[geos-commits] [SCM] GEOS branch master updated. 2036448ae9ef15ef026ff5b5bb6acbff119c75c3
git at osgeo.org
git at osgeo.org
Tue Oct 1 16:06:09 PDT 2019
the project "GEOS".
via 2036448ae9ef15ef026ff5b5bb6acbff119c75c3 (commit)
from ff05d9755d189771147acb3105bd9c9cfff730ff (commit)
revisions in full, below.
commit 2036448ae9ef15ef026ff5b5bb6acbff119c75c3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Oct 1 16:05:31 2019 -0700
Add trimmed down test case on Voronoi.
Curiously, this case blows an exception on PostGIS, but not in the unit test.
References #859
diff --git a/tests/unit/capi/GEOSVoronoiDiagramTest.cpp b/tests/unit/capi/GEOSVoronoiDiagramTest.cpp
index 9bc5ec7..91808a5 100644
--- a/tests/unit/capi/GEOSVoronoiDiagramTest.cpp
+++ b/tests/unit/capi/GEOSVoronoiDiagramTest.cpp
@@ -183,5 +183,17 @@ void object::test<6>
"MULTILINESTRING ((-14 376.5882352941176, 172.3651328095773 261.4803591470258), (172.3651328095773 261.4803591470258, 56.63157894736844 73), (172.3651328095773 261.4803591470258, 200.6640625 265.6015625), (200.6640625 265.6015625, 201 265.4), (201 265.4, 210 251), (210 251, 210 73), (208.04 450, 200.6640625 265.6015625), (397 343.8, 201 265.4), (210 251, 397 176.2))"
+template<>
+template<>
+void object::test<7>
+ /* https://trac.osgeo.org/geos/ticket/859 */
+ std::string hex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
+ geom1_ = GEOSGeomFromHEX_buf((const unsigned char*)(hex.c_str()), hex.length());
+ geom2_ = GEOSVoronoiDiagram(geom1_, nullptr, 0, 1);
} // namespace tut
Summary of changes:
tests/unit/capi/GEOSVoronoiDiagramTest.cpp | 12 ++++++++++++
1 file changed, 12 insertions(+)
hooks/post-receive
More information about the geos-commits
