[geos-commits] [SCM] GEOS branch master updated. 0c17f05ad648f8c62352f7ff6998b4ffb6661861
Wed Sep 18 20:09:12 PDT 2019
the project "GEOS".
       via  0c17f05ad648f8c62352f7ff6998b4ffb6661861 (commit)
       via  48eb7bc8fd595a2cbae9d0f5ef25a01f89fe7557 (commit)
       via  e9ca63a3a3d2243bcdadcc5cd591917268482a82 (commit)
      from  10b58fc8482345800fe377e7cd8697c92ac2ece1 (commit)
revisions in full, below.
commit 0c17f05ad648f8c62352f7ff6998b4ffb6661861
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Sep 18 23:05:29 2019 -0400
    Fix CMake inference of test suite name from file name
diff --git a/tests/unit/CMakeLists.txt b/tests/unit/CMakeLists.txt
index 024f599..e8052a7 100644
--- a/tests/unit/CMakeLists.txt
+++ b/tests/unit/CMakeLists.txt
@@ -24,7 +24,9 @@ foreach(_testfile ${_testfiles})
     string(REPLACE "Test.cpp" "" _testname ${_testname})
     string(REPLACE "/" "-" _cmake_testname  ${_testname})
     string(REPLACE "/" "::" _testname ${_testname})
-    string(CONCAT _testname "geos::" ${_testname})
+    if (NOT ${_testname} MATCHES "^capi::")
+      string(CONCAT _testname "geos::" ${_testname})
+    endif()
     add_test(NAME unit-${_cmake_testname} COMMAND test_geos_unit ${_testname})
 endforeach()
 unset(_cmake_testname)
commit 48eb7bc8fd595a2cbae9d0f5ef25a01f89fe7557
Date:   Wed Sep 18 22:48:30 2019 -0400
    Standardize test file naming
    Test file names should end in "Test.cpp"
    Test suite names should match test file names
index a72fd10..024f599 100644
@@ -24,6 +24,7 @@ foreach(_testfile ${_testfiles})
 endforeach()
diff --git a/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp b/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp
index da8d076..bbe2f38 100644
--- a/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp
@@ -33,7 +33,7 @@ struct test_computeorientation_data {
 typedef test_group<test_computeorientation_data> group;
 typedef group::object object;
-group test_computeorientation_group("geos::algorithm::Orientation::index");
+group test_computeorientation_group("geos::algorithm::CGAlgorithms::computeOrientation");
 // Test Cases
diff --git a/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp b/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
index eaa4004..e972776 100644
--- a/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
@@ -46,7 +46,7 @@ struct test_isccw_data {
 typedef test_group<test_isccw_data> group;
-group test_isccw_group("geos::algorithm::Orientation::isCCW");
+group test_isccw_group("geos::algorithm::CGAlgorithms::isCCW");
 // Test Cases
diff --git a/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp b/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp
index 53bb741..2b485e4 100644
--- a/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp
@@ -41,7 +41,7 @@ struct test_ispointinring_data {
 typedef test_group<test_ispointinring_data> group;
-group test_ispointintring_group("geos::algorithm::PointLocation::isInRing");
+group test_ispointintring_group("geos::algorithm::CGAlgorithms::isPointInRing");
 // Test Cases
diff --git a/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp b/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp
index 5d2b370..e75d614 100644
--- a/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp
@@ -45,7 +45,7 @@ struct test_signedarea_data {
 typedef test_group<test_signedarea_data> group;
-group test_signedarea_group("geos::algorithm::Area::ofRingSigned");
+group test_signedarea_group("geos::algorithm::CGAlgorithms::signedArea");
 // Test Cases
diff --git a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
index 039045f..203657d 100644
--- a/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp
@@ -82,7 +82,7 @@ const double test_DiscreteFrechetDistance_data::TOLERANCE = 0.00001;
 typedef test_group<test_DiscreteFrechetDistance_data> group;
-group test_DiscreteFrechetDistance_group("geos::algorithm::distace::DiscreteFrechetDistance");
+group test_DiscreteFrechetDistance_group("geos::algorithm::distance::DiscreteFrechetDistance");
diff --git a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
index 4c9aa94..4479f43 100644
--- a/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
+++ b/tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp
@@ -83,7 +83,7 @@ const double test_DiscreteHausdorffDistance_data::TOLERANCE = 0.00001;
 typedef test_group<test_DiscreteHausdorffDistance_data> group;
-group test_DiscreteHausdorffDistance_group("geos::algorithm::distace::DiscreteHausdorffDistance");
+group test_DiscreteHausdorffDistance_group("geos::algorithm::distance::DiscreteHausdorffDistance");
diff --git a/tests/unit/capi/GEOSBuildArea.cpp b/tests/unit/capi/GEOSBuildAreaTest.cpp
similarity index 100%
rename from tests/unit/capi/GEOSBuildArea.cpp
rename to tests/unit/capi/GEOSBuildAreaTest.cpp
diff --git a/tests/unit/capi/GEOSCAPIDefinesTest.cpp b/tests/unit/capi/GEOSCAPIDefinesTest.cpp
index 4f72373..d331e55 100644
--- a/tests/unit/capi/GEOSCAPIDefinesTest.cpp
+++ b/tests/unit/capi/GEOSCAPIDefinesTest.cpp
@@ -23,7 +23,7 @@ struct basic {};
 typedef test_group<basic> group;
-group test_capidefines_group("capi::defines");
+group test_capidefines_group("capi::GEOSCAPIDefines");
 // Make sure version elements all defined
 template<>
diff --git a/tests/unit/capi/GEOSGeom_createCollection.cpp b/tests/unit/capi/GEOSGeom_createCollectionTest.cpp
rename from tests/unit/capi/GEOSGeom_createCollection.cpp
rename to tests/unit/capi/GEOSGeom_createCollectionTest.cpp
diff --git a/tests/unit/capi/GEOSGeom_create.cpp b/tests/unit/capi/GEOSGeom_createTest.cpp
rename from tests/unit/capi/GEOSGeom_create.cpp
rename to tests/unit/capi/GEOSGeom_createTest.cpp
diff --git a/tests/unit/capi/GEOSGeom_extentTest.cpp b/tests/unit/capi/GEOSGeom_extentTest.cpp
index 637c20c..c5681b2 100644
--- a/tests/unit/capi/GEOSGeom_extentTest.cpp
+++ b/tests/unit/capi/GEOSGeom_extentTest.cpp
@@ -39,7 +39,7 @@ struct test_capigeosgeom_extent {
 typedef test_group<test_capigeosgeom_extent> group;
-group test_capigeosgeom_extent_group("capi::GEOSGeom_getXYMinMax");
+group test_capigeosgeom_extent_group("capi::GEOSGeom_extent");
 template<>
 template<>
diff --git a/tests/unit/capi/GEOSLineString_PointTest.cpp b/tests/unit/capi/GEOSLineString_PointTest.cpp
index 1c57f9c..76bc5fd 100644
--- a/tests/unit/capi/GEOSLineString_PointTest.cpp
+++ b/tests/unit/capi/GEOSLineString_PointTest.cpp
@@ -49,7 +49,7 @@ struct test_capilinestringpoint_data {
 typedef test_group<test_capilinestringpoint_data> group;
-group test_capilinestringpoint_group("capi::GEOSLineStringPoint");
+group test_capilinestringpoint_group("capi::GEOSLineString_Point");
 // Test Cases
diff --git a/tests/unit/capi/GEOSMakeValid.cpp b/tests/unit/capi/GEOSMakeValidTest.cpp
rename from tests/unit/capi/GEOSMakeValid.cpp
rename to tests/unit/capi/GEOSMakeValidTest.cpp
diff --git a/tests/unit/capi/GEOSMinimumRectangleTest.cpp b/tests/unit/capi/GEOSMinimumRectangleTest.cpp
index 49fed1f..647418e 100644
--- a/tests/unit/capi/GEOSMinimumRectangleTest.cpp
+++ b/tests/unit/capi/GEOSMinimumRectangleTest.cpp
@@ -57,7 +57,7 @@ struct test_capigeosminimumrectangle_data {
 typedef test_group<test_capigeosminimumrectangle_data> group;
-group test_capigeosminimumrectangle_group("capi::GEOSMinimumRotatedRectangle");
+group test_capigeosminimumrectangle_group("capi::GEOSMinimumRectangle");
 // Test Cases
diff --git a/tests/unit/capi/GEOSOrientationIndex.cpp b/tests/unit/capi/GEOSOrientationIndexTest.cpp
rename from tests/unit/capi/GEOSOrientationIndex.cpp
rename to tests/unit/capi/GEOSOrientationIndexTest.cpp
diff --git a/tests/unit/geom/Geometry/clone.cpp b/tests/unit/geom/Geometry/cloneTest.cpp
rename from tests/unit/geom/Geometry/clone.cpp
rename to tests/unit/geom/Geometry/cloneTest.cpp
diff --git a/tests/unit/geom/Geometry/normalize.cpp b/tests/unit/geom/Geometry/normalizeTest.cpp
rename from tests/unit/geom/Geometry/normalize.cpp
rename to tests/unit/geom/Geometry/normalizeTest.cpp
diff --git a/tests/unit/linearref/LengthIndexedLineTest.cpp b/tests/unit/linearref/LengthIndexedLineTest.cpp
index 875f567..2fd9034 100644
--- a/tests/unit/linearref/LengthIndexedLineTest.cpp
+++ b/tests/unit/linearref/LengthIndexedLineTest.cpp
@@ -153,7 +153,7 @@ struct test_lengthindexedline_data {
 typedef test_group<test_lengthindexedline_data> group;
-group test_lengthindexedline_group("geos::linearref::LocationIndexedLine");
+group test_lengthindexedline_group("geos::linearref::LengthIndexedLine");
 // testML
 template<>
diff --git a/tests/unit/noding/OrientedCoordinateArray.cpp b/tests/unit/noding/OrientedCoordinateArrayTest.cpp
rename from tests/unit/noding/OrientedCoordinateArray.cpp
rename to tests/unit/noding/OrientedCoordinateArrayTest.cpp
diff --git a/tests/unit/operation/union/CascadedPolygonUnionTest.cpp b/tests/unit/operation/geounion/CascadedPolygonUnionTest.cpp
rename from tests/unit/operation/union/CascadedPolygonUnionTest.cpp
rename to tests/unit/operation/geounion/CascadedPolygonUnionTest.cpp
diff --git a/tests/unit/operation/union/CoverageUnionTest.cpp b/tests/unit/operation/geounion/CoverageUnionTest.cpp
rename from tests/unit/operation/union/CoverageUnionTest.cpp
rename to tests/unit/operation/geounion/CoverageUnionTest.cpp
diff --git a/tests/unit/operation/union/UnaryUnionOpTest.cpp b/tests/unit/operation/geounion/UnaryUnionOpTest.cpp
rename from tests/unit/operation/union/UnaryUnionOpTest.cpp
rename to tests/unit/operation/geounion/UnaryUnionOpTest.cpp
diff --git a/tests/unit/operation/overlay/OverlayOpUnionTest.cpp b/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
index ff2abb9..672d008 100644
--- a/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
+++ b/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
@@ -31,7 +31,7 @@ struct test_overlayopunion_data {
 typedef test_group<test_overlayopunion_data> group;
-group test_overlayopunion_group("geos::operation::OverlayOp::UNION");
+group test_overlayopunion_group("geos::operation::overlay::OverlayOpUnion");
 // Test Cases
diff --git a/tests/unit/operation/polygonize/PolygonizeTest.cpp b/tests/unit/operation/polygonize/PolygonizeTest.cpp
index 933dcc2..62a35a5 100644
--- a/tests/unit/operation/polygonize/PolygonizeTest.cpp
+++ b/tests/unit/operation/polygonize/PolygonizeTest.cpp
@@ -144,7 +144,7 @@ struct test_polygonizetest_data {
 typedef test_group<test_polygonizetest_data> group;
-group test_polygonizetest_group("geos::operation::polygonize::Polygonizer");
+group test_polygonizetest_group("geos::operation::polygonize::Polygonize");
 // test1() in JTS
 template<>
diff --git a/tests/unit/operation/valid/IsValidTest.cpp b/tests/unit/operation/valid/IsValidOpTest.cpp
rename from tests/unit/operation/valid/IsValidTest.cpp
rename to tests/unit/operation/valid/IsValidOpTest.cpp
commit e9ca63a3a3d2243bcdadcc5cd591917268482a82
Date:   Wed Sep 18 22:39:58 2019 -0400
    Make geos_unit return 1 when called with non-existent test name
diff --git a/tests/unit/geos_unit.cpp b/tests/unit/geos_unit.cpp
index e4cf7c5..d5a5118 100644
--- a/tests/unit/geos_unit.cpp
+++ b/tests/unit/geos_unit.cpp
@@ -103,6 +103,7 @@ main(int argc, const char* argv[])
     catch(const std::exception& ex) {
         std::cerr << "!!! GEOS Test Suite raised exception: " << ex.what() << std::endl;
+        return EXIT_FAILURE;
     // XXX - mloskot - this should be removed in future!
Summary of changes:
 tests/unit/CMakeLists.txt                                              | 3 +++
 tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp           | 2 +-
 tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp                        | 2 +-
 tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp                | 2 +-
 tests/unit/algorithm/CGAlgorithms/signedAreaTest.cpp                   | 2 +-
 tests/unit/algorithm/distance/DiscreteFrechetDistanceTest.cpp          | 2 +-
 tests/unit/algorithm/distance/DiscreteHausdorffDistanceTest.cpp        | 2 +-
 tests/unit/capi/{GEOSBuildArea.cpp => GEOSBuildAreaTest.cpp}           | 0
 tests/unit/capi/GEOSCAPIDefinesTest.cpp                                | 2 +-
 ...GEOSGeom_createCollection.cpp => GEOSGeom_createCollectionTest.cpp} | 0
 tests/unit/capi/{GEOSGeom_create.cpp => GEOSGeom_createTest.cpp}       | 0
 tests/unit/capi/GEOSGeom_extentTest.cpp                                | 2 +-
 tests/unit/capi/GEOSLineString_PointTest.cpp                           | 2 +-
 tests/unit/capi/{GEOSMakeValid.cpp => GEOSMakeValidTest.cpp}           | 0
 tests/unit/capi/GEOSMinimumRectangleTest.cpp                           | 2 +-
 .../capi/{GEOSOrientationIndex.cpp => GEOSOrientationIndexTest.cpp}    | 0
 tests/unit/geom/Geometry/{clone.cpp => cloneTest.cpp}                  | 0
 tests/unit/geom/Geometry/{normalize.cpp => normalizeTest.cpp}          | 0
 tests/unit/geos_unit.cpp                                               | 1 +
 tests/unit/linearref/LengthIndexedLineTest.cpp                         | 2 +-
 .../{OrientedCoordinateArray.cpp => OrientedCoordinateArrayTest.cpp}   | 0
 tests/unit/operation/{union => geounion}/CascadedPolygonUnionTest.cpp  | 0
 tests/unit/operation/{union => geounion}/CoverageUnionTest.cpp         | 0
 tests/unit/operation/{union => geounion}/UnaryUnionOpTest.cpp          | 0
 tests/unit/operation/overlay/OverlayOpUnionTest.cpp                    | 2 +-
 tests/unit/operation/polygonize/PolygonizeTest.cpp                     | 2 +-
 tests/unit/operation/valid/{IsValidTest.cpp => IsValidOpTest.cpp}      | 0
 27 files changed, 17 insertions(+), 13 deletions(-)
 rename tests/unit/capi/{GEOSBuildArea.cpp => GEOSBuildAreaTest.cpp} (100%)
 rename tests/unit/capi/{GEOSGeom_createCollection.cpp => GEOSGeom_createCollectionTest.cpp} (100%)
 rename tests/unit/capi/{GEOSGeom_create.cpp => GEOSGeom_createTest.cpp} (100%)
 rename tests/unit/capi/{GEOSMakeValid.cpp => GEOSMakeValidTest.cpp} (100%)
 rename tests/unit/capi/{GEOSOrientationIndex.cpp => GEOSOrientationIndexTest.cpp} (100%)
 rename tests/unit/geom/Geometry/{clone.cpp => cloneTest.cpp} (100%)
 rename tests/unit/geom/Geometry/{normalize.cpp => normalizeTest.cpp} (100%)
 rename tests/unit/noding/{OrientedCoordinateArray.cpp => OrientedCoordinateArrayTest.cpp} (100%)
 rename tests/unit/operation/{union => geounion}/CascadedPolygonUnionTest.cpp (100%)
 rename tests/unit/operation/{union => geounion}/CoverageUnionTest.cpp (100%)
 rename tests/unit/operation/{union => geounion}/UnaryUnionOpTest.cpp (100%)
 rename tests/unit/operation/valid/{IsValidTest.cpp => IsValidOpTest.cpp} (100%)
hooks/post-receive
More information about the geos-commits mailing list
