[geos-commits] [SCM] GEOS branch master updated. a71e095d304d13c071e5144f128fe37680e6c47b
Wed Sep 25 11:34:02 PDT 2019
the project "GEOS".
       via  a71e095d304d13c071e5144f128fe37680e6c47b (commit)
       via  292fe67d954d3e3f5e901459f10a01f84051a992 (commit)
       via  5ceeb1d2918a6f078571190912271cb57e4085d3 (commit)
      from  f453c48a6d6cb0ab023caa74a8260802d16c98ef (commit)
revisions in full, below.
commit a71e095d304d13c071e5144f128fe37680e6c47b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Sep 25 11:16:37 2019 -0700
    No symlinks on libgeos, only on libgeos_c
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 76aeca3..48258ee 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -106,9 +106,6 @@ set(CAPI_VERSION_MAJOR ${_version_capi_major})
 set(CAPI_VERSION_MINOR ${_version_capi_age})
 set(CAPI_VERSION_PATCH ${_version_capi_revision})
 set(CAPI_VERSION "${_version_capi_major}.${_version_capi_age}.${_version_capi_revision}")
-if(NOT WIN32)
-  set(CAPI_SOVERSION ${_version_capi_age})
-endif()
 unset(_version_capi_current)
 unset(_version_capi_major)
@@ -230,9 +227,7 @@ if(BUILD_SHARED_LIBS)
     PRIVATE $<$<CXX_COMPILER_ID:MSVC>:GEOS_DLL_EXPORT>)
   set_target_properties(geos PROPERTIES VERSION ${GEOS_VERSION})
-  if(NOT WIN32)
-    set_target_properties(geos PROPERTIES SOVERSION ${GEOS_VERSION_MAJOR})
-  endif()
+  set_target_properties(geos PROPERTIES SOVERSION ${GEOS_VERSION})
 endif()
@@ -284,12 +279,21 @@ configure_file(cmake/geos-config.cmake
   "${CMAKE_CURRENT_BINARY_DIR}/geos-config.cmake"
   COPYONLY)
-install(TARGETS geos geos_c geos_cxx_flags
+install(TARGETS geos geos_cxx_flags
+  EXPORT geos-targets
+  LIBRARY DESTINATION lib NAMELINK_SKIP
+  ARCHIVE DESTINATION lib
+  RUNTIME DESTINATION bin
+  INCLUDES DESTINATION include
+install(TARGETS geos_c
   EXPORT geos-targets
-  INCLUDES DESTINATION include)
 install(EXPORT geos-targets
   FILE geos-targets.cmake
commit 292fe67d954d3e3f5e901459f10a01f84051a992
Date:   Wed Sep 25 09:20:05 2019 -0700
    Uncomment the mapping of GEOS_VERSION to VERSION for geos_c.h generation
diff --git a/capi/CMakeLists.txt b/capi/CMakeLists.txt
index 164064c..529869d 100644
--- a/capi/CMakeLists.txt
+++ b/capi/CMakeLists.txt
@@ -18,10 +18,12 @@ target_include_directories(geos_c
     $<BUILD_INTERFACE:${CMAKE_CURRENT_BINARY_DIR}>
     $<INSTALL_INTERFACE:include/geos>)
-# set(VERSION ${CAPI_VERSION})
-# set(VERSION_MAJOR ${CAPI_VERSION_MINOR})
-# set(VERSION_MINOR ${CAPI_VERSION_MINOR})
-# set(VERSION_PATCH ${CAPI_VERSION_PATCH})
+# Copy these over so they match the @VARIABLES@ used by autoconf
+# in geos_c.h.in
+set(VERSION ${GEOS_VERSION})
+set(VERSION_MAJOR ${GEOS_VERSION_MAJOR})
+set(VERSION_MINOR ${GEOS_VERSION_MINOR})
+set(VERSION_PATCH ${GEOS_VERSION_PATCH})
 configure_file(
   ${CMAKE_CURRENT_LIST_DIR}/geos_c.h.in
commit 5ceeb1d2918a6f078571190912271cb57e4085d3
Date:   Tue Sep 24 19:39:48 2019 -0700
    Harmonize cmake install names with autotools
    Make sure geos_c uses capi version numbers
index 625f51d..76aeca3 100644
@@ -141,7 +141,7 @@ unset(_version_patch)
 unset(_version_patch_word)
 message(STATUS "GEOS: Version ${GEOS_VERSION_FULL}")
-message(STATUS "GEOS: C API soversion ${CAPI_SOVERSION}")
+message(STATUS "GEOS: C API Version ${CAPI_VERSION}")
 message(STATUS "GEOS: JTS port ${JTS_PORT}")
@@ -245,9 +245,9 @@ if(BUILD_SHARED_LIBS)
   target_compile_definitions(geos_c
-  set_target_properties(geos_c PROPERTIES VERSION ${GEOS_VERSION})
+  set_target_properties(geos_c PROPERTIES VERSION ${CAPI_VERSION})
   if(NOT WIN32)
-    set_target_properties(geos_c PROPERTIES SOVERSION ${GEOS_VERSION_MAJOR})
+    set_target_properties(geos_c PROPERTIES SOVERSION ${CAPI_VERSION_MAJOR})
   endif()
 endif()
index d4bbb00..164064c 100644
@@ -18,10 +18,10 @@ target_include_directories(geos_c
-set(VERSION ${GEOS_VERSION})
-set(VERSION_MAJOR ${GEOS_VERSION_MAJOR})
-set(VERSION_MINOR ${GEOS_VERSION_MINOR})
-set(VERSION_PATCH ${GEOS_VERSION_PATCH})
+# set(VERSION ${CAPI_VERSION})
+# set(VERSION_MAJOR ${CAPI_VERSION_MINOR})
+# set(VERSION_MINOR ${CAPI_VERSION_MINOR})
+# set(VERSION_PATCH ${CAPI_VERSION_PATCH})
 configure_file(
Summary of changes:
 CMakeLists.txt      | 26 +++++++++++++++-----------
 capi/CMakeLists.txt |  2 ++
 2 files changed, 17 insertions(+), 11 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
