[geos-commits] [SCM] GEOS branch master updated. 4bc853900102ced2e4195194e54e974479a42cba
git at osgeo.org
git at osgeo.org
Tue Sep 10 17:59:49 PDT 2019
the project "GEOS".
via 4bc853900102ced2e4195194e54e974479a42cba (commit)
from bd66c5a7e69a474454d63c66a11358472038289e (commit)
revisions in full, below.
commit 4bc853900102ced2e4195194e54e974479a42cba
Author: Daniel Baston <dbaston at gmail.com>
Date: Mon Sep 9 10:05:27 2019 -0400
Add multi-ordinate coordseq setters and getters to C API
The following CAPI functions are added for improved performance and
convenience:
GEOSCoordSeq_setXY
GEOSCoordSeq_setXYZ
GEOSCoordSeq_getXY
GEOSCoordSeq_getXYZ
diff --git a/NEWS b/NEWS
index 2b33375..7381e1a 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,8 @@ Changes in 3.8.0
- CAPI: GEOSMakeValid (#952, Even Rouault)
- CAPI: GEOSPolygonize_valid (#727, Dan Baston)
- CAPI: GEOSCoverageUnion (Dan Baston)
+ - CAPI: GEOSCoordSeq_setXY, GEOSCoordSeq_setXYZ,
+ GEOSCoordSeq_getXY, GEOSCoordSeq_getXYZ (Dan Baston)
- Improvements:
- Improve performance and robustness of GEOSPointOnSurface (Martin Davis)
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index 1a56555..2974eca 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -845,6 +845,18 @@ extern "C" {
return GEOSCoordSeq_setOrdinate(s, idx, 2, val);
+ int
+ GEOSCoordSeq_setXY(CoordinateSequence* s, unsigned int idx, double x, double y)
+ return GEOSCoordSeq_setXY_r(handle, s, idx, x, y);
+ int
+ GEOSCoordSeq_setXYZ(CoordinateSequence* s, unsigned int idx, double x, double y, double z)
+ return GEOSCoordSeq_setXYZ_r(handle, s, idx, x, y, z);
CoordinateSequence*
GEOSCoordSeq_clone(const CoordinateSequence* s)
@@ -876,6 +888,18 @@ extern "C" {
int
+ GEOSCoordSeq_getXY(const CoordinateSequence* s, unsigned int idx, double* x, double* y)
+ return GEOSCoordSeq_getXY_r(handle, s, idx, x, y);
+ int
+ GEOSCoordSeq_getXYZ(const CoordinateSequence* s, unsigned int idx, double* x, double* y, double* z)
+ return GEOSCoordSeq_getXYZ_r(handle, s, idx, x, y, z);
+ int
GEOSCoordSeq_getSize(const CoordinateSequence* s, unsigned int* size)
return GEOSCoordSeq_getSize_r(handle, s, size);
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 5f7329e..73207e3 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -302,6 +302,13 @@ extern int GEOS_DLL GEOSCoordSeq_setY_r(GEOSContextHandle_t handle,
extern int GEOS_DLL GEOSCoordSeq_setZ_r(GEOSContextHandle_t handle,
GEOSCoordSequence* s, unsigned int idx,
double val);
+extern int GEOS_DLL GEOSCoordSeq_setXY_r(GEOSContextHandle_t handle,
+ GEOSCoordSequence* s, unsigned int idx,
+ double x, double y);
+extern int GEOS_DLL GEOSCoordSeq_setXYZ_r(GEOSContextHandle_t handle,
+ double x, double y, double z);
extern int GEOS_DLL GEOSCoordSeq_setOrdinate_r(GEOSContextHandle_t handle,
unsigned int idx,
@@ -320,6 +327,12 @@ extern int GEOS_DLL GEOSCoordSeq_getY_r(GEOSContextHandle_t handle,
extern int GEOS_DLL GEOSCoordSeq_getZ_r(GEOSContextHandle_t handle,
const GEOSCoordSequence* s,
unsigned int idx, double *val);
+extern int GEOS_DLL GEOSCoordSeq_getXY_r(GEOSContextHandle_t handle,
+ const GEOSCoordSequence* s,
+ unsigned int idx, double *x, double *y);
+extern int GEOS_DLL GEOSCoordSeq_getXYZ_r(GEOSContextHandle_t handle,
+ unsigned int idx, double *x, double *y, double *z);
extern int GEOS_DLL GEOSCoordSeq_getOrdinate_r(GEOSContextHandle_t handle,
unsigned int idx,
@@ -1393,6 +1406,10 @@ extern int GEOS_DLL GEOSCoordSeq_setY(GEOSCoordSequence* s,
unsigned int idx, double val);
extern int GEOS_DLL GEOSCoordSeq_setZ(GEOSCoordSequence* s,
+extern int GEOS_DLL GEOSCoordSeq_setXY(GEOSCoordSequence* s,
+ unsigned int idx, double x, double y);
+extern int GEOS_DLL GEOSCoordSeq_setXYZ(GEOSCoordSequence* s,
+ unsigned int idx, double x, double y, double z);
extern int GEOS_DLL GEOSCoordSeq_setOrdinate(GEOSCoordSequence* s,
unsigned int idx, unsigned int dim, double val);
@@ -1406,6 +1423,10 @@ extern int GEOS_DLL GEOSCoordSeq_getY(const GEOSCoordSequence* s,
extern int GEOS_DLL GEOSCoordSeq_getZ(const GEOSCoordSequence* s,
+extern int GEOS_DLL GEOSCoordSeq_getXY(const GEOSCoordSequence* s,
+extern int GEOS_DLL GEOSCoordSeq_getXYZ(const GEOSCoordSequence* s,
extern int GEOS_DLL GEOSCoordSeq_getOrdinate(const GEOSCoordSequence* s,
unsigned int idx, unsigned int dim, double *val);
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 05e2678..8ef1e12 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -3761,6 +3761,62 @@ extern "C" {
return GEOSCoordSeq_setOrdinate_r(extHandle, s, idx, 2, val);
+ int
+ GEOSCoordSeq_setXY_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs, unsigned int idx, double x, double y)
+ assert(0 != cs);
+ if(0 == extHandle) {
+ return 0;
+ GEOSContextHandleInternal_t* handle = 0;
+ handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ if(0 == handle->initialized) {
+ return 0;
+ try {
+ cs->setAt({x, y}, idx);
+ return 1;
+ catch(const std::exception& e) {
+ handle->ERROR_MESSAGE("%s", e.what());
+ catch(...) {
+ handle->ERROR_MESSAGE("Unknown exception thrown");
+ return 0;
+ int
+ GEOSCoordSeq_setXYZ_r(GEOSContextHandle_t extHandle, CoordinateSequence* cs, unsigned int idx, double x, double y, double z)
+ assert(0 != cs);
+ return 0;
+ return 0;
+ try {
+ cs->setAt({x, y, z}, idx);
+ return 1;
+ catch(...) {
+ return 0;
CoordinateSequence*
GEOSCoordSeq_clone_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs)
@@ -3841,6 +3897,67 @@ extern "C" {
int
+ GEOSCoordSeq_getXY_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int idx, double* x, double* y)
+ assert(0 != cs);
+ return 0;
+ return 0;
+ try {
+ auto& c = cs->getAt(idx);
+ *x = c.x;
+ *y = c.y;
+ return 1;
+ catch(...) {
+ return 0;
+ int
+ GEOSCoordSeq_getXYZ_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int idx, double* x, double* y, double* z)
+ assert(0 != cs);
+ return 0;
+ return 0;
+ try {
+ *x = c.x;
+ *y = c.y;
+ *z = c.z;
+ return 1;
+ catch(...) {
+ return 0;
+ int
GEOSCoordSeq_getSize_r(GEOSContextHandle_t extHandle, const CoordinateSequence* cs, unsigned int* size)
assert(0 != cs);
diff --git a/tests/unit/capi/GEOSCoordSeqTest.cpp b/tests/unit/capi/GEOSCoordSeqTest.cpp
index fc7d343..e604dd4 100644
--- a/tests/unit/capi/GEOSCoordSeqTest.cpp
+++ b/tests/unit/capi/GEOSCoordSeqTest.cpp
@@ -344,5 +344,48 @@ void object::test<10>
ensure_equals(GEOSCoordSeq_isCCW(cs_, &ccw), 0);
+template<>
+template<>
+void object::test<11>
+ cs_ = GEOSCoordSeq_create(1, 2);
+ unsigned int size;
+ unsigned int dims;
+ ensure(0 != GEOSCoordSeq_getSize(cs_, &size));
+ ensure_equals(size, 1u);
+ ensure(0 != GEOSCoordSeq_getDimensions(cs_, &dims));
+ ensure_equals(dims, 2u);
+ double x = 10;
+ double y = 11;
+ GEOSCoordSeq_setXY(cs_, 0, x, y);
+ double xcheck, ycheck, zcheck;
+ ensure(0 != GEOSCoordSeq_getXY(cs_, 0, &xcheck, &ycheck));
+ ensure_equals(xcheck, x);
+ ensure_equals(ycheck, y);
+ ensure(0 != GEOSCoordSeq_getXYZ(cs_, 0, &xcheck, &ycheck, &zcheck));
+ ensure(std::isnan(zcheck));
+ double z = 12;
+ GEOSCoordSeq_setXYZ(cs_, 0, x, y, z);
+ ensure_equals(zcheck, z);
} // namespace tut
Summary of changes:
NEWS | 2 +
capi/geos_c.cpp | 24 +++++++
capi/geos_c.h.in | 21 +++++++
capi/geos_ts_c.cpp | 117 +++++++++++++++++++++++++++++++++++
tests/unit/capi/GEOSCoordSeqTest.cpp | 43 +++++++++++++
5 files changed, 207 insertions(+)
hooks/post-receive
More information about the geos-commits
