[geos-commits] [SCM] GEOS branch 3.8 updated. 925397281833cbea15050c221299a1cf841afa97
git at osgeo.org
git at osgeo.org
Mon Apr 20 08:10:50 PDT 2020
the project "GEOS".
The branch, 3.8 has been updated
via 925397281833cbea15050c221299a1cf841afa97 (commit)
from b2dfcbbc147273c05c0ce521419924614831d4a3 (commit)
revisions in full, below.
commit 925397281833cbea15050c221299a1cf841afa97
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Apr 20 08:10:40 2020 -0700
news entry for #1021
diff --git a/NEWS b/NEWS
index cbdfdde..eab62a4 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ Changes in 3.8.2
- Bug fixes / improvements
- DistanceOp against geometry with empty components
crashes (#1026, Paul Ramsey)
+ - Remove undefined behaviour in CAPI (#1021, Greg Troxel)
Changes in 3.8.1
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 4391b9b..31f2f1e 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -233,7 +233,7 @@ typedef struct GEOSContextHandle_HS {
void
- NOTICE_MESSAGE(string fmt, ...)
+ NOTICE_MESSAGE(const char *fmt, ...)
if(NULL == noticeMessageOld && NULL == noticeMessageNew) {
return;
@@ -241,7 +241,7 @@ typedef struct GEOSContextHandle_HS {
va_list args;
va_start(args, fmt);
- int result = vsnprintf(msgBuffer, sizeof(msgBuffer) - 1, fmt.c_str(), args);
+ int result = vsnprintf(msgBuffer, sizeof(msgBuffer) - 1, fmt, args);
va_end(args);
if(result > 0) {
@@ -255,7 +255,7 @@ typedef struct GEOSContextHandle_HS {
void
- ERROR_MESSAGE(string fmt, ...)
+ ERROR_MESSAGE(const char *fmt, ...)
if(NULL == errorMessageOld && NULL == errorMessageNew) {
return;
@@ -263,7 +263,7 @@ typedef struct GEOSContextHandle_HS {
va_list args;
va_end(args);
if(result > 0) {
Summary of changes:
NEWS | 1 +
capi/geos_ts_c.cpp | 8 ++++----
2 files changed, 5 insertions(+), 4 deletions(-)
hooks/post-receive
More information about the geos-commits
