[geos-commits] [SCM] GEOS branch master updated. d07995369d961ff0ef3bad854dc3bdc05a904e9d
Tue Sep 17 19:05:02 PDT 2019
the project "GEOS".
       via  d07995369d961ff0ef3bad854dc3bdc05a904e9d (commit)
      from  f48babc898d5d267ae686378e17ead3f2aa6e0c0 (commit)
revisions in full, below.
commit d07995369d961ff0ef3bad854dc3bdc05a904e9d
Author: Daniel Baston <dbaston at gmail.com>
Date:   Tue Sep 17 22:04:08 2019 -0400
    Avoid heap alloc in GeometryNoder::toGeometry
diff --git a/src/noding/GeometryNoder.cpp b/src/noding/GeometryNoder.cpp
index 8a4bf13..afba323 100644
--- a/src/noding/GeometryNoder.cpp
+++ b/src/noding/GeometryNoder.cpp
@@ -98,22 +98,19 @@ GeometryNoder::toGeometry(SegmentString::NonConstVect& nodedEdges)
     std::set< OrientedCoordinateArray > ocas;
     // Create a geometry out of the noded substrings.
-    std::vector< geom::Geometry* >* lines = new std::vector< geom::Geometry* >();
-    lines->reserve(nodedEdges.size());
+    std::vector<std::unique_ptr<geom::Geometry>> lines;
+    lines.reserve(nodedEdges.size());
     for(auto& ss :  nodedEdges) {
         const geom::CoordinateSequence* coords = ss->getCoordinates();
         // Check if an equivalent edge is known
         OrientedCoordinateArray oca1(*coords);
         if(ocas.insert(oca1).second) {
-            geom::Geometry* tmp = geomFact->createLineString(coords->clone().release());
-            lines->push_back(tmp);
+            lines.push_back(geomFact->createLineString(coords->clone()));
-    std::unique_ptr<geom::Geometry> noded(geomFact->createMultiLineString(lines));
-    return noded;
+    return geomFact->createMultiLineString(std::move(lines));
 /* public */
Summary of changes:
 src/noding/GeometryNoder.cpp | 11 ++++-------
 1 file changed, 4 insertions(+), 7 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
