[geos-commits] [SCM] GEOS branch master updated. d23eb6ca3db2d5d2b4b3ab4515dc41a69a875e47
Thu Apr 30 14:19:18 PDT 2020
the project "GEOS".
       via  d23eb6ca3db2d5d2b4b3ab4515dc41a69a875e47 (commit)
      from  dc33ea4d5266da135e07204701efa39db37653fc (commit)
revisions in full, below.
commit d23eb6ca3db2d5d2b4b3ab4515dc41a69a875e47
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Apr 30 14:18:43 2020 -0700
    Remove DoubleBits in favour of exp2 and frexp
    Closes #252, Closes #317
diff --git a/include/geos/index/quadtree/DoubleBits.h b/include/geos/index/quadtree/DoubleBits.h
deleted file mode 100644
index 9a00d90..0000000
--- a/include/geos/index/quadtree/DoubleBits.h
+++ /dev/null
@@ -1,102 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2006 Refractions Research Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
- * Last port: index/quadtree/DoubleBits.java rev. 1.7 (JTS-1.16)
-#ifndef GEOS_IDX_QUADTREE_DOUBLEBITS_H
-#define GEOS_IDX_QUADTREE_DOUBLEBITS_H
-#include <geos/export.h>
-#include <geos/constants.h> // for int64
-#include <string>
-namespace geos {
-namespace index { // geos::index
-namespace quadtree { // geos::index::quadtree
-/** \brief
- * DoubleBits manipulates Double numbers
- * by using bit manipulation and bit-field extraction.
- * For some operations (such as determining the exponent)
- * this is more accurate than using mathematical operations
- * (which suffer from round-off error).
- * The algorithms and constants in this class
- * apply only to IEEE-754 double-precision floating point format.
-class GEOS_DLL DoubleBits {
-public:
-    static const int EXPONENT_BIAS = 1023;
-    static double powerOf2(int exp);
-    static int exponent(double d);
-    static double truncateToPowerOfTwo(double d);
-    static std::string toBinaryString(double d);
-    static double maximumCommonMantissa(double d1, double d2);
-    DoubleBits(double nx);
-    double getDouble() const;
-    /// Determines the exponent for the number
-    int64 biasedExponent() const;
-    int getExponent() const;
-    void zeroLowerBits(int nBits);
-    int getBit(int i) const;
-    /** \brief
-     * This computes the number of common most-significant bits in
-     * the mantissa.
-     * It does not count the hidden bit, which is always 1.
-     * It does not determine whether the numbers have the same exponent;
-     * if they do not, the value computed by this function is meaningless.
-     * @param db
-     * @return the number of common most-significant mantissa bits
-    int numCommonMantissaBits(const DoubleBits& db) const;
-    /// A representation of the Double bits formatted for easy readability
-    std::string toString() const;
-private:
-    double x;
-    int64 xBits;
-} // namespace geos::index::quadtree
-#endif // GEOS_IDX_QUADTREE_DOUBLEBITS_H
diff --git a/include/geos/index/quadtree/Makefile.am b/include/geos/index/quadtree/Makefile.am
index d3f2571..04ace02 100644
--- a/include/geos/index/quadtree/Makefile.am
+++ b/include/geos/index/quadtree/Makefile.am
@@ -1,14 +1,13 @@
-# This file is part of project GEOS (http://trac.osgeo.org/geos/)
+# This file is part of project GEOS (http://trac.osgeo.org/geos/)
-SUBDIRS =
+SUBDIRS =
-EXTRA_DIST =
+EXTRA_DIST =
 geosdir = $(includedir)/geos/index/quadtree
 geos_HEADERS = \
-    DoubleBits.h \
     IntervalSize.h \
     Key.h \
     NodeBase.h \
diff --git a/src/index/bintree/Key.cpp b/src/index/bintree/Key.cpp
index 2a35d0f..7bb24e4 100644
--- a/src/index/bintree/Key.cpp
+++ b/src/index/bintree/Key.cpp
@@ -15,7 +15,6 @@
 #include <geos/index/bintree/Key.h>
 #include <geos/index/bintree/Interval.h>
-#include <geos/index/quadtree/DoubleBits.h>
 #include <cmath>
@@ -26,10 +25,9 @@ namespace bintree { // geos.index.bintree
 int
 Key::computeLevel(Interval* newInterval)
-    using geos::index::quadtree::DoubleBits;
     double dx = newInterval->getWidth();
-    //int level = BinaryPower.exponent(dx) + 1;
-    int level = DoubleBits::exponent(dx) + 1;
+    int level;
+    frexp(dx, &level);
     return level;
@@ -85,10 +83,7 @@ Key::computeKey(Interval* itemInterval)
 void
 Key::computeInterval(int p_level, Interval* itemInterval)
-    double size = DoubleBits::powerOf2(p_level);
-    //double size = pow2.power(p_level);
+    double size = exp2(p_level);
     pt = std::floor(itemInterval->getMin() / size) * size;
     interval->init(pt, pt + size);
diff --git a/src/index/quadtree/DoubleBits.cpp b/src/index/quadtree/DoubleBits.cpp
index 336d411..0000000
--- a/src/index/quadtree/DoubleBits.cpp
+++ /dev/null
@@ -1,185 +0,0 @@
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
-#include <geos/util/IllegalArgumentException.h>
-#include <string>
-#include <cstring>
-#include <bitset>
-#if __STDC_IEC_559__
-#define ASSUME_IEEE_DOUBLE 1
-#else
-#define ASSUME_IEEE_DOUBLE 0
-#endif
-#if ! ASSUME_IEEE_DOUBLE
-#include <cmath>
-#endif
-namespace geos {
-namespace index { // geos.index
-namespace quadtree { // geos.index.quadtree
-using namespace std;
-double
-DoubleBits::powerOf2(int exp)
-    if(exp > 1023 || exp < -1022) {
-        throw util::IllegalArgumentException("Exponent out of bounds");
-#if ASSUME_IEEE_DOUBLE
-    int64 expBias = exp + EXPONENT_BIAS;
-    int64 bits = expBias << 52;
-    double ret;
-    memcpy(&ret, &bits, sizeof(int64));
-    return ret;
-#else
-    return pow(2.0, exp);
-#endif
-int
-DoubleBits::exponent(double d)
-    DoubleBits db(d);
-    return db.getExponent();
-double
-DoubleBits::truncateToPowerOfTwo(double d)
-    DoubleBits db(d);
-    db.zeroLowerBits(52);
-    return db.getDouble();
-string
-DoubleBits::toBinaryString(double d)
-    DoubleBits db(d);
-    return db.toString();
-double
-DoubleBits::maximumCommonMantissa(double d1, double d2)
-    if(d1 == 0.0 || d2 == 0.0) {
-        return 0.0;
-    DoubleBits db1(d1);
-    DoubleBits db2(d2);
-    if(db1.getExponent() != db2.getExponent()) {
-        return 0.0;
-    int maxCommon = db1.numCommonMantissaBits(db2);
-    db1.zeroLowerBits(64 - (12 + maxCommon));
-    return db1.getDouble();
-/*public*/
-DoubleBits::DoubleBits(double nx)
-    memcpy(&xBits, &nx, sizeof(double));
-#endif
-    x = nx;
-/*public*/
-double
-DoubleBits::getDouble() const
-    return x;
-/*public*/
-int64
-DoubleBits::biasedExponent() const
-    int64 signExp = xBits >> 52;
-    int64 exp = signExp & 0x07ff;
-    //cerr<<"xBits:"<<xBits<<" signExp:"<<signExp<<" exp:"<<exp<<endl;
-    return exp;
-/*public*/
-int
-DoubleBits::getExponent() const
-    return static_cast<int>(biasedExponent() - EXPONENT_BIAS);
-#else
-    if(x <= 0) {
-        return 0;    // EDOM || ERANGE
-    return (int)((log(x) / log(2.0)) + (x < 1 ? -0.9 : 0.00000000001));
-#endif
-/*public*/
-void
-DoubleBits::zeroLowerBits(int nBits)
-    long invMask = (1L << nBits) - 1L;
-    long mask = ~invMask;
-    xBits &= mask;
-/*public*/
-int
-DoubleBits::getBit(int i) const
-    long mask = (1L << i);
-    return (xBits & mask) != 0 ? 1 : 0;
-/*public*/
-int
-DoubleBits::numCommonMantissaBits(const DoubleBits& db) const
-    for(int i = 0; i < 52; i++) {
-        if(getBit(i) != db.getBit(i)) {
-            return i;
-    return 52;
-/*public*/
-string
-DoubleBits::toString() const
-    int64 bit;
-    memcpy(&bit, &x, sizeof(x));
-    string bitStr = bitset<64>(bit).to_string();
-    string str = bitStr.substr(0, 1) + "  "
-        + bitStr.substr(1, 11) + "(" + std::to_string(getExponent()) + ") "
-        + bitStr.substr(12)
-        + " [ " + std::to_string(x) + " ]";
-    return str;
-} // namespace geos.index.quadtree
diff --git a/src/index/quadtree/IntervalSize.cpp b/src/index/quadtree/IntervalSize.cpp
index 54d5e5c..68feb03 100644
--- a/src/index/quadtree/IntervalSize.cpp
+++ b/src/index/quadtree/IntervalSize.cpp
@@ -18,7 +18,6 @@
 #include <geos/index/quadtree/IntervalSize.h>
 #include <algorithm>
 #include <cmath>
@@ -40,7 +39,9 @@ IntervalSize::isZeroWidth(double mn, double mx)
     double maxAbs = max(fabs(mn), fabs(mx));
     double scaledInterval = width / maxAbs;
-    int level = DoubleBits::exponent(scaledInterval);
+    int level;
+    frexp(scaledInterval, &level);
+    level -= 1;
     return level <= MIN_BINARY_EXPONENT;
diff --git a/src/index/quadtree/Key.cpp b/src/index/quadtree/Key.cpp
index 25c830a..f3ee2f8 100644
--- a/src/index/quadtree/Key.cpp
+++ b/src/index/quadtree/Key.cpp
@@ -19,7 +19,6 @@
 #include <geos/index/quadtree/Key.h>
 #include <geos/geom/Envelope.h>
 #include <geos/geom/Coordinate.h>
@@ -46,7 +45,8 @@ Key::computeQuadLevel(const Envelope& env)
     double dx = env.getWidth();
     double dy = env.getHeight();
     double dMax = dx > dy ? dx : dy;
-    int level = DoubleBits::exponent(dMax) + 1;
+    int level;
+    frexp(dMax, &level);
 #if GEOS_DEBUG
     std::cerr << "Maxdelta:" << dMax << " exponent:" << (level - 1) << std::endl;
 #endif
@@ -113,8 +113,7 @@ Key::computeKey(const Envelope& itemEnv)
 void
 Key::computeKey(int p_level, const Envelope& itemEnv)
-    double quadSize = DoubleBits::powerOf2(p_level);
-    //double quadSize=pow2.power(level);
+    double quadSize = exp2(p_level);
     pt.x = std::floor(itemEnv.getMinX() / quadSize) * quadSize;
     pt.y = std::floor(itemEnv.getMinY() / quadSize) * quadSize;
     env.init(pt.x, pt.x + quadSize, pt.y, pt.y + quadSize);
diff --git a/src/index/quadtree/Makefile.am b/src/index/quadtree/Makefile.am
index cc77945..98d5123 100644
--- a/src/index/quadtree/Makefile.am
+++ b/src/index/quadtree/Makefile.am
@@ -1,15 +1,14 @@
 noinst_LTLIBRARIES = libindexquadtree.la
-AM_CPPFLAGS = -I$(top_srcdir)/include
+AM_CPPFLAGS = -I$(top_srcdir)/include
 libindexquadtree_la_SOURCES = \
-    DoubleBits.cpp \
     IntervalSize.cpp \
     Quadtree.cpp \
     Key.cpp \
     Node.cpp \
     NodeBase.cpp \
-    Root.cpp
+    Root.cpp
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index cef4374..50b2af7 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -145,7 +145,6 @@ geos_unit_SOURCES = \
 	geom/prep/PreparedGeometry/touchesTest.cpp \
 	geom/TriangleTest.cpp \
 	geom/util/GeometryExtracterTest.cpp \
-	index/quadtree/DoubleBitsTest.cpp \
 	index/strtree/SIRtreeTest.cpp \
 	io/ByteOrderValuesTest.cpp \
 	io/WKBReaderTest.cpp \
diff --git a/tests/unit/index/quadtree/DoubleBitsTest.cpp b/tests/unit/index/quadtree/DoubleBitsTest.cpp
index f33a128..0000000
--- a/tests/unit/index/quadtree/DoubleBitsTest.cpp
+++ /dev/null
@@ -1,49 +0,0 @@
-// Test Suite for geos::index::quadtree::DoubleBits class.
-#include <tut/tut.hpp>
-// geos
-using namespace geos::index::quadtree;
-namespace tut {
-// dummy data, not used
-struct test_doublebits_data {};
-typedef test_group<test_doublebits_data> group;
-typedef group::object object;
-group test_doublebits_group("geos::index::quadtree::DoubleBits");
-// Test Cases
-// 1 - Test exponent()
-template<>
-template<>
-void object::test<1>
-    ensure_equals(DoubleBits::exponent(-1), 0);
-    ensure_equals(DoubleBits::exponent(8.0), 3);
-    ensure_equals(DoubleBits::exponent(128.0), 7);
-// 2 - Test toString()
-template<>
-template<>
-void object::test<2>
-    ensure_equals(DoubleBits(-1).toString(),
-        "1  01111111111(0) 0000000000000000000000000000000000000000000000000000 [ -1.000000 ]");
-    ensure_equals(DoubleBits(8.0).toString(),
-        "0  10000000010(3) 0000000000000000000000000000000000000000000000000000 [ 8.000000 ]");
-    ensure_equals(DoubleBits(128.0).toString(),
-        "0  10000000110(7) 0000000000000000000000000000000000000000000000000000 [ 128.000000 ]");
-} // namespace tut
Summary of changes:
 include/geos/index/quadtree/DoubleBits.h     | 102 ---------------
 include/geos/index/quadtree/Makefile.am      |   7 +-
 src/index/bintree/Key.cpp                    |  11 +-
 src/index/quadtree/DoubleBits.cpp            | 185 ---------------------------
 src/index/quadtree/IntervalSize.cpp          |   5 +-
 src/index/quadtree/Key.cpp                   |   7 +-
 src/index/quadtree/Makefile.am               |   7 +-
 tests/unit/Makefile.am                       |   1 -
 tests/unit/index/quadtree/DoubleBitsTest.cpp |  49 -------
 9 files changed, 15 insertions(+), 359 deletions(-)
 delete mode 100644 include/geos/index/quadtree/DoubleBits.h
 delete mode 100644 src/index/quadtree/DoubleBits.cpp
 delete mode 100644 tests/unit/index/quadtree/DoubleBitsTest.cpp
hooks/post-receive
More information about the geos-commits mailing list
