsProperly(const geom::Geometry* g) const override;
+ bool containsProperly(const geom::Geometry* g) const override;
@@ -150,7 +149,7 @@ public:
* Standard implementation for all geometries.
* Supports {@link GeometryCollection}s as input.
- bool disjoint(const geom::Geometry* g) const override;
+ bool disjoint(const geom::Geometry* g) const override;
@@ -160,7 +159,7 @@ public:
- bool overlaps(const geom::Geometry* g) const override;
+ bool overlaps(const geom::Geometry* g) const override;
diff --git a/include/geos/geom/prep/PreparedLineStringIntersects.h b/include/geos/geom/prep/PreparedLineStringIntersects.h
index 2196257..bda4fc2 100644
--- a/include/geos/geom/prep/PreparedLineStringIntersects.h
+++ b/include/geos/geom/prep/PreparedLineStringIntersects.h
@@ -69,7 +69,7 @@ public:
* Tests whether this geometry intersects a given geometry.
+ * @param g the test geometry
* @return true if the test geometry intersects
bool intersects(const geom::Geometry* g) const;
@@ -82,7 +82,7 @@ protected:
* the target geometry.
* Only handles test geometries which are Puntal (dimension 0)
- * @param geom a Puntal geometry to test
+ * @param testGeom a Puntal geometry to test
* @return true if any point of the argument intersects the prepared geometry
bool isAnyTestPointInTarget(const geom::Geometry* testGeom) const;
diff --git a/include/geos/geom/prep/PreparedPolygonContains.h b/include/geos/geom/prep/PreparedPolygonContains.h
index c8fe743..6b1be77 100644
--- a/include/geos/geom/prep/PreparedPolygonContains.h
+++ b/include/geos/geom/prep/PreparedPolygonContains.h
@@ -74,7 +74,7 @@ public:
- * Computes the </tt>contains</tt> predicate between a {@link PreparedPolygon}
+ * Computes the <tt>contains</tt> predicate between a {@link PreparedPolygon}
* and a {@link Geometry}.
* @param prep the prepared polygon
diff --git a/include/geos/geom/prep/PreparedPolygonContainsProperly.h b/include/geos/geom/prep/PreparedPolygonContainsProperly.h
index 09a71e1..168e5d0 100644
--- a/include/geos/geom/prep/PreparedPolygonContainsProperly.h
+++ b/include/geos/geom/prep/PreparedPolygonContainsProperly.h
@@ -61,7 +61,7 @@ private:
protected:
public:
- * Computes the </tt>containsProperly</tt> predicate between a {@link PreparedPolygon}
+ * Computes the <tt>containsProperly</tt> predicate between a {@link PreparedPolygon}
@@ -79,7 +79,7 @@ public:
* Creates an instance of this operation.
- * @param prepPoly the PreparedPolygon to evaluate
+ * @param prep the PreparedPolygon to evaluate
PreparedPolygonContainsProperly(const PreparedPolygon* const prep)
: PreparedPolygonPredicate(prep)
diff --git a/include/geos/geom/prep/PreparedPolygonCovers.h b/include/geos/geom/prep/PreparedPolygonCovers.h
index 494e47b..b6613d0 100644
--- a/include/geos/geom/prep/PreparedPolygonCovers.h
+++ b/include/geos/geom/prep/PreparedPolygonCovers.h
@@ -66,7 +66,7 @@ protected:
public:
- * Computes the </tt>covers</tt> predicate between a {@link PreparedPolygon}
+ * Computes the <tt>covers</tt> predicate between a {@link PreparedPolygon}
@@ -83,7 +83,7 @@ public:
PreparedPolygonCovers(const PreparedPolygon* const prep)
: AbstractPreparedPolygonContains(prep, false)
diff --git a/include/geos/geom/prep/PreparedPolygonIntersects.h b/include/geos/geom/prep/PreparedPolygonIntersects.h
index c73f4cd..8c67672 100644
--- a/include/geos/geom/prep/PreparedPolygonIntersects.h
+++ b/include/geos/geom/prep/PreparedPolygonIntersects.h
PreparedPolygonIntersects(const PreparedPolygon* const prep)
diff --git a/include/geos/geom/prep/PreparedPolygonPredicate.h b/include/geos/geom/prep/PreparedPolygonPredicate.h
index bcc1812..d100ebe 100644
--- a/include/geos/geom/prep/PreparedPolygonPredicate.h
+++ b/include/geos/geom/prep/PreparedPolygonPredicate.h
@@ -69,7 +69,7 @@ protected:
* Handles both linear and point components.
- * @param geom a geometry to test
+ * @param testGeom a geometry to test
* @return true if all components of the argument are contained
* in the target geometry
@@ -81,7 +81,7 @@ protected:
* @return true if all componenta of the argument are contained in
* the target geometry interior
@@ -93,7 +93,7 @@ protected:
* Handles test geometries with both linear and point components.
* @return true if any component of the argument intersects the
* prepared geometry
@@ -105,7 +105,7 @@ protected:
* prepared area geometry interior
@@ -115,8 +115,8 @@ protected:
* Tests whether any component of the target geometry
* intersects the test geometry (which must be an areal geometry)
+ * @param targetRepPts the representative points of the target geometry
bool isAnyTargetComponentInAreaTest(const geom::Geometry* testGeom,
@@ -126,7 +126,7 @@ public:
+ * @param p_prepPoly the PreparedPolygon to evaluate
PreparedPolygonPredicate(const PreparedPolygon* const p_prepPoly)
: prepPoly(p_prepPoly)
diff --git a/include/geos/geomgraph/DirectedEdgeStar.h b/include/geos/geomgraph/DirectedEdgeStar.h
index fe1acec..c258ff8 100644
--- a/include/geos/geomgraph/DirectedEdgeStar.h
+++ b/include/geos/geomgraph/DirectedEdgeStar.h
@@ -132,8 +132,6 @@ public:
/** \brief
* Compute the DirectedEdge depths for a subsequence of the edge array.
- * @return the last depth assigned (from the R side of the last edge visited)
void computeDepths(DirectedEdge* de);
diff --git a/include/geos/geomgraph/EdgeEndStar.h b/include/geos/geomgraph/EdgeEndStar.h
index e376fe6..28dd076 100644
--- a/include/geos/geomgraph/EdgeEndStar.h
+++ b/include/geos/geomgraph/EdgeEndStar.h
virtual void insert(EdgeEnd* e) = 0;
- /** \brief
* @return the coordinate for the node this star is based at
* or NULL if this is still an unbound star.
* Be aware that the returned pointer will point to
diff --git a/include/geos/geomgraph/PlanarGraph.h b/include/geos/geomgraph/PlanarGraph.h
index b94d9ae..f22555b 100644
--- a/include/geos/geomgraph/PlanarGraph.h
+++ b/include/geos/geomgraph/PlanarGraph.h
@@ -124,7 +124,7 @@ public:
virtual Node* addNode(const geom::Coordinate& coord);
- /** \brief
* @return the node if found; null otherwise
virtual Node* find(geom::Coordinate& coord);
diff --git a/include/geos/geomgraph/Quadrant.h b/include/geos/geomgraph/Quadrant.h
index 9992071..8ed8a9c 100644
--- a/include/geos/geomgraph/Quadrant.h
+++ b/include/geos/geomgraph/Quadrant.h
@@ -42,7 +42,7 @@ namespace geomgraph { // geos.geomgraph
* 1 | 0
* 2 | 3
- * <pre>
+ * </pre>
class GEOS_DLL Quadrant {
diff --git a/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h b/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
index 3af6411..d475278 100644
--- a/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
+++ b/include/geos/index/intervalrtree/IntervalRTreeLeafNode.h
@@ -40,7 +40,7 @@ private:
protected:
public:
- /// @param item externally owned
+ /// @param p_item externally owned
IntervalRTreeLeafNode(double p_min, double p_max, void* p_item)
: IntervalRTreeNode(p_min, p_max),
item(p_item)
diff --git a/include/geos/index/quadtree/NodeBase.h b/include/geos/index/quadtree/NodeBase.h
index b306834..aefb4a9 100644
--- a/include/geos/index/quadtree/NodeBase.h
+++ b/include/geos/index/quadtree/NodeBase.h
@@ -93,7 +93,7 @@ public:
* Removes a single item from this subtree.
- * @param searchEnv the envelope containing the item
+ * @param itemEnv the envelope containing the item
* @param item the item to remove
* @return <code>true</code> if the item was found and removed
diff --git a/include/geos/linearref/LengthIndexOfPoint.h b/include/geos/linearref/LengthIndexOfPoint.h
index f640394..9e050e5 100644
--- a/include/geos/linearref/LengthIndexOfPoint.h
+++ b/include/geos/linearref/LengthIndexOfPoint.h
@@ -77,7 +77,7 @@ public:
* minLocation = [end of line] ).
* @param inputPt the coordinate to locate
- * @param minLocation the minimum location for the point location
+ * @param minIndex the minimum location for the point location
* @return the location of the nearest point
double indexOfAfter(const geom::Coordinate& inputPt, double minIndex) const;
diff --git a/include/geos/linearref/LengthIndexedLine.h b/include/geos/linearref/LengthIndexedLine.h
index 09ed091..ee0de1a 100644
--- a/include/geos/linearref/LengthIndexedLine.h
+++ b/include/geos/linearref/LengthIndexedLine.h
@@ -186,7 +186,7 @@ public:
* Tests whether an index is in the valid index range for the line.
- * @param length the index to test
+ * @param index the index to test
* @return <code>true</code> if the index is in the valid range
bool isValidIndex(double index) const;
diff --git a/include/geos/linearref/LinearGeometryBuilder.h b/include/geos/linearref/LinearGeometryBuilder.h
index ebc0bd8..0a7c0b4 100644
--- a/include/geos/linearref/LinearGeometryBuilder.h
+++ b/include/geos/linearref/LinearGeometryBuilder.h
@@ -61,8 +61,8 @@ public:
* Allows invalid lines to be ignored rather than causing Exceptions.
* An invalid line is one which has only one unique point.
- * @param ignoreShortLines <code>true</code> if short lines are
- * to be ignored
+ * @param ignoreInvalidLines <code>true</code> if short lines are
+ * to be ignored
void setIgnoreInvalidLines(bool ignoreInvalidLines);
@@ -70,8 +70,8 @@ public:
- * to be ignored
+ * @param fixInvalidLines <code>true</code> if short lines are
+ * to be ignored
void setFixInvalidLines(bool fixInvalidLines);
diff --git a/include/geos/linearref/LinearLocation.h b/include/geos/linearref/LinearLocation.h
index 2b9da08..3f8f77b 100644
--- a/include/geos/linearref/LinearLocation.h
+++ b/include/geos/linearref/LinearLocation.h
@@ -182,7 +182,7 @@ public:
* Compares this object with the specified object for order.
- *@param o the <code>LineStringLocation</code> with which this <code>Coordinate</code>
+ *@param other the <code>LineStringLocation</code> with which this <code>Coordinate</code>
* is being compared
*@return a negative integer, zero, or a positive integer as this <code>LineStringLocation</code>
* is less than, equal to, or greater than the specified <code>LineStringLocation</code>
diff --git a/include/geos/linearref/LocationIndexedLine.h b/include/geos/linearref/LocationIndexedLine.h
index 5b857f4..1dd90d6 100644
--- a/include/geos/linearref/LocationIndexedLine.h
+++ b/include/geos/linearref/LocationIndexedLine.h
@@ -248,7 +248,7 @@ public:
* \brief
bool
diff --git a/include/geos/noding/IntersectionFinderAdder.h b/include/geos/noding/IntersectionFinderAdder.h
index a828fd9..f18dec2 100644
--- a/include/geos/noding/IntersectionFinderAdder.h
+++ b/include/geos/noding/IntersectionFinderAdder.h
@@ -58,7 +58,7 @@ public:
* Creates an intersection finder which finds all proper intersections
* and stores them in the provided Coordinate array
- * @param li the LineIntersector to use
+ * @param newLi the LineIntersector to use
* @param v the Vector to push interior intersections to
IntersectionFinderAdder(algorithm::LineIntersector& newLi,
diff --git a/include/geos/noding/NodedSegmentString.h b/include/geos/noding/NodedSegmentString.h
index 46099b8..55eadc5 100644
--- a/include/geos/noding/NodedSegmentString.h
+++ b/include/geos/noding/NodedSegmentString.h
@@ -92,7 +92,7 @@ public:
* @param newPts CoordinateSequence representing the string,
* ownership transferred.
- * @param data the user-defined data of this segment string
+ * @param newContext the user-defined data of this segment string
* (may be null)
NodedSegmentString(geom::CoordinateSequence* newPts, const void* newContext)
diff --git a/include/geos/noding/NodingIntersectionFinder.h b/include/geos/noding/NodingIntersectionFinder.h
index 61ebc8c..dbf9471 100644
--- a/include/geos/noding/NodingIntersectionFinder.h
+++ b/include/geos/noding/NodingIntersectionFinder.h
@@ -52,7 +52,7 @@ public:
* Creates an intersection finder which finds an interior intersection
* if one exists
NodingIntersectionFinder(algorithm::LineIntersector& newLi)
@@ -106,7 +106,7 @@ public:
* It may be known that any potential noding failures will occur only in
* end segments.
- * @param isCheckEndSegmentsOnly whether to test only end segments
+ * @param isCESO whether to test only end segments
void
setCheckEndSegmentsOnly(bool isCESO)
diff --git a/include/geos/noding/SegmentNode.h b/include/geos/noding/SegmentNode.h
index 5b2bc47..ef2712e 100644
--- a/include/geos/noding/SegmentNode.h
+++ b/include/geos/noding/SegmentNode.h
@@ -38,10 +38,12 @@ class NodedSegmentString;
namespace geos {
namespace noding { // geos.noding
-/// Represents an intersection point between two NodedSegmentString.
-/// Final class.
+ * \brief
+ * Represents an intersection point between two NodedSegmentString.
+ * Final class.
class GEOS_DLL SegmentNode {
private:
const NodedSegmentString& segString;
@@ -67,7 +69,7 @@ public:
/// @param ss the parent NodedSegmentString
- /// @param coord the coordinate of the intersection, will be copied
+ /// @param nCoord the coordinate of the intersection, will be copied
/// @param nSegmentIndex the index of the segment on parent
/// NodedSegmentString
diff --git a/include/geos/noding/SegmentSetMutualIntersector.h b/include/geos/noding/SegmentSetMutualIntersector.h
index 3ef94f8..0da42e0 100644
--- a/include/geos/noding/SegmentSetMutualIntersector.h
+++ b/include/geos/noding/SegmentSetMutualIntersector.h
@@ -59,7 +59,7 @@ public:
- * @param segStrings0 a collection of {@link SegmentString}s to node
+ * @param segStrings a collection of {@link SegmentString}s to node
virtual void setBaseSegments(SegmentString::ConstVect* segStrings) = 0;
diff --git a/include/geos/noding/snapround/SimpleSnapRounder.h b/include/geos/noding/snapround/SimpleSnapRounder.h
index 121082b..f88fff8 100644
--- a/include/geos/noding/snapround/SimpleSnapRounder.h
+++ b/include/geos/noding/snapround/SimpleSnapRounder.h
@@ -120,7 +120,8 @@ private:
/** \brief
* Computes nodes introduced as a result of snapping segments to
* snap points (hot pixels)
- * @param li
+ * @param snapPts
void computeSnaps(const std::vector<SegmentString*>& segStrings,
std::vector<geom::Coordinate>& snapPts);
diff --git a/include/geos/operation/buffer/BufferOp.h b/include/geos/operation/buffer/BufferOp.h
index f7c0111..04cefca 100644
--- a/include/geos/operation/buffer/BufferOp.h
+++ b/include/geos/operation/buffer/BufferOp.h
@@ -54,7 +54,7 @@ namespace buffer { // geos.operation.buffer
* the Minkowski sum (or difference) of the geometry
* with a circle with radius equal to the absolute value of the buffer
* distance.
- * In the CAD/CAM world buffers are known as </i>offset curves</i>.
+ * In the CAD/CAM world buffers are known as <i>offset curves</i>.
* In morphological analysis the operation of positive and negative buffering
* is referred to as <i>erosion</i> and <i>dilation</i>.
@@ -196,16 +196,14 @@ public:
* The styles supported are CAP_ROUND, CAP_BUTT, and CAP_SQUARE.
* The default is CAP_ROUND.
- * @param endCapStyle the end cap style to specify
+ * @param nEndCapStyle the end cap style to specify
inline void setEndCapStyle(int nEndCapStyle);
- * Specifies the end cap style of the generated buffer.
- * The styles supported are CAP_ROUND, CAP_BUTT, and CAP_SQUARE.
- * The default is CAP_ROUND.
+ * Sets the number of segments used to approximate a angle fillet
+ * @param nQuadrantSegments the number of segments in a fillet for a quadrant
inline void setQuadrantSegments(int nQuadrantSegments);
@@ -235,8 +233,7 @@ public:
* Returns the buffer computed for a geometry for a given buffer
* distance.
- * @param g the geometry to buffer
- * @param distance the buffer distance
+ * @param nDistance the buffer distance
* @return the buffer of the input geometry
geom::Geometry* getResultGeometry(double nDistance);
diff --git a/include/geos/operation/buffer/BufferParameters.h b/include/geos/operation/buffer/BufferParameters.h
index 6592683..9f70690 100644
--- a/include/geos/operation/buffer/BufferParameters.h
+++ b/include/geos/operation/buffer/BufferParameters.h
@@ -166,8 +166,8 @@ public:
/// (in other words, the computed buffer curve is always inside
/// the true curve).
- /// @param quadrantSegments the number of segments in a
- /// fillet for a quadrant
+ /// @param quadSegs the number of segments in a
+ /// fillet for a quadrant
void setQuadrantSegments(int quadSegs);
@@ -275,7 +275,7 @@ public:
* always ignored,
* and forced to the equivalent of <tt>CAP_FLAT</tt>.
- * @param isSingleSided true if a single-sided buffer should be constructed
+ * @param p_isSingleSided true if a single-sided buffer should be constructed
void
setSingleSided(bool p_isSingleSided)
diff --git a/include/geos/operation/buffer/BufferSubgraph.h b/include/geos/operation/buffer/BufferSubgraph.h
index ed4872a..9e4c4e1 100644
--- a/include/geos/operation/buffer/BufferSubgraph.h
+++ b/include/geos/operation/buffer/BufferSubgraph.h
@@ -75,7 +75,7 @@ private:
* Uses an explicit stack to avoid a large depth of recursion.
- * @param node a node known to be in the subgraph
+ * @param startNode a node known to be in the subgraph
void addReachable(geomgraph::Node* startNode);
diff --git a/include/geos/operation/buffer/OffsetCurveBuilder.h b/include/geos/operation/buffer/OffsetCurveBuilder.h
index 684dcfd..7588e98 100644
--- a/include/geos/operation/buffer/OffsetCurveBuilder.h
+++ b/include/geos/operation/buffer/OffsetCurveBuilder.h
@@ -154,7 +154,7 @@ private:
* Computes the distance tolerance to use during input
* line simplification.
+ * @param bufDistance the buffer distance
* @return the simplification tolerance
double simplifyTolerance(double bufDistance);
diff --git a/include/geos/operation/buffer/OffsetCurveSetBuilder.h b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
index 5eba19c..751f6e4 100644
--- a/include/geos/operation/buffer/OffsetCurveSetBuilder.h
+++ b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
@@ -141,8 +141,8 @@ private:
* It may be degenerate (i.e. contain only 1, 2, or 3 points).
* In this case it has no area, and hence has a minimum diameter of 0.
- * @param ring
- * @param offsetDistance
+ * @param ringCoord
+ * @param bufferDistance
* @return
bool isErodedCompletely(const geom::LinearRing* ringCoord,
diff --git a/include/geos/operation/overlay/snap/LineStringSnapper.h b/include/geos/operation/overlay/snap/LineStringSnapper.h
index 58a07b4..7b675f0 100644
--- a/include/geos/operation/overlay/snap/LineStringSnapper.h
+++ b/include/geos/operation/overlay/snap/LineStringSnapper.h
@@ -57,7 +57,7 @@ public:
* as source points to be snapped.
* @param nSrcPts the points to snap
- * @param nSnapTolerance the snap tolerance to use
+ * @param nSnapTol the snap tolerance to use
LineStringSnapper(const geom::Coordinate::Vect& nSrcPts,
double nSnapTol)
diff --git a/include/geos/operation/overlay/validate/FuzzyPointLocator.h b/include/geos/operation/overlay/validate/FuzzyPointLocator.h
index 1215054..3d093cc 100644
--- a/include/geos/operation/overlay/validate/FuzzyPointLocator.h
+++ b/include/geos/operation/overlay/validate/FuzzyPointLocator.h
@@ -78,7 +78,7 @@ private:
/// Extracts linework for polygonal components.
- /// @param g the geometry from which to extract
+ /// @param geom the geometry from which to extract
/// @return a lineal geometry containing the extracted linework
std::unique_ptr<geom::Geometry> extractLineWork(const geom::Geometry& geom);
diff --git a/include/geos/operation/polygonize/EdgeRing.h b/include/geos/operation/polygonize/EdgeRing.h
index 0ef3b01..494ace1 100644
--- a/include/geos/operation/polygonize/EdgeRing.h
+++ b/include/geos/operation/polygonize/EdgeRing.h
@@ -174,6 +174,8 @@ public:
void build(PolygonizeDirectedEdge* startDE);
+ void computeHole();
/** \brief
* Tests whether this ring is a hole.
@@ -181,8 +183,6 @@ public:
* a ring is a hole if it is oriented counter-clockwise.
* @return <code>true</code> if this ring is a hole
- void computeHole();
bool isHole() const {
return is_hole;
@@ -217,7 +217,7 @@ public:
/** \brief
* Sets the containing shell ring of a ring that has been determined to be a hole.
- * @param shell the shell ring
+ * @param shellRing the shell ring
void setShell(EdgeRing* shellRing) {
shell = shellRing;
diff --git a/include/geos/operation/sharedpaths/SharedPathsOp.h b/include/geos/operation/sharedpaths/SharedPathsOp.h
index 3247352..accd293 100644
--- a/include/geos/operation/sharedpaths/SharedPathsOp.h
+++ b/include/geos/operation/sharedpaths/SharedPathsOp.h
@@ -75,12 +75,12 @@ public:
/// @param g2
/// Second geometry. Must be linear.
- /// @param sameDir
+ /// @param sameDirection
/// Shared edges having the same direction are pushed
/// onto this vector. They'll be of type LineString.
/// Ownership of the edges is tranferred.
- /// @param oppositeDir
+ /// @param oppositeDirection
/// Shared edges having the opposite direction are pushed
/// onto this vector. They'll be of type geom::LineString.
@@ -102,12 +102,12 @@ public:
/// Get shared paths
diff --git a/include/geos/operation/valid/ConsistentAreaTester.h b/include/geos/operation/valid/ConsistentAreaTester.h
index ac31408..e596e2e 100644
--- a/include/geos/operation/valid/ConsistentAreaTester.h
+++ b/include/geos/operation/valid/ConsistentAreaTester.h
@@ -46,20 +46,6 @@ namespace operation { // geos::operation
namespace valid { // geos::operation::valid
/** \brief
- * Checks that a {@link geomgraph::GeometryGraph} representing an area
- * (a {@link Polygon} or {@link MultiPolygon} )
- * is consistent with the OGC-SFS semantics for area geometries.
- * Checks include:
- * - testing for rings which self-intersect (both properly
- * and at nodes)
- * - testing for duplicate rings
- * If an inconsistency if found the location of the problem
- * is recorded.
-/** \brief
* Checks that a geomgraph::GeometryGraph representing an area
* (a geom::Polygon or geom::MultiPolygon)
* has consistent semantics for area geometries.
diff --git a/include/geos/operation/valid/IsValidOp.h b/include/geos/operation/valid/IsValidOp.h
index a4e3762..95795ab 100644
--- a/include/geos/operation/valid/IsValidOp.h
+++ b/include/geos/operation/valid/IsValidOp.h
@@ -264,7 +264,7 @@ public:
* and "C-shaped" holes which self-touch at a single point causing
* an island to be formed.
- * @param isValid states whether geometry with this condition is valid
+ * @param p_isValid states whether geometry with this condition is valid
void
setSelfTouchingRingFormingHoleValid(bool p_isValid)
diff --git a/include/geos/planargraph/DirectedEdge.h b/include/geos/planargraph/DirectedEdge.h
index cb08f3b..98db535 100644
--- a/include/geos/planargraph/DirectedEdge.h
+++ b/include/geos/planargraph/DirectedEdge.h
@@ -96,11 +96,11 @@ public:
* @param directionPt specifies this DirectedEdge's direction
* (given by an imaginary line from the
- * <code>from</code> node to
- * <code>directionPt</code>)
- * @param edgeDirection whether this DirectedEdge's direction
- * is the same as or opposite to that of the
- * parent Edge (if any)
+ * <code>from</code> node to
+ * <code>directionPt</code>)
+ * @param newEdgeDirection whether this DirectedEdge's direction
+ * is the same as or opposite to that of the
+ * parent Edge (if any)
DirectedEdge(Node* newFrom, Node* newTo,
const geom::Coordinate& directionPt,
diff --git a/include/geos/planargraph/GraphComponent.h b/include/geos/planargraph/GraphComponent.h
index 675ef5d..9583187 100644
--- a/include/geos/planargraph/GraphComponent.h
+++ b/include/geos/planargraph/GraphComponent.h
@@ -78,7 +78,7 @@ public:
/** \brief
* Sets the visited flag for this component.
- * @param isVisited the desired value of the visited flag
+ * @param p_isVisited the desired value of the visited flag
virtual void
setVisited(bool p_isVisited)
@@ -168,7 +168,7 @@ public:
/** \brief
* Sets the marked flag for this component.
- * @param isMarked the desired value of the marked flag
+ * @param p_isMarked the desired value of the marked flag
virtual void
setMarked(bool p_isMarked)
diff --git a/include/geos/planargraph/PlanarGraph.h b/include/geos/planargraph/PlanarGraph.h
index 2172c11..2001948 100644
--- a/include/geos/planargraph/PlanarGraph.h
+++ b/include/geos/planargraph/PlanarGraph.h
@@ -72,7 +72,6 @@ protected:
* Only subclasses can add Nodes, to ensure Nodes are
* of the right type.
- * @return the added node
void
add(Node* node)
diff --git a/include/geos/precision/CommonBits.h b/include/geos/precision/CommonBits.h
index 4ffe9c9..60954a0 100644
--- a/include/geos/precision/CommonBits.h
+++ b/include/geos/precision/CommonBits.h
@@ -61,7 +61,8 @@ public:
* It does not determine whether the numbers have the same
* exponent - if they do not, the value computed by this
* function is meaningless.
- * @param db
+ * @param num1
+ * @param num2
* @return the number of common most-significant mantissa bits
static int numCommonMostSigMantissaBits(int64 num1, int64 num2);
@@ -70,7 +71,7 @@ public:
* Zeroes the lower n bits of a bitstring.
* @param bits the bitstring to alter
- * @param i the number of bits to zero
+ * @param nBits the number of bits to zero
* @return the zeroed bitstring
static int64 zeroLowerBits(int64 bits, int nBits);
diff --git a/include/geos/precision/EnhancedPrecisionOp.h b/include/geos/precision/EnhancedPrecisionOp.h
index 6860be8..806535d 100644
--- a/include/geos/precision/EnhancedPrecisionOp.h
+++ b/include/geos/precision/EnhancedPrecisionOp.h
@@ -91,7 +91,7 @@ public:
* This method should no longer be necessary, since the buffer
* algorithm now is highly robust.
- * @param geom0 the first Geometry
+ * @param geom the first Geometry
* @return the Geometry representing the buffer of the input Geometry.
diff --git a/include/geos/precision/SimpleGeometryPrecisionReducer.h b/include/geos/precision/SimpleGeometryPrecisionReducer.h
index 83e1367..982d38a 100644
--- a/include/geos/precision/SimpleGeometryPrecisionReducer.h
+++ b/include/geos/precision/SimpleGeometryPrecisionReducer.h
* being removed completely, or simply being collapsed to an (invalid)
* Geometry of the same type.
- * @param removeCollapsed if <code>true</code> collapsed
+ * @param nRemoveCollapsed if <code>true</code> collapsed
* components will be removed
void setRemoveCollapsedComponents(bool nRemoveCollapsed);
diff --git a/include/geos/simplify/DouglasPeuckerSimplifier.h b/include/geos/simplify/DouglasPeuckerSimplifier.h
index 0190072..669f8a6 100644
--- a/include/geos/simplify/DouglasPeuckerSimplifier.h
+++ b/include/geos/simplify/DouglasPeuckerSimplifier.h
@@ -65,7 +65,7 @@ public:
* The tolerance value must be non-negative. A tolerance value
* of zero is effectively a no-op.
- * @param distanceTolerance the approximation tolerance to use
+ * @param tolerance the approximation tolerance to use
void setDistanceTolerance(double tolerance);
diff --git a/include/geos/simplify/TaggedLineStringSimplifier.h b/include/geos/simplify/TaggedLineStringSimplifier.h
index b1166f5..32188d0 100644
--- a/include/geos/simplify/TaggedLineStringSimplifier.h
+++ b/include/geos/simplify/TaggedLineStringSimplifier.h
@@ -130,7 +130,7 @@ private:
/** \brief
* Tests whether a segment is in a section of a TaggedLineString
- * @param line
+ * @param parentLine
* @param sectionIndex
* @param seg
* @return
@@ -144,9 +144,8 @@ private:
* Remove the segs in the section of the line
* @param line
- * @param pts
- * @param sectionStartIndex
- * @param sectionEndIndex
+ * @param start
+ * @param end
void remove(const TaggedLineString* line,
std::size_t start,
diff --git a/include/geos/simplify/TopologyPreservingSimplifier.h b/include/geos/simplify/TopologyPreservingSimplifier.h
index afba135..3cc8308 100644
--- a/include/geos/simplify/TopologyPreservingSimplifier.h
+++ b/include/geos/simplify/TopologyPreservingSimplifier.h
@@ -38,7 +38,6 @@ namespace geos {
namespace simplify { // geos::simplify
/** \brief
* Simplifies a geometry, ensuring that
* the result is a valid geometry having the
* same dimension and number of components as the input.
@@ -73,7 +72,7 @@ public:
diff --git a/include/geos/triangulate/DelaunayTriangulationBuilder.h b/include/geos/triangulate/DelaunayTriangulationBuilder.h
index aaedfc1..e39e9bf 100644
--- a/include/geos/triangulate/DelaunayTriangulationBuilder.h
+++ b/include/geos/triangulate/DelaunayTriangulationBuilder.h
@@ -110,7 +110,7 @@ public:
* to improved the robustness of the triangulation computation.
* A tolerance of 0.0 specifies that no snapping will take place.
- * @param tolerance the tolerance distance to use
+ * @param p_tolerance the tolerance distance to use
inline void
setTolerance(double p_tolerance)
diff --git a/include/geos/triangulate/quadedge/QuadEdge.h b/include/geos/triangulate/quadedge/QuadEdge.h
index 0dd0de1..0ed90b9 100644
--- a/include/geos/triangulate/quadedge/QuadEdge.h
+++ b/include/geos/triangulate/quadedge/QuadEdge.h
@@ -53,12 +53,10 @@ public:
* Creates a new QuadEdge quartet from {@link Vertex} o to {@link Vertex} d.
- * @param o
- * the origin Vertex
- * @param d
- * the destination Vertex
+ * @param o the origin Vertex
+ * @param d the destination Vertex
* @return the new QuadEdge* The caller is reponsible for
- * freeing the returned pointer
+ * freeing the returned pointer
static std::unique_ptr<QuadEdge> makeEdge(const Vertex& o, const Vertex& d);
@@ -171,7 +169,7 @@ public:
* Sets the connected edge
- * @param nextEdge edge
+ * @param p_next edge
inline void
setNext(QuadEdge* p_next)
diff --git a/include/geos/triangulate/quadedge/TrianglePredicate.h b/include/geos/triangulate/quadedge/TrianglePredicate.h
index 2218f43..f045be0 100644
--- a/include/geos/triangulate/quadedge/TrianglePredicate.h
+++ b/include/geos/triangulate/quadedge/TrianglePredicate.h
@@ -49,7 +49,7 @@ public:
* @param a a vertex of the triangle
* @param b a vertex of the triangle
* @param c a vertex of the triangle
- * @param P the point to test
+ * @param p the point to test
* @return true if this point is inside the circle defined by the points a, b, c
static bool isInCircleNonRobust(
@@ -70,7 +70,7 @@ public:
static bool isInCircleNormalized(
@@ -98,7 +98,7 @@ public:
static bool isInCircleRobust(
diff --git a/include/geos/triangulate/quadedge/Vertex.h b/include/geos/triangulate/quadedge/Vertex.h
index 9b98c1b..b9137a3 100644
--- a/include/geos/triangulate/quadedge/Vertex.h
+++ b/include/geos/triangulate/quadedge/Vertex.h
@@ -145,7 +145,7 @@ public:
* Computes the inner or dot product
- * @param v, a vertex
+ * @param v a vertex
* @return returns the dot product u.v
inline double
@@ -157,7 +157,7 @@ public:
* Computes the scalar product c(v)
+ * @param c scaling factor
* @return returns the scaled vector
inline std::unique_ptr<Vertex>
diff --git a/include/geos/util/GeometricShapeFactory.h b/include/geos/util/GeometricShapeFactory.h
index b6f0ded..c8631ed 100644
--- a/include/geos/util/GeometricShapeFactory.h
+++ b/include/geos/util/GeometricShapeFactory.h
@@ -95,10 +95,8 @@ public:
* Create a shape factory which will create shapes using the given
* GeometryFactory.
- * @param factory the factory to use. You need to keep the
- * factory alive for the whole GeometricShapeFactory
- * life time.
+ * @param factory the factory to use. You need to keep the factory
+ * alive for the whole GeometricShapeFactory life time.
GeometricShapeFactory(const geom::GeometryFactory* factory);
@@ -124,7 +122,7 @@ public:
* the ellipse.
* @param startAng start angle in radians
- * @param angExtent size of angle in radians
+ * @param angExt size of angle in radians
* @return an elliptical arc polygon
geom::Polygon* createArcPolygon(double startAng, double angExt);
diff --git a/src/operation/buffer/SubgraphDepthLocater.cpp b/src/operation/buffer/SubgraphDepthLocater.cpp
index 496117a..94d06e4 100644
--- a/src/operation/buffer/SubgraphDepthLocater.cpp
+++ b/src/operation/buffer/SubgraphDepthLocater.cpp
@@ -101,7 +101,7 @@ public:
* DS1 > DS2 if DS1.seg is right of DS2.seg
* </pre>
- * @param obj
+ * @param other
* @return
int
diff --git a/src/operation/polygonize/PolygonizeDirectedEdge.cpp b/src/operation/polygonize/PolygonizeDirectedEdge.cpp
index bfc2d78..92e2bc5 100644
--- a/src/operation/polygonize/PolygonizeDirectedEdge.cpp
+++ b/src/operation/polygonize/PolygonizeDirectedEdge.cpp
@@ -30,11 +30,11 @@ namespace polygonize { // geos.operation.polygonize
* Constructs a directed edge connecting the <code>from</code> node to the
* <code>to</code> node.
- * @param directionPt
+ * @param newDirectionPt
* specifies this DirectedEdge's direction (given by an imaginary
* line from the <code>from</code> node to <code>directionPt</code>)
+ * @param nEdgeDirection
* whether this DirectedEdge's direction is the same as or
* opposite to that of the parent Edge (if any)
diff --git a/src/operation/predicate/RectangleIntersects.cpp b/src/operation/predicate/RectangleIntersects.cpp
index e4dd758..7736f1e 100644
--- a/src/operation/predicate/RectangleIntersects.cpp
+++ b/src/operation/predicate/RectangleIntersects.cpp
@@ -56,13 +56,6 @@ private:
protected:
- * Reports whether it can be concluded that an intersection occurs,
- * or whether further testing is required.
- * @return <code>true</code> if an intersection must occur
- * <code>false</code> if no conclusion can be made
void
visit(const geom::Geometry& element) override
diff --git a/src/simplify/TopologyPreservingSimplifier.cpp b/src/simplify/TopologyPreservingSimplifier.cpp
index 4e9b8bc..61885aa 100644
--- a/src/simplify/TopologyPreservingSimplifier.cpp
+++ b/src/simplify/TopologyPreservingSimplifier.cpp
* User's constructor.
- * @param nMap - reference to LinesMap instance.
+ * @param simp - reference to LinesMap instance.
LineStringTransformer(LinesMap& simp);
Summary of changes:
include/geos/algorithm/Distance.h | 2 +-
include/geos/algorithm/Length.h | 2 +-
include/geos/algorithm/LineIntersector.h | 4 +--
include/geos/algorithm/MinimumDiameter.h | 4 +--
include/geos/geom/CoordinateList.h | 2 +-
include/geos/geom/CoordinateSequence.h | 32 +++++++++-------------
include/geos/geom/Envelope.h | 5 ++--
include/geos/geom/Geometry.h | 2 +-
include/geos/geom/GeometryFactory.h | 9 +++---
include/geos/geom/LineSegment.h | 10 +++----
include/geos/geom/Location.h | 1 -
include/geos/geom/PrecisionModel.h | 9 +++---
include/geos/geom/prep/BasicPreparedGeometry.h | 9 +++---
.../geos/geom/prep/PreparedLineStringIntersects.h | 4 +--
include/geos/geom/prep/PreparedPolygonContains.h | 2 +-
.../geom/prep/PreparedPolygonContainsProperly.h | 4 +--
include/geos/geom/prep/PreparedPolygonCovers.h | 4 +--
include/geos/geom/prep/PreparedPolygonIntersects.h | 2 +-
include/geos/geom/prep/PreparedPolygonPredicate.h | 14 +++++-----
include/geos/geomgraph/DirectedEdgeStar.h | 2 --
include/geos/geomgraph/EdgeEndStar.h | 2 +-
include/geos/geomgraph/PlanarGraph.h | 2 +-
include/geos/geomgraph/Quadrant.h | 2 +-
.../index/intervalrtree/IntervalRTreeLeafNode.h | 2 +-
include/geos/index/quadtree/NodeBase.h | 2 +-
include/geos/linearref/LengthIndexOfPoint.h | 2 +-
include/geos/linearref/LengthIndexedLine.h | 2 +-
include/geos/linearref/LinearGeometryBuilder.h | 8 +++---
include/geos/linearref/LinearLocation.h | 2 +-
include/geos/linearref/LocationIndexedLine.h | 2 +-
include/geos/noding/IntersectionFinderAdder.h | 2 +-
include/geos/noding/NodedSegmentString.h | 2 +-
include/geos/noding/NodingIntersectionFinder.h | 4 +--
include/geos/noding/SegmentNode.h | 12 ++++----
include/geos/noding/SegmentSetMutualIntersector.h | 2 +-
include/geos/noding/snapround/SimpleSnapRounder.h | 3 +-
include/geos/operation/buffer/BufferOp.h | 13 ++++-----
include/geos/operation/buffer/BufferParameters.h | 6 ++--
include/geos/operation/buffer/BufferSubgraph.h | 2 +-
include/geos/operation/buffer/OffsetCurveBuilder.h | 2 +-
.../geos/operation/buffer/OffsetCurveSetBuilder.h | 4 +--
.../operation/overlay/snap/LineStringSnapper.h | 2 +-
.../operation/overlay/validate/FuzzyPointLocator.h | 2 +-
include/geos/operation/polygonize/EdgeRing.h | 6 ++--
include/geos/operation/sharedpaths/SharedPathsOp.h | 8 +++---
.../geos/operation/valid/ConsistentAreaTester.h | 14 ----------
include/geos/operation/valid/IsValidOp.h | 2 +-
include/geos/planargraph/DirectedEdge.h | 10 +++----
include/geos/planargraph/GraphComponent.h | 4 +--
include/geos/planargraph/PlanarGraph.h | 1 -
include/geos/precision/CommonBits.h | 5 ++--
include/geos/precision/EnhancedPrecisionOp.h | 2 +-
.../precision/SimpleGeometryPrecisionReducer.h | 2 +-
include/geos/simplify/DouglasPeuckerSimplifier.h | 2 +-
include/geos/simplify/TaggedLineStringSimplifier.h | 7 ++---
.../geos/simplify/TopologyPreservingSimplifier.h | 3 +-
.../triangulate/DelaunayTriangulationBuilder.h | 2 +-
include/geos/triangulate/quadedge/QuadEdge.h | 10 +++----
.../geos/triangulate/quadedge/TrianglePredicate.h | 6 ++--
include/geos/triangulate/quadedge/Vertex.h | 4 +--
include/geos/util/GeometricShapeFactory.h | 8 ++----
src/operation/buffer/SubgraphDepthLocater.cpp | 2 +-
.../polygonize/PolygonizeDirectedEdge.cpp | 4 +--
src/operation/predicate/RectangleIntersects.cpp | 7 -----
src/simplify/TopologyPreservingSimplifier.cpp | 2 +-
65 files changed, 138 insertions(+), 178 deletions(-)
hooks/post-receive
More information about the geos-commits
