[geos-commits] [SCM] GEOS branch master updated. 3df362a9d8c04a53bdaae0916c821296641ef6a3
git at osgeo.org
git at osgeo.org
Thu Apr 16 15:32:54 PDT 2020
the project "GEOS".
via 3df362a9d8c04a53bdaae0916c821296641ef6a3 (commit)
via bed36f15c780057ae9b83eb9cd2e8ef6a9ada498 (commit)
from 312c085bdc9606896281c7d0610c1a1b3931e014 (commit)
revisions in full, below.
commit 3df362a9d8c04a53bdaae0916c821296641ef6a3
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Apr 16 15:32:47 2020 -0700
news entry for ttmath retirement
diff --git a/NEWS b/NEWS
index 6c36595..7541806 100644
--- a/NEWS
+++ b/NEWS
@@ -11,6 +11,7 @@ Changes in 3.9.0
and escape paths (https://git.osgeo.org/gitea/geos/geos/pulls/99)
changes mostly affect CMake MSVC builds (#1015, Mike Taves)
- Testing on Rasberry Pi 32-bit (berrie) (#1017, Bruce Rindahl, Regina Obe)
+ - Replace ttmath with JTS DD double-double implementation (Paul Ramsey)
Changes in 3.8.0
commit bed36f15c780057ae9b83eb9cd2e8ef6a9ada498
Date: Thu Apr 16 15:31:11 2020 -0700
Squashed commit of the following:
commit ab1b004af900354f907f9a5d31ec514c2547ada4
Date: Thu Apr 16 14:40:23 2020 -0700
remove ttmath in favour of DD
commit 472c1f9a12df1a4b9628f61c93594ee162382db4
Merge: 8ccf3bf8 312c085b
Date: Thu Apr 16 13:24:39 2020 -0700
Merge branch 'master' of https://git.osgeo.org/gitea/geos/geos into master-dd
commit 8ccf3bf874a2887b40afbaca57ee67b59b5eb40b
Date: Thu Apr 16 13:10:25 2020 -0700
add informational comment
commit 8fd12e02f060f8e35d36a162d81d1ef94da1b784
Date: Thu Apr 16 12:15:00 2020 -0700
add in all JTS unit tests for doubledouble calculations
commit e24af3ba8ce7eca76840164c2edd5e066bbebe28
Date: Wed Apr 15 13:47:56 2020 -0700
autotools build
commit cb5942a13c5113ae42108e0422fed9a34a465abf
Date: Wed Apr 15 13:31:28 2020 -0700
fix doxygen complaint?
commit 469037a4ca75b0f4df3638256c0fff2b61d37796
Date: Wed Apr 15 12:47:14 2020 -0700
change name of ifdef guard
commit 00559ec59b56a0ec6a0481b54f0ab597324d9439
Date: Wed Apr 15 12:40:50 2020 -0700
allow DD to swap in for ttmath
commit 75e70f7f28e751f26cc3db5b4964a86f3bae518f
Date: Wed Apr 15 11:28:15 2020 -0700
clean build of all DD functionality from JTS
commit e42e9bc0ea3fd35bddc892fbe51b3de5677d8e57
Date: Tue Apr 14 17:27:45 2020 -0700
DD wip
diff --git a/.codecov.yml b/.codecov.yml
index cbb62bf..c229399 100644
--- a/.codecov.yml
+++ b/.codecov.yml
@@ -2,7 +2,6 @@ coverage:
precision: 2
ignore:
- - "include/geos/algorithm/ttmath"
- "tests/unit/tut"
- "tests/xmltester/tinyxml2"
diff --git a/Makefile.am b/Makefile.am
index dbc7451..f064d45 100644
--- a/Makefile.am
+++ b/Makefile.am
@@ -73,5 +73,4 @@ valgrindcheck:
check-local:
! find $(srcdir) -name '*.cpp' -o -name '*.h' | \
grep -v tests/xmltester/tinyxml | \
- grep -v include/geos/algorithm/ttmath | \
xargs grep -n '[[:space:]]$$'
diff --git a/configure.ac b/configure.ac
index 7c54d75..1eade62 100644
--- a/configure.ac
+++ b/configure.ac
@@ -376,7 +376,6 @@ AC_OUTPUT([
include/geos/algorithm/Makefile
include/geos/algorithm/locate/Makefile
include/geos/algorithm/distance/Makefile
- include/geos/algorithm/ttmath/Makefile
include/geos/geom/Makefile
include/geos/geom/prep/Makefile
include/geos/geom/util/Makefile
@@ -391,6 +390,7 @@ AC_OUTPUT([
include/geos/index/sweepline/Makefile
include/geos/io/Makefile
include/geos/linearref/Makefile
+ include/geos/math/Makefile
include/geos/noding/Makefile
include/geos/noding/snapround/Makefile
include/geos/operation/Makefile
@@ -423,6 +423,7 @@ AC_OUTPUT([
src/index/sweepline/Makefile
src/io/Makefile
src/linearref/Makefile
+ src/math/Makefile
src/noding/Makefile
src/noding/snapround/Makefile
src/operation/Makefile
diff --git a/doc/Doxyfile.in b/doc/Doxyfile.in
index 6490c2c..0f9d70b 100644
--- a/doc/Doxyfile.in
+++ b/doc/Doxyfile.in
@@ -853,7 +853,6 @@ EXCLUDE_PATTERNS = */examples/* \
*/test/* \
*/bigtest/* \
*/io/markup/* \
- */ttmath/* \
config.h \
acconfig.h \
CoordinateList.cpp \
diff --git a/include/geos/Makefile.am b/include/geos/Makefile.am
index 363494c..e34f56d 100644
--- a/include/geos/Makefile.am
+++ b/include/geos/Makefile.am
@@ -8,6 +8,7 @@ SUBDIRS = \
index \
io \
linearref \
+ math \
noding \
operation \
planargraph \
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index f596466..583532c 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -19,17 +19,7 @@
#ifndef GEOS_ALGORITHM_CGALGORITHMDD_H
#define GEOS_ALGORITHM_CGALGORITHMDD_H
#include <geos/export.h>
-#include <geos/algorithm/ttmath/ttmath.h>
-/// \file CGAlgorithmsDD.h
-/// \brief Close to DoubleDouble equivalent used by JTS
-/// Usage: `ttmath::Big<exponent, mantissa>`
-typedef ttmath::Big<TTMATH_BITS(32), TTMATH_BITS(128)> DD;
-//typedef ttmath::Big<TTMATH_BITS(64), TTMATH_BITS(128)> DD;
-//typedef ttmath::Big<TTMATH_BITS(32), TTMATH_BITS(256)> DD;
-//typedef ttmath::Big<TTMATH_BITS(64), TTMATH_BITS(256)> DD;
+#include <geos/math/DD.h>
// Forward declarations
namespace geos {
@@ -39,6 +29,8 @@ class CoordinateSequence;
+using namespace geos::math;
namespace geos {
namespace algorithm { // geos::algorithm
@@ -139,7 +131,7 @@ public:
* The circumcentre does not necessarily lie within the triangle. For example,
* the circumcentre of an obtuse isosceles triangle lies outside the triangle.
- * This method uses @ref DD extended-precision arithmetic to provide more accurate
+ * This method uses @ref geos::math::DD extended-precision arithmetic to provide more accurate
* results than [circumcentre(Coordinate, Coordinate, Coordinate)]
* (@ref geos::geom::Triangle::circumcentre(const Coordinate& p0, const Coordinate& p1, const Coordinate& p2)).
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index 717e63d..dbd5a61 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -3,8 +3,7 @@
SUBDIRS = \
locate \
- distance \
- ttmath
+ distance
EXTRA_DIST =
diff --git a/include/geos/algorithm/RayCrossingCounterDD.h b/include/geos/algorithm/RayCrossingCounterDD.h
index 2328ab3..d7ba41e 100644
--- a/include/geos/algorithm/RayCrossingCounterDD.h
+++ b/include/geos/algorithm/RayCrossingCounterDD.h
@@ -22,7 +22,6 @@
#include <geos/geom/Location.h>
#include <vector>
diff --git a/include/geos/algorithm/ttmath/COPYRIGHT b/include/geos/algorithm/ttmath/COPYRIGHT
deleted file mode 100644
index 3111d0b..0000000
--- a/include/geos/algorithm/ttmath/COPYRIGHT
+++ /dev/null
@@ -1,28 +0,0 @@
-Copyright (c) 2006-2017, Tomasz Sowa
-All rights reserved.
-Redistribution and use in source and binary forms, with or without
-modification, are permitted provided that the following conditions are met:
- * Redistributions of source code must retain the above copyright notice,
- this list of conditions and the following disclaimer.
- * Redistributions in binary form must reproduce the above copyright
- notice, this list of conditions and the following disclaimer in the
- documentation and/or other materials provided with the distribution.
- * Neither the name Tomasz Sowa nor the names of contributors to this
- project may be used to endorse or promote products derived
- from this software without specific prior written permission.
-THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
-LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
-THE POSSIBILITY OF SUCH DAMAGE.
diff --git a/include/geos/algorithm/ttmath/Makefile.am b/include/geos/algorithm/ttmath/Makefile.am
index e60a3bf..0000000
--- a/include/geos/algorithm/ttmath/Makefile.am
+++ /dev/null
@@ -1,24 +0,0 @@
-# This file is part of project GEOS (http://trac.osgeo.org/geos/)
-SUBDIRS =
-EXTRA_DIST =
-geosdir = $(includedir)/geos/algorithm/ttmath
-geos_HEADERS = \
- ttmath.h \
- ttmathbig.h \
- ttmathdec.h \
- ttmathint.h \
- ttmathmisc.h \
- ttmathobjects.h \
- ttmathparser.h \
- ttmaththreads.h \
- ttmathtypes.h \
- ttmathuint.h \
- ttmathuint_noasm.h \
- ttmathuint_x86.h \
- ttmathuint_x86_64.h \
- ttmathuint_x86_64_msvc.asm
diff --git a/include/geos/algorithm/ttmath/README b/include/geos/algorithm/ttmath/README
index ea5bc1c..0000000
--- a/include/geos/algorithm/ttmath/README
+++ /dev/null
@@ -1,23 +0,0 @@
-A bignum library for C++
-TTMath is a small library which allows one to perform arithmetic operations
-with big unsigned integer, big signed integer and big floating point numbers.
-It provides standard mathematical operations like adding, subtracting,
-multiplying, dividing. With the library also goes a mathematical parser to
-help you solving mathematical expressions.
-TTMath is developed under the BSD licence which means that it is free for
-both personal and commercial use.
-The main goal of the library is to allow one to use big values in the same
-way as the standard types like int or float. It does not need to be compiled
-first because the whole library is written as the C++ templates. This means
-only C++ developers can use this library and one thing they have to do is
-to use 'include' directive of the preprocessor. How big the values can be
-is set at compile time.
-Author: Tomasz Sowa <t.sowa at ttmath.org>
-WWW: http://www.ttmath.org
-Contributors:
-Christian Kaiser <chk at online.de>
diff --git a/include/geos/algorithm/ttmath/ttmath.h b/include/geos/algorithm/ttmath/ttmath.h
index 94630a7..0000000
--- a/include/geos/algorithm/ttmath/ttmath.h
+++ /dev/null
@@ -1,2880 +0,0 @@
- * This file is a part of TTMath Bignum Library
- * and is distributed under the 3-Clause BSD Licence.
- * Author: Tomasz Sowa <t.sowa at ttmath.org>
- * Copyright (c) 2006-2017, Tomasz Sowa
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- * * Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * * Neither the name Tomasz Sowa nor the names of contributors to this
- * project may be used to endorse or promote products derived
- * from this software without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
- * THE POSSIBILITY OF SUCH DAMAGE.
-#ifndef headerfilettmathmathtt
-#define headerfilettmathmathtt
- \file ttmath.h
- \brief Mathematics functions.
-#ifdef _MSC_VER
-//warning C4127: conditional expression is constant
-#pragma warning( disable: 4127 )
-//warning C4702: unreachable code
-#pragma warning( disable: 4702 )
-//warning C4800: forcing value to bool 'true' or 'false' (performance warning)
-#pragma warning( disable: 4800 )
-#endif
-#include "ttmathbig.h"
-#include "ttmathobjects.h"
-namespace ttmath
- * functions defined here are used only with Big<> types
- * functions for rounding
- this function skips the fraction from x
- samples
- - 2.2 = 2
- - 2.7 = 2
- - -2.2 = 2
- - -2.7 = 2
- template<class ValueType>
- ValueType SkipFraction(const ValueType & x)
- ValueType result( x );
- result.SkipFraction();
- return result;
- this function rounds to the nearest integer value
- samples
- - 2.2 = 2
- - 2.7 = 3
- - -2.2 = -2
- - -2.7 = -3
- ValueType Round(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- *err = err_improper_argument;
- return x; // NaN
- uint c = result.Round();
- if( err )
- *err = c ? err_overflow : err_ok;
- return result;
- this function returns a value representing the smallest integer
- that is greater than or equal to x
- - Ceil(-3.7) = -3
- - Ceil(-3.1) = -3
- - Ceil(-3.0) = -3
- - Ceil(4.0) = 4
- - Ceil(4.2) = 5
- - Ceil(4.8) = 5
- ValueType Ceil(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- ValueType result(x);
- uint c = 0;
- if( result != x )
- // x is with fraction
- // if x is negative we don't have to do anything
- if( !x.IsSign() )
- ValueType one;
- one.SetOne();
- c += result.Add(one);
- if( err )
- return result;
- this function returns a value representing the largest integer
- that is less than or equal to x
- - Floor(-3.6) = -4
- - Floor(-3.1) = -4
- - Floor(-3) = -3
- - Floor(2) = 2
- - Floor(2.3) = 2
- - Floor(2.8) = 2
- ValueType Floor(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- uint c = 0;
- if( result != x )
- // if x is positive we don't have to do anything
- if( x.IsSign() )
- ValueType one;
- one.SetOne();
- c += result.Sub(one);
- if( err )
- return result;
- * logarithms and the exponent
- this function calculates the natural logarithm (logarithm with the base 'e')
- ValueType Ln(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- ValueType result;
- uint state = result.Ln(x);
- if( err )
- switch( state )
- case 0:
- *err = err_ok;
- break;
- case 1:
- *err = err_overflow;
- break;
- case 2:
- break;
- default:
- *err = err_internal_error;
- break;
- return result;
- this function calculates the logarithm
- ValueType Log(const ValueType & x, const ValueType & base, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err ) *err = err_improper_argument;
- return x;
- if( base.IsNan() )
- return base;
- ValueType result;
- uint state = result.Log(x, base);
- if( err )
- switch( state )
- case 0:
- *err = err_ok;
- break;
- case 1:
- break;
- case 2:
- case 3:
- break;
- default:
- break;
- return result;
- this function calculates the expression e^x
- ValueType Exp(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- ValueType result;
- uint c = result.Exp(x);
- if( err )
- return result;
- * trigonometric functions
- this namespace consists of auxiliary functions
- (something like 'private' in a class)
- this is excluded from doxygen documentation
- (option EXCLUDE_SYMBOLS in doxygen.cfg)
- namespace auxiliaryfunctions
- an auxiliary function for calculating the Sine
- (you don't have to call this function)
- uint PrepareSin(ValueType & x, bool & change_sign)
- ValueType temp;
- change_sign = false;
- if( x.IsSign() )
- // we're using the formula 'sin(-x) = -sin(x)'
- change_sign = !change_sign;
- x.ChangeSign();
- // we're reducing the period 2*PI
- // (for big values there'll always be zero)
- temp.Set2Pi();
- if( x.Mod(temp) )
- return 1;
- // we're setting 'x' as being in the range of <0, 0.5PI>
- temp.SetPi();
- if( x > temp )
- // x is in (pi, 2*pi>
- x.Sub( temp );
- temp.Set05Pi();
- if( x > temp )
- // x is in (0.5pi, pi>
- x.Sub( temp );
- x = temp - x;
- return 0;
- it returns Sin(x) where 'x' is from <0, PI/2>
- we're calculating the Sin with using Taylor series in zero or PI/2
- (depending on which point of these two points is nearer to the 'x')
- Taylor series:
- sin(x) = sin(a) + cos(a)*(x-a)/(1!)
- - sin(a)*((x-a)^2)/(2!) - cos(a)*((x-a)^3)/(3!)
- + sin(a)*((x-a)^4)/(4!) + ...
- when a=0 it'll be:
- sin(x) = (x)/(1!) - (x^3)/(3!) + (x^5)/(5!) - (x^7)/(7!) + (x^9)/(9!) ...
- and when a=PI/2:
- sin(x) = 1 - ((x-PI/2)^2)/(2!) + ((x-PI/2)^4)/(4!) - ((x-PI/2)^6)/(6!) ...
- ValueType Sin0pi05(const ValueType & x)
- ValueType result;
- ValueType numerator, denominator;
- ValueType d_numerator, d_denominator;
- ValueType one, temp, old_result;
- // temp = pi/4
- temp.Set05Pi();
- temp.exponent.SubOne();
- one.SetOne();
- if( x < temp )
- // we're using the Taylor series with a=0
- result = x;
- numerator = x;
- denominator = one;
- // d_numerator = x^2
- d_numerator = x;
- d_numerator.Mul(x);
- d_denominator = 2;
- else
- // we're using the Taylor series with a=PI/2
- result = one;
- numerator = one;
- // d_numerator = (x-pi/2)^2
- ValueType pi05;
- pi05.Set05Pi();
- temp = x;
- temp.Sub( pi05 );
- d_numerator = temp;
- d_numerator.Mul( temp );
- d_denominator = one;
- uint c = 0;
- bool addition = false;
- old_result = result;
- for(uint i=1 ; i<=TTMATH_ARITHMETIC_MAX_LOOP ; ++i)
- // we're starting from a second part of the formula
- c += numerator. Mul( d_numerator );
- c += denominator. Mul( d_denominator );
- c += d_denominator.Add( one );
- temp = numerator;
- c += temp.Div(denominator);
- if( c )
- // Sin is from <-1,1> and cannot make an overflow
- // but the carry can be from the Taylor series
- // (then we only break our calculations)
- break;
- if( addition )
- result.Add( temp );
- else
- result.Sub( temp );
- addition = !addition;
- // we're testing whether the result has changed after adding
- // the next part of the Taylor formula, if not we end the loop
- // (it means 'x' is zero or 'x' is PI/2 or this part of the formula
- // is too small)
- if( result == old_result )
- break;
- return result;
- } // namespace auxiliaryfunctions
- this function calculates the Sine
- ValueType Sin(ValueType x, ErrorCode * err = 0)
- using namespace auxiliaryfunctions;
- ValueType one, result;
- bool change_sign;
- if( x.IsNan() )
- if( err )
- return x;
- if( err )
- *err = err_ok;
- if( PrepareSin( x, change_sign ) )
- // x is too big, we cannnot reduce the 2*PI period
- // prior to version 0.8.5 the result was zero
- // result has NaN flag set by default
- if( err )
- *err = err_overflow; // maybe another error code? err_improper_argument?
- return result; // NaN is set by default
- result = Sin0pi05( x );
- one.SetOne();
- // after calculations there can be small distortions in the result
- if( result > one )
- result = one;
- else
- if( result.IsSign() )
- // we've calculated the sin from <0, pi/2> and the result
- // should be positive
- result.SetZero();
- if( change_sign )
- result.ChangeSign();
- return result;
- this function calulates the Cosine
- we're using the formula cos(x) = sin(x + PI/2)
- ValueType Cos(ValueType x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- ValueType pi05;
- pi05.Set05Pi();
- uint c = x.Add( pi05 );
- if( c )
- if( err )
- return ValueType(); // result is undefined (NaN is set by default)
- return Sin(x, err);
- this function calulates the Tangent
- we're using the formula tan(x) = sin(x) / cos(x)
- it takes more time than calculating the Tan directly
- from for example Taylor series but should be a bit preciser
- because Tan receives its values from -infinity to +infinity
- and when we calculate it from any series then we can make
- a greater mistake than calculating 'sin/cos'
- ValueType Tan(const ValueType & x, ErrorCode * err = 0)
- ValueType result = Cos(x, err);
- if( err && *err != err_ok )
- return result;
- if( result.IsZero() )
- if( err )
- result.SetNan();
- return result;
- return Sin(x, err) / result;
- look at the description of Tan(...)
- (the abbreviation of Tangent can be 'tg' as well)
- ValueType Tg(const ValueType & x, ErrorCode * err = 0)
- return Tan(x, err);
- this function calulates the Cotangent
- we're using the formula tan(x) = cos(x) / sin(x)
- (why do we make it in this way?
- look at information in Tan() function)
- ValueType Cot(const ValueType & x, ErrorCode * err = 0)
- ValueType result = Sin(x, err);
- return result;
- if( err )
- result.SetNan();
- return result;
- return Cos(x, err) / result;
- look at the description of Cot(...)
- (the abbreviation of Cotangent can be 'ctg' as well)
- ValueType Ctg(const ValueType & x, ErrorCode * err = 0)
- return Cot(x, err);
- * inverse trigonometric functions
- an auxiliary function for calculating the Arc Sine
- we're calculating asin from the following formula:
- asin(x) = x + (1*x^3)/(2*3) + (1*3*x^5)/(2*4*5) + (1*3*5*x^7)/(2*4*6*7) + ...
- where abs(x) <= 1
- we're using this formula when x is from <0, 1/2>
- ValueType ASin_0(const ValueType & x)
- ValueType nominator, denominator, nominator_add, nominator_x, denominator_add, denominator_x;
- ValueType two, result(x), x2(x);
- ValueType nominator_temp, denominator_temp, old_result = result;
- uint c = 0;
- x2.Mul(x);
- two = 2;
- nominator.SetOne();
- denominator = two;
- nominator_add = nominator;
- denominator_add = denominator;
- nominator_x = x;
- denominator_x = 3;
- c += nominator_x.Mul(x2);
- nominator_temp = nominator_x;
- c += nominator_temp.Mul(nominator);
- denominator_temp = denominator;
- c += denominator_temp.Mul(denominator_x);
- c += nominator_temp.Div(denominator_temp);
- // if there is a carry somewhere we only break the calculating
- // the result should be ok -- it's from <-pi/2, pi/2>
- if( c )
- break;
- result.Add(nominator_temp);
- // there's no sense to calculate more
- break;
- c += nominator_add.Add(two);
- c += denominator_add.Add(two);
- c += nominator.Mul(nominator_add);
- c += denominator.Mul(denominator_add);
- c += denominator_x.Add(two);
- return result;
- asin(x) = pi/2 - sqrt(2)*sqrt(1-x) * asin_temp
- asin_temp = 1 + (1*(1-x))/((2*3)*(2)) + (1*3*(1-x)^2)/((2*4*5)*(4)) + (1*3*5*(1-x)^3)/((2*4*6*7)*(8)) + ...
- where abs(x) <= 1
- we're using this formula when x is from (1/2, 1>
- ValueType ASin_1(const ValueType & x)
- ValueType nominator, denominator, nominator_add, nominator_x, nominator_x_add, denominator_add, denominator_x;
- ValueType denominator2;
- ValueType one, two, result;
- ValueType nominator_temp, denominator_temp, old_result;
- uint c = 0;
- two = 2;
- one.SetOne();
- nominator = one;
- result = one;
- nominator_x = one;
- nominator_x.Sub(x);
- nominator_x_add = nominator_x;
- denominator2 = two;
- c += denominator_temp.Mul(denominator2);
- if( c )
- break;
- break;
- c += nominator_x.Mul(nominator_x_add);
- c += denominator2.Mul(two);
- nominator_x_add.exponent.AddOne(); // *2
- one.exponent.SubOne(); // =0.5
- nominator_x_add.Pow(one); // =sqrt(nominator_x_add)
- result.Mul(nominator_x_add);
- one.Set05Pi();
- one.Sub(result);
- return one;
- this function calculates the Arc Sine
- x is from <-1,1>
- ValueType ASin(ValueType x, ErrorCode * err = 0)
- ValueType result, one;
- one.SetOne();
- bool change_sign = false;
- if( x.IsNan() )
- if( err )
- return x;
- if( x.GreaterWithoutSignThan(one) )
- if( err )
- if( x.IsSign() )
- change_sign = true;
- x.Abs();
- // asin(-x) = -asin(x)
- result = ASin_1(x);
- else
- result = ASin_0(x);
- if( change_sign )
- if( err )
- *err = err_ok;
- return result;
- this function calculates the Arc Cosine
- we're using the formula:
- acos(x) = pi/2 - asin(x)
- ValueType ACos(const ValueType & x, ErrorCode * err = 0)
- ValueType temp;
- temp.Set05Pi();
- temp.Sub(ASin(x, err));
- return temp;
- an auxiliary function for calculating the Arc Tangent
- arc tan (x) where x is in <0; 0.5)
- (x can be in (-0.5 ; 0.5) too)
- we're using the Taylor series expanded in zero:
- atan(x) = x - (x^3)/3 + (x^5)/5 - (x^7)/7 + ...
- ValueType ATan0(const ValueType & x)
- ValueType nominator, denominator, nominator_add, denominator_add, temp;
- ValueType result, old_result;
- bool adding = false;
- uint c = 0;
- result = x;
- nominator = x;
- nominator_add = x;
- nominator_add.Mul(x);
- denominator.SetOne();
- denominator_add = 2;
- c += denominator.Add(denominator_add);
- temp = nominator;
- if( c )
- break;
- if( adding )
- result.Add(temp);
- else
- result.Sub(temp);
- break;
- adding = !adding;
- return result;
- where x is in <0 ; 1>
- ValueType ATan01(const ValueType & x)
- ValueType half;
- half.Set05();
- it would be better if we chose about sqrt(2)-1=0.41... instead of 0.5 here
- because as you can see below:
- when x = sqrt(2)-1
- abs(x) = abs( (x-1)/(1+x) )
- so when we're calculating values around x
- then they will be better converged to each other
- for example if we have x=0.4999 then during calculating ATan0(0.4999)
- we have to make about 141 iterations but when we have x=0.5
- then during calculating ATan0( (x-1)/(1+x) ) we have to make
- only about 89 iterations (both for Big<3,9>)
- in the future this 0.5 can be changed
- if( x.SmallerWithoutSignThan(half) )
- return ATan0(x);
- x>=0.5 and x<=1
- (x can be even smaller than 0.5)
- y = atac(x)
- x = tan(y)
- tan(y-b) = (tan(y)-tab(b)) / (1+tan(y)*tan(b))
- y-b = atan( (tan(y)-tab(b)) / (1+tan(y)*tan(b)) )
- y = b + atan( (x-tab(b)) / (1+x*tan(b)) )
- let b = pi/4
- tan(b) = tan(pi/4) = 1
- y = pi/4 + atan( (x-1)/(1+x) )
- so
- atac(x) = pi/4 + atan( (x-1)/(1+x) )
- when x->1 (x converges to 1) the (x-1)/(1+x) -> 0
- and we can use ATan0() function here
- ValueType n(x),d(x),one,result;
- one.SetOne();
- n.Sub(one);
- d.Add(one);
- n.Div(d);
- result = ATan0(n);
- n.Set05Pi();
- n.exponent.SubOne(); // =pi/4
- result.Add(n);
- return result;
- where x > 1
- atan(x) = pi/2 - atan(1/x) for x>0
- ValueType ATanGreaterThanPlusOne(const ValueType & x)
- ValueType temp, atan;
- temp.SetOne();
- if( temp.Div(x) )
- // if there was a carry here that means x is very big
- // and atan(1/x) fast converged to 0
- atan.SetZero();
- else
- atan = ATan01(temp);
- temp.Set05Pi();
- temp.Sub(atan);
- return temp;
- this function calculates the Arc Tangent
- ValueType ATan(ValueType x)
- one.SetOne();
- if( x.IsNan() )
- return x;
- // if x is negative we're using the formula:
- // atan(-x) = -atan(x)
- if( x.IsSign() )
- x.Abs();
- result = ATanGreaterThanPlusOne(x);
- else
- result = ATan01(x);
- if( change_sign )
- return result;
- look at the description of ATan(...)
- (the abbreviation of Arc Tangent can be 'atg' as well)
- ValueType ATg(const ValueType & x)
- return ATan(x);
- this function calculates the Arc Cotangent
- actan(x) = pi/2 - atan(x)
- ValueType ACot(const ValueType & x)
- ValueType result;
- result.Set05Pi();
- result.Sub(ATan(x));
- return result;
- look at the description of ACot(...)
- (the abbreviation of Arc Cotangent can be 'actg' as well)
- ValueType ACtg(const ValueType & x)
- return ACot(x);
- * hyperbolic functions
- this function calculates the Hyperbolic Sine
- we're using the formula sinh(x)= ( e^x - e^(-x) ) / 2
- ValueType Sinh(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- ValueType ex, emx;
- uint c = 0;
- c += ex.Exp(x);
- c += emx.Exp(-x);
- c += ex.Sub(emx);
- c += ex.exponent.SubOne();
- if( err )
- return ex;
- this function calculates the Hyperbolic Cosine
- we're using the formula cosh(x)= ( e^x + e^(-x) ) / 2
- ValueType Cosh(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- uint c = 0;
- c += ex.Exp(x);
- c += emx.Exp(-x);
- c += ex.Add(emx);
- if( err )
- return ex;
- this function calculates the Hyperbolic Tangent
- we're using the formula tanh(x)= ( e^x - e^(-x) ) / ( e^x + e^(-x) )
- ValueType Tanh(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- ValueType ex, emx, nominator, denominator;
- uint c = 0;
- c += ex.Exp(x);
- c += emx.Exp(-x);
- nominator = ex;
- c += nominator.Sub(emx);
- denominator = ex;
- c += denominator.Add(emx);
- c += nominator.Div(denominator);
- if( err )
- return nominator;
- look at the description of Tanh(...)
- (the abbreviation of Hyperbolic Tangent can be 'tgh' as well)
- ValueType Tgh(const ValueType & x, ErrorCode * err = 0)
- return Tanh(x, err);
- this function calculates the Hyperbolic Cotangent
- we're using the formula coth(x)= ( e^x + e^(-x) ) / ( e^x - e^(-x) )
- ValueType Coth(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- if( x.IsZero() )
- if( err )
- return ValueType(); // NaN is set by default
- uint c = 0;
- c += ex.Exp(x);
- c += emx.Exp(-x);
- nominator = ex;
- c += nominator.Add(emx);
- denominator = ex;
- c += denominator.Sub(emx);
- if( err )
- return nominator;
- look at the description of Coth(...)
- (the abbreviation of Hyperbolic Cotangent can be 'ctgh' as well)
- ValueType Ctgh(const ValueType & x, ErrorCode * err = 0)
- return Coth(x, err);
- * inverse hyperbolic functions
- inverse hyperbolic sine
- asinh(x) = ln( x + sqrt(x^2 + 1) )
- ValueType ASinh(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- ValueType xx(x), one, result;
- uint c = 0;
- one.SetOne();
- c += xx.Mul(x);
- c += xx.Add(one);
- one.exponent.SubOne(); // one=0.5
- // xx is >= 1
- c += xx.PowFrac(one); // xx=sqrt(xx)
- c += xx.Add(x);
- c += result.Ln(xx); // xx > 0
- // here can only be a carry
- if( err )
- return result;
- inverse hyperbolic cosine
- acosh(x) = ln( x + sqrt(x^2 - 1) ) x in <1, infinity)
- ValueType ACosh(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- uint c = 0;
- one.SetOne();
- if( x < one )
- if( err )
- c += xx.Mul(x);
- c += xx.Sub(one);
- // xx is >= 0
- // we can't call a PowFrac when the 'x' is zero
- // if x is 0 the sqrt(0) is 0
- if( !xx.IsZero() )
- c += xx.Add(x);
- c += result.Ln(xx); // xx >= 1
- if( err )
- return result;
- inverse hyperbolic tangent
- atanh(x) = 0.5 * ln( (1+x) / (1-x) ) x in (-1, 1)
- ValueType ATanh(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- ValueType nominator(x), denominator, one, result;
- uint c = 0;
- one.SetOne();
- if( !x.SmallerWithoutSignThan(one) )
- if( err )
- c += nominator.Add(one);
- c += denominator.Sub(x);
- c += result.Ln(nominator);
- c += result.exponent.SubOne();
- if( err )
- return result;
- inverse hyperbolic tantent
- ValueType ATgh(const ValueType & x, ErrorCode * err = 0)
- return ATanh(x, err);
- inverse hyperbolic cotangent
- acoth(x) = 0.5 * ln( (x+1) / (x-1) ) x in (-infinity, -1) or (1, infinity)
- ValueType ACoth(const ValueType & x, ErrorCode * err = 0)
- if( x.IsNan() )
- if( err )
- return x; // NaN
- ValueType nominator(x), denominator(x), one, result;
- uint c = 0;
- one.SetOne();
- if( !x.GreaterWithoutSignThan(one) )
- if( err )
- c += denominator.Sub(one);
- if( err )
- return result;
- inverse hyperbolic cotantent
- ValueType ACtgh(const ValueType & x, ErrorCode * err = 0)
- return ACoth(x, err);
- * functions for converting between degrees, radians and gradians
- this function converts degrees to radians
- it returns: x * pi / 180
- ValueType DegToRad(const ValueType & x, ErrorCode * err = 0)
- ValueType result, temp;
- uint c = 0;
- if( x.IsNan() )
- if( err )
- return x;
- result = x;
- // it is better to make division first and then multiplication
- // the result is more accurate especially when x is: 90,180,270 or 360
- temp = 180;
- c += result.Div(temp);
- temp.SetPi();
- c += result.Mul(temp);
- if( err )
- return result;
- this function converts radians to degrees
- it returns: x * 180 / pi
- ValueType RadToDeg(const ValueType & x, ErrorCode * err = 0)
- ValueType result, delimiter;
- uint c = 0;
- if( x.IsNan() )
- if( err )
- return x;
- result = 180;
- c += result.Mul(x);
- delimiter.SetPi();
- c += result.Div(delimiter);
- if( err )
- return result;
- this function converts degrees in the long format into one value
- long format: (degrees, minutes, seconds)
- minutes and seconds must be greater than or equal zero
- result:
- - if d>=0 : result= d + ((s/60)+m)/60
- - if d<0 : result= d - ((s/60)+m)/60
- ((s/60)+m)/60 = (s+60*m)/3600 (second version is faster because
- there's only one division)
- samples:
- - DegToDeg(10, 30, 0) = 10.5
- - DegToDeg(10, 24, 35.6)=10.4098(8)
- ValueType DegToDeg( const ValueType & d, const ValueType & m, const ValueType & s,
- ErrorCode * err = 0)
- ValueType delimiter, multipler;
- uint c = 0;
- if( d.IsNan() || m.IsNan() || s.IsNan() || m.IsSign() || s.IsSign() )
- if( err )
- delimiter.SetZeroNan(); // not needed, only to get rid of GCC warning about an uninitialized variable
- return delimiter;
- multipler = 60;
- delimiter = 3600;
- c += multipler.Mul(m);
- c += multipler.Add(s);
- c += multipler.Div(delimiter);
- if( d.IsSign() )
- multipler.ChangeSign();
- c += multipler.Add(d);
- if( err )
- return multipler;
- this function converts degrees in the long format to radians
- ValueType DegToRad( const ValueType & d, const ValueType & m, const ValueType & s,
- ValueType temp_deg = DegToDeg(d,m,s,err);
- if( err && *err!=err_ok )
- return temp_deg;
- return DegToRad(temp_deg, err);
- this function converts gradians to radians
- it returns: x * pi / 200
- ValueType GradToRad(const ValueType & x, ErrorCode * err = 0)
- uint c = 0;
- if( x.IsNan() )
- if( err )
- return x;
- result = x;
- // the result is more accurate especially when x is: 100,200,300 or 400
- temp = 200;
- temp.SetPi();
- if( err )
- return result;
- this function converts radians to gradians
- it returns: x * 200 / pi
- ValueType RadToGrad(const ValueType & x, ErrorCode * err = 0)
- uint c = 0;
- if( x.IsNan() )
- if( err )
- return x;
- result = 200;
- if( err )
- return result;
- this function converts degrees to gradians
- it returns: x * 200 / 180
- ValueType DegToGrad(const ValueType & x, ErrorCode * err = 0)
- uint c = 0;
- if( x.IsNan() )
- if( err )
- return x;
- result = x;
- temp = 200;
- temp = 180;
- if( err )
- return result;
- this function converts degrees in the long format to gradians
- ValueType DegToGrad( const ValueType & d, const ValueType & m, const ValueType & s,
- return temp_deg;
- return DegToGrad(temp_deg, err);
- it returns: x * 180 / 200
- ValueType GradToDeg(const ValueType & x, ErrorCode * err = 0)
- uint c = 0;
- if( x.IsNan() )
- if( err )
- return x;
- result = x;
- temp = 180;
- temp = 200;
- if( err )
- return result;
- * another functions
- this function calculates the square root
- Sqrt(9) = 3
- ValueType Sqrt(ValueType x, ErrorCode * err = 0)
- if( x.IsNan() || x.IsSign() )
- if( err )
- x.SetNan();
- return x;
- uint c = x.Sqrt();
- if( err )
- return x;
- bool RootCheckIndexSign(ValueType & x, const ValueType & index, ErrorCode * err)
- if( index.IsSign() )
- // index cannot be negative
- if( err )
- x.SetNan();
- return true;
- return false;
- bool RootCheckIndexZero(ValueType & x, const ValueType & index, ErrorCode * err)
- if( index.IsZero() )
- if( x.IsZero() )
- // there isn't root(0;0) - we assume it's not defined
- if( err )
- x.SetNan();
- return true;
- // root(x;0) is 1 (if x!=0)
- x.SetOne();
- if( err )
- *err = err_ok;
- return true;
- return false;
- bool RootCheckIndexOne(const ValueType & index, ErrorCode * err)
- ValueType one;
- one.SetOne();
- if( index == one )
- //root(x;1) is x
- // we do it because if we used the PowFrac function
- // we would lose the precision
- if( err )
- *err = err_ok;
- return true;
- return false;
- bool RootCheckIndexTwo(ValueType & x, const ValueType & index, ErrorCode * err)
- if( index == 2 )
- x = Sqrt(x, err);
- return true;
- return false;
- bool RootCheckIndexFrac(ValueType & x, const ValueType & index, ErrorCode * err)
- if( !index.IsInteger() )
- // index must be integer
- if( err )
- x.SetNan();
- return true;
- return false;
- bool RootCheckXZero(ValueType & x, ErrorCode * err)
- if( x.IsZero() )
- // root(0;index) is zero (if index!=0)
- // RootCheckIndexZero() must be called beforehand
- x.SetZero();
- if( err )
- *err = err_ok;
- return true;
- return false;
- bool RootCheckIndex(ValueType & x, const ValueType & index, ErrorCode * err, bool * change_sign)
- *change_sign = false;
- if( index.Mod2() )
- // index is odd (1,3,5...)
- if( x.IsSign() )
- *change_sign = true;
- x.Abs();
- else
- // index is even
- // x cannot be negative
- if( x.IsSign() )
- if( err )
- x.SetNan();
- return true;
- return false;
- uint RootCorrectInteger(ValueType & old_x, ValueType & x, const ValueType & index)
- if( !old_x.IsInteger() || x.IsInteger() || !index.exponent.IsSign() )
- return 0;
- // old_x is integer,
- // x is not integer,
- // index is relatively small (index.exponent<0 or index.exponent<=0)
- // (because we're using a special powering algorithm Big::PowUInt())
- uint c = 0;
- ValueType temp(x);
- c += temp.Round();
- ValueType temp_round(temp);
- c += temp.PowUInt(index);
- if( temp == old_x )
- x = temp_round;
- return (c==0)? 0 : 1;
- caltulate the index'th Root of x
- index must be integer and not negative <0;1;2;3....)
- - if index==0 the result is one
- - if x==0 the result is zero and we assume root(0;0) is not defined
- - if index is even (2;4;6...) the result is x^(1/index) and x>0
- - if index is odd (1;2;3;...) the result is either
- - -(abs(x)^(1/index)) if x<0, or
- - x^(1/index)) if x>0
- - for index==1 the result is equal x
- ValueType Root(ValueType x, const ValueType & index, ErrorCode * err = 0)
- if( x.IsNan() || index.IsNan() )
- if( err )
- x.SetNan();
- return x;
- if( RootCheckIndexSign(x, index, err) ) return x;
- if( RootCheckIndexZero(x, index, err) ) return x;
- if( RootCheckIndexOne ( index, err) ) return x;
- if( RootCheckIndexTwo (x, index, err) ) return x;
- if( RootCheckIndexFrac(x, index, err) ) return x;
- if( RootCheckXZero (x, err) ) return x;
- // index integer and index!=0
- // x!=0
- ValueType old_x(x);
- bool change_sign;
- if( RootCheckIndex(x, index, err, &change_sign ) ) return x;
- ValueType temp;
- uint c = 0;
- // we're using the formula: root(x ; n) = exp( ln(x) / n )
- c += temp.Ln(x);
- c += temp.Div(index);
- c += x.Exp(temp);
- if( change_sign )
- // x is different from zero
- x.SetSign();
- c += RootCorrectInteger(old_x, x, index);
- if( err )
- return x;
- absolute value of x
- samples:
- - -2 = 2
- - 2 = 2
- ValueType Abs(const ValueType & x)
- result.Abs();
- return result;
- it returns the sign of the value
- samples:
- - -2 = -1
- - 0 = 0
- - 10 = 1
- ValueType Sgn(ValueType x)
- x.Sgn();
- return x;
- the remainder from a division
- samples:
- - mod( 12.6 ; 3) = 0.6 because 12.6 = 3*4 + 0.6
- - mod(-12.6 ; 3) = -0.6 bacause -12.6 = 3*(-4) + (-0.6)
- - mod( 12.6 ; -3) = 0.6
- - mod(-12.6 ; -3) = -0.6
- ValueType Mod(ValueType a, const ValueType & b, ErrorCode * err = 0)
- if( a.IsNan() || b.IsNan() )
- if( err )
- a.SetNan();
- return a;
- uint c = a.Mod(b);
- if( err )
- return a;
- this function is used to store factorials in a given container
- 'more' means how many values should be added at the end
- sample:
- std::vector<ValueType> fact;
- SetFactorialSequence(fact, 3);
- // now the container has three values: 1 1 2
- SetFactorialSequence(fact, 2);
- // now the container has five values: 1 1 2 6 24
- void SetFactorialSequence(std::vector<ValueType> & fact, uint more = 20)
- if( more == 0 )
- more = 1;
- uint start = static_cast<uint>(fact.size());
- fact.resize(fact.size() + more);
- if( start == 0 )
- fact[0] = 1;
- ++start;
- for(uint i=start ; i<fact.size() ; ++i)
- fact[i] = fact[i-1];
- fact[i].MulInt(i);
- an auxiliary function used to calculate Bernoulli numbers
- this function returns a sum:
- sum(m) = sum_{k=0}^{m-1} {2^k * (m k) * B(k)} k in [0, m-1] (m k) means binomial coefficient = (m! / (k! * (m-k)!))
- you should have sufficient factorials in cgamma.fact
- (cgamma.fact should have at least m items)
- n_ should be equal 2
- ValueType SetBernoulliNumbersSum(CGamma<ValueType> & cgamma, const ValueType & n_, uint m,
- const volatile StopCalculating * stop = 0)
- ValueType k_, temp, temp2, temp3, sum;
- sum.SetZero();
- for(uint k=0 ; k<m ; ++k) // k<m means k<=m-1
- if( stop && (k & 15)==0 ) // means: k % 16 == 0
- if( stop->WasStopSignal() )
- if( k>1 && (k & 1) == 1 ) // for that k the Bernoulli number is zero
- continue;
- k_ = k;
- temp = n_; // n_ is equal 2
- temp.Pow(k_);
- // temp = 2^k
- temp2 = cgamma.fact[m];
- temp3 = cgamma.fact[k];
- temp3.Mul(cgamma.fact[m-k]);
- temp2.Div(temp3);
- // temp2 = (m k) = m! / ( k! * (m-k)! )
- temp.Mul(temp2);
- temp.Mul(cgamma.bern[k]);
- sum.Add(temp);
- // sum += 2^k * (m k) * B(k)
- if( sum.IsNan() )
- break;
- return sum;
- start is >= 2
- we use the recurrence formula:
- B(m) = 1 / (2*(1 - 2^m)) * sum(m)
- where sum(m) is calculated by SetBernoulliNumbersSum()
- bool SetBernoulliNumbersMore(CGamma<ValueType> & cgamma, uint start, const volatile StopCalculating * stop = 0)
- ValueType denominator, temp, temp2, temp3, m_, sum, sum2, n_, k_;
- const uint n = 2;
- n_ = n;
- // start is >= 2
- for(uint m=start ; m<cgamma.bern.size() ; ++m)
- if( (m & 1) == 1 )
- cgamma.bern[m].SetZero();
- else
- m_ = m;
- temp = n_; // n_ = 2
- temp.Pow(m_);
- // temp = 2^m
- denominator.Sub(temp);
- if( denominator.exponent.AddOne() ) // it means: denominator.MulInt(2)
- denominator.SetNan();
- // denominator = 2 * (1 - 2^m)
- cgamma.bern[m] = SetBernoulliNumbersSum(cgamma, n_, m, stop);
- if( stop && stop->WasStopSignal() )
- cgamma.bern.resize(m); // valid numbers are in [0, m-1]
- return false;
- cgamma.bern[m].Div(denominator);
- return true;
- this function is used to calculate Bernoulli numbers,
- returns false if there was a stop signal,
- sample:
- typedef Big<1,2> MyBig;
- CGamma<MyBig> cgamma;
- SetBernoulliNumbers(cgamma, 3);
- // now we have three first Bernoulli numbers: 1 -0.5 0.16667
- SetBernoulliNumbers(cgamma, 4);
- // now we have 7 Bernoulli numbers: 1 -0.5 0.16667 0 -0.0333 0 0.0238
- bool SetBernoulliNumbers(CGamma<ValueType> & cgamma, uint more = 20, const volatile StopCalculating * stop = 0)
- if( more == 0 )
- more = 1;
- uint start = static_cast<uint>(cgamma.bern.size());
- cgamma.bern.resize(cgamma.bern.size() + more);
- if( start == 0 )
- cgamma.bern[0].SetOne();
- ++start;
- if( cgamma.bern.size() == 1 )
- return true;
- if( start == 1 )
- cgamma.bern[1].Set05();
- cgamma.bern[1].ChangeSign();
- ++start;
- // we should have sufficient factorials in cgamma.fact
- if( cgamma.fact.size() < cgamma.bern.size() )
- SetFactorialSequence(cgamma.fact, static_cast<uint>(cgamma.bern.size() - cgamma.fact.size()));
- return SetBernoulliNumbersMore(cgamma, start, stop);
- an auxiliary function used to calculate the Gamma() function
- we calculate a sum:
- sum(n) = sum_{m=2} { B(m) / ( (m^2 - m) * n^(m-1) ) } = 1/(12*n) - 1/(360*n^3) + 1/(1260*n^5) + ...
- B(m) means a mth Bernoulli number
- the sum starts from m=2, we calculate as long as the value will not change after adding a next part
- ValueType GammaFactorialHighSum(const ValueType & n, CGamma<ValueType> & cgamma, ErrorCode & err,
- const volatile StopCalculating * stop)
- ValueType temp, temp2, denominator, sum, oldsum;
- sum.SetZero();
- for(uint m=2 ; m<TTMATH_ARITHMETIC_MAX_LOOP ; m+=2)
- if( stop && (m & 3)==0 ) // (m & 3)==0 means: (m % 4)==0
- err = err_interrupt;
- temp = (m-1);
- denominator = n;
- denominator.Pow(temp);
- // denominator = n ^ (m-1)
- temp = m;
- temp2 = temp;
- temp.Mul(temp2);
- temp.Sub(temp2);
- // temp = m^2 - m
- denominator.Mul(temp);
- // denominator = (m^2 - m) * n ^ (m-1)
- if( m >= cgamma.bern.size() )
- if( !SetBernoulliNumbers(cgamma, m - cgamma.bern.size() + 1 + 3, stop) ) // 3 more than needed
- // there was the stop signal
- temp = cgamma.bern[m];
- temp.Div(denominator);
- oldsum = sum;
- sum.Add(temp);
- if( sum.IsNan() || oldsum==sum )
- break;
- return sum;
- we calculate a helper function GammaFactorialHigh() by using Stirling's series:
- n! = (n/e)^n * sqrt(2*pi*n) * exp( sum(n) )
- where n is a real number (not only an integer) and is sufficient large (greater than TTMATH_GAMMA_BOUNDARY)
- and sum(n) is calculated by GammaFactorialHighSum()
- ValueType GammaFactorialHigh(const ValueType & n, CGamma<ValueType> & cgamma, ErrorCode & err,
- ValueType temp, temp2, temp3, denominator, sum;
- temp.Set2Pi();
- temp.Mul(n);
- temp2 = Sqrt(temp);
- // temp2 = sqrt(2*pi*n)
- temp = n;
- temp3.SetE();
- temp.Div(temp3);
- temp.Pow(n);
- // temp = (n/e)^n
- sum = GammaFactorialHighSum(n, cgamma, err, stop);
- temp3.Exp(sum);
- // temp3 = exp(sum)
- temp.Mul(temp2);
- temp.Mul(temp3);
- return temp;
- Gamma(x) = GammaFactorialHigh(x-1)
- ValueType GammaPlusHigh(ValueType n, CGamma<ValueType> & cgamma, ErrorCode & err, const volatile StopCalculating * stop)
- ValueType one;
- one.SetOne();
- n.Sub(one);
- return GammaFactorialHigh(n, cgamma, err, stop);
- we use this function when n is integer and a small value (from 0 to TTMATH_GAMMA_BOUNDARY]
- we use the formula:
- gamma(n) = (n-1)! = 1 * 2 * 3 * ... * (n-1)
- ValueType GammaPlusLowIntegerInt(uint n, CGamma<ValueType> & cgamma)
- TTMATH_ASSERT( n > 0 )
- if( n - 1 < static_cast<uint>(cgamma.fact.size()) )
- return cgamma.fact[n - 1];
- ValueType res;
- uint start = 2;
- if( cgamma.fact.size() < 2 )
- res.SetOne();
- else
- start = static_cast<uint>(cgamma.fact.size());
- res = cgamma.fact[start-1];
- for(uint i=start ; i<n ; ++i)
- res.MulInt(i);
- return res;
- ValueType GammaPlusLowInteger(const ValueType & n, CGamma<ValueType> & cgamma)
- sint n_;
- n.ToInt(n_);
- return GammaPlusLowIntegerInt(n_, cgamma);
- we use this function when n is a small value (from 0 to TTMATH_GAMMA_BOUNDARY]
- we use a recurrence formula:
- gamma(z+1) = z * gamma(z)
- then: gamma(z) = gamma(z+1) / z
- samples:
- - gamma(3.89) = gamma(2001.89) / ( 3.89 * 4.89 * 5.89 * ... * 1999.89 * 2000.89 )
- ValueType GammaPlusLow(ValueType n, CGamma<ValueType> & cgamma, ErrorCode & err, const volatile StopCalculating * stop)
- ValueType one, denominator, temp, boundary;
- if( n.IsInteger() )
- return GammaPlusLowInteger(n, cgamma);
- one.SetOne();
- denominator = n;
- boundary = TTMATH_GAMMA_BOUNDARY;
- while( n < boundary )
- n.Add(one);
- denominator.Mul(n);
- n.Add(one);
- // now n is sufficient big
- temp = GammaPlusHigh(n, cgamma, err, stop);
- return temp;
- ValueType GammaPlus(const ValueType & n, CGamma<ValueType> & cgamma, ErrorCode & err, const volatile StopCalculating * stop)
- if( n > TTMATH_GAMMA_BOUNDARY )
- return GammaPlusHigh(n, cgamma, err, stop);
- return GammaPlusLow(n, cgamma, err, stop);
- this function is used when n is negative
- we use the reflection formula:
- gamma(1-z) * gamma(z) = pi / sin(pi*z)
- then: gamma(z) = pi / (sin(pi*z) * gamma(1-z))
- ValueType GammaMinus(const ValueType & n, CGamma<ValueType> & cgamma, ErrorCode & err, const volatile StopCalculating * stop)
- ValueType pi, denominator, temp, temp2;
- // gamma function is not defined when n is negative and integer
- err = err_improper_argument;
- return temp; // NaN
- pi.SetPi();
- temp = pi;
- temp.Mul(n);
- temp2 = Sin(temp);
- // temp2 = sin(pi * n)
- temp.SetOne();
- temp.Sub(n);
- temp = GammaPlus(temp, cgamma, err, stop);
- // temp = gamma(1 - n)
- temp.Mul(temp2);
- pi.Div(temp);
- return pi;
- this function calculates the Gamma function
- it's multithread safe, you should create a CGamma<> object and use it whenever you call the Gamma()
- e.g.
- MyBig x=234, y=345.53;
- std::cout << Gamma(x, cgamma) << std::endl;
- std::cout << Gamma(y, cgamma) << std::endl;
- in the CGamma<> object the function stores some coefficients (factorials, Bernoulli numbers),
- and they will be reused in next calls to the function
- each thread should have its own CGamma<> object, and you can use these objects with Factorial() function too
- ValueType Gamma(const ValueType & n, CGamma<ValueType> & cgamma, ErrorCode * err = 0,
- ValueType result;
- ErrorCode err_tmp;
- if( n.IsNan() )
- if( err )
- return n;
- if( cgamma.history.Get(n, result, err_tmp) )
- if( err )
- *err = err_tmp;
- return result;
- err_tmp = err_ok;
- if( n.IsSign() )
- result = GammaMinus(n, cgamma, err_tmp, stop);
- else
- if( n.IsZero() )
- err_tmp = err_improper_argument;
- result.SetNan();
- else
- result = GammaPlus(n, cgamma, err_tmp, stop);
- if( result.IsNan() && err_tmp==err_ok )
- err_tmp = err_overflow;
- if( err )
- *err = err_tmp;
- if( stop && !stop->WasStopSignal() )
- cgamma.history.Add(n, result, err_tmp);
- return result;
- note: this function should be used only in a single-thread environment
- ValueType Gamma(const ValueType & n, ErrorCode * err = 0)
- // warning: this static object is not thread safe
- static CGamma<ValueType> cgamma;
- return Gamma(n, cgamma, err);
- an auxiliary function for calculating the factorial function
- x! = gamma(x+1)
- ValueType Factorial2(ValueType x,
- CGamma<ValueType> * cgamma = 0,
- ErrorCode * err = 0,
- if( x.IsNan() || x.IsSign() || !x.IsInteger() )
- if( err )
- x.SetNan();
- return x;
- one.SetOne();
- x.Add(one);
- if( cgamma )
- return Gamma(x, *cgamma, err, stop);
- return Gamma(x, err);
- the factorial from given 'x'
- e.g.
- Factorial(4) = 4! = 1*2*3*4
- it's multithread safe, you should create a CGamma<> object and use it whenever you call the Factorial()
- e.g.
- MyBig x=234, y=54345;
- std::cout << Factorial(x, cgamma) << std::endl;
- std::cout << Factorial(y, cgamma) << std::endl;
- each thread should have its own CGamma<> object, and you can use these objects with Gamma() function too
- ValueType Factorial(const ValueType & x, CGamma<ValueType> & cgamma, ErrorCode * err = 0,
- return auxiliaryfunctions::Factorial2(x, &cgamma, err, stop);
- e.g.
- ValueType Factorial(const ValueType & x, ErrorCode * err = 0)
- return auxiliaryfunctions::Factorial2(x, (CGamma<ValueType>*)0, err, 0);
- this method prepares some coefficients: factorials and Bernoulli numbers
- stored in 'fact' and 'bern' objects
- we're defining the method here because we're using Gamma() function which
- is not available in ttmathobjects.h
- read the doc info in ttmathobjects.h file where CGamma<> struct is declared
- void CGamma<ValueType>::InitAll()
- ValueType x = TTMATH_GAMMA_BOUNDARY + 1;
- // history.Remove(x) removes only one object
- // we must be sure that there are not others objects with the key 'x'
- while( history.Remove(x) )
- // the simplest way to initialize is to call the Gamma function with (TTMATH_GAMMA_BOUNDARY + 1)
- // when x is larger then fewer coefficients we need
- Gamma(x, *this);
-} // namespace
- this is for convenience for the user
- he can only use '#include <ttmath/ttmath.h>'
-#include "ttmathparser.h"
-// Dec is not finished yet
-//#include "ttmathdec.h"
-#ifdef _MSC_VER
-#pragma warning( default: 4127 )
-#pragma warning( default: 4702 )
-#pragma warning( default: 4800 )
-#endif
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmathbig.h b/include/geos/algorithm/ttmath/ttmathbig.h
index bbbbda0..0000000
--- a/include/geos/algorithm/ttmath/ttmathbig.h
+++ /dev/null
@@ -1,6093 +0,0 @@
-#ifndef headerfilettmathbig
-#define headerfilettmathbig
- \file ttmathbig.h
- \brief A Class for representing floating point numbers
-#include "ttmathint.h"
-#include "ttmaththreads.h"
-#include <iostream>
-#ifdef TTMATH_MULTITHREADS
-#include <signal.h>
-#endif
-namespace ttmath
- \brief Big implements the floating point numbers
-template <uint exp, uint man>
-class Big
- value = mantissa * 2^exponent
- - exponent - an integer value with a sign
- - mantissa - an integer value without a sing
- mantissa must be pushed into the left side that is the highest bit from
- mantissa must be one (of course if there's another value than zero) -- this job
- (pushing bits into the left side) is doing by Standardizing() method
- for example:
- if we want to store value one (1) into our Big object we must:
- - set mantissa to 1
- - set exponent to 0
- - set info to 0
- - and call method Standardizing()
-public:
-Int<exp> exponent{0};
-UInt<man> mantissa{0};
-unsigned char info{0};
- Sign
- the mask of a bit from 'info' which means that there is a sign
- (when the bit is set)
-#define TTMATH_BIG_SIGN 128
- Not a number
- if this bit is set that there is not a valid number
-#define TTMATH_BIG_NAN 64
- Zero
- if this bit is set that there is value zero
- mantissa should be zero and exponent should be zero too
- (the Standardizing() method does this)
-#define TTMATH_BIG_ZERO 32
- this method sets NaN if there was a carry (and returns 1 in such a case)
- c can be 0, 1 or other value different from zero
- uint CheckCarry(uint c)
- if( c != 0 )
- SetNan();
- return 1;
- return 0;
-public:
- returning the string represents the currect type of the library
- we have following types:
- - asm_vc_32 - with asm code designed for Microsoft Visual C++ (32 bits)
- - asm_gcc_32 - with asm code designed for GCC (32 bits)
- - asm_vc_64 - with asm for VC (64 bit)
- - asm_gcc_64 - with asm for GCC (64 bit)
- - no_asm_32 - pure C++ version (32 bit) - without any asm code
- - no_asm_64 - pure C++ version (64 bit) - without any asm code
- static const char * LibTypeStr()
- return UInt<man>::LibTypeStr();
- returning the currect type of the library
- static LibTypeCode LibType()
- return UInt<man>::LibType();
- this method moves all bits from mantissa into its left side
- (suitably changes the exponent) or if the mantissa is zero
- it sets the exponent to zero as well
- (and clears the sign bit and sets the zero bit)
- it can return a carry
- the carry will be when we don't have enough space in the exponent
- you don't have to use this method if you don't change the mantissa
- and exponent directly
- uint Standardizing()
- if( mantissa.IsTheHighestBitSet() )
- ClearInfoBit(TTMATH_BIG_ZERO);
- return 0;
- if( CorrectZero() )
- return 0;
- uint comp = mantissa.CompensationToLeft();
- return exponent.Sub( comp );
-private:
- if the mantissa is equal zero this method sets exponent to zero and
- info without the sign
- it returns true if there was the correction
- bool CorrectZero()
- if( mantissa.IsZero() )
- SetInfoBit(TTMATH_BIG_ZERO);
- ClearInfoBit(TTMATH_BIG_SIGN);
- exponent.SetZero();
- return true;
- else
- return false;
-public:
- this method clears a specific bit in the 'info' variable
- bit is one of: TTMATH_BIG_SIGN, TTMATH_BIG_NAN etc.
- void ClearInfoBit(unsigned char bit)
- info = info & (unsigned char)(~bit);
- this method sets a specific bit in the 'info' variable
- void SetInfoBit(unsigned char bit)
- info = info | bit;
- this method returns true if a specific bit in the 'info' variable is set
- bool IsInfoBit(unsigned char bit) const
- return (info & bit) != 0;
- this method sets zero
- void SetZero()
- info = TTMATH_BIG_ZERO;
- mantissa.SetZero();
- we don't have to compensate zero
- this method sets one
- void SetOne()
- info = 0;
- mantissa.table[man-1] = TTMATH_UINT_HIGHEST_BIT;
- exponent = -sint(man * TTMATH_BITS_PER_UINT - 1);
- // don't have to Standardize() - the last bit from mantissa is set
- this method sets value 0.5
- void Set05()
- SetOne();
- exponent.SubOne();
- this method sets NaN flag (Not a Number)
- when this flag is set that means there is no a valid number
- void SetNan()
- SetInfoBit(TTMATH_BIG_NAN);
- also clears the mantissa and exponent (similarly as it would be a zero value)
- void SetZeroNan()
- SetZero();
- SetNan();
- this method swappes this for an argument
- void Swap(Big<exp, man> & ss2)
- unsigned char info_temp = info;
- info = ss2.info;
- ss2.info = info_temp;
- exponent.Swap(ss2.exponent);
- mantissa.Swap(ss2.mantissa);
-private:
- this method sets the mantissa of the value of pi
- void SetMantissaPi()
- // this is a static table which represents the value of Pi (mantissa of it)
- // (first is the highest word)
- // we must define this table as 'unsigned int' because
- // both on 32bit and 64bit platforms this table is 32bit
- static const unsigned int temp_table[] = {
- 0xc90fdaa2, 0x2168c234, 0xc4c6628b, 0x80dc1cd1, 0x29024e08, 0x8a67cc74, 0x020bbea6, 0x3b139b22,
- 0x514a0879, 0x8e3404dd, 0xef9519b3, 0xcd3a431b, 0x302b0a6d, 0xf25f1437, 0x4fe1356d, 0x6d51c245,
- 0xe485b576, 0x625e7ec6, 0xf44c42e9, 0xa637ed6b, 0x0bff5cb6, 0xf406b7ed, 0xee386bfb, 0x5a899fa5,
- 0xae9f2411, 0x7c4b1fe6, 0x49286651, 0xece45b3d, 0xc2007cb8, 0xa163bf05, 0x98da4836, 0x1c55d39a,
- 0x69163fa8, 0xfd24cf5f, 0x83655d23, 0xdca3ad96, 0x1c62f356, 0x208552bb, 0x9ed52907, 0x7096966d,
- 0x670c354e, 0x4abc9804, 0xf1746c08, 0xca18217c, 0x32905e46, 0x2e36ce3b, 0xe39e772c, 0x180e8603,
- 0x9b2783a2, 0xec07a28f, 0xb5c55df0, 0x6f4c52c9, 0xde2bcbf6, 0x95581718, 0x3995497c, 0xea956ae5,
- 0x15d22618, 0x98fa0510, 0x15728e5a, 0x8aaac42d, 0xad33170d, 0x04507a33, 0xa85521ab, 0xdf1cba64,
- 0xecfb8504, 0x58dbef0a, 0x8aea7157, 0x5d060c7d, 0xb3970f85, 0xa6e1e4c7, 0xabf5ae8c, 0xdb0933d7,
- 0x1e8c94e0, 0x4a25619d, 0xcee3d226, 0x1ad2ee6b, 0xf12ffa06, 0xd98a0864, 0xd8760273, 0x3ec86a64,
- 0x521f2b18, 0x177b200c, 0xbbe11757, 0x7a615d6c, 0x770988c0, 0xbad946e2, 0x08e24fa0, 0x74e5ab31,
- 0x43db5bfc, 0xe0fd108e, 0x4b82d120, 0xa9210801, 0x1a723c12, 0xa787e6d7, 0x88719a10, 0xbdba5b26,
- 0x99c32718, 0x6af4e23c, 0x1a946834, 0xb6150bda, 0x2583e9ca, 0x2ad44ce8, 0xdbbbc2db, 0x04de8ef9,
- 0x2e8efc14, 0x1fbecaa6, 0x287c5947, 0x4e6bc05d, 0x99b2964f, 0xa090c3a2, 0x233ba186, 0x515be7ed,
- 0x1f612970, 0xcee2d7af, 0xb81bdd76, 0x2170481c, 0xd0069127, 0xd5b05aa9, 0x93b4ea98, 0x8d8fddc1,
- 0x86ffb7dc, 0x90a6c08f, 0x4df435c9, 0x34028492, 0x36c3fab4, 0xd27c7026, 0xc1d4dcb2, 0x602646de,
- 0xc9751e76, 0x3dba37bd, 0xf8ff9406, 0xad9e530e, 0xe5db382f, 0x413001ae, 0xb06a53ed, 0x9027d831,
- 0x179727b0, 0x865a8918, 0xda3edbeb, 0xcf9b14ed, 0x44ce6cba, 0xced4bb1b, 0xdb7f1447, 0xe6cc254b,
- 0x33205151, 0x2bd7af42, 0x6fb8f401, 0x378cd2bf, 0x5983ca01, 0xc64b92ec, 0xf032ea15, 0xd1721d03,
- 0xf482d7ce, 0x6e74fef6, 0xd55e702f, 0x46980c82, 0xb5a84031, 0x900b1c9e, 0x59e7c97f, 0xbec7e8f3,
- 0x23a97a7e, 0x36cc88be, 0x0f1d45b7, 0xff585ac5, 0x4bd407b2, 0x2b4154aa, 0xcc8f6d7e, 0xbf48e1d8,
- 0x14cc5ed2, 0x0f8037e0, 0xa79715ee, 0xf29be328, 0x06a1d58b, 0xb7c5da76, 0xf550aa3d, 0x8a1fbff0,
- 0xeb19ccb1, 0xa313d55c, 0xda56c9ec, 0x2ef29632, 0x387fe8d7, 0x6e3c0468, 0x043e8f66, 0x3f4860ee,
- 0x12bf2d5b, 0x0b7474d6, 0xe694f91e, 0x6dbe1159, 0x74a3926f, 0x12fee5e4, 0x38777cb6, 0xa932df8c,
- 0xd8bec4d0, 0x73b931ba, 0x3bc832b6, 0x8d9dd300, 0x741fa7bf, 0x8afc47ed, 0x2576f693, 0x6ba42466,
- 0x3aab639c, 0x5ae4f568, 0x3423b474, 0x2bf1c978, 0x238f16cb, 0xe39d652d, 0xe3fdb8be, 0xfc848ad9,
- 0x22222e04, 0xa4037c07, 0x13eb57a8, 0x1a23f0c7, 0x3473fc64, 0x6cea306b, 0x4bcbc886, 0x2f8385dd,
- 0xfa9d4b7f, 0xa2c087e8, 0x79683303, 0xed5bdd3a, 0x062b3cf5, 0xb3a278a6, 0x6d2a13f8, 0x3f44f82d,
- 0xdf310ee0, 0x74ab6a36, 0x4597e899, 0xa0255dc1, 0x64f31cc5, 0x0846851d, 0xf9ab4819, 0x5ded7ea1,
- 0xb1d510bd, 0x7ee74d73, 0xfaf36bc3, 0x1ecfa268, 0x359046f4, 0xeb879f92, 0x4009438b, 0x481c6cd7,
- 0x889a002e, 0xd5ee382b, 0xc9190da6, 0xfc026e47, 0x9558e447, 0x5677e9aa, 0x9e3050e2, 0x765694df,
- 0xc81f56e8, 0x80b96e71, 0x60c980dd, 0x98a573ea, 0x4472065a, 0x139cd290, 0x6cd1cb72, 0x9ec52a53 // last one was: 0x9ec52a52
- //0x86d44014, ...
- // (the last word 0x9ec52a52 was rounded up because the next one is 0x86d44014 -- first bit is one 0x8..)
- // 256 32bit words for the mantissa -- about 2464 valid decimal digits
- // the value of PI is comming from the website http://zenwerx.com/pi.php
- // 3101 digits were taken from this website
- // (later the digits were compared with:
- // http://www.eveandersson.com/pi/digits/1000000 and http://www.geom.uiuc.edu/~huberty/math5337/groupe/digits.html )
- // and they were set into Big<1,400> type (using operator=(const char*) on a 32bit platform)
- // and then the first 256 words were taken into this table
- // (TTMATH_BUILTIN_VARIABLES_SIZE on 32bit platform should have the value 256,
- // and on 64bit platform value 128 (256/2=128))
- mantissa.SetFromTable(temp_table, sizeof(temp_table) / sizeof(int));
-public:
- this method sets the value of pi
- void SetPi()
- // IMPROVE ME
- // give some compiler-time warning when the size of mantissa is greater than the builtin size of the mantissa pi
- SetMantissaPi();
- info = 0;
- exponent = -sint(man)*sint(TTMATH_BITS_PER_UINT) + 2;
- this method sets the value of 0.5 * pi
- void Set05Pi()
- // IMPROVE ME
- SetMantissaPi();
- info = 0;
- exponent = -sint(man)*sint(TTMATH_BITS_PER_UINT) + 1;
- this method sets the value of 2 * pi
- void Set2Pi()
- // IMPROVE ME
- SetMantissaPi();
- info = 0;
- exponent = -sint(man)*sint(TTMATH_BITS_PER_UINT) + 3;
- this method sets the value of e
- (the base of the natural logarithm)
- void SetE()
- 0xadf85458, 0xa2bb4a9a, 0xafdc5620, 0x273d3cf1, 0xd8b9c583, 0xce2d3695, 0xa9e13641, 0x146433fb,
- 0xcc939dce, 0x249b3ef9, 0x7d2fe363, 0x630c75d8, 0xf681b202, 0xaec4617a, 0xd3df1ed5, 0xd5fd6561,
- 0x2433f51f, 0x5f066ed0, 0x85636555, 0x3ded1af3, 0xb557135e, 0x7f57c935, 0x984f0c70, 0xe0e68b77,
- 0xe2a689da, 0xf3efe872, 0x1df158a1, 0x36ade735, 0x30acca4f, 0x483a797a, 0xbc0ab182, 0xb324fb61,
- 0xd108a94b, 0xb2c8e3fb, 0xb96adab7, 0x60d7f468, 0x1d4f42a3, 0xde394df4, 0xae56ede7, 0x6372bb19,
- 0x0b07a7c8, 0xee0a6d70, 0x9e02fce1, 0xcdf7e2ec, 0xc03404cd, 0x28342f61, 0x9172fe9c, 0xe98583ff,
- 0x8e4f1232, 0xeef28183, 0xc3fe3b1b, 0x4c6fad73, 0x3bb5fcbc, 0x2ec22005, 0xc58ef183, 0x7d1683b2,
- 0xc6f34a26, 0xc1b2effa, 0x886b4238, 0x611fcfdc, 0xde355b3b, 0x6519035b, 0xbc34f4de, 0xf99c0238,
- 0x61b46fc9, 0xd6e6c907, 0x7ad91d26, 0x91f7f7ee, 0x598cb0fa, 0xc186d91c, 0xaefe1309, 0x85139270,
- 0xb4130c93, 0xbc437944, 0xf4fd4452, 0xe2d74dd3, 0x64f2e21e, 0x71f54bff, 0x5cae82ab, 0x9c9df69e,
- 0xe86d2bc5, 0x22363a0d, 0xabc52197, 0x9b0deada, 0x1dbf9a42, 0xd5c4484e, 0x0abcd06b, 0xfa53ddef,
- 0x3c1b20ee, 0x3fd59d7c, 0x25e41d2b, 0x669e1ef1, 0x6e6f52c3, 0x164df4fb, 0x7930e9e4, 0xe58857b6,
- 0xac7d5f42, 0xd69f6d18, 0x7763cf1d, 0x55034004, 0x87f55ba5, 0x7e31cc7a, 0x7135c886, 0xefb4318a,
- 0xed6a1e01, 0x2d9e6832, 0xa907600a, 0x918130c4, 0x6dc778f9, 0x71ad0038, 0x092999a3, 0x33cb8b7a,
- 0x1a1db93d, 0x7140003c, 0x2a4ecea9, 0xf98d0acc, 0x0a8291cd, 0xcec97dcf, 0x8ec9b55a, 0x7f88a46b,
- 0x4db5a851, 0xf44182e1, 0xc68a007e, 0x5e0dd902, 0x0bfd64b6, 0x45036c7a, 0x4e677d2c, 0x38532a3a,
- 0x23ba4442, 0xcaf53ea6, 0x3bb45432, 0x9b7624c8, 0x917bdd64, 0xb1c0fd4c, 0xb38e8c33, 0x4c701c3a,
- 0xcdad0657, 0xfccfec71, 0x9b1f5c3e, 0x4e46041f, 0x388147fb, 0x4cfdb477, 0xa52471f7, 0xa9a96910,
- 0xb855322e, 0xdb6340d8, 0xa00ef092, 0x350511e3, 0x0abec1ff, 0xf9e3a26e, 0x7fb29f8c, 0x183023c3,
- 0x587e38da, 0x0077d9b4, 0x763e4e4b, 0x94b2bbc1, 0x94c6651e, 0x77caf992, 0xeeaac023, 0x2a281bf6,
- 0xb3a739c1, 0x22611682, 0x0ae8db58, 0x47a67cbe, 0xf9c9091b, 0x462d538c, 0xd72b0374, 0x6ae77f5e,
- 0x62292c31, 0x1562a846, 0x505dc82d, 0xb854338a, 0xe49f5235, 0xc95b9117, 0x8ccf2dd5, 0xcacef403,
- 0xec9d1810, 0xc6272b04, 0x5b3b71f9, 0xdc6b80d6, 0x3fdd4a8e, 0x9adb1e69, 0x62a69526, 0xd43161c1,
- 0xa41d570d, 0x7938dad4, 0xa40e329c, 0xcff46aaa, 0x36ad004c, 0xf600c838, 0x1e425a31, 0xd951ae64,
- 0xfdb23fce, 0xc9509d43, 0x687feb69, 0xedd1cc5e, 0x0b8cc3bd, 0xf64b10ef, 0x86b63142, 0xa3ab8829,
- 0x555b2f74, 0x7c932665, 0xcb2c0f1c, 0xc01bd702, 0x29388839, 0xd2af05e4, 0x54504ac7, 0x8b758282,
- 0x2846c0ba, 0x35c35f5c, 0x59160cc0, 0x46fd8251, 0x541fc68c, 0x9c86b022, 0xbb709987, 0x6a460e74,
- 0x51a8a931, 0x09703fee, 0x1c217e6c, 0x3826e52c, 0x51aa691e, 0x0e423cfc, 0x99e9e316, 0x50c1217b,
- 0x624816cd, 0xad9a95f9, 0xd5b80194, 0x88d9c0a0, 0xa1fe3075, 0xa577e231, 0x83f81d4a, 0x3f2fa457,
- 0x1efc8ce0, 0xba8a4fe8, 0xb6855dfe, 0x72b0a66e, 0xded2fbab, 0xfbe58a30, 0xfafabe1c, 0x5d71a87e,
- 0x2f741ef8, 0xc1fe86fe, 0xa6bbfde5, 0x30677f0d, 0x97d11d49, 0xf7a8443d, 0x0822e506, 0xa9f4614e,
- 0x011e2a94, 0x838ff88c, 0xd68c8bb7, 0xc51eef6d, 0x49ea8ab4, 0xf2c3df5b, 0xb4e0735a, 0xb0d68749
- // 0x2fe26dd4, ...
- // above value was calculated using Big<1,400> type on a 32bit platform
- // and then the first 256 words were taken,
- // the calculating was made by using ExpSurrounding0(1) method
- // which took 1420 iterations
- // (the result was compared with e taken from http://antwrp.gsfc.nasa.gov/htmltest/gifcity/e.2mil)
- info = 0;
- this method sets the value of ln(2)
- the natural logarithm from 2
- void SetLn2()
- 0xb17217f7, 0xd1cf79ab, 0xc9e3b398, 0x03f2f6af, 0x40f34326, 0x7298b62d, 0x8a0d175b, 0x8baafa2b,
- 0xe7b87620, 0x6debac98, 0x559552fb, 0x4afa1b10, 0xed2eae35, 0xc1382144, 0x27573b29, 0x1169b825,
- 0x3e96ca16, 0x224ae8c5, 0x1acbda11, 0x317c387e, 0xb9ea9bc3, 0xb136603b, 0x256fa0ec, 0x7657f74b,
- 0x72ce87b1, 0x9d6548ca, 0xf5dfa6bd, 0x38303248, 0x655fa187, 0x2f20e3a2, 0xda2d97c5, 0x0f3fd5c6,
- 0x07f4ca11, 0xfb5bfb90, 0x610d30f8, 0x8fe551a2, 0xee569d6d, 0xfc1efa15, 0x7d2e23de, 0x1400b396,
- 0x17460775, 0xdb8990e5, 0xc943e732, 0xb479cd33, 0xcccc4e65, 0x9393514c, 0x4c1a1e0b, 0xd1d6095d,
- 0x25669b33, 0x3564a337, 0x6a9c7f8a, 0x5e148e82, 0x074db601, 0x5cfe7aa3, 0x0c480a54, 0x17350d2c,
- 0x955d5179, 0xb1e17b9d, 0xae313cdb, 0x6c606cb1, 0x078f735d, 0x1b2db31b, 0x5f50b518, 0x5064c18b,
- 0x4d162db3, 0xb365853d, 0x7598a195, 0x1ae273ee, 0x5570b6c6, 0x8f969834, 0x96d4e6d3, 0x30af889b,
- 0x44a02554, 0x731cdc8e, 0xa17293d1, 0x228a4ef9, 0x8d6f5177, 0xfbcf0755, 0x268a5c1f, 0x9538b982,
- 0x61affd44, 0x6b1ca3cf, 0x5e9222b8, 0x8c66d3c5, 0x422183ed, 0xc9942109, 0x0bbb16fa, 0xf3d949f2,
- 0x36e02b20, 0xcee886b9, 0x05c128d5, 0x3d0bd2f9, 0x62136319, 0x6af50302, 0x0060e499, 0x08391a0c,
- 0x57339ba2, 0xbeba7d05, 0x2ac5b61c, 0xc4e9207c, 0xef2f0ce2, 0xd7373958, 0xd7622658, 0x901e646a,
- 0x95184460, 0xdc4e7487, 0x156e0c29, 0x2413d5e3, 0x61c1696d, 0xd24aaebd, 0x473826fd, 0xa0c238b9,
- 0x0ab111bb, 0xbd67c724, 0x972cd18b, 0xfbbd9d42, 0x6c472096, 0xe76115c0, 0x5f6f7ceb, 0xac9f45ae,
- 0xcecb72f1, 0x9c38339d, 0x8f682625, 0x0dea891e, 0xf07afff3, 0xa892374e, 0x175eb4af, 0xc8daadd8,
- 0x85db6ab0, 0x3a49bd0d, 0xc0b1b31d, 0x8a0e23fa, 0xc5e5767d, 0xf95884e0, 0x6425a415, 0x26fac51c,
- 0x3ea8449f, 0xe8f70edd, 0x062b1a63, 0xa6c4c60c, 0x52ab3316, 0x1e238438, 0x897a39ce, 0x78b63c9f,
- 0x364f5b8a, 0xef22ec2f, 0xee6e0850, 0xeca42d06, 0xfb0c75df, 0x5497e00c, 0x554b03d7, 0xd2874a00,
- 0x0ca8f58d, 0x94f0341c, 0xbe2ec921, 0x56c9f949, 0xdb4a9316, 0xf281501e, 0x53daec3f, 0x64f1b783,
- 0x154c6032, 0x0e2ff793, 0x33ce3573, 0xfacc5fdc, 0xf1178590, 0x3155bbd9, 0x0f023b22, 0x0224fcd8,
- 0x471bf4f4, 0x45f0a88a, 0x14f0cd97, 0x6ea354bb, 0x20cdb5cc, 0xb3db2392, 0x88d58655, 0x4e2a0e8a,
- 0x6fe51a8c, 0xfaa72ef2, 0xad8a43dc, 0x4212b210, 0xb779dfe4, 0x9d7307cc, 0x846532e4, 0xb9694eda,
- 0xd162af05, 0x3b1751f3, 0xa3d091f6, 0x56658154, 0x12b5e8c2, 0x02461069, 0xac14b958, 0x784934b8,
- 0xd6cce1da, 0xa5053701, 0x1aa4fb42, 0xb9a3def4, 0x1bda1f85, 0xef6fdbf2, 0xf2d89d2a, 0x4b183527,
- 0x8fd94057, 0x89f45681, 0x2b552879, 0xa6168695, 0xc12963b0, 0xff01eaab, 0x73e5b5c1, 0x585318e7,
- 0x624f14a5, 0x1a4a026b, 0x68082920, 0x57fd99b6, 0x6dc085a9, 0x8ac8d8ca, 0xf9eeeea9, 0x8a2400ca,
- 0xc95f260f, 0xd10036f9, 0xf91096ac, 0x3195220a, 0x1a356b2a, 0x73b7eaad, 0xaf6d6058, 0x71ef7afb,
- 0x80bc4234, 0x33562e94, 0xb12dfab4, 0x14451579, 0xdf59eae0, 0x51707062, 0x4012a829, 0x62c59cab,
- 0x347f8304, 0xd889659e, 0x5a9139db, 0x14efcc30, 0x852be3e8, 0xfc99f14d, 0x1d822dd6, 0xe2f76797,
- 0xe30219c8, 0xaa9ce884, 0x8a886eb3, 0xc87b7295, 0x988012e8, 0x314186ed, 0xbaf86856, 0xccd3c3b6,
- 0xee94e62f, 0x110a6783, 0xd2aae89c, 0xcc3b76fc, 0x435a0ce1, 0x34c2838f, 0xd571ec6c, 0x1366a993 // last one was: 0x1366a992
- //0xcbb9ac40, ...
- // (the last word 0x1366a992 was rounded up because the next one is 0xcbb9ac40 -- first bit is one 0xc..)
- // the calculating was made by using LnSurrounding1(2) method
- // which took 4035 iterations
- // (the result was compared with ln(2) taken from http://ja0hxv.calico.jp/pai/estart.html)
- exponent = -sint(man)*sint(TTMATH_BITS_PER_UINT);
- info = 0;
- this method sets the value of ln(10)
- the natural logarithm from 10
- I introduced this constant especially to make the conversion ToString()
- being faster. In fact the method ToString() is keeping values of logarithms
- it has calculated but it must calculate the logarithm at least once.
- If a program, which uses this library, is running for a long time this
- would be ok, but for programs which are running shorter, for example for
- CGI applications which only once are printing values, this would be much
- inconvenience. Then if we're printing with base (radix) 10 and the mantissa
- of our value is smaller than or equal to TTMATH_BUILTIN_VARIABLES_SIZE
- we don't calculate the logarithm but take it from this constant.
- void SetLn10()
- 0x935d8ddd, 0xaaa8ac16, 0xea56d62b, 0x82d30a28, 0xe28fecf9, 0xda5df90e, 0x83c61e82, 0x01f02d72,
- 0x962f02d7, 0xb1a8105c, 0xcc70cbc0, 0x2c5f0d68, 0x2c622418, 0x410be2da, 0xfb8f7884, 0x02e516d6,
- 0x782cf8a2, 0x8a8c911e, 0x765aa6c3, 0xb0d831fb, 0xef66ceb0, 0x4ab3c6fa, 0x5161bb49, 0xd219c7bb,
- 0xca67b35b, 0x23605085, 0x8e93368d, 0x44789c4f, 0x5b08b057, 0xd5ede20f, 0x469ea58e, 0x9305e981,
- 0xe2478fca, 0xad3aee98, 0x9cd5b42e, 0x6a271619, 0xa47ecb26, 0x978c5d4f, 0xdb1d28ea, 0x57d4fdc0,
- 0xe40bf3cc, 0x1e14126a, 0x45765cde, 0x268339db, 0xf47fa96d, 0xeb271060, 0xaf88486e, 0xa9b7401e,
- 0x3dfd3c51, 0x748e6d6e, 0x3848c8d2, 0x5faf1bca, 0xe88047f1, 0x7b0d9b50, 0xa949eaaa, 0xdf69e8a5,
- 0xf77e3760, 0x4e943960, 0xe38a5700, 0xffde2db1, 0xad6bfbff, 0xd821ba0a, 0x4cb0466d, 0x61ba648e,
- 0xef99c8e5, 0xf6974f36, 0x3982a78c, 0xa45ddfc8, 0x09426178, 0x19127a6e, 0x3b70fcda, 0x2d732d47,
- 0xb5e4b1c8, 0xc0e5a10a, 0xaa6604a5, 0x324ec3dc, 0xbc64ea80, 0x6e198566, 0x1f1d366c, 0x20663834,
- 0x4d5e843f, 0x20642b97, 0x0a62d18e, 0x478f7bd5, 0x8fcd0832, 0x4a7b32a6, 0xdef85a05, 0xeb56323a,
- 0x421ef5e0, 0xb00410a0, 0xa0d9c260, 0x794a976f, 0xf6ff363d, 0xb00b6b33, 0xf42c58de, 0xf8a3c52d,
- 0xed69b13d, 0xc1a03730, 0xb6524dc1, 0x8c167e86, 0x99d6d20e, 0xa2defd2b, 0xd006f8b4, 0xbe145a2a,
- 0xdf3ccbb3, 0x189da49d, 0xbc1261c8, 0xb3e4daad, 0x6a36cecc, 0xb2d5ae5b, 0x89bf752f, 0xb5dfb353,
- 0xff3065c4, 0x0cfceec8, 0x1be5a9a9, 0x67fddc57, 0xc4b83301, 0x006bf062, 0x4b40ed7a, 0x56c6cdcd,
- 0xa2d6fe91, 0x388e9e3e, 0x48a93f5f, 0x5e3b6eb4, 0xb81c4a5b, 0x53d49ea6, 0x8e668aea, 0xba83c7f8,
- 0xfb5f06c3, 0x58ac8f70, 0xfa9d8c59, 0x8c574502, 0xbaf54c96, 0xc84911f0, 0x0482d095, 0x1a0af022,
- 0xabbab080, 0xec97efd3, 0x671e4e0e, 0x52f166b6, 0xcd5cd226, 0x0dc67795, 0x2e1e34a3, 0xf799677f,
- 0x2c1d48f1, 0x2944b6c5, 0x2ba1307e, 0x704d67f9, 0x1c1035e4, 0x4e927c63, 0x03cf12bf, 0xe2cd2e31,
- 0xf8ee4843, 0x344d51b0, 0xf37da42b, 0x9f0b0fd9, 0x134fb2d9, 0xf815e490, 0xd966283f, 0x23962766,
- 0xeceab1e4, 0xf3b5fc86, 0x468127e2, 0xb606d10d, 0x3a45f4b6, 0xb776102d, 0x2fdbb420, 0x80c8fa84,
- 0xd0ff9f45, 0xc58aef38, 0xdb2410fd, 0x1f1cebad, 0x733b2281, 0x52ca5f36, 0xddf29daa, 0x544334b8,
- 0xdeeaf659, 0x4e462713, 0x1ed485b4, 0x6a0822e1, 0x28db471c, 0xa53938a8, 0x44c3bef7, 0xf35215c8,
- 0xb382bc4e, 0x3e4c6f15, 0x6285f54c, 0x17ab408e, 0xccbf7f5e, 0xd16ab3f6, 0xced2846d, 0xf457e14f,
- 0xbb45d9c5, 0x646ad497, 0xac697494, 0x145de32e, 0x93907128, 0xd263d521, 0x79efb424, 0xd64651d6,
- 0xebc0c9f0, 0xbb583a44, 0xc6412c84, 0x85bb29a6, 0x4d31a2cd, 0x92954469, 0xa32b1abd, 0xf7f5202c,
- 0xa4aa6c93, 0x2e9b53cf, 0x385ab136, 0x2741f356, 0x5de9c065, 0x6009901c, 0x88abbdd8, 0x74efcf73,
- 0x3f761ad4, 0x35f3c083, 0xfd6b8ee0, 0x0bef11c7, 0xc552a89d, 0x58ce4a21, 0xd71e54f2, 0x4157f6c7,
- 0xd4622316, 0xe98956d7, 0x450027de, 0xcbd398d8, 0x4b98b36a, 0x0724c25c, 0xdb237760, 0xe9324b68,
- 0x7523e506, 0x8edad933, 0x92197f00, 0xb853a326, 0xb330c444, 0x65129296, 0x34bc0670, 0xe177806d,
- 0xe338dac4, 0x5537492a, 0xe19add83, 0xcf45000f, 0x5b423bce, 0x6497d209, 0xe30e18a1, 0x3cbf0687,
- 0x67973103, 0xd9485366, 0x81506bba, 0x2e93a9a4, 0x7dd59d3f, 0xf17cd746, 0x8c2075be, 0x552a4348 // last one was: 0x552a4347
- // 0xb4a638ef, ...
- //(the last word 0x552a4347 was rounded up because the next one is 0xb4a638ef -- first bit is one 0xb..)
- // 256 32bit words for the mantissa -- about 2464 valid digits (decimal)
- // and then the first 256 32bit words were taken,
- // the calculating was made by using LnSurrounding1(10) method
- // which took 22080 iterations
- // (the result was compared with ln(10) taken from http://ja0hxv.calico.jp/pai/estart.html)
- // (the formula used in LnSurrounding1(x) converges badly when
- // the x is greater than one but in fact we can use it, only the
- // number of iterations will be greater)
- info = 0;
- this method sets the maximum value which can be held in this type
- void SetMax()
- info = 0;
- mantissa.SetMax();
- exponent.SetMax();
- // we don't have to use 'Standardizing()' because the last bit from
- // the mantissa is set
- this method sets the minimum value which can be held in this type
- void SetMin()
- info = 0;
- SetSign();
- testing whether there is a value zero or not
- bool IsZero() const
- return IsInfoBit(TTMATH_BIG_ZERO);
- this method returns true when there's the sign set
- also we don't check the NaN flag
- bool IsSign() const
- return IsInfoBit(TTMATH_BIG_SIGN);
- this method returns true when there is not a valid number
- bool IsNan() const
- return IsInfoBit(TTMATH_BIG_NAN);
- this method clears the sign
- (there'll be an absolute value)
- samples
- - -1 -> 1
- - 2 -> 2
- void Abs()
- this method remains the 'sign' of the value
- samples
- - -2 = -1
- - 0 = 0
- - 10 = 1
- void Sgn()
- // we have to check the NaN flag, because the next SetOne() method would clear it
- if( IsNan() )
- return;
- if( IsSign() )
- SetOne();
- SetSign();
- else
- if( IsZero() )
- SetZero(); // !! is nedeed here?
- else
- SetOne();
- this method sets the sign
- samples
- - -1 -> -1
- - 2 -> -2
- we do not check whether there is a zero or not, if you're using this method
- you must be sure that the value is (or will be afterwards) different from zero
- void SetSign()
- SetInfoBit(TTMATH_BIG_SIGN);
- this method changes the sign
- when there is a value of zero then the sign is not changed
- samples
- - -1 -> 1
- - 2 -> -2
- void ChangeSign()
- // we don't have to check the NaN flag here
- if( IsZero() )
- return;
- if( IsSign() )
- else
-private:
- this method does the half-to-even rounding (banker's rounding)
- if is_half is:
- - true - that means the rest was equal the half (0.5 decimal)
- - false - that means the rest was greater than a half (greater than 0.5 decimal)
- if the rest was less than a half then don't call this method
- (the rounding should does nothing then)
- uint RoundHalfToEven(bool is_half, bool rounding_up = true)
- uint c = 0;
- if( !is_half || mantissa.IsTheLowestBitSet() )
- if( rounding_up )
- if( mantissa.AddOne() )
- mantissa.Rcr(1, 1);
- c = exponent.AddOne();
- else
- #ifdef TTMATH_DEBUG
- uint c_from_zero =
- #endif
- mantissa.SubOne();
- // we're using rounding_up=false in Add() when the mantissas have different signs
- // mantissa can be zero only when previous mantissa was equal to ss2.mantissa
- // but in such a case 'last_bit_set' will not be set and consequently 'do_rounding' will be false
- TTMATH_ASSERT( c_from_zero == 0 )
- return c;
- * basic mathematic functions
- this method adds one to the existing value
- uint AddOne()
- Big<exp, man> one;
- one.SetOne();
- return Add(one);
- this method subtracts one from the existing value
- uint SubOne()
- one.SetOne();
- return Sub(one);
-private:
- an auxiliary method for adding
- void AddCheckExponents( Big<exp, man> & ss2,
- Int<exp> & exp_offset,
- bool & last_bit_set,
- bool & rest_zero,
- bool & do_adding,
- bool & do_rounding)
- Int<exp> mantissa_size_in_bits( man * TTMATH_BITS_PER_UINT );
- if( exp_offset == mantissa_size_in_bits )
- last_bit_set = ss2.mantissa.IsTheHighestBitSet();
- rest_zero = ss2.mantissa.AreFirstBitsZero(man*TTMATH_BITS_PER_UINT - 1);
- do_rounding = true; // we'are only rounding
- else
- if( exp_offset < mantissa_size_in_bits )
- uint moved = exp_offset.ToInt(); // how many times we must move ss2.mantissa
- rest_zero = true;
- if( moved > 0 )
- last_bit_set = static_cast<bool>( ss2.mantissa.GetBit(moved-1) );
- if( moved > 1 )
- rest_zero = ss2.mantissa.AreFirstBitsZero(moved - 1);
- // (2) moving 'exp_offset' times
- ss2.mantissa.Rcr(moved, 0);
- do_adding = true;
- // if exp_offset is greater than mantissa_size_in_bits then we do nothing
- // ss2 is too small for taking into consideration in the sum
- uint AddMantissas( Big<exp, man> & ss2,
- bool & rest_zero)
- uint c = 0;
- if( IsSign() == ss2.IsSign() )
- // values have the same signs
- if( mantissa.Add(ss2.mantissa) )
- // we have one bit more from addition (carry)
- // now rest_zero means the old rest_zero with the old last_bit_set
- rest_zero = (!last_bit_set && rest_zero);
- last_bit_set = mantissa.Rcr(1,1);
- c += exponent.AddOne();
- else
- // values have different signs
- // there shouldn't be a carry here because
- // (1) (2) guarantee that the mantissa of this
- // is greater than or equal to the mantissa of the ss2
- uint c_temp =
- #endif
- mantissa.Sub(ss2.mantissa);
- TTMATH_ASSERT( c_temp == 0 )
- return c;
-public:
- Addition this = this + ss2
- it returns carry if the sum is too big
- uint Add(Big<exp, man> ss2, bool round = true, bool adding = true)
- bool last_bit_set, rest_zero, do_adding, do_rounding, rounding_up;
- Int<exp> exp_offset( exponent );
- uint c = 0;
- if( IsNan() || ss2.IsNan() )
- return CheckCarry(1);
- if( !adding )
- ss2.ChangeSign(); // subtracting
- exp_offset.Sub( ss2.exponent );
- exp_offset.Abs();
- // (1) abs(this) will be >= abs(ss2)
- if( SmallerWithoutSignThan(ss2) )
- Swap(ss2);
- if( ss2.IsZero() )
- return 0;
- last_bit_set = rest_zero = do_adding = do_rounding = false;
- rounding_up = (IsSign() == ss2.IsSign());
- AddCheckExponents(ss2, exp_offset, last_bit_set, rest_zero, do_adding, do_rounding);
- if( do_adding )
- c += AddMantissas(ss2, last_bit_set, rest_zero);
- if( !round || !last_bit_set )
- do_rounding = false;
- if( do_rounding )
- c += RoundHalfToEven(rest_zero, rounding_up);
- if( do_adding || do_rounding )
- c += Standardizing();
- return CheckCarry(c);
- Subtraction this = this - ss2
- it returns carry if the result is too big
- uint Sub(const Big<exp, man> & ss2, bool round = true)
- return Add(ss2, round, false);
- bitwise AND
- this and ss2 must be >= 0
- return values:
- - 0 - ok
- - 1 - carry
- - 2 - this or ss2 was negative
- uint BitAnd(Big<exp, man> ss2)
- if( IsSign() || ss2.IsSign() )
- SetNan();
- return 2;
- if( IsZero() )
- return 0;
- SetZero();
- return 0;
- uint c = 0;
- exp_offset.Abs();
- // abs(this) will be >= abs(ss2)
- Swap(ss2);
- if( exp_offset >= mantissa_size_in_bits )
- // the second value is too small
- SetZero();
- return 0;
- // exp_offset < mantissa_size_in_bits, moving 'exp_offset' times
- ss2.mantissa.Rcr( exp_offset.ToInt(), 0 );
- mantissa.BitAnd(ss2.mantissa);
- bitwise OR
- return values:
- - 0 - ok
- - 1 - carry
- uint BitOr(Big<exp, man> ss2)
- SetNan();
- return 2;
- if( IsZero() )
- *this = ss2;
- return 0;
- return 0;
- uint c = 0;
- exp_offset.Abs();
- Swap(ss2);
- return 0;
- mantissa.BitOr(ss2.mantissa);
- bitwise XOR
- return values:
- - 0 - ok
- - 1 - carry
- uint BitXor(Big<exp, man> ss2)
- SetNan();
- return 2;
- return 0;
- if( IsZero() )
- *this = ss2;
- return 0;
- uint c = 0;
- exp_offset.Abs();
- Swap(ss2);
- return 0;
- mantissa.BitXor(ss2.mantissa);
- Multiplication this = this * ss2 (ss2 is uint)
- ss2 without a sign
- uint MulUInt(uint ss2)
- UInt<man+1> man_result;
- uint i,c = 0;
- if( IsNan() )
- return 1;
- if( IsZero() )
- return 0;
- if( ss2 == 0 )
- SetZero();
- return 0;
- // man_result = mantissa * ss2.mantissa
- mantissa.MulInt(ss2, man_result);
- sint bit = UInt<man>::FindLeadingBitInWord(man_result.table[man]); // man - last word
- if( bit!=-1 && uint(bit) > (TTMATH_BITS_PER_UINT/2) )
- // 'i' will be from 0 to TTMATH_BITS_PER_UINT
- i = man_result.CompensationToLeft();
- c = exponent.Add( TTMATH_BITS_PER_UINT - i );
- for(i=0 ; i<man ; ++i)
- mantissa.table[i] = man_result.table[i+1];
- else
- if( bit != -1 )
- man_result.Rcr(bit+1, 0);
- c += exponent.Add(bit+1);
- mantissa.table[i] = man_result.table[i];
- Multiplication this = this * ss2 (ss2 is sint)
- ss2 with a sign
- uint MulInt(sint ss2)
- if( IsNan() )
- return 1;
- if( ss2 == 0 )
- SetZero();
- return 0;
- if( IsZero() )
- return 0;
- if( IsSign() == (ss2<0) )
- // the signs are the same (both are either - or +), the result is positive
- Abs();
- else
- // the signs are different, the result is negative
- SetSign();
- if( ss2<0 )
- ss2 = -ss2;
- return MulUInt( uint(ss2) );
-private:
- this method checks whether a table pointed by 'tab' and 'len'
- has the value 0.5 decimal
- (it is treated as the comma operator would be before the highest bit)
- call this method only if the highest bit is set - you have to test it beforehand
- return:
- - true - tab was equal the half (0.5 decimal)
- - false - tab was greater than a half (greater than 0.5 decimal)
- bool CheckGreaterOrEqualHalf(uint * tab, uint len)
- uint i;
- TTMATH_ASSERT( len>0 && (tab[len-1] & TTMATH_UINT_HIGHEST_BIT)!=0 )
- for(i=0 ; i<len-1 ; ++i)
- if( tab[i] != 0 )
- return false;
- if( tab[i] != TTMATH_UINT_HIGHEST_BIT )
- return false;
- return true;
-private:
- multiplication this = this * ss2
- this method returns a carry
- uint MulRef(const Big<exp, man> & ss2, bool round = true)
- TTMATH_REFERENCE_ASSERT( ss2 )
- UInt<man*2> man_result;
- uint c = 0;
- uint i;
- if( IsZero() )
- return 0;
- SetZero();
- return 0;
- mantissa.MulBig(ss2.mantissa, man_result);
- // 'i' will be from 0 to man*TTMATH_BITS_PER_UINT
- // because mantissa and ss2.mantissa are standardized
- // (the highest bit in man_result is set to 1 or
- // if there is a zero value in man_result the method CompensationToLeft()
- // returns 0 but we'll correct this at the end in Standardizing() method)
- uint exp_add = man * TTMATH_BITS_PER_UINT - i;
- if( exp_add )
- c += exponent.Add( exp_add );
- c += exponent.Add( ss2.exponent );
- mantissa.table[i] = man_result.table[i+man];
- if( round && (man_result.table[man-1] & TTMATH_UINT_HIGHEST_BIT) != 0 )
- bool is_half = CheckGreaterOrEqualHalf(man_result.table, man);
- c += RoundHalfToEven(is_half);
- // the signs are the same, the result is positive
- Abs();
- else
- // if the value is zero it will be corrected later in Standardizing method
- SetSign();
-public:
- uint Mul(const Big<exp, man> & ss2, bool round = true)
- if( this == &ss2 )
- Big<exp, man> copy_ss2(ss2);
- return MulRef(copy_ss2, round);
- else
- return MulRef(ss2, round);
-private:
- division this = this / ss2
- return value:
- - 0 - ok
- - 1 - carry (in a division carry can be as well)
- - 2 - improper argument (ss2 is zero)
- uint DivRef(const Big<exp, man> & ss2, bool round = true)
- UInt<man*2> man1;
- UInt<man*2> man2;
- uint i,c = 0;
- SetNan();
- return 2;
- if( IsZero() )
- return 0;
- // !! this two loops can be joined together
- man1.table[i+man] = mantissa.table[i];
- man2.table[i] = ss2.mantissa.table[i];
- man1.table[i] = 0;
- man2.table[i+man] = 0;
- man1.Div(man2);
- i = man1.CompensationToLeft();
- if( i )
- c += exponent.Sub(i);
- c += exponent.Sub(ss2.exponent);
- mantissa.table[i] = man1.table[i+man];
- if( round && (man1.table[man-1] & TTMATH_UINT_HIGHEST_BIT) != 0 )
- bool is_half = CheckGreaterOrEqualHalf(man1.table, man);
- Abs();
- else
- SetSign(); // if there is a zero it will be corrected in Standardizing()
-public:
- return value:
- - 0 - ok
- uint Div(const Big<exp, man> & ss2, bool round = true)
- return DivRef(copy_ss2, round);
- else
- return DivRef(ss2, round);
-private:
- uint ModRef(const Big<exp, man> & ss2)
- uint c = 0;
- SetNan();
- return 2;
- if( !SmallerWithoutSignThan(ss2) )
- Big<exp, man> temp(*this);
- c = temp.Div(ss2);
- temp.SkipFraction();
- c += temp.Mul(ss2);
- c += Sub(temp);
- if( !SmallerWithoutSignThan( ss2 ) )
- c += 1;
-public:
- caltulate the remainder from a division
- samples
- - 12.6 mod 3 = 0.6 because 12.6 = 3*4 + 0.6
- - -12.6 mod 3 = -0.6 bacause -12.6 = 3*(-4) + (-0.6)
- - 12.6 mod -3 = 0.6
- - -12.6 mod -3 = -0.6
- in other words: this(old) = ss2 * q + this(new)
- return value:
- - 0 - ok
- - 1 - carry
- uint Mod(const Big<exp, man> & ss2)
- return ModRef(copy_ss2);
- else
- return ModRef(ss2);
- this method returns: 'this' mod 2
- (either zero or one)
- this method is much faster than using Mod( object_with_value_two )
- uint Mod2() const
- if( exponent>sint(0) || exponent<=-sint(man*TTMATH_BITS_PER_UINT) )
- return 0;
- sint exp_int = exponent.ToInt();
- // 'exp_int' is negative (or zero), we set it as positive
- exp_int = -exp_int;
- return mantissa.GetBit(exp_int);
- power this = this ^ pow
- (pow without a sign)
- binary algorithm (r-to-l)
- return values:
- - 0 - ok
- - 1 - carry
- - 2 - incorrect arguments (0^0)
- template<uint pow_size>
- uint Pow(UInt<pow_size> pow)
- if( IsNan() )
- return 1;
- if( IsZero() )
- if( pow.IsZero() )
- // we don't define zero^zero
- SetNan();
- return 2;
- // 0^(+something) is zero
- return 0;
- Big<exp, man> start(*this);
- Big<exp, man> result;
- result.SetOne();
- uint c = 0;
- while( !c )
- if( pow.table[0] & 1 )
- c += result.Mul(start);
- pow.Rcr(1);
- break;
- c += start.Mul(start);
- *this = result;
- p can be negative
- return values:
- - 0 - ok
- - 1 - carry
- - 2 - incorrect arguments 0^0 or 0^(-something)
- uint Pow(Int<pow_size> pow)
- if( IsNan() )
- return 1;
- if( !pow.IsSign() )
- return Pow( UInt<pow_size>(pow) );
- if( IsZero() )
- // if 'p' is negative then
- // 'this' must be different from zero
- SetNan();
- return 2;
- uint c = pow.ChangeSign();
- Big<exp, man> t(*this);
- c += t.Pow( UInt<pow_size>(pow) ); // here can only be a carry (return:1)
- SetOne();
- c += Div(t);
- power this = this ^ abs([pow])
- pow is treated as a value without a sign and without a fraction
- if pow has a sign then the method pow.Abs() is used
- if pow has a fraction the fraction is skipped (not used in calculation)
- return values:
- - 0 - ok
- - 1 - carry
- uint PowUInt(Big<exp, man> pow)
- if( IsNan() || pow.IsNan() )
- if( IsZero() )
- SetNan();
- return 2;
- return 0;
- if( pow.IsSign() )
- pow.Abs();
- uint c = 0;
- one.SetOne();
- result = one;
- while( !c )
- if( pow.Mod2() )
- c += pow.exponent.SubOne();
- if( pow < one )
- break;
- *this = result;
- power this = this ^ [pow]
- pow is treated as a value without a fraction
- pow can be negative
- return values:
- - 0 - ok
- - 1 - carry
- uint PowInt(const Big<exp, man> & pow)
- return PowUInt(pow);
- if( IsZero() )
- // if 'pow' is negative then
- SetNan();
- return 2;
- uint c = temp.PowUInt(pow); // here can only be a carry (result:1)
- SetOne();
- c += Div(temp);
- this must be greater than zero (this > 0)
- pow can be negative and with fraction
- return values:
- - 0 - ok
- - 1 - carry
- - 2 - incorrect argument ('this' <= 0)
- uint PowFrac(const Big<exp, man> & pow)
- Big<exp, man> temp;
- uint c = temp.Ln(*this);
- if( c != 0 ) // can be 2 from Ln()
- SetNan();
- return c;
- c += temp.Mul(pow);
- c += Exp(temp);
- return values:
- - 0 - ok
- - 1 - carry
- - 2 - incorrect argument ('this' or 'pow')
- uint Pow(const Big<exp, man> & pow)
- if( IsZero() )
- // 0^pow will be 0 only for pow>0
- if( pow.IsSign() || pow.IsZero() )
- SetNan();
- return 2;
- SetZero();
- return 0;
- if( pow.exponent>-sint(man*TTMATH_BITS_PER_UINT) && pow.exponent<=0 )
- if( pow.IsInteger() )
- return PowInt( pow );
- return PowFrac(pow);
- e.g. let this=9 then this.Sqrt() gives 3
- return:
- - 0 - ok
- - 1 - carry
- - 2 - improper argument (this<0 or NaN)
- uint Sqrt()
- if( IsNan() || IsSign() )
- SetNan();
- return 2;
- if( IsZero() )
- return 0;
- Big<exp, man> old(*this);
- Big<exp, man> ln;
- uint c = 0;
- // we're using the formula: sqrt(x) = e ^ (ln(x) / 2)
- c += ln.Ln(*this);
- c += ln.exponent.SubOne(); // ln = ln / 2
- c += Exp(ln);
- // above formula doesn't give accurate results for some integers
- // e.g. Sqrt(81) would not be 9 but a value very closed to 9
- // we're rounding the result, calculating result*result and comparing
- // with the old value, if they are equal then the result is an integer too
- if( !c && old.IsInteger() && !IsInteger() )
- Big<exp, man> temp2(temp);
- c += temp.Mul(temp2);
- if( temp == old )
- *this = temp2;
-private:
-#ifdef TTMATH_CONSTANTSGENERATOR
-public:
-#endif
- Exponent this = exp(x) = e^x where x is in (-1,1)
- we're using the formula exp(x) = 1 + (x)/(1!) + (x^2)/(2!) + (x^3)/(3!) + ...
- void ExpSurrounding0(const Big<exp,man> & x, uint * steps = 0)
- TTMATH_REFERENCE_ASSERT( x )
- Big<exp,man> denominator, denominator_i;
- Big<exp,man> one, old_value, next_part;
- Big<exp,man> numerator = x;
- SetOne();
- one.SetOne();
- denominator.SetOne();
- denominator_i.SetOne();
- uint i;
- old_value = *this;
- // we begin from 1 in order to not test at the beginning
- #ifdef TTMATH_CONSTANTSGENERATOR
- for(i=1 ; true ; ++i)
- #else
- for(i=1 ; i<=TTMATH_ARITHMETIC_MAX_LOOP ; ++i)
- #endif
- bool testing = ((i & 3) == 0); // it means '(i % 4) == 0'
- next_part = numerator;
- if( next_part.Div( denominator ) )
- // if there is a carry here we only break the loop
- // however the result we return as good
- // it means there are too many parts of the formula
- break;
- Add( next_part );
- if( testing )
- if( old_value == *this )
- // we've added next few parts of the formula but the result
- // is still the same then we break the loop
- break;
- else
- // we set the denominator and the numerator for a next part of the formula
- if( denominator_i.Add(one) )
- // if there is a carry here the result we return as good
- break;
- if( denominator.Mul(denominator_i) )
- break;
- if( numerator.Mul(x) )
- break;
- if( steps )
- *steps = i;
-public:
- we're using the fact that our value is stored in form of:
- x = mantissa * 2^exponent
- then
- e^x = e^(mantissa* 2^exponent) or
- e^x = (e^mantissa)^(2^exponent)
- 'Exp' returns a carry if we can't count the result ('x' is too big)
- uint Exp(const Big<exp,man> & x)
- uint c = 0;
- if( x.IsNan() )
- if( x.IsZero() )
- SetOne();
- return 0;
- // m will be the value of the mantissa in range (-1,1)
- Big<exp,man> m(x);
- m.exponent = -sint(man*TTMATH_BITS_PER_UINT);
- // 'e_' will be the value of '2^exponent'
- // e_.mantissa.table[man-1] = TTMATH_UINT_HIGHEST_BIT; and
- // e_.exponent.Add(1) mean:
- // e_.mantissa.table[0] = 1;
- // e_.Standardizing();
- // e_.exponent.Add(man*TTMATH_BITS_PER_UINT)
- // (we must add 'man*TTMATH_BITS_PER_UINT' because we've taken it from the mantissa)
- Big<exp,man> e_(x);
- e_.mantissa.SetZero();
- e_.mantissa.table[man-1] = TTMATH_UINT_HIGHEST_BIT;
- c += e_.exponent.Add(1);
- e_.Abs();
- now we've got:
- m - the value of the mantissa in range (-1,1)
- e_ - 2^exponent
- e_ can be as:
- ...2^-2, 2^-1, 2^0, 2^1, 2^2 ...
- ...1/4 , 1/2 , 1 , 2 , 4 ...
- above one e_ is integer
- if e_ is greater than 1 we calculate the exponent as:
- e^(m * e_) = ExpSurrounding0(m) ^ e_
- and if e_ is smaller or equal one we calculate the exponent in this way:
- e^(m * e_) = ExpSurrounding0(m* e_)
- because if e_ is smaller or equal 1 then the product of m*e_ is smaller or equal m
- if( e_ <= 1 )
- m.Mul(e_);
- ExpSurrounding0(m);
- else
- c += PowUInt(e_);
-private:
-public:
-#endif
- Natural logarithm this = ln(x) where x in range <1,2)
- we're using the formula:
- ln x = 2 * [ (x-1)/(x+1) + (1/3)((x-1)/(x+1))^3 + (1/5)((x-1)/(x+1))^5 + ... ]
- void LnSurrounding1(const Big<exp,man> & x, uint * steps = 0)
- Big<exp,man> old_value, next_part, denominator, one, two, x1(x), x2(x);
- one.SetOne();
- if( x == one )
- // LnSurrounding1(1) is 0
- SetZero();
- return;
- two = 2;
- x1.Sub(one);
- x2.Add(one);
- x1.Div(x2);
- x2 = x1;
- x2.Mul(x1);
- SetZero();
- uint i;
- #else
- #endif
- next_part = x1;
- if( next_part.Div(denominator) )
- break;
- Add(next_part);
- if( testing )
- // we've added next (step_test) parts of the formula but the result
- break;
- else
- if( x1.Mul(x2) )
- break;
- if( denominator.Add(two) )
- break;
- // this = this * 2
- // ( there can't be a carry here because we calculate the logarithm between <1,2) )
- exponent.AddOne();
- if( steps )
- *steps = i;
-public:
- (a logarithm with the base equal 'e')
- then
- ln(x) = ln (mantissa * 2^exponent) = ln (mantissa) + (exponent * ln (2))
- the mantissa we'll show as a value from range <1,2) because the logarithm
- is decreasing too fast when 'x' is going to 0
- return values:
- - 0 - ok
- - 1 - overflow (carry)
- - 2 - incorrect argument (x<=0)
- uint Ln(const Big<exp,man> & x)
- if( x.IsNan() )
- if( x.IsSign() || x.IsZero() )
- SetNan();
- return 2;
- Big<exp,man> exponent_temp;
- exponent_temp.FromInt( x.exponent );
- // m will be the value of the mantissa in range <1,2)
- m.exponent = -sint(man*TTMATH_BITS_PER_UINT - 1);
- // we must add 'man*TTMATH_BITS_PER_UINT-1' because we've taken it from the mantissa
- uint c = exponent_temp.Add(man*TTMATH_BITS_PER_UINT-1);
- LnSurrounding1(m);
- Big<exp,man> ln2;
- ln2.SetLn2();
- c += exponent_temp.Mul(ln2);
- c += Add(exponent_temp);
- Logarithm from 'x' with a 'base'
- Log(x) with 'base' = ln(x) / ln(base)
- return values:
- - 0 - ok
- - 1 - overflow
- - 3 - incorrect base (a<=0 or a=1)
- uint Log(const Big<exp,man> & x, const Big<exp,man> & base)
- if( x.IsNan() || base.IsNan() )
- SetNan();
- return 2;
- Big<exp,man> denominator;;
- if( base.IsSign() || base.IsZero() || base==denominator )
- SetNan();
- return 3;
- if( x == denominator ) // (this is: if x == 1)
- // log(1) is 0
- SetZero();
- return 0;
- // another error values we've tested at the beginning
- // there can only be a carry
- uint c = Ln(x);
- c += denominator.Ln(base);
- c += Div(denominator);
- * converting methods
- converting from another type of a Big object
- template<uint another_exp, uint another_man>
- uint FromBig(const Big<another_exp, another_man> & another)
- info = another.info;
- if( IsNan() )
- return 1;
- if( exponent.FromInt(another.exponent) )
- SetNan();
- return 1;
- uint man_len_min = (man < another_man)? man : another_man;
- uint i;
- uint c = 0;
- for( i = 0 ; i<man_len_min ; ++i )
- mantissa.table[man-1-i] = another.mantissa.table[another_man-1-i];
- for( ; i<man ; ++i )
- mantissa.table[man-1-i] = 0;
- // MS Visual Express 2005 reports a warning (in the lines with 'uint man_diff = ...'):
- // warning C4307: '*' : integral constant overflow
- // but we're using 'if( man > another_man )' and 'if( man < another_man )' and there'll be no such situation here
- #ifdef _MSC_VER
- #pragma warning( disable: 4307 )
- #endif
- if( man > another_man )
- uint man_diff = (man - another_man) * TTMATH_BITS_PER_UINT;
- c += exponent.SubInt(man_diff, 0);
- else
- if( man < another_man )
- uint man_diff = (another_man - man) * TTMATH_BITS_PER_UINT;
- c += exponent.AddInt(man_diff, 0);
- #ifdef _MSC_VER
- #pragma warning( default: 4307 )
- #endif
- // mantissa doesn't have to be standardized (either the highest bit is set or all bits are equal zero)
- CorrectZero();
-private:
- an auxiliary method for converting 'this' into 'result'
- if the value is too big this method returns a carry (1)
- uint ToUIntOrInt(uint & result) const
- result = 0;
- if( IsZero() )
- return 0;
- sint maxbit = -sint(man*TTMATH_BITS_PER_UINT);
- if( exponent > maxbit + sint(TTMATH_BITS_PER_UINT) )
- // if exponent > (maxbit + sint(TTMATH_BITS_PER_UINT)) the value can't be passed
- // into the 'sint' type (it's too big)
- return 1;
- if( exponent <= maxbit )
- // our value is from the range of (-1,1) and we return zero
- return 0;
- // exponent is from a range of (maxbit, maxbit + sint(TTMATH_BITS_PER_UINT) >
- // and [maxbit + sint(TTMATH_BITS_PER_UINT] <= 0
- sint how_many_bits = exponent.ToInt();
- // how_many_bits is negative, we'll make it positive
- how_many_bits = -how_many_bits;
- result = (mantissa.table[man-1] >> (how_many_bits % TTMATH_BITS_PER_UINT));
- return 0;
-public:
- this method converts 'this' into uint
- uint ToUInt() const
- uint result;
- ToUInt(result);
- return result;
- this method converts 'this' into 'result'
- uint ToUInt(uint & result) const
- if( ToUIntOrInt(result) )
- return 1;
- if( IsSign() )
- return 1;
- return 0;
- this method converts 'this' into sint
- sint ToInt() const
- sint result;
- ToInt(result);
- return result;
- uint ToInt(uint & result) const
- return ToUInt(result);
- uint ToInt(sint & result) const
- uint result_uint;
- uint c = ToUIntOrInt(result_uint);
- result = sint(result_uint);
- if( c )
- return 1;
- uint mask = 0;
- if( IsSign() )
- mask = TTMATH_UINT_MAX_VALUE;
- result = -result;
- return ((result & TTMATH_UINT_HIGHEST_BIT) == (mask & TTMATH_UINT_HIGHEST_BIT)) ? 0 : 1;
-private:
- template<uint int_size>
- uint ToUIntOrInt(UInt<int_size> & result) const
- result.SetZero();
- if( IsZero() )
- return 0;
- if( exponent > maxbit + sint(int_size*TTMATH_BITS_PER_UINT) )
- // if exponent > (maxbit + sint(int_size*TTMATH_BITS_PER_UINT)) the value can't be passed
- // into the 'UInt<int_size>' type (it's too big)
- return 1;
- // our value is from range (-1,1) and we return zero
- return 0;
- if( how_many_bits < 0 )
- uint index = how_many_bits / TTMATH_BITS_PER_UINT;
- UInt<man> mantissa_temp(mantissa);
- mantissa_temp.Rcr( how_many_bits % TTMATH_BITS_PER_UINT, 0 );
- for(uint i=index, a=0 ; i<man ; ++i,++a)
- result.table[a] = mantissa_temp.table[i];
- else
- if( index + (man-1) < int_size )
- // above 'if' is always true
- // this is only to get rid of a warning "warning: array subscript is above array bounds"
- // (from gcc)
- // we checked the condition there: "if( exponent > maxbit + sint(int_size*TTMATH_BITS_PER_UINT) )"
- // but gcc doesn't understand our types - exponent is Int<>
- for(uint i=0 ; i<man ; ++i)
- result.table[index+i] = mantissa.table[i];
- result.Rcl( how_many_bits % TTMATH_BITS_PER_UINT, 0 );
- return 0;
-public:
- uint ToUInt(UInt<int_size> & result) const
- uint c = ToUIntOrInt(result);
- if( c )
- return 1;
- if( IsSign() )
- return 1;
- return 0;
- uint ToInt(UInt<int_size> & result) const
- uint ToInt(Int<int_size> & result) const
- if( c )
- return 1;
- uint mask = 0;
- if( IsSign() )
- result.ChangeSign();
- return ((result.table[int_size-1] & TTMATH_UINT_HIGHEST_BIT) == (mask & TTMATH_UINT_HIGHEST_BIT))? 0 : 1;
- a method for converting 'uint' to this class
- uint FromUInt(uint value)
- if( value == 0 )
- SetZero();
- return 0;
- info = 0;
- for(uint i=0 ; i<man-1 ; ++i)
- mantissa.table[i] = 0;
- mantissa.table[man-1] = value;
- exponent = -sint(man-1) * sint(TTMATH_BITS_PER_UINT);
- // there shouldn't be a carry because 'value' has the 'uint' type
- Standardizing();
- return 0;
- uint FromInt(uint value)
- return FromUInt(value);
- a method for converting 'sint' to this class
- uint FromInt(sint value)
- bool is_sign = false;
- if( value < 0 )
- value = -value;
- is_sign = true;
- FromUInt(uint(value));
- if( is_sign )
- SetSign();
- return 0;
- this method converts from standard double into this class
- standard double means IEEE-754 floating point value with 64 bits
- it is as follows (from http://www.psc.edu/general/software/packages/ieee/ieee.html):
- The IEEE double precision floating point standard representation requires
- a 64 bit word, which may be represented as numbered from 0 to 63, left to
- right. The first bit is the sign bit, S, the next eleven bits are the
- exponent bits, 'E', and the final 52 bits are the fraction 'F':
- S EEEEEEEEEEE FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
- 0 1 11 12 63
- The value V represented by the word may be determined as follows:
- - If E=2047 and F is nonzero, then V=NaN ("Not a number")
- - If E=2047 and F is zero and S is 1, then V=-Infinity
- - If E=2047 and F is zero and S is 0, then V=Infinity
- - If 0<E<2047 then V=(-1)**S * 2 ** (E-1023) * (1.F) where "1.F" is intended
- to represent the binary number created by prefixing F with an implicit
- leading 1 and a binary point.
- - If E=0 and F is nonzero, then V=(-1)**S * 2 ** (-1022) * (0.F) These are
- "unnormalized" values.
- - If E=0 and F is zero and S is 1, then V=-0
- - If E=0 and F is zero and S is 0, then V=0
-#ifdef TTMATH_PLATFORM32
- uint FromDouble(double value)
- // I am not sure what will be on a platform which has
- // a different endianness... but we use this library only
- // on x86 and amd (intel) 64 bits (as there's a lot of assembler code)
- union
- double d;
- uint u[2]; // two 32bit words
- } temp;
- temp.d = value;
- sint e = ( temp.u[1] & 0x7FF00000u) >> 20;
- uint m1 = ((temp.u[1] & 0xFFFFFu) << 11) | (temp.u[0] >> 21);
- uint m2 = temp.u[0] << 11;
- if( e == 2047 )
- // If E=2047 and F is nonzero, then V=NaN ("Not a number")
- // If E=2047 and F is zero and S is 1, then V=-Infinity
- // If E=2047 and F is zero and S is 0, then V=Infinity
- // we do not support -Infinity and +Infinity
- // we assume that there is always NaN
- SetNan();
- else
- if( e > 0 )
- // If 0<E<2047 then
- // V=(-1)**S * 2 ** (E-1023) * (1.F)
- // where "1.F" is intended to represent the binary number
- // created by prefixing F with an implicit leading 1 and a binary point.
- FromDouble_SetExpAndMan((temp.u[1] & 0x80000000u) != 0,
- e - 1023 - man*TTMATH_BITS_PER_UINT + 1, 0x80000000u,
- m1, m2);
- // we do not have to call Standardizing() here
- // because the mantissa will have the highest bit set
- else
- // e == 0
- if( m1 != 0 || m2 != 0 )
- // If E=0 and F is nonzero,
- // then V=(-1)**S * 2 ** (-1022) * (0.F)
- // These are "unnormalized" values.
- UInt<2> m;
- m.table[1] = m1;
- m.table[0] = m2;
- uint moved = m.CompensationToLeft();
- e - 1022 - man*TTMATH_BITS_PER_UINT + 1 - moved, 0,
- m.table[1], m.table[0]);
- else
- // If E=0 and F is zero and S is 1, then V=-0
- // If E=0 and F is zero and S is 0, then V=0
- // we do not support -0 or 0, only is one 0
- SetZero();
- return 0; // never be a carry
-private:
- void FromDouble_SetExpAndMan(bool is_sign, int e, uint mhighest, uint m1, uint m2)
- exponent = e;
- if( man > 1 )
- mantissa.table[man-1] = m1 | mhighest;
- mantissa.table[sint(man-2)] = m2;
- // although man>1 we're using casting into sint
- // to get rid from a warning which generates Microsoft Visual:
- for(uint i=0 ; i<man-2 ; ++i)
- else
- mantissa.table[0] = m1 | mhighest;
- info = 0;
- // the value should be different from zero
- TTMATH_ASSERT( mantissa.IsZero() == false )
- if( is_sign )
- SetSign();
-#else
-public:
- // 64bit platforms
- // I am not sure what will be on a plaltform which has
- union
- double d;
- uint u; // one 64bit word
- } temp;
- temp.d = value;
- sint e = (temp.u & 0x7FF0000000000000ul) >> 52;
- uint m = (temp.u & 0xFFFFFFFFFFFFFul) << 11;
- if( e == 2047 )
- SetNan();
- else
- if( e > 0 )
- FromDouble_SetExpAndMan((temp.u & 0x8000000000000000ul) != 0,
- 0x8000000000000000ul, m);
- else
- // e == 0
- if( m != 0 )
- FromDouble_SetExpAndMan(bool(temp.u & 0x8000000000000000ul),
- e - 1022 - man*TTMATH_BITS_PER_UINT + 1, 0, m);
- Standardizing();
- else
- SetZero();
-private:
- void FromDouble_SetExpAndMan(bool is_sign, sint e, uint mhighest, uint m)
- exponent = e;
- mantissa.table[man-1] = m | mhighest;
- info = 0;
- if( is_sign )
- SetSign();
-#endif
-public:
- this method converts from float to this class
- uint FromFloat(float value)
- return FromDouble(double(value));
- this method converts from this class into the 'double'
- if the value is too big:
- 'result' will be +/-infinity (depending on the sign)
- if the value is too small:
- 'result' will be 0
- double ToDouble() const
- double result;
- ToDouble(result);
- return result;
-private:
- an auxiliary method to check if the float value is +/-infinity
- we provide this method because isinf(float) in only in C99 language
- description taken from: http://www.psc.edu/general/software/packages/ieee/ieee.php
- The IEEE single precision floating point standard representation requires a 32 bit word,
- which may be represented as numbered from 0 to 31, left to right.
- The first bit is the sign bit, S, the next eight bits are the exponent bits, 'E',
- and the final 23 bits are the fraction 'F':
- S EEEEEEEE FFFFFFFFFFFFFFFFFFFFFFF
- 0 1 8 9 31
- - If E=255 and F is nonzero, then V=NaN ("Not a number")
- - If E=255 and F is zero and S is 1, then V=-Infinity
- - If E=255 and F is zero and S is 0, then V=Infinity
- - If 0<E<255 then V=(-1)**S * 2 ** (E-127) * (1.F) where "1.F" is intended to represent
- the binary number created by prefixing F with an implicit leading 1 and a binary point.
- - If E=0 and F is nonzero, then V=(-1)**S * 2 ** (-126) * (0.F) These are "unnormalized" values.
- bool IsInf(float value) const
- // CHECK ME
- // need testing on a 64 bit machine
- union
- float d;
- uint u;
- } temp;
- temp.d = value;
- if( ((temp.u >> 23) & 0xff) == 0xff )
- if( (temp.u & 0x7FFFFF) == 0 )
- return true; // +/- infinity
- return false;
-public:
- this method converts from this class into the 'float'
- float ToFloat() const
- float result;
- ToFloat(result);
- return result;
- - 'result' will be +/-infinity (depending on the sign)
- - and the method returns 1
- - 'result' will be 0
- uint ToFloat(float & result) const
- double result_double;
- uint c = ToDouble(result_double);
- result = float(result_double);
- if( result == -0.0f )
- result = 0.0f;
- if( c )
- return 1;
- // although the result_double can have a correct value
- // but after converting to float there can be infinity
- if( IsInf(result) )
- return 1;
- if( result == 0.0f && result_double != 0.0 )
- // result_double was too small for float
- return 1;
- return 0;
- uint ToDouble(double & result) const
- if( IsZero() )
- result = 0.0;
- return 0;
- if( IsNan() )
- result = ToDouble_SetDouble( false, 2047, 0, false, true);
- return 0;
- sint e_correction = sint(man*TTMATH_BITS_PER_UINT) - 1;
- if( exponent >= 1024 - e_correction )
- // +/- infinity
- result = ToDouble_SetDouble( IsSign(), 2047, 0, true);
- return 1;
- else
- if( exponent <= -1023 - 52 - e_correction )
- // too small value - we assume that there'll be a zero
- result = 0;
- // and return a carry
- return 1;
- sint e = exponent.ToInt() + e_correction;
- if( e <= -1023 )
- // -1023-52 < e <= -1023 (unnormalized value)
- result = ToDouble_SetDouble( IsSign(), 0, -(e + 1023));
- else
- // -1023 < e < 1024
- result = ToDouble_SetDouble( IsSign(), e + 1023, -1);
- return 0;
-private:
- // 32bit platforms
- double ToDouble_SetDouble(bool is_sign, uint e, sint move, bool infinity = false, bool nan = false) const
- union
- double d;
- } temp;
- temp.u[0] = temp.u[1] = 0;
- if( is_sign )
- temp.u[1] |= 0x80000000u;
- temp.u[1] |= (e << 20) & 0x7FF00000u;
- if( nan )
- temp.u[0] |= 1;
- return temp.d;
- if( infinity )
- return temp.d;
- UInt<2> m;
- m.table[1] = mantissa.table[man-1];
- m.table[0] = ( man > 1 ) ? mantissa.table[sint(man-2)] : 0;
- m.Rcr( 12 + move );
- m.table[1] &= 0xFFFFFu; // cutting the 20 bit (when 'move' was -1)
- temp.u[1] |= m.table[1];
- temp.u[0] |= m.table[0];
- return temp.d;
-#else
- union
- double d;
- uint u; // 64bit word
- } temp;
- temp.u = 0;
- if( is_sign )
- temp.u |= 0x8000000000000000ul;
- temp.u |= (e << 52) & 0x7FF0000000000000ul;
- if( nan )
- temp.u |= 1;
- return temp.d;
- if( infinity )
- return temp.d;
- uint m = mantissa.table[man-1];
- m >>= ( 12 + move );
- m &= 0xFFFFFFFFFFFFFul; // cutting the 20 bit (when 'move' was -1)
- temp.u |= m;
- return temp.d;
-#endif
-public:
- an operator= for converting 'sint' to this class
- Big<exp, man> & operator=(sint value)
- FromInt(value);
- return *this;
- an operator= for converting 'uint' to this class
- Big<exp, man> & operator=(uint value)
- FromUInt(value);
- return *this;
- an operator= for converting 'float' to this class
- Big<exp, man> & operator=(float value)
- FromFloat(value);
- return *this;
- an operator= for converting 'double' to this class
- Big<exp, man> & operator=(double value)
- FromDouble(value);
- return *this;
- a constructor for converting 'sint' to this class
- Big(sint value)
- FromInt(value);
- a constructor for converting 'uint' to this class
- Big(uint value)
- FromUInt(value);
- a constructor for converting 'double' to this class
- Big(double value)
- a constructor for converting 'float' to this class
- Big(float value)
- FromFloat(value);
- this method converts 'this' into 'result' (64 bit unsigned integer)
- uint ToUInt(ulint & result) const
- UInt<2> temp; // 64 bits container
- uint c = ToUInt(temp);
- temp.ToUInt(result);
- return c;
- uint ToInt(ulint & result) const
- uint ToInt(slint & result) const
- Int<2> temp; // 64 bits container
- uint c = ToInt(temp);
- temp.ToInt(result);
- return c;
- a method for converting 'ulint' (64bit unsigned integer) to this class
- uint FromUInt(ulint value)
- if( value == 0 )
- SetZero();
- return 0;
- info = 0;
- if( man == 1 )
- sint bit = mantissa.FindLeadingBitInWord(uint(value >> TTMATH_BITS_PER_UINT));
- if( bit != -1 )
- // the highest word from value is different from zero
- bit += 1;
- value >>= bit;
- exponent = bit;
- else
- mantissa.table[0] = uint(value);
- else
- #ifdef _MSC_VER
- //warning C4307: '*' : integral constant overflow
- #endif
- // man >= 2
- mantissa.table[man-1] = uint(value >> TTMATH_BITS_PER_UINT);
- mantissa.table[man-2] = uint(value);
- #ifdef _MSC_VER
- #endif
- exponent = -sint(man-2) * sint(TTMATH_BITS_PER_UINT);
- // there shouldn't be a carry because 'value' has the 'ulint' type
- // (we have sufficient exponent)
- Standardizing();
- return 0;
- uint FromInt(ulint value)
- a method for converting 'slint' (64bit signed integer) to this class
- uint FromInt(slint value)
- if( value < 0 )
- value = -value;
- is_sign = true;
- FromUInt(ulint(value));
- if( is_sign )
- SetSign();
- return 0;
- a constructor for converting 'ulint' (64bit unsigned integer) to this class
- Big(ulint value)
- FromUInt(value);
- an operator for converting 'ulint' (64bit unsigned integer) to this class
- Big<exp, man> & operator=(ulint value)
- FromUInt(value);
- return *this;
- a constructor for converting 'slint' (64bit signed integer) to this class
- Big(slint value)
- FromInt(value);
- an operator for converting 'slint' (64bit signed integer) to this class
- Big<exp, man> & operator=(slint value)
- FromInt(value);
- return *this;
-#endif
-#ifdef TTMATH_PLATFORM64
- this method converts 'this' into 'result' (32 bit unsigned integer)
- ***this method is created only on a 64bit platform***
- uint ToUInt(unsigned int & result) const
- uint result_uint;
- uint c = ToUInt(result_uint);
- result = (unsigned int)result_uint;
- if( c || result_uint != uint(result) )
- return 1;
- return 0;
- uint ToInt(unsigned int & result) const
- this method converts 'this' into 'result' (32 bit signed integer)
- uint ToInt(signed int & result) const
- sint result_sint;
- uint c = ToInt(result_sint);
- result = (signed int)result_sint;
- if( c || result_sint != sint(result) )
- return 1;
- return 0;
- this method converts 32 bit unsigned int to this class
- uint FromUInt(unsigned int value)
- return FromUInt(uint(value));
- uint FromInt(unsigned int value)
- this method converts 32 bit signed int to this class
- uint FromInt(signed int value)
- return FromInt(sint(value));
- an operator= for converting 32 bit unsigned int to this class
- ***this operator is created only on a 64bit platform***
- Big<exp, man> & operator=(unsigned int value)
- FromUInt(value);
- return *this;
- a constructor for converting 32 bit unsigned int to this class
- ***this constructor is created only on a 64bit platform***
- Big(unsigned int value)
- FromUInt(value);
- an operator for converting 32 bit signed int to this class
- Big<exp, man> & operator=(signed int value)
- FromInt(value);
- return *this;
- a constructor for converting 32 bit signed int to this class
- Big(signed int value)
- FromInt(value);
-#endif
-private:
- an auxiliary method for converting from UInt and Int
- we assume that there'll never be a carry here
- (we have an exponent and the value in Big can be bigger than
- that one from the UInt)
- uint FromUIntOrInt(const UInt<int_size> & value, sint compensation)
- uint minimum_size = (int_size < man)? int_size : man;
- exponent = (sint(int_size)-sint(man)) * sint(TTMATH_BITS_PER_UINT) - compensation;
- // copying the highest words
- uint i;
- for(i=1 ; i<=minimum_size ; ++i)
- mantissa.table[man-i] = value.table[int_size-i];
- // setting the rest of mantissa.table into zero (if some has left)
- for( ; i<=man ; ++i)
- mantissa.table[man-i] = 0;
- // the highest bit is either one or zero (when the whole mantissa is zero)
- // we can only call CorrectZero()
- CorrectZero();
- return 0;
-public:
- a method for converting from 'UInt<int_size>' to this class
- uint FromUInt(UInt<int_size> value)
- info = 0;
- sint compensation = (sint)value.CompensationToLeft();
- return FromUIntOrInt(value, compensation);
- uint FromInt(const UInt<int_size> & value)
- a method for converting from 'Int<int_size>' to this class
- uint FromInt(Int<int_size> value)
- info = 0;
- if( value.IsSign() )
- value.ChangeSign();
- is_sign = true;
- FromUIntOrInt(value, compensation);
- if( is_sign )
- SetSign();
- return 0;
- an operator= for converting from 'Int<int_size>' to this class
- Big<exp,man> & operator=(const Int<int_size> & value)
- FromInt(value);
- return *this;
- a constructor for converting from 'Int<int_size>' to this class
- Big(const Int<int_size> & value)
- FromInt(value);
- an operator= for converting from 'UInt<int_size>' to this class
- Big<exp,man> & operator=(const UInt<int_size> & value)
- FromUInt(value);
- return *this;
- a constructor for converting from 'UInt<int_size>' to this class
- Big(const UInt<int_size> & value)
- FromUInt(value);
- an operator= for converting from 'Big<another_exp, another_man>' to this class
- Big<exp,man> & operator=(const Big<another_exp, another_man> & value)
- FromBig(value);
- return *this;
- a constructor for converting from 'Big<another_exp, another_man>' to this class
- Big(const Big<another_exp, another_man> & value)
- FromBig(value);
- a default constructor
- by default we don't set any of the members to zero
- only NaN flag is set
- if you want the mantissa and exponent to be set to zero
- define TTMATH_BIG_DEFAULT_CLEAR macro
- (useful for debug purposes)
- Big()
- #ifdef TTMATH_BIG_DEFAULT_CLEAR
- SetZeroNan();
- #else
- info = TTMATH_BIG_NAN;
- // we're directly setting 'info' (instead of calling SetNan())
- // in order to get rid of a warning saying that 'info' is uninitialized
- #endif
- a destructor
- ~Big()
- the default assignment operator
- Big<exp,man> & operator=(const Big<exp,man> & value)
- info = value.info;
- exponent = value.exponent;
- mantissa = value.mantissa;
- return *this;
- a constructor for copying from another object of this class
- Big(const Big<exp,man> & value)
- operator=(value);
- a method for converting into a string
- struct Conv is defined in ttmathtypes.h, look there for more information about parameters
- return value:
- - 0 - ok and 'result' will be an object of type std::string (or std::wstring) which holds the value
- - 1 - if there is a carry (it shoudn't be in a normal situation - if it is that means there
- is somewhere an error in the library)
- uint ToString( std::string & result,
- uint base = 10,
- bool scient = false,
- sint scient_from = 15,
- sint round = -1,
- bool trim_zeroes = true,
- char comma = '.' ) const
- Conv conv;
- conv.base = base;
- conv.scient = scient;
- conv.scient_from = scient_from;
- conv.round = round;
- conv.trim_zeroes = trim_zeroes;
- conv.comma = static_cast<uint>(comma);
- return ToStringBase<std::string, char>(result, conv);
- uint ToString(std::string & result, const Conv & conv) const
- std::string ToString(const Conv & conv) const
- std::string result;
- ToStringBase<std::string, char>(result, conv);
- return result;
- std::string ToString(uint base = 10) const
- Conv conv;
- conv.base = base;
- return ToString(conv);
-#ifndef TTMATH_DONT_USE_WCHAR
- uint ToString( std::wstring & result,
- uint base = 10,
- sint round = -1,
- wchar_t comma = '.' ) const
- Conv conv;
- conv.base = base;
- return ToStringBase<std::wstring, wchar_t>(result, conv);
- uint ToString(std::wstring & result, const Conv & conv) const
- std::wstring ToWString(const Conv & conv) const
- std::wstring result;
- ToStringBase<std::wstring, wchar_t>(result, conv);
- return result;
- std::wstring ToWString(uint base = 10) const
- Conv conv;
- conv.base = base;
- return ToWString(conv);
-#endif
-private:
- an auxiliary method for converting into the string
- template<class string_type, class char_type>
- uint ToStringBase(string_type & result, const Conv & conv) const
- static char error_overflow_msg[] = "overflow";
- static char error_nan_msg[] = "NaN";
- result.erase();
- if( IsNan() )
- Misc::AssignString(result, error_nan_msg);
- return 0;
- if( conv.base<2 || conv.base>16 )
- Misc::AssignString(result, error_overflow_msg);
- return 1;
- if( IsZero() )
- result = '0';
- return 0;
- since 'base' is greater or equal 2 that 'new_exp' of type 'Int<exp>' should
- hold the new value of exponent but we're using 'Int<exp+1>' because
- if the value for example would be 'max()' then we couldn't show it
- max() -> 11111111 * 2 ^ 11111111111 (bin)(the mantissa and exponent have all bits set)
- if we were using 'Int<exp>' we couldn't show it in this format:
- 1,1111111 * 2 ^ 11111111111 (bin)
- because we have to add something to the mantissa and because
- mantissa is full we can't do it and it'll be a carry
- (look at ToString_SetCommaAndExponent(...))
- when the base would be greater than two (for example 10)
- we could use 'Int<exp>' here
- Int<exp+1> new_exp;
- if( ToString_CreateNewMantissaAndExponent<string_type, char_type>(result, conv, new_exp) )
- return 1;
- if( ToString_SetCommaAndExponent<string_type, char_type>(result, conv, new_exp) )
- return 1;
- if( IsSign() )
- result.insert(result.begin(), '-');
- // converted successfully
- return 0;
- in the method 'ToString_CreateNewMantissaAndExponent()' we're using
- type 'Big<exp+1,man>' and we should have the ability to use some
- necessary methods from that class (methods which are private here)
- friend class Big<exp-1,man>;
- input:
- base - the base in range <2,16>
- output:
- return values:
- 0 - ok
- 1 - if there was a carry
- new_man - the new mantissa for 'base'
- new_exp - the new exponent for 'base'
- mathematic part:
- the value is stored as:
- value = mantissa * 2^exponent
- we want to show 'value' as:
- value = new_man * base^new_exp
- then 'new_man' we'll print using the standard method from UInt<> type for printing
- and 'new_exp' is the offset of the comma operator in a system of a base 'base'
- value = mantissa * 2^exponent * (base^new_exp / base^new_exp)
- value = mantissa * (2^exponent / base^new_exp) * base^new_exp
- look at the part (2^exponent / base^new_exp), there'll be good if we take
- a 'new_exp' equal that value when the (2^exponent / base^new_exp) will be equal one
- on account of the 'base' is not as power of 2 (can be from 2 to 16),
- this formula will not be true for integer 'new_exp' then in our case we take
- 'base^new_exp' _greater_ than '2^exponent'
- if 'base^new_exp' were smaller than '2^exponent' the new mantissa could be
- greater than the max value of the container UInt<man>
- let M = mantissa * (2^exponent / base^new_exp) then
- value = M * base^new_exp
- in our calculation we treat M as floating value showing it as:
- M = mm * 2^ee where ee will be <= 0
- next we'll move all bits of mm into the right when ee is equal zero
- abs(ee) must not be too big that only few bits from mm we can leave
- then we'll have:
- M = mmm * 2^0
- 'mmm' is the new_man which we're looking for
- new_exp we calculate in this way:
- 2^exponent <= base^new_exp
- new_exp >= log base (2^exponent) <- logarithm with the base 'base' from (2^exponent)
- but we need new_exp as integer then we test:
- if new_exp is greater than zero and with fraction we add one to new_exp
- new_exp = new_exp + 1 (if new_exp>0 and with fraction)
- and at the end we take the integer part:
- new_exp = int(new_exp)
- uint ToString_CreateNewMantissaAndExponent( string_type & new_man, const Conv & conv,
- Int<exp+1> & new_exp) const
- uint c = 0;
- return 1;
- // special method for base equal 2
- if( conv.base == 2 )
- return ToString_CreateNewMantissaAndExponent_Base2(new_man, new_exp);
- // special method for base equal 4
- if( conv.base == 4 )
- return ToString_CreateNewMantissaAndExponent_BasePow2(new_man, new_exp, 2);
- // special method for base equal 8
- if( conv.base == 8 )
- return ToString_CreateNewMantissaAndExponent_BasePow2(new_man, new_exp, 3);
- // special method for base equal 16
- if( conv.base == 16 )
- return ToString_CreateNewMantissaAndExponent_BasePow2(new_man, new_exp, 4);
- // this = mantissa * 2^exponent
- // temp = +1 * 2^exponent
- // we're using a bigger type than 'big<exp,man>' (look below)
- Big<exp+1,man> temp;
- temp.info = 0;
- temp.exponent = exponent;
- temp.mantissa.SetOne();
- c += temp.Standardizing();
- // new_exp_ = log base (2^exponent)
- // if new_exp_ is positive and with fraction then we add one
- Big<exp+1,man> new_exp_;
- c += new_exp_.ToString_Log(temp, conv.base); // this logarithm isn't very complicated
- // rounding up to the nearest integer
- if( !new_exp_.IsInteger() )
- if( !new_exp_.IsSign() )
- c += new_exp_.AddOne(); // new_exp_ > 0 and with fraction
- new_exp_.SkipFraction();
- if( ToString_CreateNewMantissaTryExponent<string_type, char_type>(new_man, conv, new_exp_, new_exp) )
- // in very rare cases there can be an overflow from ToString_CreateNewMantissaTryExponent
- // it means that new_exp_ was too small (the problem comes from floating point numbers precision)
- // so we increse new_exp_ and try again
- new_exp_.AddOne();
- c += ToString_CreateNewMantissaTryExponent<string_type, char_type>(new_man, conv, new_exp_, new_exp);
- return (c==0)? 0 : 1;
- trying to calculate new_man for given exponent (new_exp_)
- if there is a carry it can mean that new_exp_ is too small
- uint ToString_CreateNewMantissaTryExponent( string_type & new_man, const Conv & conv,
- const Big<exp+1,man> & new_exp_, Int<exp+1> & new_exp) const
- uint c = 0;
- // because 'base^new_exp' is >= '2^exponent' then
- // because base is >= 2 then we've got:
- // 'new_exp_' must be smaller or equal 'new_exp'
- // and we can pass it into the Int<exp> type
- // (in fact we're using a greater type then it'll be ok)
- c += new_exp_.ToInt(new_exp);
- // base_ = base
- Big<exp+1,man> base_(conv.base);
- // base_ = base_ ^ new_exp_
- c += base_.Pow( new_exp_ ); // use new_exp_ so Pow(Big<> &) version will be used
- // if we hadn't used a bigger type than 'Big<exp,man>' then the result
- // of this formula 'Pow(...)' would have been with an overflow
- // temp = mantissa * 2^exponent / base_^new_exp_
- temp.info = 0;
- temp.mantissa = mantissa;
- c += temp.Div(base_);
- // moving all bits of the mantissa into the right
- // (how many times to move depend on the exponent)
- c += temp.ToString_MoveMantissaIntoRight();
- // because we took 'new_exp' as small as it was
- // possible ([log base (2^exponent)] + 1) that after the division
- // (temp.Div( base_ )) the value of exponent should be equal zero or
- // minimum smaller than zero then we've got the mantissa which has
- // maximum valid bits
- temp.mantissa.ToString(new_man, conv.base);
- if( IsInteger() )
- // making sure the new mantissa will be without fraction (integer)
- ToString_CheckMantissaInteger<string_type, char_type>(new_man, new_exp);
- else
- if( conv.base_round )
- c += ToString_BaseRound<string_type, char_type>(new_man, conv, new_exp);
- this method calculates the logarithm
- it is used by ToString_CreateNewMantissaAndExponent() method
- it's not too complicated
- because x=+1*2^exponent (mantissa is one) then during the calculation
- the Ln(x) will not be making the long formula from LnSurrounding1()
- and only we have to calculate 'Ln(base)' but it'll be calculated
- only once, the next time we will get it from the 'history'
- x is greater than 0
- base is in <2,16> range
- uint ToString_Log(const Big<exp,man> & x, uint base)
- TTMATH_ASSERT( base>=2 && base<=16 )
- Big<exp,man> temp;
- temp.SetOne();
- if( x == temp )
- // log(1) is 0
- SetZero();
- return 0;
- // there can be only a carry
- // because the 'x' is in '1+2*exponent' form then
- // the long formula from LnSurrounding1() will not be calculated
- // (LnSurrounding1() will return one immediately)
- uint c = Ln(x);
- if( base==10 && man<=TTMATH_BUILTIN_VARIABLES_SIZE )
- // for the base equal 10 we're using SetLn10() instead of calculating it
- // (only if we have the constant sufficient big)
- temp.SetLn10();
- else
- c += ToString_LogBase(base, temp);
- c += Div( temp );
-#ifndef TTMATH_MULTITHREADS
- this method calculates the logarithm of 'base'
- it's used in single thread environment
- uint ToString_LogBase(uint base, Big<exp,man> & result)
- // this guardians are initialized before the program runs (static POD types)
- static int guardians[15] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
- static Big<exp,man> log_history[15];
- uint index = base - 2;
- uint c = 0;
- if( guardians[index] == 0 )
- Big<exp,man> base_(base);
- c += log_history[index].Ln(base_);
- guardians[index] = 1;
- result = log_history[index];
-#else
- it's used in multi-thread environment
- volatile static sig_atomic_t guardians[15] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
- static Big<exp,man> * plog_history;
- uint c = 0;
- // double-checked locking
- ThreadLock thread_lock;
- // locking
- if( thread_lock.Lock() )
- plog_history = log_history;
- else
- // there was a problem with locking, we store the result directly in 'result' object
- c += result.Ln(base_);
- // automatically unlocking
- result = plog_history[index];
-#endif
- an auxiliary method for converting into the string (private)
- this method moving all bits from mantissa into the right side
- the exponent tell us how many times moving (the exponent is <=0)
- uint ToString_MoveMantissaIntoRight()
- if( exponent.IsZero() )
- return 0;
- // exponent can't be greater than zero
- // because we would cat the highest bits of the mantissa
- if( !exponent.IsSign() )
- return 1;
- if( exponent <= -sint(man*TTMATH_BITS_PER_UINT) )
- // if 'exponent' is <= than '-sint(man*TTMATH_BITS_PER_UINT)'
- // it means that we must cut the whole mantissa
- // (there'll not be any of the valid bits)
- return 1;
- // e will be from (-man*TTMATH_BITS_PER_UINT, 0>
- sint e = -( exponent.ToInt() );
- mantissa.Rcr(e,0);
- return 0;
- a special method similar to the 'ToString_CreateNewMantissaAndExponent'
- when the 'base' is equal 2
- we use it because if base is equal 2 we don't have to make those
- complicated calculations and the output is directly from the source
- (there will not be any small distortions)
- template<class string_type>
- uint ToString_CreateNewMantissaAndExponent_Base2( string_type & new_man,
- Int<exp+1> & new_exp ) const
- for( sint i=man-1 ; i>=0 ; --i )
- uint value = mantissa.table[i];
- for( uint bit=0 ; bit<TTMATH_BITS_PER_UINT ; ++bit )
- if( (value & TTMATH_UINT_HIGHEST_BIT) != 0 )
- new_man += '1';
- else
- new_man += '0';
- value <<= 1;
- new_exp = exponent;
- return 0;
- a special method used to calculate the new mantissa and exponent
- when the 'base' is equal 4, 8 or 16
- - when base is 4 then bits is 2
- - when base is 8 then bits is 3
- - when base is 16 then bits is 4
- (and the algorithm can be used with a base greater than 16)
- uint ToString_CreateNewMantissaAndExponent_BasePow2( string_type & new_man,
- Int<exp+1> & new_exp,
- uint bits) const
- sint move; // how many times move the mantissa
- UInt<man+1> man_temp(mantissa); // man+1 for moving
- new_exp.DivInt((sint)bits, move);
- if( move != 0 )
- // we're moving the man_temp to left-hand side
- if( move < 0 )
- move = sint(bits) + move;
- new_exp.SubOne(); // when move is < than 0 then new_exp is < 0 too
- man_temp.Rcl(move);
- if( bits == 3 )
- // base 8
- // now 'move' is greater than or equal 0
- uint len = man*TTMATH_BITS_PER_UINT + move;
- return ToString_CreateNewMantissaAndExponent_Base8(new_man, man_temp, len, bits);
- else
- // base 4 or 16
- return ToString_CreateNewMantissaAndExponent_Base4or16(new_man, man_temp, bits);
- when the 'base' is equal 8
- bits is always 3
- we can use this algorithm when the base is 4 or 16 too
- but we have a faster method ToString_CreateNewMantissaAndExponent_Base4or16()
- uint ToString_CreateNewMantissaAndExponent_Base8( string_type & new_man,
- UInt<man+1> & man_temp,
- uint len,
- uint bits) const
- uint shift = TTMATH_BITS_PER_UINT - bits;
- uint mask = TTMATH_UINT_MAX_VALUE >> shift;
- uint i;
- for( i=0 ; i<len ; i+=bits )
- uint digit = man_temp.table[0] & mask;
- new_man.insert(new_man.begin(), static_cast<char>(Misc::DigitToChar(digit)));
- man_temp.Rcr(bits);
- TTMATH_ASSERT( man_temp.IsZero() )
- return 0;
- when the 'base' is equal 4 or 16
- when the base is equal 4 or 16 the bits is 2 or 4
- and because TTMATH_BITS_PER_UINT (32 or 64) is divisible by 2 (or 4)
- then we can get digits from the end of our mantissa
- uint ToString_CreateNewMantissaAndExponent_Base4or16( string_type & new_man,
- uint bits) const
- TTMATH_ASSERT( TTMATH_BITS_PER_UINT % 2 == 0 )
- TTMATH_ASSERT( TTMATH_BITS_PER_UINT % 4 == 0 )
- uint mask = TTMATH_UINT_MAX_VALUE << shift;
- uint digit;
- // table[man] - last word - is different from zero if we moved man_temp
- digit = man_temp.table[man];
- if( digit != 0 )
- new_man += static_cast<char>(Misc::DigitToChar(digit));
- for( int i=man-1 ; i>=0 ; --i )
- uint shift_local = shift;
- uint mask_local = mask;
- while( mask_local != 0 )
- digit = man_temp.table[i] & mask_local;
- if( shift_local != 0 )
- digit = digit >> shift_local;
- mask_local = mask_local >> bits;
- shift_local = shift_local - bits;
- return 0;
- bool ToString_RoundMantissaWouldBeInteger(string_type & new_man, const Conv & conv, Int<exp+1> & new_exp) const
- // if new_exp is greater or equal to zero then we have an integer value,
- // if new_exp is equal -1 then we have only one digit after the comma
- // and after rounding it would be an integer value
- if( !new_exp.IsSign() || new_exp == -1 )
- return true;
- if( new_man.size() >= TTMATH_UINT_HIGHEST_BIT || new_man.size() < 2 )
- return true; // oops, the mantissa is too large for calculating (or too small) - we are not doing the base rounding
- uint i = 0;
- char_type digit;
- if( new_exp >= -sint(new_man.size()) )
- uint new_exp_abs = -new_exp.ToInt();
- i = new_man.size() - new_exp_abs; // start from the first digit after the comma operator
- if( Misc::CharToDigit(new_man[new_man.size()-1]) >= conv.base/2 )
- if( new_exp < -sint(new_man.size()) )
- // there are some zeroes after the comma operator
- // (between the comma and the first digit from the mantissa)
- // and the result value will never be an integer
- return false;
- digit = static_cast<char_type>( Misc::DigitToChar(conv.base-1) );
- else
- digit = '0';
- for( ; i < new_man.size()-1 ; ++i)
- if( new_man[i] != digit )
- return false; // it will not be an integer
- return true; // it will be integer after rounding
- (when this is integer)
- after floating point calculating the new mantissa can consist of some fraction
- so if our value is integer we should check the new mantissa
- (after the decimal point there should be only zeroes)
- often this is a last digit different from zero
- ToString_BaseRound would not get rid of it because the method make a test against
- an integer value (ToString_RoundMantissaWouldBeInteger) and returns immediately
- void ToString_CheckMantissaInteger(string_type & new_man, const Int<exp+1> & new_exp) const
- if( !new_exp.IsSign() )
- return; // return if new_exp >= 0
- uint i = 0;
- uint man_size = new_man.size();
- if( man_size >= TTMATH_UINT_HIGHEST_BIT )
- return; // ops, the mantissa is too long
- sint sman_size = -sint(man_size);
- if( new_exp >= sman_size )
- sint e = new_exp.ToInt();
- e = -e;
- // now e means how many last digits from the mantissa should be equal zero
- i = man_size - uint(e);
- for( ; i<man_size ; ++i)
- new_man[i] = '0';
- this method is used for base!=2, base!=4, base!=8 and base!=16
- we do the rounding when the value has fraction (is not an integer)
- uint ToString_BaseRound(string_type & new_man, const Conv & conv, Int<exp+1> & new_exp) const
- // we must have minimum two characters
- if( new_man.size() < 2 )
- return 0;
- // assert that there will not be an integer after rounding
- if( ToString_RoundMantissaWouldBeInteger<string_type, char_type>(new_man, conv, new_exp) )
- return 0;
- typename string_type::size_type i = new_man.length() - 1;
- // we're erasing the last character
- uint digit = Misc::CharToDigit( new_man[i] );
- new_man.erase(i, 1);
- uint c = new_exp.AddOne();
- // if the last character is greater or equal 'base/2'
- // we are adding one into the new mantissa
- if( digit >= conv.base / 2 )
- ToString_RoundMantissa_AddOneIntoMantissa<string_type, char_type>(new_man, conv);
- return c;
- this method addes one into the new mantissa
- void ToString_RoundMantissa_AddOneIntoMantissa(string_type & new_man, const Conv & conv) const
- if( new_man.empty() )
- return;
- sint i = sint( new_man.length() ) - 1;
- bool was_carry = true;
- for( ; i>=0 && was_carry ; --i )
- // we can have the comma as well because
- // we're using this method later in ToString_CorrectDigitsAfterComma_Round()
- // (we're only ignoring it)
- if( new_man[i] == static_cast<char_type>(conv.comma) )
- continue;
- // we're adding one
- uint digit = Misc::CharToDigit( new_man[i] ) + 1;
- if( digit == conv.base )
- digit = 0;
- else
- was_carry = false;
- new_man[i] = static_cast<char_type>( Misc::DigitToChar(digit) );
- if( i<0 && was_carry )
- new_man.insert( new_man.begin() , '1' );
- this method sets the comma operator and/or puts the exponent
- into the string
- uint ToString_SetCommaAndExponent(string_type & new_man, const Conv & conv, Int<exp+1> & new_exp) const
- uint carry = 0;
- return carry;
- Int<exp+1> scientific_exp( new_exp );
- // 'new_exp' depends on the 'new_man' which is stored like this e.g:
- // 32342343234 (the comma is at the end)
- // we'd like to show it in this way:
- // 3.2342343234 (the 'scientific_exp' is connected with this example)
- sint offset = sint( new_man.length() ) - 1;
- carry += scientific_exp.Add( offset );
- // there shouldn't have been a carry because we're using
- // a greater type -- 'Int<exp+1>' instead of 'Int<exp>'
- bool print_scientific = conv.scient;
- if( !print_scientific )
- if( scientific_exp > conv.scient_from || scientific_exp < -sint(conv.scient_from) )
- print_scientific = true;
- ToString_SetCommaAndExponent_Normal<string_type, char_type>(new_man, conv, new_exp);
- else
- // we're passing the 'scientific_exp' instead of 'new_exp' here
- ToString_SetCommaAndExponent_Scientific<string_type, char_type>(new_man, conv, scientific_exp);
- return (carry==0)? 0 : 1;
- void ToString_SetCommaAndExponent_Normal(string_type & new_man, const Conv & conv, Int<exp+1> & new_exp ) const
- if( !new_exp.IsSign() ) // it means: if( new_exp >= 0 )
- ToString_SetCommaAndExponent_Normal_AddingZero<string_type, char_type>(new_man, new_exp);
- else
- ToString_SetCommaAndExponent_Normal_SetCommaInside<string_type, char_type>(new_man, conv, new_exp);
- ToString_Group_man<string_type, char_type>(new_man, conv);
- void ToString_SetCommaAndExponent_Normal_AddingZero(string_type & new_man,
- // we're adding zero characters at the end
- // 'i' will be smaller than 'when_scientific' (or equal)
- uint i = new_exp.ToInt();
- if( new_man.length() + i > new_man.capacity() )
- // about 6 characters more (we'll need it for the comma or something)
- new_man.reserve( new_man.length() + i + 6 );
- for( ; i>0 ; --i)
- new_man += '0';
- void ToString_SetCommaAndExponent_Normal_SetCommaInside(
- string_type & new_man,
- const Conv & conv,
- // new_exp is < 0
- sint new_man_len = sint(new_man.length()); // 'new_man_len' with a sign
- sint e = -( new_exp.ToInt() ); // 'e' will be positive
- if( new_exp > -new_man_len )
- // we're setting the comma within the mantissa
- sint index = new_man_len - e;
- new_man.insert( new_man.begin() + index, static_cast<char_type>(conv.comma));
- else
- // we're adding zero characters before the mantissa
- uint how_many = e - new_man_len;
- string_type man_temp(how_many+1, '0');
- man_temp.insert( man_temp.begin()+1, static_cast<char_type>(conv.comma));
- new_man.insert(0, man_temp);
- ToString_CorrectDigitsAfterComma<string_type, char_type>(new_man, conv);
- void ToString_SetCommaAndExponent_Scientific( string_type & new_man,
- Int<exp+1> & scientific_exp ) const
- return;
- if( new_man.size() > 1 )
- new_man.insert( new_man.begin()+1, static_cast<char_type>(conv.comma) );
- if( conv.base == 10 )
- new_man += 'e';
- if( !scientific_exp.IsSign() )
- new_man += '+';
- else
- // the 10 here is meant as the base 'base'
- // (no matter which 'base' we're using there'll always be 10 here)
- Misc::AddString(new_man, "*10^");
- string_type temp_exp;
- scientific_exp.ToString( temp_exp, conv.base );
- new_man += temp_exp;
- void ToString_Group_man(string_type & new_man, const Conv & conv) const
- typedef typename string_type::size_type StrSize;
- if( conv.group == 0 )
- return;
- // first we're looking for the comma operator
- StrSize index = new_man.find(static_cast<char_type>(conv.comma), 0);
- if( index == string_type::npos )
- index = new_man.size();
- ToString_Group_man_before_comma<string_type, char_type>(new_man, conv, index);
- ToString_Group_man_after_comma<string_type, char_type>(new_man, conv, index+1);
- void ToString_Group_man_before_comma( string_type & new_man, const Conv & conv,
- typename string_type::size_type & index) const
- uint group = 0;
- StrSize i = index;
- uint group_digits = conv.group_digits;
- if( group_digits < 1 )
- group_digits = 1;
- // adding group characters before the comma operator
- // i>0 because on the first position we don't put any additional grouping characters
- for( ; i>0 ; --i, ++group)
- if( group >= group_digits )
- group = 0;
- new_man.insert(i, 1, static_cast<char_type>(conv.group));
- ++index;
- void ToString_Group_man_after_comma(string_type & new_man, const Conv & conv,
- typename string_type::size_type index) const
- uint group = 0;
- group_digits = 1;
- for( ; index<new_man.size() ; ++index, ++group)
- group = 0;
- new_man.insert(index, 1, static_cast<char_type>(conv.group));
- ++index;
- void ToString_CorrectDigitsAfterComma( string_type & new_man,
- const Conv & conv ) const
- if( conv.round >= 0 )
- ToString_CorrectDigitsAfterComma_Round<string_type, char_type>(new_man, conv);
- if( conv.trim_zeroes )
- ToString_CorrectDigitsAfterComma_CutOffZeroCharacters<string_type, char_type>(new_man, conv);
- void ToString_CorrectDigitsAfterComma_CutOffZeroCharacters(
- const Conv & conv) const
- // minimum two characters
- if( new_man.length() < 2 )
- return;
- // we're looking for the index of the last character which is not zero
- uint i = uint( new_man.length() ) - 1;
- for( ; i>0 && new_man[i]=='0' ; --i );
- // if there is another character than zero at the end
- // we're finishing
- if( i == new_man.length() - 1 )
- return;
- // we must have a comma
- // (the comma can be removed by ToString_CorrectDigitsAfterComma_Round
- // which is called before)
- if( new_man.find_last_of(static_cast<char_type>(conv.comma), i) == string_type::npos )
- return;
- // if directly before the first zero is the comma operator
- // we're cutting it as well
- if( i>0 && new_man[i]==static_cast<char_type>(conv.comma) )
- --i;
- new_man.erase(i+1, new_man.length()-i-1);
- void ToString_CorrectDigitsAfterComma_Round(
- // nothing was found (actually there can't be this situation)
- return;
- // we're calculating how many digits there are at the end (after the comma)
- // 'after_comma' will be greater than zero because at the end
- // we have at least one digit
- StrSize after_comma = new_man.length() - index - 1;
- // if 'max_digit_after_comma' is greater than 'after_comma' (or equal)
- // we don't have anything for cutting
- if( static_cast<StrSize>(conv.round) >= after_comma )
- return;
- uint last_digit = Misc::CharToDigit( new_man[ index + conv.round + 1 ], conv.base );
- // we're cutting the rest of the string
- new_man.erase(index + conv.round + 1, after_comma - conv.round);
- if( conv.round == 0 )
- // we're cutting the comma operator as well
- // (it's not needed now because we've cut the whole rest after the comma)
- new_man.erase(index, 1);
- if( last_digit >= conv.base / 2 )
- // we must round here
-public:
- a method for converting a string into its value
- it returns 1 if the value is too big -- we cannot pass it into the range
- of our class Big<exp,man> (or if the base is incorrect)
- that means only digits before the comma operator can make this value too big,
- all digits after the comma we can ignore
- 'source' - pointer to the string for parsing
- if 'after_source' is set that when this method finishes
- it sets the pointer to the new first character after parsed value
- 'value_read' - if the pointer is provided that means the value_read will be true
- only when a value has been actually read, there can be situation where only such
- a string '-' or '+' will be parsed -- 'after_source' will be different from 'source' but
- no value has been read (there are no digits)
- on other words if 'value_read' is true -- there is at least one digit in the string
- uint FromString(const char * source, uint base = 10, const char ** after_source = 0, bool * value_read = 0)
- Conv conv;
- conv.base = base;
- return FromStringBase(source, conv, after_source, value_read);
- uint FromString(const char * source, const Conv & conv, const char ** after_source = 0, bool * value_read = 0)
- uint FromString(const std::string & string, uint base = 10, const char ** after_source = 0, bool * value_read = 0)
- return FromString(string.c_str(), base, after_source, value_read);
- uint FromString(const std::string & string, const Conv & conv, const char ** after_source = 0, bool * value_read = 0)
- return FromString(string.c_str(), conv, after_source, value_read);
- uint FromString(const wchar_t * source, uint base = 10, const wchar_t ** after_source = 0, bool * value_read = 0)
- Conv conv;
- conv.base = base;
- uint FromString(const wchar_t * source, const Conv & conv, const wchar_t ** after_source = 0, bool * value_read = 0)
- uint FromString(const std::wstring & string, uint base = 10, const wchar_t ** after_source = 0, bool * value_read = 0)
- uint FromString(const std::wstring & string, const Conv & conv, const wchar_t ** after_source = 0, bool * value_read = 0)
-#endif
-private:
- an auxiliary method for converting from a string
- template<class char_type>
- uint FromStringBase(const char_type * source, const Conv & conv, const char_type ** after_source = 0, bool * value_read = 0)
- bool is_sign;
- bool value_read_temp = false;
- SetNan();
- if( after_source )
- *after_source = source;
- if( value_read )
- *value_read = value_read_temp;
- return 1;
- SetZero();
- FromString_TestSign( source, is_sign );
- uint c = FromString_ReadPartBeforeComma( source, conv, value_read_temp );
- if( FromString_TestCommaOperator(source, conv) )
- c += FromString_ReadPartAfterComma( source, conv, value_read_temp );
- if( value_read_temp && conv.base == 10 )
- c += FromString_ReadScientificIfExists( source );
- if( is_sign && !IsZero() )
- ChangeSign();
- if( value_read )
- return CheckCarry(c);
- we're testing whether the value is with the sign
- (this method is used from 'FromString_ReadPartScientific' too)
- void FromString_TestSign( const char_type * & source, bool & is_sign )
- Misc::SkipWhiteCharacters(source);
- is_sign = false;
- if( *source == '-' )
- is_sign = true;
- ++source;
- else
- if( *source == '+' )
- ++source;
- we're testing whether there's a comma operator
- bool FromString_TestCommaOperator(const char_type * & source, const Conv & conv)
- if( (*source == static_cast<char_type>(conv.comma)) ||
- (*source == static_cast<char_type>(conv.comma2) && conv.comma2 != 0 ) )
- ++source;
- return true;
- return false;
- this method reads the first part of a string
- (before the comma operator)
- uint FromString_ReadPartBeforeComma( const char_type * & source, const Conv & conv, bool & value_read )
- sint character;
- Big<exp, man> base_( conv.base );
- Misc::SkipWhiteCharacters( source );
- for( ; true ; ++source )
- if( conv.group!=0 && *source==static_cast<char>(conv.group) )
- continue;
- character = Misc::CharToDigit(*source, conv.base);
- if( character == -1 )
- break;
- value_read = true;
- temp = character;
- if( Mul(base_) )
- return 1;
- if( Add(temp) )
- return 1;
- return 0;
- this method reads the second part of a string
- (after the comma operator)
- uint FromString_ReadPartAfterComma( const char_type * & source, const Conv & conv, bool & value_read )
- sint character;
- uint c = 0, power = 0;
- UInt<1> power_;
- Big<exp, man> sum, base_(conv.base);
- // we don't remove any white characters here
- sum.SetZero();
- for( ; sum.exponent.IsSign() || sum.exponent.IsZero() ; ++source )
- continue;
- break;
- // there actually shouldn't be a carry here
- c += sum.Mul(base_);
- c += sum.Add(character);
- power += 1;
- if( power == 0 )
- c += 1;
- // we could break the parsing somewhere in the middle of the string,
- // but the result (value) still can be good
- // we should set a correct value of 'source' now
- while( Misc::CharToDigit(*source, conv.base) != -1 )
- ++source;
- power_ = power;
- c += base_.Pow(power_);
- c += sum.Div(base_);
- c += Add(sum);
- this method checks whether there is a scientific part: [e|E][-|+]value
- it is called when the base is 10 and some digits were read before
- uint FromString_ReadScientificIfExists(const char_type * & source)
- uint c = 0;
- bool scientific_read = false;
- const char_type * before_scientific = source;
- if( FromString_TestScientific(source) )
- c += FromString_ReadPartScientific( source, scientific_read );
- if( !scientific_read )
- source = before_scientific;
- we're testing whether is there the character 'e'
- this character is only allowed when we're using the base equals 10
- bool FromString_TestScientific(const char_type * & source)
- if( *source=='e' || *source=='E' )
- ++source;
- return true;
- return false;
- this method reads the exponent (after 'e' character) when there's a scientific
- format of value and only when we're using the base equals 10
- uint FromString_ReadPartScientific( const char_type * & source, bool & scientific_read )
- uint c = 0;
- Big<exp, man> new_exponent, temp;
- bool was_sign = false;
- FromString_TestSign( source, was_sign );
- c += FromString_ReadPartScientific_ReadExponent( source, new_exponent, scientific_read );
- if( scientific_read )
- if( was_sign )
- new_exponent.ChangeSign();
- temp = 10;
- c += temp.Pow( new_exponent );
- c += Mul(temp);
- this method reads the value of the extra exponent when scientific format is used
- (only when base == 10)
- uint FromString_ReadPartScientific_ReadExponent( const char_type * & source, Big<exp, man> & new_exponent, bool & scientific_read )
- sint character;
- Big<exp, man> base, temp;
- new_exponent.SetZero();
- base = 10;
- for( ; (character=Misc::CharToDigit(*source, 10)) != -1 ; ++source )
- scientific_read = true;
- temp = character;
- if( new_exponent.Mul(base) )
- return 1;
- if( new_exponent.Add(temp) )
- return 1;
- return 0;
-public:
- a constructor for converting a string into this class
- Big(const char * string)
- FromString( string );
- Big(const std::string & string)
- FromString( string.c_str() );
- an operator= for converting a string into its value
- Big<exp, man> & operator=(const char * string)
- return *this;
- Big<exp, man> & operator=(const std::string & string)
- return *this;
- Big(const wchar_t * string)
- Big(const std::wstring & string)
- Big<exp, man> & operator=(const wchar_t * string)
- return *this;
- Big<exp, man> & operator=(const std::wstring & string)
- return *this;
-#endif
- * methods for comparing
- this method performs the formula 'abs(this) < abs(ss2)'
- and returns the result
- (in other words it treats 'this' and 'ss2' as values without a sign)
- we don't check the NaN flag
- bool SmallerWithoutSignThan(const Big<exp,man> & ss2) const
- if( IsZero() )
- if( ss2.IsZero() )
- // we've got two zeroes
- return false;
- else
- // this==0 and ss2!=0
- return true;
- // this!=0 and ss2==0
- return false;
- // we're using the fact that all bits in mantissa are pushed
- // into the left side -- Standardizing()
- if( exponent == ss2.exponent )
- return mantissa < ss2.mantissa;
- return exponent < ss2.exponent;
- this method performs the formula 'abs(this) > abs(ss2)'
- bool GreaterWithoutSignThan(const Big<exp,man> & ss2) const
- if( IsZero() )
- return false;
- else
- return false;
- return true;
- return mantissa > ss2.mantissa;
- return exponent > ss2.exponent;
- this method performs the formula 'abs(this) == abs(ss2)'
- bool EqualWithoutSign(const Big<exp,man> & ss2) const
- if( IsZero() )
- return true;
- else
- return false;
- return false;
- if( exponent==ss2.exponent && mantissa==ss2.mantissa )
- return true;
- return false;
- bool operator<(const Big<exp,man> & ss2) const
- if( IsSign() && !ss2.IsSign() )
- // this<0 and ss2>=0
- return true;
- if( !IsSign() && ss2.IsSign() )
- // this>=0 and ss2<0
- return false;
- // both signs are the same
- if( IsSign() )
- return ss2.SmallerWithoutSignThan( *this );
- return SmallerWithoutSignThan( ss2 );
- bool operator==(const Big<exp,man> & ss2) const
- if( IsSign() != ss2.IsSign() )
- return false;
- return EqualWithoutSign( ss2 );
- bool operator>(const Big<exp,man> & ss2) const
- return false;
- return true;
- if( IsSign() )
- return ss2.GreaterWithoutSignThan( *this );
- return GreaterWithoutSignThan( ss2 );
- bool operator>=(const Big<exp,man> & ss2) const
- return !operator<( ss2 );
- bool operator<=(const Big<exp,man> & ss2) const
- return !operator>( ss2 );
- bool operator!=(const Big<exp,man> & ss2) const
- return !operator==(ss2);
- * standard mathematical operators
- an operator for changing the sign
- this method is not changing 'this' but the changed value is returned
- Big<exp,man> operator-() const
- Big<exp,man> temp(*this);
- temp.ChangeSign();
- return temp;
- Big<exp,man> operator-(const Big<exp,man> & ss2) const
- temp.Sub(ss2);
- return temp;
- Big<exp,man> & operator-=(const Big<exp,man> & ss2)
- Sub(ss2);
- return *this;
- Big<exp,man> operator+(const Big<exp,man> & ss2) const
- temp.Add(ss2);
- return temp;
- Big<exp,man> & operator+=(const Big<exp,man> & ss2)
- Add(ss2);
- return *this;
- Big<exp,man> operator*(const Big<exp,man> & ss2) const
- temp.Mul(ss2);
- return temp;
- Big<exp,man> & operator*=(const Big<exp,man> & ss2)
- Mul(ss2);
- return *this;
- Big<exp,man> operator/(const Big<exp,man> & ss2) const
- temp.Div(ss2);
- return temp;
- Big<exp,man> & operator/=(const Big<exp,man> & ss2)
- Div(ss2);
- return *this;
- Prefix operator e.g ++variable
- Big<exp,man> & operator++()
- AddOne();
- return *this;
- Postfix operator e.g variable++
- Big<exp,man> operator++(int)
- Big<exp,man> temp( *this );
- AddOne();
- return temp;
- Big<exp,man> & operator--()
- SubOne();
- return *this;
- Big<exp,man> operator--(int)
- SubOne();
- return temp;
- * bitwise operators
- * (we do not define bitwise not)
- Big<exp,man> operator&(const Big<exp,man> & p2) const
- temp.BitAnd(p2);
- return temp;
- Big<exp,man> & operator&=(const Big<exp,man> & p2)
- BitAnd(p2);
- return *this;
- Big<exp,man> operator|(const Big<exp,man> & p2) const
- temp.BitOr(p2);
- return temp;
- Big<exp,man> & operator|=(const Big<exp,man> & p2)
- BitOr(p2);
- return *this;
- Big<exp,man> operator^(const Big<exp,man> & p2) const
- temp.BitXor(p2);
- return temp;
- Big<exp,man> & operator^=(const Big<exp,man> & p2)
- BitXor(p2);
- return *this;
- this method makes an integer value by skipping any fractions
- samples:
- - 10.7 will be 10
- - 12.1 -- 12
- - -20.2 -- 20
- - -20.9 -- 20
- - -0.7 -- 0
- - 0.8 -- 0
- void SkipFraction()
- if( IsNan() || IsZero() )
- return;
- // exponent >=0 -- the value don't have any fractions
- return;
- // the value is from (-1,1), we return zero
- SetZero();
- return;
- // exponent is in range (-man*TTMATH_BITS_PER_UINT, 0)
- sint e = exponent.ToInt();
- mantissa.ClearFirstBits( -e );
- // we don't have to standardize 'Standardizing()' the value because
- // there's at least one bit in the mantissa
- // (the highest bit which we didn't touch)
- this method remains only a fraction from the value
- samples:
- - 30.56 will be 0.56
- - -12.67 will be -0.67
- void RemainFraction()
- return;
- // exponent >= 0 -- the value doesn't have any fractions
- // we return zero
- SetZero();
- return;
- // we don't make anything with the value
- return;
- // e will be from (-man*TTMATH_BITS_PER_UINT, 0)
- sint how_many_bits_leave = sint(man*TTMATH_BITS_PER_UINT) + e; // there'll be a subtraction -- e is negative
- mantissa.Rcl( how_many_bits_leave, 0);
- // there'll not be a carry because the exponent is too small
- exponent.Sub( how_many_bits_leave );
- // we must call Standardizing() here
- Standardizing();
- this method returns true if the value is integer
- (there is no a fraction)
- (we don't check NaN)
- bool IsInteger() const
- if( IsZero() )
- return true;
- return true;
- return false;
- e = -e; // e means how many bits we must check
- uint len = e / TTMATH_BITS_PER_UINT;
- uint rest = e % TTMATH_BITS_PER_UINT;
- uint i = 0;
- for( ; i<len ; ++i )
- if( mantissa.table[i] != 0 )
- return false;
- if( rest > 0 )
- uint rest_mask = TTMATH_UINT_MAX_VALUE >> (TTMATH_BITS_PER_UINT - rest);
- if( (mantissa.table[i] & rest_mask) != 0 )
- return false;
- return true;
- this method rounds to the nearest integer value
- (it returns a carry if it was)
- samples:
- - 2.3 = 2
- - 2.8 = 3
- - -2.3 = -2
- - -2.8 = 3
- uint Round()
- Big<exp,man> half;
- uint c;
- if( IsNan() )
- return 1;
- if( IsZero() )
- return 0;
- half.Set05();
- if( IsSign() )
- // 'this' is < 0
- c = Sub( half );
- else
- // 'this' is > 0
- c = Add( half );
- SkipFraction();
- * input/output operators for standard streams
-private:
- an auxiliary method for outputing to standard streams
- template<class ostream_type, class string_type>
- static ostream_type & OutputToStream(ostream_type & s, const Big<exp,man> & l)
- string_type ss;
- l.ToString(ss);
- s << ss;
- return s;
-public:
- output to standard streams
- friend std::ostream & operator<<(std::ostream & s, const Big<exp,man> & l)
- return OutputToStream<std::ostream, std::string>(s, l);
- friend std::wostream & operator<<(std::wostream & s, const Big<exp,man> & l)
- return OutputToStream<std::wostream, std::wstring>(s, l);
-#endif
-private:
- template<class istream_type, class string_type, class char_type>
- static istream_type & InputFromStream(istream_type & s, Big<exp,man> & l)
- string_type ss;
- // char or wchar_t for operator>>
- char_type z, old_z;
- bool was_comma = false;
- bool was_e = false;
- // operator>> omits white characters if they're set for ommiting
- s >> z;
- if( z=='-' || z=='+' )
- ss += z;
- s >> z; // we're reading a next character (white characters can be ommited)
- old_z = 0;
- // we're reading only digits (base=10) and only one comma operator
- for( ; s.good() ; z=static_cast<char_type>(s.get()) )
- if( z=='.' || z==',' )
- if( was_comma || was_e )
- // second comma operator or comma operator after 'e' character
- break;
- was_comma = true;
- else
- if( z == 'e' || z == 'E' )
- if( was_e )
- // second 'e' character
- break;
- was_e = true;
- else
- if( z == '+' || z == '-' )
- if( old_z != 'e' && old_z != 'E' )
- // '+' or '-' is allowed only after 'e' character
- break;
- else
- if( Misc::CharToDigit(z, 10) < 0 )
- break;
- ss += z;
- old_z = z;
- // we're leaving the last read character
- // (it's not belonging to the value)
- s.unget();
- l.FromString( ss );
- return s;
-public:
- input from standard streams
- friend std::istream & operator>>(std::istream & s, Big<exp,man> & l)
- return InputFromStream<std::istream, std::string, char>(s, l);
- friend std::wistream & operator>>(std::wistream & s, Big<exp,man> & l)
- return InputFromStream<std::wistream, std::wstring, wchar_t>(s, l);
-#endif
-} // namespace
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmathdec.h b/include/geos/algorithm/ttmath/ttmathdec.h
deleted file mode 100644
index ec2c753..0000000
--- a/include/geos/algorithm/ttmath/ttmathdec.h
+++ /dev/null
@@ -1,419 +0,0 @@
- * This file is a part of TTMath Bignum Library
- * and is distributed under the 3-Clause BSD Licence.
- * Author: Tomasz Sowa <t.sowa at ttmath.org>
- * Copyright (c) 2012, Tomasz Sowa
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- * * Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * * Neither the name Tomasz Sowa nor the names of contributors to this
- * project may be used to endorse or promote products derived
- * from this software without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
- * THE POSSIBILITY OF SUCH DAMAGE.
-#ifndef headerfilettmathdec
-#define headerfilettmathdec
-#include "ttmathtypes.h"
-#include "ttmaththreads.h"
-#include "ttmathuint.h"
-namespace ttmath
-template<uint value_size, uint dec_digits>
-class Dec
-public:
- UInt<value_size> value;
- unsigned char info;
- Sign
- the mask of a bit from 'info' which means that there is a sign
- (when the bit is set)
- #define TTMATH_DEC_SIGN 128
- Not a number
- if this bit is set that there is not a valid number
- #define TTMATH_DEC_NAN 64
- Dec()
- info = TTMATH_DEC_NAN;
- Dec(const char * s)
- FromString(s);
- Dec<value_size, dec_digits> & operator=(const char * s)
- FromString(s);
- return *this;
- uint FromString(const char * s, const char ** after_source = 0, bool * value_read = 0)
- return FromStringBase(s, after_source, value_read);
- void ToString(std::string & result) const
- ToStringBase(result);
- this method clears a specific bit in the 'info' variable
- bit is one of:
- void ClearInfoBit(unsigned char bit)
- info = info & (~bit);
- this method sets a specific bit in the 'info' variable
- bit is one of:
- void SetInfoBit(unsigned char bit)
- info = info | bit;
- this method returns true if a specific bit in the 'info' variable is set
- bit is one of:
- bool IsInfoBit(unsigned char bit) const
- return (info & bit) != 0;
- bool IsNan() const
- return IsInfoBit(TTMATH_DEC_NAN);
- bool IsSign() const
- return IsInfoBit(TTMATH_DEC_SIGN);
- this method sets the sign
- e.g.
- -1 -> -1
- 2 -> -2
- we do not check whether there is a zero or not, if you're using this method
- you must be sure that the value is (or will be afterwards) different from zero
- void SetSign()
- SetInfoBit(TTMATH_DEC_SIGN);
- void SetNaN()
- SetInfoBit(TTMATH_DEC_NAN);
- void Abs()
- ClearInfoBit(TTMATH_DEC_SIGN);
- uint Add(const Dec<value_size, dec_digits> & arg)
- uint c = 0;
- if( IsSign() == arg.IsSign() )
- c += value.Add(arg.value);
- else
- bool is_sign;
- if( value > arg.value )
- is_sign = IsSign();
- value.Sub(arg.value);
- else
- is_sign = arg.IsSign();
- UInt<value_size> temp(this->value);
- value = arg.value;
- value.Sub(temp);
- is_sign ? SetSign() : Abs();
- if( c )
- SetNaN();
- uint Sub(const Dec<value_size, dec_digits> & arg)
-private:
- void SetMultipler(UInt<value_size> & result)
- // this guardian is initialized before the program runs (static POD type)
- static int guardian = 0;
- static UInt<value_size> multipler;
- if( guardian == 0 )
- multipler = 10;
- multipler.Pow(dec_digits);
- guardian = 1;
- result = multipler;
-#else
- volatile static sig_atomic_t guardian = 0;
- static UInt<value_size> * pmultipler;
- // locking
- pmultipler = &multipler;
- multipler = 10;
- guardian = 1;
- else
- result = 10;
- result.Pow(dec_digits);
- return;
- result = *pmultipler;
-#endif
- uint FromStringBase(const char_type * s, const char_type ** after_source = 0, bool * value_read = 0)
- UInt<value_size> multipler;
- const char_type * after;
- uint c = 0;
- info = 0;
- Misc::SkipWhiteCharacters(s);
- if( *s == '-' )
- s += 1;
- SetSign();
- else
- if( *s == '+' )
- s += 1;
- c += value.FromString(s, 10, &after, value_read);
- *after_source = after;
- SetMultipler(multipler);
- c += value.Mul(multipler);
- if( *after == '.' )
- c += FromStringBaseAfterComma(after+1, after_source);
- if( c )
- uint FromStringBaseAfterComma(const char_type * s, const char_type ** after_source = 0, bool * value_read = 0)
- UInt<value_size> temp;
- sint z;
- uint c = 0;
- size_t i = dec_digits;
- for( ; i>0 && (z=Misc::CharToDigit(*s, 10)) != -1 ; --i, ++s )
- multipler.DivInt(10);
- temp.SetZero();
- if( value_read )
- *value_read = true;
- if( c == 0 )
- temp.table[0] = z;
- c += temp.Mul(multipler);
- c += value.Add(temp);
- if( i == 0 && (z=Misc::CharToDigit(*s, 10)) != -1 && z >= 5 )
- c += value.AddOne();
- while( (z=Misc::CharToDigit(*s, 10)) != -1 )
- s += 1;
- *after_source = s;
- return c;
- void ToStringBase(string_type & result) const
- if( IsNan() )
- result = "NaN";
- return;
- value.ToStringBase(result, 10, IsSign());
- if( dec_digits > 0 )
- size_t size = result.size();
- if( IsSign() && size > 0 )
- size -= 1;
- if( dec_digits >= size )
- size_t zeroes = dec_digits - size + 1;
- size_t start = IsSign() ? 1 : 0;
- result.insert(start, zeroes, '0');
- result.insert(result.end() - dec_digits, '.');
-} // namespace
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmathint.h b/include/geos/algorithm/ttmath/ttmathint.h
index 7188184..0000000
--- a/include/geos/algorithm/ttmath/ttmathint.h
+++ /dev/null
@@ -1,1923 +0,0 @@
- * Copyright (c) 2006-2017, Tomasz Sowa
-#ifndef headerfilettmathint
-#define headerfilettmathint
- \file ttmathint.h
- \brief template class Int<uint>
-namespace ttmath
- \brief Int implements a big integer value with a sign
- value_size - how many bytes specify our value
- - on 32bit platforms: value_size=1 -> 4 bytes -> 32 bits
- - on 64bit platforms: value_size=1 -> 8 bytes -> 64 bits
- value_size = 1,2,3,4,5,6....
-template<uint value_size>
-class Int : public UInt<value_size>
-public:
- this method sets the max value which this class can hold
- (all bits will be one besides the last one)
- void SetMax()
- UInt<value_size>::SetMax();
- UInt<value_size>::table[value_size-1] = ~ TTMATH_UINT_HIGHEST_BIT;
- this method sets the min value which this class can hold
- (all bits will be zero besides the last one which is one)
- void SetMin()
- UInt<value_size>::SetZero();
- UInt<value_size>::table[value_size-1] = TTMATH_UINT_HIGHEST_BIT;
- this method sets -1 as the value
- (-1 is equal the max value in an unsigned type)
- void SetSignOne()
- we change the sign of the value
- if it isn't possible to change the sign this method returns 1
- else return 0 and changing the sign
- uint ChangeSign()
- if the value is equal that one which has been returned from SetMin
- (only the highest bit is set) that means we can't change sign
- because the value is too big (bigger about one)
- e.g. when value_size = 1 and value is -2147483648 we can't change it to the
- 2147483648 because the max value which can be held is 2147483647
- we don't change the value and we're using this fact somewhere in some methods
- (if we look on our value without the sign we get the correct value
- eg. -2147483648 in Int<1> will be 2147483648 on the UInt<1> type)
- if( UInt<value_size>::IsOnlyTheHighestBitSet() )
- return 1;
- UInt<value_size> temp(*this);
- UInt<value_size>::Sub(temp);
- return 0;
- samples
- - 1 -> -1
- - -2 -> -2
- from a positive value we make a negative value,
- if the value is negative we do nothing
- void SetSign()
- if( IsSign() )
- return;
- ChangeSign();
- this method returns true if there's the sign
- (the highest bit will be converted to the bool)
- return UInt<value_size>::IsTheHighestBitSet();
- it sets an absolute value
- it can return carry (1) (look on ChangeSign() for details)
- uint Abs()
- if( !IsSign() )
- return 0;
- return ChangeSign();
- * basic mathematic functions
-private:
- uint CorrectCarryAfterAdding(bool p1_is_sign, bool p2_is_sign)
- if( !p1_is_sign && !p2_is_sign )
- if( UInt<value_size>::IsTheHighestBitSet() )
- return 1;
- if( p1_is_sign && p2_is_sign )
- if( ! UInt<value_size>::IsTheHighestBitSet() )
- return 1;
- return 0;
-public:
- this method adds two value with a sign and returns a carry
- we're using methods from the base class because values are stored with U2
- we must only make the carry correction
- this = p1(=this) + p2
- when p1>=0 i p2>=0 carry is set when the highest bit of value is set
- when p1<0 i p2<0 carry is set when the highest bit of value is clear
- when p1>=0 i p2<0 carry will never be set
- when p1<0 i p2>=0 carry will never be set
- uint Add(const Int<value_size> & ss2)
- bool p1_is_sign = IsSign();
- bool p2_is_sign = ss2.IsSign();
- UInt<value_size>::Add(ss2);
- return CorrectCarryAfterAdding(p1_is_sign, p2_is_sign);
- this method adds one *unsigned* word (at a specific position)
- and returns a carry (if it was)
- look at a description in UInt<>::AddInt(...)
- uint AddInt(uint value, uint index = 0)
- UInt<value_size>::AddInt(value, index);
- return CorrectCarryAfterAdding(p1_is_sign, false);
- this method adds two *unsigned* words to the existing value
- and these words begin on the 'index' position
- index should be equal or smaller than value_size-2 (index <= value_size-2)
- x1 - lower word, x2 - higher word
- look at a description in UInt<>::AddTwoInts(...)
- uint AddTwoInts(uint x2, uint x1, uint index)
- UInt<value_size>::AddTwoInts(x2, x1, index);
-private:
- uint CorrectCarryAfterSubtracting(bool p1_is_sign, bool p2_is_sign)
- if( !p1_is_sign && p2_is_sign )
- return 1;
- if( p1_is_sign && !p2_is_sign )
- return 1;
- return 0;
-public:
- this method subtracts two values with a sign
- we don't use the previous Add because the method ChangeSign can
- sometimes return carry
- this = p1(=this) - p2
- - when p1>=0 i p2>=0 carry will never be set
- - when p1<0 i p2<0 carry will never be set
- - when p1>=0 i p2<0 carry is set when the highest bit of value is set
- - when p1<0 i p2>=0 carry is set when the highest bit of value is clear
- uint Sub(const Int<value_size> & ss2)
- UInt<value_size>::Sub(ss2);
- return CorrectCarryAfterSubtracting(p1_is_sign, p2_is_sign);
- this method subtracts one *unsigned* word (at a specific position)
- uint SubInt(uint value, uint index = 0)
- UInt<value_size>::SubInt(value, index);
- return CorrectCarryAfterSubtracting(p1_is_sign, false);
- this method adds one to the value and returns carry
- uint AddOne()
- UInt<value_size>::AddOne();
- this method subtracts one from the value and returns carry
- uint SubOne()
- UInt<value_size>::SubOne();
-private:
- uint CheckMinCarry(bool ss1_is_sign, bool ss2_is_sign)
- we have to examine the sign of the result now
- but if the result is with the sign then:
- 1. if the signs were the same that means the result is too big
- (the result must be without a sign)
- 2. if the signs were different that means if the result
- is different from that one which has been returned from SetMin()
- that is carry (result too big) but if the result is equal SetMin()
- there'll be ok (and the next SetSign will has no effect because
- the value is actually negative -- look at description of that case
- in ChangeSign())
- if( IsSign() )
- if( ss1_is_sign != ss2_is_sign )
- there can be one case where signs are different and
- the result will be equal the value from SetMin() (only the highest bit is set)
- (this situation is ok)
- if( !UInt<value_size>::IsOnlyTheHighestBitSet() )
- return 1;
- else
- // signs were the same
- return 1;
- return 0;
-public:
- multiplication: this = this * ss2
- it can return a carry
- uint MulInt(sint ss2)
- bool ss1_is_sign, ss2_is_sign;
- uint c;
- ss1_is_sign = IsSign();
- we don't have to check the carry from Abs (values will be correct
- because next we're using the method MulInt from the base class UInt
- which is without a sign)
- Abs();
- if( ss2 < 0 )
- ss2 = -ss2;
- ss2_is_sign = true;
- else
- ss2_is_sign = false;
- c = UInt<value_size>::MulInt((uint)ss2);
- c += CheckMinCarry(ss1_is_sign, ss2_is_sign);
- SetSign();
- return c;
- multiplication this = this * ss2
- it returns carry if the result is too big
- (we're using the method from the base class but we have to make
- one correction in account of signs)
- uint Mul(Int<value_size> ss2)
- uint c;
- ss2_is_sign = ss2.IsSign();
- because next we're using the method Mul from the base class UInt
- Abs();
- ss2.Abs();
- c = UInt<value_size>::Mul(ss2);
- SetSign();
- return c;
- division this = this / ss2
- returned values:
- - 0 - ok
- - 1 - division by zero
- for example: (result means 'this')
- - 20 / 3 --> result: 6 remainder: 2
- - -20 / 3 --> result: -6 remainder: -2
- - 20 / -3 --> result: -6 remainder: 2
- - -20 / -3 --> result: 6 remainder: -2
- in other words: this(old) = ss2 * this(new)(result) + remainder
- uint Div(Int<value_size> ss2, Int<value_size> * remainder = 0)
- we don't have to test the carry from Abs as well as in Mul
- Abs();
- ss2.Abs();
- uint c = UInt<value_size>::Div(ss2, remainder);
- SetSign();
- if( ss1_is_sign && remainder )
- remainder->SetSign();
- return c;
- uint Div(const Int<value_size> & ss2, Int<value_size> & remainder)
- return Div(ss2, &remainder);
- division this = this / ss2 (ss2 is int)
- returned values:
- - 0 - ok
- uint DivInt(sint ss2, sint * remainder = 0)
- Abs();
- if( ss2 < 0 )
- ss2 = -ss2;
- else
- uint rem;
- uint c = UInt<value_size>::DivInt((uint)ss2, &rem);
- SetSign();
- if( remainder )
- if( ss1_is_sign )
- *remainder = -sint(rem);
- else
- *remainder = sint(rem);
- return c;
- uint DivInt(sint ss2, sint & remainder)
- return DivInt(ss2, &remainder);
-private:
- power this = this ^ pow
- this can be negative
- pow is >= 0
- uint Pow2(const Int<value_size> & pow)
- bool was_sign = IsSign();
- uint c = 0;
- if( was_sign )
- c += Abs();
- uint c_temp = UInt<value_size>::Pow(pow);
- if( c_temp > 0 )
- return c_temp; // c_temp can be: 0, 1 or 2
- if( was_sign && (pow.table[0] & 1) == 1 )
- // negative value to the power of odd number is negative
- c += ChangeSign();
-public:
- return values:
- - 0 - ok
- - 1 - carry
- - 2 - incorrect arguments 0^0 or 0^(-something)
- uint Pow(Int<value_size> pow)
- if( !pow.IsSign() )
- return Pow2(pow);
- if( UInt<value_size>::IsZero() )
- // if 'pow' is negative then
- // 'this' must be different from zero
- return 2;
- if( pow.ChangeSign() )
- return 1;
- Int<value_size> t(*this);
- uint c_temp = t.Pow2(pow);
- if( c_temp > 0 )
- return c_temp;
- UInt<value_size>::SetOne();
- if( Div(t) )
- return 1;
- return 0;
- * convertion methods
-private:
- an auxiliary method for converting both from UInt and Int
- template<uint argument_size>
- uint FromUIntOrInt(const UInt<argument_size> & p, bool UInt_type)
- uint min_size = (value_size < argument_size)? value_size : argument_size;
- uint i;
- for(i=0 ; i<min_size ; ++i)
- UInt<value_size>::table[i] = p.table[i];
- if( value_size > argument_size )
- uint fill;
- if( UInt_type )
- fill = 0;
- else
- fill = (p.table[argument_size-1] & TTMATH_UINT_HIGHEST_BIT)?
- TTMATH_UINT_MAX_VALUE : 0;
- // 'this' is longer than 'p'
- for( ; i<value_size ; ++i)
- UInt<value_size>::table[i] = fill;
- else
- uint test = (UInt<value_size>::table[value_size-1] & TTMATH_UINT_HIGHEST_BIT)?
- if( UInt_type && test!=0 )
- return 1;
- for( ; i<argument_size ; ++i)
- if( p.table[i] != test )
- return 1;
- return 0;
-public:
- this method converts an Int<another_size> type into this class
- this operation has mainly sense if the value from p
- can be held in this type
- it returns a carry if the value 'p' is too big
- uint FromInt(const Int<argument_size> & p)
- return FromUIntOrInt(p, false);
- this method converts the sint type into this class
- uint FromInt(sint value)
- uint fill = ( value<0 ) ? TTMATH_UINT_MAX_VALUE : 0;
- for(uint i=1 ; i<value_size ; ++i)
- UInt<value_size>::table[0] = uint(value);
- // there'll never be a carry here
- return 0;
- this method converts UInt<another_size> into this class
- uint FromUInt(const UInt<argument_size> & p)
- return FromUIntOrInt(p, true);
- uint FromInt(const UInt<argument_size> & p)
- this method converts the uint type into this class
- uint FromUInt(uint value)
- UInt<value_size>::table[i] = 0;
- UInt<value_size>::table[0] = value;
- // there can be a carry here when the size of this value is equal one word
- // and the 'value' has the highest bit set
- if( value_size==1 && (value & TTMATH_UINT_HIGHEST_BIT)!=0 )
- return 1;
- return 0;
- uint FromInt(uint value)
- return FromUInt(value);
- Int<value_size> & operator=(const Int<value_size> & p)
- FromInt(p);
- return *this;
- this operator converts an Int<another_size> type to this class
- it doesn't return a carry
- Int<value_size> & operator=(const Int<argument_size> & p)
- FromInt(p);
- return *this;
- this method converts the sint type to this class
- Int<value_size> & operator=(sint i)
- FromInt(i);
- return *this;
- a constructor for converting the uint to this class
- Int(sint i)
- FromInt(i);
- a copy constructor
- Int(const Int<value_size> & u) : UInt<value_size>()
- FromInt(u);
- a constructor for copying from another types
- Int(const Int<argument_size> & u)
- // look that 'size' we still set as 'value_size' and not as u.value_size
- FromInt(u);
- this operator converts an UInt<another_size> type to this class
- Int<value_size> & operator=(const UInt<argument_size> & p)
- FromUInt(p);
- return *this;
- this method converts the Uint type to this class
- Int<value_size> & operator=(uint i)
- FromUInt(i);
- return *this;
- Int(uint i)
- FromUInt(i);
- Int(const UInt<argument_size> & u)
- FromUInt(u);
-#ifdef TTMATH_PLATFORM32
- this method converts unsigned 64 bit int type to this class
- ***this method is created only on a 32bit platform***
- uint FromUInt(ulint n)
- uint c = UInt<value_size>::FromUInt(n);
- if( c )
- return 1;
- if( value_size == 1 )
- return ((UInt<value_size>::table[0] & TTMATH_UINT_HIGHEST_BIT) == 0) ? 0 : 1;
- if( value_size == 2 )
- return ((UInt<value_size>::table[1] & TTMATH_UINT_HIGHEST_BIT) == 0) ? 0 : 1;
- return 0;
- uint FromInt(ulint n)
- return FromUInt(n);
- this method converts signed 64 bit int type to this class
- uint FromInt(slint n)
- uint mask = (n < 0) ? TTMATH_UINT_MAX_VALUE : 0;
- UInt<value_size>::table[0] = (uint)(ulint)n;
- if( uint(ulint(n) >> 32) != mask )
- return 1;
- return ((UInt<value_size>::table[0] & TTMATH_UINT_HIGHEST_BIT) == (mask & TTMATH_UINT_HIGHEST_BIT)) ? 0 : 1;
- UInt<value_size>::table[1] = (uint)(ulint(n) >> 32);
- for(uint i=2 ; i<value_size ; ++i)
- UInt<value_size>::table[i] = mask;
- return 0;
- this operator converts unsigned 64 bit int type to this class
- ***this operator is created only on a 32bit platform***
- Int<value_size> & operator=(ulint n)
- FromUInt(n);
- return *this;
- a constructor for converting unsigned 64 bit int to this class
- ***this constructor is created only on a 32bit platform***
- Int(ulint n)
- FromUInt(n);
- this operator converts signed 64 bit int type to this class
- Int<value_size> & operator=(slint n)
- FromInt(n);
- return *this;
- a constructor for converting signed 64 bit int to this class
- Int(slint n)
- FromInt(n);
-#endif
-#ifdef TTMATH_PLATFORM64
- this method converts 32 bit unsigned int type to this class
- ***this operator is created only on a 64bit platform***
- uint FromUInt(unsigned int i)
- return FromUInt(uint(i));
- uint FromInt(unsigned int i)
- return FromUInt(i);
- this method converts 32 bit signed int type to this class
- uint FromInt(signed int i)
- return FromInt(sint(i));
- Int<value_size> & operator=(unsigned int i)
- FromUInt(i);
- return *this;
- a constructor for converting 32 bit unsigned int to this class
- ***this constructor is created only on a 64bit platform***
- Int(unsigned int i)
- FromUInt(i);
- this operator converts 32 bit signed int type to this class
- Int<value_size> & operator=(signed int i)
- FromInt(i);
- return *this;
- a constructor for converting 32 bit signed int to this class
- Int(signed int i)
- FromInt(i);
-#endif
- a constructor for converting string to this class (with the base=10)
- Int(const char * s)
- FromString(s);
- a constructor for converting a string to this class (with the base=10)
- Int(const std::string & s)
- FromString( s.c_str() );
-#ifndef TTMATH_DONT_USE_WCHAR
- Int(const wchar_t * s)
- FromString(s);
- Int(const std::wstring & s)
-#endif
- a default constructor
- we don't clear table etc.
- Int()
- the destructor
- ~Int()
- this method returns the lowest value from table with a sign
- we must be sure when we using this method whether the value
- will hold in an sint type or not (the rest value from table must be zero or -1)
- sint ToInt() const
- return sint( UInt<value_size>::table[0] );
- this method converts the value to uint type
- can return a carry if the value is too long to store it in uint type
- uint ToUInt(uint & result) const
- uint c = UInt<value_size>::ToUInt(result);
- return (result & TTMATH_UINT_HIGHEST_BIT) == 0 ? 0 : 1;
- return c;
- uint ToInt(uint & result) const
- return ToUInt(result);
- this method converts the value to sint type
- can return a carry if the value is too long to store it in sint type
- uint ToInt(sint & result) const
- result = sint( UInt<value_size>::table[0] );
- uint mask = IsSign() ? TTMATH_UINT_MAX_VALUE : 0;
- if( (result & TTMATH_UINT_HIGHEST_BIT) != (mask & TTMATH_UINT_HIGHEST_BIT) )
- return 1;
- if( UInt<value_size>::table[i] != mask )
- return 1;
- return 0;
- this method converts the value to ulint type (64 bit unsigned integer)
- can return a carry if the value is too long to store it in ulint type
- *** this method is created only on a 32 bit platform ***
- uint ToUInt(ulint & result) const
- return (UInt<value_size>::table[0] & TTMATH_UINT_HIGHEST_BIT) == 0 ? 0 : 1;
- return (UInt<value_size>::table[1] & TTMATH_UINT_HIGHEST_BIT) == 0 ? 0 : 1;
- return c;
- uint ToInt(ulint & result) const
- this method converts the value to slint type (64 bit signed integer)
- can return a carry if the value is too long to store it in slint type
- uint ToInt(slint & result) const
- result = slint(sint(UInt<value_size>::table[0]));
- else
- uint low = UInt<value_size>::table[0];
- uint high = UInt<value_size>::table[1];
- result = low;
- result |= (ulint(high) << TTMATH_BITS_PER_UINT);
- if( (high & TTMATH_UINT_HIGHEST_BIT) != (mask & TTMATH_UINT_HIGHEST_BIT) )
- return 1;
- return 1;
- return 0;
-#endif
- this method converts the value to a 32 bit unsigned integer
- can return a carry if the value is too long to store it in this type
- *** this method is created only on a 64 bit platform ***
- uint ToUInt(unsigned int & result) const
- if( c || IsSign() )
- return 1;
- return 0;
- uint ToInt(unsigned int & result) const
- this method converts the value to a 32 bit signed integer
- uint ToInt(int & result) const
- uint first = UInt<value_size>::table[0];
- result = int(first);
- if( (first >> 31) != (mask >> 31) )
- return 1;
- return 1;
- return 0;
-#endif
-private:
- an auxiliary method for converting to a string
- void ToStringBase(string_type & result, uint b = 10) const
- if( IsSign() )
- Int<value_size> temp(*this);
- temp.Abs();
- temp.UInt<value_size>::ToStringBase(result, b, true);
- else
- UInt<value_size>::ToStringBase(result, b, false);
-public:
- this method converts the value to a string with a base equal 'b'
- void ToString(std::string & result, uint b = 10) const
- return ToStringBase(result, b);
- std::string ToString(uint b = 10) const
- std::string result;
- ToStringBase(result, b);
- return result;
- void ToString(std::wstring & result, uint b = 10) const
- std::wstring ToWString(uint b = 10) const
- std::wstring result;
- return result;
-#endif
-private:
- uint FromStringBase(const char_type * s, uint b = 10, const char_type ** after_source = 0, bool * value_read = 0)
- bool is_sign = false;
- if( *s == '-' )
- is_sign = true;
- Misc::SkipWhiteCharacters(++s);
- else
- if( *s == '+' )
- if( UInt<value_size>::FromString(s,b,after_source,value_read) )
- return 1;
- if( is_sign )
- Int<value_size> mmin;
- mmin.SetMin();
- the reference to mmin will be automatically converted to the reference
- to UInt type
- (this value can be equal mmin -- look at a description in ChangeSign())
- if( UInt<value_size>::operator>( mmin ) )
- return 1;
- if the value is equal mmin the method ChangeSign() does nothing (only returns 1 but we ignore it)
- ChangeSign();
- else
- Int<value_size> mmax;
- mmax.SetMax();
- if( UInt<value_size>::operator>( mmax ) )
- return 1;
- return 0;
-public:
- this method converts a string into its value
- it returns carry=1 if the value will be too big or an incorrect base 'b' is given
- string is ended with a non-digit value, for example:
- "-12" will be translated to -12
- as well as:
- "- 12foo" will be translated to -12 too
- existing first white characters will be ommited
- (between '-' and a first digit can be white characters too)
- after_source (if exists) is pointing at the end of the parsed string
- value_read (if exists) tells whether something has actually been read (at least one digit)
- uint FromString(const char * s, uint b = 10, const char ** after_source = 0, bool * value_read = 0)
- return FromStringBase(s, b, after_source, value_read);
- uint FromString(const wchar_t * s, uint b = 10, const wchar_t ** after_source = 0, bool * value_read = 0)
- uint FromString(const std::string & s, uint b = 10)
- return FromString( s.c_str(), b );
- this operator converts a string into its value (with base = 10)
- Int<value_size> & operator=(const char * s)
- FromString(s);
- return *this;
- uint FromString(const std::wstring & s, uint b = 10)
- Int<value_size> & operator=(const wchar_t * s)
- FromString(s);
- return *this;
- Int<value_size> & operator=(const std::wstring & s)
- return *this;
-#endif
- Int<value_size> & operator=(const std::string & s)
- return *this;
- bool operator==(const Int<value_size> & l) const
- return UInt<value_size>::operator==(l);
- bool operator!=(const Int<value_size> & l) const
- return UInt<value_size>::operator!=(l);
- bool operator<(const Int<value_size> & l) const
- sint i=value_size-1;
- sint a1 = sint(UInt<value_size>::table[i]);
- sint a2 = sint(l.table[i]);
- if( a1 != a2 )
- return a1 < a2;
- for(--i ; i>=0 ; --i)
- if( UInt<value_size>::table[i] != l.table[i] )
- // comparison as unsigned int
- return UInt<value_size>::table[i] < l.table[i];
- // they're equal
- return false;
- bool operator>(const Int<value_size> & l) const
- if( a1 != a2 )
- return a1 > a2;
- return UInt<value_size>::table[i] > l.table[i];
- // they're equal
- return false;
- bool operator<=(const Int<value_size> & l) const
- if( a1 != a2 )
- return a1 < a2;
- // they're equal
- return true;
- bool operator>=(const Int<value_size> & l) const
- if( a1 != a2 )
- return a1 > a2;
- // they're equal
- return true;
- it's not changing 'this' but the changed value will be returned
- Int<value_size> operator-() const
- return temp;
- Int<value_size> operator-(const Int<value_size> & p2) const
- temp.Sub(p2);
- return temp;
- Int<value_size> & operator-=(const Int<value_size> & p2)
- Sub(p2);
- return *this;
- Int<value_size> operator+(const Int<value_size> & p2) const
- temp.Add(p2);
- return temp;
- Int<value_size> & operator+=(const Int<value_size> & p2)
- Add(p2);
- return *this;
- Int<value_size> operator*(const Int<value_size> & p2) const
- temp.Mul(p2);
- return temp;
- Int<value_size> & operator*=(const Int<value_size> & p2)
- Mul(p2);
- return *this;
- Int<value_size> operator/(const Int<value_size> & p2) const
- temp.Div(p2);
- return temp;
- Int<value_size> & operator/=(const Int<value_size> & p2)
- Div(p2);
- return *this;
- Int<value_size> operator%(const Int<value_size> & p2) const
- Int<value_size> remainder;
- temp.Div(p2, remainder);
- return remainder;
- Int<value_size> & operator%=(const Int<value_size> & p2)
- Div(p2, remainder);
- operator=(remainder);
- return *this;
- Prefix operator e.g. ++variable
- UInt<value_size> & operator++()
- AddOne();
- return *this;
- Postfix operator e.g. variable++
- UInt<value_size> operator++(int)
- UInt<value_size> temp( *this );
- AddOne();
- return temp;
- UInt<value_size> & operator--()
- SubOne();
- return *this;
- UInt<value_size> operator--(int)
- SubOne();
- return temp;
-private:
- static ostream_type & OutputToStream(ostream_type & s, const Int<value_size> & l)
- string_type ss;
- l.ToString(ss);
- s << ss;
- return s;
-public:
- friend std::ostream & operator<<(std::ostream & s, const Int<value_size> & l)
- friend std::wostream & operator<<(std::wostream & s, const Int<value_size> & l)
-#endif
-private:
- static istream_type & InputFromStream(istream_type & s, Int<value_size> & l)
- string_type ss;
- char_type z;
- s >> z;
- ss += z;
- while( s.good() && Misc::CharToDigit(z, 10)>=0 )
- ss += z;
- z = static_cast<char_type>(s.get());
- // we're leaving the last readed character
- s.unget();
- l.FromString(ss);
- return s;
-public:
- friend std::istream & operator>>(std::istream & s, Int<value_size> & l)
- friend std::wistream & operator>>(std::wistream & s, Int<value_size> & l)
-#endif
-} // namespace
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmathmisc.h b/include/geos/algorithm/ttmath/ttmathmisc.h
index c9e1560..0000000
--- a/include/geos/algorithm/ttmath/ttmathmisc.h
+++ /dev/null
@@ -1,250 +0,0 @@
- * Copyright (c) 2006-2010, Tomasz Sowa
-#ifndef headerfilettmathmisc
-#define headerfilettmathmisc
- \file ttmathmisc.h
- \brief some helpful functions
-#include <string>
-namespace ttmath
- some helpful functions
-class Misc
-public:
- * AssignString(result, str)
- * result = str
- result = str
-static void AssignString(std::string & result, const char * str)
- result = str;
- result = str
-static void AssignString(std::wstring & result, const char * str)
- result.clear();
- for( ; *str ; ++str )
- result += *str;
- result = str
-static void AssignString(std::wstring & result, const std::string & str)
- return AssignString(result, str.c_str());
- result = str
-static void AssignString(std::string & result, const wchar_t * str)
- result.clear();
- result += static_cast<char>(*str);
- result = str
-static void AssignString(std::string & result, const std::wstring & str)
-#endif
- * AddString(result, str)
- * result += str
- result += str
-static void AddString(std::string & result, const char * str)
- result += str;
- result += str
-static void AddString(std::wstring & result, const char * str)
- result += *str;
-#endif
- this method omits any white characters from the string
- char_type is char or wchar_t
-template<class char_type>
-static void SkipWhiteCharacters(const char_type * & c)
- // 13 is at the end in a DOS text file (\r\n)
- while( (*c==' ' ) || (*c=='\t') || (*c==13 ) || (*c=='\n') )
- ++c;
- this static method converts one character into its value
- for example:
- - 1 -> 1
- - 8 -> 8
- - A -> 10
- - f -> 15
- this method don't check whether c is correct or not
-static uint CharToDigit(uint c)
- if(c>='0' && c<='9')
- return c-'0';
- if(c>='a' && c<='z')
- return c-'a'+10;
-return c-'A'+10;
- this method changes a character 'c' into its value
- (if there can't be a correct value it returns -1)
- for example:
- - c=2, base=10 -> function returns 2
- - c=A, base=10 -> function returns -1
- - c=A, base=16 -> function returns 10
-static sint CharToDigit(uint c, uint base)
- if( c>='0' && c<='9' )
- c=c-'0';
- else
- if( c>='a' && c<='z' )
- c=c-'a'+10;
- else
- if( c>='A' && c<='Z' )
- c=c-'A'+10;
- else
- return -1;
- if( c >= base )
- return -1;
-return sint(c);
- this method converts a digit into a char
- digit should be from <0,F>
- (we don't have to get a base)
- for example:
- - 1 -> 1
- - 8 -> 8
- - 10 -> A
- - 15 -> F
-static uint DigitToChar(uint digit)
- if( digit < 10 )
- return digit + '0';
-return digit - 10 + 'A';
-}; // struct Misc
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmathobjects.h b/include/geos/algorithm/ttmath/ttmathobjects.h
index 2902c9a..0000000
--- a/include/geos/algorithm/ttmath/ttmathobjects.h
+++ /dev/null
@@ -1,812 +0,0 @@
- * This file is a part of TTMath Mathematical Library
-#ifndef headerfilettmathobject
-#define headerfilettmathobject
- \file ttmathobjects.h
- \brief Mathematic functions.
-#include <string>
-#include <vector>
-#include <list>
-#include <map>
-#include "ttmathmisc.h"
-namespace ttmath
- objects of this class are used with the mathematical parser
- they hold variables or functions defined by a user
- each object has its own table in which we're keeping variables or functions
-class Objects
-public:
- one item (variable or function)
- 'items' will be on the table
- struct Item
- // name of a variable of a function
- // internally we store variables and funcions as std::string (not std::wstring even when wide characters are used)
- std::string value;
- // number of parameters required by the function
- // (if there's a variable this 'param' is ignored)
- int param;
- Item() { param = 0; }
- Item(const std::string & v, int p) : value(v), param(p) {}
- // 'Table' is the type of our table
- typedef std::map<std::string, Item> Table;
- typedef Table::iterator Iterator;
- typedef Table::const_iterator CIterator;
- this method returns true if a character 'c' is a character
- which can be in a name
- if 'can_be_digit' is true that means when the 'c' is a digit this
- method returns true otherwise it returns false
- static bool CorrectCharacter(int c, bool can_be_digit)
- if( (c>='a' && c<='z') || (c>='A' && c<='Z') )
- return true;
- if( can_be_digit && ((c>='0' && c<='9') || c=='_') )
- return true;
- return false;
- this method returns true if the name can be as a name of an object
- template<class string_type>
- static bool IsNameCorrect(const string_type & name)
- if( name.empty() )
- return false;
- if( !CorrectCharacter(name[0], false) )
- return false;
- typename string_type::const_iterator i = name.begin();
- for(++i ; i!=name.end() ; ++i)
- if( !CorrectCharacter(*i, true) )
- return false;
- return true;
- this method returns true if such an object is defined (name exists)
- bool IsDefined(const std::string & name)
- Iterator i = table.find(name);
- if( i != table.end() )
- // we have this object in our table
- return true;
- return false;
- bool IsDefined(const std::wstring & name)
- // we should check whether the name (in wide characters) are correct
- // before calling AssignString() function
- if( !IsNameCorrect(name) )
- return false;
- Misc::AssignString(str_tmp1, name);
- return IsDefined(str_tmp1);
-#endif
- this method adds one object (variable of function) into the table
- ErrorCode Add(const std::string & name, const std::string & value, int param = 0)
- return err_incorrect_name;
- return err_object_exists;
- table.insert( std::make_pair(name, Item(value, param)) );
- return err_ok;
- ErrorCode Add(const std::wstring & name, const std::wstring & value, int param = 0)
- Misc::AssignString(str_tmp2, value);
- return Add(str_tmp1, str_tmp2, param);
-#endif
- this method returns 'true' if the table is empty
- bool Empty() const
- return table.empty();
- this method clears the table
- void Clear()
- return table.clear();
- this method returns 'const_iterator' on the first item on the table
- CIterator Begin() const
- return table.begin();
- this method returns 'const_iterator' pointing at the space after last item
- (returns table.end())
- CIterator End() const
- return table.end();
- this method changes the value and the number of parameters for a specific object
- ErrorCode EditValue(const std::string & name, const std::string & value, int param = 0)
- if( i == table.end() )
- return err_unknown_object;
- i->second.value = value;
- i->second.param = param;
- return err_ok;
- ErrorCode EditValue(const std::wstring & name, const std::wstring & value, int param = 0)
- return EditValue(str_tmp1, str_tmp2, param);
-#endif
- this method changes the name of a specific object
- ErrorCode EditName(const std::string & old_name, const std::string & new_name)
- if( !IsNameCorrect(old_name) || !IsNameCorrect(new_name) )
- Iterator old_i = table.find(old_name);
- if( old_i == table.end() )
- if( old_name == new_name )
- // the new name is the same as the old one
- // we treat it as a normal situation
- return err_ok;
- ErrorCode err = Add(new_name, old_i->second.value, old_i->second.param);
- if( err == err_ok )
- old_i = table.find(old_name);
- TTMATH_ASSERT( old_i != table.end() )
- table.erase(old_i);
- return err;
- ErrorCode EditName(const std::wstring & old_name, const std::wstring & new_name)
- Misc::AssignString(str_tmp1, old_name);
- Misc::AssignString(str_tmp2, new_name);
- return EditName(str_tmp1, str_tmp2);
-#endif
- this method deletes an object
- ErrorCode Delete(const std::string & name)
- table.erase( i );
- return err_ok;
- ErrorCode Delete(const std::wstring & name)
- return Delete(str_tmp1);
-#endif
- this method gets the value of a specific object
- ErrorCode GetValue(const std::string & name, std::string & value) const
- CIterator i = table.find(name);
- value.clear();
- value = i->second.value;
- return err_ok;
- ErrorCode GetValue(const std::wstring & name, std::wstring & value)
- ErrorCode err = GetValue(str_tmp1, str_tmp2);
- Misc::AssignString(value, str_tmp2);
- return err;
-#endif
- (this version is used for not copying the whole string)
- ErrorCode GetValue(const std::string & name, const char ** value) const
- *value = 0;
- *value = i->second.value.c_str();
- return err_ok;
- ErrorCode GetValue(const std::wstring & name, const char ** value)
- return GetValue(str_tmp1, value);
-#endif
- this method gets the value and the number of parameters
- of a specific object
- ErrorCode GetValueAndParam(const std::string & name, std::string & value, int * param) const
- value.clear();
- *param = 0;
- *param = i->second.param;
- return err_ok;
- ErrorCode GetValueAndParam(const std::wstring & name, std::wstring & value, int * param)
- ErrorCode err = GetValueAndParam(str_tmp1, str_tmp2, param);
- return err;
-#endif
- this method sets the value and the number of parameters
- ErrorCode GetValueAndParam(const std::string & name, const char ** value, int * param) const
- *value = 0;
- *param = 0;
- return err_ok;
- but in fact we make one copying during AssignString())
- ErrorCode GetValueAndParam(const std::wstring & name, const char ** value, int * param)
- return GetValueAndParam(str_tmp1, value, param);
-#endif
- this method returns a pointer into the table
- Table * GetTable()
- return &table;
-private:
- Table table;
- std::string str_tmp1, str_tmp2;
-}; // end of class Objects
- objects of the class History are used to keep values in functions
- which take a lot of time during calculating, for instance in the
- function Factorial(x)
- it means that when we're calculating e.g. Factorial(1000) and the
- Factorial finds that we have calculated it before, the value (result)
- is taken from the history
-template<class ValueType>
-class History
- one item in the History's object holds a key, a value for the key
- and a corresponding error code
- struct Item
- ValueType key, value;
- ErrorCode err;
- we use std::list for simply deleting the first item
- but because we're searching through the whole container
- (in the method Get) the container should not be too big
- (linear time of searching)
- typedef std::list<Item> buffer_type;
- buffer_type buffer;
- typename buffer_type::size_type buffer_max_size;
-public:
- default constructor
- default max size of the History's container is 15 items
- History()
- buffer_max_size = 15;
- a constructor which takes another value of the max size
- of the History's container
- History(typename buffer_type::size_type new_size)
- buffer_max_size = new_size;
- this method adds one item into the History
- if the size of the container is greater than buffer_max_size
- the first item will be removed
- void Add(const ValueType & key, const ValueType & value, ErrorCode err)
- Item item;
- item.key = key;
- item.value = value;
- item.err = err;
- buffer.insert( buffer.end(), item );
- if( buffer.size() > buffer_max_size )
- buffer.erase(buffer.begin());
- this method checks whether we have an item which has the key equal 'key'
- if there's such item the method sets the 'value' and the 'err'
- and returns true otherwise it returns false and 'value' and 'err'
- remain unchanged
- bool Get(const ValueType & key, ValueType & value, ErrorCode & err)
- typename buffer_type::iterator i = buffer.begin();
- for( ; i != buffer.end() ; ++i )
- if( i->key == key )
- value = i->value;
- err = i->err;
- return true;
- return false;
- this methods deletes an item
- we assume that there is only one item with the 'key'
- (this methods removes the first one)
- bool Remove(const ValueType & key)
- buffer.erase(i);
- return true;
- return false;
-}; // end of class History
- this is an auxiliary class used when calculating Gamma() or Factorial()
- in multithreaded environment you can provide an object of this class to
- the Gamma() or Factorial() function, e.g;
- typedef Big<1, 3> MyBig;
- MyBig x = 123456;
- CGamma<MyBig> cgamma;
- std::cout << Gamma(x, cgamma);
- each thread should have its own CGamma<> object
- in a single-thread environment a CGamma<> object is a static variable
- and you don't have to explicitly use it, e.g.
- MyBig x = 123456;
- std::cout << Gamma(x);
-struct CGamma
- this table holds factorials
- 1
- 1
- 2
- 6
- 24
- 120
- 720
- std::vector<ValueType> fact;
- this table holds Bernoulli numbers
- 1
- -0.5
- 0.166666666666666666666666667
- 0
- -0.0333333333333333333333333333
- 0
- 0.0238095238095238095238095238
- 0
- 0
- 0.075757575757575757575757576
- std::vector<ValueType> bern;
- here we store some calculated values
- (this is for speeding up, if the next argument of Gamma() or Factorial()
- is in the 'history' then the result we are not calculating but simply
- return from the 'history' object)
- History<ValueType> history;
- this method prepares some coefficients: factorials and Bernoulli numbers
- stored in 'fact' and 'bern' objects
- how many values should be depends on the size of the mantissa - if
- the mantissa is larger then we must calculate more values
- for a mantissa which consists of 256 bits (8 words on a 32bit platform)
- we have to calculate about 30 values (the size of fact and bern will be 30),
- and for a 2048 bits mantissa we have to calculate 306 coefficients
- you don't have to call this method, these coefficients will be automatically calculated
- when they are needed
- you must note that calculating these coefficients is a little time-consuming operation,
- (especially when the mantissa is large) and first call to Gamma() or Factorial()
- can take more time than next calls, and in the end this is the point when InitAll()
- comes in handy: you can call this method somewhere at the beginning of your program
- void InitAll();
- // definition is in ttmath.h
-} // namespace
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmathparser.h b/include/geos/algorithm/ttmath/ttmathparser.h
index d9b7ce7..0000000
--- a/include/geos/algorithm/ttmath/ttmathparser.h
+++ /dev/null
@@ -1,2777 +0,0 @@
-#ifndef headerfilettmathparser
-#define headerfilettmathparser
- \file ttmathparser.h
- \brief A mathematical parser
-#include <cstdio>
-#include <vector>
-#include <map>
-#include <set>
-#include "ttmath.h"
-#include "ttmathobjects.h"
-namespace ttmath
- \brief Mathematical parser
- let x will be an input string meaning an expression for converting:
- x = [+|-]Value[operator[+|-]Value][operator[+|-]Value]...
- where:
- an operator can be:
- ^ (pow) (the heighest priority)
- * (mul) (or multiplication without an operator -- short mul)
- / (div) (* and / have the same priority)
- + (add)
- - (sub) (+ and - have the same priority)
- < (lower than)
- > (greater than)
- <= (lower or equal than)
- >= (greater or equal than)
- == (equal)
- != (not equal) (all above logical operators have the same priority)
- && (logical and)
- || (logical or) (the lowest priority)
- short mul:
- if the second Value (Var below) is either a variable or function there might not be
- an operator between them, e.g.
- "[+|-]Value Var" is treated as "[+|-]Value * Var" and the multiplication
- has the same priority as a normal multiplication:
- 4x = 4 * x
- 2^3m = (2^3)* m
- 6h^3 = 6 * (h^3)
- 2sin(pi) = 2 * sin(pi)
- etc.
- Value can be:
- constant e.g. 100, can be preceded by operators for changing the base (radix): [#|&]
- # - hex
- & - bin
- sample: #10 = 16
- &10 = 2
- variable e.g. pi
- another expression between brackets e.g (x)
- function e.g. sin(x)
- for example a correct input string can be:
- "1"
- "2.1234"
- "2,1234" (they are the same, by default we can either use a comma or a dot)
- "1 + 2"
- "(1 + 2) * 3"
- "pi"
- "sin(pi)"
- "(1+2)*(2+3)"
- "log(2;1234)" there's a semicolon here (not a comma), we use it in functions
- for separating parameters
- "1 < 2" (the result will be: 1)
- "4 < 3" (the result will be: 0)
- "2+x" (of course if the variable 'x' is defined)
- "4x+10"
- "#20+10" = 32 + 10 = 42
- "10 ^ -&101" = 10 ^ -5 = 0.00001
- "8 * -&10" = 8 * -2 = -16
- etc.
- we can also use a semicolon for separating any 'x' input strings
- for example:
- "1+2;4+5"
- the result will be on the stack as follows:
- stack[0].value=3
- stack[1].value=9
-class Parser
-private:
- there are 5 mathematical operators as follows (with their standard priorities):
- add (+)
- sub (-)
- mul (*)
- div (/)
- pow (^)
- and 'shortmul' used when there is no any operators between
- a first parameter and a variable or function
- (the 'shortmul' has the same priority as the normal multiplication )
- class MatOperator
- public:
- enum Type
- none,add,sub,mul,div,pow,lt,gt,let,get,eq,neq,lor,land,shortmul
- enum Assoc
- right, // right-associative
- non_right // associative or left-associative
- Type GetType() const { return type; }
- int GetPriority() const { return priority; }
- Assoc GetAssoc() const { return assoc; }
- void SetType(Type t)
- type = t;
- assoc = non_right;
- switch( type )
- case lor:
- priority = 4;
- break;
- case land:
- priority = 5;
- break;
- case eq:
- case neq:
- case lt:
- case gt:
- case let:
- case get:
- priority = 7;
- break;
- case add:
- case sub:
- priority = 10;
- break;
- case mul:
- case shortmul:
- case div:
- priority = 12;
- break;
- case pow:
- priority = 14;
- assoc = right;
- break;
- default:
- Error( err_internal_error );
- break;
- MatOperator(): type(none), priority(0), assoc(non_right)
- private:
- Type type;
- int priority;
- Assoc assoc;
- }; // end of MatOperator class
-public:
- Objects of type 'Item' we are keeping on our stack
- struct Item
- enum Type
- none, numerical_value, mat_operator, first_bracket,
- last_bracket, variable, semicolon
- // The kind of type which we're keeping
- Type type;
- // if type == numerical_value
- ValueType value;
- // if type == mat_operator
- MatOperator moperator;
- if type == first_bracket
- if 'function' is set to true it means that the first recognized bracket
- was the bracket from function in other words we must call a function when
- we'll find the 'last' bracket
- bool function;
- // if function is true
- std::string function_name;
- the sign of value
- it can be for type==numerical_value or type==first_bracket
- when it's true it means e.g. that value is equal -value
- bool sign;
- Item(): type(none), function(false), sign(false)
- }; // end of Item struct
- stack on which we're keeping the Items
- at the end of parsing we'll have the result here
- the result don't have to be one value, it can be
- more than one if we have used a semicolon in the global space
- e.g. such input string "1+2;3+4" will generate a result:
- stack[0].value=3
- stack[1].value=7
- you should check if the stack is not empty, because if there was
- a syntax error in the input string then we do not have any results
- on the stack
-std::vector<Item> stack;
-private:
- size of the stack when we're starting parsing of the string
- if it's to small while parsing the stack will be automatically resized
-const int default_stack_size;
- index of an object in our stack
- it's pointing on the place behind the last element
- for example at the beginning of parsing its value is zero
-unsigned int stack_index;
- code of the last error
-ErrorCode error;
- pointer to the currently reading char
- when an error has occured it may be used to count the index of the wrong character
-const char * pstring;
- the base (radix) of the mathematic system (for example it may be '10')
-int base;
- the unit of angles used in: sin,cos,tan,cot,asin,acos,atan,acot
- 0 - deg
- 1 - rad (default)
- 2 - grad
-int deg_rad_grad;
- a pointer to an object which tell us whether we should stop calculating or not
-const volatile StopCalculating * pstop_calculating;
- a pointer to the user-defined variables' table
-const Objects * puser_variables;
- a pointer to the user-defined functions' table
-const Objects * puser_functions;
-typedef std::map<std::string, ValueType> FunctionLocalVariables;
- a pointer to the local variables of a function
-const FunctionLocalVariables * pfunction_local_variables;
- a temporary set using during parsing user defined variables
-std::set<std::string> visited_variables;
- a temporary set using during parsing user defined functions
-std::set<std::string> visited_functions;
- pfunction is the type of pointer to a mathematic function
- these mathematic functions are private members of this class,
- they are the wrappers for standard mathematics function
- 'pstack' is the pointer to the first argument on our stack
- 'amount_of_arg' tell us how many argument there are in our stack
- 'result' is the reference for result of function
-typedef void (Parser<ValueType>::*pfunction)(int pstack, int amount_of_arg, ValueType & result);
- pfunction is the type of pointer to a method which returns value of variable
-typedef void (ValueType::*pfunction_var)();
- table of mathematic functions
- this map consists of:
- std::string - function's name
- pfunction - pointer to specific function
-typedef std::map<std::string, pfunction> FunctionsTable;
-FunctionsTable functions_table;
- table of mathematic operators
- std::string - operators's name
- MatOperator::Type - type of the operator
-typedef std::map<std::string, typename MatOperator::Type> OperatorsTable;
-OperatorsTable operators_table;
- table of mathematic variables
- std::string - variable's name
- pfunction_var - pointer to specific function which returns value of variable
-typedef std::map<std::string, pfunction_var> VariablesTable;
-VariablesTable variables_table;
- some coefficients used when calculating the gamma (or factorial) function
-CGamma<ValueType> cgamma;
- temporary object for a whole string when Parse(std::wstring) is used
-std::string wide_to_ansi;
- group character (used when parsing)
- default zero (not used)
-int group;
- characters used as a comma
- default: '.' and ','
- comma2 can be zero (it means it is not used)
-int comma, comma2;
- an additional character used as a separator between function parameters
- (semicolon is used always)
-int param_sep;
- true if something was calculated (at least one mathematical operator was used or a function or a variable)
-bool calculated;
- we're using this method for reporting an error
-static void Error(ErrorCode code)
- throw code;
- this method skips the white character from the string
- it's moving the 'pstring' to the first no-white character
-void SkipWhiteCharacters()
- while( (*pstring==' ' ) || (*pstring=='\t') )
- ++pstring;
- an auxiliary method for RecurrenceParsingVariablesOrFunction(...)
-void RecurrenceParsingVariablesOrFunction_CheckStopCondition(bool variable, const std::string & name)
- if( variable )
- if( visited_variables.find(name) != visited_variables.end() )
- Error( err_variable_loop );
- else
- if( visited_functions.find(name) != visited_functions.end() )
- Error( err_functions_loop );
-void RecurrenceParsingVariablesOrFunction_AddName(bool variable, const std::string & name)
- if( variable )
- visited_variables.insert( name );
- else
- visited_functions.insert( name );
-void RecurrenceParsingVariablesOrFunction_DeleteName(bool variable, const std::string & name)
- if( variable )
- visited_variables.erase( name );
- else
- visited_functions.erase( name );
- this method returns the value of a variable or function
- by creating a new instance of the mathematical parser
- and making the standard parsing algorithm on the given string
- this method is used only during parsing user defined variables or functions
- (there can be a recurrence here therefore we're using 'visited_variables'
- and 'visited_functions' sets to make a stop condition)
-ValueType RecurrenceParsingVariablesOrFunction(bool variable, const std::string & name, const char * new_string,
- FunctionLocalVariables * local_variables = 0)
- RecurrenceParsingVariablesOrFunction_CheckStopCondition(variable, name);
- RecurrenceParsingVariablesOrFunction_AddName(variable, name);
- Parser<ValueType> NewParser(*this);
- ErrorCode err;
- NewParser.pfunction_local_variables = local_variables;
- try
- err = NewParser.Parse(new_string);
- catch(...)
- RecurrenceParsingVariablesOrFunction_DeleteName(variable, name);
- throw;
- if( err != err_ok )
- Error( err );
- if( NewParser.stack.size() != 1 )
- Error( err_must_be_only_one_value );
- if( NewParser.stack[0].type != Item::numerical_value )
- // I think there shouldn't be this error here
- Error( err_incorrect_value );
-return NewParser.stack[0].value;
-public:
- this method returns the user-defined value of a variable
-bool GetValueOfUserDefinedVariable(const std::string & variable_name,ValueType & result)
- if( !puser_variables )
- return false;
- const char * string_value;
- if( puser_variables->GetValue(variable_name, &string_value) != err_ok )
- return false;
- result = RecurrenceParsingVariablesOrFunction(true, variable_name, string_value);
- calculated = true;
-return true;
- this method returns the value of a local variable of a function
-bool GetValueOfFunctionLocalVariable(const std::string & variable_name, ValueType & result)
- if( !pfunction_local_variables )
- return false;
- typename FunctionLocalVariables::const_iterator i = pfunction_local_variables->find(variable_name);
- if( i == pfunction_local_variables->end() )
- return false;
- result = i->second;
-return true;
- this method returns the value of a variable from variables' table
- we make an object of type ValueType then call a method which
- sets the correct value in it and finally we'll return the object
-ValueType GetValueOfVariable(const std::string & variable_name)
-ValueType result;
- if( GetValueOfFunctionLocalVariable(variable_name, result) )
- return result;
- if( GetValueOfUserDefinedVariable(variable_name, result) )
- return result;
- typename std::map<std::string, pfunction_var>::iterator i =
- variables_table.find(variable_name);
- if( i == variables_table.end() )
- Error( err_unknown_variable );
- (result.*(i->second))();
-return result;
-private:
- wrappers for mathematic functions
- 'sindex' is pointing on the first argument on our stack
- (the second argument has 'sindex+2'
- because 'sindex+1' is guaranted for the 'semicolon' operator)
- the third artument has of course 'sindex+4' etc.
- 'result' will be the result of the function
- (we're using exceptions here for example when function gets an improper argument)
- used by: sin,cos,tan,cot
-ValueType ConvertAngleToRad(const ValueType & input)
- if( deg_rad_grad == 1 ) // rad
- return input;
- ValueType result;
- ErrorCode err;
- if( deg_rad_grad == 0 ) // deg
- result = ttmath::DegToRad(input, &err);
- else // grad
- result = ttmath::GradToRad(input, &err);
- Error( err );
-return result;
- used by: asin,acos,atan,acot
-ValueType ConvertRadToAngle(const ValueType & input)
- return input;
- ValueType result;
- ErrorCode err;
- result = ttmath::RadToDeg(input, &err);
- else // grad
- result = ttmath::RadToGrad(input, &err);
- Error( err );
-return result;
-void Gamma(int sindex, int amount_of_args, ValueType & result)
- if( amount_of_args != 1 )
- Error( err_improper_amount_of_arguments );
- ErrorCode err;
- result = ttmath::Gamma(stack[sindex].value, cgamma, &err, pstop_calculating);
- if(err != err_ok)
- Error( err );
- factorial
- result = 1 * 2 * 3 * 4 * .... * x
-void Factorial(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Factorial(stack[sindex].value, cgamma, &err, pstop_calculating);
- if(err != err_ok)
- Error( err );
-void Abs(int sindex, int amount_of_args, ValueType & result)
- result = ttmath::Abs(stack[sindex].value);
-void Sin(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Sin( ConvertAngleToRad(stack[sindex].value), &err );
- if(err != err_ok)
- Error( err );
-void Cos(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Cos( ConvertAngleToRad(stack[sindex].value), &err );
- if(err != err_ok)
- Error( err );
-void Tan(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Tan(ConvertAngleToRad(stack[sindex].value), &err);
- if(err != err_ok)
- Error( err );
-void Cot(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Cot(ConvertAngleToRad(stack[sindex].value), &err);
- if(err != err_ok)
- Error( err );
-void Int(int sindex, int amount_of_args, ValueType & result)
- result = ttmath::SkipFraction(stack[sindex].value);
-void Round(int sindex, int amount_of_args, ValueType & result)
- result = stack[sindex].value;
- if( result.Round() )
- Error( err_overflow );
-void Ln(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Ln(stack[sindex].value, &err);
- if(err != err_ok)
- Error( err );
-void Log(int sindex, int amount_of_args, ValueType & result)
- if( amount_of_args != 2 )
- ErrorCode err;
- result = ttmath::Log(stack[sindex].value, stack[sindex+2].value, &err);
- if(err != err_ok)
- Error( err );
-void Exp(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Exp(stack[sindex].value, &err);
- if(err != err_ok)
- Error( err );
-void Max(int sindex, int amount_of_args, ValueType & result)
- if( amount_of_args == 0 )
- result.SetMax();
- return;
- for(int i=1 ; i<amount_of_args ; ++i)
- if( result < stack[sindex + i*2].value )
- result = stack[sindex + i*2].value;
-void Min(int sindex, int amount_of_args, ValueType & result)
- result.SetMin();
- return;
- if( result > stack[sindex + i*2].value )
-void ASin(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- ValueType temp = ttmath::ASin(stack[sindex].value, &err);
- if(err != err_ok)
- Error( err );
- result = ConvertRadToAngle(temp);
-void ACos(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- ValueType temp = ttmath::ACos(stack[sindex].value, &err);
- if(err != err_ok)
- Error( err );
-void ATan(int sindex, int amount_of_args, ValueType & result)
- result = ConvertRadToAngle(ttmath::ATan(stack[sindex].value));
-void ACot(int sindex, int amount_of_args, ValueType & result)
- result = ConvertRadToAngle(ttmath::ACot(stack[sindex].value));
-void Sgn(int sindex, int amount_of_args, ValueType & result)
- result = ttmath::Sgn(stack[sindex].value);
-void Mod(int sindex, int amount_of_args, ValueType & result)
- if( stack[sindex+2].value.IsZero() )
- Error( err_improper_argument );
- uint c = result.Mod(stack[sindex+2].value);
- if( c )
-void If(int sindex, int amount_of_args, ValueType & result)
- if( amount_of_args != 3 )
- if( !stack[sindex].value.IsZero() )
- result = stack[sindex+2].value;
- else
- result = stack[sindex+4].value;
-void Or(int sindex, int amount_of_args, ValueType & result)
- if( amount_of_args < 2 )
- for(int i=0 ; i<amount_of_args ; ++i)
- if( !stack[sindex+i*2].value.IsZero() )
- result.SetOne();
- return;
- result.SetZero();
-void And(int sindex, int amount_of_args, ValueType & result)
- if( stack[sindex+i*2].value.IsZero() )
- result.SetZero();
- return;
- result.SetOne();
-void Not(int sindex, int amount_of_args, ValueType & result)
- if( stack[sindex].value.IsZero() )
- result.SetOne();
- else
- result.SetZero();
-void DegToRad(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err = err_ok;
- if( amount_of_args == 1 )
- result = ttmath::DegToRad(stack[sindex].value, &err);
- else
- if( amount_of_args == 3 )
- result = ttmath::DegToRad( stack[sindex].value, stack[sindex+2].value,
- stack[sindex+4].value, &err);
- else
- Error( err );
-void RadToDeg(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::RadToDeg(stack[sindex].value, &err);
- Error( err );
-void DegToDeg(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::DegToDeg( stack[sindex].value, stack[sindex+2].value,
- Error( err );
-void GradToRad(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::GradToRad(stack[sindex].value, &err);
- Error( err );
-void RadToGrad(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::RadToGrad(stack[sindex].value, &err);
- Error( err );
-void DegToGrad(int sindex, int amount_of_args, ValueType & result)
- result = ttmath::DegToGrad(stack[sindex].value, &err);
- else
- result = ttmath::DegToGrad( stack[sindex].value, stack[sindex+2].value,
- else
- Error( err );
-void GradToDeg(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::GradToDeg(stack[sindex].value, &err);
- Error( err );
-void Ceil(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Ceil(stack[sindex].value, &err);
- Error( err );
-void Floor(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Floor(stack[sindex].value, &err);
- Error( err );
-void Sqrt(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Sqrt(stack[sindex].value, &err);
- Error( err );
-void Sinh(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Sinh(stack[sindex].value, &err);
- Error( err );
-void Cosh(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Cosh(stack[sindex].value, &err);
- Error( err );
-void Tanh(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Tanh(stack[sindex].value, &err);
- Error( err );
-void Coth(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Coth(stack[sindex].value, &err);
- Error( err );
-void Root(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::Root(stack[sindex].value, stack[sindex+2].value, &err);
- Error( err );
-void ASinh(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::ASinh(stack[sindex].value, &err);
- Error( err );
-void ACosh(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::ACosh(stack[sindex].value, &err);
- Error( err );
-void ATanh(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::ATanh(stack[sindex].value, &err);
- Error( err );
-void ACoth(int sindex, int amount_of_args, ValueType & result)
- ErrorCode err;
- result = ttmath::ACoth(stack[sindex].value, &err);
- Error( err );
-void BitAnd(int sindex, int amount_of_args, ValueType & result)
- uint err;
- err = result.BitAnd(stack[sindex+2].value);
- switch(err)
- case 1:
- break;
- case 2:
- break;
-void BitOr(int sindex, int amount_of_args, ValueType & result)
- uint err;
- err = result.BitOr(stack[sindex+2].value);
- switch(err)
- case 1:
- break;
- case 2:
- break;
-void BitXor(int sindex, int amount_of_args, ValueType & result)
- uint err;
- err = result.BitXor(stack[sindex+2].value);
- switch(err)
- case 1:
- break;
- case 2:
- break;
-void Sum(int sindex, int amount_of_args, ValueType & result)
- for(int i=1 ; i<amount_of_args ; ++i )
- if( result.Add( stack[ sindex + i*2 ].value ) )
-void Avg(int sindex, int amount_of_args, ValueType & result)
- if( result.Div( amount_of_args ) )
-void Frac(int sindex, int amount_of_args, ValueType & result)
- result.RemainFraction();
- we use such a method because 'wvsprintf' is not everywhere defined
-void Sprintf(char * buffer, int par)
-char buf[30]; // char, not wchar_t
-int i;
- #ifdef _MSC_VER
- #pragma warning( disable: 4996 )
- //warning C4996: 'sprintf': This function or variable may be unsafe.
- #endif
- sprintf(buf, "%d", par);
- for(i=0 ; buf[i] != 0 ; ++i)
- buffer[i] = buf[i];
- buffer[i] = 0;
- #ifdef _MSC_VER
- #pragma warning( default: 4996 )
- #endif
- this method returns the value from a user-defined function
- (look at the description in 'CallFunction(...)')
-bool GetValueOfUserDefinedFunction(const std::string & function_name, int amount_of_args, int sindex)
- if( !puser_functions )
- return false;
- int param;
- if( puser_functions->GetValueAndParam(function_name, &string_value, ¶m) != err_ok )
- return false;
- if( param != amount_of_args )
- FunctionLocalVariables local_variables;
- if( amount_of_args > 0 )
- char buffer[30];
- // x = x1
- buffer[0] = 'x';
- buffer[1] = 0;
- local_variables.insert( std::make_pair(buffer, stack[sindex].value) );
- buffer[0] = 'x';
- Sprintf(buffer+1, i+1);
- local_variables.insert( std::make_pair(buffer, stack[sindex + i*2].value) );
- stack[sindex-1].value = RecurrenceParsingVariablesOrFunction(false, function_name, string_value, &local_variables);
-return true;
- we're calling a specific function
- function_name - name of the function
- amount_of_args - how many arguments there are on our stack
- (function must check whether this is a correct value or not)
- sindex - index of the first argument on the stack (sindex is greater than zero)
- if there aren't any arguments on the stack 'sindex' pointing on
- a non existend element (after the first bracket)
- result will be stored in 'stack[sindex-1].value'
- (we don't have to set the correct type of this element, it'll be set later)
-void CallFunction(const std::string & function_name, int amount_of_args, int sindex)
- if( GetValueOfUserDefinedFunction(function_name, amount_of_args, sindex) )
- return;
- typename FunctionsTable::iterator i = functions_table.find( function_name );
- if( i == functions_table.end() )
- Error( err_unknown_function );
- calling the specify function
- (this->*(i->second))(sindex, amount_of_args, stack[sindex-1].value);
- inserting a function to the functions' table
- pf - pointer to the function (to the wrapper)
-void InsertFunctionToTable(const char * function_name, pfunction pf)
- std::string str;
- Misc::AssignString(str, function_name);
- functions_table.insert( std::make_pair(str, pf) );
- inserting a function to the variables' table
- (this function returns value of variable)
- variable_name - name of the function
-void InsertVariableToTable(const char * variable_name, pfunction_var pf)
- std::string str;
- Misc::AssignString(str, variable_name);
- variables_table.insert( std::make_pair(str, pf) );
- this method creates the table of functions
-void CreateFunctionsTable()
- InsertFunctionToTable("gamma", &Parser<ValueType>::Gamma);
- InsertFunctionToTable("factorial", &Parser<ValueType>::Factorial);
- InsertFunctionToTable("abs", &Parser<ValueType>::Abs);
- InsertFunctionToTable("sin", &Parser<ValueType>::Sin);
- InsertFunctionToTable("cos", &Parser<ValueType>::Cos);
- InsertFunctionToTable("tan", &Parser<ValueType>::Tan);
- InsertFunctionToTable("tg", &Parser<ValueType>::Tan);
- InsertFunctionToTable("cot", &Parser<ValueType>::Cot);
- InsertFunctionToTable("ctg", &Parser<ValueType>::Cot);
- InsertFunctionToTable("int", &Parser<ValueType>::Int);
- InsertFunctionToTable("round", &Parser<ValueType>::Round);
- InsertFunctionToTable("ln", &Parser<ValueType>::Ln);
- InsertFunctionToTable("log", &Parser<ValueType>::Log);
- InsertFunctionToTable("exp", &Parser<ValueType>::Exp);
- InsertFunctionToTable("max", &Parser<ValueType>::Max);
- InsertFunctionToTable("min", &Parser<ValueType>::Min);
- InsertFunctionToTable("asin", &Parser<ValueType>::ASin);
- InsertFunctionToTable("acos", &Parser<ValueType>::ACos);
- InsertFunctionToTable("atan", &Parser<ValueType>::ATan);
- InsertFunctionToTable("atg", &Parser<ValueType>::ATan);
- InsertFunctionToTable("acot", &Parser<ValueType>::ACot);
- InsertFunctionToTable("actg", &Parser<ValueType>::ACot);
- InsertFunctionToTable("sgn", &Parser<ValueType>::Sgn);
- InsertFunctionToTable("mod", &Parser<ValueType>::Mod);
- InsertFunctionToTable("if", &Parser<ValueType>::If);
- InsertFunctionToTable("or", &Parser<ValueType>::Or);
- InsertFunctionToTable("and", &Parser<ValueType>::And);
- InsertFunctionToTable("not", &Parser<ValueType>::Not);
- InsertFunctionToTable("degtorad", &Parser<ValueType>::DegToRad);
- InsertFunctionToTable("radtodeg", &Parser<ValueType>::RadToDeg);
- InsertFunctionToTable("degtodeg", &Parser<ValueType>::DegToDeg);
- InsertFunctionToTable("gradtorad", &Parser<ValueType>::GradToRad);
- InsertFunctionToTable("radtograd", &Parser<ValueType>::RadToGrad);
- InsertFunctionToTable("degtograd", &Parser<ValueType>::DegToGrad);
- InsertFunctionToTable("gradtodeg", &Parser<ValueType>::GradToDeg);
- InsertFunctionToTable("ceil", &Parser<ValueType>::Ceil);
- InsertFunctionToTable("floor", &Parser<ValueType>::Floor);
- InsertFunctionToTable("sqrt", &Parser<ValueType>::Sqrt);
- InsertFunctionToTable("sinh", &Parser<ValueType>::Sinh);
- InsertFunctionToTable("cosh", &Parser<ValueType>::Cosh);
- InsertFunctionToTable("tanh", &Parser<ValueType>::Tanh);
- InsertFunctionToTable("tgh", &Parser<ValueType>::Tanh);
- InsertFunctionToTable("coth", &Parser<ValueType>::Coth);
- InsertFunctionToTable("ctgh", &Parser<ValueType>::Coth);
- InsertFunctionToTable("root", &Parser<ValueType>::Root);
- InsertFunctionToTable("asinh", &Parser<ValueType>::ASinh);
- InsertFunctionToTable("acosh", &Parser<ValueType>::ACosh);
- InsertFunctionToTable("atanh", &Parser<ValueType>::ATanh);
- InsertFunctionToTable("atgh", &Parser<ValueType>::ATanh);
- InsertFunctionToTable("acoth", &Parser<ValueType>::ACoth);
- InsertFunctionToTable("actgh", &Parser<ValueType>::ACoth);
- InsertFunctionToTable("bitand", &Parser<ValueType>::BitAnd);
- InsertFunctionToTable("bitor", &Parser<ValueType>::BitOr);
- InsertFunctionToTable("bitxor", &Parser<ValueType>::BitXor);
- InsertFunctionToTable("band", &Parser<ValueType>::BitAnd);
- InsertFunctionToTable("bor", &Parser<ValueType>::BitOr);
- InsertFunctionToTable("bxor", &Parser<ValueType>::BitXor);
- InsertFunctionToTable("sum", &Parser<ValueType>::Sum);
- InsertFunctionToTable("avg", &Parser<ValueType>::Avg);
- InsertFunctionToTable("frac", &Parser<ValueType>::Frac);
- this method creates the table of variables
-void CreateVariablesTable()
- InsertVariableToTable("pi", &ValueType::SetPi);
- InsertVariableToTable("e", &ValueType::SetE);
- converting from a big letter to a small one
-int ToLowerCase(int c)
- return c - 'A' + 'a';
-return c;
- this method read the name of a variable or a function
- 'result' will be the name of a variable or a function
- function return 'false' if this name is the name of a variable
- or function return 'true' if this name is the name of a function
- what should be returned is tested just by a '(' character that means if there's
- a '(' character after a name that function returns 'true'
-bool ReadName(std::string & result)
-int character;
- result.erase();
- character = *pstring;
- the first letter must be from range 'a' - 'z' or 'A' - 'Z'
- if( ! (( character>='a' && character<='z' ) || ( character>='A' && character<='Z' )) )
- Error( err_unknown_character );
- do
- result += static_cast<char>( character );
- character = * ++pstring;
- while( (character>='a' && character<='z') ||
- (character>='A' && character<='Z') ||
- (character>='0' && character<='9') ||
- character=='_' );
- SkipWhiteCharacters();
- if there's a character '(' that means this name is a name of a function
- if( *pstring == '(' )
- ++pstring;
- return true;
-return false;
- we're checking whether the first character is '-' or '+'
- if it is we'll return 'true' and if it is equally '-' we'll set the 'sign' member of 'result'
-bool TestSign(Item & result)
- result.sign = false;
- if( *pstring == '-' || *pstring == '+' )
- if( *pstring == '-' )
- result.sign = true;
- ++pstring;
- return true;
-return false;
- we're reading the name of a variable or a function
- if is there a function we'll return 'true'
-bool ReadVariableOrFunction(Item & result)
-std::string name;
-bool is_it_name_of_function = ReadName(name);
- if( is_it_name_of_function )
- we've read the name of a function
- result.function_name = name;
- result.type = Item::first_bracket;
- result.function = true;
- else
- we've read the name of a variable and we're getting its value now
- result.value = GetValueOfVariable( name );
-return is_it_name_of_function;
- we're reading a numerical value directly from the string
-void ReadValue(Item & result, int reading_base)
-const char * new_stack_pointer;
-bool value_read;
-Conv conv;
- conv.base = reading_base;
- conv.comma = comma;
- conv.comma2 = comma2;
- conv.group = group;
- uint carry = result.value.FromString(pstring, conv, &new_stack_pointer, &value_read);
- pstring = new_stack_pointer;
- if( carry )
- if( !value_read )
- this method returns true if 'character' is a proper first digit for the value (or a comma -- can be first too)
-bool ValueStarts(int character, int character_base)
- if( character == comma )
- return true;
- if( comma2!=0 && character==comma2 )
- return true;
- if( Misc::CharToDigit(character, character_base) != -1 )
- return true;
-return false;
- we're reading the item
- return values:
- 0 - all ok, the item is successfully read
- 1 - the end of the string (the item is not read)
- 2 - the final bracket ')'
-int ReadValueVariableOrFunction(Item & result)
-bool it_was_sign = false;
-int character;
- if( TestSign(result) )
- // 'result.sign' was set as well
- it_was_sign = true;
- character = ToLowerCase( *pstring );
- if( character == 0 )
- if( it_was_sign )
- // at the end of the string a character like '-' or '+' has left
- Error( err_unexpected_end );
- // there's the end of the string here
- return 1;
- else
- if( character == '(' )
- // we've got a normal bracket (not a function)
- result.function = false;
- ++pstring;
- return 0;
- else
- if( character == ')' )
- // we've got a final bracket
- // (in this place we can find a final bracket only when there are empty brackets
- // without any values inside or with a sign '-' or '+' inside)
- if( it_was_sign )
- Error( err_unexpected_final_bracket );
- result.type = Item::last_bracket;
- // we don't increment 'pstring', this final bracket will be read next by the
- // 'ReadOperatorAndCheckFinalBracket(...)' method
- return 2;
- else
- if( character == '#' )
- ++pstring;
- // after '#' character we do not allow '-' or '+' (can be white characters)
- if( ValueStarts(*pstring, 16) )
- ReadValue( result, 16 );
- else
- else
- if( character == '&' )
- ++pstring;
- // after '&' character we do not allow '-' or '+' (can be white characters)
- if( ValueStarts(*pstring, 2) )
- ReadValue( result, 2 );
- else
- else
- if( ValueStarts(character, base) )
- ReadValue( result, base );
- else
- if( character>='a' && character<='z' )
- if( ReadVariableOrFunction(result) )
- // we've read the name of a function
- return 0;
- else
- we've got a value in the 'result'
- this value is from a variable or directly from the string
- result.type = Item::numerical_value;
- if( result.sign )
- result.value.ChangeSign();
-return 0;
-void InsertOperatorToTable(const char * name, typename MatOperator::Type type)
- operators_table.insert( std::make_pair(std::string(name), type) );
- this method creates the table of operators
-void CreateMathematicalOperatorsTable()
- InsertOperatorToTable("||", MatOperator::lor);
- InsertOperatorToTable("&&", MatOperator::land);
- InsertOperatorToTable("!=", MatOperator::neq);
- InsertOperatorToTable("==", MatOperator::eq);
- InsertOperatorToTable(">=", MatOperator::get);
- InsertOperatorToTable("<=", MatOperator::let);
- InsertOperatorToTable(">", MatOperator::gt);
- InsertOperatorToTable("<", MatOperator::lt);
- InsertOperatorToTable("-", MatOperator::sub);
- InsertOperatorToTable("+", MatOperator::add);
- InsertOperatorToTable("/", MatOperator::div);
- InsertOperatorToTable("*", MatOperator::mul);
- InsertOperatorToTable("^", MatOperator::pow);
- returns true if 'str2' is the substring of str1
- e.g.
- true when str1="test" and str2="te"
-bool IsSubstring(const std::string & str1, const std::string & str2)
- if( str2.length() > str1.length() )
- return false;
- for(typename std::string::size_type i=0 ; i<str2.length() ; ++i)
- if( str1[i] != str2[i] )
- return false;
-return true;
- this method reads a mathematical (or logical) operator
-void ReadMathematicalOperator(Item & result)
-std::string oper;
-typename OperatorsTable::iterator iter_old, iter_new;
- iter_old = operators_table.end();
- for( ; true ; ++pstring )
- oper += *pstring;
- iter_new = operators_table.lower_bound(oper);
- if( iter_new == operators_table.end() || !IsSubstring(iter_new->first, oper) )
- oper.erase(oper.begin() + oper.size() - 1); // we've got mininum one element
- if( iter_old != operators_table.end() && iter_old->first == oper )
- result.type = Item::mat_operator;
- result.moperator.SetType( iter_old->second );
- break;
- Error( err_unknown_operator );
- iter_old = iter_new;
- this method makes a calculation for the percentage operator
- e.g.
- 1000-50% = 1000-(1000*0,5) = 500
-void OperatorPercentage()
- if( stack_index < 3 ||
- stack[stack_index-1].type != Item::numerical_value ||
- stack[stack_index-2].type != Item::mat_operator ||
- stack[stack_index-3].type != Item::numerical_value )
- Error(err_percent_from);
- ++pstring;
- uint c = 0;
- c += stack[stack_index-1].value.Div(100);
- c += stack[stack_index-1].value.Mul(stack[stack_index-3].value);
- if( c )
- Error(err_overflow);
- this method reads a mathematic operators
- or the final bracket or the semicolon operator
- return values:
- 0 - ok
- 1 - the string is finished
-int ReadOperator(Item & result)
- if( *pstring == '%' )
- OperatorPercentage();
- if( *pstring == 0 )
- return 1;
- else
- if( *pstring == ')' )
- ++pstring;
- else
- if( *pstring == ';' || (param_sep!=0 && *pstring==param_sep) )
- result.type = Item::semicolon;
- ++pstring;
- else
- if( (*pstring>='a' && *pstring<='z') || (*pstring>='A' && *pstring<='Z') )
- // short mul (without any operators)
- result.moperator.SetType( MatOperator::shortmul );
- else
- ReadMathematicalOperator(result);
-return 0;
- this method is making the standard mathematic operation like '-' '+' '*' '/' and '^'
- the operation is made between 'value1' and 'value2'
- the result of this operation is stored in the 'value1'
-void MakeStandardMathematicOperation(ValueType & value1, typename MatOperator::Type mat_operator,
- const ValueType & value2)
-uint res;
- switch( mat_operator )
- case MatOperator::land:
- (!value1.IsZero() && !value2.IsZero()) ? value1.SetOne() : value1.SetZero();
- break;
- case MatOperator::lor:
- (!value1.IsZero() || !value2.IsZero()) ? value1.SetOne() : value1.SetZero();
- break;
- case MatOperator::eq:
- (value1 == value2) ? value1.SetOne() : value1.SetZero();
- break;
- case MatOperator::neq:
- (value1 != value2) ? value1.SetOne() : value1.SetZero();
- break;
- case MatOperator::lt:
- (value1 < value2) ? value1.SetOne() : value1.SetZero();
- break;
- case MatOperator::gt:
- (value1 > value2) ? value1.SetOne() : value1.SetZero();
- break;
- case MatOperator::let:
- (value1 <= value2) ? value1.SetOne() : value1.SetZero();
- break;
- case MatOperator::get:
- (value1 >= value2) ? value1.SetOne() : value1.SetZero();
- break;
- case MatOperator::sub:
- if( value1.Sub(value2) ) Error( err_overflow );
- break;
- case MatOperator::add:
- if( value1.Add(value2) ) Error( err_overflow );
- break;
- case MatOperator::mul:
- case MatOperator::shortmul:
- if( value1.Mul(value2) ) Error( err_overflow );
- break;
- case MatOperator::div:
- if( value2.IsZero() ) Error( err_division_by_zero );
- if( value1.Div(value2) ) Error( err_overflow );
- break;
- case MatOperator::pow:
- res = value1.Pow( value2 );
- if( res == 1 ) Error( err_overflow );
- else
- if( res == 2 ) Error( err_improper_argument );
- break;
- default:
- on the stack left an unknown operator but we had to recognize its before
- that means there's an error in our algorithm
- this method is trying to roll the stack up with the operator's priority
- for example if there are:
- "1 - 2 +"
- we can subtract "1-2" and the result store on the place where is '1' and copy the last
- operator '+', that means there'll be '-1+' on our stack
- but if there are:
- "1 - 2 *"
- we can't roll the stack up because the operator '*' has greater priority than '-'
-void TryRollingUpStackWithOperatorPriority()
- while( stack_index>=4 &&
- stack[stack_index-4].type == Item::numerical_value &&
- stack[stack_index-3].type == Item::mat_operator &&
- stack[stack_index-2].type == Item::numerical_value &&
- stack[stack_index-1].type == Item::mat_operator &&
- // the first operator has greater priority
- stack[stack_index-3].moperator.GetPriority() > stack[stack_index-1].moperator.GetPriority()
- // or both operators have the same priority and the first operator is not right associative
- stack[stack_index-3].moperator.GetPriority() == stack[stack_index-1].moperator.GetPriority() &&
- stack[stack_index-3].moperator.GetAssoc() == MatOperator::non_right
- MakeStandardMathematicOperation(stack[stack_index-4].value,
- stack[stack_index-3].moperator.GetType(),
- stack[stack_index-2].value);
- copying the last operator and setting the stack pointer to the correct value
- stack[stack_index-3] = stack[stack_index-1];
- stack_index -= 2;
- this method is trying to roll the stack up without testing any operators
- "1 - 2"
- there'll be "-1" on our stack
-void TryRollingUpStack()
- while( stack_index >= 3 &&
- stack[stack_index-3].type == Item::numerical_value &&
- stack[stack_index-2].type == Item::mat_operator &&
- stack[stack_index-1].type == Item::numerical_value )
- MakeStandardMathematicOperation( stack[stack_index-3].value,
- stack[stack_index-2].moperator.GetType(),
- stack[stack_index-1].value );
- stack_index -= 2;
- this method is reading a value or a variable or a function
- (the normal first bracket as well) and push it into the stack
-int ReadValueVariableOrFunctionAndPushItIntoStack(Item & temp)
-int code = ReadValueVariableOrFunction( temp );
- if( code == 0 )
- if( stack_index < stack.size() )
- stack[stack_index] = temp;
- else
- stack.push_back( temp );
- ++stack_index;
- if( code == 2 )
- // there was a final bracket, we didn't push it into the stack
- // (it'll be read by the 'ReadOperatorAndCheckFinalBracket' method next)
- code = 0;
-return code;
- this method calculate how many parameters there are on the stack
- and the index of the first parameter
- if there aren't any parameters on the stack this method returns
- 'size' equals zero and 'index' pointing after the first bracket
- (on non-existend element)
-void HowManyParameters(int & size, int & index)
- size = 0;
- index = stack_index;
- if( index == 0 )
- // we haven't put a first bracket on the stack
- if( stack[index-1].type == Item::first_bracket )
- // empty brackets
- return;
- for( --index ; index>=1 ; index-=2 )
- if( stack[index].type != Item::numerical_value )
- this element must be 'numerical_value', if not that means
- there's an error in our algorithm
- ++size;
- if( stack[index-1].type != Item::semicolon )
- break;
- if( index<1 || stack[index-1].type != Item::first_bracket )
- we haven't put a first bracket on the stack
- this method is being called when the final bracket ')' is being found
- this method's rolling the stack up, counting how many parameters there are
- on the stack and if there was a function it's calling the function
-void RollingUpFinalBracket()
-int amount_of_parameters;
-int index;
- if( stack_index<1 ||
- (stack[stack_index-1].type != Item::numerical_value &&
- stack[stack_index-1].type != Item::first_bracket)
- TryRollingUpStack();
- HowManyParameters(amount_of_parameters, index);
- // 'index' will be greater than zero
- // 'amount_of_parameters' can be zero
- if( amount_of_parameters==0 && !stack[index-1].function )
- bool was_sign = stack[index-1].sign;
- if( stack[index-1].function )
- // the result of a function will be on 'stack[index-1]'
- // and then at the end we'll set the correct type (numerical value) of this element
- CallFunction(stack[index-1].function_name, amount_of_parameters, index);
- else
- there was a normal bracket (not a funcion)
- if( amount_of_parameters != 1 )
- Error( err_unexpected_semicolon_operator );
- in the place where is the bracket we put the result
- stack[index-1] = stack[index];
- if there was a '-' character before the first bracket
- we change the sign of the expression
- stack[index-1].sign = false;
- if( was_sign )
- stack[index-1].value.ChangeSign();
- stack[index-1].type = Item::numerical_value;
- the pointer of the stack will be pointing on the next (non-existing now) element
- stack_index = index;
- this method is putting the operator on the stack
-void PushOperatorIntoStack(Item & temp)
- else
- ++stack_index;
- this method is reading a operator and if it's a final bracket
- it's calling RollingUpFinalBracket() and reading a operator again
-int ReadOperatorAndCheckFinalBracket(Item & temp)
- do
- if( ReadOperator(temp) == 1 )
- return 1;
- if( temp.type == Item::last_bracket )
- RollingUpFinalBracket();
- while( temp.type == Item::last_bracket );
-return 0;
- we check wheter there are only numerical value's or 'semicolon' operators on the stack
-void CheckIntegrityOfStack()
- for(unsigned int i=0 ; i<stack_index; ++i)
- if( stack[i].type != Item::numerical_value &&
- stack[i].type != Item::semicolon)
- on the stack we must only have 'numerical_value' or 'semicolon' operator
- if there is something another that means
- we probably didn't close any of the 'first' bracket
- Error( err_stack_not_clear );
- the main loop of parsing
-void Parse()
-Item item;
-int result_code;
- while( true )
- if( pstop_calculating && pstop_calculating->WasStopSignal() )
- Error( err_interrupt );
- result_code = ReadValueVariableOrFunctionAndPushItIntoStack( item );
- if( result_code == 0 )
- if( item.type == Item::first_bracket )
- continue;
- result_code = ReadOperatorAndCheckFinalBracket( item );
- if( result_code==1 || item.type==Item::semicolon )
- the string is finished or the 'semicolon' operator has appeared
- if( stack_index == 0 )
- Error( err_nothing_has_read );
- if( result_code == 1 )
- CheckIntegrityOfStack();
- return;
- PushOperatorIntoStack( item );
- TryRollingUpStackWithOperatorPriority();
- this method is called at the end of the parsing process
- on our stack we can have another value than 'numerical_values' for example
- when someone use the operator ';' in the global scope or there was an error during
- parsing and the parser hasn't finished its job
- if there was an error the stack is cleaned up now
- otherwise we resize stack and leave on it only 'numerical_value' items
-void NormalizeStack()
- if( error!=err_ok || stack_index==0 )
- stack.clear();
- return;
- 'stack_index' tell us how many elements there are on the stack,
- we must resize the stack now because 'stack_index' is using only for parsing
- and stack has more (or equal) elements than value of 'stack_index'
- stack.resize( stack_index );
- for(uint i=stack_index-1 ; i!=uint(-1) ; --i)
- if( stack[i].type != Item::numerical_value )
- stack.erase( stack.begin() + i );
-public:
- the default constructor
-Parser(): default_stack_size(100)
- pstop_calculating = 0;
- puser_variables = 0;
- puser_functions = 0;
- pfunction_local_variables = 0;
- base = 10;
- deg_rad_grad = 1;
- error = err_ok;
- group = 0;
- comma = '.';
- comma2 = ',';
- param_sep = 0;
- CreateFunctionsTable();
- CreateVariablesTable();
- CreateMathematicalOperatorsTable();
- the assignment operator
-Parser<ValueType> & operator=(const Parser<ValueType> & p)
- pstop_calculating = p.pstop_calculating;
- puser_variables = p.puser_variables;
- puser_functions = p.puser_functions;
- base = p.base;
- deg_rad_grad = p.deg_rad_grad;
- error = p.error;
- group = p.group;
- comma = p.comma;
- comma2 = p.comma2;
- param_sep = p.param_sep;
- we don't have to call 'CreateFunctionsTable()' etc.
- we can only copy these tables
- functions_table = p.functions_table;
- variables_table = p.variables_table;
- operators_table = p.operators_table;
- visited_variables = p.visited_variables;
- visited_functions = p.visited_functions;
-return *this;
- the copying constructor
-Parser(const Parser<ValueType> & p): default_stack_size(p.default_stack_size)
- operator=(p);
- the new base of mathematic system
- default is 10
-void SetBase(int b)
- if( b>=2 && b<=16 )
- base = b;
- 0 - deg
- 1 - rad (default)
- 2 - grad
-void SetDegRadGrad(int angle)
- if( angle >= 0 && angle <= 2 )
- deg_rad_grad = angle;
- this method sets a pointer to the object which tell us whether we should stop
- calculations
-void SetStopObject(const volatile StopCalculating * ps)
- pstop_calculating = ps;
- this method sets the new table of user-defined variables
- if you don't want any other variables just put zero value into the 'puser_variables' variable
- (you can have only one table at the same time)
-void SetVariables(const Objects * pv)
- puser_variables = pv;
- this method sets the new table of user-defined functions
- if you don't want any other functions just put zero value into the 'puser_functions' variable
-void SetFunctions(const Objects * pf)
- puser_functions = pf;
- setting the group character
-void SetGroup(int g)
- group = g;
- setting the main comma operator and the additional comma operator
- the additional operator can be zero (which means it is not used)
- default are: '.' and ','
-void SetComma(int c, int c2 = 0)
- comma = c;
- comma2 = c2;
- setting an additional character which is used as a parameters separator
- the main parameters separator is a semicolon (is used always)
- this character is used also as a global separator
-void SetParamSep(int s)
- param_sep = s;
- the main method using for parsing string
-ErrorCode Parse(const char * str)
- stack_index = 0;
- pstring = str;
- error = err_ok;
- calculated = false;
- stack.resize( default_stack_size );
- try
- Parse();
- catch(ErrorCode c)
- error = c;
- NormalizeStack();
-return error;
-ErrorCode Parse(const std::string & str)
- return Parse(str.c_str());
-#ifndef TTMATH_DONT_USE_WCHAR
-ErrorCode Parse(const wchar_t * str)
- Misc::AssignString(wide_to_ansi, str);
-return Parse(wide_to_ansi.c_str());
- // !! wide_to_ansi clearing can be added here
-ErrorCode Parse(const std::wstring & str)
-#endif
- this method returns true is something was calculated
- (at least one mathematical operator was used or a function or variable)
- e.g. true if the string to Parse() looked like this:
- "1+1"
- "2*3"
- "sin(5)"
- if the string was e.g. "678" the result is false
-bool Calculated()
- return calculated;
- initializing coefficients used when calculating the gamma (or factorial) function
- this speed up the next calculations
- you don't have to call this method explicitly
- these coefficients will be calculated when needed
-void InitCGamma()
- cgamma.InitAll();
-} // namespace
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmaththreads.h b/include/geos/algorithm/ttmath/ttmaththreads.h
deleted file mode 100644
index 57c3650..0000000
--- a/include/geos/algorithm/ttmath/ttmaththreads.h
+++ /dev/null
@@ -1,252 +0,0 @@
- * This file is a part of TTMath Bignum Library
- * and is distributed under the 3-Clause BSD Licence.
- * Author: Tomasz Sowa <t.sowa at ttmath.org>
- * Copyright (c) 2006-2009, Tomasz Sowa
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- * * Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * * Neither the name Tomasz Sowa nor the names of contributors to this
- * project may be used to endorse or promote products derived
- * from this software without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
- * THE POSSIBILITY OF SUCH DAMAGE.
-#ifndef headerfilettmaththreads
-#define headerfilettmaththreads
-#include "ttmathtypes.h"
-#ifdef TTMATH_WIN32_THREADS
-#include <windows.h>
-#include <cstdio>
-#endif
-#ifdef TTMATH_POSIX_THREADS
-#include <pthread.h>
-#endif
- \file ttmaththreads.h
- \brief Some objects used in multithreads environment
-namespace ttmath
- we use win32 threads
- in multithreads environment you should use TTMATH_MULTITHREADS_HELPER macro
- somewhere in *.cpp file
- (at the moment in win32 this macro does nothing)
- #define TTMATH_MULTITHREADS_HELPER
- objects of this class are used to synchronize
- class ThreadLock
- HANDLE mutex_handle;
- void CreateName(char * buffer) const
- #ifdef _MSC_VER
- #pragma warning (disable : 4996)
- // warning C4996: 'sprintf': This function or variable may be unsafe. Consider using sprintf_s instead.
- #endif
- sprintf(buffer, "TTMATH_LOCK_%ul", (unsigned long)GetCurrentProcessId());
- #ifdef _MSC_VER
- #pragma warning (default : 4996)
- #endif
- public:
- bool Lock()
- char buffer[50];
- CreateName(buffer);
- mutex_handle = CreateMutexA(0, false, buffer);
- if( mutex_handle == 0 )
- return false;
- WaitForSingleObject(mutex_handle, INFINITE);
- return true;
- ThreadLock()
- mutex_handle = 0;
- ~ThreadLock()
- if( mutex_handle != 0 )
- ReleaseMutex(mutex_handle);
- CloseHandle(mutex_handle);
-#endif // #ifdef TTMATH_WIN32_THREADS
- we use posix threads
- (this macro defines a pthread_mutex_t object used by TTMath library)
- #define TTMATH_MULTITHREADS_HELPER \
- namespace ttmath \
- pthread_mutex_t ttmath_mutex = PTHREAD_MUTEX_INITIALIZER; \
- ttmath_mutex will be defined by TTMATH_MULTITHREADS_HELPER macro
- extern pthread_mutex_t ttmath_mutex;
- \brief objects of this class are used to synchronize
- this is a simple skeleton of a program in multithreads environment:
- #include<ttmath/ttmath.h>
- TTMATH_MULTITHREADS_HELPER
- int main()
- make sure that macro TTMATH_MULTITHREADS is defined and (somewhere in *.cpp file)
- use TTMATH_MULTITHREADS_HELPER macro (outside of any classes/functions/namespaces scope)
- class ThreadLock
- public:
- lock the current thread
- it uses a global mutex created by TTMATH_MULTITHREADS_HELPER macro
- bool Lock()
- if( pthread_mutex_lock(&ttmath_mutex) != 0 )
- return false;
- return true;
- ~ThreadLock()
- pthread_mutex_unlock(&ttmath_mutex);
-#endif // #ifdef TTMATH_POSIX_THREADS
-#if !defined(TTMATH_POSIX_THREADS) && !defined(TTMATH_WIN32_THREADS)
- we don't use win32 and pthreads
- actually we don't synchronize, the method Lock() returns always 'false'
- class ThreadLock
- public:
- bool Lock()
- return false;
-#endif // #if !defined(TTMATH_POSIX_THREADS) && !defined(TTMATH_WIN32_THREADS)
-} // namespace
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmathtypes.h b/include/geos/algorithm/ttmath/ttmathtypes.h
index 5c4e0b7..0000000
--- a/include/geos/algorithm/ttmath/ttmathtypes.h
+++ /dev/null
@@ -1,718 +0,0 @@
- * Copyright (c) 2006-2017, Tomasz Sowa
-#ifndef headerfilettmathtypes
-#define headerfilettmathtypes
- \file ttmathtypes.h
- \brief constants used in the library
- As our library is written in header files (templates) we cannot use
- constants like 'const int' etc. because we should have some source files
- *.cpp to define this variables. Only what we can have are constants
- defined by \#define preprocessor macros.
- All macros are preceded by TTMATH_ prefix
-#include <stdexcept>
-#include <sstream>
-#include <vector>
-#ifndef _MSC_VER
-#include <stdint.h>
-// for uint64_t and int64_t on a 32 bit platform
-#endif
- the major version of the library
- the version present to the end user is constructed in this way:
- TTMATH_MAJOR_VER.TTMATH_MINOR_VER.TTMATH_REVISION_VER.[prerelease if TTMATH_PRERELEASE_VER==1]
-#define TTMATH_MAJOR_VER 0
- the minor version of the library
-#define TTMATH_MINOR_VER 9
- the revision version of the library
-#define TTMATH_REVISION_VER 4
- TTMATH_PRERELEASE_VER is either zero or one
- zero means that this is the release version of the library
- (one means something like beta)
-#define TTMATH_PRERELEASE_VER 1
- you can define a platform explicitly by defining either
- TTMATH_PLATFORM32 or TTMATH_PLATFORM64 macro
-#if !defined TTMATH_PLATFORM32 && !defined TTMATH_PLATFORM64
- #if !defined _M_X64 && !defined __x86_64__
- other platforms than x86 and amd64 are not recognized at the moment
- so you should set TTMATH_PLATFORMxx manually
- // we're using a 32bit platform
- #define TTMATH_PLATFORM32
- #else
- // we're using a 64bit platform
- #define TTMATH_PLATFORM64
- #endif
-#endif
- asm version of the library is available by default only for:
- x86 and amd64 platforms and for Microsoft Visual and GCC compilers
- but you can force using asm version (the same asm as for Microsoft Visual)
- by defining TTMATH_FORCEASM macro
- you have to be sure that your compiler accept such an asm format
-#ifndef TTMATH_FORCEASM
- #if !defined __i386__ && !defined _X86_ && !defined _M_IX86 && !defined __x86_64__ && !defined _M_X64
- x86 architecture:
- __i386__ defined by GNU C
- _X86_ defined by MinGW32
- _M_IX86 defined by Visual Studio, Intel C/C++, Digital Mars and Watcom C/C++
- amd64 architecture:
- __x86_64__ defined by GNU C, CLANG (LLVM) and Sun Studio
- _M_X64 defined by Visual Studio
- asm version is available only for x86 or amd64 platforms
- #define TTMATH_NOASM
- #endif
- #if !defined _MSC_VER && !defined __GNUC__
- another compilers than MS VC or GCC or CLANG (LLVM) by default use no asm version
- (CLANG defines __GNUC__ too)
- #endif
- /* 32-bit gcc < 5 doesn't like to build the ASM with PIC enabled as */
- /* we do for GEOS */
- #if defined __GNUC__ && __GNUC__ < 5 && !defined __x86_64__ && !defined _M_X64
- #endif
-#endif
-namespace ttmath
-#ifdef TTMATH_PLATFORM32
- on 32bit platforms one word (uint, sint) will be equal 32bits
- typedef unsigned int uint;
- typedef signed int sint;
- on 32 bit platform ulint and slint will be equal 64 bits
- #ifdef _MSC_VER
- // long long on MS Windows (Visual and GCC mingw compilers) have 64 bits
- // stdint.h is not available on Visual Studio prior to VS 2010 version
- typedef unsigned long long int ulint;
- typedef signed long long int slint;
- #else
- // we do not use 'long' here because there is a difference in unix and windows
- // environments: in unix 'long' has 64 bits but in windows it has only 32 bits
- typedef uint64_t ulint;
- typedef int64_t slint;
- #endif
- how many bits there are in the uint type
- #define TTMATH_BITS_PER_UINT 32u
- the mask for the highest bit in the unsigned 32bit word (2^31)
- #define TTMATH_UINT_HIGHEST_BIT 2147483648u
- the max value of the unsigned 32bit word (2^32 - 1)
- (all bits equal one)
- #define TTMATH_UINT_MAX_VALUE 4294967295u
- the number of words (32bit words on 32bit platform)
- which are kept in built-in variables for a Big<> type
- (these variables are defined in ttmathbig.h)
- #define TTMATH_BUILTIN_VARIABLES_SIZE 256u
- this macro returns the number of machine words
- capable to hold min_bits bits
- e.g. TTMATH_BITS(128) returns 4
- #define TTMATH_BITS(min_bits) ((min_bits-1)/32 + 1)
-#else
- #ifdef _MSC_VER
- /* in VC 'long' type has 32 bits, __int64 is VC extension */
- typedef unsigned __int64 uint;
- typedef signed __int64 sint;
- #else
- #ifdef __MINGW64__
- //Mingw64 64-bit patch from https://www.ttmath.org/forum/patch_for_building_64_bit_using_windows_mingw64_gcc
- typedef uint64_t uint;
- typedef int64_t sint;
- #else
- on 64bit platforms one word (uint, sint) will be equal 64bits
- typedef unsigned long uint;
- typedef signed long sint;
- #endif
- #endif
- on 64bit platforms we do not define ulint and slint
- #define TTMATH_BITS_PER_UINT 64ul
- the mask for the highest bit in the unsigned 64bit word (2^63)
- #define TTMATH_UINT_HIGHEST_BIT 9223372036854775808ul
- the max value of the unsigned 64bit word (2^64 - 1)
- #define TTMATH_UINT_MAX_VALUE 18446744073709551615ul
- the number of words (64bit words on 64bit platforms)
- #define TTMATH_BUILTIN_VARIABLES_SIZE 128ul
- e.g. TTMATH_BITS(128) returns 2
- #define TTMATH_BITS(min_bits) ((min_bits-1)/64 + 1)
-#endif
-#if defined(TTMATH_MULTITHREADS) && !defined(TTMATH_MULTITHREADS_NOSYNC)
- #if !defined(TTMATH_POSIX_THREADS) && !defined(TTMATH_WIN32_THREADS)
- #if defined(_WIN32)
- #define TTMATH_WIN32_THREADS
- #elif defined(unix) || defined(__unix__) || defined(__unix)
- #define TTMATH_POSIX_THREADS
- #endif
- #endif
-#endif
- this variable defines how many iterations are performed
- during some kind of calculating when we're making any long formulas
- (for example Taylor series)
- it's used in ExpSurrounding0(...), LnSurrounding1(...), Sin0pi05(...), etc.
- note! there'll not be so many iterations, iterations are stopped when
- there is no sense to continue calculating (for example when the result
- still remains unchanged after adding next series and we know that the next
- series are smaller than previous ones)
-#define TTMATH_ARITHMETIC_MAX_LOOP 10000
- this is a limit when calculating Karatsuba multiplication
- if the size of a vector is smaller than TTMATH_USE_KARATSUBA_MULTIPLICATION_FROM_SIZE
- the Karatsuba algorithm will use standard schoolbook multiplication
-#ifdef TTMATH_DEBUG_LOG
- // if TTMATH_DEBUG_LOG is defined then we should use the same size regardless of the compiler
- #define TTMATH_USE_KARATSUBA_MULTIPLICATION_FROM_SIZE 3
-#else
- #ifdef __GNUC__
- #else
- #define TTMATH_USE_KARATSUBA_MULTIPLICATION_FROM_SIZE 5
- #endif
-#endif
- this is a special value used when calculating the Gamma(x) function
- if x is greater than this value then the Gamma(x) will be calculated using
- some kind of series
- don't use smaller values than about 100
-#define TTMATH_GAMMA_BOUNDARY 2000
-namespace ttmath
- lib type codes:
- - asm_vc_32 - with asm code designed for Microsoft Visual C++ (32 bits)
- - asm_gcc_32 - with asm code designed for GCC (32 bits)
- - asm_vc_64 - with asm for VC (64 bit)
- - asm_gcc_64 - with asm for GCC (64 bit)
- - no_asm_32 - pure C++ version (32 bit) - without any asm code
- - no_asm_64 - pure C++ version (64 bit) - without any asm code
- enum LibTypeCode
- asm_vc_32 = 0,
- asm_gcc_32,
- asm_vc_64,
- asm_gcc_64,
- no_asm_32,
- no_asm_64
- error codes
- enum ErrorCode
- err_ok = 0,
- err_nothing_has_read,
- err_unknown_character,
- err_unexpected_final_bracket,
- err_stack_not_clear,
- err_unknown_variable,
- err_division_by_zero,
- err_interrupt,
- err_overflow,
- err_unknown_function,
- err_unknown_operator,
- err_unexpected_semicolon_operator,
- err_improper_amount_of_arguments,
- err_improper_argument,
- err_unexpected_end,
- err_internal_error,
- err_incorrect_name,
- err_incorrect_value,
- err_variable_exists,
- err_variable_loop,
- err_functions_loop,
- err_must_be_only_one_value,
- err_object_exists,
- err_unknown_object,
- err_still_calculating,
- err_in_short_form_used_function,
- err_percent_from
- this struct is used when converting to/from a string
- /temporarily only in Big::ToString() and Big::FromString()/
- struct Conv
- base (radix) on which the value will be shown (or read)
- default: 10
- uint base;
- used only in Big::ToString()
- if true the value will be always shown in the scientific mode, e.g: 123e+30
- default: false
- bool scient;
- if scient is false then the value will be printed in the scientific mode
- only if the exponent is greater than scien_from
- default: 15
- sint scient_from;
- if 'base_round' is true and 'base' is different from 2, 4, 8, or 16
- and the result value is not an integer then we make an additional rounding
- (after converting the last digit from the result is skipped)
- default: true
- e.g.
- Conv c;
- c.base_round = false;
- Big<1, 1> a = "0.1"; // decimal input
- std::cout << a.ToString(c) << std::endl; // the result is: 0.099999999
- bool base_round;
- tells how many digits after comma are possible
- default: -1 which means all digits are printed
- set it to zero if you want integer value only
- for example when the value is:
- 12.345678 and 'round' is 4
- then the result will be
- 12.3457 (the last digit was rounded)
- sint round;
- if true that not mattered digits in the mantissa will be cut off
- (zero characters at the end -- after the comma operator)
- e.g. 1234,78000 will be: 1234,78
- default: true
- bool trim_zeroes;
- the main comma operator (used when reading and writing)
- default is a dot '.'
- uint comma;
- additional comma operator (used only when reading)
- if you don't want it just set it to zero
- default is a comma ','
- this allowes you to convert from a value:
- 123.45 as well as from 123,45
- uint comma2;
- it sets the character which is used for grouping
- if group=' ' then: 1234,56789 will be printed as: 1 234,567 89
- if you don't want grouping just set it to zero (which is default)
- uint group;
- how many digits should be grouped (it is used if 'group' is non zero)
- default: 3
- uint group_digits;
- uint group_exp; // not implemented yet
- Conv()
- // default values
- base = 10;
- scient = false;
- scient_from = 15;
- base_round = true;
- round = -1;
- trim_zeroes = true;
- comma = '.';
- comma2 = ',';
- group = 0;
- group_digits = 3;
- group_exp = 0;
- this simple class can be used in multithreading model
- (you can write your own class derived from this one)
- for example: in some functions like Factorial()
- /at the moment only Factorial/ you can give a pointer to
- the 'stop object', if the method WasStopSignal() of this
- object returns true that means we should break the calculating
- and return
- class StopCalculating
- public:
- virtual bool WasStopSignal() const volatile { return false; }
- virtual ~StopCalculating(){}
- a small class which is useful when compiling with gcc
- object of this type holds the name and the line of a file
- in which the macro TTMATH_ASSERT or TTMATH_REFERENCE_ASSERT was used
- class ExceptionInfo
- const char * file;
- int line;
- public:
- ExceptionInfo() : file(0), line(0) {}
- ExceptionInfo(const char * f, int l) : file(f), line(l) {}
- std::string Where() const
- if( !file )
- return "unknown";
- std::ostringstream result;
- result << file << ":" << line;
- return result.str();
- A small class used for reporting 'reference' errors
- In the library is used macro TTMATH_REFERENCE_ASSERT which
- can throw an exception of this type
- ** from version 0.9.2 this macro is removed from all methods
- in public interface so you don't have to worry about it **
- If you compile with gcc you can get a small benefit
- from using method Where() (it returns std::string) with
- the name and the line of a file where the macro TTMATH_REFERENCE_ASSERT
- was used)
- class ReferenceError : public std::logic_error, public ExceptionInfo
- public:
- ReferenceError() : std::logic_error("reference error")
- ReferenceError(const char * f, int l) :
- std::logic_error("reference error"), ExceptionInfo(f,l)
- return ExceptionInfo::Where();
- a small class used for reporting errors
- in the library is used macro TTMATH_ASSERT which
- (if the condition in it is false) throw an exception
- of this type
- if you compile with gcc you can get a small benefit
- the name and the line of a file where the macro TTMATH_ASSERT
- was used)
- class RuntimeError : public std::runtime_error, public ExceptionInfo
- public:
- RuntimeError() : std::runtime_error("internal error")
- RuntimeError(const char * f, int l) :
- std::runtime_error("internal error"), ExceptionInfo(f,l)
- TTMATH_DEBUG
- this macro enables further testing during writing your code
- you don't have to define it in a release mode
- if this macro is set then macros TTMATH_ASSERT and TTMATH_REFERENCE_ASSERT
- are set as well and these macros can throw an exception if a condition in it
- is not fulfilled (look at the definition of TTMATH_ASSERT and TTMATH_REFERENCE_ASSERT)
- TTMATH_DEBUG is set automatically if DEBUG or _DEBUG are defined
- #if defined DEBUG || defined _DEBUG
- #define TTMATH_DEBUG
- #endif
- #ifdef TTMATH_DEBUG
- #if defined(__FILE__) && defined(__LINE__)
- #define TTMATH_REFERENCE_ASSERT(expression) \
- if( &(expression) == this ) throw ttmath::ReferenceError(__FILE__, __LINE__);
- #define TTMATH_ASSERT(expression) \
- if( !(expression) ) throw ttmath::RuntimeError(__FILE__, __LINE__);
- #else
- if( &(expression) == this ) throw ReferenceError();
- if( !(expression) ) throw RuntimeError();
- #endif
- #else
- #endif
- #ifdef TTMATH_DEBUG_LOG
- #define TTMATH_LOG(msg) PrintLog(msg, std::cout);
- #define TTMATH_LOGC(msg, carry) PrintLog(msg, carry, std::cout);
- #define TTMATH_VECTOR_LOG(msg, vector, len) PrintVectorLog(msg, std::cout, vector, len);
- #define TTMATH_VECTOR_LOGC(msg, carry, vector, len) PrintVectorLog(msg, carry, std::cout, vector, len);
- #else
- #endif
-} // namespace
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmathuint.h b/include/geos/algorithm/ttmath/ttmathuint.h
index 9b64745..0000000
--- a/include/geos/algorithm/ttmath/ttmathuint.h
+++ /dev/null
@@ -1,4189 +0,0 @@
-#ifndef headerfilettmathuint
-#define headerfilettmathuint
- \file ttmathuint.h
- \brief template class UInt<uint>
-#include <iostream>
-#include <iomanip>
-#include "ttmathmisc.h"
- \brief a namespace for the TTMath library
-namespace ttmath
- \brief UInt implements a big integer value without a sign
- value_size - how many bytes specify our value
- - on 32bit platforms: value_size=1 -> 4 bytes -> 32 bits
- - on 64bit platforms: value_size=1 -> 8 bytes -> 64 bits
- value_size = 1,2,3,4,5,6....
-template<uint value_size>
-class UInt
-public:
- buffer for the integer value
- table[0] - the lowest word of the value
- uint table[value_size];
- some methods used for debugging purposes
- this method is only for debugging purposes or when we want to make
- a table of a variable (constant) in ttmathbig.h
- it prints the table in a nice form of several columns
- template<class ostream_type>
- void PrintTable(ostream_type & output) const
- // how many columns there'll be
- const int columns = 8;
- int c = 1;
- for(int i=value_size-1 ; i>=0 ; --i)
- output << "0x" << std::setfill('0');
- #ifdef TTMATH_PLATFORM32
- output << std::setw(8);
- #else
- output << std::setw(16);
- #endif
- output << std::hex << table[i];
- if( i>0 )
- output << ", ";
- if( ++c > columns )
- output << std::endl;
- c = 1;
- output << std::dec << std::endl;
- this method is used when macro TTMATH_DEBUG_LOG is defined
- template<class char_type, class ostream_type>
- static void PrintVectorLog(const char_type * msg, ostream_type & output, const uint * vector, uint vector_len)
- output << msg << std::endl;
- for(uint i=0 ; i<vector_len ; ++i)
- output << " table[" << i << "]: " << vector[i] << std::endl;
- static void PrintVectorLog(const char_type * msg, uint carry, ostream_type & output, const uint * vector, uint vector_len)
- PrintVectorLog(msg, output, vector, vector_len);
- output << " carry: " << carry << std::endl;
- void PrintLog(const char_type * msg, ostream_type & output) const
- PrintVectorLog(msg, output, table, value_size);
- void PrintLog(const char_type * msg, uint carry, ostream_type & output) const
- this method returns the size of the table
- uint Size() const
- return value_size;
- this method sets zero
- void SetZero()
- // in the future here can be 'memset'
- for(uint i=0 ; i<value_size ; ++i)
- table[i] = 0;
- TTMATH_LOG("UInt::SetZero")
- this method sets one
- void SetOne()
- SetZero();
- table[0] = 1;
- TTMATH_LOG("UInt::SetOne")
- this method sets the max value which this class can hold
- (all bits will be one)
- void SetMax()
- table[i] = TTMATH_UINT_MAX_VALUE;
- TTMATH_LOG("UInt::SetMax")
- this method sets the min value which this class can hold
- (for an unsigned integer value the zero is the smallest value)
- void SetMin()
- SetZero();
- TTMATH_LOG("UInt::SetMin")
- this method swappes this for an argument
- void Swap(UInt<value_size> & ss2)
- uint temp = table[i];
- table[i] = ss2.table[i];
- ss2.table[i] = temp;
- this method copies the value stored in an another table
- (warning: first values in temp_table are the highest words -- it's different
- from our table)
- we copy as many words as it is possible
- if temp_table_len is bigger than value_size we'll try to round
- the lowest word from table depending on the last not used bit in temp_table
- (this rounding isn't a perfect rounding -- look at the description below)
- and if temp_table_len is smaller than value_size we'll clear the rest words
- in the table
- void SetFromTable(const uint * temp_table, uint temp_table_len)
- uint temp_table_index = 0;
- sint i; // 'i' with a sign
- for(i=value_size-1 ; i>=0 && temp_table_index<temp_table_len; --i, ++temp_table_index)
- table[i] = temp_table[ temp_table_index ];
- // rounding mantissa
- if( temp_table_index < temp_table_len )
- if( (temp_table[temp_table_index] & TTMATH_UINT_HIGHEST_BIT) != 0 )
- very simply rounding
- if the bit from not used last word from temp_table is set to one
- we're rouding the lowest word in the table
- in fact there should be a normal addition but
- we don't use Add() or AddTwoInts() because these methods
- can set a carry and then there'll be a small problem
- for optimization
- if( table[0] != TTMATH_UINT_MAX_VALUE )
- ++table[0];
- // cleaning the rest of the mantissa
- for( ; i>=0 ; --i)
- table[i] = 0;
- TTMATH_LOG("UInt::SetFromTable")
-#endif
-#ifdef TTMATH_PLATFORM64
- from our table)
- ***this method is created only on a 64bit platform***
- in the table
- warning: we're using 'temp_table' as a pointer at 32bit words
- void SetFromTable(const unsigned int * temp_table, uint temp_table_len)
- table[i] = uint(temp_table[ temp_table_index ]) << 32;
- ++temp_table_index;
- if( temp_table_index<temp_table_len )
- table[i] |= temp_table[ temp_table_index ];
- for optimization
- ++table[0];
- for( ; i >= 0 ; --i)
- table[i] = 0;
-#endif
- * basic mathematic functions
- this method adds one to the existing value
- uint AddOne()
- return AddInt(1);
- this method subtracts one from the existing value
- uint SubOne()
- return SubInt(1);
-private:
- an auxiliary method for moving bits into the left hand side
- this method moves only words
- void RclMoveAllWords(uint & rest_bits, uint & last_c, uint bits, uint c)
- rest_bits = bits % TTMATH_BITS_PER_UINT;
- uint all_words = bits / TTMATH_BITS_PER_UINT;
- uint mask = ( c ) ? TTMATH_UINT_MAX_VALUE : 0;
- if( all_words >= value_size )
- if( all_words == value_size && rest_bits == 0 )
- last_c = table[0] & 1;
- // else: last_c is default set to 0
- // clearing
- for(uint i = 0 ; i<value_size ; ++i)
- table[i] = mask;
- rest_bits = 0;
- else
- if( all_words > 0 )
- // 0 < all_words < value_size
- sint first, second;
- last_c = table[value_size - all_words] & 1; // all_words is greater than 0
- // copying the first part of the value
- for(first = value_size-1, second=first-all_words ; second>=0 ; --first, --second)
- table[first] = table[second];
- // setting the rest to 'c'
- for( ; first>=0 ; --first )
- table[first] = mask;
- TTMATH_LOG("UInt::RclMoveAllWords")
-public:
- moving all bits into the left side 'bits' times
- return value <- this <- C
- bits is from a range of <0, man * TTMATH_BITS_PER_UINT>
- or it can be even bigger then all bits will be set to 'c'
- the value c will be set into the lowest bits
- and the method returns state of the last moved bit
- uint Rcl(uint bits, uint c=0)
- uint last_c = 0;
- uint rest_bits = bits;
- if( bits == 0 )
- return 0;
- if( bits >= TTMATH_BITS_PER_UINT )
- RclMoveAllWords(rest_bits, last_c, bits, c);
- if( rest_bits == 0 )
- TTMATH_LOG("UInt::Rcl")
- return last_c;
- // rest_bits is from 1 to TTMATH_BITS_PER_UINT-1 now
- if( rest_bits == 1 )
- last_c = Rcl2_one(c);
- else if( rest_bits == 2 )
- // performance tests showed that for rest_bits==2 it's better to use Rcl2_one twice instead of Rcl2(2,c)
- Rcl2_one(c);
- else
- last_c = Rcl2(rest_bits, c);
- TTMATH_LOGC("UInt::Rcl", last_c)
- return last_c;
-private:
- an auxiliary method for moving bits into the right hand side
- void RcrMoveAllWords(uint & rest_bits, uint & last_c, uint bits, uint c)
- last_c = (table[value_size-1] & TTMATH_UINT_HIGHEST_BIT) ? 1 : 0;
- // clearing
- table[i] = mask;
- rest_bits = 0;
- else if( all_words > 0 )
- uint first, second;
- last_c = (table[all_words - 1] & TTMATH_UINT_HIGHEST_BIT) ? 1 : 0; // all_words is > 0
- for(first=0, second=all_words ; second<value_size ; ++first, ++second)
- for( ; first<value_size ; ++first )
- TTMATH_LOG("UInt::RcrMoveAllWords")
-public:
- moving all bits into the right side 'bits' times
- c -> this -> return value
- the value c will be set into the highest bits
- uint Rcr(uint bits, uint c=0)
- uint last_c = 0;
- if( bits == 0 )
- return 0;
- RcrMoveAllWords(rest_bits, last_c, bits, c);
- TTMATH_LOG("UInt::Rcr")
- return last_c;
- last_c = Rcr2_one(c);
- // performance tests showed that for rest_bits==2 it's better to use Rcr2_one twice instead of Rcr2(2,c)
- Rcr2_one(c);
- else
- last_c = Rcr2(rest_bits, c);
- TTMATH_LOGC("UInt::Rcr", last_c)
- return last_c;
- this method moves all bits into the left side
- (it returns value how many bits have been moved)
- uint CompensationToLeft()
- uint moving = 0;
- // a - index a last word which is different from zero
- sint a;
- for(a=value_size-1 ; a>=0 && table[a]==0 ; --a);
- if( a < 0 )
- return moving; // all words in table have zero
- if( a != value_size-1 )
- moving += ( value_size-1 - a ) * TTMATH_BITS_PER_UINT;
- // moving all words
- sint i;
- for(i=value_size-1 ; a>=0 ; --i, --a)
- table[i] = table[a];
- // setting the rest word to zero
- for(; i>=0 ; --i)
- table[i] = 0;
- uint moving2 = FindLeadingBitInWord( table[value_size-1] );
- // moving2 is different from -1 because the value table[value_size-1]
- // is not zero
- moving2 = TTMATH_BITS_PER_UINT - moving2 - 1;
- Rcl(moving2);
- TTMATH_LOG("UInt::CompensationToLeft")
- return moving + moving2;
- this method looks for the highest set bit
- result:
- - if 'this' is not zero:
- return value - true,
- 'table_id' - the index of a word <0..value_size-1>,
- 'index' - the index of this set bit in the word <0..TTMATH_BITS_PER_UINT)
- - if 'this' is zero:
- return value - false,
- both 'table_id' and 'index' are zero
- bool FindLeadingBit(uint & table_id, uint & index) const
- for(table_id=value_size-1 ; table_id!=0 && table[table_id]==0 ; --table_id);
- if( table_id==0 && table[table_id]==0 )
- // is zero
- index = 0;
- return false;
- // table[table_id] is different from 0
- index = FindLeadingBitInWord( table[table_id] );
- return true;
- this method looks for the smallest set bit
- result:
- bool FindLowestBit(uint & table_id, uint & index) const
- for(table_id=0 ; table_id<value_size && table[table_id]==0 ; ++table_id);
- if( table_id >= value_size )
- // is zero
- index = 0;
- table_id = 0;
- return false;
- index = FindLowestBitInWord( table[table_id] );
- return true;
- getting the 'bit_index' bit
- bit_index bigger or equal zero
- uint GetBit(uint bit_index) const
- TTMATH_ASSERT( bit_index < value_size * TTMATH_BITS_PER_UINT )
- uint index = bit_index / TTMATH_BITS_PER_UINT;
- uint bit = bit_index % TTMATH_BITS_PER_UINT;
- uint temp = table[index];
- uint res = SetBitInWord(temp, bit);
- return res;
- setting the 'bit_index' bit
- and returning the last state of the bit
- uint SetBit(uint bit_index)
- uint res = SetBitInWord(table[index], bit);
- TTMATH_LOG("UInt::SetBit")
- return res;
- this method performs a bitwise operation AND
- void BitAnd(const UInt<value_size> & ss2)
- for(uint x=0 ; x<value_size ; ++x)
- table[x] &= ss2.table[x];
- TTMATH_LOG("UInt::BitAnd")
- this method performs a bitwise operation OR
- void BitOr(const UInt<value_size> & ss2)
- table[x] |= ss2.table[x];
- TTMATH_LOG("UInt::BitOr")
- this method performs a bitwise operation XOR
- void BitXor(const UInt<value_size> & ss2)
- table[x] ^= ss2.table[x];
- TTMATH_LOG("UInt::BitXor")
- this method performs a bitwise operation NOT
- void BitNot()
- table[x] = ~table[x];
- TTMATH_LOG("UInt::BitNot")
- this method performs a bitwise operation NOT but only
- on the range of <0, leading_bit>
- for example:
- BitNot2(8) = BitNot2( 1000(bin) ) = 111(bin) = 7
- void BitNot2()
- uint table_id, index;
- if( FindLeadingBit(table_id, index) )
- for(uint x=0 ; x<table_id ; ++x)
- uint mask = TTMATH_UINT_MAX_VALUE;
- uint shift = TTMATH_BITS_PER_UINT - index - 1;
- if(shift)
- mask >>= shift;
- table[table_id] ^= mask;
- else
- table[0] = 1;
- TTMATH_LOG("UInt::BitNot2")
- * Multiplication
-public:
- multiplication: this = this * ss2
- it can return a carry
- uint MulInt(uint ss2)
- uint r1, r2, x1;
- uint c = 0;
- UInt<value_size> u(*this);
- SetZero();
- if( ss2 == 0 )
- TTMATH_LOGC("UInt::MulInt(uint)", 0)
- return 0;
- for(x1=0 ; x1<value_size-1 ; ++x1)
- MulTwoWords(u.table[x1], ss2, &r2, &r1);
- c += AddTwoInts(r2,r1,x1);
- // x1 = value_size-1 (last word)
- c += (r2!=0) ? 1 : 0;
- c += AddInt(r1, x1);
- TTMATH_LOGC("UInt::MulInt(uint)", c)
- return (c==0)? 0 : 1;
- multiplication: result = this * ss2
- we're using this method only when result_size is greater than value_size
- if so there will not be a carry
- template<uint result_size>
- void MulInt(uint ss2, UInt<result_size> & result) const
- TTMATH_ASSERT( result_size > value_size )
- uint r2,r1;
- uint x1size=value_size;
- uint x1start=0;
- result.SetZero();
- if( ss2 == 0 )
- TTMATH_VECTOR_LOG("UInt::MulInt(uint, UInt<>)", result.table, result_size)
- return;
- if( value_size > 2 )
- // if the value_size is smaller than or equal to 2
- // there is no sense to set x1size and x1start to another values
- for(x1size=value_size ; x1size>0 && table[x1size-1]==0 ; --x1size);
- if( x1size == 0 )
- return;
- for(x1start=0 ; x1start<x1size && table[x1start]==0 ; ++x1start);
- for(uint x1=x1start ; x1<x1size ; ++x1)
- MulTwoWords(table[x1], ss2, &r2, &r1 );
- result.AddTwoInts(r2,r1,x1);
- return;
- the multiplication 'this' = 'this' * ss2
- algorithm: 100 - means automatically choose the fastest algorithm
- uint Mul(const UInt<value_size> & ss2, uint algorithm = 100)
- switch( algorithm )
- case 1:
- return Mul1(ss2);
- case 2:
- return Mul2(ss2);
- case 3:
- return Mul3(ss2);
- case 100:
- default:
- return MulFastest(ss2);
- the multiplication 'result' = 'this' * ss2
- since the 'result' is twice bigger than 'this' and 'ss2'
- this method never returns a carry
- void MulBig(const UInt<value_size> & ss2,
- UInt<value_size*2> & result,
- uint algorithm = 100)
- case 1:
- Mul1Big(ss2, result);
- break;
- case 2:
- Mul2Big(ss2, result);
- break;
- case 3:
- Mul3Big(ss2, result);
- break;
- case 100:
- default:
- MulFastestBig(ss2, result);
- the first version of the multiplication algorithm
-private:
- it returns carry if it has been
- uint Mul1Ref(const UInt<value_size> & ss2)
- TTMATH_REFERENCE_ASSERT( ss2 )
- UInt<value_size> ss1( *this );
- SetZero();
- for(uint i=0; i < value_size*TTMATH_BITS_PER_UINT ; ++i)
- if( Add(*this) )
- TTMATH_LOGC("UInt::Mul1", 1)
- return 1;
- if( ss1.Rcl(1) )
- if( Add(ss2) )
- return 1;
- TTMATH_LOGC("UInt::Mul1", 0)
- return 0;
-public:
- can return carry
- uint Mul1(const UInt<value_size> & ss2)
- if( this == &ss2 )
- UInt<value_size> copy_ss2(ss2);
- return Mul1Ref(copy_ss2);
- else
- return Mul1Ref(ss2);
- result is twice bigger than 'this' and 'ss2'
- this method never returns carry
- void Mul1Big(const UInt<value_size> & ss2_, UInt<value_size*2> & result)
- UInt<value_size*2> ss2;
- uint i;
- // copying *this into result and ss2_ into ss2
- for(i=0 ; i<value_size ; ++i)
- result.table[i] = table[i];
- ss2.table[i] = ss2_.table[i];
- // cleaning the highest bytes in result and ss2
- for( ; i < value_size*2 ; ++i)
- result.table[i] = 0;
- ss2.table[i] = 0;
- // multiply
- // (there will not be a carry)
- result.Mul1( ss2 );
- TTMATH_LOG("UInt::Mul1Big")
- the second version of the multiplication algorithm
- this algorithm is similar to the 'schoolbook method' which is done by hand
- uint Mul2(const UInt<value_size> & ss2)
- UInt<value_size*2> result;
- uint i, c = 0;
- // copying result
- table[i] = result.table[i];
- // testing carry
- for( ; i<value_size*2 ; ++i)
- if( result.table[i] != 0 )
- c = 1;
- break;
- TTMATH_LOGC("UInt::Mul2", c)
- return c;
- result is twice bigger than this and ss2
- void Mul2Big(const UInt<value_size> & ss2, UInt<value_size*2> & result)
- Mul2Big2<value_size>(table, ss2.table, result);
- TTMATH_LOG("UInt::Mul2Big")
-private:
- an auxiliary method for calculating the multiplication
- arguments we're taking as pointers (this is to improve the Mul3Big2()- avoiding
- unnecessary copying objects), the result should be taken as a pointer too,
- but at the moment there is no method AddTwoInts() which can operate on pointers
- template<uint ss_size>
- void Mul2Big2(const uint * ss1, const uint * ss2, UInt<ss_size*2> & result)
- uint x1size = ss_size, x2size = ss_size;
- uint x1start = 0, x2start = 0;
- if( ss_size > 2 )
- // if the ss_size is smaller than or equal to 2
- // there is no sense to set x1size (and others) to another values
- for(x1size=ss_size ; x1size>0 && ss1[x1size-1]==0 ; --x1size);
- for(x2size=ss_size ; x2size>0 && ss2[x2size-1]==0 ; --x2size);
- for(x1start=0 ; x1start<x1size && ss1[x1start]==0 ; ++x1start);
- for(x2start=0 ; x2start<x2size && ss2[x2start]==0 ; ++x2start);
- Mul2Big3<ss_size>(ss1, ss2, result, x1start, x1size, x2start, x2size);
- void Mul2Big3(const uint * ss1, const uint * ss2, UInt<ss_size*2> & result, uint x1start, uint x1size, uint x2start, uint x2size)
- uint r2, r1;
- result.SetZero();
- if( x1size==0 || x2size==0 )
- return;
- for(uint x2=x2start ; x2<x2size ; ++x2)
- MulTwoWords(ss1[x1], ss2[x2], &r2, &r1);
- result.AddTwoInts(r2, r1, x2+x1);
- // here will never be a carry
-public:
- This is Karatsuba Multiplication algorithm, we're using it when value_size is greater than
- or equal to TTMATH_USE_KARATSUBA_MULTIPLICATION_FROM_SIZE macro (defined in ttmathuint.h).
- If value_size is smaller then we're using Mul2Big() instead.
- Karatsuba multiplication:
- Assume we have:
- this = x = x1*B^m + x0
- ss2 = y = y1*B^m + y0
- where x0 and y0 are less than B^m
- the product from multiplication we can show as:
- x*y = (x1*B^m + x0)(y1*B^m + y0) = z2*B^(2m) + z1*B^m + z0
- where
- z2 = x1*y1
- z1 = x1*y0 + x0*y1
- z0 = x0*y0
- this is standard schoolbook algorithm with O(n^2), Karatsuba observed that z1 can be given in other form:
- z1 = (x1 + x0)*(y1 + y0) - z2 - z0 / z1 = (x1*y1 + x1*y0 + x0*y1 + x0*y0) - x1*y1 - x0*y0 = x1*y0 + x0*y1 /
- and to calculate the multiplication we need only three multiplications (with some additions and subtractions)
- Our objects 'this' and 'ss2' we divide into two parts and by using recurrence we calculate the multiplication.
- Karatsuba multiplication has O( n^(ln(3)/ln(2)) )
- uint Mul3(const UInt<value_size> & ss2)
- uint i, c = 0;
- // copying result
- // testing carry
- c = 1;
- break;
- TTMATH_LOGC("UInt::Mul3", c)
- return c;
- result is twice bigger than this and ss2,
- this method never returns carry,
- (Karatsuba multiplication)
- void Mul3Big(const UInt<value_size> & ss2, UInt<value_size*2> & result)
- Mul3Big2<value_size>(table, ss2.table, result.table);
- TTMATH_LOG("UInt::Mul3Big")
-private:
- an auxiliary method for calculating the Karatsuba multiplication
- result_size is equal ss_size*2
- void Mul3Big2(const uint * ss1, const uint * ss2, uint * result)
- const uint * x1, * x0, * y1, * y0;
- if( ss_size>1 && ss_size<TTMATH_USE_KARATSUBA_MULTIPLICATION_FROM_SIZE )
- UInt<ss_size*2> res;
- Mul2Big2<ss_size>(ss1, ss2, res);
-#ifdef __clang__
-#pragma clang diagnostic push
-#pragma clang diagnostic ignored "-Wtautological-compare"
-#endif
- for(uint i=0 ; i<ss_size*2 ; ++i)
- result[i] = res.table[i];
-#ifdef __clang__
-#pragma clang diagnostic pop
-#endif
- return;
- else
- if( ss_size == 1 )
- return MulTwoWords(*ss1, *ss2, &result[1], &result[0]);
- if( (ss_size & 1) == 1 )
- // ss_size is odd
- x0 = ss1;
- y0 = ss2;
- x1 = ss1 + ss_size / 2 + 1;
- y1 = ss2 + ss_size / 2 + 1;
- // the second vectors (x1 and y1) are smaller about one from the first ones (x0 and y0)
- Mul3Big3<ss_size/2 + 1, ss_size/2, ss_size*2>(x1, x0, y1, y0, result);
- else
- // ss_size is even
- x0 = ss1;
- y0 = ss2;
- x1 = ss1 + ss_size / 2;
- y1 = ss2 + ss_size / 2;
- // all four vectors (x0 x1 y0 y1) are equal in size
- Mul3Big3<ss_size/2, ss_size/2, ss_size*2>(x1, x0, y1, y0, result);
-#ifdef _MSC_VER
-#pragma warning (disable : 4717)
-//warning C4717: recursive on all control paths, function will cause runtime stack overflow
-//we have the stop point in Mul3Big2() method
-#endif
-#if defined(__GNUC__) && !defined(__clang__)
-#pragma GCC diagnostic push
-#pragma GCC diagnostic ignored "-Wunused-but-set-variable"
-#endif
- x = x1*B^m + x0
- y = y1*B^m + y0
- first_size - is the size of vectors: x0 and y0
- second_size - is the size of vectors: x1 and y1 (can be either equal first_size or smaller about one from first_size)
- where
- z0 = x0*y0
- z2 = x1*y1
- template<uint first_size, uint second_size, uint result_size>
- void Mul3Big3(const uint * x1, const uint * x0, const uint * y1, const uint * y0, uint * result)
- uint i, c, xc, yc;
- UInt<first_size> temp, temp2;
- UInt<first_size*3> z1;
- // z0 and z2 we store directly in the result (we don't use any temporary variables)
- Mul3Big2<first_size>(x0, y0, result); // z0
- Mul3Big2<second_size>(x1, y1, result+first_size*2); // z2
- // now we calculate z1
- // temp = (x0 + x1)
- // temp2 = (y0 + y1)
- // we're using temp and temp2 with UInt<first_size>, although there can be a carry but
- // we simple remember it in xc and yc (xc and yc can be either 0 or 1),
- // and (x0 + x1)*(y0 + y1) we calculate in this way (schoolbook algorithm):
- // xc | temp
- // yc | temp2
- // (temp * temp2)
- // xc*temp2 |
- // yc*temp |
- // xc*yc |
- // ---------- z1 --------
- // and the result is never larger in size than 3*first_size
- xc = AddVector(x0, x1, first_size, second_size, temp.table);
- yc = AddVector(y0, y1, first_size, second_size, temp2.table);
- Mul3Big2<first_size>(temp.table, temp2.table, z1.table);
-#ifdef __clang__
-#endif
- // clearing the rest of z1
- for(i=first_size*2 ; i<first_size*3 ; ++i)
- z1.table[i] = 0;
-#ifdef __clang__
-#endif
- if( xc )
- c = AddVector(z1.table+first_size, temp2.table, first_size*3-first_size, first_size, z1.table+first_size);
- TTMATH_ASSERT( c==0 )
- if( yc )
- c = AddVector(z1.table+first_size, temp.table, first_size*3-first_size, first_size, z1.table+first_size);
- if( xc && yc )
-#ifdef __clang__
-#endif
- for( i=first_size*2 ; i<first_size*3 ; ++i )
- if( ++z1.table[i] != 0 )
- break; // break if there was no carry
-#ifdef __clang__
-#endif
- // z1 = z1 - z2
- c = SubVector(z1.table, result+first_size*2, first_size*3, second_size*2, z1.table);
- TTMATH_ASSERT(c==0)
- // z1 = z1 - z0
- c = SubVector(z1.table, result, first_size*3, first_size*2, z1.table);
- // here we've calculated the z1
- // now we're adding it to the result
- if( first_size > second_size )
- uint z1_size = result_size - first_size;
- TTMATH_ASSERT( z1_size <= first_size*3 )
-#ifdef __clang__
-#endif
- for(i=z1_size ; i<first_size*3 ; ++i)
- TTMATH_ASSERT( z1.table[i] == 0 )
-#ifdef __clang__
-#endif
- c = AddVector(result+first_size, z1.table, result_size-first_size, z1_size, result+first_size);
- else
- c = AddVector(result+first_size, z1.table, result_size-first_size, first_size*3, result+first_size);
-#pragma GCC diagnostic pop
-#endif
-#ifdef _MSC_VER
-#pragma warning (default : 4717)
-#endif
-public:
- multiplication this = this * ss2
- uint MulFastest(const UInt<value_size> & ss2)
- uint i, c = 0;
- // copying result
- // testing carry
- c = 1;
- break;
- TTMATH_LOGC("UInt::MulFastest", c)
- return c;
- multiplication result = this * ss2
- this method is trying to select the fastest algorithm
- (in the future this method can be improved)
- void MulFastestBig(const UInt<value_size> & ss2, UInt<value_size*2> & result)
- if( value_size < TTMATH_USE_KARATSUBA_MULTIPLICATION_FROM_SIZE )
- return;
- uint x1size = value_size, x2size = value_size;
- for(x2size=value_size ; x2size>0 && ss2.table[x2size-1]==0 ; --x2size);
- // either 'this' or 'ss2' is equal zero - the result is zero too
- result.SetZero();
- return;
- for(x2start=0 ; x2start<x2size && ss2.table[x2start]==0 ; ++x2start);
- uint distancex1 = x1size - x1start;
- uint distancex2 = x2size - x2start;
- if( distancex1 < 3 || distancex2 < 3 )
- // either 'this' or 'ss2' have only 2 (or 1) items different from zero (side by side)
- // (this condition in the future can be improved)
- Mul2Big3<value_size>(table, ss2.table, result, x1start, x1size, x2start, x2size);
- return;
- // Karatsuba multiplication
- TTMATH_LOG("UInt::MulFastestBig")
- * Division
-public:
- division by one unsigned word
- returns 1 when divisor is zero
- uint DivInt(uint divisor, uint * remainder = 0)
- if( divisor == 0 )
- if( remainder )
- *remainder = 0; // this is for convenience, without it the compiler can report that 'remainder' is uninitialized
- TTMATH_LOG("UInt::DivInt")
- return 1;
- if( divisor == 1 )
- if( remainder )
- *remainder = 0;
- return 0;
- UInt<value_size> dividend(*this);
- SetZero();
- sint i; // i must be with a sign
- uint r = 0;
- // we're looking for the last word in ss1
- for(i=value_size-1 ; i>0 && dividend.table[i]==0 ; --i);
- DivTwoWords(r, dividend.table[i], divisor, &table[i], &r);
- if( remainder )
- *remainder = r;
- return 0;
- uint DivInt(uint divisor, uint & remainder)
- return DivInt(divisor, &remainder);
- division this = this / ss2
- return values:
- - 0 - ok
- - 1 - division by zero
- - 'this' will be the quotient
- - 'remainder' - remainder
- uint Div( const UInt<value_size> & divisor,
- UInt<value_size> * remainder = 0,
- uint algorithm = 3)
- case 1:
- return Div1(divisor, remainder);
- case 2:
- return Div2(divisor, remainder);
- case 3:
- default:
- return Div3(divisor, remainder);
- uint Div(const UInt<value_size> & divisor, UInt<value_size> & remainder, uint algorithm = 3)
- return Div(divisor, &remainder, algorithm);
-private:
- return values:
- - 0 - none has to be done
- - 2 - division should be made
- uint Div_StandardTest( const UInt<value_size> & v,
- uint & m, uint & n,
- UInt<value_size> * remainder = 0)
- switch( Div_CalculatingSize(v, m, n) )
- case 4: // 'this' is equal v
- if( remainder )
- remainder->SetZero();
- SetOne();
- TTMATH_LOG("UInt::Div_StandardTest")
- return 0;
- case 3: // 'this' is smaller than v
- if( remainder )
- *remainder = *this;
- SetZero();
- return 0;
- case 2: // 'this' is zero
- if( remainder )
- SetZero();
- return 0;
- case 1: // v is zero
- return 1;
- return 2;
- return values:
- - 0 - ok
- - 'm' - is the index (from 0) of last non-zero word in table ('this')
- - 'n' - is the index (from 0) of last non-zero word in v.table
- - 1 - v is zero
- - 2 - 'this' is zero
- - 3 - 'this' is smaller than v
- - 4 - 'this' is equal v
- if the return value is different than zero the 'm' and 'n' are undefined
- uint Div_CalculatingSize(const UInt<value_size> & v, uint & m, uint & n)
- m = n = value_size-1;
- for( ; n!=0 && v.table[n]==0 ; --n);
- if( n==0 && v.table[n]==0 )
- return 1;
- for( ; m!=0 && table[m]==0 ; --m);
- if( m==0 && table[m]==0 )
- return 2;
- if( m < n )
- return 3;
- else
- if( m == n )
- uint i;
- for(i = n ; i!=0 && table[i]==v.table[i] ; --i);
- if( table[i] < v.table[i] )
- return 3;
- else
- if (table[i] == v.table[i] )
- return 4;
- return 0;
-public:
- the first division algorithm
- (radix 2)
- uint Div1(const UInt<value_size> & divisor, UInt<value_size> * remainder = 0)
- uint m,n, test;
- test = Div_StandardTest(divisor, m, n, remainder);
- if( test < 2 )
- return test;
- if( !remainder )
- UInt<value_size> rem;
- return Div1_Calculate(divisor, rem);
- return Div1_Calculate(divisor, *remainder);
- (radix 2)
- uint Div1(const UInt<value_size> & divisor, UInt<value_size> & remainder)
- return Div1(divisor, &remainder);
-private:
- uint Div1_Calculate(const UInt<value_size> & divisor, UInt<value_size> & rest)
- if( this == &divisor )
- UInt<value_size> divisor_copy(divisor);
- return Div1_CalculateRef(divisor_copy, rest);
- else
- return Div1_CalculateRef(divisor, rest);
- uint Div1_CalculateRef(const UInt<value_size> & divisor, UInt<value_size> & rest)
- TTMATH_REFERENCE_ASSERT( divisor )
- sint loop;
- sint c;
- rest.SetZero();
- loop = value_size * TTMATH_BITS_PER_UINT;
- c = 0;
- div_a:
- c = Rcl(1, c);
- c = rest.Add(rest,c);
- c = rest.Sub(divisor,c);
- c = !c;
- if(!c)
- goto div_d;
- div_b:
- --loop;
- if(loop)
- goto div_a;
- c = Rcl(1, c);
- TTMATH_LOG("UInt::Div1_Calculate")
- return 0;
- div_c:
- c = Rcl(1, c);
- c = rest.Add(divisor);
- if(c)
- goto div_b;
- div_d:
- --loop;
- if(loop)
- goto div_c;
- c = Rcl(1, c);
- return 0;
-public:
- the second division algorithm
- return values:
- - 0 - ok
- uint Div2(const UInt<value_size> & divisor, UInt<value_size> * remainder = 0)
- return Div2Ref(divisor_copy, remainder);
- else
- return Div2Ref(divisor, remainder);
- return values:
- - 0 - ok
- uint Div2(const UInt<value_size> & divisor, UInt<value_size> & remainder)
- return Div2(divisor, &remainder);
-private:
- return values:
- - 0 - ok
- uint Div2Ref(const UInt<value_size> & divisor, UInt<value_size> * remainder = 0)
- uint bits_diff;
- uint status = Div2_Calculate(divisor, remainder, bits_diff);
- if( status < 2 )
- return status;
- if( CmpBiggerEqual(divisor) )
- Div2(divisor, remainder);
- SetBit(bits_diff);
- else
- if( remainder )
- SetZero();
- TTMATH_LOG("UInt::Div2")
- return 0;
- return values:
- - 0 - we've calculated the division
- - 2 - we have to still calculate
- uint Div2_Calculate(const UInt<value_size> & divisor, UInt<value_size> * remainder,
- uint & bits_diff)
- uint divisor_table_id, divisor_index;
- uint status = Div2_FindLeadingBitsAndCheck( divisor, remainder,
- table_id, index,
- divisor_table_id, divisor_index);
- if( status < 2 )
- TTMATH_LOG("UInt::Div2_Calculate")
- return status;
- // here we know that 'this' is greater than divisor
- // then 'index' is greater or equal 'divisor_index'
- bits_diff = index - divisor_index;
- divisor_copy.Rcl(bits_diff, 0);
- if( CmpSmaller(divisor_copy, table_id) )
- divisor_copy.Rcr(1);
- --bits_diff;
- Sub(divisor_copy, 0);
- return 2;
- return values:
- uint Div2_FindLeadingBitsAndCheck( const UInt<value_size> & divisor,
- UInt<value_size> * remainder,
- uint & table_id, uint & index,
- uint & divisor_table_id, uint & divisor_index)
- if( !divisor.FindLeadingBit(divisor_table_id, divisor_index) )
- // division by zero
- TTMATH_LOG("UInt::Div2_FindLeadingBitsAndCheck")
- return 1;
- if( !FindLeadingBit(table_id, index) )
- // zero is divided by something
- SetZero();
- if( remainder )
- return 0;
- divisor_index += divisor_table_id * TTMATH_BITS_PER_UINT;
- index += table_id * TTMATH_BITS_PER_UINT;
- if( divisor_table_id == 0 )
- // dividor has only one 32-bit word
- uint r;
- DivInt(divisor.table[0], &r);
- if( remainder )
- remainder->table[0] = r;
- return 0;
- if( Div2_DivisorGreaterOrEqual( divisor, remainder,
- table_id, index,
- divisor_index) )
- return 0;
- return 2;
- return values:
- - true if divisor is equal or greater than 'this'
- bool Div2_DivisorGreaterOrEqual( const UInt<value_size> & divisor,
- uint table_id, uint index,
- uint divisor_index )
- if( divisor_index > index )
- // divisor is greater than this
- if( remainder )
- SetZero();
- TTMATH_LOG("UInt::Div2_DivisorGreaterOrEqual")
- return true;
- if( divisor_index == index )
- // table_id == divisor_table_id as well
- uint i;
- for(i = table_id ; i!=0 && table[i]==divisor.table[i] ; --i);
- if( table[i] < divisor.table[i] )
- // divisor is greater than 'this'
- if( remainder )
- SetZero();
- return true;
- else
- if( table[i] == divisor.table[i] )
- // divisor is equal 'this'
- if( remainder )
- SetOne();
- return true;
- return false;
-public:
- the third division algorithm
- uint Div3(const UInt<value_size> & ss2, UInt<value_size> * remainder = 0)
- return Div3Ref(copy_ss2, remainder);
- else
- return Div3Ref(ss2, remainder);
- uint Div3(const UInt<value_size> & ss2, UInt<value_size> & remainder)
- return Div3(ss2, &remainder);
-private:
- this algorithm is described in the following book:
- "The art of computer programming 2" (4.3.1 page 272)
- Donald E. Knuth
- !! give the description here (from the book)
- uint Div3Ref(const UInt<value_size> & v, UInt<value_size> * remainder = 0)
- uint m,n, test;
- test = Div_StandardTest(v, m, n, remainder);
- if( test < 2 )
- return test;
- if( n == 0 )
- uint r;
- DivInt( v.table[0], &r );
- if( remainder )
- TTMATH_LOG("UInt::Div3")
- return 0;
- // we can only use the third division algorithm when
- // the divisor is greater or equal 2^32 (has more than one 32-bit word)
- ++m;
- ++n;
- m = m - n;
- Div3_Division(v, remainder, m, n);
- return 0;
-private:
- void Div3_Division(UInt<value_size> v, UInt<value_size> * remainder, uint m, uint n)
- TTMATH_ASSERT( n>=2 )
- UInt<value_size+1> uu, vv;
- UInt<value_size> q;
- uint d, u_value_size, u0, u1, u2, v1, v0, j=m;
- u_value_size = Div3_Normalize(v, n, d);
- if( j+n == value_size )
- u2 = u_value_size;
- else
- u2 = table[j+n];
- Div3_MakeBiggerV(v, vv);
- for(uint i = j+1 ; i<value_size ; ++i)
- q.table[i] = 0;
- while( true )
- u1 = table[j+n-1];
- u0 = table[j+n-2];
- v1 = v.table[n-1];
- v0 = v.table[n-2];
- uint qp = Div3_Calculate(u2,u1,u0, v1,v0);
- Div3_MakeNewU(uu, j, n, u2);
- Div3_MultiplySubtract(uu, vv, qp);
- Div3_CopyNewU(uu, j, n);
- q.table[j] = qp;
- // the next loop
- if( j-- == 0 )
- break;
- u2 = table[j+n];
- if( remainder )
- Div3_Unnormalize(remainder, n, d);
- *this = q;
- TTMATH_LOG("UInt::Div3_Division")
- void Div3_MakeNewU(UInt<value_size+1> & uu, uint j, uint n, uint u_max)
- uint i;
- for(i=0 ; i<n ; ++i, ++j)
- uu.table[i] = table[j];
- // 'n' is from <1..value_size> so and 'i' is from <0..value_size>
- // then table[i] is always correct (look at the declaration of 'uu')
- uu.table[i] = u_max;
- for( ++i ; i<value_size+1 ; ++i)
- uu.table[i] = 0;
- TTMATH_LOG("UInt::Div3_MakeNewU")
- void Div3_CopyNewU(const UInt<value_size+1> & uu, uint j, uint n)
- uint i;
- for(i=0 ; i<n ; ++i)
- table[i+j] = uu.table[i];
- if( i+j < value_size )
- TTMATH_LOG("UInt::Div3_CopyNewU")
- we're making the new 'vv'
- the value is actually the same but the 'table' is bigger (value_size+1)
- void Div3_MakeBiggerV(const UInt<value_size> & v, UInt<value_size+1> & vv)
- vv.table[i] = v.table[i];
- vv.table[value_size] = 0;
- TTMATH_LOG("UInt::Div3_MakeBiggerV")
- we're moving all bits from 'v' into the left side of the n-1 word
- (the highest bit at v.table[n-1] will be equal one,
- the bits from 'this' we're moving the same times as 'v')
- return values:
- - d - how many times we've moved
- - return - the next-left value from 'this' (that after table[value_size-1])
- uint Div3_Normalize(UInt<value_size> & v, uint n, uint & d)
- // v.table[n-1] is != 0
- uint bit = (uint)FindLeadingBitInWord(v.table[n-1]);
- uint move = (TTMATH_BITS_PER_UINT - bit - 1);
- uint res = table[value_size-1];
- d = move;
- if( move > 0 )
- v.Rcl(move, 0);
- Rcl(move, 0);
- res = res >> (bit + 1);
- else
- res = 0;
- TTMATH_LOG("UInt::Div3_Normalize")
- return res;
- void Div3_Unnormalize(UInt<value_size> * remainder, uint n, uint d)
- for(uint i=n ; i<value_size ; ++i)
- table[i] = 0;
- Rcr(d,0);
- TTMATH_LOG("UInt::Div3_Unnormalize")
- uint Div3_Calculate(uint u2, uint u1, uint u0, uint v1, uint v0)
- UInt<2> u_temp;
- uint rp;
- bool next_test;
- TTMATH_ASSERT( v1 != 0 )
- u_temp.table[1] = u2;
- u_temp.table[0] = u1;
- u_temp.DivInt(v1, &rp);
- TTMATH_ASSERT( u_temp.table[1]==0 || u_temp.table[1]==1 )
- do
- bool decrease = false;
- if( u_temp.table[1] == 1 )
- decrease = true;
- else
- UInt<2> temp1, temp2;
- UInt<2>::MulTwoWords(u_temp.table[0], v0, temp1.table+1, temp1.table);
- temp2.table[1] = rp;
- temp2.table[0] = u0;
- if( temp1 > temp2 )
- decrease = true;
- next_test = false;
- if( decrease )
- u_temp.SubOne();
- rp += v1;
- if( rp >= v1 ) // it means that there wasn't a carry (r<b from the book)
- next_test = true;
- while( next_test );
- TTMATH_LOG("UInt::Div3_Calculate")
- return u_temp.table[0];
- void Div3_MultiplySubtract( UInt<value_size+1> & uu,
- const UInt<value_size+1> & vv, uint & qp)
- // D4 (in the book)
- UInt<value_size+1> vv_temp(vv);
- vv_temp.MulInt(qp);
- if( uu.Sub(vv_temp) )
- // there was a carry
- // !!! this part of code was not tested
- --qp;
- uu.Add(vv);
- // can be a carry from this additions but it should be ignored
- // because it cancels with the borrow from uu.Sub(vv_temp)
- TTMATH_LOG("UInt::Div3_MultiplySubtract")
-public:
- power this = this ^ pow
- binary algorithm (r-to-l)
- return values:
- - 0 - ok
- - 1 - carry
- - 2 - incorrect argument (0^0)
- uint Pow(UInt<value_size> pow)
- if(pow.IsZero() && IsZero())
- // we don't define zero^zero
- return 2;
- UInt<value_size> start(*this);
- UInt<value_size> result;
- result.SetOne();
- uint c = 0;
- while( !c )
- if( pow.table[0] & 1 )
- c += result.Mul(start);
- pow.Rcr2_one(0);
- if( pow.IsZero() )
- break;
- c += start.Mul(start);
- *this = result;
- TTMATH_LOGC("UInt::Pow(UInt<>)", c)
- square root
- e.g. Sqrt(9) = 3
- ('digit-by-digit' algorithm)
- void Sqrt()
- UInt<value_size> bit, temp;
- if( IsZero() )
- return;
- UInt<value_size> value(*this);
- SetZero();
- bit.SetZero();
- bit.table[value_size-1] = (TTMATH_UINT_HIGHEST_BIT >> 1);
- while( bit > value )
- bit.Rcr(2);
- while( !bit.IsZero() )
- temp = *this;
- temp.Add(bit);
- if( value >= temp )
- value.Sub(temp);
- Rcr(1);
- Add(bit);
- else
- Rcr(1);
- bit.Rcr(2);
- TTMATH_LOG("UInt::Sqrt")
- this method sets n first bits to value zero
- For example:
- let n=2 then if there's a value 111 (bin) there'll be '100' (bin)
- void ClearFirstBits(uint n)
- if( n >= value_size*TTMATH_BITS_PER_UINT )
- SetZero();
- TTMATH_LOG("UInt::ClearFirstBits")
- return;
- uint * p = table;
- // first we're clearing the whole words
- while( n >= TTMATH_BITS_PER_UINT )
- *p++ = 0;
- n -= TTMATH_BITS_PER_UINT;
- if( n == 0 )
- return;
- // and then we're clearing one word which has left
- // mask -- all bits are set to one
- mask = mask << n;
- (*p) &= mask;
- this method returns true if the highest bit of the value is set
- bool IsTheHighestBitSet() const
- return (table[value_size-1] & TTMATH_UINT_HIGHEST_BIT) != 0;
- this method returns true if the lowest bit of the value is set
- bool IsTheLowestBitSet() const
- return (*table & 1) != 0;
- returning true if only the highest bit is set
- bool IsOnlyTheHighestBitSet() const
-#ifdef __clang__
-#endif
- for(uint i=0 ; i<value_size-1 ; ++i)
- if( table[i] != 0 )
- return false;
-#ifdef __clang__
-#endif
- if( table[value_size-1] != TTMATH_UINT_HIGHEST_BIT )
- return false;
- return true;
- returning true if only the lowest bit is set
- bool IsOnlyTheLowestBitSet() const
- if( table[0] != 1 )
- return false;
- for(uint i=1 ; i<value_size ; ++i)
- return false;
- return true;
- this method returns true if the value is equal zero
- bool IsZero() const
- if(table[i] != 0)
- return false;
- return true;
- returning true if first 'bits' bits are equal zero
- bool AreFirstBitsZero(uint bits) const
- TTMATH_ASSERT( bits <= value_size * TTMATH_BITS_PER_UINT )
- uint index = bits / TTMATH_BITS_PER_UINT;
- uint rest = bits % TTMATH_BITS_PER_UINT;
- uint i;
- for(i=0 ; i<index ; ++i)
- if(table[i] != 0 )
- return false;
- if( rest == 0 )
- return true;
- uint mask = TTMATH_UINT_MAX_VALUE >> (TTMATH_BITS_PER_UINT - rest);
- return (table[i] & mask) == 0;
- * conversion methods
- this method converts an UInt<another_size> type to this class
- this operation has mainly sense if the value from p is
- equal or smaller than that one which is returned from UInt<value_size>::SetMax()
- it returns a carry if the value 'p' is too big
- template<uint argument_size>
- uint FromUInt(const UInt<argument_size> & p)
- uint min_size = (value_size < argument_size)? value_size : argument_size;
- uint i;
- for(i=0 ; i<min_size ; ++i)
- table[i] = p.table[i];
- if( value_size > argument_size )
- // 'this' is longer than 'p'
- for( ; i<value_size ; ++i)
- table[i] = 0;
- else
- for( ; i<argument_size ; ++i)
- if( p.table[i] != 0 )
- TTMATH_LOGC("UInt::FromUInt(UInt<>)", 1)
- return 1;
- TTMATH_LOGC("UInt::FromUInt(UInt<>)", 0)
- return 0;
- uint FromInt(const UInt<argument_size> & p)
- return FromUInt(p);
- this method converts the uint type to this class
- uint FromUInt(uint value)
- table[i] = 0;
- table[0] = value;
- TTMATH_LOG("UInt::FromUInt(uint)")
- // there'll never be a carry here
- return 0;
- uint FromInt(uint value)
- return FromUInt(value);
- this method converts the sint type to this class
- uint FromInt(sint value)
- uint c = FromUInt(uint(value));
- if( c || value < 0 )
- return 1;
- return 0;
- this operator converts an UInt<another_size> type to this class
- it doesn't return a carry
- UInt<value_size> & operator=(const UInt<argument_size> & p)
- FromUInt(p);
- return *this;
- the assignment operator
- UInt<value_size> & operator=(const UInt<value_size> & p)
- TTMATH_LOG("UInt::operator=(UInt<>)")
- return *this;
- UInt<value_size> & operator=(uint i)
- FromUInt(i);
- return *this;
- a constructor for converting the uint to this class
- UInt(uint i)
- FromUInt(i);
- UInt<value_size> & operator=(sint i)
- FromInt(i);
- return *this;
- a constructor for converting the sint to this class
- look at the description of UInt::operator=(sint)
- UInt(sint i)
- FromInt(i);
- this method converts unsigned 64 bit int type to this class
- ***this method is created only on a 32bit platform***
- uint FromUInt(ulint n)
- table[0] = (uint)n;
- if( value_size == 1 )
- uint c = ((n >> TTMATH_BITS_PER_UINT) == 0) ? 0 : 1;
- TTMATH_LOGC("UInt::FromUInt(ulint)", c)
- return c;
- table[1] = (uint)(n >> TTMATH_BITS_PER_UINT);
- for(uint i=2 ; i<value_size ; ++i)
- table[i] = 0;
- TTMATH_LOG("UInt::FromUInt(ulint)")
- return 0;
- uint FromInt(ulint n)
- return FromUInt(n);
- this method converts signed 64 bit int type to this class
- uint FromInt(slint n)
- uint c = FromUInt(ulint(n));
- if( c || n < 0 )
- return 1;
- return 0;
- this operator converts unsigned 64 bit int type to this class
- ***this operator is created only on a 32bit platform***
- UInt<value_size> & operator=(ulint n)
- FromUInt(n);
- return *this;
- a constructor for converting unsigned 64 bit int to this class
- ***this constructor is created only on a 32bit platform***
- UInt(ulint n)
- FromUInt(n);
- this operator converts signed 64 bit int type to this class
- UInt<value_size> & operator=(slint n)
- FromInt(n);
- return *this;
- a constructor for converting signed 64 bit int to this class
- UInt(slint n)
- FromInt(n);
-#endif
- this method converts 32 bit unsigned int type to this class
- ***this operator is created only on a 64bit platform***
- uint FromUInt(unsigned int i)
- return FromUInt(uint(i));
- uint FromInt(unsigned int i)
- this method converts 32 bit signed int type to this class
- uint FromInt(signed int i)
- return FromInt(sint(i));
- this operator converts 32 bit unsigned int type to this class
- UInt<value_size> & operator=(unsigned int i)
- FromUInt(i);
- return *this;
- a constructor for converting 32 bit unsigned int to this class
- ***this constructor is created only on a 64bit platform***
- UInt(unsigned int i)
- FromUInt(i);
- an operator for converting 32 bit signed int to this class
- UInt<value_size> & operator=(signed int i)
- FromInt(i);
- return *this;
- a constructor for converting 32 bit signed int to this class
- UInt(signed int i)
- FromInt(i);
-#endif
- a constructor for converting a string to this class (with the base=10)
- UInt(const char * s)
- FromString(s);
- UInt(const std::string & s)
- FromString( s.c_str() );
-#ifndef TTMATH_DONT_USE_WCHAR
- UInt(const wchar_t * s)
- FromString(s);
- UInt(const std::wstring & s)
-#endif
- a default constructor
- we don't clear the table
- UInt()
- // when macro TTMATH_DEBUG_LOG is defined
- // we set special values to the table
- // in order to be everywhere the same value of the UInt object
- // without this it would be difficult to analyse the log file
- table[i] = 0xc1c1c1c1;
- #else
- table[i] = 0xc1c1c1c1c1c1c1c1;
- #endif
- #endif
- a copy constructor
- UInt(const UInt<value_size> & u)
- table[i] = u.table[i];
- TTMATH_LOG("UInt::UInt(UInt<>)")
- a template for producting constructors for copying from another types
- UInt(const UInt<argument_size> & u)
- // look that 'size' we still set as 'value_size' and not as u.value_size
- FromUInt(u);
- a destructor
- ~UInt()
- this method returns the lowest value from table
- we must be sure when we using this method whether the value
- will hold in an uint type or not (the rest value from the table must be zero)
- uint ToUInt() const
- return table[0];
- this method converts the value to uint type
- can return a carry if the value is too long to store it in uint type
- uint ToUInt(uint & result) const
- result = table[0];
- return 1;
- return 0;
- uint ToInt(uint & result) const
- return ToUInt(result);
- this method converts the value to sint type (signed integer)
- can return a carry if the value is too long to store it in sint type
- uint ToInt(sint & result) const
- result = sint(table[0]);
- if( (result & TTMATH_UINT_HIGHEST_BIT) != 0 )
- return 1;
- return 1;
- return 0;
- this method converts the value to ulint type (64 bit unsigned integer)
- can return a carry if the value is too long to store it in ulint type
- *** this method is created only on a 32 bit platform ***
- uint ToUInt(ulint & result) const
- else
- uint low = table[0];
- uint high = table[1];
- result = low;
- result |= (ulint(high) << TTMATH_BITS_PER_UINT);
- return 1;
- return 0;
- uint ToInt(ulint & result) const
- this method converts the value to slint type (64 bit signed integer)
- can return a carry if the value is too long to store it in slint type
- uint ToInt(slint & result) const
- ulint temp;
- uint c = ToUInt(temp);
- result = slint(temp);
- if( c || result < 0 )
- return 1;
- return 0;
-#endif
- this method converts the value to a 32 unsigned integer
- can return a carry if the value is too long to store it in this type
- *** this method is created only on a 64 bit platform ***
- uint ToUInt(unsigned int & result) const
- result = (unsigned int)table[0];
- if( (table[0] >> 32) != 0 )
- return 1;
- return 1;
- return 0;
- uint ToInt(unsigned int & result) const
- this method converts the value to a 32 signed integer
- uint ToInt(int & result) const
- unsigned int temp;
- result = int(temp);
- return 1;
- return 0;
-#endif
-protected:
- an auxiliary method for converting into the string
- it returns the log (with the base 2) from x
- where x is in <2;16>
- double ToStringLog2(uint x) const
- static double log_tab[] = {
- 1.000000000000000000,
- 0.630929753571457437,
- 0.500000000000000000,
- 0.430676558073393050,
- 0.386852807234541586,
- 0.356207187108022176,
- 0.333333333333333333,
- 0.315464876785728718,
- 0.301029995663981195,
- 0.289064826317887859,
- 0.278942945651129843,
- 0.270238154427319741,
- 0.262649535037193547,
- 0.255958024809815489,
- 0.250000000000000000
- if( x<2 || x>16 )
- return 0;
- return log_tab[x-2];
-public:
- an auxiliary method for converting to a string
- it's used from Int::ToString() too (negative is set true then)
- template<class string_type>
- void ToStringBase(string_type & result, uint b = 10, bool negative = false) const
- UInt<value_size> temp(*this);
- uint rest, table_id, index, digits;
- double digits_d;
- char character;
- result.clear();
- if( b<2 || b>16 )
- return;
- result = '0';
- return;
- if( negative )
- result = '-';
- digits_d = static_cast<double>(table_id); // for not making an overflow in uint type
- digits_d *= TTMATH_BITS_PER_UINT;
- digits_d += index + 1;
- digits_d *= ToStringLog2(b);
- digits = static_cast<uint>(digits_d) + 3; // plus some epsilon
- if( result.capacity() < digits )
- result.reserve(digits);
- do
- temp.DivInt(b, &rest);
- character = static_cast<char>(Misc::DigitToChar(rest));
- result.insert(result.end(), character);
- while( !temp.IsZero() );
- size_t i1 = negative ? 1 : 0; // the first is a hyphen (when negative is true)
- size_t i2 = result.size() - 1;
- for( ; i1 < i2 ; ++i1, --i2 )
- char tempc = static_cast<char>(result[i1]);
- result[i1] = result[i2];
- result[i2] = tempc;
- this method converts the value to a string with a base equal 'b'
- void ToString(std::string & result, uint b = 10) const
- return ToStringBase(result, b);
- std::string ToString(uint b = 10) const
- std::string result;
- ToStringBase(result, b);
- return result;
- void ToString(std::wstring & result, uint b = 10) const
- std::wstring ToWString(uint b = 10) const
- std::wstring result;
- return result;
-#endif
-private:
- an auxiliary method for converting from a string
- template<class char_type>
- uint FromStringBase(const char_type * s, uint b = 10, const char_type ** after_source = 0, bool * value_read = 0)
- UInt<value_size> base( b );
- UInt<value_size> temp;
- sint z;
- uint c = 0;
- SetZero();
- temp.SetZero();
- Misc::SkipWhiteCharacters(s);
- if( after_source )
- *after_source = s;
- if( value_read )
- *value_read = false;
- if( b<2 || b>16 )
- return 1;
- for( ; (z=Misc::CharToDigit(*s, b)) != -1 ; ++s)
- if( value_read )
- *value_read = true;
- if( c == 0 )
- temp.table[0] = z;
- c += Mul(base); // !! IMPROVE ME: there can be used MulInt here
- c += Add(temp);
- TTMATH_LOGC("UInt::FromString", c)
-public:
- this method converts a string into its value
- it returns carry=1 if the value will be too big or an incorrect base 'b' is given
- string is ended with a non-digit value, for example:
- "12" will be translated to 12
- as well as:
- "12foo" will be translated to 12 too
- existing first white characters will be ommited
- if the value from s is too large the rest digits will be skipped
- after_source (if exists) is pointing at the end of the parsed string
- value_read (if exists) tells whether something has actually been read (at least one digit)
- uint FromString(const char * s, uint b = 10, const char ** after_source = 0, bool * value_read = 0)
- return FromStringBase(s, b, after_source, value_read);
- (it returns carry=1 if the value will be too big or an incorrect base 'b' is given)
- uint FromString(const std::string & s, uint b = 10)
- return FromString( s.c_str(), b );
- this operator converts a string into its value (with base = 10)
- UInt<value_size> & operator=(const char * s)
- FromString(s);
- return *this;
- UInt<value_size> & operator=(const std::string & s)
- return *this;
- uint FromString(const wchar_t * s, uint b = 10, const wchar_t ** after_source = 0, bool * value_read = 0)
- uint FromString(const std::wstring & s, uint b = 10)
- UInt<value_size> & operator=(const wchar_t * s)
- FromString(s);
- return *this;
- UInt<value_size> & operator=(const std::wstring & s)
- return *this;
-#endif
- * methods for comparing
- this method returns true if 'this' is smaller than 'l'
- 'index' is an index of the first word from will be the comparison performed
- (note: we start the comparison from back - from the last word, when index is -1 /default/
- it is automatically set into the last word)
- I introduced it for some kind of optimization made in the second division algorithm (Div2)
- bool CmpSmaller(const UInt<value_size> & l, sint index = -1) const
- sint i;
- if( index==-1 || index>=sint(value_size) )
- i = value_size - 1;
- else
- i = index;
- if( table[i] != l.table[i] )
- return table[i] < l.table[i];
- // they're equal
- return false;
- this method returns true if 'this' is bigger than 'l'
- bool CmpBigger(const UInt<value_size> & l, sint index = -1) const
- sint i;
- else
- i = index;
- return table[i] > l.table[i];
- // they're equal
- return false;
- this method returns true if 'this' is equal 'l'
- bool CmpEqual(const UInt<value_size> & l, sint index = -1) const
- sint i;
- else
- i = index;
- return false;
- return true;
- this method returns true if 'this' is smaller than or equal 'l'
- bool CmpSmallerEqual(const UInt<value_size> & l, sint index=-1) const
- sint i;
- else
- i = index;
- // they're equal
- return true;
- this method returns true if 'this' is bigger than or equal 'l'
- bool CmpBiggerEqual(const UInt<value_size> & l, sint index=-1) const
- sint i;
- else
- i = index;
- // they're equal
- return true;
- operators for comparising
- bool operator<(const UInt<value_size> & l) const
- return CmpSmaller(l);
- bool operator>(const UInt<value_size> & l) const
- return CmpBigger(l);
- bool operator==(const UInt<value_size> & l) const
- return CmpEqual(l);
- bool operator!=(const UInt<value_size> & l) const
- return !operator==(l);
- bool operator<=(const UInt<value_size> & l) const
- return CmpSmallerEqual(l);
- bool operator>=(const UInt<value_size> & l) const
- return CmpBiggerEqual(l);
- * standard mathematical operators
- UInt<value_size> operator-(const UInt<value_size> & p2) const
- temp.Sub(p2);
- return temp;
- UInt<value_size> & operator-=(const UInt<value_size> & p2)
- Sub(p2);
- return *this;
- UInt<value_size> operator+(const UInt<value_size> & p2) const
- temp.Add(p2);
- return temp;
- UInt<value_size> & operator+=(const UInt<value_size> & p2)
- Add(p2);
- return *this;
- UInt<value_size> operator*(const UInt<value_size> & p2) const
- temp.Mul(p2);
- return temp;
- UInt<value_size> & operator*=(const UInt<value_size> & p2)
- Mul(p2);
- return *this;
- UInt<value_size> operator/(const UInt<value_size> & p2) const
- temp.Div(p2);
- return temp;
- UInt<value_size> & operator/=(const UInt<value_size> & p2)
- Div(p2);
- return *this;
- UInt<value_size> operator%(const UInt<value_size> & p2) const
- UInt<value_size> remainder;
- temp.Div( p2, remainder );
- return remainder;
- UInt<value_size> & operator%=(const UInt<value_size> & p2)
- Div( p2, remainder );
- operator=(remainder);
- return *this;
- Prefix operator e.g ++variable
- UInt<value_size> & operator++()
- AddOne();
- return *this;
- Postfix operator e.g variable++
- UInt<value_size> operator++(int)
- UInt<value_size> temp( *this );
- AddOne();
- return temp;
- UInt<value_size> & operator--()
- SubOne();
- return *this;
- UInt<value_size> operator--(int)
- SubOne();
- return temp;
- * bitwise operators
- UInt<value_size> operator~() const
- temp.BitNot();
- return temp;
- UInt<value_size> operator&(const UInt<value_size> & p2) const
- temp.BitAnd(p2);
- return temp;
- UInt<value_size> & operator&=(const UInt<value_size> & p2)
- BitAnd(p2);
- return *this;
- UInt<value_size> operator|(const UInt<value_size> & p2) const
- temp.BitOr(p2);
- return temp;
- UInt<value_size> & operator|=(const UInt<value_size> & p2)
- BitOr(p2);
- return *this;
- UInt<value_size> operator^(const UInt<value_size> & p2) const
- temp.BitXor(p2);
- return temp;
- UInt<value_size> & operator^=(const UInt<value_size> & p2)
- BitXor(p2);
- return *this;
- UInt<value_size> operator>>(int move) const
- temp.Rcr(move);
- return temp;
- UInt<value_size> & operator>>=(int move)
- Rcr(move);
- return *this;
- UInt<value_size> operator<<(int move) const
- temp.Rcl(move);
- return temp;
- UInt<value_size> & operator<<=(int move)
- Rcl(move);
- return *this;
- * input/output operators for standard streams
- * (they are very simple, in the future they should be changed)
-private:
- an auxiliary method for outputing to standard streams
- template<class ostream_type, class string_type>
- static ostream_type & OutputToStream(ostream_type & s, const UInt<value_size> & l)
- string_type ss;
- l.ToString(ss);
- s << ss;
- return s;
-public:
- output to standard streams
- friend std::ostream & operator<<(std::ostream & s, const UInt<value_size> & l)
- return OutputToStream<std::ostream, std::string>(s, l);
- friend std::wostream & operator<<(std::wostream & s, const UInt<value_size> & l)
- return OutputToStream<std::wostream, std::wstring>(s, l);
-#endif
-private:
- an auxiliary method for reading from standard streams
- template<class istream_type, class string_type, class char_type>
- static istream_type & InputFromStream(istream_type & s, UInt<value_size> & l)
- string_type ss;
- // char or wchar_t for operator>>
- char_type z;
- // operator>> omits white characters if they're set for ommiting
- s >> z;
- // we're reading only digits (base=10)
- while( s.good() && Misc::CharToDigit(z, 10)>=0 )
- ss += z;
- z = static_cast<char_type>(s.get());
- // we're leaving the last read character
- // (it's not belonging to the value)
- s.unget();
- l.FromString(ss);
- return s;
-public:
- input from standard streams
- friend std::istream & operator>>(std::istream & s, UInt<value_size> & l)
- return InputFromStream<std::istream, std::string, char>(s, l);
- friend std::wistream & operator>>(std::wistream & s, UInt<value_size> & l)
- return InputFromStream<std::wistream, std::wstring, wchar_t>(s, l);
-#endif
- Following methods are defined in:
- ttmathuint_x86.h
- ttmathuint_x86_64.h
- ttmathuint_noasm.h
-#ifdef TTMATH_NOASM
- static uint AddTwoWords(uint a, uint b, uint carry, uint * result);
- static uint SubTwoWords(uint a, uint b, uint carry, uint * result);
- union uint_
- struct
- unsigned int low; // 32 bit
- unsigned int high; // 32 bit
- } u_;
- uint u; // 64 bit
- static void DivTwoWords2(uint a,uint b, uint c, uint * r, uint * rest);
- static uint DivTwoWordsNormalize(uint_ & a_, uint_ & b_, uint_ & c_);
- static uint DivTwoWordsUnnormalize(uint u, uint d);
- static unsigned int DivTwoWordsCalculate(uint_ u_, unsigned int u3, uint_ v_);
- static void MultiplySubtract(uint_ & u_, unsigned int & u3, unsigned int & q, uint_ v_);
-#endif // TTMATH_PLATFORM64
-#endif // TTMATH_NOASM
-private:
- uint Rcl2_one(uint c);
- uint Rcr2_one(uint c);
- uint Rcl2(uint bits, uint c);
- uint Rcr2(uint bits, uint c);
-public:
- static const char * LibTypeStr();
- static LibTypeCode LibType();
- uint Add(const UInt<value_size> & ss2, uint c=0);
- uint AddInt(uint value, uint index = 0);
- uint AddTwoInts(uint x2, uint x1, uint index);
- static uint AddVector(const uint * ss1, const uint * ss2, uint ss1_size, uint ss2_size, uint * result);
- uint Sub(const UInt<value_size> & ss2, uint c=0);
- uint SubInt(uint value, uint index = 0);
- static uint SubVector(const uint * ss1, const uint * ss2, uint ss1_size, uint ss2_size, uint * result);
- static sint FindLeadingBitInWord(uint x);
- static sint FindLowestBitInWord(uint x);
- static uint SetBitInWord(uint & value, uint bit);
- static void MulTwoWords(uint a, uint b, uint * result_high, uint * result_low);
- static void DivTwoWords(uint a,uint b, uint c, uint * r, uint * rest);
- this specialization is needed in order to not confuse the compiler "error: ISO C++ forbids zero-size array"
- when compiling Mul3Big2() method
-template<>
-class UInt<0>
-public:
- uint table[1];
- void Mul2Big(const UInt<0> &, UInt<0> &) { TTMATH_ASSERT(false) };
- void SetZero() { TTMATH_ASSERT(false) };
- uint AddTwoInts(uint, uint, uint) { TTMATH_ASSERT(false) return 0; };
-} //namespace
-#include "ttmathuint_x86.h"
-#include "ttmathuint_x86_64.h"
-#include "ttmathuint_noasm.h"
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmathuint_noasm.h b/include/geos/algorithm/ttmath/ttmathuint_noasm.h
deleted file mode 100644
index 96ab494..0000000
--- a/include/geos/algorithm/ttmath/ttmathuint_noasm.h
+++ /dev/null
@@ -1,1038 +0,0 @@
- * This file is a part of TTMath Bignum Library
- * and is distributed under the 3-Clause BSD Licence.
- * Author: Tomasz Sowa <t.sowa at ttmath.org>
- * Copyright (c) 2006-2010, Tomasz Sowa
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions are met:
- * * Redistributions of source code must retain the above copyright notice,
- * this list of conditions and the following disclaimer.
- * * Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in the
- * documentation and/or other materials provided with the distribution.
- * * Neither the name Tomasz Sowa nor the names of contributors to this
- * project may be used to endorse or promote products derived
- * from this software without specific prior written permission.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
- * THE POSSIBILITY OF SUCH DAMAGE.
-#ifndef headerfilettmathuint_noasm
-#define headerfilettmathuint_noasm
- \file ttmathuint_noasm.h
- \brief template class UInt<uint> with methods without any assembler code (used for no-asm version of ttmath)
- this file is included at the end of ttmathuint.h
-namespace ttmath
- returning the string represents the currect type of the library
- we have following types:
- - asm_vc_32 - with asm code designed for Microsoft Visual C++ (32 bits)
- - asm_gcc_32 - with asm code designed for GCC (32 bits)
- - asm_vc_64 - with asm for VC (64 bit)
- - asm_gcc_64 - with asm for GCC (64 bit)
- - no_asm_32 - pure C++ version (32 bit) - without any asm code
- - no_asm_64 - pure C++ version (64 bit) - without any asm code
- template<uint value_size>
- const char * UInt<value_size>::LibTypeStr()
- static const char info[] = "no_asm_32";
- #endif
- #ifdef TTMATH_PLATFORM64
- static const char info[] = "no_asm_64";
- #endif
- return info;
- returning the currect type of the library
- LibTypeCode UInt<value_size>::LibType()
- #ifdef TTMATH_PLATFORM32
- LibTypeCode info = no_asm_32;
- #endif
- LibTypeCode info = no_asm_64;
- #endif
- return info;
- this method adds two words together
- returns carry
- this method is created only when TTMATH_NOASM macro is defined
- uint UInt<value_size>::AddTwoWords(uint a, uint b, uint carry, uint * result)
- uint temp;
- if( carry == 0 )
- temp = a + b;
- if( temp < a )
- carry = 1;
- else
- carry = 1;
- temp = a + b + carry;
- if( temp > a ) // !(temp<=a)
- carry = 0;
- *result = temp;
- return carry;
- this method adding ss2 to the this and adding carry if it's defined
- (this = this + ss2 + c)
- c must be zero or one (might be a bigger value than 1)
- function returns carry (1) (if it was)
- uint UInt<value_size>::Add(const UInt<value_size> & ss2, uint c)
- uint i;
- c = AddTwoWords(table[i], ss2.table[i], c, &table[i]);
- TTMATH_LOGC("UInt::Add", c)
- return c;
- this method adds one word (at a specific position)
- and returns a carry (if it was)
- if we've got (value_size=3):
- table[0] = 10;
- table[1] = 30;
- table[2] = 5;
- and we call:
- AddInt(2,1)
- then it'll be:
- table[0] = 10;
- table[1] = 30 + 2;
- table[2] = 5;
- of course if there was a carry from table[2] it would be returned
- uint UInt<value_size>::AddInt(uint value, uint index)
- uint i, c;
- TTMATH_ASSERT( index < value_size )
- c = AddTwoWords(table[index], value, 0, &table[index]);
- for(i=index+1 ; i<value_size && c ; ++i)
- c = AddTwoWords(table[i], 0, c, &table[i]);
- TTMATH_LOGC("UInt::AddInt", c)
- return c;
- this method adds only two unsigned words to the existing value
- and these words begin on the 'index' position
- (it's used in the multiplication algorithm 2)
- index should be equal or smaller than value_size-2 (index <= value_size-2)
- x1 - lower word, x2 - higher word
- for example if we've got value_size equal 4 and:
- table[0] = 3
- table[1] = 4
- table[2] = 5
- table[3] = 6
- then let
- x1 = 10
- x2 = 20
- and
- index = 1
- the result of this method will be:
- table[0] = 3
- table[1] = 4 + x1 = 14
- table[2] = 5 + x2 = 25
- table[3] = 6
- and no carry at the end of table[3]
- (of course if there was a carry in table[2](5+20) then
- this carry would be passed to the table[3] etc.)
- uint UInt<value_size>::AddTwoInts(uint x2, uint x1, uint index)
- uint i, c;
- TTMATH_ASSERT( index < value_size - 1 )
- c = AddTwoWords(table[index], x1, 0, &table[index]);
- c = AddTwoWords(table[index+1], x2, c, &table[index+1]);
- for(i=index+2 ; i<value_size && c ; ++i)
- TTMATH_LOGC("UInt::AddTwoInts", c)
- return c;
- this static method addes one vector to the other
- 'ss1' is larger in size or equal to 'ss2'
- - ss1 points to the first (larger) vector
- - ss2 points to the second vector
- - ss1_size - size of the ss1 (and size of the result too)
- - ss2_size - size of the ss2
- - result - is the result vector (which has size the same as ss1: ss1_size)
- Example: ss1_size is 5, ss2_size is 3
- ss1: ss2: result (output):
- 5 1 5+1
- 4 3 4+3
- 2 7 2+7
- 6 6
- 9 9
- of course the carry is propagated and will be returned from the last item
- (this method is used by the Karatsuba multiplication algorithm)
- uint UInt<value_size>::AddVector(const uint * ss1, const uint * ss2, uint ss1_size, uint ss2_size, uint * result)
- uint i, c = 0;
- TTMATH_ASSERT( ss1_size >= ss2_size )
- for(i=0 ; i<ss2_size ; ++i)
- c = AddTwoWords(ss1[i], ss2[i], c, &result[i]);
- for( ; i<ss1_size ; ++i)
- c = AddTwoWords(ss1[i], 0, c, &result[i]);
- TTMATH_VECTOR_LOGC("UInt::AddVector", c, result, ss1_size)
- return c;
- this method subtractes one word from the other
- returns carry
- uint UInt<value_size>::SubTwoWords(uint a, uint b, uint carry, uint * result)
- if( carry == 0 )
- *result = a - b;
- if( a < b )
- carry = 1;
- else
- carry = 1;
- *result = a - b - carry;
- if( a > b ) // !(a <= b )
- carry = 0;
- return carry;
- this method's subtracting ss2 from the 'this' and subtracting
- carry if it has been defined
- (this = this - ss2 - c)
- uint UInt<value_size>::Sub(const UInt<value_size> & ss2, uint c)
- uint i;
- c = SubTwoWords(table[i], ss2.table[i], c, &table[i]);
- TTMATH_LOGC("UInt::Sub", c)
- return c;
- this method subtracts one word (at a specific position)
- table[0] = 10;
- table[1] = 30;
- table[2] = 5;
- and we call:
- SubInt(2,1)
- then it'll be:
- table[0] = 10;
- table[1] = 30 - 2;
- table[2] = 5;
- uint UInt<value_size>::SubInt(uint value, uint index)
- uint i, c;
- c = SubTwoWords(table[index], value, 0, &table[index]);
- c = SubTwoWords(table[i], 0, c, &table[i]);
- TTMATH_LOGC("UInt::SubInt", c)
- return c;
- this static method subtractes one vector from the other
- 5 1 5-1
- 4 3 4-3
- 2 7 2-7
- 6 6-1 (the borrow from previous item)
- 9 9
- return (carry): 0
- of course the carry (borrow) is propagated and will be returned from the last item
- uint UInt<value_size>::SubVector(const uint * ss1, const uint * ss2, uint ss1_size, uint ss2_size, uint * result)
- uint i, c = 0;
- c = SubTwoWords(ss1[i], ss2[i], c, &result[i]);
- c = SubTwoWords(ss1[i], 0, c, &result[i]);
- TTMATH_VECTOR_LOGC("UInt::SubVector", c, result, ss1_size)
- return c;
- this method moves all bits into the left hand side
- return value <- this <- c
- the lowest *bit* will be held the 'c' and
- the state of one additional bit (on the left hand side)
- will be returned
- for example:
- let this is 001010000
- after Rcl2_one(1) there'll be 010100001 and Rcl2_one returns 0
- uint UInt<value_size>::Rcl2_one(uint c)
- uint i, new_c;
- if( c != 0 )
- c = 1;
- new_c = (table[i] & TTMATH_UINT_HIGHEST_BIT) ? 1 : 0;
- table[i] = (table[i] << 1) | c;
- c = new_c;
- TTMATH_LOGC("UInt::Rcl2_one", c)
- return c;
- this method moves all bits into the right hand side
- the highest *bit* will be held the 'c' and
- the state of one additional bit (on the right hand side)
- will be returned
- for example:
- let this is 000000010
- after Rcr2_one(1) there'll be 100000001 and Rcr2_one returns 0
- uint UInt<value_size>::Rcr2_one(uint c)
- sint i; // signed i
- uint new_c;
- if( c != 0 )
- c = TTMATH_UINT_HIGHEST_BIT;
- for(i=sint(value_size)-1 ; i>=0 ; --i)
- new_c = (table[i] & 1) ? TTMATH_UINT_HIGHEST_BIT : 0;
- table[i] = (table[i] >> 1) | c;
- c = new_c;
- c = (c != 0)? 1 : 0;
- TTMATH_LOGC("UInt::Rcr2_one", c)
- return c;
- the lowest *bits* will be held the 'c' and
- will be returned
- for example:
- after Rcl2(3, 1) there'll be 010000111 and Rcl2 returns 1
- uint UInt<value_size>::Rcl2(uint bits, uint c)
- TTMATH_ASSERT( bits>0 && bits<TTMATH_BITS_PER_UINT )
- uint move = TTMATH_BITS_PER_UINT - bits;
- uint i, new_c;
- if( c != 0 )
- c = TTMATH_UINT_MAX_VALUE >> move;
- new_c = table[i] >> move;
- table[i] = (table[i] << bits) | c;
- c = new_c;
- TTMATH_LOGC("UInt::Rcl2", (c & 1))
- return (c & 1);
- C -> this -> return value
- the highest *bits* will be held the 'c' and
- will be returned
- for example:
- after Rcr2(2, 1) there'll be 110000000 and Rcr2 returns 1
- uint UInt<value_size>::Rcr2(uint bits, uint c)
- sint i; // signed
- uint new_c;
- if( c != 0 )
- c = TTMATH_UINT_MAX_VALUE << move;
- for(i=value_size-1 ; i>=0 ; --i)
- new_c = table[i] << move;
- table[i] = (table[i] >> bits) | c;
- c = new_c;
- c = (c & TTMATH_UINT_HIGHEST_BIT) ? 1 : 0;
- TTMATH_LOGC("UInt::Rcr2", c)
- return c;
- this method returns the number of the highest set bit in x
- if the 'x' is zero this method returns '-1'
- sint UInt<value_size>::FindLeadingBitInWord(uint x)
- if( x == 0 )
- return -1;
- uint bit = TTMATH_BITS_PER_UINT - 1;
- while( (x & TTMATH_UINT_HIGHEST_BIT) == 0 )
- x = x << 1;
- --bit;
- return bit;
- sint UInt<value_size>::FindLowestBitInWord(uint x)
- if( x == 0 )
- return -1;
- uint bit = 0;
- while( (x & 1) == 0 )
- x = x >> 1;
- ++bit;
- return bit;
- this method sets a special bit in the 'value'
- and returns the last state of the bit (zero or one)
- bit is from <0,TTMATH_BITS_PER_UINT-1>
- e.g.
- uint x = 100;
- uint bit = SetBitInWord(x, 3);
- now: x = 108 and bit = 0
- uint UInt<value_size>::SetBitInWord(uint & value, uint bit)
- TTMATH_ASSERT( bit < TTMATH_BITS_PER_UINT )
- uint mask = 1;
- if( bit > 0 )
- mask = mask << bit;
- uint last = value & mask;
- value = value | mask;
- return (last != 0) ? 1 : 0;
- * Multiplication
- multiplication: result_high:result_low = a * b
- - result_high - higher word of the result
- - result_low - lower word of the result
- this methos never returns a carry
- this method is used in the second version of the multiplication algorithms
- void UInt<value_size>::MulTwoWords(uint a, uint b, uint * result_high, uint * result_low)
- on 32bit platforms we have defined 'unsigned long long int' type known as 'ulint' in ttmath namespace
- this type has 64 bits, then we're using only one multiplication: 32bit * 32bit = 64bit
- union uint_
- struct
- uint low; // 32 bits
- uint high; // 32 bits
- } u_;
- ulint u; // 64 bits
- } res;
- res.u = ulint(a) * ulint(b); // multiply two 32bit words, the result has 64 bits
- *result_high = res.u_.high;
- *result_low = res.u_.low;
- #else
- 64 bits platforms
- we don't have a native type which has 128 bits
- then we're splitting 'a' and 'b' to 4 parts (high and low halves)
- and using 4 multiplications (with additions and carry correctness)
- uint_ a_;
- uint_ b_;
- uint_ res_high1, res_high2;
- uint_ res_low1, res_low2;
- a_.u = a;
- b_.u = b;
- the multiplication is as follows (schoolbook algorithm with O(n^2) ):
- 32 bits 32 bits
- | a_.u_.high | a_.u_.low |
- | b_.u_.high | b_.u_.low |
- | res_high1.u | res_low1.u |
- | res_high2.u | res_low2.u |
- 64 bits 64 bits
- uint_ temp;
- res_low1.u = uint(b_.u_.low) * uint(a_.u_.low);
- temp.u = uint(res_low1.u_.high) + uint(b_.u_.low) * uint(a_.u_.high);
- res_low1.u_.high = temp.u_.low;
- res_high1.u_.low = temp.u_.high;
- res_high1.u_.high = 0;
- res_low2.u_.low = 0;
- temp.u = uint(b_.u_.high) * uint(a_.u_.low);
- res_low2.u_.high = temp.u_.low;
- res_high2.u = uint(b_.u_.high) * uint(a_.u_.high) + uint(temp.u_.high);
- uint c = AddTwoWords(res_low1.u, res_low2.u, 0, &res_low2.u);
- AddTwoWords(res_high1.u, res_high2.u, c, &res_high2.u); // there is no carry from here
- *result_high = res_high2.u;
- *result_low = res_low2.u;
- #endif
- * Division
- this method calculates 64bits word a:b / 32bits c (a higher, b lower word)
- r = a:b / c and rest - remainder
- * WARNING:
- * the c has to be suitably large for the result being keeped in one word,
- * if c is equal zero there'll be a hardware interruption (0)
- * and probably the end of your program
- void UInt<value_size>::DivTwoWords(uint a, uint b, uint c, uint * r, uint * rest)
- // (a < c ) for the result to be one word
- TTMATH_ASSERT( c != 0 && a < c )
- union
- struct
- } u_;
- } ab;
- ab.u_.high = a;
- ab.u_.low = b;
- *r = uint(ab.u / c);
- *rest = uint(ab.u % c);
- #else
- uint_ c_;
- c_.u = c;
- if( a == 0 )
- *r = b / c;
- *rest = b % c;
- else
- if( c_.u_.high == 0 )
- // higher half of 'c' is zero
- // then higher half of 'a' is zero too (look at the asserts at the beginning - 'a' is smaller than 'c')
- uint_ a_, b_, res_, temp1, temp2;
- a_.u = a;
- b_.u = b;
- temp1.u_.high = a_.u_.low;
- temp1.u_.low = b_.u_.high;
- res_.u_.high = (unsigned int)(temp1.u / c);
- temp2.u_.high = (unsigned int)(temp1.u % c);
- temp2.u_.low = b_.u_.low;
- res_.u_.low = (unsigned int)(temp2.u / c);
- *rest = temp2.u % c;
- *r = res_.u;
- else
- return DivTwoWords2(a, b, c, r, rest);
- #endif
-#ifdef TTMATH_PLATFORM64
- this method is available only on 64bit platforms
- the same algorithm like the third division algorithm in ttmathuint.h
- but now with the radix=2^32
- void UInt<value_size>::DivTwoWords2(uint a, uint b, uint c, uint * r, uint * rest)
- // a is not zero
- // c_.u_.high is not zero
- uint_ a_, b_, c_, u_, q_;
- unsigned int u3; // 32 bit
- a_.u = a;
- b_.u = b;
- c_.u = c;
- // normalizing
- uint d = DivTwoWordsNormalize(a_, b_, c_);
- // loop from j=1 to j=0
- // the first step (for j=2) is skipped because our result is only in one word,
- // (first 'q' were 0 and nothing would be changed)
- u_.u_.high = a_.u_.high;
- u_.u_.low = a_.u_.low;
- u3 = b_.u_.high;
- q_.u_.high = DivTwoWordsCalculate(u_, u3, c_);
- MultiplySubtract(u_, u3, q_.u_.high, c_);
- u_.u_.high = u_.u_.low;
- u_.u_.low = u3;
- u3 = b_.u_.low;
- q_.u_.low = DivTwoWordsCalculate(u_, u3, c_);
- MultiplySubtract(u_, u3, q_.u_.low, c_);
- *r = q_.u;
- // unnormalizing for the remainder
- u_.u_.low = u3;
- *rest = DivTwoWordsUnnormalize(u_.u, d);
- uint UInt<value_size>::DivTwoWordsNormalize(uint_ & a_, uint_ & b_, uint_ & c_)
- uint d = 0;
- for( ; (c_.u & TTMATH_UINT_HIGHEST_BIT) == 0 ; ++d )
- c_.u = c_.u << 1;
- uint bc = b_.u & TTMATH_UINT_HIGHEST_BIT; // carry from 'b'
- b_.u = b_.u << 1;
- a_.u = a_.u << 1; // carry bits from 'a' are simply skipped
- if( bc )
- a_.u = a_.u | 1;
- return d;
- uint UInt<value_size>::DivTwoWordsUnnormalize(uint u, uint d)
- if( d == 0 )
- return u;
- u = u >> d;
- return u;
- unsigned int UInt<value_size>::DivTwoWordsCalculate(uint_ u_, unsigned int u3, uint_ v_)
- bool next_test;
- uint_ qp_, rp_, temp_;
- qp_.u = u_.u / uint(v_.u_.high);
- rp_.u = u_.u % uint(v_.u_.high);
- TTMATH_ASSERT( qp_.u_.high==0 || qp_.u_.high==1 )
- do
- if( qp_.u_.high == 1 )
- decrease = true;
- else
- temp_.u_.high = rp_.u_.low;
- temp_.u_.low = u3;
- if( qp_.u * uint(v_.u_.low) > temp_.u )
- decrease = true;
- if( decrease )
- --qp_.u;
- rp_.u += v_.u_.high;
- if( rp_.u_.high == 0 )
- next_test = true;
- return qp_.u_.low;
- void UInt<value_size>::MultiplySubtract(uint_ & u_, unsigned int & u3, unsigned int & q, uint_ v_)
- uint_ temp_;
- uint res_high;
- uint res_low;
- MulTwoWords(v_.u, q, &res_high, &res_low);
- uint_ sub_res_high_;
- uint_ sub_res_low_;
- temp_.u_.high = u_.u_.low;
- uint c = SubTwoWords(temp_.u, res_low, 0, &sub_res_low_.u);
- temp_.u_.high = 0;
- temp_.u_.low = u_.u_.high;
- c = SubTwoWords(temp_.u, res_high, c, &sub_res_high_.u);
- if( c )
- --q;
- c = AddTwoWords(sub_res_low_.u, v_.u, 0, &sub_res_low_.u);
- AddTwoWords(sub_res_high_.u, 0, c, &sub_res_high_.u);
- u_.u_.high = sub_res_high_.u_.low;
- u_.u_.low = sub_res_low_.u_.high;
- u3 = sub_res_low_.u_.low;
-#endif // #ifdef TTMATH_PLATFORM64
-} //namespace
-#endif //ifdef TTMATH_NOASM
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmathuint_x86.h b/include/geos/algorithm/ttmath/ttmathuint_x86.h
index 811b225..0000000
--- a/include/geos/algorithm/ttmath/ttmathuint_x86.h
+++ /dev/null
@@ -1,1620 +0,0 @@
- * Copyright (c) 2006-2009, Tomasz Sowa
-#ifndef headerfilettmathuint_x86
-#define headerfilettmathuint_x86
- \file ttmathuint_x86.h
- \brief template class UInt<uint> with assembler code for 32bit x86 processors
-#ifndef TTMATH_NOASM
-#ifdef TTMATH_PLATFORM32
- \brief a namespace for the TTMath library
-namespace ttmath
- #ifndef __GNUC__
- static const char info[] = "asm_vc_32";
- #endif
- #ifdef __GNUC__
- static const char info[] = "asm_gcc_32";
- #endif
- return info;
- #ifndef __GNUC__
- LibTypeCode info = asm_vc_32;
- #endif
- #ifdef __GNUC__
- LibTypeCode info = asm_gcc_32;
- #endif
- return info;
- * basic mathematic functions
- adding ss2 to the this and adding carry if it's defined
- function returns carry (1) (if it has been)
- uint b = value_size;
- uint * p1 = table;
- uint * p2 = const_cast<uint*>(ss2.table);
- // we don't have to use TTMATH_REFERENCE_ASSERT here
- // this algorithm doesn't require it
- #ifndef __GNUC__
- // this part might be compiled with for example visual c
- __asm
- push eax
- push ebx
- push ecx
- push edx
- push esi
- mov ecx,[b]
- mov ebx,[p1]
- mov esi,[p2]
- xor edx,edx // edx=0
- mov eax,[c]
- neg eax // CF=1 if rax!=0 , CF=0 if rax==0
- ttmath_loop:
- mov eax,[esi+edx*4]
- adc [ebx+edx*4],eax
- inc edx
- dec ecx
- jnz ttmath_loop
- adc ecx, ecx
- mov [c], ecx
- pop esi
- pop edx
- pop ecx
- pop ebx
- pop eax
- #endif
- #ifdef __GNUC__
- uint dummy, dummy2;
- // this part should be compiled with gcc
- __asm__ __volatile__(
- "xorl %%edx, %%edx \n"
- "negl %%eax \n" // CF=1 if rax!=0 , CF=0 if rax==0
- "1: \n"
- "movl (%%esi,%%edx,4), %%eax \n"
- "adcl %%eax, (%%ebx,%%edx,4) \n"
- "incl %%edx \n"
- "decl %%ecx \n"
- "jnz 1b \n"
- "adc %%ecx, %%ecx \n"
- : "=c" (c), "=a" (dummy), "=d" (dummy2)
- : "0" (b), "1" (c), "b" (p1), "S" (p2)
- : "cc", "memory" );
- #endif
- return c;
- adding one word (at a specific position)
- and returning a carry (if it has been)
- e.g.
- table[0] = 10;
- table[1] = 30;
- table[2] = 5;
- and we call:
- AddInt(2,1)
- then it'll be:
- table[0] = 10;
- table[2] = 5;
- uint c;
- #ifndef __GNUC__
- __asm
- push eax
- push ebx
- push ecx
- push edx
- mov ecx, [b]
- sub ecx, [index]
- mov edx, [index]
- mov ebx, [p1]
- mov eax, [value]
- ttmath_loop:
- add [ebx+edx*4], eax
- jnc ttmath_end
- mov eax, 1
- inc edx
- dec ecx
- jnz ttmath_loop
- ttmath_end:
- setc al
- movzx edx, al
- mov [c], edx
- pop edx
- pop ecx
- pop ebx
- pop eax
- #endif
- #ifdef __GNUC__
- "subl %%edx, %%ecx \n"
- "1: \n"
- "addl %%eax, (%%ebx,%%edx,4) \n"
- "jnc 2f \n"
- "movl $1, %%eax \n"
- "incl %%edx \n"
- "decl %%ecx \n"
- "jnz 1b \n"
- "2: \n"
- "setc %%al \n"
- "movzx %%al, %%edx \n"
- : "=d" (c), "=a" (dummy), "=c" (dummy2)
- : "0" (index), "1" (value), "2" (b), "b" (p1)
- #endif
- return c;
- adding only two unsigned words to the existing value
- table[0] = 3
- table[1] = 4
- table[2] = 5
- table[3] = 6
- then let
- x1 = 10
- x2 = 20
- and
- index = 1
- table[0] = 3
- table[3] = 6
- uint c;
- #ifndef __GNUC__
- __asm
- push eax
- push ebx
- push ecx
- push edx
- mov ecx, [b]
- sub ecx, [index]
- mov ebx, [p1]
- mov edx, [index]
- mov eax, [x1]
- inc edx
- dec ecx
- mov eax, [x2]
- ttmath_loop:
- adc [ebx+edx*4], eax
- jnc ttmath_end
- mov eax, 0
- inc edx
- dec ecx
- jnz ttmath_loop
- ttmath_end:
- setc al
- movzx edx, al
- mov [c], edx
- pop edx
- pop ecx
- pop ebx
- pop eax
- #endif
- #ifdef __GNUC__
- "addl %%esi, (%%ebx,%%edx,4) \n"
- "incl %%edx \n"
- "decl %%ecx \n"
- "1: \n"
- "jnc 2f \n"
- "mov $0, %%eax \n"
- "incl %%edx \n"
- "decl %%ecx \n"
- "jnz 1b \n"
- "2: \n"
- "setc %%al \n"
- "movzx %%al, %%eax \n"
- : "=a" (c), "=c" (dummy), "=d" (dummy2)
- : "0" (x2), "1" (b), "2" (index), "b" (p1), "S" (x1)
- #endif
- return c;
- 5 1 5+1
- 4 3 4+3
- 2 7 2+7
- 6 6
- 9 9
- uint rest = ss1_size - ss2_size;
- uint c;
- #ifndef __GNUC__
- __asm
- pushad
- mov ecx, [ss2_size]
- xor edx, edx // edx = 0, cf = 0
- mov esi, [ss1]
- mov ebx, [ss2]
- mov edi, [result]
- ttmath_loop:
- mov eax, [esi+edx*4]
- adc eax, [ebx+edx*4]
- mov [edi+edx*4], eax
- inc edx
- dec ecx
- jnz ttmath_loop
- adc ecx, ecx // ecx has the cf state
- mov ebx, [rest]
- or ebx, ebx
- jz ttmath_end
- xor ebx, ebx // ebx = 0
- neg ecx // setting cf from ecx
- mov ecx, [rest] // ecx is != 0
- ttmath_loop2:
- adc eax, ebx
- inc edx
- dec ecx
- jnz ttmath_loop2
- adc ecx, ecx
- ttmath_end:
- mov [c], ecx
- popad
- #endif
- #ifdef __GNUC__
- uint dummy1, dummy2, dummy3;
- "push %%edx \n"
- "xor %%edx, %%edx \n" // edx = 0, cf = 0
- "1: \n"
- "mov (%%esi,%%edx,4), %%eax \n"
- "adc (%%ebx,%%edx,4), %%eax \n"
- "mov %%eax, (%%edi,%%edx,4) \n"
- "inc %%edx \n"
- "dec %%ecx \n"
- "jnz 1b \n"
- "adc %%ecx, %%ecx \n" // ecx has the cf state
- "pop %%eax \n" // eax = rest
- "or %%eax, %%eax \n"
- "jz 3f \n"
- "xor %%ebx, %%ebx \n" // ebx = 0
- "neg %%ecx \n" // setting cf from ecx
- "mov %%eax, %%ecx \n" // ecx=rest and is != 0
- "2: \n"
- "mov (%%esi, %%edx, 4), %%eax \n"
- "adc %%ebx, %%eax \n"
- "mov %%eax, (%%edi, %%edx, 4) \n"
- "inc %%edx \n"
- "dec %%ecx \n"
- "jnz 2b \n"
- "3: \n"
- : "=a" (dummy1), "=b" (dummy2), "=c" (c), "=d" (dummy3)
- : "1" (ss2), "2" (ss2_size), "3" (rest), "S" (ss1), "D" (result)
- #endif
- return c;
- subtracting ss2 from the 'this' and subtracting
- #ifndef __GNUC__
- __asm
- push eax
- push ebx
- push ecx
- push edx
- push esi
- mov ecx,[b]
- mov ebx,[p1]
- mov esi,[p2]
- mov eax,[c]
- ttmath_loop:
- sbb [ebx+edx*4],eax
- inc edx
- dec ecx
- jnz ttmath_loop
- adc ecx, ecx
- mov [c], ecx
- pop esi
- pop edx
- pop ecx
- pop ebx
- pop eax
- #endif
- #ifdef __GNUC__
- "1: \n"
- "sbbl %%eax, (%%ebx,%%edx,4) \n"
- "incl %%edx \n"
- "decl %%ecx \n"
- "jnz 1b \n"
- #endif
- return c;
- e.g.
- table[0] = 10;
- table[1] = 30;
- table[2] = 5;
- and we call:
- SubInt(2,1)
- then it'll be:
- table[0] = 10;
- table[2] = 5;
- uint c;
- #ifndef __GNUC__
- __asm
- push eax
- push ebx
- push ecx
- push edx
- mov ecx, [b]
- sub ecx, [index]
- mov edx, [index]
- mov ebx, [p1]
- mov eax, [value]
- ttmath_loop:
- sub [ebx+edx*4], eax
- jnc ttmath_end
- mov eax, 1
- inc edx
- dec ecx
- jnz ttmath_loop
- ttmath_end:
- setc al
- movzx edx, al
- mov [c], edx
- pop edx
- pop ecx
- pop ebx
- pop eax
- #endif
- #ifdef __GNUC__
- "1: \n"
- "subl %%eax, (%%ebx,%%edx,4) \n"
- "jnc 2f \n"
- "incl %%edx \n"
- "decl %%ecx \n"
- "jnz 1b \n"
- "2: \n"
- "setc %%al \n"
- #endif
- return c;
- 5 1 5-1
- 4 3 4-3
- 2 7 2-7
- 9 9
- return (carry): 0
- uint c;
- #ifndef __GNUC__
- the asm code is nearly the same as in AddVector
- only two instructions 'adc' are changed to 'sbb'
- __asm
- pushad
- mov esi, [ss1]
- mov ebx, [ss2]
- mov edi, [result]
- ttmath_loop:
- sbb eax, [ebx+edx*4]
- inc edx
- dec ecx
- jnz ttmath_loop
- mov ebx, [rest]
- or ebx, ebx
- jz ttmath_end
- ttmath_loop2:
- sbb eax, ebx
- inc edx
- dec ecx
- jnz ttmath_loop2
- adc ecx, ecx
- ttmath_end:
- mov [c], ecx
- popad
- #endif
- #ifdef __GNUC__
- "push %%edx \n"
- "1: \n"
- "sbb (%%ebx,%%edx,4), %%eax \n"
- "inc %%edx \n"
- "dec %%ecx \n"
- "jnz 1b \n"
- "jz 3f \n"
- "2: \n"
- "sbb %%ebx, %%eax \n"
- "inc %%edx \n"
- "dec %%ecx \n"
- "jnz 2b \n"
- "3: \n"
- #endif
- return c;
- will be returned
- for example:
- #ifndef __GNUC__
- __asm
- push ebx
- push ecx
- push edx
- mov ebx, [p1]
- xor edx, edx
- mov ecx, [c]
- neg ecx
- mov ecx, [b]
- ttmath_loop:
- rcl dword ptr [ebx+edx*4], 1
- inc edx
- dec ecx
- jnz ttmath_loop
- adc ecx, ecx
- mov [c], ecx
- pop edx
- pop ecx
- pop ebx
- #endif
- #ifdef __GNUC__
- "xorl %%edx, %%edx \n" // edx=0
- "negl %%eax \n" // CF=1 if eax!=0 , CF=0 if eax==0
- "1: \n"
- "rcll $1, (%%ebx, %%edx, 4) \n"
- "incl %%edx \n"
- "decl %%ecx \n"
- "jnz 1b \n"
- "adcl %%ecx, %%ecx \n"
- #endif
- return c;
- c -> this -> return value
- will be returned
- for example:
- #ifndef __GNUC__
- __asm
- push ebx
- push ecx
- mov ebx, [p1]
- mov ecx, [c]
- neg ecx
- mov ecx, [b]
- ttmath_loop:
- rcr dword ptr [ebx+ecx*4-4], 1
- dec ecx
- jnz ttmath_loop
- adc ecx, ecx
- mov [c], ecx
- pop ecx
- pop ebx
- #endif
- #ifdef __GNUC__
- uint dummy;
- "1: \n"
- "rcrl $1, -4(%%ebx, %%ecx, 4) \n"
- "decl %%ecx \n"
- "jnz 1b \n"
- #endif
- return c;
-#ifdef _MSC_VER
-#pragma warning (disable : 4731)
-//warning C4731: frame pointer register 'ebp' modified by inline assembly code
-#endif
- will be returned
- for example:
- #ifndef __GNUC__
- __asm
- push eax
- push ebx
- push ecx
- push edx
- push esi
- push edi
- push ebp
- mov edi, [b]
- mov ecx, 32
- sub ecx, [bits]
- mov edx, -1
- shr edx, cl
- mov ecx, [bits]
- mov ebx, [p1]
- mov eax, [c]
- mov ebp, edx // ebp = mask (modified ebp - don't read/write to variables)
- mov esi, edx
- or eax, eax
- cmovnz esi, ebp // if(c) esi=mask else esi=0
- ttmath_loop:
- rol dword ptr [ebx+edx*4], cl
- mov eax, [ebx+edx*4]
- and eax, ebp
- xor [ebx+edx*4], eax // clearing bits
- or [ebx+edx*4], esi // saving old value
- mov esi, eax
- inc edx
- dec edi
- jnz ttmath_loop
- pop ebp // restoring ebp
- and eax, 1
- mov [c], eax
- pop edi
- pop esi
- pop edx
- pop ecx
- pop ebx
- pop eax
- #endif
- #ifdef __GNUC__
- uint dummy, dummy2, dummy3;
- "push %%ebp \n"
- "movl %%ecx, %%esi \n"
- "movl $32, %%ecx \n"
- "subl %%esi, %%ecx \n" // ecx = 32 - bits
- "movl $-1, %%edx \n" // edx = -1 (all bits set to one)
- "shrl %%cl, %%edx \n" // shifting (0 -> edx -> cf) (cl times)
- "movl %%edx, %%ebp \n" // ebp = edx = mask
- "movl %%esi, %%ecx \n"
- "movl %%edx, %%esi \n"
- "orl %%eax, %%eax \n"
- "cmovnz %%ebp, %%esi \n" // if(c) esi=mask else esi=0
- "1: \n"
- "roll %%cl, (%%ebx,%%edx,4) \n"
- "movl (%%ebx,%%edx,4), %%eax \n"
- "andl %%ebp, %%eax \n"
- "xorl %%eax, (%%ebx,%%edx,4) \n"
- "orl %%esi, (%%ebx,%%edx,4) \n"
- "movl %%eax, %%esi \n"
- "incl %%edx \n"
- "decl %%edi \n"
- "jnz 1b \n"
- "and $1, %%eax \n"
- "pop %%ebp \n"
- : "=a" (c), "=D" (dummy), "=S" (dummy2), "=d" (dummy3)
- : "0" (c), "1" (b), "b" (p1), "c" (bits)
- #endif
- TTMATH_LOGC("UInt::Rcl2", c)
- return c;
- will be returned
- for example:
- #ifndef __GNUC__
- __asm
- push eax
- push ebx
- push ecx
- push edx
- push esi
- push edi
- push ebp
- mov edi, [b]
- mov ecx, 32
- sub ecx, [bits]
- mov edx, -1
- shl edx, cl
- mov ecx, [bits]
- mov ebx, [p1]
- mov eax, [c]
- mov esi, edx
- add edx, edi
- dec edx // edx is pointing at the end of the table (on last word)
- or eax, eax
- ttmath_loop:
- ror dword ptr [ebx+edx*4], cl
- and eax, ebp
- mov esi, eax
- dec edx
- dec edi
- jnz ttmath_loop
- rol eax, 1 // 31bit will be first
- and eax, 1
- mov [c], eax
- pop edi
- pop esi
- pop edx
- pop ecx
- pop ebx
- pop eax
- #endif
- #ifdef __GNUC__
- "push %%ebp \n"
- "shll %%cl, %%edx \n" // shifting (cf <- edx <- 0) (cl times)
- "addl %%edi, %%edx \n"
- "decl %%edx \n" // edx is pointing at the end of the table (on last word)
- "1: \n"
- "rorl %%cl, (%%ebx,%%edx,4) \n"
- "decl %%edx \n"
- "decl %%edi \n"
- "jnz 1b \n"
- "roll $1, %%eax \n"
- "andl $1, %%eax \n"
- "pop %%ebp \n"
- #endif
- return c;
-#ifdef _MSC_VER
-#pragma warning (default : 4731)
-#endif
- this method returns the number of the highest set bit in one 32-bit word
- sint result;
- #ifndef __GNUC__
- __asm
- push eax
- push edx
- mov edx,-1
- bsr eax,[x]
- cmovz eax,edx
- mov [result], eax
- pop edx
- pop eax
- #endif
- #ifdef __GNUC__
- uint dummy;
- __asm__ (
- "movl $-1, %1 \n"
- "bsrl %2, %0 \n"
- "cmovz %1, %0 \n"
- : "=r" (result), "=&r" (dummy)
- : "r" (x)
- : "cc" );
- #endif
- return result;
- this method returns the number of the smallest set bit in one 32-bit word
- sint result;
- #ifndef __GNUC__
- __asm
- push eax
- push edx
- mov edx,-1
- bsf eax,[x]
- cmovz eax,edx
- mov [result], eax
- pop edx
- pop eax
- #endif
- #ifdef __GNUC__
- uint dummy;
- __asm__ (
- "movl $-1, %1 \n"
- "bsfl %2, %0 \n"
- "cmovz %1, %0 \n"
- : "r" (x)
- : "cc" );
- #endif
- return result;
- bit is from <0,31>
- e.g.
- uint x = 100;
- uint old_bit;
- uint v = value;
- #ifndef __GNUC__
- __asm
- push ebx
- push eax
- mov eax, [v]
- mov ebx, [bit]
- bts eax, ebx
- mov [v], eax
- setc bl
- movzx ebx, bl
- mov [old_bit], ebx
- pop eax
- pop ebx
- #endif
- #ifdef __GNUC__
- __asm__ (
- "btsl %%ebx, %%eax \n"
- "setc %%bl \n"
- "movzx %%bl, %%ebx \n"
- : "=a" (v), "=b" (old_bit)
- : "0" (v), "1" (bit)
- : "cc" );
- #endif
- value = v;
- return old_bit;
- we must use these temporary variables in order to inform the compilator
- that value pointed with result1 and result2 has changed
- this has no effect in visual studio but it's useful when
- using gcc and options like -Ox
- uint result1_;
- uint result2_;
- #ifndef __GNUC__
- __asm
- push eax
- push edx
- mov eax, [a]
- mul dword ptr [b]
- mov [result2_], edx
- mov [result1_], eax
- pop edx
- pop eax
- #endif
- #ifdef __GNUC__
- __asm__ (
- "mull %%edx \n"
- : "=a" (result1_), "=d" (result2_)
- : "0" (a), "1" (b)
- : "cc" );
- #endif
- *result_low = result1_;
- *result_high = result2_;
- * Division
- * WARNING:
- * if r (one word) is too small for the result or c is equal zero
- * there'll be a hardware interruption (0)
- uint r_;
- uint rest_;
- these variables have similar meaning like those in
- the multiplication algorithm MulTwoWords
- TTMATH_ASSERT( c != 0 )
- #ifndef __GNUC__
- __asm
- push eax
- push edx
- mov edx, [a]
- mov eax, [b]
- div dword ptr [c]
- mov [r_], eax
- mov [rest_], edx
- pop edx
- pop eax
- #endif
- #ifdef __GNUC__
- __asm__ (
- "divl %%ecx \n"
- : "=a" (r_), "=d" (rest_)
- : "0" (b), "1" (a), "c" (c)
- : "cc" );
- #endif
- *r = r_;
- *rest = rest_;
-} //namespace
-#endif //ifdef TTMATH_PLATFORM32
-#endif //ifndef TTMATH_NOASM
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmathuint_x86_64.h b/include/geos/algorithm/ttmath/ttmathuint_x86_64.h
index 7ec501d..0000000
--- a/include/geos/algorithm/ttmath/ttmathuint_x86_64.h
+++ /dev/null
@@ -1,1177 +0,0 @@
-#ifndef headerfilettmathuint_x86_64
-#define headerfilettmathuint_x86_64
- \file ttmathuint_x86_64.h
- \brief template class UInt<uint> with assembler code for 64bit x86_64 processors
- \file ttmathuint_x86_64_msvc.asm
- \brief some asm routines for x86_64 when using Microsoft compiler
- this file should be first compiled:
- - compile with debug info: ml64.exe /c /Zd /Zi ttmathuint_x86_64_msvc.asm
- - compile without debug info: ml64.exe /c ttmathuint_x86_64_msvc.asm
- this creates ttmathuint_x86_64_msvc.obj file which can be linked with your program
- (you can use win64_assemble.bat file from ttmath subdirectory)
-#ifndef __GNUC__
-#include <intrin.h>
-#endif
-namespace ttmath
- #ifndef __GNUC__
- extern "C"
- uint __fastcall ttmath_adc_x64(uint* p1, const uint* p2, uint nSize, uint c);
- uint __fastcall ttmath_addindexed_x64(uint* p1, uint nSize, uint nPos, uint nValue);
- uint __fastcall ttmath_addindexed2_x64(uint* p1, uint nSize, uint nPos, uint nValue1, uint nValue2);
- uint __fastcall ttmath_addvector_x64(const uint * ss1, const uint * ss2, uint ss1_size, uint ss2_size, uint * result);
- uint __fastcall ttmath_sbb_x64(uint* p1, const uint* p2, uint nSize, uint c);
- uint __fastcall ttmath_subindexed_x64(uint* p1, uint nSize, uint nPos, uint nValue);
- uint __fastcall ttmath_subvector_x64(const uint * ss1, const uint * ss2, uint ss1_size, uint ss2_size, uint * result);
- uint __fastcall ttmath_rcl_x64(uint* p1, uint nSize, uint nLowestBit);
- uint __fastcall ttmath_rcr_x64(uint* p1, uint nSize, uint nLowestBit);
- uint __fastcall ttmath_div_x64(uint* pnValHi, uint* pnValLo, uint nDiv);
- uint __fastcall ttmath_rcl2_x64(uint* p1, uint nSize, uint nBits, uint c);
- uint __fastcall ttmath_rcr2_x64(uint* p1, uint nSize, uint nBits, uint c);
- #endif
- #ifndef __GNUC__
- static const char info[] = "asm_vc_64";
- #endif
- #ifdef __GNUC__
- static const char info[] = "asm_gcc_64";
- #endif
- return info;
- #ifndef __GNUC__
- LibTypeCode info = asm_vc_64;
- #endif
- #ifdef __GNUC__
- LibTypeCode info = asm_gcc_64;
- #endif
- return info;
- ***this method is created only on a 64bit platform***
- const uint * p2 = ss2.table;
- #ifndef __GNUC__
- c = ttmath_adc_x64(p1,p2,b,c);
- #endif
- #ifdef __GNUC__
- this part should be compiled with gcc
- "xorq %%rdx, %%rdx \n"
- "negq %%rax \n" // CF=1 if rax!=0 , CF=0 if rax==0
- "1: \n"
- "movq (%%rsi,%%rdx,8), %%rax \n"
- "adcq %%rax, (%%rbx,%%rdx,8) \n"
- "incq %%rdx \n"
- "decq %%rcx \n"
- "jnz 1b \n"
- "adcq %%rcx, %%rcx \n"
- #endif
- return c;
- table[0] = 10;
- table[1] = 30;
- table[2] = 5;
- and we call:
- AddInt(2,1)
- then it'll be:
- table[0] = 10;
- table[2] = 5;
- uint c;
- #ifndef __GNUC__
- c = ttmath_addindexed_x64(p1,b,index,value);
- #endif
- #ifdef __GNUC__
- "subq %%rdx, %%rcx \n"
- "1: \n"
- "addq %%rax, (%%rbx,%%rdx,8) \n"
- "jnc 2f \n"
- "movq $1, %%rax \n"
- "incq %%rdx \n"
- "decq %%rcx \n"
- "jnz 1b \n"
- "2: \n"
- "setc %%al \n"
- "movzx %%al, %%rdx \n"
- #endif
- return c;
- table[0] = 3
- table[1] = 4
- table[2] = 5
- table[3] = 6
- then let
- x1 = 10
- x2 = 20
- and
- index = 1
- table[0] = 3
- table[3] = 6
- uint c;
- #ifndef __GNUC__
- c = ttmath_addindexed2_x64(p1,b,index,x1,x2);
- #endif
- #ifdef __GNUC__
- "addq %%rsi, (%%rbx,%%rdx,8) \n"
- "incq %%rdx \n"
- "decq %%rcx \n"
- "1: \n"
- "jnc 2f \n"
- "mov $0, %%rax \n"
- "incq %%rdx \n"
- "decq %%rcx \n"
- "jnz 1b \n"
- "2: \n"
- "setc %%al \n"
- "movzx %%al, %%rax \n"
- #endif
- return c;
- 5 1 5+1
- 4 3 4+3
- 2 7 2+7
- 6 6
- 9 9
- uint c;
- #ifndef __GNUC__
- c = ttmath_addvector_x64(ss1, ss2, ss1_size, ss2_size, result);
- #endif
- #ifdef __GNUC__
- "mov %%rdx, %%r8 \n"
- "xor %%rdx, %%rdx \n" // rdx = 0, cf = 0
- "1: \n"
- "mov (%%rsi,%%rdx,8), %%rax \n"
- "adc (%%rbx,%%rdx,8), %%rax \n"
- "mov %%rax, (%%rdi,%%rdx,8) \n"
- "inc %%rdx \n"
- "dec %%rcx \n"
- "jnz 1b \n"
- "adc %%rcx, %%rcx \n" // rcx has the cf state
- "or %%r8, %%r8 \n"
- "jz 3f \n"
- "xor %%rbx, %%rbx \n" // ebx = 0
- "neg %%rcx \n" // setting cf from rcx
- "mov %%r8, %%rcx \n" // rcx=rest and is != 0
- "2: \n"
- "mov (%%rsi, %%rdx, 8), %%rax \n"
- "adc %%rbx, %%rax \n"
- "mov %%rax, (%%rdi, %%rdx, 8) \n"
- "inc %%rdx \n"
- "dec %%rcx \n"
- "jnz 2b \n"
- "3: \n"
- : "%r8", "cc", "memory" );
- #endif
- return c;
- #ifndef __GNUC__
- c = ttmath_sbb_x64(p1,p2,b,c);
- #endif
- #ifdef __GNUC__
- "1: \n"
- "sbbq %%rax, (%%rbx,%%rdx,8) \n"
- "incq %%rdx \n"
- "decq %%rcx \n"
- "jnz 1b \n"
- #endif
- return c;
- table[0] = 10;
- table[1] = 30;
- table[2] = 5;
- and we call:
- SubInt(2,1)
- then it'll be:
- table[0] = 10;
- table[2] = 5;
- uint c;
- #ifndef __GNUC__
- c = ttmath_subindexed_x64(p1,b,index,value);
- #endif
- #ifdef __GNUC__
- "1: \n"
- "subq %%rax, (%%rbx,%%rdx,8) \n"
- "jnc 2f \n"
- "incq %%rdx \n"
- "decq %%rcx \n"
- "jnz 1b \n"
- "2: \n"
- "setc %%al \n"
- #endif
- return c;
- 5 1 5-1
- 4 3 4-3
- 2 7 2-7
- 9 9
- return (carry): 0
- uint c;
- #ifndef __GNUC__
- c = ttmath_subvector_x64(ss1, ss2, ss1_size, ss2_size, result);
- #endif
- #ifdef __GNUC__
- // the asm code is nearly the same as in AddVector
- // only two instructions 'adc' are changed to 'sbb'
- "1: \n"
- "sbb (%%rbx,%%rdx,8), %%rax \n"
- "inc %%rdx \n"
- "dec %%rcx \n"
- "jnz 1b \n"
- "jz 3f \n"
- "2: \n"
- "sbb %%rbx, %%rax \n"
- "inc %%rdx \n"
- "dec %%rcx \n"
- "jnz 2b \n"
- "3: \n"
- #endif
- return c;
- will be returned
- for example:
- sint b = value_size;
- #ifndef __GNUC__
- c = ttmath_rcl_x64(p1,b,c);
- #endif
- #ifdef __GNUC__
- "xorq %%rdx, %%rdx \n" // rdx=0
- "1: \n"
- "rclq $1, (%%rbx, %%rdx, 8) \n"
- "incq %%rdx \n"
- "decq %%rcx \n"
- "jnz 1b \n"
- #endif
- return c;
- will be returned
- for example:
- #ifndef __GNUC__
- c = ttmath_rcr_x64(p1,b,c);
- #endif
- #ifdef __GNUC__
- uint dummy;
- "1: \n"
- "rcrq $1, -8(%%rbx, %%rcx, 8) \n"
- "decq %%rcx \n"
- "jnz 1b \n"
- #endif
- return c;
- will be returned
- for example:
- #ifndef __GNUC__
- c = ttmath_rcl2_x64(p1,b,bits,c);
- #endif
- #ifdef __GNUC__
- "movq %%rcx, %%rsi \n"
- "movq $64, %%rcx \n"
- "subq %%rsi, %%rcx \n"
- "movq $-1, %%rdx \n"
- "shrq %%cl, %%rdx \n"
- "movq %%rdx, %%r8 \n"
- "movq %%rsi, %%rcx \n"
- "movq %%rdx, %%rsi \n"
- "orq %%rax, %%rax \n"
- "cmovnz %%r8, %%rsi \n"
- "1: \n"
- "rolq %%cl, (%%rbx,%%rdx,8) \n"
- "movq (%%rbx,%%rdx,8), %%rax \n"
- "andq %%r8, %%rax \n"
- "xorq %%rax, (%%rbx,%%rdx,8) \n"
- "orq %%rsi, (%%rbx,%%rdx,8) \n"
- "movq %%rax, %%rsi \n"
- "incq %%rdx \n"
- "decq %%rdi \n"
- "jnz 1b \n"
- "and $1, %%rax \n"
- #endif
- return c;
- will be returned
- for example:
- #ifndef __GNUC__
- c = ttmath_rcr2_x64(p1,b,bits,c);
- #endif
- #ifdef __GNUC__
- "shlq %%cl, %%rdx \n"
- "movq %%rdx, %%R8 \n"
- "addq %%rdi, %%rdx \n"
- "decq %%rdx \n"
- "cmovnz %%R8, %%rsi \n"
- "1: \n"
- "rorq %%cl, (%%rbx,%%rdx,8) \n"
- "andq %%R8, %%rax \n"
- "decq %%rdx \n"
- "decq %%rdi \n"
- "jnz 1b \n"
- "rolq $1, %%rax \n"
- "andq $1, %%rax \n"
- #endif
- return c;
- this method returns the number of the highest set bit in one 64-bit word
- sint result;
- #ifndef __GNUC__
- unsigned long nIndex = 0;
- if( _BitScanReverse64(&nIndex,x) == 0 )
- result = -1;
- else
- result = nIndex;
- #endif
- #ifdef __GNUC__
- uint dummy;
- __asm__ (
- "movq $-1, %1 \n"
- "bsrq %2, %0 \n"
- "cmovz %1, %0 \n"
- : "r" (x)
- : "cc" );
- #endif
- return result;
- sint result;
- #ifndef __GNUC__
- if( _BitScanForward64(&nIndex,x) == 0 )
- result = -1;
- else
- result = nIndex;
- #endif
- #ifdef __GNUC__
- uint dummy;
- __asm__ (
- "movq $-1, %1 \n"
- "bsfq %2, %0 \n"
- "cmovz %1, %0 \n"
- : "r" (x)
- : "cc" );
- #endif
- return result;
- bit is from <0,63>
- e.g.
- uint x = 100;
- uint old_bit;
- uint v = value;
- #ifndef __GNUC__
- old_bit = _bittestandset64((__int64*)&value,bit) != 0;
- #endif
- #ifdef __GNUC__
- __asm__ (
- "btsq %%rbx, %%rax \n"
- "setc %%bl \n"
- "movzx %%bl, %%rbx \n"
- : "cc" );
- #endif
- value = v;
- return old_bit;
- * Multiplication
- this has no effect in visual studio but it's usefull when
- uint result1_;
- uint result2_;
- #ifndef __GNUC__
- result1_ = _umul128(a,b,&result2_);
- #endif
- #ifdef __GNUC__
- __asm__ (
- "mulq %%rdx \n"
- : "cc" );
- #endif
- * Division
- * WARNING:
- void UInt<value_size>::DivTwoWords(uint a,uint b, uint c, uint * r, uint * rest)
- uint r_;
- uint rest_;
- #ifndef __GNUC__
- ttmath_div_x64(&a,&b,c);
- r_ = a;
- rest_ = b;
- #endif
- #ifdef __GNUC__
- __asm__ (
- "divq %%rcx \n"
- : "d" (a), "a" (b), "c" (c)
- : "cc" );
- #endif
- *r = r_;
- *rest = rest_;
-} //namespace
-#endif //ifdef TTMATH_PLATFORM64
-#endif
diff --git a/include/geos/algorithm/ttmath/ttmathuint_x86_64_msvc.asm b/include/geos/algorithm/ttmath/ttmathuint_x86_64_msvc.asm
index 2f23a63..0000000
--- a/include/geos/algorithm/ttmath/ttmathuint_x86_64_msvc.asm
+++ /dev/null
@@ -1,551 +0,0 @@
-; This file is a part of TTMath Bignum Library
-; and is distributed under the 3-Clause BSD Licence.
-; Author: Christian Kaiser <chk at online.de>, Tomasz Sowa <t.sowa at ttmath.org>
-; Copyright (c) 2009-2017, Christian Kaiser, Tomasz Sowa
-; All rights reserved.
-; Redistribution and use in source and binary forms, with or without
-; modification, are permitted provided that the following conditions are met:
-; * Redistributions of source code must retain the above copyright notice,
-; this list of conditions and the following disclaimer.
-; * Redistributions in binary form must reproduce the above copyright
-; notice, this list of conditions and the following disclaimer in the
-; documentation and/or other materials provided with the distribution.
-; * Neither the name Christian Kaiser nor the names of contributors to this
-; project may be used to endorse or promote products derived
-; from this software without specific prior written permission.
-; THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-; AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-; IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-; ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
-; LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-; CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-; SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-; INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-; CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-; ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
-; THE POSSIBILITY OF SUCH DAMAGE.
-; compile with debug info: ml64.exe /c /Zd /Zi ttmathuint_x86_64_msvc.asm
-; compile without debug info: ml64.exe /c ttmathuint_x86_64_msvc.asm
-; this creates ttmathuint_x86_64_msvc.obj file which can be linked with your program
-; doxygen info is put to ttmathuint_x86_64.h file
-PUBLIC ttmath_adc_x64
-PUBLIC ttmath_addindexed_x64
-PUBLIC ttmath_addindexed2_x64
-PUBLIC ttmath_addvector_x64
-PUBLIC ttmath_sbb_x64
-PUBLIC ttmath_subindexed_x64
-PUBLIC ttmath_subvector_x64
-PUBLIC ttmath_rcl_x64
-PUBLIC ttmath_rcr_x64
-PUBLIC ttmath_rcl2_x64
-PUBLIC ttmath_rcr2_x64
-PUBLIC ttmath_div_x64
-; Microsoft x86_64 convention: http://msdn.microsoft.com/en-us/library/9b372w95.aspx
-; "rax, rcx, rdx, r8-r11 are volatile."
-; "rbx, rbp, rdi, rsi, r12-r15 are nonvolatile."
-.CODE
- ALIGN 8
-ttmath_adc_x64 PROC
- ; rcx = p1
- ; rdx = p2
- ; r8 = nSize
- ; r9 = nCarry
- xor rax, rax
- xor r11, r11
- sub rax, r9 ; sets CARRY if r9 != 0
- ALIGN 16
- loop1:
- mov rax,qword ptr [rdx + r11 * 8]
- adc qword ptr [rcx + r11 * 8], rax
- lea r11, [r11+1]
- dec r8
- jnz loop1
- setc al
- movzx rax, al
- ret
-ttmath_adc_x64 ENDP
- ALIGN 8
-ttmath_addindexed_x64 PROC
- ; rcx = p1
- ; rdx = nSize
- ; r8 = nPos
- ; r9 = nValue
- xor rax, rax ; rax = result
- sub rdx, r8 ; rdx = remaining count of uints
- add qword ptr [rcx + r8 * 8], r9
- jc next1
- ret
-next1:
- mov r9, 1
- ALIGN 16
-loop1:
- dec rdx
- jz done_with_cy
- lea r8, [r8+1]
- jc loop1
- ret
-done_with_cy:
- lea rax, [rax+1] ; rax = 1
- ret
-ttmath_addindexed_x64 ENDP
- ALIGN 8
-ttmath_addindexed2_x64 PROC
- ; rcx = p1 (pointer)
- ; rdx = b (value size)
- ; r8 = nPos
- ; r9 = nValue1
- ; [rsp+0x28] = nValue2
- xor rax, rax ; return value
- mov r11, rcx ; table
- mov r10, [rsp+028h] ; r10 = nValue2
- add qword ptr [r11 + r8 * 8], r9
- lea r8, [r8+1]
- lea rdx, [rdx-1]
- adc qword ptr [r11 + r8 * 8], r10
- jc next
- ret
- ALIGN 16
-loop1:
- lea r8, [r8+1]
- add qword ptr [r11 + r8 * 8], 1
- jc next
- ret
-next:
- dec rdx ; does not modify CY too...
- jnz loop1
- lea rax, [rax+1]
- ret
-ttmath_addindexed2_x64 ENDP
- ALIGN 8
-ttmath_addvector_x64 PROC
- ; rcx = ss1
- ; rdx = ss2
- ; r8 = ss1_size
- ; r9 = ss2_size
- ; [rsp+0x28] = result
- sub r8, r9
- xor r11, r11 ; r11=0, cf=0
- ALIGN 16
- loop1:
- mov rax, qword ptr [rcx + r11 * 8]
- adc rax, qword ptr [rdx + r11 * 8]
- mov qword ptr [r10 + r11 * 8], rax
- inc r11
- dec r9
- jnz loop1
- adc r9, r9 ; r9 has the cf state
- or r8, r8
- jz done
- neg r9 ; setting cf from r9
- mov r9, 0 ; don't use xor here (cf is used)
- loop2:
- adc rax, r9
- inc r11
- dec r8
- jnz loop2
- adc r8, r8
- mov rax, r8
- ret
-done:
- mov rax, r9
- ret
-ttmath_addvector_x64 ENDP
- ALIGN 8
-ttmath_sbb_x64 PROC
- ; rcx = p1
- ; rdx = p2
- ; r8 = nCount
- ; r9 = nCarry
- xor rax, rax
- xor r11, r11
- ALIGN 16
- loop1:
- sbb qword ptr [rcx + r11 * 8], rax
- lea r11, [r11+1]
- dec r8
- jnz loop1
- setc al
- movzx rax, al
- ret
-ttmath_sbb_x64 ENDP
- ALIGN 8
-ttmath_subindexed_x64 PROC
- ; rcx = p1
- ; rdx = nSize
- ; r8 = nPos
- ; r9 = nValue
- ALIGN 16
-loop1:
- sub qword ptr [rcx + r8 * 8], r9
- jnc done
- lea r8, [r8+1]
- mov r9, 1
- dec rdx
- jnz loop1
- mov rax, 1
- ret
-done:
- xor rax, rax
- ret
-ttmath_subindexed_x64 ENDP
- ALIGN 8
-; the same asm code as in addvector_x64 only two instructions 'adc' changed to 'sbb'
-ttmath_subvector_x64 PROC
- ; rcx = ss1
- ; rdx = ss2
- ; r8 = ss1_size
- ; r9 = ss2_size
- sub r8, r9
- ALIGN 16
- loop1:
- sbb rax, qword ptr [rdx + r11 * 8]
- inc r11
- dec r9
- jnz loop1
- or r8, r8
- jz done
- loop2:
- sbb rax, r9
- inc r11
- dec r8
- jnz loop2
- adc r8, r8
- mov rax, r8
- ret
-done:
- mov rax, r9
- ret
-ttmath_subvector_x64 ENDP
- ALIGN 8
-ttmath_rcl_x64 PROC
- ; rcx = p1
- ; rdx = b
- ; r8 = nLowestBit
- xor r10, r10
- neg r8 ; CY set if r8 <> 0
- ALIGN 16
-loop1:
- rcl qword ptr [r11 + r10 * 8], 1
- lea r10, [r10+1]
- dec rdx
- jnz loop1
- setc al
- movzx rax, al
- ret
-ttmath_rcl_x64 ENDP
- ALIGN 8
-ttmath_rcr_x64 PROC
- ; rcx = p1
- ; rdx = nSize
- ; r8 = nLowestBit
- xor r10, r10
- ALIGN 16
-loop1:
- rcr qword ptr -8[rcx + rdx * 8], 1
- dec rdx
- jnz loop1
- setc al
- movzx rax, al
- ret
-ttmath_rcr_x64 ENDP
- ALIGN 8
-ttmath_div_x64 PROC
- ; rcx = &Hi
- ; rdx = &Lo
- ; r8 = nDiv
- mov r11, rcx
- mov r10, rdx
- mov rdx, qword ptr [r11]
- mov rax, qword ptr [r10]
- div r8
- mov qword ptr [r10], rdx ; remainder
- mov qword ptr [r11], rax ; value
- ret
-ttmath_div_x64 ENDP
- ALIGN 8
-ttmath_rcl2_x64 PROC
- ; rcx = p1
- ; rdx = nSize
- ; r8 = bits
- ; r9 = c
- push rbx
- mov r10, rcx ; r10 = p1
- xor rax, rax
- mov rcx, 64
- sub rcx, r8
- mov r11, -1
- shr r11, cl ; r11 = mask
- mov rcx, r8 ; rcx = count of bits
- mov rbx, rax ; rbx = old value = 0
- or r9, r9
- cmovnz rbx, r11 ; if (c) then old value = mask
- mov r9, rax ; r9 = index (0..nSize-1)
- ALIGN 16
-loop1:
- rol qword ptr [r10+r9*8], cl
- mov rax, qword ptr [r10+r9*8]
- and rax, r11
- xor qword ptr [r10+r9*8], rax
- or qword ptr [r10+r9*8], rbx
- mov rbx, rax
- lea r9, [r9+1]
- dec rdx
- jnz loop1
- and rax, 1
- pop rbx
- ret
-ttmath_rcl2_x64 ENDP
- ALIGN 8
-ttmath_rcr2_x64 PROC
- ; rcx = p1
- ; rdx = nSize
- ; r8 = bits
- ; r9 = c
- push rbx
- xor rax, rax
- mov rcx, 64
- sub rcx, r8
- mov r11, -1
- shl r11, cl ; r11 = mask
- or r9, r9
- mov r9, rdx ; r9 = index (0..nSize-1)
- lea r9, [r9-1]
- ALIGN 16
-loop1:
- ror qword ptr [r10+r9*8], cl
- and rax, r11
- mov rbx, rax
- lea r9, [r9-1]
- dec rdx
- jnz loop1
- rol rax, 1
- and rax, 1
- pop rbx
- ret
-ttmath_rcr2_x64 ENDP
-END
diff --git a/include/geos/math/DD.h b/include/geos/math/DD.h
new file mode 100644
index 0000000..7bcbb18
--- /dev/null
+++ b/include/geos/math/DD.h
@@ -0,0 +1,204 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2020 Crunchy Data
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Implements extended-precision floating-point numbers
+ * which maintain 106 bits (approximately 30 decimal digits) of precision.
+ * <p>
+ * A DoubleDouble uses a representation containing two double-precision values.
+ * A number x is represented as a pair of doubles, x.hi and x.lo,
+ * such that the number represented by x is x.hi + x.lo, where
+ * <pre>
+ * |x.lo| <= 0.5*ulp(x.hi)
+ * </pre>
+ * and ulp(y) means "unit in the last place of y".
+ * The basic arithmetic operations are implemented using
+ * convenient properties of IEEE-754 floating-point arithmetic.
+ * <p>
+ * The range of values which can be represented is the same as in IEEE-754.
+ * The precision of the representable numbers
+ * is twice as great as IEEE-754 double precision.
+ * <p>
+ * The correctness of the arithmetic algorithms relies on operations
+ * being performed with standard IEEE-754 double precision and rounding.
+ * This is the Java standard arithmetic model, but for performance reasons
+ * Java implementations are not
+ * constrained to using this standard by default.
+ * Some processors (notably the Intel Pentium architecture) perform
+ * floating point operations in (non-IEEE-754-standard) extended-precision.
+ * A JVM implementation may choose to use the non-standard extended-precision
+ * as its default arithmetic mode.
+ * To prevent this from happening, this code uses the
+ * Java <tt>strictfp</tt> modifier,
+ * which forces all operations to take place in the standard IEEE-754 rounding model.
+ * <p>
+ * The API provides both a set of value-oriented operations
+ * and a set of mutating operations.
+ * Value-oriented operations treat DoubleDouble values as
+ * immutable; operations on them return new objects carrying the result
+ * of the operation. This provides a simple and safe semantics for
+ * writing DoubleDouble expressions. However, there is a performance
+ * penalty for the object allocations required.
+ * The mutable interface updates object values in-place.
+ * It provides optimum memory performance, but requires
+ * care to ensure that aliasing errors are not created
+ * and constant values are not changed.
+ * <p>
+ * For example, the following code example constructs three DD instances:
+ * two to hold the input values and one to hold the result of the addition.
+ * <pre>
+ * DD a = new DD(2.0);
+ * DD b = new DD(3.0);
+ * DD c = a.add(b);
+ * </pre>
+ * In contrast, the following approach uses only one object:
+ * <pre>
+ * a.selfAdd(3.0);
+ * </pre>
+ * <p>
+ * This implementation uses algorithms originally designed variously by
+ * Knuth, Kahan, Dekker, and Linnainmaa.
+ * Douglas Priest developed the first C implementation of these techniques.
+ * Other more recent C++ implementation are due to Keith M. Briggs and David Bailey et al.
+ * <h3>References</h3>
+ * <ul>
+ * <li>Priest, D., <i>Algorithms for Arbitrary Precision Floating Point Arithmetic</i>,
+ * in P. Kornerup and D. Matula, Eds., Proc. 10th Symposium on Computer Arithmetic,
+ * IEEE Computer Society Press, Los Alamitos, Calif., 1991.
+ * <li>Yozo Hida, Xiaoye S. Li and David H. Bailey,
+ * <i>Quad-Double Arithmetic: Algorithms, Implementation, and Application</i>,
+ * manuscript, Oct 2000; Lawrence Berkeley National Laboratory Report BNL-46996.
+ * <li>David Bailey, <i>High Precision Software Directory</i>;
+ * <tt>http://crd.lbl.gov/~dhbailey/mpdist/index.html</tt>
+ * </ul>
+ * @author Martin Davis
+#ifndef GEOS_MATH_DD_H
+#define GEOS_MATH_DD_H
+#include <cmath>
+namespace geos {
+namespace math { // geos.math
+ * \class DD
+ * \brief
+ * Wrapper for DoubleDouble higher precision mathematics
+ * operations.
+class GEOS_DLL DD {
+ private:
+ static constexpr double SPLIT = 134217729.0; // 2^27+1, for IEEE double
+ double hi;
+ double lo;
+ int magnitude(double x) const;
+ int signum() const;
+ DD rint() const;
+ public:
+ DD(double p_hi, double p_lo) : hi(p_hi), lo(p_lo) {};
+ DD(double x) : hi(x), lo(0.0) {};
+ DD(const DD &dd) : hi(dd.hi), lo(dd.lo) {};
+ DD() : hi(0.0), lo(0.0) {};
+ bool operator==(const DD &rhs) const
+ return hi == rhs.hi && lo == rhs.lo;
+ bool operator!=(const DD &rhs) const
+ return hi != rhs.hi || lo != rhs.lo;
+ bool operator<(const DD &rhs) const
+ return (hi < rhs.hi) || (hi == rhs.hi && lo < rhs.lo);
+ bool operator<=(const DD &rhs) const
+ return (hi < rhs.hi) || (hi == rhs.hi && lo <= rhs.lo);
+ bool operator>(const DD &rhs) const
+ return (hi > rhs.hi) || (hi == rhs.hi && lo > rhs.lo);
+ bool operator>=(const DD &rhs) const
+ return (hi > rhs.hi) || (hi == rhs.hi && lo >= rhs.lo);
+ friend DD operator+ (const DD &lhs, const DD &rhs);
+ friend DD operator+ (const DD &lhs, double rhs);
+ friend DD operator- (const DD &lhs, const DD &rhs);
+ friend DD operator- (const DD &lhs, double rhs);
+ friend DD operator* (const DD &lhs, const DD &rhs);
+ friend DD operator* (const DD &lhs, double rhs);
+ friend DD operator/ (const DD &lhs, const DD &rhs);
+ friend DD operator/ (const DD &lhs, double rhs);
+ static DD determinant(const DD &x1, const DD &y1, const DD &x2, const DD &y2);
+ static DD determinant(double x1, double y1, double x2, double y2);
+ static DD abs(const DD &d);
+ static DD pow(const DD &d, int exp);
+ static DD trunc(const DD &d);
+ bool isNaN() const;
+ bool isNegative() const;
+ bool isPositive() const;
+ bool isZero() const;
+ double doubleValue() const;
+ double ToDouble() const { return doubleValue(); }
+ int intValue() const;
+ DD negate() const;
+ DD reciprocal() const;
+ DD floor() const;
+ DD ceil() const;
+ void selfAdd(const DD &d);
+ void selfAdd(double p_hi, double p_lo);
+ void selfAdd(double y);
+ void selfSubtract(const DD &d);
+ void selfSubtract(double p_hi, double p_lo);
+ void selfSubtract(double y);
+ void selfMultiply(double p_hi, double p_lo);
+ void selfMultiply(const DD &d);
+ void selfMultiply(double y);
+ void selfDivide(double p_hi, double p_lo);
+ void selfDivide(const DD &d);
+ void selfDivide(double y);
+} // namespace geos::math
+#endif // GEOS_MATH_DD_H
diff --git a/include/geos/math/Makefile.am b/include/geos/math/Makefile.am
index 0000000..5396b95
--- /dev/null
+++ b/include/geos/math/Makefile.am
@@ -0,0 +1,11 @@
+# This file is part of project GEOS (http://trac.osgeo.org/geos/)
+SUBDIRS =
+EXTRA_DIST =
+geosdir = $(includedir)/geos/math
+geos_HEADERS = \
+ DD.h
diff --git a/src/Makefile.am b/src/Makefile.am
index 1bba8e8..ea46524 100644
--- a/src/Makefile.am
+++ b/src/Makefile.am
@@ -7,6 +7,7 @@ SUBDIRS = \
index \
io \
linearref \
+ math \
noding \
operation \
planargraph \
@@ -39,6 +40,7 @@ libgeos_la_LIBADD = \
index/libindex.la \
io/libio.la \
linearref/liblinearref.la \
+ math/libmath.la \
noding/libnoding.la \
operation/liboperation.la \
planargraph/libplanargraph.la \
diff --git a/src/algorithm/CGAlgorithmsDD.cpp b/src/algorithm/CGAlgorithmsDD.cpp
index 1ec67c8..57f8d20 100644
--- a/src/algorithm/CGAlgorithmsDD.cpp
+++ b/src/algorithm/CGAlgorithmsDD.cpp
@@ -35,7 +35,7 @@ namespace {
double constexpr DP_SAFE_EPSILON = 1e-15;
inline int
-OrientationDD(DD const& dd)
+OrientationDD(const DD &dd)
static DD const zero(0.0);
if(dd < zero) {
@@ -49,10 +49,7 @@ OrientationDD(DD const& dd)
return CGAlgorithmsDD::STRAIGHT;
-// inline std::string ToStringDD(DD const& dd)
-// return dd.ToString();
namespace geos {
diff --git a/src/algorithm/InteriorPointArea.cpp b/src/algorithm/InteriorPointArea.cpp
index c455948..1236898 100644
--- a/src/algorithm/InteriorPointArea.cpp
+++ b/src/algorithm/InteriorPointArea.cpp
@@ -200,7 +200,6 @@ private:
// edge intersects scan line, so add a crossing
double xInt = intersection(p0, p1, scanY);
crossings.push_back(xInt);
- //checkIntersectionDD(p0, p1, scanY, xInt);
void findBestMidpoint(vector<double>& crossings)
diff --git a/src/geom/LineString.cpp b/src/geom/LineString.cpp
index 65f86a0..ac5d7fe 100644
--- a/src/geom/LineString.cpp
+++ b/src/geom/LineString.cpp
@@ -45,7 +45,7 @@ using namespace geos::algorithm;
namespace geos {
namespace geom { // geos::geom
-LineString::~LineString(){};
+LineString::~LineString(){}
/*protected*/
LineString::LineString(const LineString& ls)
diff --git a/src/math/DD.cpp b/src/math/DD.cpp
index 0000000..673e921
--- /dev/null
+++ b/src/math/DD.cpp
@@ -0,0 +1,403 @@
+#include <cmath>
+#include <geos/profiler.h>
+#include <geos/math/DD.h>
+namespace geos {
+namespace math { // geos.util
+/* private */
+int
+DD::magnitude(double x) const
+ double xAbs = std::fabs(x);
+ double xLog10 = std::log(xAbs) / std::log(10);
+ int xMag = (int) std::floor(xLog10);
+ * Since log computation is inexact, there may be an off-by-one error
+ * in the computed magnitude.
+ * Following tests that magnitude is correct, and adjusts it if not
+ double xApprox = std::pow(10, xMag);
+ if (xApprox * 10 <= xAbs)
+ xMag += 1;
+ return xMag;
+/* public */
+bool DD::isNaN() const
+ return std::isnan(hi);
+/* public */
+bool DD::isNegative() const
+ return hi < 0.0 || (hi == 0.0 && lo < 0.0);
+/* public */
+bool DD::isPositive() const
+ return hi > 0.0 || (hi == 0.0 && lo > 0.0);
+/* public */
+bool DD::isZero() const
+ return hi == 0.0 && lo == 0.0;
+/* public */
+double DD::doubleValue() const
+ return hi + lo;
+/* public */
+int DD::intValue() const
+ return (int) hi;
+/* public */
+void DD::selfAdd(const DD &y)
+ return selfAdd(y.hi, y.lo);
+/* public */
+void DD::selfAdd(double yhi, double ylo)
+ double H, h, T, t, S, s, e, f;
+ S = hi + yhi;
+ T = lo + ylo;
+ e = S - hi;
+ f = T - lo;
+ s = S-e;
+ t = T-f;
+ s = (yhi-e)+(hi-s);
+ t = (ylo-f)+(lo-t);
+ e = s+T; H = S+e; h = e+(S-H); e = t+h;
+ double zhi = H + e;
+ double zlo = e + (H - zhi);
+ hi = zhi;
+ lo = zlo;
+ return;
+/* public */
+void DD::selfAdd(double y)
+ double H, h, S, s, e, f;
+ S = hi + y;
+ e = S - hi;
+ s = S - e;
+ s = (y - e) + (hi - s);
+ f = s + lo;
+ H = S + f;
+ h = f + (S - H);
+ hi = H + h;
+ lo = h + (H - hi);
+ return;
+/* public */
+DD operator+(const DD &lhs, const DD &rhs)
+ DD rv(lhs.hi, lhs.lo);
+ rv.selfAdd(rhs);
+ return rv;
+/* public */
+DD operator+(const DD &lhs, double rhs)
+ rv.selfAdd(rhs);
+ return rv;
+/* public */
+void DD::selfSubtract(const DD &d)
+ return selfAdd(-1*d.hi, -1*d.lo);
+/* public */
+void DD::selfSubtract(double p_hi, double p_lo)
+ return selfAdd(-1*p_hi, -1*p_lo);
+/* public */
+void DD::selfSubtract(double y)
+ return selfAdd(-1*y, 0.0);
+/* public */
+DD operator-(const DD &lhs, const DD &rhs)
+ rv.selfSubtract(rhs);
+ return rv;
+/* public */
+DD operator-(const DD &lhs, double rhs)
+ return rv;
+/* public */
+void DD::selfMultiply(double yhi, double ylo)
+ double hx, tx, hy, ty, C, c;
+ C = SPLIT * hi; hx = C-hi; c = SPLIT * yhi;
+ hx = C-hx; tx = hi-hx; hy = c-yhi;
+ C = hi*yhi; hy = c-hy; ty = yhi-hy;
+ c = ((((hx*hy-C)+hx*ty)+tx*hy)+tx*ty)+(hi*ylo+lo*yhi);
+ double zhi = C+c; hx = C-zhi;
+ double zlo = c+hx;
+ hi = zhi;
+ lo = zlo;
+ return;
+/* public */
+void DD::selfMultiply(DD const &d)
+ return selfMultiply(d.hi, d.lo);
+/* public */
+void DD::selfMultiply(double y)
+ return selfMultiply(y, 0.0);
+/* public */
+DD operator*(const DD &lhs, const DD &rhs)
+ rv.selfMultiply(rhs);
+ return rv;
+/* public */
+DD operator*(const DD &lhs, double rhs)
+ return rv;
+/* public */
+void DD::selfDivide(double yhi, double ylo)
+ double hc, tc, hy, ty, C, c, U, u;
+ C = hi/yhi; c = SPLIT*C; hc =c-C;
+ u = SPLIT*yhi; hc = c-hc;
+ tc = C-hc; hy = u-yhi; U = C * yhi;
+ hy = u-hy; ty = yhi-hy;
+ u = (((hc*hy-U)+hc*ty)+tc*hy)+tc*ty;
+ c = ((((hi-U)-u)+lo)-C*ylo)/yhi;
+ u = C+c;
+ hi = u;
+ lo = (C-u)+c;
+ return;
+/* public */
+void DD::selfDivide(const DD &d)
+ return selfDivide(d.hi, d.lo);
+/* public */
+void DD::selfDivide(double y)
+ return selfDivide(y, 0.0);
+/* public */
+DD operator/(const DD &lhs, const DD &rhs)
+ rv.selfDivide(rhs);
+ return rv;
+/* public */
+DD operator/(const DD &lhs, double rhs)
+ return rv;
+/* public */
+DD DD::negate() const
+ DD rv(hi, lo);
+ if (rv.isNaN())
+ return rv;
+ rv.hi = -hi;
+ rv.lo = -lo;
+ return rv;
+/* public static */
+DD DD::reciprocal() const
+ C = 1.0/hi;
+ c = SPLIT*C;
+ hc = c-C;
+ u = SPLIT*hi;
+ hc = c-hc; tc = C-hc; hy = u-hi; U = C*hi; hy = u-hy; ty = hi-hy;
+ c = ((((1.0-U)-u))-C*lo)/hi;
+ double zhi = C+c;
+ double zlo = (C-zhi)+c;
+ return DD(zhi, zlo);
+DD DD::floor() const
+ DD rv(hi, lo);
+ if (isNaN()) return rv;
+ double fhi = std::floor(hi);
+ double flo = 0.0;
+ // Hi is already integral. Floor the low word
+ if (fhi == hi) {
+ flo = std::floor(lo);
+ // do we need to renormalize here?
+ rv.hi = fhi;
+ rv.lo = flo;
+ return rv;
+DD DD::ceil() const
+ DD rv(hi, lo);
+ double fhi = std::ceil(hi);
+ double flo = 0.0;
+ // Hi is already integral. Ceil the low word
+ if (fhi == hi) {
+ flo = std::ceil(lo);
+ rv.hi = fhi;
+ rv.lo = flo;
+ return rv;
+int DD::signum() const
+ if (hi > 0) return 1;
+ if (hi < 0) return -1;
+ if (lo > 0) return 1;
+ if (lo < 0) return -1;
+ return 0;
+DD DD::rint() const
+ DD rv(hi, lo);
+ return (rv + 0.5).floor();
+DD DD::trunc(const DD &d)
+ DD rv(d);
+ if (rv.isNaN()) return rv;
+ if (rv.isPositive())
+ return rv.floor();
+ return rv.ceil();
+DD DD::abs(const DD &d)
+ DD rv(d);
+ if (rv.isNegative())
+ return rv.negate();
+ return rv;
+DD DD::determinant(const DD &x1, const DD &y1, const DD &x2, const DD &y2)
+ return (x1 * y2) - (y1 * x2);
+DD DD::determinant(double x1, double y1, double x2, double y2)
+ return determinant(DD(x1), DD(y1), DD(x2), DD(y2) );
+* Computes the value of this number raised to an integral power.
+* Follows semantics of Java Math.pow as closely as possible.
+DD DD::pow(const DD &d, int exp)
+ if (exp == 0.0)
+ return DD(1.0);
+ DD r(d);
+ DD s(1.0);
+ int n = std::abs(exp);
+ if (n > 1) {
+ /* Use binary exponentiation */
+ while (n > 0) {
+ if (n % 2 == 1) {
+ s.selfMultiply(r);
+ n /= 2;
+ if (n > 0)
+ r = r*r;
+ } else {
+ s = r;
+ /* Compute the reciprocal if n is negative. */
+ if (exp < 0)
+ return s.reciprocal();
+ return s;
diff --git a/src/math/Makefile.am b/src/math/Makefile.am
index 0000000..c30e97e
--- /dev/null
+++ b/src/math/Makefile.am
@@ -0,0 +1,13 @@
+SUBDIRS =
+noinst_LTLIBRARIES = libmath.la
+AM_CPPFLAGS = -I$(top_srcdir)/include
+libmath_la_SOURCES = \
+ DD.cpp
+libmath_la_LIBADD =
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 88c4816..3c836fc 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -151,6 +151,7 @@ geos_unit_SOURCES = \
io/WKTWriterTest.cpp \
io/WriterTest.cpp \
linearref/LengthIndexedLineTest.cpp \
+ math/DDTest.cpp \
noding/BasicSegmentStringTest.cpp \
noding/NodedSegmentStringTest.cpp \
noding/OrientedCoordinateArrayTest.cpp \
diff --git a/tests/unit/math/DDTest.cpp b/tests/unit/math/DDTest.cpp
index 0000000..00a29b8
--- /dev/null
+++ b/tests/unit/math/DDTest.cpp
@@ -0,0 +1,414 @@
+// Test Suite for geos::util::UniqueCoordinateArrayFilter class.
+// geos
+// tut
+#include <tut/tut.hpp>
+#include <utility.h>
+// std
+#include <memory>
+#include <string>
+using namespace geos::math;
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_dd_data {
+ double eps;
+ DD pi;
+ DD e;
+ void ensure_dd_equals(const char *str, const DD &d1, const DD &d2, double tolerance)
+ DD delta = DD::abs(d1 - d2);
+ double diff = delta.doubleValue();
+ ensure(str, diff <= tolerance);
+ void checkTrunc(const DD &x, const DD &expected)
+ DD trunc = DD::trunc(x);
+ ensure("checkTrunc", trunc == expected);
+ void checkDeterminant(double x1, double y1, double x2, double y2, double expected, double errBound)
+ DD det = DD::determinant(x1, y1, x2, y2);
+ //ensure_equals("1", Angle::angle(Coordinate(10, 0)), 0.0, TOL);
+ ensure_dd_equals("checkDeterminant", det, DD(expected), errBound);
+ void checkDeterminantDD(double x1, double y1, double x2, double y2, double expected, double errBound)
+ DD det = DD::determinant(DD(x1), DD(y1), DD(x2), DD(y2));
+ ensure_dd_equals("checkDeterminantDD", det, DD(expected), errBound);
+ void checkAddMult2(const DD &dd)
+ DD sum = dd + dd;
+ DD prod = dd * DD(2.0);
+ ensure_dd_equals("checkAddMult2", sum, prod, 0.0);
+ void checkMultiplyDivide(const DD &a, const DD &b, double errBound)
+ DD a2 = (a * b) / b;
+ ensure_dd_equals("checkMultiplyDivide", a, a2, errBound);
+ void checkDivideMultiply(const DD &a, const DD &b, double errBound)
+ DD a2 = (a / b) * b;
+ ensure_dd_equals("checkDivideMultiply", a, a2, errBound);
+ * Computes (a+b)^2 in two different ways and compares the result.
+ * For correct results, a and b should be integers.
+ void checkBinomialSquare(double a, double b)
+ // binomial square
+ DD add(a);
+ DD bdd(b);
+ DD aPlusb = add + bdd;
+ DD abSq = aPlusb * aPlusb;
+ // expansion
+ DD a2dd = add * add;
+ DD b2dd = bdd * bdd;
+ DD ab = add * bdd;
+ DD sum = b2dd + ab + ab;
+ DD diff = abSq - a2dd;
+ DD delta = diff - sum;
+ ensure("isSame", diff == sum);
+ ensure("isDeltaZero", delta.isZero());
+ void checkBinomial2(double a, double b)
+ // binomial product
+ DD add(a);
+ DD bdd(b);
+ DD aSubb = add - bdd;
+ DD abProd = aPlusb * aSubb;
+ // expansion
+ // this should equal b^2
+ DD diff = (abProd - a2dd).negate();
+ DD delta = diff - b2dd;
+ ensure("isSame", diff == b2dd);
+ void checkReciprocal(double x, double errBound)
+ DD xdd(x);
+ DD rr = xdd.reciprocal().reciprocal();
+ double err = (xdd - rr).doubleValue();
+ ensure("checkReciprocal", err <= errBound);
+ DD slowPow(const DD &x, int exp)
+ if (exp == 0)
+ return DD(1.0);
+ // MD - could use binary exponentiation for better precision & speed
+ DD pow(x);
+ for (int i = 1; i < n; i++) {
+ pow = pow * x;
+ if (exp < 0) {
+ return pow.reciprocal();
+ return pow;
+ void checkPow(double x, int exp, double errBound)
+ DD xdd(x);
+ DD pow = DD::pow(xdd, exp);
+ DD pow2 = slowPow(xdd, exp);
+ double err = (pow - pow2).doubleValue();
+ ensure("checkPow", err <= errBound);
+ DD arctan(DD x)
+ DD t = x;
+ DD t2 = t*t;
+ DD at(0.0);
+ DD two(2.0);
+ int k = 0;
+ DD d(1.0);
+ int sign = 1;
+ while (t.doubleValue() > eps) {
+ k++;
+ if (sign < 0)
+ at = at - (t / d);
+ else
+ at = at + (t / d);
+ d = d + two;
+ t = t * t2;
+ sign = -sign;
+ return at;
+ * Uses Taylor series to compute e
+ * e = 1 + 1 + 1/2! + 1/3! + 1/4! + ...
+ DD computeEByTaylorSeries()
+ DD s(2.0);
+ DD t(1.0);
+ double n = 1.0;
+ int i = 0;
+ while(t.doubleValue() > eps)
+ i++;
+ n += 1.0;
+ t = t / DD(n);
+ s = s + t;
+ return s;
+ * Uses Machin's arctangent formula to compute Pi:
+ * Pi / 4 = 4 arctan(1/5) - arctan(1/239)
+ DD computePiByMachin()
+ DD t1 = DD(1.0) / DD(5.0);
+ DD t2 = DD(1.0) / DD(239.0);
+ DD pi4 = (DD(4.0) * arctan(t1)) - arctan(t2);
+ DD pi = DD(4.0) * pi4;
+ return pi;
+ test_dd_data():
+ eps(1.23259516440783e-32), /* = 2^-106 */
+ pi(DD(3.141592653589793116e+00, 1.224646799147353207e-16)),
+ e(DD(2.718281828459045091e+00, 1.445646891729250158e-16))
+typedef test_group<test_dd_data> group;
+typedef group::object object;
+group test_dd_group("geos::math::DD");
+// Test Cases
+// Test PI calculation
+template<>
+template<>
+void object::test<1>
+ DD testPi = computePiByMachin();
+ double err = std::abs((testPi - pi).doubleValue());
+ // std::cout << "Difference from PI = " << err << std::endl;
+ ensure("Test PI calculation", err < 8*eps);
+// Test E calculation
+template<>
+template<>
+void object::test<2>
+ DD testE = computeEByTaylorSeries();
+ double err = std::abs((testE - e).doubleValue());
+ // std::cout << "Difference from E = " << err << std::endl;
+ ensure("Test E calculation", err < eps);
+// Test NaN
+template<>
+template<>
+void object::test<3>
+ DD nan = DD(1.0) / DD(0.0);
+ ensure("isNan", nan.isNaN());
+ ensure("isNan", (DD(1.0) * nan).isNaN());
+// testAddMult2
+template<>
+template<>
+void object::test<4>
+ checkAddMult2(DD(3.0));
+ checkAddMult2(DD(pi));
+// testMultiplyDivide
+template<>
+template<>
+void object::test<5>
+ checkMultiplyDivide(DD(pi), DD(e), 1e-30);
+ checkMultiplyDivide(DD(DD(2.0)*pi), DD(e), 1e-30);
+ checkMultiplyDivide(DD(DD(0.5)*pi), DD(e), 1e-30);
+ checkMultiplyDivide(DD(39.4), DD(10), 1e-30);
+// testDivideMultiply
+template<>
+template<>
+void object::test<6>
+ checkDivideMultiply(DD(pi), DD(e), 1e-30);
+ checkDivideMultiply(DD(39.4), DD(10), 1e-30);
+// testTrunc
+template<>
+template<>
+void object::test<7>
+ checkTrunc(DD(1e16) - DD(1), DD(1e16) - DD(1));
+ // the appropriate error bound is determined empirically
+ checkTrunc(DD(pi), DD(3));
+ checkTrunc(DD(999.999), DD(999));
+ checkTrunc(DD(e).negate(), DD(-2));
+ checkTrunc(DD(-999.999), DD(-999));
+// testPow
+template<>
+template<>
+void object::test<8>
+ checkPow(0, 3, 16 * eps);
+ checkPow(14, 3, 16 * eps);
+ checkPow(3, -5, 16 * eps);
+ checkPow(-3, 5, 16 * eps);
+ checkPow(-3, -5, 16 * eps);
+ checkPow(0.12345, -5, 1e5 * eps);
+// testReciprocal
+template<>
+template<>
+void object::test<9>
+ checkReciprocal(3.0, 0);
+ checkReciprocal(99.0, 1e-29);
+ checkReciprocal(999.0, 0);
+ checkReciprocal(314159269.0, 0);
+// testDeterminant
+template<>
+template<>
+void object::test<10>
+ checkDeterminant(3, 8, 4, 6, -14, 0);
+ checkDeterminantDD(3, 8, 4, 6, -14, 0);
+// testDeterminantRobust
+template<>
+template<>
+void object::test<11>
+ checkDeterminant(1.0e9, 1.0e9 - 1, 1.0e9 - 1, 1.0e9 - 2, -1, 0);
+ checkDeterminantDD(1.0e9, 1.0e9 - 1, 1.0e9 - 1, 1.0e9 - 2, -1, 0);
+// testBinom
+template<>
+template<>
+void object::test<12>
+ checkBinomialSquare(100.0, 1.0);
+ checkBinomialSquare(1000.0, 1.0);
+ checkBinomialSquare(10000.0, 1.0);
+ checkBinomialSquare(100000.0, 1.0);
+ checkBinomialSquare(1000000.0, 1.0);
+ checkBinomialSquare(1e8, 1.0);
+ checkBinomialSquare(1e10, 1.0);
+ checkBinomialSquare(1e14, 1.0);
+ // Following call will fail, because it requires 32 digits of precision
+ // checkBinomialSquare(1e16, 1.0);
+ checkBinomialSquare(1e14, 291.0);
+ checkBinomialSquare(5e14, 291.0);
+ checkBinomialSquare(5e14, 345291.0);
+// testBinom2
+template<>
+template<>
+void object::test<13>
+ checkBinomial2(100.0, 1.0);
+ checkBinomial2(1000.0, 1.0);
+ checkBinomial2(10000.0, 1.0);
+ checkBinomial2(100000.0, 1.0);
+ checkBinomial2(1000000.0, 1.0);
+ checkBinomial2(1e8, 1.0);
+ checkBinomial2(1e10, 1.0);
+ checkBinomial2(1e14, 1.0);
+ checkBinomial2(1e14, 291.0);
+ checkBinomial2(5e14, 291.0);
+ checkBinomial2(5e14, 345291.0);
+} // namespace tut
Summary of changes:
.codecov.yml | 1 -
Makefile.am | 1 -
NEWS | 1 +
configure.ac | 3 +-
doc/Doxyfile.in | 1 -
include/geos/Makefile.am | 1 +
include/geos/algorithm/CGAlgorithmsDD.h | 16 +-
include/geos/algorithm/Makefile.am | 3 +-
include/geos/algorithm/RayCrossingCounterDD.h | 1 -
include/geos/algorithm/ttmath/COPYRIGHT | 28 -
include/geos/algorithm/ttmath/Makefile.am | 24 -
include/geos/algorithm/ttmath/README | 23 -
include/geos/algorithm/ttmath/ttmath.h | 2880 ---------
include/geos/algorithm/ttmath/ttmathbig.h | 6093 --------------------
include/geos/algorithm/ttmath/ttmathdec.h | 419 --
include/geos/algorithm/ttmath/ttmathint.h | 1923 ------
include/geos/algorithm/ttmath/ttmathmisc.h | 250 -
include/geos/algorithm/ttmath/ttmathobjects.h | 812 ---
include/geos/algorithm/ttmath/ttmathparser.h | 2777 ---------
include/geos/algorithm/ttmath/ttmaththreads.h | 252 -
include/geos/algorithm/ttmath/ttmathtypes.h | 718 ---
include/geos/algorithm/ttmath/ttmathuint.h | 4189 --------------
include/geos/algorithm/ttmath/ttmathuint_noasm.h | 1038 ----
include/geos/algorithm/ttmath/ttmathuint_x86.h | 1620 ------
include/geos/algorithm/ttmath/ttmathuint_x86_64.h | 1177 ----
.../algorithm/ttmath/ttmathuint_x86_64_msvc.asm | 551 --
include/geos/math/DD.h | 204 +
include/geos/math/Makefile.am | 11 +
src/Makefile.am | 2 +
src/algorithm/CGAlgorithmsDD.cpp | 7 +-
src/algorithm/InteriorPointArea.cpp | 1 -
src/geom/LineString.cpp | 2 +-
src/math/DD.cpp | 403 ++
src/{operation/sharedpaths => math}/Makefile.am | 8 +-
tests/unit/Makefile.am | 1 +
tests/unit/math/DDTest.cpp | 414 ++
36 files changed, 1052 insertions(+), 24803 deletions(-)
delete mode 100644 include/geos/algorithm/ttmath/COPYRIGHT
delete mode 100644 include/geos/algorithm/ttmath/Makefile.am
delete mode 100644 include/geos/algorithm/ttmath/README
delete mode 100644 include/geos/algorithm/ttmath/ttmath.h
delete mode 100644 include/geos/algorithm/ttmath/ttmathbig.h
delete mode 100644 include/geos/algorithm/ttmath/ttmathdec.h
delete mode 100644 include/geos/algorithm/ttmath/ttmathint.h
delete mode 100644 include/geos/algorithm/ttmath/ttmathmisc.h
delete mode 100644 include/geos/algorithm/ttmath/ttmathobjects.h
delete mode 100644 include/geos/algorithm/ttmath/ttmathparser.h
delete mode 100644 include/geos/algorithm/ttmath/ttmaththreads.h
delete mode 100644 include/geos/algorithm/ttmath/ttmathtypes.h
delete mode 100644 include/geos/algorithm/ttmath/ttmathuint.h
delete mode 100644 include/geos/algorithm/ttmath/ttmathuint_noasm.h
delete mode 100644 include/geos/algorithm/ttmath/ttmathuint_x86.h
delete mode 100644 include/geos/algorithm/ttmath/ttmathuint_x86_64.h
delete mode 100644 include/geos/algorithm/ttmath/ttmathuint_x86_64_msvc.asm
create mode 100644 include/geos/math/DD.h
create mode 100644 include/geos/math/Makefile.am
create mode 100644 src/math/DD.cpp
copy src/{operation/sharedpaths => math}/Makefile.am (56%)
create mode 100644 tests/unit/math/DDTest.cpp
hooks/post-receive
More information about the geos-commits
