[geos-commits] [SCM] GEOS branch master updated. 1357b728c30c6008d6d4fafba158f0cee71f3e9d
Thu Apr 30 07:25:02 PDT 2020
the project "GEOS".
       via  1357b728c30c6008d6d4fafba158f0cee71f3e9d (commit)
      from  5b7778bf0915e03c3600f536b44d717de861457f (commit)
revisions in full, below.
commit 1357b728c30c6008d6d4fafba158f0cee71f3e9d
Author: Daniel Baston <dbaston at gmail.com>
Date:   Wed Apr 29 23:43:37 2020 -0400
    Remove manual memory management from FacetSequenceTreeBuilder
diff --git a/include/geos/operation/distance/FacetSequenceTreeBuilder.h b/include/geos/operation/distance/FacetSequenceTreeBuilder.h
index fef2ed3..68026f8 100644
--- a/include/geos/operation/distance/FacetSequenceTreeBuilder.h
+++ b/include/geos/operation/distance/FacetSequenceTreeBuilder.h
@@ -19,6 +19,7 @@
 #ifndef GEOS_OPERATION_DISTANCE_FACETSEQUENCETREEBUILDER_H
 #define GEOS_OPERATION_DISTANCE_FACETSEQUENCETREEBUILDER_H
+#include <geos/index/ItemVisitor.h>
 #include <geos/index/strtree/STRtree.h>
 #include <geos/geom/Geometry.h>
 #include <geos/geom/CoordinateSequence.h>
@@ -37,11 +38,35 @@ private:
     static void addFacetSequences(const geom::Geometry* geom,
                                   const geom::CoordinateSequence* pts,
-                                  std::vector<FacetSequence*>& sections);
-    static std::vector<FacetSequence*>* computeFacetSequences(const geom::Geometry* g);
+                                  std::vector<std::unique_ptr<FacetSequence>> & sections);
+    static std::vector<std::unique_ptr<FacetSequence>> computeFacetSequences(const geom::Geometry* g);
+    class FacetSequenceTree : public geos::index::strtree::STRtree {
+        using geos::index::strtree::STRtree::STRtree;
+        struct Deleter : public index::ItemVisitor {
+            void
+            visitItem(void* item) override
+                delete static_cast<FacetSequence*>(item);
+        } deleter;
+    public:
+        ~FacetSequenceTree() override {
+            iterate(deleter);
 public:
-    static geos::index::strtree::STRtree* build(const geom::Geometry* g);
+    /** \brief
+     * Return a tree of FacetSequences constructed from the supplied Geometry.
+     * The FacetSequences are owned by the tree and are automatically deleted by
+     * the tree on destruction.
+    static std::unique_ptr<geos::index::strtree::STRtree> build(const geom::Geometry* g);
diff --git a/include/geos/operation/distance/IndexedFacetDistance.h b/include/geos/operation/distance/IndexedFacetDistance.h
index 0348934..19d7e5b 100644
--- a/include/geos/operation/distance/IndexedFacetDistance.h
+++ b/include/geos/operation/distance/IndexedFacetDistance.h
@@ -98,8 +98,6 @@ public:
     /// \return the nearest points
     std::vector<geom::Coordinate> nearestPoints(const geom::Geometry* g) const;
-    ~IndexedFacetDistance();
 private:
     std::unique_ptr<geos::index::strtree::STRtree> cachedTree;
diff --git a/src/operation/distance/FacetSequenceTreeBuilder.cpp b/src/operation/distance/FacetSequenceTreeBuilder.cpp
index 58e632c..d9c20af 100644
--- a/src/operation/distance/FacetSequenceTreeBuilder.cpp
+++ b/src/operation/distance/FacetSequenceTreeBuilder.cpp
@@ -27,55 +27,55 @@ namespace geos {
 namespace operation {
 namespace distance {
-STRtree*
+std::unique_ptr<STRtree>
 FacetSequenceTreeBuilder::build(const Geometry* g)
-    std::unique_ptr<STRtree> tree(new STRtree(STR_TREE_NODE_CAPACITY));
-    std::unique_ptr<std::vector<FacetSequence*> > sections(computeFacetSequences(g));
-    for(std::vector<FacetSequence*>::iterator it = sections->begin(); it != sections->end(); ++it) {
-        FacetSequence* section = *it;
-        tree->insert(section->getEnvelope(), section);
+    auto tree = std::unique_ptr<STRtree>(new FacetSequenceTree(STR_TREE_NODE_CAPACITY));
+    std::vector<std::unique_ptr<FacetSequence>> sections(computeFacetSequences(g));
+    for(auto& section : sections) {
+        const Envelope* e = section->getEnvelope();
+        tree->insert(e, section.release());
     tree->build();
-    return tree.release();
+    return tree;
-std::vector<FacetSequence*>*
+std::vector<std::unique_ptr<FacetSequence>>
 FacetSequenceTreeBuilder::computeFacetSequences(const Geometry* g)
-    std::unique_ptr<std::vector<FacetSequence*> > sections(new std::vector<FacetSequence*>());
+    std::vector<std::unique_ptr<FacetSequence>> sections;
-    class FacetSequenceAdder;
     class FacetSequenceAdder : public geom::GeometryComponentFilter {
-        std::vector<FacetSequence*>*  m_sections;
+        std::vector<std::unique_ptr<FacetSequence>>&  m_sections;
     public :
-        FacetSequenceAdder(std::vector<FacetSequence*>* p_sections) :
+        FacetSequenceAdder(std::vector<std::unique_ptr<FacetSequence>> & p_sections) :
             m_sections(p_sections) {}
         void
         filter_ro(const Geometry* geom) override
             if(const LineString* ls = dynamic_cast<const LineString*>(geom)) {
                 const CoordinateSequence* seq = ls->getCoordinatesRO();
-                addFacetSequences(geom, seq, *m_sections);
+                addFacetSequences(geom, seq, m_sections);
             else if(const Point* pt = dynamic_cast<const Point*>(geom)) {
                 const CoordinateSequence* seq = pt->getCoordinatesRO();
-    FacetSequenceAdder facetSequenceAdder(sections.get());
+    FacetSequenceAdder facetSequenceAdder(sections);
     g->apply_ro(&facetSequenceAdder);
-    return sections.release();
+    return sections;
 void
 FacetSequenceTreeBuilder::addFacetSequences(const Geometry* geom, const CoordinateSequence* pts,
     size_t i = 0;
     size_t size = pts->size();
@@ -87,8 +87,8 @@ FacetSequenceTreeBuilder::addFacetSequences(const Geometry* geom, const Coordina
         if(end >= size - 1) {
             end = size;
-        FacetSequence* sect = new FacetSequence(geom, pts, i, end);
-        sections.push_back(sect);
+        std::unique_ptr<FacetSequence> sect = detail::make_unique<FacetSequence>(geom, pts, i, end);
+        sections.emplace_back(std::move(sect));
         i += FACET_SEQUENCE_SIZE;
diff --git a/src/operation/distance/IndexedFacetDistance.cpp b/src/operation/distance/IndexedFacetDistance.cpp
index 7c4877c..ccbf78f 100644
--- a/src/operation/distance/IndexedFacetDistance.cpp
+++ b/src/operation/distance/IndexedFacetDistance.cpp
@@ -17,7 +17,6 @@
 #include <geos/geom/Coordinate.h>
-#include <geos/index/ItemVisitor.h>
 #include <geos/operation/distance/IndexedFacetDistance.h>
@@ -27,13 +26,6 @@ using namespace geos::index::strtree;
 namespace geos {
-struct Deleter : public index::ItemVisitor {
-    void
-    visitItem(void* item) override
-        delete static_cast<FacetSequence*>(item);
-} deleter;
 /*public static*/
 double
@@ -73,8 +65,6 @@ IndexedFacetDistance::distance(const Geometry* g) const
     double p_distance = fs1->distance(*fs2);
-    tree2->iterate(deleter);
     return p_distance;
@@ -96,7 +86,6 @@ IndexedFacetDistance::nearestLocations(const geom::Geometry* g) const
     const FacetSequence *fs2 = static_cast<const FacetSequence*>(obj.second);
     std::vector<GeometryLocation> locs;
     locs = fs1->nearestLocations(*fs2);
     return locs;
@@ -110,11 +99,6 @@ IndexedFacetDistance::nearestPoints(const geom::Geometry* g) const
     return nearestPts;
-IndexedFacetDistance::~IndexedFacetDistance()
-    cachedTree->iterate(deleter);
diff --git a/src/precision/MinimumClearance.cpp b/src/precision/MinimumClearance.cpp
index 26f848b..21d3348 100644
--- a/src/precision/MinimumClearance.cpp
+++ b/src/precision/MinimumClearance.cpp
@@ -23,7 +23,6 @@
 #include <geos/geom/CoordinateArraySequenceFactory.h>
 #include <geos/operation/distance/FacetSequenceTreeBuilder.h>
 #include <geos/geom/LineSegment.h>
 using namespace geos::geom;
 using namespace geos::operation::distance;
@@ -165,28 +164,6 @@ MinimumClearance::compute()
-    struct ItemDeleter : public index::ItemVisitor {
-        void
-    struct ManagedResourceSTRtree {
-        STRtree* m_tree;
-        ManagedResourceSTRtree(STRtree* p_tree) : m_tree(p_tree) {}
-        ~ManagedResourceSTRtree()
-            ItemDeleter id;
-            m_tree->iterate(id);
-            delete m_tree;
     // already computed
     if(minClearancePts.get() != nullptr) {
         return;
@@ -202,9 +179,9 @@ MinimumClearance::compute()
         return;
-    ManagedResourceSTRtree tree(FacetSequenceTreeBuilder::build(inputGeom));
+    auto tree = FacetSequenceTreeBuilder::build(inputGeom);
     MinClearanceDistance mcd;
-    std::pair<const void*, const void*> nearest = tree.m_tree->nearestNeighbour(&mcd);
+    std::pair<const void*, const void*> nearest = tree->nearestNeighbour(&mcd);
     minClearance = mcd.distance(
                        static_cast<const FacetSequence*>(nearest.first),
Summary of changes:
 .../operation/distance/FacetSequenceTreeBuilder.h  | 31 ++++++++++++++++--
 .../geos/operation/distance/IndexedFacetDistance.h |  2 --
 .../distance/FacetSequenceTreeBuilder.cpp          | 38 +++++++++++-----------
 src/operation/distance/IndexedFacetDistance.cpp    | 16 ---------
 src/precision/MinimumClearance.cpp                 | 27 ++-------------
 5 files changed, 49 insertions(+), 65 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
