[geos-commits] [SCM] GEOS branch master updated. a6edac73e4c958d27369f8750133cab1c453275d
Sun Sep 15 12:23:56 PDT 2019
the project "GEOS".
       via  a6edac73e4c958d27369f8750133cab1c453275d (commit)
      from  2fbaf5707f11ed364bceddfd1960b8be3c28bdc5 (commit)
revisions in full, below.
commit a6edac73e4c958d27369f8750133cab1c453275d
Author: Daniel Baston <dbaston at gmail.com>
Date:   Sun Sep 15 15:23:27 2019 -0400
    Improve MinimumDiameter
    - Address TODO to avoid unnecessary heap-allocation of Coordinate and
    LineSegment
    - Use unique_ptr to return pointers owned by caller
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 8ef1e12..9c8853f 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1929,8 +1929,7 @@ extern "C" {
         try {
             geos::algorithm::MinimumDiameter m(g);
-            Geometry* g3 = m.getMinimumRectangle();
-            return g3;
+            return m.getMinimumRectangle().release();
         catch(const std::exception& e) {
             handle->ERROR_MESSAGE("%s", e.what());
@@ -1958,8 +1957,7 @@ extern "C" {
         try {
-            Geometry* g3 = m.getDiameter();
-            return g3;
+            return m.getDiameter().release();
diff --git a/include/geos/algorithm/MinimumDiameter.h b/include/geos/algorithm/MinimumDiameter.h
index 4917f30..8fb0622 100644
--- a/include/geos/algorithm/MinimumDiameter.h
+++ b/include/geos/algorithm/MinimumDiameter.h
@@ -20,6 +20,9 @@
 #ifndef GEOS_ALGORITHM_MINIMUMDIAMETER_H
 #define GEOS_ALGORITHM_MINIMUMDIAMETER_H
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/LineSegment.h>
 #include <memory>
 #include <geos/export.h>
@@ -27,9 +30,7 @@
 namespace geos {
 namespace geom {
 class Geometry;
-class LineSegment;
 class LineString;
-class Coordinate;
 class CoordinateSequence;
@@ -66,9 +67,9 @@ private:
     std::unique_ptr<geom::CoordinateSequence> convexHullPts;
-    geom::LineSegment* minBaseSeg;
-    geom::Coordinate* minWidthPt;
-    int minPtIndex;
+    geom::LineSegment minBaseSeg;
+    geom::Coordinate minWidthPt;
+    size_t minPtIndex;
     double minWidth;
     void computeMinimumDiameter();
     void computeWidthConvex(const geom::Geometry* geom);
@@ -83,7 +84,7 @@ private:
     void computeConvexRingMinDiameter(const geom::CoordinateSequence* pts);
     unsigned int findMaxPerpDistance(const geom::CoordinateSequence* pts,
-                                     geom::LineSegment* seg, unsigned int startIndex);
+                                     const geom::LineSegment* seg, unsigned int startIndex);
     static unsigned int getNextIndex(const geom::CoordinateSequence* pts,
                                      unsigned int index);
@@ -93,7 +94,7 @@ private:
     static geom::LineSegment computeSegmentForLine(double a, double b, double c);
 public:
-    ~MinimumDiameter();
+    ~MinimumDiameter() = default;
     /** \brief
      * Compute a minimum diameter for a given [Geometry](@ref geom::Geometry).
@@ -126,21 +127,21 @@ public:
      * @return a coordinate forming one end of the minimum diameter
-    geom::Coordinate* getWidthCoordinate();
+    const geom::Coordinate& getWidthCoordinate();
     /** \brief
      * Gets the segment forming the base of the minimum diameter.
      * @return the segment forming the base of the minimum diameter
-    geom::LineString* getSupportingSegment();
+    std::unique_ptr<geom::LineString> getSupportingSegment();
     /** \brief
      * Gets a LineString which is a minimum diameter.
      * @return a LineString which is a minimum diameter
-    geom::LineString* getDiameter();
+    std::unique_ptr<geom::LineString> getDiameter();
     /** \brief
      * Gets the minimum rectangular Polygon which encloses the input geometry.
@@ -153,7 +154,7 @@ public:
      * @return the minimum rectangle enclosing the input (or a line or point if degenerate)
-    geom::Geometry* getMinimumRectangle();
+    std::unique_ptr<geom::Geometry> getMinimumRectangle();
     /** \brief
      * Gets the minimum rectangle enclosing a geometry.
@@ -161,14 +162,14 @@ public:
      * @param geom the geometry
      * @return the minimum rectangle enclosing the geometry
-    static geom::Geometry* getMinimumRectangle(geom::Geometry* geom);
+    static std::unique_ptr<geom::Geometry> getMinimumRectangle(geom::Geometry* geom);
     /** \brief
      * Gets the length of the minimum diameter enclosing a geometry.
      * @return the length of the minimum diameter of the geometry
-    static geom::Geometry* getMinimumDiameter(geom::Geometry* geom);
+    static std::unique_ptr<geom::Geometry> getMinimumDiameter(geom::Geometry* geom);
diff --git a/src/algorithm/MinimumDiameter.cpp b/src/algorithm/MinimumDiameter.cpp
index 31ceb24..e53ef17 100644
--- a/src/algorithm/MinimumDiameter.cpp
+++ b/src/algorithm/MinimumDiameter.cpp
@@ -15,11 +15,6 @@
  * Last port: algorithm/MinimumDiameter.java r966
- * TODO:
- * 	- avoid heap allocation for LineSegment and Coordinate
 #include <geos/constants.h>
@@ -68,8 +63,7 @@ namespace algorithm { // geos.algorithm
 MinimumDiameter::MinimumDiameter(const Geometry* newInputGeom)
-    minBaseSeg = new LineSegment();
-    minWidthPt = nullptr;
+    minWidthPt = Coordinate::getNull();
     minPtIndex = 0;
     minWidth = 0.0;
     inputGeom = newInputGeom;
@@ -89,20 +83,13 @@ MinimumDiameter::MinimumDiameter(const Geometry* newInputGeom)
 MinimumDiameter::MinimumDiameter(const Geometry* newInputGeom, const bool newIsConvex)
     minWidth = 0.0;
     isConvex = newIsConvex;
     convexHullPts = nullptr;
-MinimumDiameter::~MinimumDiameter()
-    delete minBaseSeg;
-    delete minWidthPt;
  * Gets the length of the minimum diameter of the input Geometry
@@ -120,7 +107,7 @@ MinimumDiameter::getLength()
-Coordinate*
+const Coordinate&
 MinimumDiameter::getWidthCoordinate()
@@ -132,15 +119,12 @@ MinimumDiameter::getWidthCoordinate()
-LineString*
+std::unique_ptr<LineString>
 MinimumDiameter::getSupportingSegment()
     const GeometryFactory* fact = inputGeom->getFactory();
-    auto cl = fact->getCoordinateSequenceFactory()->create(2);
-    cl->setAt(minBaseSeg->p0, 0);
-    cl->setAt(minBaseSeg->p1, 1);
-    return fact->createLineString(cl.release());
+    return minBaseSeg.toGeometry(*fact);
@@ -148,22 +132,22 @@ MinimumDiameter::getSupportingSegment()
-LineString*
 MinimumDiameter::getDiameter()
     // return empty linestring if no minimum width calculated
-    if(minWidthPt == nullptr) {
-        return inputGeom->getFactory()->createLineString(nullptr);
+    if(minWidthPt.isNull()) {
+        return std::unique_ptr<LineString>(inputGeom->getFactory()->createLineString(nullptr));
     Coordinate basePt;
-    minBaseSeg->project(*minWidthPt, basePt);
+    minBaseSeg.project(minWidthPt, basePt);
     auto cl = inputGeom->getFactory()->getCoordinateSequenceFactory()->create(2);
     cl->setAt(basePt, 0);
-    cl->setAt(*minWidthPt, 1);
-    return inputGeom->getFactory()->createLineString(cl.release());
+    cl->setAt(minWidthPt, 1);
+    return inputGeom->getFactory()->createLineString(std::move(cl));
 /* private */
@@ -171,7 +155,7 @@ void
 MinimumDiameter::computeMinimumDiameter()
     // check if computation is cached
-    if(minWidthPt != nullptr) {
         return;
     if(isConvex) {
@@ -201,25 +185,20 @@ MinimumDiameter::computeWidthConvex(const Geometry* geom)
     switch(convexHullPts->getSize()) {
     case 0:
         minWidth = 0.0;
-        minBaseSeg = nullptr;
         break;
     case 1:
         minWidth = 0.0;
-        minWidthPt = new Coordinate(convexHullPts->getAt(0));
-        minBaseSeg->p0 = convexHullPts->getAt(0);
-        minBaseSeg->p1 = convexHullPts->getAt(0);
+        minWidthPt = convexHullPts->getAt(0);
+        minBaseSeg.p0 = convexHullPts->getAt(0);
+        minBaseSeg.p1 = convexHullPts->getAt(0);
         break;
     case 2:
     case 3:
         minWidth = 0.0;
-        minBaseSeg->p1 = convexHullPts->getAt(1);
+        minBaseSeg.p1 = convexHullPts->getAt(1);
         break;
     default:
         computeConvexRingMinDiameter(convexHullPts.get());
@@ -251,7 +230,7 @@ MinimumDiameter::computeConvexRingMinDiameter(const CoordinateSequence* pts)
 unsigned int
 MinimumDiameter::findMaxPerpDistance(const CoordinateSequence* pts,
-                                     LineSegment* seg, unsigned int startIndex)
+                                     const LineSegment* seg, unsigned int startIndex)
     double maxPerpDistance = seg->distancePerpendicular(pts->getAt(startIndex));
     double nextPerpDistance = maxPerpDistance;
@@ -268,12 +247,8 @@ MinimumDiameter::findMaxPerpDistance(const CoordinateSequence* pts,
     if(maxPerpDistance < minWidth) {
         minPtIndex = maxIndex;
         minWidth = maxPerpDistance;
-        minWidthPt = new Coordinate(pts->getAt(minPtIndex));
-        minBaseSeg = new LineSegment(*seg);
-//      System.out.println(minBaseSeg);
-//      System.out.println(minWidth);
+        minWidthPt = pts->getAt(minPtIndex);
+        minBaseSeg = *seg;
     return maxIndex;
@@ -288,27 +263,27 @@ MinimumDiameter::getNextIndex(const CoordinateSequence* pts,
     return index;
-Geometry*
+std::unique_ptr<Geometry>
 MinimumDiameter::getMinimumRectangle()
-    if(!minBaseSeg || !convexHullPts) {
+    if(minWidthPt.isNull() || !convexHullPts) {
         //return empty polygon
-        return inputGeom->getFactory()->createPolygon();
+        return std::unique_ptr<Geometry>(inputGeom->getFactory()->createPolygon());
     // check if minimum rectangle is degenerate (a point or line segment)
     if(minWidth == 0.0) {
-        if(minBaseSeg->p0.equals2D(minBaseSeg->p1)) {
-            return inputGeom->getFactory()->createPoint(minBaseSeg->p0);
+        if(minBaseSeg.p0.equals2D(minBaseSeg.p1)) {
+            return std::unique_ptr<Geometry>(inputGeom->getFactory()->createPoint(minBaseSeg.p0));
-        return minBaseSeg->toGeometry(*inputGeom->getFactory()).release();
+        return minBaseSeg.toGeometry(*inputGeom->getFactory());
     // deltas for the base segment of the minimum diameter
-    double dx = minBaseSeg->p1.x - minBaseSeg->p0.x;
-    double dy = minBaseSeg->p1.y - minBaseSeg->p0.y;
+    double dx = minBaseSeg.p1.x - minBaseSeg.p0.x;
+    double dy = minBaseSeg.p1.y - minBaseSeg.p0.y;
     double minPara = DoubleMax;
     double maxPara = -DoubleMax;
@@ -358,8 +333,8 @@ MinimumDiameter::getMinimumRectangle()
     seq->setAt(p3, 3);
     seq->setAt(p0, 4); // close
-    LinearRing* shell = inputGeom->getFactory()->createLinearRing(seq.release());
-    return inputGeom->getFactory()->createPolygon(shell, nullptr);
+    std::unique_ptr<LinearRing> shell = inputGeom->getFactory()->createLinearRing(std::move(seq));
+    return inputGeom->getFactory()->createPolygon(std::move(shell));
 double
@@ -390,14 +365,14 @@ MinimumDiameter::computeSegmentForLine(double a, double b, double c)
-Geometry*
 MinimumDiameter::getMinimumRectangle(Geometry* geom)
     MinimumDiameter md(geom);
     return md.getMinimumRectangle();
-Geometry*
 MinimumDiameter::getMinimumDiameter(Geometry* geom)
Summary of changes:
 capi/geos_ts_c.cpp                       |  6 +--
 include/geos/algorithm/MinimumDiameter.h | 27 +++++-----
 src/algorithm/MinimumDiameter.cpp        | 93 ++++++++++++--------------------
 3 files changed, 50 insertions(+), 76 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
