[geos-commits] [SCM] GEOS branch master updated. aaf468f51390972ebc55e6621ba25268ff7bb624
git at osgeo.org
git at osgeo.org
Tue Oct 8 14:26:01 PDT 2019
the project "GEOS".
via aaf468f51390972ebc55e6621ba25268ff7bb624 (commit)
from 518c382a0ced3eeca1155a3648ba78753409b9c6 (commit)
revisions in full, below.
commit aaf468f51390972ebc55e6621ba25268ff7bb624
Author: Daniel Baston <dbaston at gmail.com>
Date: Tue Oct 8 17:25:47 2019 -0400
Provide more XML test output on failure
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index 97a3d7f..b99cc0b 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -28,7 +28,7 @@ foreach(_testdir general issue misc robust validate)
file(GLOB_RECURSE _testfiles ${CMAKE_CURRENT_LIST_DIR}/tests/${_testdir}/*.xml CONFIGURE_DEPEND)
foreach(_testfile ${_testfiles})
get_filename_component(_testname ${_testfile} NAME_WE)
- add_test(NAME ${_testdir}-${_testname} COMMAND test_xmltester --test-valid-output ${_testfile})
+ add_test(NAME ${_testdir}-${_testname} COMMAND test_xmltester -v --test-valid-output ${_testfile})
endforeach()
endforeach()
unset(_testdir)
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index d94a452..aa02b95 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -367,8 +367,9 @@ XMLTester::printTest(bool success, const std::string& expected_result, const std
std::cout << ": " << (success ? "ok." : "failed.");
std::cout << " (" << std::setprecision(15) << java_math_round(prof.getTot() / 1000) << " ms)" << std::endl;
- // print geometry etc for -v -v and above
- if (verbose > 1) {
+ // print geometry on failure for -v
+ // print geometry no matter what for -v -v and above
+ if (verbose > 1 || (verbose == 1 && !success)) {
std::cout << "\tDescription: " << curr_case_desc << std::endl;
if(gA) {
Summary of changes:
tests/xmltester/CMakeLists.txt | 2 +-
tests/xmltester/XMLTester.cpp | 5 +++--
2 files changed, 4 insertions(+), 3 deletions(-)
hooks/post-receive
More information about the geos-commits
