[geos-commits] [SCM] GEOS branch master updated. 9e79f3db1f677feb0309ddae8f900cf0c38f971e
Mon Sep 16 13:15:32 PDT 2019
the project "GEOS".
       via  9e79f3db1f677feb0309ddae8f900cf0c38f971e (commit)
      from  326b89e67bc082a0708ced2f10ea646ff93bee2d (commit)
revisions in full, below.
commit 9e79f3db1f677feb0309ddae8f900cf0c38f971e
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri Sep 13 19:52:44 2019 -0400
    Register individual tests with ctest
    Allows running of a single XML file or TUT test group.
    Fixes #930
diff --git a/README.md b/README.md
index 63124fe..b37f684 100644
--- a/README.md
+++ b/README.md
@@ -57,8 +57,13 @@ Setting `CMAKE_BUILD_TYPE` to `Release` is necessary to enable compiler
 optimizations.
 Once the `cmake` tool has run, GEOS can be built by running `make` and
-installed by running `make install`. The test suite can be run using `make
-check`.
+installed by running `make install`.
+The entire test suite can be run using `make check`.
+Alternatively, the `ctest` command can be used, which provides more control over test execution.
+For example, `ctest -R unit-capi -j2` uses a regular expression to run all tests
+associated with the C API, using two processes in parallel.
+A list of available tests can be obtained using `ctest -N`.
 ### Microsoft Windows
diff --git a/tests/unit/CMakeLists.txt b/tests/unit/CMakeLists.txt
index a36e227..a72fd10 100644
--- a/tests/unit/CMakeLists.txt
+++ b/tests/unit/CMakeLists.txt
@@ -2,6 +2,7 @@
 # Part of CMake configuration for GEOS
 # Copyright (C) 2018 Mateusz Loskot <mateusz at loskot.net>
+# Copyright (C) 2019 Daniel Baston <dbaston at gmail.com>
 # This is free software; you can redistribute and/or modify it under
 # the terms of the GNU Lesser General Public Licence as published
@@ -17,4 +18,16 @@ target_include_directories(test_geos_unit
   PRIVATE
     $<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>)
-add_test(NAME test_unit COMMAND test_geos_unit)
+file(GLOB_RECURSE _testfiles ${CMAKE_CURRENT_LIST_DIR}/**/*.cpp CONFIGURE_DEPEND)
+foreach(_testfile ${_testfiles})
+    string(REPLACE ${CMAKE_CURRENT_LIST_DIR}/ "" _testname ${_testfile})
+    string(REPLACE "Test.cpp" "" _testname ${_testname})
+    string(REPLACE "/" "-" _cmake_testname  ${_testname})
+    string(REPLACE "/" "::" _testname ${_testname})
+    add_test(NAME unit-${_cmake_testname} COMMAND test_geos_unit ${_testname})
+endforeach()
+unset(_cmake_testname)
+unset(_testfile)
+unset(_testfiles)
+unset(_testname)
diff --git a/tests/xmltester/CMakeLists.txt b/tests/xmltester/CMakeLists.txt
index f334d0d..97a3d7f 100644
--- a/tests/xmltester/CMakeLists.txt
+++ b/tests/xmltester/CMakeLists.txt
@@ -2,6 +2,7 @@
@@ -23,7 +24,14 @@ target_include_directories(test_xmltester
   PRIVATE
     $<BUILD_INTERFACE:${CMAKE_CURRENT_LIST_DIR}>/tinyxml)
-file(GLOB_RECURSE _tests ${CMAKE_CURRENT_LIST_DIR}/tests/*.xml CONFIGURE_DEPEND)
-list(FILTER _tests EXCLUDE REGEX failure)
-add_test(NAME test_xml COMMAND test_xmltester --test-valid-output ${_tests})
-unset(_tests)
+foreach(_testdir general issue misc robust validate)
+    file(GLOB_RECURSE _testfiles ${CMAKE_CURRENT_LIST_DIR}/tests/${_testdir}/*.xml CONFIGURE_DEPEND)
+    foreach(_testfile ${_testfiles})
+        get_filename_component(_testname ${_testfile} NAME_WE)
+        add_test(NAME ${_testdir}-${_testname} COMMAND test_xmltester --test-valid-output ${_testfile})
+    endforeach()
+endforeach()
+unset(_testdir)
+unset(_testname)
+unset(_testfile)
+unset(_testfiles)
Summary of changes:
 README.md                      |  9 +++++++--
 tests/unit/CMakeLists.txt      | 15 ++++++++++++++-
 tests/xmltester/CMakeLists.txt | 16 ++++++++++++----
 3 files changed, 33 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
