[geos-commits] [SCM] GEOS branch master updated. 8b844facb246eb7eb9ab2791aeb07886eeea4a9d
Mon Aug 10 14:43:12 PDT 2020
the project "GEOS".
       via  8b844facb246eb7eb9ab2791aeb07886eeea4a9d (commit)
      from  23d172214148f6dc1300d04cedce6dabd4fd7393 (commit)
revisions in full, below.
commit 8b844facb246eb7eb9ab2791aeb07886eeea4a9d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Aug 10 14:43:06 2020 -0700
    Fix doxygen errors and re-enable CI test
diff --git a/include/geos/algorithm/CGAlgorithmsDD.h b/include/geos/algorithm/CGAlgorithmsDD.h
index e620389..df62696 100644
--- a/include/geos/algorithm/CGAlgorithmsDD.h
+++ b/include/geos/algorithm/CGAlgorithmsDD.h
@@ -73,7 +73,7 @@ public:
                                 double p2x, double p2y,
                                 double qx,  double qy);
-    /** \brief
      * A filter for computing the orientation index of three coordinates.
      * If the orientation can be computed safely using standard DP arithmetic,
@@ -86,13 +86,7 @@ public:
      * average performance.
      * Uses an approach due to Jonathan Shewchuk, which is in the public domain.
-     * @param pa a coordinate
-     * @param pb a coordinate
-     * @param pc a coordinate
-     * @return the orientation index if it can be computed safely
-     * @return `i > 1` if the orientation index cannot be computed safely
     static int orientationIndexFilter(double pax, double pay,
                                       double pbx, double pby,
                                       double pcx, double pcy);
diff --git a/include/geos/edgegraph/EdgeGraph.h b/include/geos/edgegraph/EdgeGraph.h
index 1e636c3..9edc20f 100644
--- a/include/geos/edgegraph/EdgeGraph.h
+++ b/include/geos/edgegraph/EdgeGraph.h
@@ -43,12 +43,12 @@ namespace edgegraph { // geos.edgegraph
  * It supports tracking the vertices in the graph
  * via edges incident on them,
  * to allow efficient lookup of edges and vertices.
- * <p>
  * This class may be subclassed to use a
  * different subclass of HalfEdge,
- * by overriding {@link #createEdge(Coordinate)}.
+ * by overriding {@link createEdge}.
  * If additional logic is required to initialize
- * edges then {@link EdgeGraph#addEdge(Coordinate, Coordinate)}
+ * edges then {@link addEdge}
  * can be overridden as well.
  * @author Martin Davis
@@ -104,7 +104,7 @@ public:
     * @return the created edge
     * @return null if the edge was invalid and not added
-    * @see #isValidEdge(Coordinate, Coordinate)
+    * @see isValidEdge(Coordinate, Coordinate)
     HalfEdge* addEdge(const geom::Coordinate& orig, const geom::Coordinate& dest);
diff --git a/include/geos/edgegraph/EdgeGraphBuilder.h b/include/geos/edgegraph/EdgeGraphBuilder.h
index eafbaec..38fe035 100644
--- a/include/geos/edgegraph/EdgeGraphBuilder.h
+++ b/include/geos/edgegraph/EdgeGraphBuilder.h
@@ -72,7 +72,7 @@ public:
     void add(const geom::LineString* linestring);
-    * Adds the edges in a collection of {@link Geometry}s to the graph.
+    * Adds the edges in a collection of {@link geom::Geometry} to the graph.
     * May be called multiple times.
     * Any dimension of Geometry may be added.
diff --git a/include/geos/edgegraph/HalfEdge.h b/include/geos/edgegraph/HalfEdge.h
index 9c1df75..ccfa334 100644
--- a/include/geos/edgegraph/HalfEdge.h
+++ b/include/geos/edgegraph/HalfEdge.h
@@ -32,26 +32,26 @@ namespace edgegraph { // geos.edgegraph
  * Represents a directed component of an edge in an {@link EdgeGraph}.
- * HalfEdges link vertices whose locations are defined by {@link Coordinate}s.
- * HalfEdges start at an <b>origin</b> vertex,
- * and terminate at a <b>destination</b> vertex.
- * HalfEdges always occur in symmetric pairs, with the {@link #sym()} method
+ * HalfEdges link vertices whose locations are defined by {@link geom::Coordinate}s.
+ * HalfEdges start at an origin vertex,
+ * and terminate at a destination vertex.
+ * HalfEdges always occur in symmetric pairs, with the {@link sym()} method
  * giving access to the oppositely-oriented component.
  * HalfEdges and the methods on them form an edge algebra,
  * which can be used to traverse and query the topology
  * of the graph formed by the edges.
- * <p>
  * To support graphs where the edges are sequences of coordinates
  * each edge may also have a direction point supplied.
  * This is used to determine the ordering
  * of the edges around the origin.
  * HalfEdges with the same origin are ordered
  * so that the ring of edges formed by them is oriented CCW.
- * <p>
  * By design HalfEdges carry minimal information
  * about the actual usage of the graph they represent.
  * They can be subclassed to carry more information if required.
- * <p>
  * HalfEdges form a complete and consistent data structure by themselves,
  * but an {@link EdgeGraph} is useful to allow retrieving edges
  * by vertex and edge location, as well as ensuring
@@ -124,7 +124,7 @@ public:
     * Creates a half-edge originating from a given coordinate.
-    * @param orig the origin coordinate
+    * @param p_orig the origin coordinate
     HalfEdge(const geom::Coordinate& p_orig) :
         m_orig(p_orig)
@@ -144,7 +144,7 @@ public:
     * Links this edge with its sym (opposite) edge.
     * This must be done for each pair of edges created.
-    * @param e the sym edge to link.
+    * @param p_sym the sym edge to link.
     void link(HalfEdge* p_sym);
@@ -258,26 +258,25 @@ public:
     * Implements the total order relation:
-    * <p>
     *    The angle of edge a is greater than the angle of edge b,
     *    where the angle of an edge is the angle made by
     *    the first segment of the edge with the positive x-axis
-    * <p>
     * When applied to a list of edges originating at the same point,
     * this produces a CCW ordering of the edges around the point.
-    * <p>
     * Using the obvious algorithm of computing the angle is not robust,
     * since the angle calculation is susceptible to roundoff error.
     * A robust algorithm is:
-    * <ul>
-    * <li>First, compare the quadrants the edge vectors lie in.
-    * If the quadrants are different,
-    * it is trivial to determine which edge has a greater angle.
-    * <li>if the vectors lie in the same quadrant, the
-    * {@link Orientation#index(Coordinate, Coordinate, Coordinate)} function
-    * can be used to determine the relative orientation of the vectors.
-    * </ul>
+    * * First, compare the quadrants the edge vectors lie in.
+    *   If the quadrants are different,
+    *   it is trivial to determine which edge has a greater angle.
+    * * if the vectors lie in the same quadrant, the
+    *   geom::Orientation::index() function
+    *   can be used to determine the relative orientation of the vectors.
     int compareAngularDirection(const HalfEdge* e) const;
     int compareTo(const HalfEdge* e) const { return compareAngularDirection(e); };
diff --git a/include/geos/index/kdtree/KdNode.h b/include/geos/index/kdtree/KdNode.h
index b561c12..e1238ab 100644
--- a/include/geos/index/kdtree/KdNode.h
+++ b/include/geos/index/kdtree/KdNode.h
@@ -24,6 +24,9 @@ namespace geos {
 namespace index { // geos::index
 namespace kdtree { // geos::index::kdtree
+ * A node of a {@link KdTree}, which represents one or more points in the same location.
 class GEOS_DLL KdNode {
 private:
diff --git a/include/geos/index/kdtree/KdTree.h b/include/geos/index/kdtree/KdTree.h
index c57215a..e160663 100644
--- a/include/geos/index/kdtree/KdTree.h
+++ b/include/geos/index/kdtree/KdTree.h
@@ -119,17 +119,16 @@ private:
 public:
-    * Converts a collection of {@link KdNode}s to an vector of {@link Coordinate}s.
+    * Converts a collection of {@link KdNode}s to an vector of {@link geom::Coordinate}s.
-    * @param kdnodes
-    *          a collection of nodes
+    * @param kdnodes a collection of nodes
     * @return an vector of the coordinates represented by the nodes
     static std::unique_ptr<std::vector<geom::Coordinate>> toCoordinates(std::vector<KdNode*>& kdnodes);
-    * to an vector of {@link Coordinate}s,
+    * to an vector of {@link geom::Coordinate}s,
     * specifying whether repeated nodes should be represented
     * by multiple coordinates.
@@ -177,9 +176,6 @@ public:
     * Searches for a given point in the index and returns its node if found.
-    * @param queryPt the point to query
-    * @return the point node, if it is found in the index, or null if not
     KdNode* query(const geom::Coordinate& queryPt);
diff --git a/include/geos/noding/ValidatingNoder.h b/include/geos/noding/ValidatingNoder.h
index 6d9b7ed..ce45c74 100644
--- a/include/geos/noding/ValidatingNoder.h
+++ b/include/geos/noding/ValidatingNoder.h
@@ -33,6 +33,20 @@ class Geometry;
 namespace geos {
 namespace noding { // geos.noding
+ * A wrapper for {@link noding::Noder}s which validates
+ * the output arrangement is correctly noded.
+ * An arrangement of line segments is fully noded if
+ * there is no line segment
+ * which has another segment intersecting its interior.
+ * If the noding is not correct, a {@link util::TopologyException} is thrown
+ * with details of the first invalid location found.
+ * @author mdavis
+ * @see FastNodingValidator
 class GEOS_DLL ValidatingNoder : public Noder {
 private:
diff --git a/include/geos/noding/snap/SnappingNoder.h b/include/geos/noding/snap/SnappingNoder.h
index 5ee58fa..d8efccc 100644
--- a/include/geos/noding/snap/SnappingNoder.h
+++ b/include/geos/noding/snap/SnappingNoder.h
@@ -61,7 +61,7 @@ namespace snap {   // geos::noding::snap
  * given a small enough snap tolerance.
  * The correctness of the output is not verified by this noder.
- * If required this can be done by {@link ValidatingNoder}.
+ * If required this can be done by {@link noding::ValidatingNoder}.
 class GEOS_DLL SnappingNoder : public Noder {
diff --git a/include/geos/noding/snapround/HotPixel.h b/include/geos/noding/snapround/HotPixel.h
index d221f12..1121419 100644
--- a/include/geos/noding/snapround/HotPixel.h
+++ b/include/geos/noding/snapround/HotPixel.h
@@ -55,12 +55,10 @@ namespace snapround { // geos::noding::snapround
  * Implements a "hot pixel" as used in the Snap Rounding algorithm.
  * A hot pixel contains the interior of the tolerance square and
- * the boundary
- * <b>minus</b> the top and right segments.
+ * the boundary minus the top and right segments.
  * The hot pixel operations are all computed in the integer domain
  * to avoid rounding problems.
 class GEOS_DLL HotPixel {
@@ -112,10 +110,7 @@ public:
      * @param pt the coordinate at the centre of the pixel.
      *           Will be kept by reference, so make sure to keep it alive.
-     * @param scaleFact the scaleFactor determining the pixel size
-     * @param li the intersector to use for testing intersection with
-     *        line segments
+     * @param scaleFactor the scaleFactor determining the pixel size     */
     HotPixel(const geom::Coordinate& pt, double scaleFactor);
diff --git a/include/geos/noding/snapround/SnapRoundingNoder.h b/include/geos/noding/snapround/SnapRoundingNoder.h
index 2ceab38..1abd80c 100644
--- a/include/geos/noding/snapround/SnapRoundingNoder.h
+++ b/include/geos/noding/snapround/SnapRoundingNoder.h
@@ -43,13 +43,13 @@ namespace snapround { // geos::noding::snapround
  * Uses Snap Rounding to compute a rounded,
- * fully noded arrangement from a set of {@link SegmentString}s,
+ * fully noded arrangement from a set of {@link noding::SegmentString}s,
  * in a performant way, and avoiding unnecessary noding.
  * Implements the Snap Rounding technique described in
  * the papers by Hobby, Guibas & Marimont, and Goodrich et al.
  * Snap Rounding enforces that all output vertices lie on a uniform grid,
- * which is determined by the provided {@link PrecisionModel}.
+ * which is determined by the provided {@link geom::PrecisionModel}.
  * Input vertices do not have to be rounded to the grid beforehand;
  * this is done during the snap-rounding process.
@@ -66,7 +66,7 @@ namespace snapround { // geos::noding::snapround
  * each of the segment vertices will be noded.
  * This still provides fully-noded output.
  * This is the same behaviour provided by other noders,
- * such as {@link MCIndexNoder} and {@link SnappingNoder}.
+ * such as {@link noding::MCIndexNoder} and {@link noding::snap::SnappingNoder}.
 class GEOS_DLL SnapRoundingNoder : public Noder {
diff --git a/include/geos/operation/overlayng/EdgeNodingBuilder.h b/include/geos/operation/overlayng/EdgeNodingBuilder.h
index 05dd09b..725eb29 100644
--- a/include/geos/operation/overlayng/EdgeNodingBuilder.h
+++ b/include/geos/operation/overlayng/EdgeNodingBuilder.h
@@ -66,7 +66,7 @@ namespace overlayng { // geos.operation.overlayng
  *  - Extracts input edges, and attaches topological information
  *  - if clipping is enabled, handles clipping or limiting input geometry
- *  - chooses a {@link Noder} based on provided precision model, unless a custom one is supplied
+ *  - chooses a {@link noding::Noder} based on provided precision model, unless a custom one is supplied
  *  - calls the chosen Noder, with precision model
  *  - removes any fully collapsed noded edges
  *  - builds {@link Edge}s and merges them
diff --git a/include/geos/operation/overlayng/OverlayEdge.h b/include/geos/operation/overlayng/OverlayEdge.h
index 3d4882f..243d80e 100644
--- a/include/geos/operation/overlayng/OverlayEdge.h
+++ b/include/geos/operation/overlayng/OverlayEdge.h
@@ -43,7 +43,9 @@ namespace overlayng { // geos.operation.overlayng
 using namespace geos::geom;
+* Creates a single OverlayEdge.
 class GEOS_DLL OverlayEdge : public edgegraph::HalfEdge {
 private:
diff --git a/include/geos/operation/overlayng/OverlayGraph.h b/include/geos/operation/overlayng/OverlayGraph.h
index e9f8756..4e56a13 100644
--- a/include/geos/operation/overlayng/OverlayGraph.h
+++ b/include/geos/operation/overlayng/OverlayGraph.h
@@ -42,7 +42,7 @@ namespace overlayng { // geos.operation.overlayng
- * A planar graph of {@link OverlayEdge}s, representing
+ * A planar graph of {@link OverlayEdge}, representing
  * the topology resulting from an overlay operation.
  * Each source {@link Edge} is represented
  * by two OverlayEdges, with opposite orientation.
diff --git a/include/geos/operation/overlayng/OverlayLabel.h b/include/geos/operation/overlayng/OverlayLabel.h
index 2619b28..a184fcc 100644
--- a/include/geos/operation/overlayng/OverlayLabel.h
+++ b/include/geos/operation/overlayng/OverlayLabel.h
@@ -23,6 +23,11 @@ namespace geos {      // geos.
 namespace operation { // geos.operation
+using geos::geom::Location;
+using geos::geom::Position;
 * A label for a pair of {@link OverlayEdge}s which records
 * the topological information for the edge
@@ -32,11 +37,11 @@ namespace overlayng { // geos.operation.overlayng
 * Accessors for orientation-sensitive information
 * require the orientation of the containing OverlayEdge.
-* A label contains the topological {@link Location}s for
+* A label contains the topological {@link geom::Location}s for
 * the two overlay input geometries.
 * A labelled input geometry may be either a Line or an Area.
 * In both cases, the label locations are populated
-* with the locations for the edge {@link Position}s
+* with the locations for the edge {@link geom::Position}s
 * once they are computed by topological evaluation.
 * The label also records the dimension of each geometry,
 * and in the case of area boundary edges, the role
@@ -82,11 +87,6 @@ namespace overlayng { // geos.operation.overlayng
-using geos::geom::Location;
-using geos::geom::Position;
 class GEOS_DLL OverlayLabel {
 private:
diff --git a/include/geos/operation/overlayng/OverlayNG.h b/include/geos/operation/overlayng/OverlayNG.h
index d09485d..aa88b12 100644
--- a/include/geos/operation/overlayng/OverlayNG.h
+++ b/include/geos/operation/overlayng/OverlayNG.h
@@ -41,8 +41,47 @@ namespace geos {      // geos.
+ * Computes the geometric overlay of two {@link geom::Geometry}s,
+ * using an explicit precision model to allow robust computation.
+ * The overlay can be used to determine any of the
+ * following set-theoretic operations (boolean combinations) of the geometries:
+ * * INTERSECTION - all points which lie in both geometries
+ * * UNION - all points which lie in at least one geometry
+ * * DIFFERENCE - all points which lie in the first geometry but not the second
+ * * SYMDIFFERENCE - all points which lie in one geometry but not both
+ * Input geometries may have different dimension.
+ * Collections must be homogeneous
+ * (all elements must have the same dimension).
+ * The precision model used for the computation can be supplied
+ * independent of the precision model of the input geometry.
+ * The main use for this is to allow using a fixed precision
+ * for geometry with a floating precision model.
+ * This does two things: ensures robust computation;
+ * and forces the output to be validly rounded to the precision model.
+ * For fixed precision models noding is performed using a {@link noding::snapround::SnapRoundingNoder}.
+ * This provides robust computation (as long as precision is limited to
+ * around 13 decimal digits).
+ * For floating precision an {@link noding::MCIndexNoder} is used.
+ * This is not fully robust, so can sometimes result in
+ * {@link util::TopologyException}s being thrown.
+ * For robust full-precision overlay see {@link OverlayNGSnapIfNeeded}.
+ * Note: If a {@link noding::snap::SnappingNoder} is used
+ * it is best to specify a fairly small snap tolerance,
+ * since the intersection clipping optimization can
+ * interact with the snapping to alter the result.
+ * @author mdavis
+ * @see OverlayNGSnapIfNeeded
 class GEOS_DLL OverlayNG {
 private:
@@ -117,7 +156,7 @@ public:
     *  - For {@link PrecisionModel#FLOATING}
     * a non-snapping noder is used,
     * and this computation may not be robust.
-    * If errors occur a {@link TopologyException} is thrown.
+    * If errors occur a {@link util::TopologyException} is thrown.
     OverlayNG(const geom::Geometry* geom0, const geom::Geometry* geom1, int p_opCode)
         : OverlayNG(geom0, geom1, geom0->getFactory()->getPrecisionModel(), p_opCode)
@@ -133,7 +172,7 @@ public:
     * for testing purposes.
     * Default is TRUE (optimization enabled).
-    * @param isOptimized whether to optimize processing
+    * @param p_isOptimized whether to optimize processing
     void setOptimized(bool p_isOptimized) { isOptimized = p_isOptimized; }
     void setOutputEdges(bool p_isOutputEdges) { isOutputEdges = p_isOutputEdges; }
@@ -149,7 +188,7 @@ public:
     std::unique_ptr<Geometry> getResult();
-    * Tests whether a point with a given topological {@link Label}
+    * Tests whether a point with a given topological {@link OverlayLabel}
     * relative to two geometries is contained in
     * the result of overlaying the geometries using
     * a given overlay operation.
@@ -159,7 +198,7 @@ public:
     static bool isResultOfOpPoint(const OverlayLabel* label, int opCode);
-    * Tests whether a point with given {@link Location}s
+    * Tests whether a point with given {@link geom::Location}s
     * relative to two geometries would be contained in
@@ -189,7 +228,7 @@ public:
     * Computes an overlay operation on the given geometry operands,
-    * using a supplied {@link Noder}.
+    * using a supplied {@link noding::Noder}.
     * @param geom0 the first geometry argument
     * @param geom1 the second geometry argument
@@ -205,7 +244,7 @@ public:
@@ -225,12 +264,12 @@ public:
     * The noder is chosen according to the precision model specified.
-    *  - For {@link PrecisionModel#FIXED}
+    *  - For {@link geom::PrecisionModel#FIXED}
     *    a snap-rounding noder is used, and the computation is robust.
-    *  - For {@link PrecisionModel#FLOATING}
+    *  - For {@link geom::PrecisionModel#FLOATING}
     * @param geom0 the first argument geometry
     * @param geom1 the second argument geometry
@@ -250,11 +289,7 @@ public:
     * The input must be a valid geometry.
     * Collections must be homogeneous.
-    * To union an overlapping set of polygons in a more performant way use {@link UnaryUnionNG}.
-    * To union a polyonal coverage or linear network in a more performant way,
-    * use {@link CoverageUnion}.
-    * @param geom0 the geometry
+    * @param geom the geometry
     * @param pm the precision model to use
     * @return the result of the union operation
diff --git a/include/geos/operation/overlayng/OverlayNGSnapIfNeeded.h b/include/geos/operation/overlayng/OverlayNGSnapIfNeeded.h
index 545c34f..1857424 100644
--- a/include/geos/operation/overlayng/OverlayNGSnapIfNeeded.h
+++ b/include/geos/operation/overlayng/OverlayNGSnapIfNeeded.h
@@ -39,20 +39,20 @@ namespace overlayng { // geos.operation.overlayng
  * The noding strategies used are:
  *  - A simple, fast noder using FLOATING precision.
- *  - A {@link SnappingNoder} using an automatically-determined snap tolerance
+ *  - A {@link noding::snap::SnappingNoder} using an automatically-determined snap tolerance
  *  - First snapping each geometry to itself,
  *    and then overlaying them using a SnappingNoder.
  *  - The above two strategies are repeated with increasing snap tolerance, up to a limit.
  * If the above heuristics still fail to compute a valid overlay,
- * the original {@link TopologyException} is thrown.
+ * the original {@link util::TopologyException} is thrown.
  * This algorithm relies on each overlay operation execution
- * throwing a {@link TopologyException} if it is unable
+ * throwing a {@link util::TopologyException} if it is unable
  * to compute the overlay correctly.
  * Generally this occurs because the noding phase does
  * not produce a valid noding.
- * This requires the use of a {@link ValidatingNoder}
+ * This requires the use of a {@link noding::ValidatingNoder}
  * in order to check the results of using a floating noder.
@@ -141,7 +141,7 @@ public:
     * Computes a heuristic snap tolerance distance
-    * for overlaying a pair of geometries using a {@link SnappingNoder}.
+    * for overlaying a pair of geometries using a {@link noding::snap::SnappingNoder}.
     static double snapTolerance(const Geometry* geom0, const Geometry* geom1);
diff --git a/include/geos/operation/overlayng/OverlayUtil.h b/include/geos/operation/overlayng/OverlayUtil.h
index 58c3595..7d26062 100644
--- a/include/geos/operation/overlayng/OverlayUtil.h
+++ b/include/geos/operation/overlayng/OverlayUtil.h
@@ -111,10 +111,10 @@ public:
     * This assumes that complete collapse does not occur.
     * The result dimension is computed according to the following rules:
-    * - {@link OverlayNG#INTERSECTION} - result has the dimension of the lowest input dimension
-    * - {@link OverlayNG#UNION} - result has the dimension of the highest input dimension
-    * - {@link OverlayNG#DIFFERENCE} - result has the dimension of the left-hand input
-    * - {@link OverlayNG#SYMDIFFERENCE} - result has the dimension of the highest input dimension
+    * - OverlayNG::INTERSECTION - result has the dimension of the lowest input dimension
+    * - OverlayNG::UNION - result has the dimension of the highest input dimension
+    * - OverlayNG::DIFFERENCE - result has the dimension of the left-hand input
+    * - OverlayNG::SYMDIFFERENCE - result has the dimension of the highest input dimension
     * (since the Symmetric Difference is the Union of the Differences).
     static int resultDimension(int opCode, int dim0, int dim1);
diff --git a/include/geos/operation/overlayng/PrecisionReducer.h b/include/geos/operation/overlayng/PrecisionReducer.h
index 77cdbc0..87e7447 100644
--- a/include/geos/operation/overlayng/PrecisionReducer.h
+++ b/include/geos/operation/overlayng/PrecisionReducer.h
@@ -39,7 +39,7 @@ using namespace geos::geom;
 * Reduces the precision of a geometry by rounding it to the
-* supplied {@link PrecisionModel}.
+* supplied {@link geom::PrecisionModel}.
 * The output is always a valid geometry.  This implies that input components
 * may be merged if they are closer than the grid precision.
@@ -47,7 +47,7 @@ using namespace geos::geom;
 * should be processed separately.
 * The output is fully noded.
-* This provides an effective way to node / snap-round a collection of {@link LineString}s.
+* This provides an effective way to node / snap-round a collection of {@link geom::LineString}s.
 class GEOS_DLL PrecisionReducer {
diff --git a/include/geos/operation/overlayng/PrecisionUtil.h b/include/geos/operation/overlayng/PrecisionUtil.h
index 3c5a98d..71def56 100644
--- a/include/geos/operation/overlayng/PrecisionUtil.h
+++ b/include/geos/operation/overlayng/PrecisionUtil.h
@@ -132,7 +132,7 @@ public:
     * Computes a safe scale factor for a numeric value.
     * A safe scale factor ensures that rounded
-    * number has no more than {@link MAX_PRECISION_DIGITS}
+    * number has no more than MAX_PRECISION_DIGITS
     * digits of precision.
     static double safeScale(double value);
@@ -140,7 +140,7 @@ public:
     * Computes a safe scale factor for a geometry.
     * A safe scale factor ensures that the rounded
-    * ordinates have no more than {@link MAX_PRECISION_DIGITS}
+    * ordinates have no more than MAX_PRECISION_DIGITS
     static double safeScale(const Geometry* geom);
@@ -148,7 +148,7 @@ public:
     * Computes a safe scale factor for two geometries.
     static double safeScale(const Geometry* a, const Geometry* b);
diff --git a/include/geos/operation/union/CascadedPolygonUnion.h b/include/geos/operation/union/CascadedPolygonUnion.h
index b746d0f..bb7db11 100644
--- a/include/geos/operation/union/CascadedPolygonUnion.h
+++ b/include/geos/operation/union/CascadedPolygonUnion.h
@@ -64,7 +64,7 @@ public:
     * Computes the union of two geometries.
-    * This method may throw a {@link Toppology Exception}
+    * This method may throw a {@link util::TopologyException}
     * if one is encountered
     std::unique_ptr<geom::Geometry> Union(const geom::Geometry*, const geom::Geometry*) override;
@@ -157,17 +157,18 @@ public:
      * @tparam T an iterator yelding something castable to const Polygon *
      * @param start start iterator
      * @param end end iterator
+     * @param unionStrategy strategy to apply
     template <class T>
     static geom::Geometry*
-    Union(T start, T end, UnionStrategy *unionStrat)
+    Union(T start, T end, UnionStrategy *unionStrategy)
         std::vector<geom::Polygon*> polys;
         for(T i = start; i != end; ++i) {
             const geom::Polygon* p = dynamic_cast<const geom::Polygon*>(*i);
             polys.push_back(const_cast<geom::Polygon*>(p));
-        return Union(&polys, unionStrat);
+        return Union(&polys, unionStrategy);
     /** \brief
diff --git a/include/geos/operation/union/OverlapUnion.h b/include/geos/operation/union/OverlapUnion.h
index 533273f..d6d073c 100644
--- a/include/geos/operation/union/OverlapUnion.h
+++ b/include/geos/operation/union/OverlapUnion.h
@@ -54,13 +54,15 @@ namespace geounion {  // geos::operation::geounion
  * and thus may group disjoint polygons which can lie far apart.
  * It may also occur in real world data which contains many disjoint polygons
  * (e.g. polygons representing parcels on different street blocks).
- * <h2>Algorithm</h2>
+ * # Algorithm
  * The overlap region is determined as the common envelope of intersection.
  * The input polygons are partitioned into two sets:
- * <ul>
- * <li>Overlapping: Polygons which intersect the overlap region, and thus potentially overlap each other
- * <li>Disjoint: Polygons which are disjoint from (lie wholly outside) the overlap region
- * </ul>
+ * * Overlapping: Polygons which intersect the overlap region, and thus potentially overlap each other
+ * * Disjoint: Polygons which are disjoint from (lie wholly outside) the overlap region
  * The Overlapping set is fully unioned, and then combined with the Disjoint set.
  * Performing a simple combine works because
  * the disjoint polygons do not interact with each
@@ -68,7 +70,8 @@ namespace geounion {  // geos::operation::geounion
  * They also do not interact with the Overlapping polygons,
  * since they are outside their envelope.
- * <h2>Verification</h2>
+ * # Verification
  * In the general case the Overlapping set of polygons will
  * extend beyond the overlap envelope.  This means that the union result
  * will extend beyond the overlap region.
@@ -80,7 +83,7 @@ namespace geounion {  // geos::operation::geounion
  * Detection is done by a fairly efficient comparison of edge segments which
  * extend beyond the overlap region.  If any segments have changed
  * then there is a risk of introduced intersections, and full union is performed.
- * <p>
  * This situation has not been observed in JTS using floating precision,
  * but it could happen due to snapping.  It has been observed
  * in other APIs (e.g. GEOS) due to more aggressive snapping.
@@ -89,7 +92,6 @@ namespace geounion {  // geos::operation::geounion
  * @author mbdavis
 class GEOS_DLL OverlapUnion {
 public:
diff --git a/include/geos/operation/union/UnionStrategy.h b/include/geos/operation/union/UnionStrategy.h
index 18040da..b68d090 100644
--- a/include/geos/operation/union/UnionStrategy.h
+++ b/include/geos/operation/union/UnionStrategy.h
@@ -45,7 +45,7 @@ public:
     virtual std::unique_ptr<geom::Geometry> Union(const geom::Geometry*, const geom::Geometry*) = 0;
@@ -54,7 +54,7 @@ public:
     * Indicates whether the union function operates using
     * a floating (full) precision model.
     * If this is the case, then the unary union code
-    * can make use of the {@link OverlapUnion} performance optimization,
+    * can make use of the operation::union::OverlapUnion performance optimization,
     * and perhaps other optimizations as well.
     * Otherwise, the union result extent may not be the same as the extent of the inputs,
     * which prevents using some optimizations.
diff --git a/tools/ci/script_cmake.sh b/tools/ci/script_cmake.sh
index b80dda6..b5a173e 100755
--- a/tools/ci/script_cmake.sh
+++ b/tools/ci/script_cmake.sh
@@ -23,9 +23,9 @@ set -e
 cmake --version
-cmake -DCMAKE_BUILD_TYPE=${BUILD_TYPE} -DBUILD_DOCUMENTATION=NO ${TRAVIS_BUILD_DIR}
+cmake -DCMAKE_BUILD_TYPE=${BUILD_TYPE} -DBUILD_DOCUMENTATION=YES ${TRAVIS_BUILD_DIR}
 run_make
-# cmake --build . --target docs
+cmake --build . --target docs
 ctest --output-on-failure .
 if [ "${BUILD_TYPE}" = "Coverage" ]; then
Summary of changes:
 include/geos/algorithm/CGAlgorithmsDD.h            | 10 +---
 include/geos/edgegraph/EdgeGraph.h                 |  8 +--
 include/geos/edgegraph/EdgeGraphBuilder.h          |  2 +-
 include/geos/edgegraph/HalfEdge.h                  | 39 ++++++-------
 include/geos/index/kdtree/KdNode.h                 |  3 +
 include/geos/index/kdtree/KdTree.h                 | 10 +---
 include/geos/noding/ValidatingNoder.h              | 14 +++++
 include/geos/noding/snap/SnappingNoder.h           |  2 +-
 include/geos/noding/snapround/HotPixel.h           |  9 +--
 include/geos/noding/snapround/SnapRoundingNoder.h  |  6 +-
 .../geos/operation/overlayng/EdgeNodingBuilder.h   |  2 +-
 include/geos/operation/overlayng/OverlayEdge.h     |  4 +-
 include/geos/operation/overlayng/OverlayGraph.h    |  2 +-
 include/geos/operation/overlayng/OverlayLabel.h    | 14 ++---
 include/geos/operation/overlayng/OverlayNG.h       | 67 ++++++++++++++++------
 .../operation/overlayng/OverlayNGSnapIfNeeded.h    | 10 ++--
 include/geos/operation/overlayng/OverlayUtil.h     |  8 +--
 .../geos/operation/overlayng/PrecisionReducer.h    |  4 +-
 include/geos/operation/overlayng/PrecisionUtil.h   |  6 +-
 .../geos/operation/union/CascadedPolygonUnion.h    |  7 ++-
 include/geos/operation/union/OverlapUnion.h        | 18 +++---
 include/geos/operation/union/UnionStrategy.h       |  4 +-
 tools/ci/script_cmake.sh                           |  4 +-
 23 files changed, 147 insertions(+), 106 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
