[geos-commits] [SCM] GEOS branch master updated. 2e4a7562f31f3663e0488044d0550da077ad66d9
Mon Aug 24 20:05:19 PDT 2020
the project "GEOS".
       via  2e4a7562f31f3663e0488044d0550da077ad66d9 (commit)
       via  97c3e7778d3e0be6dfa849462e8308ddf278a726 (commit)
      from  87ce4c1a06460d82fa97fb1c7736434015928ac5 (commit)
revisions in full, below.
commit 2e4a7562f31f3663e0488044d0550da077ad66d9
Merge: 97c3e77 87ce4c1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Aug 24 20:05:12 2020 -0700
    Merge branch 'master' of https://git.osgeo.org/gitea/geos/geos
diff --cc capi/geos_ts_c.cpp
index 00a5cd7,361d634..7557459
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@@ -63,9 -63,9 +63,11 @@@
  #include <geos/operation/distance/IndexedFacetDistance.h>
  #include <geos/operation/linemerge/LineMerger.h>
  #include <geos/operation/overlay/OverlayOp.h>
+ #include <geos/operation/overlayng/OverlayNG.h>
+ #include <geos/operation/overlayng/OverlayNGSnapIfNeeded.h>
  #include <geos/operation/overlay/snap/GeometrySnapper.h>
 +#include <geos/operation/overlayng/PrecisionReducer.h>
 +#include <geos/operation/overlayng/OverlayNG.h>
  #include <geos/operation/intersection/Rectangle.h>
  #include <geos/operation/intersection/RectangleIntersection.h>
  #include <geos/operation/polygonize/Polygonizer.h>
commit 97c3e7778d3e0be6dfa849462e8308ddf278a726
Date:   Mon Aug 24 20:05:03 2020 -0700
    When called without options, use OverlayNG for CAPI GEOSGeom_setPrecision
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 519da23..00a5cd7 100644
@@ -64,6 +64,8 @@
@@ -2336,15 +2338,23 @@ extern "C" {
             else {
                 newpm.reset(new PrecisionModel());
+            Geometry* ret;
             GeometryFactory::Ptr gf =
                 GeometryFactory::create(newpm.get(), g->getSRID());
-            Geometry* ret;
             if(gridSize != 0 && cursize != gridSize) {
                 // We need to snap the geometry
-                GeometryPrecisionReducer reducer(*gf);
-                reducer.setPointwise(flags & GEOS_PREC_NO_TOPO);
-                reducer.setRemoveCollapsedComponents(!(flags & GEOS_PREC_KEEP_COLLAPSED));
-                ret = reducer.reduce(*g).release();
+                if (flags) {
+                    GeometryPrecisionReducer reducer(*gf);
+                    reducer.setPointwise(flags & GEOS_PREC_NO_TOPO);
+                    reducer.setRemoveCollapsedComponents(!(flags & GEOS_PREC_KEEP_COLLAPSED));
+                    ret = reducer.reduce(*g).release();
+                else {
+                    // OverlayNG reducer preserves topology and drops collapsed elements
+                    // All it really is, is a call to OverlayNG::geomunion()
+                    auto reducedGeom = geos::operation::overlayng::PrecisionReducer::reducePrecision(g, newpm.get());
+                    ret = reducedGeom.release();
             else {
                 // No need or willing to snap, just change the factory
diff --git a/include/geos/operation/overlayng/OverlayNG.h b/include/geos/operation/overlayng/OverlayNG.h
index aa88b12..d25a6f0 100644
--- a/include/geos/operation/overlayng/OverlayNG.h
+++ b/include/geos/operation/overlayng/OverlayNG.h
@@ -133,6 +133,23 @@ public:
     * with a defined precision model.
     * The noding strategy is determined by the precision model.
+    OverlayNG(const geom::Geometry* geom0, const geom::Geometry* geom1, const geom::GeometryFactory* p_geomFact, int p_opCode)
+        : pm(p_geomFact->getPrecisionModel())
+        , inputGeom(geom0, geom1)
+        , geomFact(p_geomFact)
+        , opCode(p_opCode)
+        , noder(nullptr)
+        , isOptimized(true)
+        , isOutputEdges(false)
+        , isOutputResultEdges(false)
+        , isOutputNodedEdges(false)
+    * Creates an overlay operation on the given geometries,
+    * with a defined precision model.
+    * The noding strategy is determined by the precision model.
     OverlayNG(const geom::Geometry* geom0, const geom::Geometry* geom1, const geom::PrecisionModel* p_pm, int p_opCode)
         : pm(p_pm)
diff --git a/src/geom/LineString.cpp b/src/geom/LineString.cpp
index dc88966..dbd5ab0 100644
--- a/src/geom/LineString.cpp
+++ b/src/geom/LineString.cpp
@@ -324,7 +324,8 @@ LineString::normalizeClosed()
     CoordinateSequence::scroll(uniqueCoordinates.get(), minCoordinate);
     uniqueCoordinates->add(uniqueCoordinates->getAt(0));
-    if(algorithm::Orientation::isCCW(uniqueCoordinates.get())) {
+    if(uniqueCoordinates->size() >= 4 && algorithm::Orientation::isCCW(uniqueCoordinates.get())) {
         CoordinateSequence::reverse(uniqueCoordinates.get());
     points = uniqueCoordinates.get()->clone();
diff --git a/src/operation/overlayng/OverlayNG.cpp b/src/operation/overlayng/OverlayNG.cpp
index dbcae1b..096f07e 100644
--- a/src/operation/overlayng/OverlayNG.cpp
+++ b/src/operation/overlayng/OverlayNG.cpp
@@ -101,7 +101,7 @@ std::unique_ptr<Geometry>
 OverlayNG::overlay(const Geometry* geom0, const Geometry* geom1,
         int opCode, noding::Noder* noder)
-    OverlayNG ov(geom0, geom1, nullptr, opCode);
+    OverlayNG ov(geom0, geom1, static_cast<PrecisionModel*>(nullptr), opCode);
     ov.setNoder(noder);
     return ov.getResult();
diff --git a/src/operation/overlayng/PrecisionReducer.cpp b/src/operation/overlayng/PrecisionReducer.cpp
index 94bd2bc..811cbb7 100644
--- a/src/operation/overlayng/PrecisionReducer.cpp
+++ b/src/operation/overlayng/PrecisionReducer.cpp
@@ -26,8 +26,10 @@ namespace overlayng { // geos.operation.overlayng
 PrecisionReducer::reducePrecision(const Geometry* geom, const PrecisionModel* pm)
-    std::unique_ptr<Geometry> reduced = OverlayNG::geomunion(geom, pm);
-    return reduced;
+    auto gf = GeometryFactory::create(pm, geom->getSRID());
+    // OverlayNG(const geom::Geometry* geom0, const geom::Geometry* geom1, const geom::GeometryFactory* p_geomFact, int p_opCode)
+    OverlayNG ov(geom, nullptr, gf.get(), OverlayNG::UNION);
+    return ov.getResult();
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 44b2ad2..f4e29f3 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -25,6 +25,7 @@ EXTRA_DIST = \
 	tut/tut_runner.hpp \
 	tut/tut_xml_reporter.hpp \
 	util/NodingTestUtil.h \
+	capi/capi_test_utils.h \
 	CMakeLists.txt
diff --git a/tests/unit/capi/GEOSGeomFromWKBTest.cpp b/tests/unit/capi/GEOSGeomFromWKBTest.cpp
index 5d1b428..2f6638a 100644
--- a/tests/unit/capi/GEOSGeomFromWKBTest.cpp
+++ b/tests/unit/capi/GEOSGeomFromWKBTest.cpp
@@ -3,14 +3,8 @@
 #include <tut/tut.hpp>
 #include <utility.h> // wkb_hex_decoder
-// geos
-#include <geos_c.h>
-// std
-#include <string>
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
-#include <memory>
+#include "capi_test_utils.h"
 namespace tut {
@@ -18,24 +12,11 @@ namespace tut {
 // Common data used in test cases.
-struct test_capigeosgeomfromwkb_data {
+struct test_capigeosgeomfromwkb_data : public capitest::test_handlers {
     GEOSGeometry* geom1_;
     GEOSGeometry* geom2_;
     GEOSWKTReader* reader_;
-    static void
-    notice(const char* fmt, ...)
-        std::fprintf(stdout, "NOTICE: ");
-        va_list ap;
-        va_start(ap, fmt);
-        std::vfprintf(stdout, fmt, ap);
-        va_end(ap);
-        std::fprintf(stdout, "\n");
     test_capigeosgeomfromwkb_data()
         : geom1_(nullptr), geom2_(nullptr), reader_(nullptr)
diff --git a/tests/unit/capi/GEOSGeom_createLineStringTest.cpp b/tests/unit/capi/GEOSGeom_createLineStringTest.cpp
index a9181bc..1061ce3 100644
--- a/tests/unit/capi/GEOSGeom_createLineStringTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createLineStringTest.cpp
@@ -1,7 +1,4 @@
-// geos
 namespace tut {
diff --git a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
index 68f3220..1f4998a 100644
--- a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
@@ -1,13 +1,6 @@
-// Test Suite for C-API GEOSGeom_setPrecision_r
-// geos
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
 namespace tut {
@@ -15,25 +8,13 @@ namespace tut {
-struct test_capigeosgeomsetprecision_data {
+struct test_capigeosgeomsetprecision_data : public capitest::test_handlers {
     GEOSWKTWriter* wktw_;
     GEOSGeometry* geom3_;
-    static void
-        va_list ap;
-        va_end(ap);
     GEOSGeometry*
     fromWKT(const char* wkt)
@@ -69,9 +50,7 @@ struct test_capigeosgeomsetprecision_data {
         GEOSWKTWriter_destroy(wktw_);
-        geom1_ = nullptr;
-        geom2_ = nullptr;
-        geom3_ = nullptr;
+        geom1_ = geom2_ = geom3_ = nullptr;
         finishGEOS();
@@ -92,14 +71,12 @@ void object::test<1>
     geom1_ = fromWKT("POLYGON EMPTY");
-    ensure(geom1_ != 0);
-    double scale = GEOSGeom_getPrecision(geom1_);
-    ensure_equals(scale, 0.0);
+    ensure_equals(GEOSGeom_getPrecision(geom1_), 0.0);
     geom3_ = GEOSGeom_setPrecision(geom1_, 2.0, 0);
     ensure(geom3_ != 0);
-    ensure_equals(toWKT(geom3_), std::string("POLYGON EMPTY"));
-    scale = GEOSGeom_getPrecision(geom3_);
-    ensure_equals(scale, 2.0);
+    ensure(capi_geometry_same(geom3_, "POLYGON EMPTY"));
+    ensure_equals(GEOSGeom_getPrecision(geom3_), 2.0);
 template<>
@@ -108,10 +85,9 @@ void object::test<2>
     geom1_ = fromWKT("LINESTRING(-3 6, 9 1)");
-    ensure_equals(toWKT(geom3_), std::string("LINESTRING (-2 6, 10 2)"));
+    ensure(capi_geometry_same(geom3_, "LINESTRING (-2 6, 10 2)"));
 // See effects of precision reduction on intersection operation
@@ -121,12 +97,11 @@ void object::test<3>
     geom1_ = fromWKT("LINESTRING(2 10, 4 30)");
     geom2_ = fromWKT("LINESTRING(4 10, 2 30)");
-    ensure(geom2_ != 0);
     geom3_ = GEOSIntersection(geom1_, geom2_);
-    ensure_equals(toWKT(geom3_), std::string("POINT (3 20)"));
+    ensure(capi_geometry_same(geom3_, "POINT (3 20)"));
     GEOSGeometry* g;
@@ -142,7 +117,7 @@ void object::test<3>
     GEOSGeom_destroy(geom3_);
-    ensure_equals(toWKT(geom3_), std::string("POINT (4 20)"));
+    ensure(capi_geometry_same(geom3_, "POINT (4 20)"));
     // One input with precision grid of 0.5, the other of 2.0
     g = GEOSGeom_setPrecision(geom1_, 0.5, 0);
@@ -152,11 +127,10 @@ void object::test<3>
-    ensure_equals(scale, 0.5);
-    scale = GEOSGeom_getPrecision(geom2_);
+    ensure_equals(GEOSGeom_getPrecision(geom1_), 0.5);
+    ensure_equals(GEOSGeom_getPrecision(geom2_), 2.0);
 // Retain (or not) topology
@@ -166,15 +140,14 @@ void object::test<4>
     geom1_ = fromWKT("POLYGON((10 10,20 10,16 15,20 20, 10 20, 14 15, 10 10))");
     geom2_ = GEOSGeom_setPrecision(geom1_, 5.0, 0);
-    ensure_equals(toWKT(geom2_), std::string(
-                      "MULTIPOLYGON (((10 10, 15 15, 20 10, 10 10)), ((15 15, 10 20, 20 20, 15 15)))"
+    ensure(capi_geometry_same(geom2_,
+        "MULTIPOLYGON (((10 10, 15 15, 20 10, 10 10)), ((15 15, 10 20, 20 20, 15 15)))"));
     geom3_ = GEOSGeom_setPrecision(geom1_, 5.0, GEOS_PREC_NO_TOPO);
-                      "POLYGON ((10 10, 20 10, 15 15, 20 20, 10 20, 15 15, 10 10))"
+        "POLYGON ((10 10, 20 10, 15 15, 20 20, 10 20, 15 15, 10 10))"));
 // Retain (or not) collapsed elements
@@ -184,15 +157,12 @@ void object::test<5>
     geom1_ = fromWKT("LINESTRING(1 0, 2 0)");
-                      "LINESTRING EMPTY"
+    ensure(capi_geometry_same(geom2_, "LINESTRING EMPTY"));
     geom3_ = GEOSGeom_setPrecision(geom1_, 5.0, GEOS_PREC_KEEP_COLLAPSED);
-                      "LINESTRING (0 0, 0 0)"
+    ensure_equals(toWKT(geom3_), "LINESTRING (0 0, 0 0)");
 } // namespace tut
diff --git a/tests/unit/capi/capi_test_utils.h b/tests/unit/capi/capi_test_utils.h
index 3a4a6e5..a725c53 100644
--- a/tests/unit/capi/capi_test_utils.h
+++ b/tests/unit/capi/capi_test_utils.h
@@ -1,5 +1,5 @@
-#ifndef GEOS_CAPI_TEST_UTILS_H
-#define GEOS_CAPI_TEST_UTILS_H
+#pragma once
 #include <geos_c.h>
@@ -9,8 +9,6 @@
 #include <cstring>
 namespace capitest {
     struct test_handlers {
@@ -26,6 +24,30 @@ namespace capitest {
+        bool
+        capi_geometry_same(GEOSGeometry* g1, GEOSGeometry* g2, double tolerance)
+            GEOSNormalize(g1);
+            GEOSNormalize(g2);
+            return GEOSEqualsExact(g1, g2, tolerance);
+        bool
+        capi_geometry_same(GEOSGeometry* g1, GEOSGeometry* g2)
+            return capi_geometry_same(g1, g2, 1e-12);
+        bool
+        capi_geometry_same(GEOSGeometry* g1, const char* g2str)
+            GEOSGeometry* g2 = GEOSGeomFromWKT(g2str);
+            tut::ensure(g2 != 0);
+            bool rslt = capi_geometry_same(g1, g2);
+            GEOSGeom_destroy(g2);
+            return rslt;
         test_handlers()
             initGEOS(notice, notice);
@@ -39,4 +61,3 @@ namespace capitest {
-#endif
Summary of changes:
 capi/geos_ts_c.cpp                                | 20 ++++--
 include/geos/operation/overlayng/OverlayNG.h      | 17 +++++
 src/geom/LineString.cpp                           |  3 +-
 src/operation/overlayng/OverlayNG.cpp             |  2 +-
 src/operation/overlayng/PrecisionReducer.cpp      |  6 +-
 tests/unit/Makefile.am                            |  1 +
 tests/unit/capi/GEOSGeomFromWKBTest.cpp           | 25 +------
 tests/unit/capi/GEOSGeom_createLineStringTest.cpp |  3 -
 tests/unit/capi/GEOSGeom_setPrecisionTest.cpp     | 84 ++++++++---------------
 tests/unit/capi/capi_test_utils.h                 | 31 +++++++--
 10 files changed, 96 insertions(+), 96 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
