[geos-commits] [SCM] GEOS branch 3.7 updated. b363b501d5ceeecee3eba51277adecf975308174
git at osgeo.org
git at osgeo.org
Fri Oct 18 15:17:35 PDT 2019
the project "GEOS".
The branch, 3.7 has been updated
via b363b501d5ceeecee3eba51277adecf975308174 (commit)
from 6b64a820d18365fc2170cd6f36d8256c4f806ec3 (commit)
revisions in full, below.
commit b363b501d5ceeecee3eba51277adecf975308174
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri Oct 18 18:16:49 2019 -0400
Backport perf tests to 3.7
diff --git a/tests/perf/algorithm/CMakeLists.txt b/tests/perf/algorithm/CMakeLists.txt
new file mode 100644
index 0000000..8b0ab39
--- /dev/null
+++ b/tests/perf/algorithm/CMakeLists.txt
@@ -0,0 +1,23 @@
+# CMake configuration for GEOS perf/algorithm tests
+# Copyright (C) 2017 Mateusz Loskot <mateusz at loskot.net>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU Lesser General Public Licence as published
+# by the Free Software Foundation.
+# See the COPYING file for more information.
+add_executable(perf_voronoi VoronoiPerfTest.cpp)
+target_link_libraries(perf_voronoi geos)
+add_test(perf_voronoi ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_voronoi)
+add_executable(perf_unaryunion_segments UnaryUnionSegmentsPerfTest.cpp)
+target_link_libraries(perf_unaryunion_segments geos)
+add_executable(perf_interiorpoint_area InteriorPointAreaPerfTest.cpp)
+target_link_libraries(perf_interiorpoint_area geos)
diff --git a/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp b/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
index 0000000..7dc7d40
--- /dev/null
+++ b/tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
@@ -0,0 +1,138 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2011 Sandro Santilli <strk at kbt.io>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: perf/operation/predicate/RectangleIntersectsPerfTest.java r378 (JTS-1.12)
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/util/GeometricShapeFactory.h>
+#include <geos/precision/SimpleGeometryPrecisionReducer.h>
+#include <geos/geom/util/SineStarFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/Point.h>
+#include <geos/profiler.h>
+#include <iostream>
+#include <vector>
+#include <cmath>
+#include <sstream>
+#include <memory>
+using namespace geos::geom;
+using namespace geos::io;
+using namespace std;
+class InteriorPointAreaPerfTest {
+public:
+ InteriorPointAreaPerfTest()
+ pm(),
+ fact(GeometryFactory::create(&pm, 0))
+ showHeader();
+ void
+ test(int nPts)
+ Coordinate origin(ORG_X, ORG_Y);
+ std::unique_ptr<geos::geom::Polygon> sinePoly =
+ createSineStar(origin, SIZE, nPts);
+ * Make the geometry "crinkly" by rounding off the points.
+ * This defeats the MonotoneChain optimization in the full relate
+ * algorithm, and provides a more realistic test.
+ using geos::precision::SimpleGeometryPrecisionReducer;
+ double scale = nPts / SIZE;
+ PrecisionModel p_pm(scale);
+ SimpleGeometryPrecisionReducer reducer(&p_pm);
+ std::unique_ptr<Geometry> sinePolyCrinkly(reducer.reduce(sinePoly.get()));
+ sinePoly.reset();
+ //cout << sinePolyCrinkly->toText() << endl;
+ test(*sinePolyCrinkly);
+ const double ORG_X = 100.0;
+ const double ORG_Y = 100.0;
+ const double SIZE = 100.0;
+ const int N_ARMS = 20;
+ const double ARM_RATIO = 0.3;
+ const int N_ITER = 100;
+private:
+ PrecisionModel pm;
+ GeometryFactory::Ptr fact;
+ void
+ showHeader() {
+ cout << "Interior Point Area perf test" << endl;
+ cout << "# Iterations: " << N_ITER << endl;
+ cout << "SineStar: origin: ("
+ << ORG_X << ", " << ORG_Y
+ << ") size: " << SIZE
+ << " # arms: " << N_ARMS
+ << " arm ratio: " << ARM_RATIO
+ << endl;
+ void
+ test(geos::geom::Geometry& poly)
+ geos::util::Profile sw("");
+ sw.start();
+ for(int i = 0; i < N_ITER; i++) {
+ std::unique_ptr<geos::geom::Point> pt( poly.getInteriorPoint() );
+ sw.stop();
+ cout << poly.getNumPoints() << " points: " << sw.getTot() << endl;
+ createSineStar(const Coordinate& origin,
+ double size, int nPts)
+ using geos::geom::util::SineStarFactory;
+ SineStarFactory gsf(fact.get());
+ gsf.setCentre(origin);
+ gsf.setSize(size);
+ gsf.setNumPoints(nPts);
+ gsf.setArmLengthRatio( ARM_RATIO );
+ gsf.setNumArms( N_ARMS );
+ std::unique_ptr<geos::geom::Polygon> poly = gsf.createSineStar();
+ return poly;
+int
+main()
+ InteriorPointAreaPerfTest tester;
+ tester.test(100);
+ tester.test(1000);
+ tester.test(10000);
+ tester.test(100000);
+ tester.test(1000000);
diff --git a/tests/perf/algorithm/UnaryUnionSegmentsPerfTest.cpp b/tests/perf/algorithm/UnaryUnionSegmentsPerfTest.cpp
index 0000000..19099c6
--- /dev/null
+++ b/tests/perf/algorithm/UnaryUnionSegmentsPerfTest.cpp
@@ -0,0 +1,72 @@
+ * Copyright (C) 2019 Daniel Baston <dbaston at gmail.com>
+#include <geos/triangulate/DelaunayTriangulationBuilder.h>
+#include <geos/triangulate/VoronoiDiagramBuilder.h>
+#include <geos/geom/CoordinateArraySequence.h>
+#include <geos/geom/LineString.h>
+#include <algorithm>
+#include <random>
+#include <vector>
+#include <memory>
+class SegmentUnaryUnionPerfTest {
+public:
+ void test(size_t num_lines) {
+ using namespace geos::geom;
+ std::default_random_engine e(12345);
+ std::uniform_real_distribution<> dis(0, 100);
+ std::vector<Geometry*>* lines = new std::vector<Geometry*>();
+ for (size_t i = 0; i < num_lines; i++) {
+ CoordinateArraySequence* cas = new CoordinateArraySequence(2, 2);
+ cas->setAt(Coordinate(dis(e), dis(e)), 0);
+ cas->setAt(Coordinate(dis(e), dis(e)), 1);
+ Geometry* line = gfact->createLineString(cas);
+ lines->push_back(line);
+ auto g = gfact->createMultiLineString(lines);
+ auto sw = profiler->get("union");
+ sw->start();
+ g->Union();
+ sw->stop();
+ std::cout << *sw << std::endl;
+private:
+ decltype(geos::geom::GeometryFactory::create()) gfact = geos::geom::GeometryFactory::create();
+ geos::util::Profiler* profiler = geos::util::Profiler::instance();
+int main(int argc, char** argv) {
+ SegmentUnaryUnionPerfTest tester;
+ auto num_lines = std::atol(argv[1]);
+ auto num_reps = argc > 2 ? std::atol(argv[2]) : 1;
+ for (int i = 0; i < num_reps; i++) {
+ tester.test(num_lines);
diff --git a/tests/perf/algorithm/VoronoiPerfTest.cpp b/tests/perf/algorithm/VoronoiPerfTest.cpp
index 0000000..ab6e9dc
--- /dev/null
+++ b/tests/perf/algorithm/VoronoiPerfTest.cpp
@@ -0,0 +1,93 @@
+#include <random>
+#include <vector>
+#include <memory>
+class VoronoiPerfTest {
+public:
+ void test(size_t num_points) {
+ std::unique_ptr<std::vector<Coordinate>> coords(new std::vector<Coordinate>(num_points));
+ std::generate(coords->begin(), coords->end(), [&dis, &e]() {
+ return Coordinate(dis(e), dis(e));
+ CoordinateArraySequence seq(coords.release());
+ Geometry* geom = gfact->createLineString(seq.clone());
+ voronoi(seq);
+ voronoi(*geom);
+ delaunay(seq);
+ delaunay(*geom);
+ std::cout << std::endl;
+private:
+ template<typename T>
+ void voronoi(const T & sites) {
+ auto sw = profiler->get(std::string("Voronoi from ") + typeid(T).name());
+ sw->start();
+ geos::triangulate::VoronoiDiagramBuilder vdb;
+ vdb.setSites(sites);
+ auto result = vdb.getDiagram(*gfact);
+ sw->stop();
+ std::cout << sw->name << ": " << result->getNumGeometries() << ": " << *sw << std::endl;
+ void delaunay(const T & seq) {
+ auto sw = profiler->get(std::string("Delaunay from ") + typeid(T).name());
+ sw->start();
+ geos::triangulate::DelaunayTriangulationBuilder dtb;
+ dtb.setSites(seq);
+ auto result = dtb.getTriangles(*gfact);
+ sw->stop();
+int main() {
+ VoronoiPerfTest tester;
+ //tester.test(100);
+ //tester.test(1000);
+ //tester.test(10000);
+ for (auto i = 0; i < 5; i++) {
\ No newline at end of file
diff --git a/tests/perf/capi/CMakeLists.txt b/tests/perf/capi/CMakeLists.txt
index 9019629..7d92704 100644
--- a/tests/perf/capi/CMakeLists.txt
+++ b/tests/perf/capi/CMakeLists.txt
@@ -22,3 +22,5 @@ add_test(perf_memleak_mp_prep ${CMAKE_RUNTIME_OUTPUT_DIRECTORY}/perf_memleak_mp_
add_executable(perf_intersection IntersectionPerfTest.cpp)
target_link_libraries(perf_intersection geos_c)
+add_executable(perf_geospreparedcontains GEOSPreparedContainsPerfTest.cpp)
+target_link_libraries(perf_geospreparedcontains geos_c)
diff --git a/tests/perf/capi/GEOSPreparedContainsPerfTest.cpp b/tests/perf/capi/GEOSPreparedContainsPerfTest.cpp
index 0000000..8b75a05
--- /dev/null
+++ b/tests/perf/capi/GEOSPreparedContainsPerfTest.cpp
@@ -0,0 +1,115 @@
+#include <geos_c.h>
+#include <geos/geom/Coordinate.h>
+#include <random>
+#include <vector>
+#include <memory>
+#include <fstream>
+#include <sstream>
+class GEOSPreparedContainsPerfTest {
+public:
+ void test(const GEOSGeometry* g, size_t num_points) {
+ double xmin, xmax, ymin, ymax;
+ GEOSGeom_getXMin(g, &xmin);
+ GEOSGeom_getXMax(g, &xmax);
+ GEOSGeom_getYMin(g, &ymin);
+ GEOSGeom_getYMax(g, &ymax);
+ std::uniform_real_distribution<> xdist(xmin, xmax);
+ std::uniform_real_distribution<> ydist(ymin, ymax);
+ std::vector<Coordinate> coords(num_points);
+ std::generate(coords.begin(), coords.end(), [&xdist, &ydist, &e]() {
+ return Coordinate(xdist(e), ydist(e));
+ geos::util::Profile sw("GEOSPreparedContains");
+ sw.start();
+ size_t hits = 0;
+ auto prep = GEOSPrepare(g);
+ for (const auto& c : coords) {
+ auto seq = GEOSCoordSeq_create(1, 2);
+ GEOSCoordSeq_setX(seq, 0, c.x);
+ GEOSCoordSeq_setY(seq, 0, c.y);
+ auto pt = GEOSGeom_createPoint(seq);
+ if (GEOSPreparedContains(prep, pt)) {
+ hits++;
+ GEOSGeom_destroy(pt);
+ GEOSPreparedGeom_destroy(prep);
+ sw.stop();
+ std::cout << sw.name << ": " << hits << " hits from " << num_points << " points in " << sw.getTot() << std::endl;
+ if (argc != 3) {
+ std::cout << "perf_geospreparedcontins performs a specified number of point-in-polygon tests" << std::endl;
+ std::cout << "on randomly generated points from the bounding box of a single geometry provided" << std::endl;
+ std::cout << "in a file as WKT." << std::endl;
+ std::cout << "Usage: perf_geospreparedcontins [wktfile] [n]" << std::endl;
+ return 0;
+ GEOSPreparedContainsPerfTest tester;
+ int n = std::atoi(argv[2]);
+ std::cout << "Performing " << n << " point-in-polygon tests." << std::endl;
+ std::string fname{argv[1]};
+ std::cout << "Reading shape from " << fname << std::endl;
+ std::ifstream f(fname);
+ std::stringstream buff;
+ buff << f.rdbuf();
+ f.close();
+ std::string wkt = buff.str();
+ buff.clear();
+ initGEOS(nullptr, nullptr);
+ GEOSGeometry* g = GEOSGeomFromWKT(wkt.c_str());
+ wkt.clear();
+ tester.test(g, n);
+ GEOSGeom_destroy(g);
Summary of changes:
tests/perf/algorithm/CMakeLists.txt | 23 ++++
tests/perf/algorithm/InteriorPointAreaPerfTest.cpp | 138 +++++++++++++++++++++
.../perf/algorithm/UnaryUnionSegmentsPerfTest.cpp | 72 +++++++++++
tests/perf/algorithm/VoronoiPerfTest.cpp | 93 ++++++++++++++
tests/perf/capi/CMakeLists.txt | 2 +
tests/perf/capi/GEOSPreparedContainsPerfTest.cpp | 115 +++++++++++++++++
6 files changed, 443 insertions(+)
create mode 100644 tests/perf/algorithm/CMakeLists.txt
create mode 100644 tests/perf/algorithm/InteriorPointAreaPerfTest.cpp
create mode 100644 tests/perf/algorithm/UnaryUnionSegmentsPerfTest.cpp
create mode 100644 tests/perf/algorithm/VoronoiPerfTest.cpp
create mode 100644 tests/perf/capi/GEOSPreparedContainsPerfTest.cpp
hooks/post-receive
More information about the geos-commits
