[geos-commits] [SCM] GEOS branch master updated. 66908f9e268661a25cc38bd9d17a4bc566b516e9
Tue Apr 28 13:40:40 PDT 2020
the project "GEOS".
       via  66908f9e268661a25cc38bd9d17a4bc566b516e9 (commit)
       via  0909042df5f8d4b9ae1832b3fd67713e206057fb (commit)
      from  5ac945758d82a134c1c9bcde0c5c3f723b29f4c3 (commit)
revisions in full, below.
commit 66908f9e268661a25cc38bd9d17a4bc566b516e9
Merge: 0909042 5ac9457
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Apr 28 13:40:34 2020 -0700
    Merge branch 'master' of https://git.osgeo.org/gitea/geos/geos
commit 0909042df5f8d4b9ae1832b3fd67713e206057fb
Date:   Tue Apr 28 13:39:11 2020 -0700
    Port MaximumInscribedCircle and LargestEmptyCircle
    From https://github.com/locationtech/jts/pull/530
    Closes #1029
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml
index 3c16549..2d4d4e9 100644
--- a/.azure-pipelines.yml
+++ b/.azure-pipelines.yml
@@ -158,11 +158,10 @@ stages:
       matrix:
         #Disabled until MSVC 16.4 is released
         #(see https://developercommunity.visualstudio.com/content/problem/726778/this-snippet-compiles-totally-fine-on-godbolt-msvc.html?childToView=744771#comment-744771)
-        #VS 2019 C++20 Strict:
-        #  TOOLSET: msvc-14.2
-        #  CXXSTD: 20
-        #  CXXFLAGS: -permissive-
-        #  VM_IMAGE: 'windows-2019'
+        VS 2019 C++20 Strict:
+          TOOLSET: msvc-14.2
+          CXXSTD: 20
+          VM_IMAGE: 'windows-2019'
         VS 2017 C++17:
           TOOLSET: msvc-14.1
           CXXSTD: 17
@@ -171,10 +170,6 @@ stages:
           TOOLSET: msvc-14.1
           CXXSTD: 14 # default
           VM_IMAGE: 'vs2017-win2016'
-        VS 2015 C++14:
-          TOOLSET: msvc-14.0
-          CXXSTD: 14 # default
-          VM_IMAGE: 'vs2015-win2012r2'
     pool:
       vmImage: $(VM_IMAGE)
     steps:
@@ -202,7 +197,7 @@ stages:
   - job: 'macOS'
     pool:
-      vmImage: 'macOS-10.13'
+      vmImage: 'macOS-10.14'
     strategy:
       matrix:
         Xcode 10.1:
@@ -215,30 +210,6 @@ stages:
         Xcode 9.4.1:
           CXXSTD: 11, 14, 17
           XCODE_APP: /Applications/Xcode_9.4.1.app
-        Xcode 9.4:
-          CXXSTD: 11, 14, 17
-          XCODE_APP: /Applications/Xcode_9.4.app
-        Xcode 9.3.1:
-          XCODE_APP: /Applications/Xcode_9.3.1.app
-        Xcode 9.3:
-          CXXSTD: 11, 14
-          XCODE_APP: /Applications/Xcode_9.3.app
-        Xcode 9.2:
-          CXXSTD: 11, 14
-          XCODE_APP: /Applications/Xcode_9.2.app
-        Xcode 9.1:
-          CXXSTD: 11
-          XCODE_APP: /Applications/Xcode_9.1.app
-        Xcode 9.0.1:
-          CXXSTD: 11
-          XCODE_APP: /Applications/Xcode_9.0.1.app
-        Xcode 9.0:
-          CXXSTD: 11
-          XCODE_APP: /Applications/Xcode_9.app
-        Xcode 8.3.3:
-          CXXSTD: 11
-          XCODE_APP: /Applications/Xcode_8.3.3.app
     steps:
     - script: |
         set -e
diff --git a/.gitignore b/.gitignore
index 57712f8..697cb79 100644
--- a/.gitignore
+++ b/.gitignore
@@ -8,6 +8,7 @@ Makefile
 .vimrc
 .dirstamp
 .tm_properties
 *.o
 *.orig
 *.lo
diff --git a/NEWS b/NEWS
index db44ee1..f04c50f 100644
--- a/NEWS
+++ b/NEWS
@@ -2,13 +2,13 @@ Changes in 3.9.0
 2020-xx-xx
 - New things:
+  -  MaximumInscribedCircle and LargestEmptyCircle (JTS-530, Paul Ramsey)
 - Improvements:
   - Stack allocate segments in OverlapUnion (Paul Ramsey)
   - Improve performance of GEOSisValid (Dan Baston)
-  - Update geos-config tool for consistency
-    and escape paths (https://git.osgeo.org/gitea/geos/geos/pulls/99)
+  - Update geos-config tool for consistency
+    and escape paths (https://git.osgeo.org/gitea/geos/geos/pulls/99)
     changes mostly affect CMake MSVC builds (#1015, Mike Taves)
   - Testing on Rasberry Pi 32-bit (berrie) (#1017, Bruce Rindahl, Regina Obe)
   - Replace ttmath with JTS DD double-double implementation (Paul Ramsey)
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index acf5cb3..8e4547d 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -458,6 +458,18 @@ extern "C" {
     Geometry*
+    GEOSMaximumInscribedCircle(const Geometry* g, double tolerance)
+        return GEOSMaximumInscribedCircle_r(handle, g, tolerance);
+    Geometry*
+    GEOSLargestEmptyCircle(const Geometry* g, double tolerance)
+        return GEOSLargestEmptyCircle_r(handle, g, tolerance);
+    Geometry*
     GEOSMinimumWidth(const Geometry* g)
         return GEOSMinimumWidth_r(handle, g);
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 0de0be1..e411f79 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -561,6 +561,9 @@ extern GEOSGeometry GEOS_DLL *GEOSConvexHull_r(GEOSContextHandle_t handle,
 extern GEOSGeometry GEOS_DLL *GEOSMinimumRotatedRectangle_r(GEOSContextHandle_t handle,
                                                const GEOSGeometry* g);
+extern GEOSGeometry GEOS_DLL *GEOSMaximumInscribedCircle_r(GEOSContextHandle_t handle, const GEOSGeometry* g, double tolerance);
+extern GEOSGeometry GEOS_DLL *GEOSLargestEmptyCircle_r(GEOSContextHandle_t handle, const GEOSGeometry* g, double tolerance);
 /* Returns a LINESTRING geometry which represents the minimum diameter of the geometry.
  * The minimum diameter is defined to be the width of the smallest band that
  * contains the geometry, where a band is a strip of the plane defined
@@ -1599,6 +1602,38 @@ extern GEOSGeometry GEOS_DLL *GEOSConvexHull(const GEOSGeometry* g);
 extern GEOSGeometry GEOS_DLL *GEOSMinimumRotatedRectangle(const GEOSGeometry* g);
+/* Constructs the Maximum Inscribed Circle for a  polygonal geometry, up to a specified tolerance.
+ * The Maximum Inscribed Circle is determined by a point in the interior of the area
+ * which has the farthest distance from the area boundary, along with a boundary point at that distance.
+ * In the context of geography the center of the Maximum Inscribed Circle is known as the
+ * Pole of Inaccessibility. A cartographic use case is to determine a suitable point
+ * to place a map label within a polygon.
+ * The radius length of the Maximum Inscribed Circle is a  measure of how "narrow" a polygon is. It is the
+ * distance at which the negative buffer becomes empty.
+ * The class supports polygons with holes and multipolygons.
+ * The implementation uses a successive-approximation technique over a grid of square cells covering the area geometry.
+ * The grid is refined using a branch-and-bound algorithm. Point containment and distance are computed in a performant
+ * way by using spatial indexes.
+ * Returns a two-point linestring, with one point at the center of the inscribed circle and the other
+ * on the boundary of the inscribed circle.
+extern GEOSGeometry GEOS_DLL *GEOSMaximumInscribedCircle(const GEOSGeometry* g, double tolerance);
+/* Constructs the Largest Empty Circle for a set of obstacle geometries, up to a
+ * specified tolerance. The obstacles are point and line geometries.
+ * The Largest Empty Circle is the largest circle which  has its center in the convex hull of the
+ * obstacles (the boundary), and whose interior does not intersect with any obstacle.
+ * The circle center is the point in the interior of the boundary which has the farthest distance from
+ * the obstacles (up to tolerance). The circle is determined by the center point and a point lying on an
+ * obstacle indicating the circle radius.
+ * The implementation uses a successive-approximation technique over a grid of square cells covering the obstacles and boundary.
+extern GEOSGeometry GEOS_DLL *GEOSLargestEmptyCircle(const GEOSGeometry* g, double tolerance);
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index d46a0af..a4b2692 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -48,6 +48,8 @@
 #include <geos/algorithm/MinimumBoundingCircle.h>
 #include <geos/algorithm/MinimumDiameter.h>
 #include <geos/algorithm/Orientation.h>
+#include <geos/algorithm/construct/MaximumInscribedCircle.h>
+#include <geos/algorithm/construct/LargestEmptyCircle.h>
 #include <geos/algorithm/distance/DiscreteHausdorffDistance.h>
 #include <geos/algorithm/distance/DiscreteFrechetDistance.h>
 #include <geos/simplify/DouglasPeuckerSimplifier.h>
@@ -1159,6 +1161,28 @@ extern "C" {
     Geometry*
+    GEOSMaximumInscribedCircle_r(GEOSContextHandle_t extHandle, const Geometry* g, double tolerance)
+        return execute(extHandle, [&]() {
+            geos::algorithm::construct::MaximumInscribedCircle mic(g, tolerance);
+            auto g3 = mic.getRadiusLine();
+            g3->setSRID(g->getSRID());
+            return g3.release();
+    Geometry*
+    GEOSLargestEmptyCircle_r(GEOSContextHandle_t extHandle, const Geometry* g, double tolerance)
+            geos::algorithm::construct::LargestEmptyCircle lec(g, tolerance);
+            auto g3 = lec.getRadiusLine();
+    Geometry*
     GEOSMinimumWidth_r(GEOSContextHandle_t extHandle, const Geometry* g)
diff --git a/configure.ac b/configure.ac
index 1eade62..1c149aa 100644
--- a/configure.ac
+++ b/configure.ac
@@ -364,8 +364,9 @@ AC_OUTPUT([
 	macros/Makefile
 	src/Makefile
 	src/algorithm/Makefile
-	src/algorithm/locate/Makefile
+	src/algorithm/construct/Makefile
 	src/algorithm/distance/Makefile
+	src/algorithm/locate/Makefile
 	src/geom/Makefile
 	src/geom/prep/Makefile
 	src/geom/util/Makefile
@@ -376,6 +377,7 @@ AC_OUTPUT([
 	include/geos/algorithm/Makefile
 	include/geos/algorithm/locate/Makefile
 	include/geos/algorithm/distance/Makefile
+	include/geos/algorithm/construct/Makefile
 	include/geos/geom/Makefile
 	include/geos/geom/prep/Makefile
 	include/geos/geom/util/Makefile
diff --git a/include/geos/algorithm/Makefile.am b/include/geos/algorithm/Makefile.am
index dbd5a61..67fc727 100644
--- a/include/geos/algorithm/Makefile.am
+++ b/include/geos/algorithm/Makefile.am
@@ -3,7 +3,8 @@
 SUBDIRS = \
 	locate \
-	distance
+	distance \
+	construct
 EXTRA_DIST =
diff --git a/include/geos/algorithm/construct/LargestEmptyCircle.h b/include/geos/algorithm/construct/LargestEmptyCircle.h
new file mode 100644
index 0000000..fb8c8de
--- /dev/null
+++ b/include/geos/algorithm/construct/LargestEmptyCircle.h
@@ -0,0 +1,207 @@
+ * GEOS - Geometry Engine Open Source
+ * http://geos.osgeo.org
+ * Copyright (C) 2020 Paul Ramsey <pramsey at cleverelephant.ca>
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Public Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
+ * Last port: algorithm/construct/LargestEmptyCircle.java
+ * https://github.com/locationtech/jts/commit/98274a7ea9b40651e9de6323dc10fb2cac17a245
+#ifndef GEOS_ALGORITHM_CONSTRUCT_LARGESTCIRCLE_H
+#define GEOS_ALGORITHM_CONSTRUCT_LARGESTCIRCLE_H
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/Point.h>
+#include <geos/geom/Envelope.h>
+#include <geos/algorithm/locate/IndexedPointInAreaLocator.h>
+#include <geos/operation/distance/IndexedFacetDistance.h>
+#include <memory>
+#include <queue>
+namespace geos {
+namespace geom {
+class Coordinate;
+class Envelope;
+class Geometry;
+class GeometryFactory;
+class LineString;
+class Point;
+namespace operation {
+namespace distance {
+class IndexedFacetDistance;
+namespace geos {
+namespace algorithm { // geos::algorithm
+namespace construct { // geos::algorithm::construct
+ * Computes the Euclidean distance (L2 metric) from a Point to a Geometry.
+ * Also computes two points which are separated by the distance.
+class GEOS_DLL LargestEmptyCircle {
+public:
+    * Creates a new instance of a Largest Empty Circle construction.
+    * @param obstacles a geometry representing the obstacles (points and lines)
+    * @param tolerance the distance tolerance for computing the circle center point
+    LargestEmptyCircle(const geom::Geometry* polygonal, double tolerance);
+    ~LargestEmptyCircle() = default;
+    * Computes the center point of the Largest Empty Circle
+    * `within a set of obstacles, up to a given tolerance distance.
+    * @param tolerance the distance tolerance for computing the center point
+    * @return the center point of the Largest Empty Circle
+    static std::unique_ptr<geom::Point> getCenter(const geom::Geometry* polygonal, double tolerance);
+    * Computes a radius line of the Largest Empty Circle
+    * within a set of obstacles, up to a given distance tolerance.
+    * @return a line from the center of the circle to a point on the edge
+    static std::unique_ptr<geom::LineString> getRadiusLine(const geom::Geometry* polygonal, double tolerance);
+    std::unique_ptr<geom::Point> getCenter();
+    std::unique_ptr<geom::Point> getRadiusPoint();
+    std::unique_ptr<geom::LineString> getRadiusLine();
+private:
+    /* private members */
+    double tolerance;
+    const geom::Geometry* obstacles;
+    const geom::GeometryFactory* factory;
+    std::unique_ptr<geom::Geometry> boundary; // convexhull(obstacles)
+    operation::distance::IndexedFacetDistance obstacleDistance;
+    bool done;
+    std::unique_ptr<algorithm::locate::IndexedPointInAreaLocator> ptLocator;
+    std::unique_ptr<operation::distance::IndexedFacetDistance> boundaryDistance;
+    geom::Coordinate centerPt;
+    geom::Coordinate radiusPt;
+    /* private methods */
+    void setBoundary(const geom::Geometry* obstacles);
+    * Computes the signed distance from a point to the constraints
+    * (obstacles and boundary).
+    * Points outside the boundary polygon are assigned a negative distance.
+    * Their containing cells will be last in the priority queue
+    * (but will still end up being tested since they may be refined).
+    * @param p the point to compute the distance for
+    * @return the signed distance to the constraints (negative indicates outside the boundary)
+    double distanceToConstraints(const geom::Coordinate& c);
+    double distanceToConstraints(double x, double y);
+    void compute();
+    /* private class */
+    class Cell {
+    private:
+        static constexpr double SQRT2 = 1.4142135623730951;
+        double x;
+        double y;
+        double hSize;
+        double distance;
+        double maxDist;
+    public:
+        Cell(double p_x, double p_y, double p_hSize, double p_distanceToConstraints)
+            : x(p_x)
+            , y(p_y)
+            , hSize(p_hSize)
+            , distance(p_distanceToConstraints)
+            , maxDist(p_distanceToConstraints + (p_hSize*SQRT2))
+        geom::Envelope getEnvelope() const
+            geom::Envelope env(x-hSize, x+hSize, y-hSize, y+hSize);
+            return env;
+        bool isFullyOutside() const
+            return maxDist < 0.0;
+        bool isOutside() const
+            return distance < 0.0;
+        double getMaxDistance() const
+            return maxDist;
+        double getDistance() const
+            return distance;
+        double getHSize() const
+            return hSize;
+        double getX() const
+            return x;
+        double getY() const
+            return y;
+        bool operator< (const Cell& rhs) const
+            return maxDist < rhs.maxDist;
+        bool operator> (const Cell& rhs) const
+            return maxDist > rhs.maxDist;
+        bool operator==(const Cell& rhs) const
+            return maxDist == rhs.maxDist;
+    bool mayContainCircleCenter(const Cell& cell, const Cell& farthestCell);
+    void createInitialGrid(const geom::Envelope* env, std::priority_queue<Cell>& cellQueue);
+    Cell createCentroidCell(const geom::Geometry* geom);
+} // geos::algorithm::construct
+} // geos
+#endif // GEOS_ALGORITHM_CONSTRUCT_LARGESTCIRCLE_H
diff --git a/include/geos/algorithm/construct/Makefile.am b/include/geos/algorithm/construct/Makefile.am
index 0000000..5986e03
--- /dev/null
+++ b/include/geos/algorithm/construct/Makefile.am
@@ -0,0 +1,12 @@
+# This file is part of project GEOS (http://trac.osgeo.org/geos/)
+SUBDIRS =
+EXTRA_DIST =
+geosdir = $(includedir)/geos/algorithm/construct
+geos_HEADERS = \
+    LargestEmptyCircle.h \
+    MaximumInscribedCircle.h
diff --git a/include/geos/algorithm/construct/MaximumInscribedCircle.h b/include/geos/algorithm/construct/MaximumInscribedCircle.h
index 0000000..fef9ccf
--- /dev/null
+++ b/include/geos/algorithm/construct/MaximumInscribedCircle.h
@@ -0,0 +1,198 @@
+ * Last port: algorithm/construct/MaximumInscribedCircle.java
+#ifndef GEOS_ALGORITHM_CONSTRUCT_MAXIMUMCIRCLE_H
+#define GEOS_ALGORITHM_CONSTRUCT_MAXIMUMCIRCLE_H
+#include <memory>
+#include <queue>
+namespace geos {
+namespace geom {
+class Coordinate;
+class Envelope;
+class Geometry;
+class LineString;
+class Point;
+using geos::algorithm::locate::IndexedPointInAreaLocator;
+using geos::operation::distance::IndexedFacetDistance;
+namespace geos {
+class GEOS_DLL MaximumInscribedCircle {
+public:
+    MaximumInscribedCircle(const geom::Geometry* polygonal, double tolerance);
+    ~MaximumInscribedCircle() = default;
+    * Gets the center point of the maximum inscribed circle
+    * (up to the tolerance distance).
+    * @return the center point of the maximum inscribed circle
+    * Gets a point defining the radius of the Maximum Inscribed Circle.
+    * This is a point on the boundary which is
+    * nearest to the computed center of the Maximum Inscribed Circle.
+    * The line segment from the center to this point
+    * is a radius of the constructed circle, and this point
+    * lies on the boundary of the circle.
+    * @return a point defining the radius of the Maximum Inscribed Circle
+    * Gets a line representing a radius of the Largest Empty Circle.
+    * Computes the center point of the Maximum Inscribed Circle
+    * of a polygonal geometry, up to a given tolerance distance.
+    * @param polygonal a polygonal geometry
+    * Computes a radius line of the Maximum Inscribed Circle
+    * @return a line from the center to a point on the circle
+private:
+    const geom::Geometry* inputGeom;
+    std::unique_ptr<geom::Geometry> inputGeomBoundary;
+    double tolerance;
+    IndexedFacetDistance indexedDistance;
+    IndexedPointInAreaLocator ptLocator;
+    bool done;
+    double distanceToBoundary(const geom::Coordinate& c);
+    double distanceToBoundary(double x, double y);
+    void compute();
+    class Cell {
+    private:
+        double x;
+        double y;
+        double hSize;
+        double distance;
+        double maxDist;
+    public:
+        Cell(double p_x, double p_y, double p_hSize, double p_distanceToBoundary)
+            : x(p_x)
+            , y(p_y)
+            , hSize(p_hSize)
+            , distance(p_distanceToBoundary)
+            , maxDist(p_distanceToBoundary+(p_hSize*SQRT2))
+            return env;
+            return maxDist;
+            return distance;
+            return hSize;
+            return x;
+            return y;
+} // geos
+#endif // GEOS_ALGORITHM_CONSTRUCT_MAXIMUMCIRCLE_H
diff --git a/include/geos/geom/Envelope.h b/include/geos/geom/Envelope.h
index 7f7da87..9ecca80 100644
--- a/include/geos/geom/Envelope.h
+++ b/include/geos/geom/Envelope.h
@@ -453,6 +453,28 @@ public:
     double distance(const Envelope* env) const;
+    /** \brief
+     * Computes the distance between one Coordinate and an Envelope
+     * defined by two other Coordinates. The order of the Coordinates
+     * used to define the envelope is not significant.
+     * @param c the coordinate to from which distance should be found
+     * @param p1 first coordinate defining an envelope
+     * @param p2 second coordinate defining an envelope.
+    static double distanceToCoordinate(const Coordinate & c, const Coordinate & p1, const Coordinate & p2);
+    /** \brief
+     * Computes the squared distance between one Coordinate and an Envelope
+    static double distanceSquaredToCoordinate(const Coordinate & c, const Coordinate & p1, const Coordinate & p2);
     size_t hashCode() const;
 private:
diff --git a/include/geos/geom/Envelope.inl b/include/geos/geom/Envelope.inl
index 30599f0..7942cb6 100644
--- a/include/geos/geom/Envelope.inl
+++ b/include/geos/geom/Envelope.inl
@@ -19,7 +19,9 @@
 #ifndef GEOS_GEOM_ENVELOPE_INL
 #define GEOS_GEOM_ENVELOPE_INL
+#include <algorithm> // std::min, std::max
 #include <cassert>
+#include <numeric> // std::signbit
@@ -262,6 +264,25 @@ Envelope::setToNull()
     maxy = -1;
+INLINE double
+Envelope::distanceToCoordinate(const Coordinate & c, const Coordinate & p0, const Coordinate & p1) {
+    return std::sqrt(distanceSquaredToCoordinate(c, p0, p1));
+INLINE double
+Envelope::distanceSquaredToCoordinate(const Coordinate & c, const Coordinate & p0, const Coordinate & p1) {
+    double xa = c.x - p0.x;
+    double xb = c.x - p1.x;
+    double ya = c.y - p0.y;
+    double yb = c.y - p1.y;
+    // If sign of a and b are not the same, then Envelope spans c and distance is zero.
+    double dx = (std::signbit(xa) == std::signbit(xb)) * std::min(std::abs(xa), std::abs(xb));
+    double dy = (std::signbit(ya) == std::signbit(yb)) * std::min(std::abs(ya), std::abs(yb));
+    return dx*dx + dy*dy;
 } // namespace geos::geom
 } // namespace geos
diff --git a/include/geos/index/strtree/Boundable.h b/include/geos/index/strtree/Boundable.h
index e8c34fb..290ee1f 100644
--- a/include/geos/index/strtree/Boundable.h
+++ b/include/geos/index/strtree/Boundable.h
@@ -40,8 +40,7 @@ public:
     virtual const void* getBounds() const = 0;
     virtual bool isLeaf() const = 0;
-    virtual
-    ~Boundable() {}
+    virtual ~Boundable() {}
diff --git a/src/algorithm/Makefile.am b/src/algorithm/Makefile.am
index 75dfb6c..a4a8180 100644
--- a/src/algorithm/Makefile.am
+++ b/src/algorithm/Makefile.am
@@ -3,7 +3,8 @@
 SUBDIRS = \
 	locate \
-	distance
+	distance \
+	construct
 noinst_LTLIBRARIES = libalgorithm.la
@@ -36,4 +37,5 @@ libalgorithm_la_SOURCES = \
 libalgorithm_la_LIBADD = \
 	locate/liblocation.la \
-	distance/libdistance.la
+	distance/libdistance.la \
+	construct/libconstruct.la
diff --git a/src/algorithm/construct/LargestEmptyCircle.cpp b/src/algorithm/construct/LargestEmptyCircle.cpp
index 0000000..6506442
--- /dev/null
+++ b/src/algorithm/construct/LargestEmptyCircle.cpp
@@ -0,0 +1,272 @@
+#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/CoordinateSequenceFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/LineString.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/MultiPolygon.h>
+#include <typeinfo> // for dynamic_cast
+#include <cassert>
+using namespace geos::geom;
+namespace geos {
+namespace algorithm { // geos.algorithm
+namespace construct { // geos.algorithm.construct
+LargestEmptyCircle::LargestEmptyCircle(const Geometry* p_obstacles, double p_tolerance)
+    : tolerance(p_tolerance)
+    , obstacles(p_obstacles)
+    , factory(p_obstacles->getFactory())
+    , boundary(p_obstacles->convexHull())
+    , obstacleDistance(p_obstacles)
+    , done(false)
+    if (p_obstacles->isEmpty()) {
+        throw util::IllegalArgumentException("Empty obstacles geometry is not supported");
+    // if boundary does not enclose an area cannot create a ptLocator
+    if (boundary->getDimension() >= 2) {
+        ptLocator.reset(new algorithm::locate::IndexedPointInAreaLocator(*(boundary.get())));
+        boundaryDistance.reset(new operation::distance::IndexedFacetDistance(boundary.get()));
+/* public static */
+std::unique_ptr<Point>
+LargestEmptyCircle::getCenter(const Geometry* polygonal, double tolerance)
+    LargestEmptyCircle lec(polygonal, tolerance);
+    return lec.getCenter();
+std::unique_ptr<LineString>
+LargestEmptyCircle::getRadiusLine(const Geometry* polygonal, double tolerance)
+    return lec.getRadiusLine();
+/* public */
+LargestEmptyCircle::getCenter()
+    compute();
+    return std::unique_ptr<Point>(factory->createPoint(centerPt));
+/* public */
+LargestEmptyCircle::getRadiusPoint()
+    compute();
+    return std::unique_ptr<Point>(factory->createPoint(radiusPt));
+/* public */
+LargestEmptyCircle::getRadiusLine()
+    compute();
+    auto cl = factory->getCoordinateSequenceFactory()->create(2);
+    cl->setAt(centerPt, 0);
+    cl->setAt(radiusPt, 1);
+    return factory->createLineString(std::move(cl));
+/* private */
+void
+LargestEmptyCircle::createInitialGrid(const Envelope* env, std::priority_queue<Cell>& cellQueue)
+    double minX = env->getMinX();
+    double maxX = env->getMaxX();
+    double minY = env->getMinY();
+    double maxY = env->getMaxY();
+    double width = env->getWidth();
+    double height = env->getHeight();
+    double cellSize = std::min(width, height);
+    double hSize = cellSize / 2.0;
+    // compute initial grid of cells to cover area
+    for (double x = minX; x < maxX; x += cellSize) {
+        for (double y = minY; y < maxY; y += cellSize) {
+            cellQueue.emplace(x+hSize, y+hSize, hSize, distanceToConstraints(x+hSize, y+hSize));
+/* private */
+bool
+LargestEmptyCircle::mayContainCircleCenter(const Cell& cell, const Cell& farthestCell)
+     * Every point in the cell lies outside the boundary,
+     * so they cannot be the center point
+    if (cell.isFullyOutside())
+        return false;
+     * The cell is outside, but overlaps the boundary
+     * so it may contain a point which should be checked.
+     * This is only the case if the potential overlap distance
+     * is larger than the tolerance.
+    if (cell.isOutside()) {
+        bool isOverlapSignificant = cell.getMaxDistance() > tolerance;
+        return isOverlapSignificant;
+     * Cell is inside the boundary. It may contain the center
+     * if the maximum possible distance is greater than the current distance
+     * (up to tolerance).
+    double potentialIncrease = cell.getMaxDistance() - farthestCell.getDistance();
+    return potentialIncrease > tolerance;
+/* private */
+double
+LargestEmptyCircle::distanceToConstraints(const Coordinate& c)
+    bool isOutside = ptLocator && (Location::EXTERIOR == ptLocator->locate(&c));
+    std::unique_ptr<Point> pt(factory->createPoint(c));
+    if (isOutside) {
+        double boundaryDist = boundaryDistance->distance(pt.get());
+        return -boundaryDist;
+    double dist = obstacleDistance.distance(pt.get());
+    return dist;
+/* private */
+double
+LargestEmptyCircle::distanceToConstraints(double x, double y)
+    Coordinate coord(x, y);
+    return distanceToConstraints(coord);
+/* private */
+LargestEmptyCircle::Cell
+LargestEmptyCircle::createCentroidCell(const Geometry* geom)
+    Coordinate c;
+    geom->getCentroid(c);
+    Cell cell(c.x, c.y, 0, distanceToConstraints(c));
+    return cell;
+/* private */
+void
+LargestEmptyCircle::compute()
+    // check if already computed
+    if (done) return;
+    // if ptLocator is not present then result is degenerate (represented as zero-radius circle)
+    if (!ptLocator) {
+        const Coordinate* pt = obstacles->getCoordinate();
+        centerPt = *pt;
+        radiusPt = *pt;
+        done = true;
+        return;
+    // Priority queue of cells, ordered by decreasing distance from constraints
+    std::priority_queue<Cell> cellQueue;
+    createInitialGrid(obstacles->getEnvelopeInternal(), cellQueue);
+    Cell farthestCell = createCentroidCell(obstacles);
+     * Carry out the branch-and-bound search
+     * of the cell space
+    while (!cellQueue.empty()) {
+        // pick the most promising cell from the queue
+        Cell cell = cellQueue.top();
+        cellQueue.pop();
+        // update the center cell if the candidate is further from the constraints
+        if (cell.getDistance() > farthestCell.getDistance()) {
+            farthestCell = cell;
+        * If this cell may contain a better approximation to the center
+        * of the empty circle, then refine it (partition into subcells
+        * which are added into the queue for further processing).
+        * Otherwise the cell is pruned (not investigated further),
+        * since no point in it can be further than the current farthest distance.
+        if (mayContainCircleCenter(cell, farthestCell)) {
+            // split the cell into four sub-cells
+            double h2 = cell.getHSize() / 2;
+            cellQueue.emplace(cell.getX()-h2, cell.getY()-h2, h2, distanceToConstraints(cell.getX()-h2, cell.getY()-h2));
+            cellQueue.emplace(cell.getX()+h2, cell.getY()-h2, h2, distanceToConstraints(cell.getX()+h2, cell.getY()-h2));
+            cellQueue.emplace(cell.getX()-h2, cell.getY()+h2, h2, distanceToConstraints(cell.getX()-h2, cell.getY()+h2));
+            cellQueue.emplace(cell.getX()+h2, cell.getY()+h2, h2, distanceToConstraints(cell.getX()+h2, cell.getY()+h2));
+    // the farthest cell is the best approximation to the MIC center
+    Cell centerCell = farthestCell;
+    centerPt.x = centerCell.getX();
+    centerPt.y = centerCell.getY();
+    // compute radius point
+    std::unique_ptr<Point> centerPoint(factory->createPoint(centerPt));
+    std::vector<geom::Coordinate> nearestPts = obstacleDistance.nearestPoints(centerPoint.get());
+    radiusPt = nearestPts[0];
+    // flag computation
+    done = true;
+} // namespace geos.algorithm.construct
diff --git a/src/algorithm/construct/Makefile.am b/src/algorithm/construct/Makefile.am
index 0000000..d9e47aa
--- /dev/null
+++ b/src/algorithm/construct/Makefile.am
@@ -0,0 +1,14 @@
+SUBDIRS =
+noinst_LTLIBRARIES = libconstruct.la
+AM_CPPFLAGS = -I$(top_srcdir)/include
+libconstruct_la_SOURCES = \
+    LargestEmptyCircle.cpp \
+    MaximumInscribedCircle.cpp
+libconstruct_la_LIBADD =
diff --git a/src/algorithm/construct/MaximumInscribedCircle.cpp b/src/algorithm/construct/MaximumInscribedCircle.cpp
index 0000000..b68c942
--- /dev/null
+++ b/src/algorithm/construct/MaximumInscribedCircle.cpp
@@ -0,0 +1,232 @@
+#include <cassert>
+namespace geos {
+/* public */
+MaximumInscribedCircle::MaximumInscribedCircle(const Geometry* polygonal, double p_tolerance)
+    : inputGeom(polygonal)
+    , inputGeomBoundary(polygonal->getBoundary())
+    , tolerance(p_tolerance)
+    , indexedDistance(inputGeomBoundary.get())
+    , ptLocator(*polygonal)
+    , factory(polygonal->getFactory())
+    , done(false)
+    if (!(typeid(*polygonal) == typeid(Polygon) ||
+          typeid(*polygonal) == typeid(MultiPolygon))) {
+        throw util::IllegalArgumentException("Input geometry must be a Polygon or MultiPolygon");
+    if (polygonal->isEmpty()) {
+        throw util::IllegalArgumentException("Empty input geometry is not supported");
+MaximumInscribedCircle::getCenter(const Geometry* polygonal, double tolerance)
+    MaximumInscribedCircle mic(polygonal, tolerance);
+    return mic.getCenter();
+MaximumInscribedCircle::getRadiusLine(const Geometry* polygonal, double tolerance)
+    return mic.getRadiusLine();
+/* public */
+MaximumInscribedCircle::getCenter()
+    compute();
+    auto pt = factory->createPoint(centerPt);
+    return std::unique_ptr<Point>(pt);
+/* public */
+MaximumInscribedCircle::getRadiusPoint()
+    compute();
+    auto pt = factory->createPoint(radiusPt);
+/* public */
+MaximumInscribedCircle::getRadiusLine()
+    compute();
+/* private */
+void
+MaximumInscribedCircle::createInitialGrid(const Envelope* env, std::priority_queue<Cell>& cellQueue)
+            cellQueue.emplace(x+hSize, y+hSize, hSize, distanceToBoundary(x+hSize, y+hSize));
+/* private */
+double
+MaximumInscribedCircle::distanceToBoundary(const Coordinate& c)
+    double dist = indexedDistance.distance(pt.get());
+    // double dist = inputGeomBoundary->distance(pt.get());
+    bool isOutside = (Location::EXTERIOR == ptLocator.locate(&c));
+    if (isOutside) return -dist;
+    return dist;
+/* private */
+double
+MaximumInscribedCircle::distanceToBoundary(double x, double y)
+    return distanceToBoundary(coord);
+/* private */
+MaximumInscribedCircle::Cell
+MaximumInscribedCircle::createCentroidCell(const Geometry* geom)
+    Coordinate c;
+    Cell cell(c.x, c.y, 0, distanceToBoundary(c));
+    return cell;
+/* private */
+void
+MaximumInscribedCircle::compute()
+    if (done) return;
+    // Priority queue of cells, ordered by maximum distance from boundary
+    createInitialGrid(inputGeom->getEnvelopeInternal(), cellQueue);
+    // use the area centroid as the initial candidate center point
+    Cell farthestCell = createCentroidCell(inputGeom);
+        cellQueue.pop();
+        // std::cout << i << ": (" << cell.getX() << ", " << cell.getY() << ") " << cell.getHSize() << " dist = " << cell.getDistance() << std::endl;
+        // update the center cell if the candidate is further from the boundary
+        * Refine this cell if the potential distance improvement
+        * is greater than the required tolerance.
+        * since no point in it is further than
+        * the current farthest distance.
+        if (potentialIncrease > tolerance) {
+            cellQueue.emplace(cell.getX()-h2, cell.getY()-h2, h2, distanceToBoundary(cell.getX()-h2, cell.getY()-h2));
+            cellQueue.emplace(cell.getX()+h2, cell.getY()-h2, h2, distanceToBoundary(cell.getX()+h2, cell.getY()-h2));
+            cellQueue.emplace(cell.getX()-h2, cell.getY()+h2, h2, distanceToBoundary(cell.getX()-h2, cell.getY()+h2));
+            cellQueue.emplace(cell.getX()+h2, cell.getY()+h2, h2, distanceToBoundary(cell.getX()+h2, cell.getY()+h2));
+    // std::cout << "number of iterations: " << i << std::endl;
+    std::vector<geom::Coordinate> nearestPts = indexedDistance.nearestPoints(centerPoint.get());
+    done = true;
diff --git a/src/index/strtree/BoundablePair.cpp b/src/index/strtree/BoundablePair.cpp
index 60409b7..aa7820c 100644
--- a/src/index/strtree/BoundablePair.cpp
+++ b/src/index/strtree/BoundablePair.cpp
@@ -77,7 +77,8 @@ BoundablePair::isLeaves() const
 bool
 BoundablePair::isComposite(const Boundable* item)
-    return dynamic_cast<const AbstractNode*>(item) != nullptr;
+    return !(item->isLeaf());
+    // return dynamic_cast<const AbstractNode*>(item) != nullptr;
 double
diff --git a/src/operation/distance/FacetSequence.cpp b/src/operation/distance/FacetSequence.cpp
index 6633e81..e1589c7 100644
--- a/src/operation/distance/FacetSequence.cpp
+++ b/src/operation/distance/FacetSequence.cpp
@@ -95,6 +95,9 @@ FacetSequence::nearestLocations(const FacetSequence& facetSeq)  const
         const Coordinate& seqPt = facetSeq.pts->getAt(facetSeq.start);
         GeometryLocation gl1(geom, start, pt);
         GeometryLocation gl2(facetSeq.geom, facetSeq.start, seqPt);
+        locs.clear();
+        locs.push_back(gl1);
+        locs.push_back(gl2);
     else if (isPointThis) {
         const Coordinate& pt = pts->getAt(start);
@@ -120,15 +123,11 @@ FacetSequence::computeDistancePointLine(const Coordinate& pt,
                                         std::vector<GeometryLocation> *locs) const
     double minDistance = std::numeric_limits<double>::infinity();
-    double dist;
     for(size_t i = facetSeq.start; i < facetSeq.end - 1; i++) {
         const Coordinate& q0 = facetSeq.pts->getAt(i);
         const Coordinate& q1 = facetSeq.pts->getAt(i + 1);
-        dist = Distance::pointToSegment(pt, q0, q1);
-        if(dist == 0.0) {
-            return dist;
+        double dist = Distance::pointToSegment(pt, q0, q1);
         if(dist < minDistance) {
             minDistance = dist;
             if (locs != nullptr) {
diff --git a/src/operation/overlay/snap/LineStringSnapper.cpp b/src/operation/overlay/snap/LineStringSnapper.cpp
index aadef3b..9b89580 100644
--- a/src/operation/overlay/snap/LineStringSnapper.cpp
+++ b/src/operation/overlay/snap/LineStringSnapper.cpp
@@ -24,6 +24,7 @@
 #include <geos/geom/CoordinateList.h>
 #include <geos/util/UniqueCoordinateArrayFilter.h>
 #include <geos/geom/LineSegment.h>
 #include <geos/util/Interrupt.h>
@@ -431,6 +432,10 @@ LineStringSnapper::findSegmentToSnap(
+        if (Envelope::distanceSquaredToCoordinate(snapPt, seg.p0, seg.p1) >= minDist*minDist) {
+            continue;
         double dist = seg.distance(snapPt);
         if(dist >= minDist) {
 #if GEOS_DEBUG
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 3c836fc..cef4374 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -46,6 +46,8 @@ geos_unit_SOURCES = \
 	algorithm/CGAlgorithms/isPointInRingTest.cpp \
 	algorithm/CGAlgorithms/signedAreaTest.cpp \
 	algorithm/ConvexHullTest.cpp \
+	algorithm/construct/LargestEmptyCircleTest.cpp \
+	algorithm/construct/MaximumInscribedCircleTest.cpp \
 	algorithm/distance/DiscreteFrechetDistanceTest.cpp \
 	algorithm/distance/DiscreteHausdorffDistanceTest.cpp \
 	algorithm/InteriorPointAreaTest.cpp \
@@ -87,6 +89,7 @@ geos_unit_SOURCES = \
 	capi/GEOSisValidDetailTest.cpp \
 	capi/GEOSLineString_PointTest.cpp \
 	capi/GEOSMakeValidTest.cpp \
+	capi/GEOSMaximumInscribedCircleTest.cpp \
 	capi/GEOSMinimumBoundingCircleTest.cpp \
 	capi/GEOSMinimumClearanceTest.cpp \
 	capi/GEOSMinimumRectangleTest.cpp \
diff --git a/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp b/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
index 0000000..a424772
--- /dev/null
+++ b/tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
@@ -0,0 +1,243 @@
+// Test Suite for geos::algorithm::construct::LargestEmptyCircle
+#include <tut/tut.hpp>
+// geos
+#include <geos/geom/CoordinateArraySequence.h>
+#include <geos/geom/Dimension.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+using namespace geos;
+using geos::algorithm::construct::LargestEmptyCircle;
+namespace tut {
+// Test Group
+// dummy data, not used
+struct test_lec_data {
+    geos::geom::Geometry* geom_;
+    geos::geom::PrecisionModel pm_;
+    geos::geom::GeometryFactory::Ptr factory_;
+    geos::io::WKTReader reader_;
+    geos::io::WKTWriter writer_;
+    test_lec_data():
+        geom_(nullptr),
+        pm_(geos::geom::PrecisionModel::FLOATING),
+        factory_(GeometryFactory::create(&pm_, 0)),
+        reader_(factory_.get())
+    ~test_lec_data()
+        factory_->destroyGeometry(geom_);
+        geom_ = nullptr;
+    void
+    ensure_equals_coordinate(const geos::geom::Coordinate &lhs,
+                             const geos::geom::Coordinate &rhs, double tolerance)
+        ensure_equals("x coordinate does not match", lhs.x, rhs.x, tolerance);
+        ensure_equals("y coordinate does not match", lhs.y, rhs.y, tolerance);
+    void
+    checkCircle(const Geometry *geom, double build_tolerance, double x, double y, double expectedRadius)
+        double tolerance = 2*build_tolerance;
+        LargestEmptyCircle lec(geom, tolerance);
+        std::unique_ptr<Point> centerPoint = lec.getCenter();
+        const Coordinate* centerPt = centerPoint->getCoordinate();
+        Coordinate expectedCenter(x, y);
+        ensure_equals_coordinate(*centerPt, expectedCenter, tolerance);
+        std::unique_ptr<LineString> radiusLine = lec.getRadiusLine();
+        double actualRadius = radiusLine->getLength();
+        ensure_equals("radius", actualRadius, expectedRadius, tolerance);
+        const Coordinate& linePt0 = radiusLine->getCoordinateN(0);
+        const Coordinate& linePt1 = radiusLine->getCoordinateN(1);
+        // std::cout << std::endl;
+        // std::cout << writer_.write(geom) << std::endl;
+        // std::cout << writer_.write(radiusLine.get()) << std::endl;
+        ensure_equals_coordinate(*centerPt, linePt0, tolerance);
+        const Coordinate* radiusPt = lec.getRadiusPoint()->getCoordinate();
+        ensure_equals_coordinate(*radiusPt, linePt1, tolerance);
+    void
+    checkCircleZeroRadius(const Geometry *geom, double tolerance)
+        ensure_equals("radius", actualRadius, 0.0, tolerance);
+    void
+    checkCircleZeroRadius(std::string wkt, double tolerance)
+        std::unique_ptr<Geometry> geom(reader_.read(wkt));
+        checkCircleZeroRadius(geom.get(), tolerance);
+    void
+    checkCircle(std::string wkt, double tolerance, double x, double y, double expectedRadius)
+        checkCircle(geom.get(), tolerance, x, y, expectedRadius);
+typedef test_group<test_lec_data> group;
+typedef group::object object;
+group test_lec_group("geos::algorithm::construct::LargestEmptyCircle");
+// testPointsSquare
+template<>
+template<>
+void object::test<1>
+    checkCircle("MULTIPOINT ((100 100), (100 200), (200 200), (200 100))",
+       0.01, 150, 150, 70.71 );}
+// testPointsTriangleOnHull
+template<>
+template<>
+void object::test<2>
+    checkCircle("MULTIPOINT ((100 100), (300 100), (150 50))",
+       0.01, 216.66, 99.99, 83.33 );
+// testPointsTriangleInterior
+template<>
+template<>
+void object::test<3>
+ checkCircle("MULTIPOINT ((100 100), (300 100), (200 250))",
+       0.01, 200.00, 141.66, 108.33 );
+// testLinesOpenDiamond
+template<>
+template<>
+void object::test<4>
+    checkCircle("MULTILINESTRING ((50 100, 150 50), (250 50, 350 100), (350 150, 250 200), (50 150, 150 200))",
+       0.01, 200, 125, 90.13 );}
+//    testLinesCrossed
+template<>
+template<>
+void object::test<5>
+  checkCircle("MULTILINESTRING ((100 100, 300 300), (100 200, 300 0))",
+       0.01, 299.99, 150.00, 106.05 );
+// testLinesZigzag
+template<>
+template<>
+void object::test<6>
+    checkCircle("MULTILINESTRING ((100 100, 200 150, 100 200, 250 250, 100 300, 300 350, 100 400), (50 400, 0 350, 50 300, 0 250, 50 200, 0 150, 50 100))",
+       0.01, 77.52, 349.99, 54.81 );
+// testPointsLinesTriangle
+template<>
+template<>
+void object::test<7>
+checkCircle("GEOMETRYCOLLECTION (LINESTRING (100 100, 300 100), POINT (250 200))",
+       0.01, 196.49, 164.31, 64.31 );
+template<>
+template<>
+void object::test<8>
+checkCircleZeroRadius("POINT (100 100)",
+       0.01 );
+// testLineFlat
+template<>
+template<>
+void object::test<9>
+ checkCircleZeroRadius("LINESTRING (0 0, 50 50)",
+       0.01 );
+} // namespace tut
diff --git a/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
index 0000000..59c674d
--- /dev/null
+++ b/tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
@@ -0,0 +1,180 @@
+// Test Suite for geos::algorithm::construct::MaximumInscribedCircle
+// geos
+// std
+#include <sstream>
+#include <string>
+#include <memory>
+using geos::algorithm::construct::MaximumInscribedCircle;
+namespace tut {
+// Test Group
+struct test_mic_data {
+    test_mic_data():
+        geom_(nullptr),
+    ~test_mic_data()
+        geom_ = nullptr;
+    void
+    void
+        MaximumInscribedCircle mic(geom, tolerance);
+        std::unique_ptr<Point> centerPoint = mic.getCenter();
+        std::unique_ptr<LineString> radiusLine = mic.getRadiusLine();
+        const Coordinate* radiusPt = mic.getRadiusPoint()->getCoordinate();
+    void
+typedef test_group<test_mic_data> group;
+group test_mic_group("geos::algorithm::construct::MaximumInscribedCircle");
+// testSquare
+template<>
+template<>
+    checkCircle("POLYGON ((100 200, 200 200, 200 100, 100 100, 100 200))",
+                0.001, 150, 150, 50);
+// testDiamond
+template<>
+template<>
+    checkCircle("POLYGON ((150 250, 50 150, 150 50, 250 150, 150 250))",
+                0.001, 150, 150, 70.71 );
+// testCircle
+template<>
+template<>
+    std::unique_ptr<Geometry> geom(reader_.read("POINT (100 100)"));
+    std::unique_ptr<Geometry> circle(geom->buffer(100, 20));
+    // MIC radius is less than 100 because buffer boundary segments lie inside circle
+    checkCircle(circle.get(), 0.01, 100, 100, 99.9229);
+// testDoubleKite
+template<>
+template<>
+    checkCircle("MULTIPOLYGON (((150 200, 100 150, 150 100, 250 150, 150 200)), ((400 250, 300 150, 400 50, 560 150, 400 250)))",
+       0.001, 411.38877, 149.9996185, 78.7634662 );
+// Invalid polygon collapsed to a line
+template<>
+template<>
+    checkCircle("POLYGON ((100 100, 200 200, 100 100, 100 100))",
+       0.01, 150, 150, 0 );
+// // Invalid polygon collapsed to a point
+template<>
+template<>
+     checkCircle("POLYGON ((100 100, 100 100, 100 100, 100 100))",
+       0.01, 100, 100, 0 );
+} // namespace tut
diff --git a/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp b/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
index 0000000..210f9e8
--- /dev/null
+++ b/tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
@@ -0,0 +1,106 @@
+// $Id$
+// Test Suite for C-API GEOSGetCentroid
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capimaximuminscribedcircle_data {
+    GEOSGeometry* geom1_;
+    GEOSGeometry* geom2_;
+    GEOSWKTWriter* wktw_;
+    char* wkt_;
+    double area_;
+    static void
+    notice(const char* fmt, ...)
+        std::fprintf(stdout, "NOTICE: ");
+        va_list ap;
+        va_start(ap, fmt);
+        std::vfprintf(stdout, fmt, ap);
+        va_end(ap);
+        std::fprintf(stdout, "\n");
+    test_capimaximuminscribedcircle_data()
+        : geom1_(nullptr), geom2_(nullptr), wkt_(nullptr)
+        initGEOS(notice, notice);
+        wktw_ = GEOSWKTWriter_create();
+        GEOSWKTWriter_setTrim(wktw_, 1);
+        GEOSWKTWriter_setRoundingPrecision(wktw_, 8);
+    ~test_capimaximuminscribedcircle_data()
+        GEOSGeom_destroy(geom1_);
+        GEOSGeom_destroy(geom2_);
+        GEOSWKTWriter_destroy(wktw_);
+        GEOSFree(wkt_);
+        geom1_ = nullptr;
+        geom2_ = nullptr;
+        wkt_ = nullptr;
+        finishGEOS();
+typedef test_group<test_capimaximuminscribedcircle_data> group;
+group test_capimaximuminscribedcircle_group("capi::GEOSMaximumInscribedCircle");
+// Test Cases
+// Single point
+template<>
+template<>
+    geom1_ = GEOSGeomFromWKT("POLYGON ((100 200, 200 200, 200 100, 100 100, 100 200))");
+    ensure(nullptr != geom1_);
+    geom2_ = GEOSMaximumInscribedCircle(geom1_, 0.001);
+    ensure(nullptr != geom2_);
+    wkt_ = GEOSWKTWriter_write(wktw_, geom2_);
+    ensure_equals(std::string(wkt_), std::string("LINESTRING (150 150, 150 200)"));
+// Single point
+template<>
+template<>
+    geom1_ = GEOSGeomFromWKT("MULTIPOINT ((100 100), (100 200), (200 200), (200 100))");
+    geom2_ = GEOSLargestEmptyCircle(geom1_, 0.001);
+    ensure_equals(std::string(wkt_), std::string("LINESTRING (150 150, 100 100)"));
+} // namespace tut
diff --git a/tests/unit/geom/EnvelopeTest.cpp b/tests/unit/geom/EnvelopeTest.cpp
index a68c1c6..bd98f6e 100644
--- a/tests/unit/geom/EnvelopeTest.cpp
+++ b/tests/unit/geom/EnvelopeTest.cpp
@@ -242,5 +242,67 @@ void object::test<9>
     ensure(empty == exemplar);
+// Test point-to-envelope distance
+template<>
+template<>
+void object::test<10>
+    using geos::geom::Coordinate;
+    using geos::geom::Envelope;
+    // Create a 5x5 grid of points and use them to test various
+    // spatial arrangements of the envelope and test point
+    //  0  1  2  3  4
+    //  5  6  7  8  9
+    // 10 11 12 13 14
+    // 15 16 17 18 19
+    // 20 21 22 23 24
+    std::vector<Coordinate> c(25);
+    std::cout<<std::endl;
+    for (size_t i = 0; i < c.size(); i++) {
+        c[i].x = static_cast<double>(i % 5);
+        c[i].y = static_cast<double>(5 - (i / 5));
+        std::cout<< c[i] << std::endl;
+    // point contained in envelope
+    ensure_equals( Envelope::distanceToCoordinate(c[18], c[22], c[9]), 0);
+    ensure_equals( Envelope::distanceToCoordinate(c[18], c[14], c[18]), 0);
+    ensure_equals( Envelope::distanceToCoordinate(c[18], c[14], c[17]), 0);
+    ensure_equals( Envelope::distanceToCoordinate(c[18], c[19], c[22]), 0);
+    // envelope above point
+    ensure_equals(Envelope::distanceToCoordinate(c[17], c[5], c[4]), 2);
+    // envelope below point
+    ensure_equals(Envelope::distanceToCoordinate(c[7], c[20], c[19]), 2);
+    // envelope left of point
+    ensure_equals(Envelope::distanceToCoordinate(c[13], c[20], c[11]), 2);
+    // envelope right of point
+    ensure_equals(Envelope::distanceToCoordinate(c[5], c[9], c[8]), 3);
+    // envelope upper-left of point
+    ensure_equals(Envelope::distanceToCoordinate(c[17], c[6], c[0]),
+            c[17].distance(c[6]));
+    // envelope upper-right of point
+    ensure_equals(Envelope::distanceToCoordinate(c[21], c[9], c[13]),
+            c[21].distance(c[13]));
+    // envelope lower-left of point
+    ensure_equals(Envelope::distanceToCoordinate(c[3], c[10], c[21]),
+                  c[3].distance(c[11]));
+    // envelope lower-right of point
+    ensure_equals(Envelope::distanceToCoordinate(c[6], c[12], c[14]),
+                  c[6].distance(c[12]));
 } // namespace tut
diff --git a/tests/unit/io/WKTReaderTest.cpp b/tests/unit/io/WKTReaderTest.cpp
index fe370d0..a50fe6f 100644
--- a/tests/unit/io/WKTReaderTest.cpp
+++ b/tests/unit/io/WKTReaderTest.cpp
@@ -126,14 +126,14 @@ void object::test<6>
     try {
         geom = wktreader.read("POLYGON( EMPTY, (1 1,2 2,1 2,1 1))");
-        fail("Didn't get expected exception");
+        fail("Did not get expected exception");
     catch(const geos::util::IllegalArgumentException& ex) {
         ensure("Got expected exception", true);
-        ex.what();
+        (void)(ex.what());
     catch(...) {
-        fail("Got unexpected execpetion.");
+        fail("Got unexpected exception");
@@ -162,7 +162,7 @@ void object::test<7>
-        ex.what();
     catch(...) {
diff --git a/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp b/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
index 3dcabb5..a0e2c8a 100644
--- a/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
+++ b/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
@@ -1,12 +1,18 @@
 // Test Suite for geos::operation::distance::DistanceOp class.
+#define _USE_MATH_DEFINES
+// std
+#include <memory>
+#include <string>
+#include <vector>
+#include <cmath>
 // tut
 // geos
-#include <geos/algorithm/PointLocator.h>
-#include <geos/io/WKTReader.h>
-#include <geos/io/WKBReader.h>
+#include <geos/profiler.h>
 #include <geos/constants.h>
@@ -16,12 +22,14 @@
 #include <geos/operation/distance/DistanceOp.h>
-// std
-#include <memory>
-#include <string>
-#include <vector>
+#ifndef M_PI
+#define M_PI 3.14159265358979323846
+#endif
 namespace tut {
@@ -30,13 +38,21 @@ namespace tut {
 // Common data used by tests
 struct test_facetdistanceop_data {
-    geos::io::WKTReader wktreader;
     typedef std::unique_ptr<geos::geom::Geometry> GeomPtr;
     typedef std::unique_ptr<geos::geom::CoordinateSequence> CSPtr;
+    geos::io::WKTWriter _wktwriter;
+    geos::geom::PrecisionModel _pm;
+    geos::geom::GeometryFactory::Ptr _factory;
+    geos::io::WKTReader _wktreader;
     test_facetdistanceop_data()
-        : wktreader()
+        : _wktwriter()
+        , _pm(geos::geom::PrecisionModel::FLOATING)
+        , _factory(geos::geom::GeometryFactory::create(&_pm, 0))
+        , _wktreader(_factory.get())
     void
@@ -44,8 +60,8 @@ struct test_facetdistanceop_data {
                                geos::geom::Coordinate& p1, geos::geom::Coordinate& p2)
-        GeomPtr g1(wktreader.read(wkt1));
-        GeomPtr g2(wktreader.read(wkt2));
+        GeomPtr g1(_wktreader.read(wkt1));
+        GeomPtr g2(_wktreader.read(wkt2));
         std::vector<geos::geom::Coordinate> pts;
         pts = IndexedFacetDistance::nearestPoints(g1.get(), g2.get());
         ensure(fabs(pts[0].distance(pts[1])-distance) < 1e08);
@@ -56,6 +72,37 @@ struct test_facetdistanceop_data {
         return;
+    int
+    angle2sincircle(double theta_deg, double radius, double amplitude, double* x, double* y)
+        // π‘Ÿ=𝑅+π‘Žsin(π‘›πœƒ)
+        int n = 16;
+        double theta = theta_deg * M_PI / 180.0;
+        double a = radius * amplitude;
+        double r = radius + a * std::sin(n*theta);
+        if (x) *x = r * std::cos(theta);
+        if (y) *y = r * std::sin(theta);
+        return 1;
+    std::unique_ptr<geos::geom::LineString>
+    makeSinCircle(size_t nvertices, double radius, double amplitude)
+        geos::geom::CoordinateArraySequence cs;
+        std::vector<geos::geom::Coordinate> coords;
+        for (size_t i = 0; i < nvertices; i++) {
+            geos::geom::Coordinate c;
+            angle2sincircle(i*360.0/nvertices, radius, amplitude, &c.x, &c.y);
+            cs.add(c);
+        std::unique_ptr<geos::geom::LineString> ls(_factory->createLineString(cs));
+        return ls;
 typedef test_group<test_facetdistanceop_data> group;
@@ -64,7 +111,6 @@ typedef group::object object;
 group test_facetdistanceop_group("geos::operation::distance::IndexedFacetDistance");
 // Test Cases
@@ -77,8 +123,8 @@ void object::test<1>
     std::string wkt0("POINT(0 0)");
     std::string wkt1("POINT(10 0)");
-    GeomPtr g0(wktreader.read(wkt0));
+    GeomPtr g0(_wktreader.read(wkt0));
     double d = IndexedFacetDistance::distance(g0.get(), g1.get());
     ensure_equals(d, 10);
@@ -158,8 +204,8 @@ void object::test<6>
     std::string wkt0("POLYGON((100 200, 200 200, 200 100, 100 100, 100 200))");
     std::string wkt1("POINT(150 150)");
     ensure_equals(d, 50);
@@ -174,12 +220,121 @@ void object::test<7>
+template<>
+template<>
+    using geos::operation::distance::IndexedFacetDistance;
+    std::string wkt0("POLYGON((100 200, 200 200, 200 100, 100 100, 100 200))");
+    std::string wkt1("POINT(150 150)");
+    IndexedFacetDistance ifd(g0.get());
+    double d = ifd.distance(g1.get());
+    ensure_equals(d, 50);
+template<>
+template<>
+    std::string wkt0("POLYGON((100 100, 200 200, 100 100, 100 100))");
+    ensure_equals("incorrect distance", d, 0.0, 0.001);
+    std::vector<geos::geom::Coordinate> nearestPts = ifd.nearestPoints(g1.get());
+    ensure_equals("nearest points x", nearestPts[0].x, nearestPts[1].x, 0.00001);
+    ensure_equals("nearest points y", nearestPts[0].y, nearestPts[1].y, 0.00001);
+template<>
+template<>
+    int npoints = 1000; // vertices in sinstar test shape
+    int ncells = 100; // number of colums/rows in test grid square
+    double radius = 100.0;
+    double amplitude = 0.3; // how far the sin deviates from perfect circle (0.0)
+    double width = radius * (1+amplitude); // total radius of shape
+    double cellsize = 2.0*width/ncells; // how big a cell is
+    // Build a sine star of the requested size and prepare
+    // the IndexedFacetDistance for it
+    std::unique_ptr<geos::geom::LineString> ls = makeSinCircle(npoints, radius, amplitude);
+    IndexedFacetDistance ifd(ls.get());
+    // std::string wkt = _wktwriter.write(ls.get());
+    // std::cout << wkt << std::endl;
+    // Build out the set of test points ahead of time so that
+    // point creation overhead isn't included in the test timings
+    std::vector<std::unique_ptr<geos::geom::Point>> pts;
+    for (double x = -width; x < width; x += cellsize) {
+        for (double y = -width; y < width; y += cellsize) {
+            geos::geom::Coordinate c(x, y);
+            pts.emplace(pts.end(), _factory->createPoint(c));
+    geos::util::Profiler prof;
+    enum modes {
+        TestIndexedFacetDistance = 0,
+        TestGeometryDistance = 1,
+        TestBoth = 2
+    std::vector<std::string> profiles = {"TestIndexedFacetDistance",
+                                         "TestGeometryDistance",
+                                         "TestBoth"};
+    bool perfTest = false;
+    std::vector<int> m = {TestBoth};
+    if (perfTest) {
+        m.push_back(TestIndexedFacetDistance);
+        m.push_back(TestGeometryDistance);
+    for (auto it = m.begin() ; it != m.end(); ++it)
+        prof.start(profiles[*it]);
+        for (size_t j = 0; j < pts.size(); j++) {
+            double dist_ifd = 0.0, dist_geom = 0.0;
+            if (*it == TestIndexedFacetDistance || *it == TestBoth)
+                dist_ifd = ifd.distance(pts[j].get());
+            if (*it == TestGeometryDistance || *it == TestBoth)
+                dist_geom = ls->distance(pts[j].get());
+            if (*it == TestBoth)
+                ensure_equals("distance", dist_ifd, dist_geom, 0.00001);
+        prof.stop(profiles[*it]);
+    if (perfTest) {
+        std::cout << "npoints=" << npoints << " ncells=" << ncells << std::endl;
+        std::cout << prof << std::endl;
 // TODO: finish the tests by adding:
diff --git a/tests/unit/operation/geounion/CoverageUnionTest.cpp b/tests/unit/operation/geounion/CoverageUnionTest.cpp
index 2312bfa..91de550 100644
--- a/tests/unit/operation/geounion/CoverageUnionTest.cpp
+++ b/tests/unit/operation/geounion/CoverageUnionTest.cpp
@@ -78,7 +78,9 @@ namespace tut {
         try {
             auto u1 = CoverageUnion::Union(coll.get());
             fail();
-        } catch(const geos::util::TopologyException & e) {}
+        } catch(const geos::util::TopologyException & e) {
+            (void)(e); // silence unused warning
     template<>
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index b44cf31..11eae81 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -166,7 +166,12 @@ getIndent(unsigned int numIndents)
 void
 tolower(std::string& str)
-    std::transform(str.begin(), str.end(), str.begin(), (int(*)(int))std::tolower);
+    std::transform(
+        str.begin(),
+        str.end(),
+        str.begin(),
+        [](unsigned char c){ return std::tolower(c); }
 std::string
Summary of changes:
 .azure-pipelines.yml                               |  39 +--
 .gitignore                                         |   1 +
 NEWS                                               |   6 +-
 capi/geos_c.cpp                                    |  12 +
 capi/geos_c.h.in                                   |  35 +++
 capi/geos_ts_c.cpp                                 |  24 ++
 configure.ac                                       |   4 +-
 include/geos/algorithm/Makefile.am                 |   3 +-
 .../geos/algorithm/construct/LargestEmptyCircle.h  | 207 ++++++++++++++++
 .../geos/{math => algorithm/construct}/Makefile.am |   5 +-
 .../algorithm/construct/MaximumInscribedCircle.h   | 198 +++++++++++++++
 include/geos/index/strtree/Boundable.h             |   3 +-
 src/algorithm/Makefile.am                          |   6 +-
 src/algorithm/construct/LargestEmptyCircle.cpp     | 272 +++++++++++++++++++++
 src/algorithm/construct/Makefile.am                |  14 ++
 src/algorithm/construct/MaximumInscribedCircle.cpp | 232 ++++++++++++++++++
 src/index/strtree/BoundablePair.cpp                |   3 +-
 src/operation/distance/FacetSequence.cpp           |   9 +-
 tests/unit/Makefile.am                             |   3 +
 .../algorithm/construct/LargestEmptyCircleTest.cpp | 243 ++++++++++++++++++
 .../construct/MaximumInscribedCircleTest.cpp       | 180 ++++++++++++++
 tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp | 106 ++++++++
 tests/unit/io/WKTReaderTest.cpp                    |   8 +-
 .../distance/IndexedFacetDistanceTest.cpp          | 191 +++++++++++++--
 .../unit/operation/geounion/CoverageUnionTest.cpp  |   4 +-
 tests/xmltester/XMLTester.cpp                      |   7 +-
 26 files changed, 1740 insertions(+), 75 deletions(-)
 create mode 100644 include/geos/algorithm/construct/LargestEmptyCircle.h
 copy include/geos/{math => algorithm/construct}/Makefile.am (52%)
 create mode 100644 include/geos/algorithm/construct/MaximumInscribedCircle.h
 create mode 100644 src/algorithm/construct/LargestEmptyCircle.cpp
 create mode 100644 src/algorithm/construct/Makefile.am
 create mode 100644 src/algorithm/construct/MaximumInscribedCircle.cpp
 create mode 100644 tests/unit/algorithm/construct/LargestEmptyCircleTest.cpp
 create mode 100644 tests/unit/algorithm/construct/MaximumInscribedCircleTest.cpp
 create mode 100644 tests/unit/capi/GEOSMaximumInscribedCircleTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
