[geos-commits] [SCM] GEOS branch master updated. c82abc242a3f4ffdd3da5fbe34945e4027273345
Sun Sep 15 14:05:00 PDT 2019
the project "GEOS".
       via  c82abc242a3f4ffdd3da5fbe34945e4027273345 (commit)
       via  1aaa406e97488d34de62d3fd40ea1a4b7e66c638 (commit)
       via  eef7fa11856e63d9836c31a0b7ecfe688af71440 (commit)
      from  eb5673a656c5f7f226b54246bbab6e0c8c64a37d (commit)
revisions in full, below.
commit c82abc242a3f4ffdd3da5fbe34945e4027273345
Author: Daniel Baston <dbaston at gmail.com>
Date:   Sun Sep 15 17:03:45 2019 -0400
    Simplify QuadEdgeSubdivision::getVoronoiCellPolygon
    Avoid conversions between unmanaged and managed pointers.
    Avoid creating a coordinate sequence inconsistent with implementation
    used in GeometryFactory.
diff --git a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
index 2fccbad..6352459 100644
--- a/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
+++ b/src/triangulate/quadedge/QuadEdgeSubdivision.cpp
@@ -591,9 +591,8 @@ QuadEdgeSubdivision::getVoronoiCellPolygon(const QuadEdge* qe, const geom::Geome
         cellPts.push_back(cellPts.back());
-    std::unique_ptr<CoordinateSequence> seq(new CoordinateArraySequence(std::move(cellPts)));
-    std::unique_ptr<geom::Geometry> cellPoly(geomFact.createPolygon(geomFact.createLinearRing(seq.release()), nullptr));
+    auto seq = geomFact.getCoordinateSequenceFactory()->create(std::move(cellPts));
+    auto cellPoly = geomFact.createPolygon(geomFact.createLinearRing(std::move(seq)));
     // FIXME why is this returning a pointer to a local variable?
     Vertex v = startQE->orig();
commit 1aaa406e97488d34de62d3fd40ea1a4b7e66c638
Date:   Sun Sep 15 17:00:24 2019 -0400
    Simplify WKTReader::readPolygonText
    Use factory method for building empty polygons.
diff --git a/src/io/WKTReader.cpp b/src/io/WKTReader.cpp
index d89f1b0..fcff5be 100644
--- a/src/io/WKTReader.cpp
+++ b/src/io/WKTReader.cpp
@@ -352,7 +352,7 @@ WKTReader::readPolygonText(StringTokenizer* tokenizer)
     string nextToken = getNextEmptyOrOpener(tokenizer);
     if(nextToken == "EMPTY") {
-        return std::unique_ptr<Polygon>(geometryFactory->createPolygon(nullptr, nullptr));
+        return std::unique_ptr<Polygon>(geometryFactory->createPolygon());
     std::vector<std::unique_ptr<LinearRing>> holes;
commit eef7fa11856e63d9836c31a0b7ecfe688af71440
Date:   Sun Sep 15 16:58:55 2019 -0400
    Simplify ConvexHull::lineOrPolygon
    Avoid converting back and forth between managed and raw pointers.
diff --git a/src/algorithm/ConvexHull.cpp b/src/algorithm/ConvexHull.cpp
index 3e8b7be..2fd08b3 100644
--- a/src/algorithm/ConvexHull.cpp
+++ b/src/algorithm/ConvexHull.cpp
@@ -346,12 +346,11 @@ ConvexHull::lineOrPolygon(const Coordinate::ConstVect& input)
     if(cleaned.size() == 3) { // shouldn't this be 2 ??
         cleaned.resize(2);
         auto cl1 = toCoordinateSequence(cleaned);
-        std::unique_ptr<Geometry> ret(geomFactory->createLineString(cl1.release()));
-        return ret;
+        return geomFactory->createLineString(std::move(cl1));
     auto cl2 = toCoordinateSequence(cleaned);
-    LinearRing* linearRing = geomFactory->createLinearRing(cl2.release());
-    return std::unique_ptr<Geometry>(geomFactory->createPolygon(linearRing, nullptr));
+    std::unique_ptr<LinearRing> linearRing = geomFactory->createLinearRing(std::move(cl2));
+    return geomFactory->createPolygon(std::move(linearRing));
 /*private*/
Summary of changes:
 src/algorithm/ConvexHull.cpp                     | 7 +++----
 src/io/WKTReader.cpp                             | 2 +-
 src/triangulate/quadedge/QuadEdgeSubdivision.cpp | 5 ++---
 3 files changed, 6 insertions(+), 8 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
