[geos-commits] [SCM] GEOS branch master updated. 3a9ce5422c929b5adbae3f2a59d391937600c82a
git at osgeo.org
git at osgeo.org
Tue Oct 8 06:56:45 PDT 2019
the project "GEOS".
via 3a9ce5422c929b5adbae3f2a59d391937600c82a (commit)
from b54786f9e1a4538c23a5145064fd51570ff7507a (commit)
revisions in full, below.
commit 3a9ce5422c929b5adbae3f2a59d391937600c82a
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Oct 8 09:56:22 2019 -0400
Avoid accessing pointer after move
Fixes #994
diff --git a/src/operation/union/OverlapUnion.cpp b/src/operation/union/OverlapUnion.cpp
index 39ab438..8f21660 100644
--- a/src/operation/union/OverlapUnion.cpp
+++ b/src/operation/union/OverlapUnion.cpp
@@ -124,12 +124,12 @@ OverlapUnion::unionFull(const Geometry* geom0, const Geometry* geom1)
std::unique_ptr<Geometry>
OverlapUnion::unionBuffer(const Geometry* geom0, const Geometry* geom1)
+ const GeometryFactory* factory = geom0->getFactory();
std::unique_ptr<Geometry> copy0 = geom0->clone();
std::unique_ptr<Geometry> copy1 = geom1->clone();
std::vector<std::unique_ptr<Geometry>> geoms;
geoms.push_back(std::move(copy0));
geoms.push_back(std::move(copy1));
- const GeometryFactory* factory = copy0->getFactory();
std::unique_ptr<GeometryCollection> gColl(factory->createGeometryCollection(std::move(geoms)));
return gColl->buffer(0.0);
diff --git a/tests/xmltester/tests/issue/issue-geos-994.xml b/tests/xmltester/tests/issue/issue-geos-994.xml
new file mode 100644
index 0000000..49d2c92
--- /dev/null
+++ b/tests/xmltester/tests/issue/issue-geos-994.xml
@@ -0,0 +1,171 @@
+<run>
+<precisionModel type="FLOATING" />
+<case>
+<desc>
+Unary union test from QGIS test suite
+</desc>
+<a>
+GEOMETRYCOLLECTION (MULTIPOLYGON (((1756184.5450235498137772 5080652.1657676175236702, 1756184.5450235498137772
+ 5080614.4680011207237840, 1756123.0812665277626365 5080614.4680011207237840,
+ 1756123.0812665277626365 5080430.0767300482839346, 1756061.6175095040816814 5080430.0767300482839346,
+ 1756061.6175095040816814 5080491.5404870714992285, 1756000.1537524810992181 5080491.5404870714992285,
+ 1756000.1537524810992181 5080653.7726632226258516, 1756184.5450235498137772 5080652.1657676175236702))),
+ MULTIPOLYGON (((1756000.1537524810992181 5080491.5404870714992285,
+ 1756061.6175095040816814 5080491.5404870714992285, 1756061.6175095040816814 5080430.0767300482839346,
+ 1756000.1537524810992181 5080430.0767300482839346, 1756000.1537524810992181 5080491.5404870714992285))),
+ MULTIPOLYGON (((1756184.5450235498137772 5080307.1492160055786371,
+ 1756246.0087805732619017 5080307.1492160055786371, 1756246.0087805732619017 5080245.6854589805006981,
+ 1756184.5450235498137772 5080245.6854589805006981, 1756184.5450235498137772 5080307.1492160055786371))),
+ MULTIPOLYGON (((1756491.8638086654245853 5080061.2941879099234939,
+ 1756614.7913227111566812 5080061.2941879099234939, 1756614.7913227111566812 5079938.3666738653555512,
+ 1756491.8638086654245853 5079938.3666738653555512, 1756491.8638086654245853 5080061.2941879099234939))),
+ MULTIPOLYGON (((1755508.4436962972395122 5079938.3666738653555512,
+ 1755569.9074533204548061 5079938.3666738653555512, 1755569.9074533204548061 5079876.9029168421402574,
+ 1755508.4436962972395122 5079876.9029168421402574, 1755508.4436962972395122 5079938.3666738653555512))),
+ MULTIPOLYGON (((1755692.8349673661869019 5079938.3666738653555512,
+ 1755754.2987243889365345 5079938.3666738653555512, 1755754.2987243889365345 5079876.9029168421402574,
+ 1755692.8349673661869019 5079876.9029168421402574, 1755692.8349673661869019 5079938.3666738653555512))),
+ MULTIPOLYGON (((1755569.9074533204548061 5079876.9029168421402574,
+ 1755631.3712103427387774 5079876.9029168421402574, 1755631.3712103427387774 5079753.9754027975723147,
+ 1755569.9074533204548061 5079753.9754027975723147, 1755569.9074533204548061 5079876.9029168421402574))),
+ MULTIPOLYGON (((1755938.6899954585824162 5080122.7579449350014329,
+ 1756123.0812665277626365 5080122.7579449350014329, 1756123.0812665277626365 5079876.9029168421402574,
+ 1756061.6175095040816814 5079876.9029168421402574, 1756061.6175095040816814 5079631.0478887520730495,
+ 1755815.7624814116861671 5079631.0478887520730495, 1755815.7624814116861671 5079938.3666738653555512,
+ 1755877.2262384353671223 5079938.3666738653555512, 1755938.6899954585824162 5079938.3666738653555512,
+ 1755938.6899954585824162 5080122.7579449350014329))),
+ MULTIPOLYGON (((1756246.0087805732619017 5079938.3666738653555512,
+ 1756307.4725375962443650 5079938.3666738653555512, 1756307.4725375962443650 5079753.9754027975723147,
+ 1756368.9362946192268282 5079753.9754027975723147, 1756368.9362946192268282 5079569.5841317288577557,
+ 1756307.4725375962443650 5079569.5841317288577557, 1756184.5450235498137772 5079569.5841317288577557,
+ 1756184.5450235498137772 5079753.9754027975723147, 1756246.0087805732619017 5079753.9754027975723147,
+ 1756246.0087805732619017 5079938.3666738653555512))),
+ MULTIPOLYGON (((1756614.7913227111566812 5079631.0478887520730495,
+ 1756676.2550797339063138 5079631.0478887520730495, 1756676.2550797339063138 5079569.5841317288577557,
+ 1756614.7913227111566812 5079569.5841317288577557, 1756614.7913227111566812 5079631.0478887520730495))),
+ MULTIPOLYGON (((1756553.3275656879413873 5079569.5841317288577557,
+ 1756614.7913227111566812 5079569.5841317288577557, 1756614.7913227111566812 5079446.6566176833584905,
+ 1756553.3275656879413873 5079446.6566176833584905, 1756553.3275656879413873 5079569.5841317288577557))),
+ MULTIPOLYGON (((1756676.2550797339063138 5079569.5841317288577557,
+ 1756737.7188367566559464 5079569.5841317288577557, 1756737.7188367566559464 5079446.6566176833584905,
+ 1756676.2550797339063138 5079446.6566176833584905, 1756676.2550797339063138 5079569.5841317288577557))),
+ MULTIPOLYGON (((1756000.1537524810992181 5079385.1928606573492289,
+ 1756061.6175095040816814 5079385.1928606573492289, 1756061.6175095040816814 5079262.2653466118499637,
+ 1756000.1537524810992181 5079262.2653466118499637, 1756000.1537524810992181 5079385.1928606573492289))),
+ MULTIPOLYGON (((1756491.8638086654245853 5079262.2653466118499637,
+ 1756553.3275656879413873 5079262.2653466118499637, 1756553.3275656879413873 5079200.8015895904973149,
+ 1756491.8638086654245853 5079200.8015895904973149, 1756491.8638086654245853 5079262.2653466118499637))),
+ MULTIPOLYGON (((1756000.1537524810992181 5079077.8740755440667272,
+ 1756061.6175095040816814 5079077.8740755440667272, 1756061.6175095040816814 5079016.4103185208514333,
+ 1756000.1537524810992181 5079016.4103185208514333, 1756000.1537524810992181 5079077.8740755440667272))),
+ MULTIPOLYGON (((1757045.0376218727324158 5078832.0190474493429065,
+ 1757106.5013788954820484 5078832.0190474493429065, 1757106.5013788954820484 5078709.0915334057062864,
+ 1757045.0376218727324158 5078709.0915334057062864, 1757045.0376218727324158 5078832.0190474493429065))),
+ MULTIPOLYGON (((1756246.0087805732619017 5078832.0190474493429065,
+ 1756307.4725375962443650 5078832.0190474493429065, 1756307.4725375962443650 5078709.0915334057062864,
+ 1756368.9362946192268282 5078709.0915334057062864, 1756368.9362946192268282 5078697.1378769595175982,
+ 1756061.6175095040816814 5078704.4868044294416904, 1756061.6175095040816814 5078709.0915334057062864,
+ 1756184.5450235498137772 5078709.0915334057062864, 1756246.0087805732619017 5078709.0915334057062864,
+ 1756246.0087805732619017 5078832.0190474493429065))),
+ MULTIPOLYGON (((1755877.2262384353671223 5080654.8439269624650478,
+ 1755877.2262384353671223 5080491.5404870714992285, 1756000.1537524810992181 5080491.5404870714992285,
+ 1756000.1537524810992181 5080430.0767300482839346, 1756061.6175095040816814 5080430.0767300482839346,
+ 1756061.6175095040816814 5080307.1492160055786371, 1756000.1537524810992181 5080307.1492160055786371,
+ 1756000.1537524810992181 5080245.6854589805006981, 1756123.0812665277626365 5080245.6854589805006981,
+ 1756123.0812665277626365 5080122.7579449350014329, 1756061.6175095040816814 5080122.7579449350014329,
+ 1755938.6899954585824162 5080122.7579449350014329, 1755938.6899954585824162 5079938.3666738653555512,
+ 1755877.2262384353671223 5079938.3666738653555512, 1755815.7624814116861671 5079938.3666738653555512,
+ 1755815.7624814116861671 5079631.0478887520730495, 1756061.6175095040816814 5079631.0478887520730495,
+ 1756061.6175095040816814 5079876.9029168421402574, 1756123.0812665277626365 5079876.9029168421402574,
+ 1756123.0812665277626365 5080122.7579449350014329, 1756307.4725375962443650 5080122.7579449350014329,
+ 1756307.4725375962443650 5080061.2941879099234939, 1756430.4000516426749527 5080061.2941879099234939,
+ 1756430.4000516426749527 5079876.9029168421402574, 1756553.3275656879413873 5079876.9029168421402574,
+ 1756553.3275656879413873 5079631.0478887520730495, 1756491.8638086654245853 5079631.0478887520730495,
+ 1756491.8638086654245853 5079446.6566176833584905, 1756430.4000516426749527 5079446.6566176833584905,
+ 1756246.0087805732619017 5079446.6566176833584905, 1756246.0087805732619017 5079200.8015895904973149,
+ 1756184.5450235498137772 5079200.8015895904973149, 1756123.0812665277626365 5079200.8015895904973149,
+ 1756123.0812665277626365 5079077.8740755440667272, 1756184.5450235498137772 5079077.8740755440667272,
+ 1756184.5450235498137772 5079016.4103185208514333, 1756307.4725375962443650 5079016.4103185208514333,
+ 1756307.4725375962443650 5078893.4828044744208455, 1756246.0087805732619017 5078893.4828044744208455,
+ 1756246.0087805732619017 5078832.0190474493429065, 1756123.0812665277626365 5078832.0190474493429065,
+ 1756123.0812665277626365 5078893.4828044744208455, 1756000.1537524810992181 5078893.4828044744208455,
+ 1756000.1537524810992181 5078832.0190474493429065, 1755938.6899954585824162 5078832.0190474493429065,
+ 1755877.2262384353671223 5078832.0190474493429065, 1755877.2262384353671223 5078709.0915334057062864,
+ 1756000.1537524810992181 5078709.0915334057062864, 1756000.1537524810992181 5078705.9565899241715670,
+ 1754455.4951298737432808 5078742.8940787250176072, 1754447.7975028993096203 5080667.3008222607895732,
+ 1755877.2262384353671223 5080654.8439269624650478),
+ (1756184.5450235498137772 5079753.9754027975723147, 1756184.5450235498137772 5079569.5841317288577557,
+ 1756307.4725375962443650 5079569.5841317288577557, 1756368.9362946192268282 5079569.5841317288577557,
+ 1756368.9362946192268282 5079753.9754027975723147, 1756307.4725375962443650 5079753.9754027975723147,
+ 1756307.4725375962443650 5079938.3666738653555512, 1756246.0087805732619017 5079938.3666738653555512,
+ 1756246.0087805732619017 5079753.9754027975723147, 1756184.5450235498137772 5079753.9754027975723147),
+ (1755508.4436962972395122 5079938.3666738653555512, 1755508.4436962972395122 5079876.9029168421402574,
+ 1755569.9074533204548061 5079876.9029168421402574, 1755569.9074533204548061 5079753.9754027975723147,
+ 1755631.3712103427387774 5079753.9754027975723147, 1755631.3712103427387774 5079876.9029168421402574,
+ 1755569.9074533204548061 5079876.9029168421402574, 1755569.9074533204548061 5079938.3666738653555512,
+ 1755508.4436962972395122 5079938.3666738653555512), (1756000.1537524810992181 5079385.1928606573492289,
+ 1756000.1537524810992181 5079262.2653466118499637, 1756061.6175095040816814 5079262.2653466118499637,
+ 1756061.6175095040816814 5079385.1928606573492289, 1756000.1537524810992181 5079385.1928606573492289),
+ (1755692.8349673661869019 5079938.3666738653555512, 1755692.8349673661869019 5079876.9029168421402574,
+ 1755754.2987243889365345 5079876.9029168421402574, 1755754.2987243889365345 5079938.3666738653555512,
+ 1755692.8349673661869019 5079938.3666738653555512), (1756000.1537524810992181 5079077.8740755440667272,
+ 1756000.1537524810992181 5079016.4103185208514333, 1756061.6175095040816814 5079016.4103185208514333,
+ 1756061.6175095040816814 5079077.8740755440667272, 1756000.1537524810992181 5079077.8740755440667272))),
+ MULTIPOLYGON (((1756000.1537524810992181 5078705.9565899241715670, 1756000.1537524810992181 5078709.0915334057062864,
+ 1755877.2262384353671223 5078709.0915334057062864, 1755877.2262384353671223 5078832.0190474493429065,
+ 1755938.6899954585824162 5078832.0190474493429065, 1756000.1537524810992181 5078832.0190474493429065,
+ 1756000.1537524810992181 5078893.4828044744208455, 1756123.0812665277626365 5078893.4828044744208455,
+ 1756123.0812665277626365 5078832.0190474493429065, 1756246.0087805732619017 5078832.0190474493429065,
+ 1756246.0087805732619017 5078709.0915334057062864, 1756184.5450235498137772 5078709.0915334057062864,
+ 1756061.6175095040816814 5078709.0915334057062864, 1756061.6175095040816814 5078704.4868044294416904,
+ 1756000.1537524810992181 5078705.9565899241715670)), ((1756368.9362946192268282 5078697.1378769595175982,
+ 1756368.9362946192268282 5078709.0915334057062864, 1756307.4725375962443650 5078709.0915334057062864,
+ 1756307.4725375962443650 5078832.0190474493429065, 1756246.0087805732619017 5078832.0190474493429065,
+ 1756246.0087805732619017 5078893.4828044744208455, 1756307.4725375962443650 5078893.4828044744208455,
+ 1756307.4725375962443650 5079016.4103185208514333, 1756184.5450235498137772 5079016.4103185208514333,
+ 1756184.5450235498137772 5079077.8740755440667272, 1756123.0812665277626365 5079077.8740755440667272,
+ 1756123.0812665277626365 5079200.8015895904973149, 1756184.5450235498137772 5079200.8015895904973149,
+ 1756246.0087805732619017 5079200.8015895904973149, 1756246.0087805732619017 5079446.6566176833584905,
+ 1756430.4000516426749527 5079446.6566176833584905, 1756491.8638086654245853 5079446.6566176833584905,
+ 1756491.8638086654245853 5079631.0478887520730495, 1756553.3275656879413873 5079631.0478887520730495,
+ 1756553.3275656879413873 5079876.9029168421402574, 1756430.4000516426749527 5079876.9029168421402574,
+ 1756430.4000516426749527 5080061.2941879099234939, 1756307.4725375962443650 5080061.2941879099234939,
+ 1756307.4725375962443650 5080122.7579449350014329, 1756123.0812665277626365 5080122.7579449350014329,
+ 1756123.0812665277626365 5080245.6854589805006981, 1756000.1537524810992181 5080245.6854589805006981,
+ 1756000.1537524810992181 5080307.1492160055786371, 1756061.6175095040816814 5080307.1492160055786371,
+ 1756061.6175095040816814 5080430.0767300482839346, 1756123.0812665277626365 5080430.0767300482839346,
+ 1756123.0812665277626365 5080614.4680011207237840, 1756184.5450235498137772 5080614.4680011207237840,
+ 1756184.5450235498137772 5080652.1657676175236702, 1757981.0082840309478343 5080636.5103143639862537,
+ 1757996.4035379793494940 5078658.2201820081099868, 1756368.9362946192268282 5078697.1378769595175982),
+ (1756553.3275656879413873 5079569.5841317288577557, 1756553.3275656879413873 5079446.6566176833584905,
+ 1756614.7913227111566812 5079446.6566176833584905, 1756614.7913227111566812 5079569.5841317288577557,
+ 1756676.2550797339063138 5079569.5841317288577557, 1756676.2550797339063138 5079631.0478887520730495,
+ 1756614.7913227111566812 5079631.0478887520730495, 1756614.7913227111566812 5079569.5841317288577557,
+ 1756553.3275656879413873 5079569.5841317288577557), (1756676.2550797339063138 5079569.5841317288577557,
+ 1756676.2550797339063138 5079446.6566176833584905, 1756737.7188367566559464 5079446.6566176833584905,
+ 1756737.7188367566559464 5079569.5841317288577557, 1756676.2550797339063138 5079569.5841317288577557),
+ (1756184.5450235498137772 5080307.1492160055786371, 1756184.5450235498137772 5080245.6854589805006981,
+ 1756246.0087805732619017 5080245.6854589805006981, 1756246.0087805732619017 5080307.1492160055786371,
+ 1756184.5450235498137772 5080307.1492160055786371), (1756491.8638086654245853 5080061.2941879099234939,
+ 1756491.8638086654245853 5079938.3666738653555512, 1756614.7913227111566812 5079938.3666738653555512,
+ 1756614.7913227111566812 5080061.2941879099234939, 1756491.8638086654245853 5080061.2941879099234939),
+ (1757045.0376218727324158 5078832.0190474493429065, 1757045.0376218727324158 5078709.0915334057062864,
+ 1757106.5013788954820484 5078709.0915334057062864, 1757106.5013788954820484 5078832.0190474493429065,
+ 1757045.0376218727324158 5078832.0190474493429065), (1756491.8638086654245853 5079262.2653466118499637,
+ 1756491.8638086654245853 5079200.8015895904973149, 1756553.3275656879413873 5079200.8015895904973149,
+ 1756553.3275656879413873 5079262.2653466118499637, 1756491.8638086654245853 5079262.2653466118499637)),
+ ((1756000.1537524810992181 5080653.7726632226258516, 1756000.1537524810992181 5080491.5404870714992285,
+ 1755877.2262384353671223 5080491.5404870714992285, 1755877.2262384353671223 5080654.8439269624650478,
+ 1756000.1537524810992181 5080653.7726632226258516))))</a>
+<test>
+<op name="union" arg1="A">
+ POLYGON ((1756000.153752481 5080653.772663223, 1756184.5450235498 5080652.1657676175,
+ 1757981.008284031 5080636.510314364, 1757996.4035379793 5078658.220182008,
+ 1756368.9362946192 5078697.1378769595, 1756061.617509504 5078704.486804429,
+ 1756000.153752481 5078705.956589924, 1754455.4951298737 5078742.894078725,
+ 1754447.7975028993 5080667.300822261, 1755877.2262384354 5080654.843926962,
+ 1756000.153752481 5080653.772663223))
+</op>
+</test>
+</case>
+</run>
Summary of changes:
src/operation/union/OverlapUnion.cpp | 2 +-
tests/xmltester/tests/issue/issue-geos-994.xml | 171 +++++++++++++++++++++++++
2 files changed, 172 insertions(+), 1 deletion(-)
create mode 100644 tests/xmltester/tests/issue/issue-geos-994.xml
hooks/post-receive
More information about the geos-commits
