[geos-commits] [SCM] GEOS branch master updated. 98594fd421edad01c73a78148595a1fbc6a0e14f
Fri Sep 13 14:00:11 PDT 2019
the project "GEOS".
       via  98594fd421edad01c73a78148595a1fbc6a0e14f (commit)
      from  f61d6572579ead3f0ac24c44ebc1acfbe843d497 (commit)
revisions in full, below.
commit 98594fd421edad01c73a78148595a1fbc6a0e14f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Sep 13 13:59:34 2019 -0700
    Use Release as default cmake build instead of Debug
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 9045f78..e3752d2 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -13,6 +13,9 @@
 # modes for specific C/C++ language standard levels.
 cmake_minimum_required(VERSION 3.8)
+# Default to release build so packagers don't release debug builds
+set(DEFAULT_BUILD_TYPE Release)
 # Require CMake 3.13+ with VS generator for complete support of VS versions
 # and support by AppVeyor.
 if(${CMAKE_GENERATOR} MATCHES "Visual Studio")
@@ -27,7 +30,14 @@ if(EXISTS ${CMAKE_SOURCE_DIR}/.git/HEAD)
   set(GEOS_BUILD_FROM_GIT ON)
 endif()
-message(STATUS "GEOS: Build type: ${CMAKE_BUILD_TYPE}")
+# Make sure we know our build type
+if(NOT CMAKE_BUILD_TYPE)
+  set(CMAKE_BUILD_TYPE ${DEFAULT_BUILD_TYPE})
+  message(STATUS "GEOS: Using default build type: ${CMAKE_BUILD_TYPE}")
+else()
+  message(STATUS "GEOS: Build type: ${CMAKE_BUILD_TYPE}")
+endif()
 # Options
Summary of changes:
 CMakeLists.txt | 12 +++++++++++-
 1 file changed, 11 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
