[geos-commits] [SCM] GEOS branch master updated. 466cff135c8e504632ae38b79a1348dbadb390f1
git at osgeo.org
git at osgeo.org
Tue Aug 11 12:47:32 PDT 2020
the project "GEOS".
via 466cff135c8e504632ae38b79a1348dbadb390f1 (commit)
from 2a2e67ff4400adc9041e21eb0031c51f8f4d2487 (commit)
revisions in full, below.
commit 466cff135c8e504632ae38b79a1348dbadb390f1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Aug 11 12:20:36 2020 -0700
Output POINT EMPTY in WKB. References #1005
diff --git a/include/geos/io/WKBWriter.h b/include/geos/io/WKBWriter.h
index 4bbadf0..d40e281 100644
--- a/include/geos/io/WKBWriter.h
+++ b/include/geos/io/WKBWriter.h
@@ -184,6 +184,7 @@ private:
unsigned char buf[8];
void writePoint(const geom::Point& p);
+ void writePointEmpty(const geom::Point& p);
// throws IOException
void writeLineString(const geom::LineString& ls);
diff --git a/src/io/WKBWriter.cpp b/src/io/WKBWriter.cpp
index 7876383..37babfd 100644
--- a/src/io/WKBWriter.cpp
+++ b/src/io/WKBWriter.cpp
@@ -30,6 +30,7 @@
#include <geos/geom/MultiLineString.h>
#include <geos/geom/MultiPolygon.h>
#include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/CoordinateArraySequence.h>
#include <geos/geom/PrecisionModel.h>
#include <ostream>
@@ -121,10 +122,25 @@ WKBWriter::write(const Geometry& g, ostream& os)
void
+WKBWriter::writePointEmpty(const Point& g)
+ writeByteOrder();
+ writeGeometryType(WKBConstants::wkbPoint, g.getSRID());
+ writeSRID(g.getSRID());
+ Coordinate c(DoubleNotANumber, DoubleNotANumber, DoubleNotANumber);
+ CoordinateArraySequence cas(std::size_t(1), g.getCoordinateDimension());
+ cas.setAt(c, 0);
+ writeCoordinateSequence(cas, false);
+void
WKBWriter::writePoint(const Point& g)
- if(g.isEmpty()) throw
- util::IllegalArgumentException("Empty Points cannot be represented in WKB");
+ if(g.isEmpty()) {
+ return writePointEmpty(g);
writeByteOrder();
diff --git a/tests/unit/io/WKBWriterTest.cpp b/tests/unit/io/WKBWriterTest.cpp
index bf29c88..381449c 100644
--- a/tests/unit/io/WKBWriterTest.cpp
+++ b/tests/unit/io/WKBWriterTest.cpp
@@ -173,5 +173,30 @@ void object::test<5>
assert(geom->equals(geom2.get()));
+// 5 - Check WKB representation of empty polygon
+// See http://trac.osgeo.org/geos/ticket/680
+template<>
+template<>
+void object::test<6>
+ auto geom = wktreader.read("POINT EMPTY");
+ geom->setSRID(4326);
+ std::stringstream result_stream;
+ wkbwriter.setOutputDimension(2);
+ wkbwriter.setByteOrder(1);
+ wkbwriter.setIncludeSRID(1);
+ wkbwriter.writeHEX(*geom, result_stream);
+ std::string actual = result_stream.str();
+ ensure_equals(actual, "0101000020E6100000000000000000F87F000000000000F87F");
+ auto geom2 = wkbreader.readHEX(result_stream);
+ assert(geom->equals(geom2.get()));
} // namespace tut
Summary of changes:
include/geos/io/WKBWriter.h | 1 +
src/io/WKBWriter.cpp | 20 ++++++++++++++++++--
tests/unit/io/WKBWriterTest.cpp | 25 +++++++++++++++++++++++++
3 files changed, 44 insertions(+), 2 deletions(-)
hooks/post-receive
More information about the geos-commits
