[geos-commits] [SCM] GEOS branch master updated. 1d34d2c497786920f69521c77e50620f2efb34a6
Thu Aug 13 12:57:12 PDT 2020
the project "GEOS".
       via  1d34d2c497786920f69521c77e50620f2efb34a6 (commit)
      from  8a4f50edddd9740742562b3f81ea2f5880eaf093 (commit)
revisions in full, below.
commit 1d34d2c497786920f69521c77e50620f2efb34a6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Aug 13 12:28:14 2020 -0700
    Support reading WKB that includes M coordinates, but do not actually store the M (because we have nowhere to store it right now). References #460
diff --git a/include/geos/io/WKBReader.h b/include/geos/io/WKBReader.h
index 63e4128..33461ee 100644
--- a/include/geos/io/WKBReader.h
+++ b/include/geos/io/WKBReader.h
@@ -22,12 +22,12 @@
 #include <geos/export.h>
-#include <geos/geom/GeometryFactory.h>
 #include <geos/io/ByteOrderDataInStream.h> // for composition
 #include <iosfwd> // ostream, istream
 #include <memory>
-#include <vector>
+// #include <vector>
+#include <array>
 #define BAD_GEOM_TYPE_MSG "Bad geometry type encountered in"
@@ -40,7 +40,7 @@
 namespace geos {
 namespace geom {
-//class GeometryFactory;
+class GeometryFactory;
 class Coordinate;
 class Geometry;
 class GeometryCollection;
@@ -52,6 +52,7 @@ class MultiPoint;
 class MultiLineString;
 class MultiPolygon;
 class PrecisionModel;
+class CoordinateSequence;
 } // namespace geom
 } // namespace geos
@@ -80,7 +81,7 @@ class GEOS_DLL WKBReader {
 public:
-    WKBReader(geom::GeometryFactory const& f): factory(f) {}
+    WKBReader(geom::GeometryFactory const& f);
     /// Inizialize parser with default GeometryFactory.
     WKBReader();
@@ -119,10 +120,12 @@ private:
     // for now support the WKB standard only - may be generalized later
     unsigned int inputDimension;
+    bool hasZ;
+    bool hasM;
     ByteOrderDataInStream dis;
-    std::vector<double> ordValues;
+    std::array<double, 4> ordValues;
     std::unique_ptr<geom::Geometry> readGeometry();
diff --git a/src/io/WKBReader.cpp b/src/io/WKBReader.cpp
index f264f38..c38c367 100644
--- a/src/io/WKBReader.cpp
+++ b/src/io/WKBReader.cpp
@@ -46,10 +46,16 @@ using namespace geos::geom;
 namespace geos {
 namespace io { // geos.io
+WKBReader::WKBReader(geom::GeometryFactory const& f)
+    : factory(f)
+    , inputDimension(2)
+    , hasZ(false)
+    , hasM(false)
 WKBReader::WKBReader()
-    factory(*(GeometryFactory::getDefaultInstance()))
+    : WKBReader(*(GeometryFactory::getDefaultInstance()))
 ostream&
 WKBReader::printHEX(istream& is, ostream& os)
@@ -195,21 +201,25 @@ WKBReader::readGeometry()
     /* ISO type range 1000 is Z, 2000 is M, 3000 is ZM */
     int isoTypeRange = (typeInt & 0xffff) / 1000;
     int isoHasZ = (isoTypeRange == 1) || (isoTypeRange == 3);
-    //int isoHasM = (isoTypeRange == 2) || (isoTypeRange == 3);
+    int isoHasM = (isoTypeRange == 2) || (isoTypeRange == 3);
     /* SFSQL high bit flag for Z, next bit for M */
     int sfsqlHasZ = (typeInt & 0x80000000) != 0;
-    //int sfsqlHasM = (typeInt & 0x40000000) != 0;
+    int sfsqlHasM = (typeInt & 0x40000000) != 0;
 #if DEBUG_WKB_READER
     cout << "WKB geometryType: " << geometryType << endl;
 #endif
-    bool hasZ = sfsqlHasZ || isoHasZ;
-    if(hasZ) {
+    hasZ = sfsqlHasZ || isoHasZ;
+    hasM = sfsqlHasM || isoHasM;
+    if(hasZ && hasM) {
+        inputDimension = 4;
+    else if (hasZ || hasM) {
         inputDimension = 3;
     else {
-        inputDimension = 2;    // doesn't handle M currently
+        inputDimension = 2;
@@ -231,12 +241,6 @@ WKBReader::readGeometry()
         SRID = dis.readInt();    // read SRID
-    // allocate space for ordValues
-    if(ordValues.size() < inputDimension) {
-        ordValues.resize(inputDimension);
     std::unique_ptr<Geometry> result;
     switch(geometryType) {
@@ -275,7 +279,7 @@ std::unique_ptr<Point>
 WKBReader::readPoint()
     readCoordinate();
-    if(inputDimension == 3) {
+    if (hasZ) {
         return std::unique_ptr<Point>(factory.createPoint(Coordinate(ordValues[0], ordValues[1], ordValues[2])));
     else {
@@ -377,7 +381,7 @@ WKBReader::readMultiPolygon()
         if(!dynamic_cast<Polygon*>(geoms[i].get())) {
             stringstream err;
             err << BAD_GEOM_TYPE_MSG << " Polygon";
-            throw  ParseException(err.str());
+            throw ParseException(err.str());
@@ -400,12 +404,12 @@ WKBReader::readGeometryCollection()
 std::unique_ptr<CoordinateSequence>
 WKBReader::readCoordinateSequence(int size)
-    auto seq = factory.getCoordinateSequenceFactory()->create(size, inputDimension);
-    auto targetDim = seq->getDimension();
+    unsigned int targetDim = 2 + (hasZ ? 1 : 0);
+    auto seq = factory.getCoordinateSequenceFactory()->create(size, targetDim);
     if(targetDim > inputDimension) {
         targetDim = inputDimension;
-    for(int i = 0; i < size; i++) {
+    for(unsigned int i = 0; i < size; i++) {
         readCoordinate();
         for(unsigned int j = 0; j < targetDim; j++) {
             seq->setOrdinate(i, j, ordValues[j]);
@@ -418,13 +422,17 @@ void
 WKBReader::readCoordinate()
     const PrecisionModel& pm = *factory.getPrecisionModel();
-    for(unsigned int i = 0; i < inputDimension; ++i) {
-        if(i <= 1) {
+    for(std::size_t i = 0; i < inputDimension; ++i) {
+        if (i < 2) {
             ordValues[i] = pm.makePrecise(dis.readDouble());
-        else {
+        else if (hasZ) {
             ordValues[i] = dis.readDouble();
+        else {
+            // Read and throw away any extra (M) dimensions
+            dis.readDouble();
     cout << "WKB coordinate: " << ordValues[0] << "," << ordValues[1] << endl;
diff --git a/tests/unit/capi/GEOSContainsTest.cpp b/tests/unit/capi/GEOSContainsTest.cpp
index d06ce2e..558e61f 100644
--- a/tests/unit/capi/GEOSContainsTest.cpp
+++ b/tests/unit/capi/GEOSContainsTest.cpp
@@ -6,6 +6,7 @@
 #include <geos_c.h>
 #include <geos/io/WKBReader.h>
 #include <geos/geom/PrecisionModel.h>
+#include <geos/geom/GeometryFactory.h>
 // std
 #include <cstdarg>
 #include <cstdio>
diff --git a/tests/unit/capi/GEOSPreparedGeometryTest.cpp b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
index ca760b9..040d0d1 100644
--- a/tests/unit/capi/GEOSPreparedGeometryTest.cpp
+++ b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
@@ -6,6 +6,7 @@
 #include <geos_c.h>
 // std
 #include <cstdarg>
 #include <cstdio>
diff --git a/tests/unit/io/WKBReaderTest.cpp b/tests/unit/io/WKBReaderTest.cpp
index c313252..82cd14d 100644
--- a/tests/unit/io/WKBReaderTest.cpp
+++ b/tests/unit/io/WKBReaderTest.cpp
@@ -33,6 +33,7 @@ struct test_wkbreader_data {
     geos::io::WKBReader wkbreader;
     geos::io::WKBWriter xdrwkbwriter;
     geos::io::WKBWriter ndrwkbwriter;
+    geos::io::WKBWriter ndr3dwkbwriter;
     geos::io::WKTReader wktreader;
     typedef std::unique_ptr<geos::geom::Geometry> GeomPtr;
@@ -46,10 +47,24 @@ struct test_wkbreader_data {
         xdrwkbwriter(2, geos::io::WKBConstants::wkbXDR),
         // 2D only, NDR (little endian)
         ndrwkbwriter(2, geos::io::WKBConstants::wkbNDR),
+        // 3D only, NDR (little endian)
+        ndr3dwkbwriter(3, geos::io::WKBConstants::wkbNDR),
         wktreader(gf.get())
     void
+    testInput(const std::string& hexwkb,
+              const std::string& expected)
+        std::stringstream hexin(hexwkb);
+        GeomPtr g(wkbreader.readHEX(hexin));
+        std::stringstream ndr_out;
+        ndr3dwkbwriter.writeHEX(*g, ndr_out);
+        ensure_equals("hex output",
+                      ndr_out.str(), expected.c_str());
+    void
     testInputNdr(const std::string& WKT,
                  const std::string& ndrWKB)
@@ -457,5 +472,57 @@ void object::test<19>
+// POINT M (1 2 3)
+template<>
+template<>
+void object::test<20>
+    testInput(
+        "01D1070000000000000000F03F00000000000000400000000000000840",
+        "0101000000000000000000F03F0000000000000040"
+// POINT ZM (1 2 3 4)
+template<>
+template<>
+void object::test<21>
+    testInput(
+        "01B90B0000000000000000F03F000000000000004000000000000008400000000000001040",
+        "0101000080000000000000F03F00000000000000400000000000000840"
+// LINESTRING M (1 2 3, 4 5 6)
+template<>
+template<>
+void object::test<22>
+    testInput(
+        "01D207000002000000000000000000F03F00000000000000400000000000000840000000000000104000000000000014400000000000001840",
+        "010200000002000000000000000000F03F000000000000004000000000000010400000000000001440"
+// LINESTRING ZM (1 2 3 4, 5 6 7 8)
+template<>
+template<>
+void object::test<23>
+    testInput(
+        "01BA0B000002000000000000000000F03F000000000000004000000000000008400000000000001040000000000000144000000000000018400000000000001C400000000000002040",
+        "010200008002000000000000000000F03F00000000000000400000000000000840000000000000144000000000000018400000000000001C40"
 } // namespace tut
Summary of changes:
 include/geos/io/WKBReader.h                  | 13 +++---
 src/io/WKBReader.cpp                         | 52 ++++++++++++---------
 tests/unit/capi/GEOSContainsTest.cpp         |  1 +
 tests/unit/capi/GEOSPreparedGeometryTest.cpp |  1 +
 tests/unit/io/WKBReaderTest.cpp              | 67 ++++++++++++++++++++++++++++
 5 files changed, 107 insertions(+), 27 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
