[geos-commits] [SCM] GEOS branch master updated. 2ac00b1c5ae669c384d78155cbf94042d0fc90b0
Fri Apr 17 15:06:41 PDT 2020
the project "GEOS".
       via  2ac00b1c5ae669c384d78155cbf94042d0fc90b0 (commit)
      from  3df362a9d8c04a53bdaae0916c821296641ef6a3 (commit)
revisions in full, below.
commit 2ac00b1c5ae669c384d78155cbf94042d0fc90b0
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Apr 17 15:06:35 2020 -0700
    Fix bug in DistanceOp for geometries with empty components, Closes #1026
diff --git a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
index 89e2b69..a29fb94 100644
--- a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
+++ b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
@@ -48,6 +48,9 @@ namespace locate { // geos::algorithm::locate
  * or segments will return [Location::BOUNDARY](@ref geom::Location::BOUNDARY).
  * Polygonal and [LinearRing](@ref geom::LinearRing) geometries are supported.
+ * The index is lazy-loaded, which allows creating instances even if they are not used.
 class IndexedPointInAreaLocator : public PointOnGeometryLocator {
 private:
diff --git a/include/geos/operation/distance/ConnectedElementLocationFilter.h b/include/geos/operation/distance/ConnectedElementLocationFilter.h
index 9273653..379dd19 100644
--- a/include/geos/operation/distance/ConnectedElementLocationFilter.h
+++ b/include/geos/operation/distance/ConnectedElementLocationFilter.h
@@ -42,7 +42,7 @@ namespace distance { // geos::operation::distance
 /** \brief
  * A ConnectedElementPointFilter extracts a single point from each connected
  * element in a Geometry (e.g. a polygon, linestring or point) and returns
- * them in a list.
+ * them in a list. Empty geometries do not provide a location item.
  * The elements of the list are GeometryLocation.
diff --git a/include/geos/operation/distance/DistanceOp.h b/include/geos/operation/distance/DistanceOp.h
index 3ba3264..bdf6282 100644
--- a/include/geos/operation/distance/DistanceOp.h
+++ b/include/geos/operation/distance/DistanceOp.h
@@ -64,6 +64,8 @@ namespace distance { // geos::operation::distance
  * the coordinate computed is a close
  * approximation to the exact point.
+ * Empty geometry collection components are ignored.
  * The algorithms used are straightforward O(n^2)
  * comparisons.  This worst-case performance could be improved on
  * by using Voronoi techniques or spatial indexes.
diff --git a/src/geom/util/LinearComponentExtracter.cpp b/src/geom/util/LinearComponentExtracter.cpp
index 57c5372..2eca78a 100644
--- a/src/geom/util/LinearComponentExtracter.cpp
+++ b/src/geom/util/LinearComponentExtracter.cpp
@@ -38,6 +38,7 @@ LinearComponentExtracter::getLines(const Geometry& geom, std::vector<const LineS
 void
 LinearComponentExtracter::filter_rw(Geometry* geom)
+    if (geom->isEmpty()) return;
     if(const LineString* ls = dynamic_cast<const LineString*>(geom)) {
         comps.push_back(ls);
@@ -46,6 +47,7 @@ LinearComponentExtracter::filter_rw(Geometry* geom)
 void
 LinearComponentExtracter::filter_ro(const Geometry* geom)
diff --git a/src/operation/distance/ConnectedElementLocationFilter.cpp b/src/operation/distance/ConnectedElementLocationFilter.cpp
index e12b892..aeefb7a 100644
--- a/src/operation/distance/ConnectedElementLocationFilter.cpp
+++ b/src/operation/distance/ConnectedElementLocationFilter.cpp
@@ -46,6 +46,7 @@ ConnectedElementLocationFilter::getLocations(const Geometry* geom)
 void
 ConnectedElementLocationFilter::filter_ro(const Geometry* geom)
     if((typeid(*geom) == typeid(Point)) ||
             (typeid(*geom) == typeid(LineString)) ||
             (typeid(*geom) == typeid(LinearRing)) ||
@@ -57,6 +58,8 @@ ConnectedElementLocationFilter::filter_ro(const Geometry* geom)
 void
 ConnectedElementLocationFilter::filter_rw(Geometry* geom)
+    // empty geometries do not provide a location
diff --git a/tests/xmltester/tests/general/TestDistance.xml b/tests/xmltester/tests/general/TestDistance.xml
index af243e9..4ce6d0f 100644
--- a/tests/xmltester/tests/general/TestDistance.xml
+++ b/tests/xmltester/tests/general/TestDistance.xml
@@ -57,4 +57,11 @@
 <test><op name="distance" arg1="A" arg2="B" >    0.0   </op></test>
 </case>
+<case>
+  <desc>mAmA - multipolygon with empty component</desc>
+  <a> MULTIPOLYGON (EMPTY, ((98 200, 200 200, 200 99, 98 99, 98 200))) </a>
+  <b> POLYGON ((300 200, 400 200, 400 100, 300 100, 300 200)) </b>
+<test><op name="distance" arg1="A" arg2="B" >    100.0   </op></test>
+</case>
 </run>
Summary of changes:
 include/geos/algorithm/locate/IndexedPointInAreaLocator.h        | 3 +++
 include/geos/operation/distance/ConnectedElementLocationFilter.h | 2 +-
 include/geos/operation/distance/DistanceOp.h                     | 2 ++
 src/geom/util/LinearComponentExtracter.cpp                       | 2 ++
 src/operation/distance/ConnectedElementLocationFilter.cpp        | 3 +++
 tests/xmltester/tests/general/TestDistance.xml                   | 7 +++++++
 6 files changed, 18 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits mailing list
