[geos-commits] [SCM] GEOS branch master updated. c3a65c9ae2363aca06945deb7b007101f3813888
git at osgeo.org
git at osgeo.org
Tue Aug 25 15:07:38 PDT 2020
the project "GEOS".
via c3a65c9ae2363aca06945deb7b007101f3813888 (commit)
via aac987dda9be5a4bcc4bd4a1abcd63211f89f99e (commit)
from c5f33f91a2eb631e3419a91f4f02076babacf00b (commit)
revisions in full, below.
commit c3a65c9ae2363aca06945deb7b007101f3813888
Merge: aac987d c5f33f9
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Aug 25 15:07:31 2020 -0700
Merge branch 'master' of https://git.osgeo.org/gitea/geos/geos
commit aac987dda9be5a4bcc4bd4a1abcd63211f89f99e
Date: Tue Aug 25 15:07:24 2020 -0700
Rename the utility test functions to ensure_* and change the struct name to reflect larger goals than just providing helper init/finish code
diff --git a/tests/unit/capi/GEOSBoundaryTest.cpp b/tests/unit/capi/GEOSBoundaryTest.cpp
index 1368155..b658833 100644
--- a/tests/unit/capi/GEOSBoundaryTest.cpp
+++ b/tests/unit/capi/GEOSBoundaryTest.cpp
@@ -9,7 +9,7 @@ namespace tut {
// Test Group
-struct test_geosboundary_data : public capitest::test_handlers {};
+struct test_geosboundary_data : public capitest::utility {};
typedef test_group<test_geosboundary_data> group;
typedef group::object object;
diff --git a/tests/unit/capi/GEOSEnvelopeTest.cpp b/tests/unit/capi/GEOSEnvelopeTest.cpp
index bc1a635..f1bbc0f 100644
--- a/tests/unit/capi/GEOSEnvelopeTest.cpp
+++ b/tests/unit/capi/GEOSEnvelopeTest.cpp
// Test Group
-struct test_geosenvelope_data : public capitest::test_handlers {};
+struct test_geosenvelope_data : public capitest::utility {};
typedef test_group<test_geosenvelope_data> group;
diff --git a/tests/unit/capi/GEOSGeomFromWKBTest.cpp b/tests/unit/capi/GEOSGeomFromWKBTest.cpp
index 2f6638a..e74f080 100644
--- a/tests/unit/capi/GEOSGeomFromWKBTest.cpp
+++ b/tests/unit/capi/GEOSGeomFromWKBTest.cpp
@@ -12,7 +12,7 @@ namespace tut {
// Common data used in test cases.
-struct test_capigeosgeomfromwkb_data : public capitest::test_handlers {
+struct test_capigeosgeomfromwkb_data : public capitest::utility {
GEOSGeometry* geom1_;
GEOSGeometry* geom2_;
GEOSWKTReader* reader_;
diff --git a/tests/unit/capi/GEOSGeom_createLineStringTest.cpp b/tests/unit/capi/GEOSGeom_createLineStringTest.cpp
index 1061ce3..c9f6148 100644
--- a/tests/unit/capi/GEOSGeom_createLineStringTest.cpp
+++ b/tests/unit/capi/GEOSGeom_createLineStringTest.cpp
@@ -6,7 +6,7 @@ namespace tut {
// Test Group
-struct test_geosgeom_createlinestring_data : public capitest::test_handlers {};
+struct test_geosgeom_createlinestring_data : public capitest::utility {};
typedef test_group<test_geosgeom_createlinestring_data> group;
diff --git a/tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp b/tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp
index 62b12b3..871ff87 100644
--- a/tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp
+++ b/tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp
// Test Group
-struct test_geosgeom_getcoordseq_data : public capitest::test_handlers {};
+struct test_geosgeom_getcoordseq_data : public capitest::utility {};
typedef test_group<test_geosgeom_getcoordseq_data> group;
diff --git a/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp b/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp
index fa736e9..57c7e7f 100644
--- a/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp
// Test Group
-struct test_geosgeom_getcoordinatedimension_data : public capitest::test_handlers {};
+struct test_geosgeom_getcoordinatedimension_data : public capitest::utility {};
typedef test_group<test_geosgeom_getcoordinatedimension_data> group;
diff --git a/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp b/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp
index f03296a..79686b0 100644
--- a/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp
+++ b/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp
// Test Group
-struct test_geosgeom_getdimensions_data : public capitest::test_handlers {};
+struct test_geosgeom_getdimensions_data : public capitest::utility {};
typedef test_group<test_geosgeom_getdimensions_data> group;
diff --git a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
index 1f4998a..0f84e21 100644
--- a/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
+++ b/tests/unit/capi/GEOSGeom_setPrecisionTest.cpp
@@ -1,4 +1,3 @@
-#include <tut/tut.hpp>
#include "capi_test_utils.h"
@@ -8,7 +7,7 @@ namespace tut {
-struct test_capigeosgeomsetprecision_data : public capitest::test_handlers {
+struct test_capigeosgeomsetprecision_data : public capitest::utility {
GEOSWKTWriter* wktw_;
@@ -75,7 +74,7 @@ void object::test<1>
geom3_ = GEOSGeom_setPrecision(geom1_, 2.0, 0);
ensure(geom3_ != 0);
- ensure(capi_geometry_same(geom3_, "POLYGON EMPTY"));
+ ensure_geometry_equals(geom3_, "POLYGON EMPTY");
ensure_equals(GEOSGeom_getPrecision(geom3_), 2.0);
@@ -87,7 +86,7 @@ void object::test<2>
geom1_ = fromWKT("LINESTRING(-3 6, 9 1)");
- ensure(capi_geometry_same(geom3_, "LINESTRING (-2 6, 10 2)"));
+ ensure_geometry_equals(geom3_, "LINESTRING (-2 6, 10 2)");
// See effects of precision reduction on intersection operation
@@ -101,7 +100,7 @@ void object::test<3>
geom3_ = GEOSIntersection(geom1_, geom2_);
- ensure(capi_geometry_same(geom3_, "POINT (3 20)"));
+ ensure_geometry_equals(geom3_, "POINT (3 20)");
GEOSGeometry* g;
@@ -117,7 +116,7 @@ void object::test<3>
GEOSGeom_destroy(geom3_);
- ensure(capi_geometry_same(geom3_, "POINT (4 20)"));
+ ensure_geometry_equals(geom3_, "POINT (4 20)");
// One input with precision grid of 0.5, the other of 2.0
g = GEOSGeom_setPrecision(geom1_, 0.5, 0);
@@ -127,7 +126,7 @@ void object::test<3>
ensure_equals(GEOSGeom_getPrecision(geom1_), 0.5);
ensure_equals(GEOSGeom_getPrecision(geom2_), 2.0);
@@ -142,12 +141,12 @@ void object::test<4>
geom1_ = fromWKT("POLYGON((10 10,20 10,16 15,20 20, 10 20, 14 15, 10 10))");
geom2_ = GEOSGeom_setPrecision(geom1_, 5.0, 0);
- ensure(capi_geometry_same(geom2_,
- "MULTIPOLYGON (((10 10, 15 15, 20 10, 10 10)), ((15 15, 10 20, 20 20, 15 15)))"));
+ ensure_geometry_equals(geom2_,
+ "MULTIPOLYGON (((10 10, 15 15, 20 10, 10 10)), ((15 15, 10 20, 20 20, 15 15)))");
geom3_ = GEOSGeom_setPrecision(geom1_, 5.0, GEOS_PREC_NO_TOPO);
- "POLYGON ((10 10, 20 10, 15 15, 20 20, 10 20, 15 15, 10 10))"));
+ "POLYGON ((10 10, 20 10, 15 15, 20 20, 10 20, 15 15, 10 10))");
// Retain (or not) collapsed elements
@@ -159,7 +158,7 @@ void object::test<5>
geom1_ = fromWKT("LINESTRING(1 0, 2 0)");
- ensure(capi_geometry_same(geom2_, "LINESTRING EMPTY"));
+ ensure_geometry_equals(geom2_, "LINESTRING EMPTY");
geom3_ = GEOSGeom_setPrecision(geom1_, 5.0, GEOS_PREC_KEEP_COLLAPSED);
ensure_equals(toWKT(geom3_), "LINESTRING (0 0, 0 0)");
diff --git a/tests/unit/capi/GEOSGetNumInteriorRingsTest.cpp b/tests/unit/capi/GEOSGetNumInteriorRingsTest.cpp
index ce9d96b..968868e 100644
--- a/tests/unit/capi/GEOSGetNumInteriorRingsTest.cpp
+++ b/tests/unit/capi/GEOSGetNumInteriorRingsTest.cpp
// Test Group
-struct test_geosgetnuminteriorrings_data : public capitest::test_handlers {};
+struct test_geosgetnuminteriorrings_data : public capitest::utility {};
typedef test_group<test_geosgetnuminteriorrings_data> group;
diff --git a/tests/unit/capi/GEOSIntersectionTest.cpp b/tests/unit/capi/GEOSIntersectionTest.cpp
index 9dcd61c..a919533 100644
--- a/tests/unit/capi/GEOSIntersectionTest.cpp
+++ b/tests/unit/capi/GEOSIntersectionTest.cpp
@@ -1,14 +1,8 @@
// Test Suite for C-API GEOSintersection
+#include "capi_test_utils.h"
-// geos
-#include <geos_c.h>
-// std
-#include <cstdarg>
-#include <cstdio>
-#include <cstdlib>
namespace tut {
@@ -16,30 +10,18 @@ namespace tut {
-struct test_capigeosintersection_data {
+struct test_capigeosintersection_data : public capitest::utility
GEOSGeometry* geom3_;
GEOSGeometry* expected_;
- static void
- notice(const char* fmt, ...)
- std::fprintf(stdout, "NOTICE: ");
- va_list ap;
- va_start(ap, fmt);
- std::vfprintf(stdout, fmt, ap);
- va_end(ap);
- std::fprintf(stdout, "\n");
test_capigeosintersection_data()
: geom1_(nullptr), geom2_(nullptr), geom3_(nullptr)
- initGEOS(notice, notice);
wktw_ = GEOSWKTWriter_create();
GEOSWKTWriter_setTrim(wktw_, 1);
GEOSWKTWriter_setOutputDimension(wktw_, 3);
@@ -49,23 +31,6 @@ struct test_capigeosintersection_data {
expected_ = nullptr;
- std::string
- toWKT(GEOSGeometry* g)
- char* wkt = GEOSWKTWriter_write(wktw_, g);
- std::string ret(wkt);
- GEOSFree(wkt);
- return ret;
- int
- same(GEOSGeometry* g1, GEOSGeometry* g2, double tolerance)
- GEOSNormalize(g1);
- GEOSNormalize(g2);
- return GEOSEqualsExact(g1, g2, tolerance);
~test_capigeosintersection_data()
GEOSWKTWriter_destroy(wktw_);
@@ -77,7 +42,6 @@ struct test_capigeosintersection_data {
geom2_ = nullptr;
geom3_ = nullptr;
- finishGEOS();
@@ -104,7 +68,7 @@ void object::test<1>
ensure(nullptr != geom3_);
- ensure_equals(toWKT(geom3_), std::string("POLYGON EMPTY"));
template<>
@@ -120,7 +84,7 @@ void object::test<2>
- ensure_equals(toWKT(geom3_), std::string("POINT (2 2)"));
+ ensure_geometry_equals(geom3_, "POINT (2 2)");
template<>
@@ -138,7 +102,7 @@ void object::test<3>
- ensure(same(geom3_, expected_, 0.1));
+ ensure_geometry_equals(geom3_, expected_, 0.1);
/* See http://trac.osgeo.org/geos/ticket/719 */
diff --git a/tests/unit/capi/GEOSLengthTest.cpp b/tests/unit/capi/GEOSLengthTest.cpp
index 9214e76..a57033d 100644
--- a/tests/unit/capi/GEOSLengthTest.cpp
+++ b/tests/unit/capi/GEOSLengthTest.cpp
// Test Group
-struct test_geoslength_data : public capitest::test_handlers {};
+struct test_geoslength_data : public capitest::utility {};
typedef test_group<test_geoslength_data> group;
diff --git a/tests/unit/capi/GEOSSetSRIDTest.cpp b/tests/unit/capi/GEOSSetSRIDTest.cpp
index 13a7645..7dce47d 100644
--- a/tests/unit/capi/GEOSSetSRIDTest.cpp
+++ b/tests/unit/capi/GEOSSetSRIDTest.cpp
// Test Group
-struct test_geossetsrid_data : public capitest::test_handlers {};
+struct test_geossetsrid_data : public capitest::utility {};
typedef test_group<test_geossetsrid_data> group;
diff --git a/tests/unit/capi/GEOSUnionPrecTest.cpp b/tests/unit/capi/GEOSUnionPrecTest.cpp
index b5c2ab9..11cb581 100644
--- a/tests/unit/capi/GEOSUnionPrecTest.cpp
+++ b/tests/unit/capi/GEOSUnionPrecTest.cpp
// Test Group
-struct test_geosunionprec_data : public capitest::test_handlers {};
+struct test_geosunionprec_data : public capitest::utility {};
typedef test_group<test_geosunionprec_data> group;
diff --git a/tests/unit/capi/GEOSUnionTest.cpp b/tests/unit/capi/GEOSUnionTest.cpp
index ed962db..2efceb2 100644
--- a/tests/unit/capi/GEOSUnionTest.cpp
+++ b/tests/unit/capi/GEOSUnionTest.cpp
// Test Group
-struct test_geosunion_data : public capitest::test_handlers {};
+struct test_geosunion_data : public capitest::utility {};
typedef test_group<test_geosunion_data> group;
diff --git a/tests/unit/capi/GEOSisValidReasonTest.cpp b/tests/unit/capi/GEOSisValidReasonTest.cpp
index 4f4bfd7..8166cc5 100644
--- a/tests/unit/capi/GEOSisValidReasonTest.cpp
+++ b/tests/unit/capi/GEOSisValidReasonTest.cpp
// Test Group
-struct test_geosisvalid_data : public capitest::test_handlers {};
+struct test_geosisvalid_data : public capitest::utility {};
typedef test_group<test_geosisvalid_data> group;
diff --git a/tests/unit/capi/GEOSisValidTest.cpp b/tests/unit/capi/GEOSisValidTest.cpp
index b1aa68a..cf20091 100644
--- a/tests/unit/capi/GEOSisValidTest.cpp
+++ b/tests/unit/capi/GEOSisValidTest.cpp
// Test Group
-struct test_geosisvalidreason_data : public capitest::test_handlers {};
+struct test_geosisvalidreason_data : public capitest::utility {};
typedef test_group<test_geosisvalidreason_data> group;
diff --git a/tests/unit/capi/capi_test_utils.h b/tests/unit/capi/capi_test_utils.h
index a725c53..0f20a0b 100644
--- a/tests/unit/capi/capi_test_utils.h
+++ b/tests/unit/capi/capi_test_utils.h
@@ -1,6 +1,8 @@
#pragma once
+#include <tut/tut.hpp>
#include <geos_c.h>
#include <cstdarg>
@@ -11,7 +13,18 @@
namespace capitest {
- struct test_handlers {
+ struct utility {
+ utility()
+ initGEOS(notice, notice);
+ ~utility()
+ finishGEOS();
static void notice(const char* fmt, ...)
@@ -24,39 +37,50 @@ namespace capitest {
- bool
- capi_geometry_same(GEOSGeometry* g1, GEOSGeometry* g2, double tolerance)
+ void
+ ensure_geometry_equals(GEOSGeometry* g1, GEOSGeometry* g2, double tolerance)
GEOSNormalize(g1);
GEOSNormalize(g2);
+ bool rslt = GEOSEqualsExact(g1, g2, tolerance);
+ if (!rslt)
+ char* wkt1 = GEOSGeomToWKT(g1);
+ char* wkt2 = GEOSGeomToWKT(g2);
+ std::fprintf(stdout, "\n%s != %s\n", wkt1, wkt2);
+ GEOSFree(wkt1);
+ GEOSFree(wkt2);
+ tut::ensure_equals("GEOSEqualsExact(g1, g2, tolerance)", rslt, 1);
+ return;
- bool
- capi_geometry_same(GEOSGeometry* g1, GEOSGeometry* g2)
+ void
+ ensure_geometry_equals(GEOSGeometry* g1, GEOSGeometry* g2)
- return capi_geometry_same(g1, g2, 1e-12);
+ return ensure_geometry_equals(g1, g2, 1e-12);
- bool
- capi_geometry_same(GEOSGeometry* g1, const char* g2str)
+ void
+ ensure_geometry_equals(GEOSGeometry* g1, const char* g2str)
GEOSGeometry* g2 = GEOSGeomFromWKT(g2str);
tut::ensure(g2 != 0);
- bool rslt = capi_geometry_same(g1, g2);
- GEOSGeom_destroy(g2);
- return rslt;
- test_handlers()
+ GEOSNormalize(g1);
+ GEOSNormalize(g2);
+ bool rslt = GEOSEqualsExact(g1, g2, 1e-12);
+ if (!rslt)
+ GEOSFree(wkt1);
+ GEOSFree(wkt2);
+ tut::ensure_equals("GEOSEqualsExact(g1, g2, 1e-12)", rslt, 1);
+ return;
- ~test_handlers()
- finishGEOS();
Summary of changes:
tests/unit/capi/GEOSBoundaryTest.cpp | 2 +-
tests/unit/capi/GEOSEnvelopeTest.cpp | 2 +-
tests/unit/capi/GEOSGeomFromWKBTest.cpp | 2 +-
tests/unit/capi/GEOSGeom_createLineStringTest.cpp | 2 +-
tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp | 2 +-
.../capi/GEOSGeom_getCoordinateDimensionTest.cpp | 2 +-
tests/unit/capi/GEOSGeom_getDimensionsTest.cpp | 2 +-
tests/unit/capi/GEOSGeom_setPrecisionTest.cpp | 23 ++++----
tests/unit/capi/GEOSGetNumInteriorRingsTest.cpp | 2 +-
tests/unit/capi/GEOSIntersectionTest.cpp | 50 +++-------------
tests/unit/capi/GEOSLengthTest.cpp | 2 +-
tests/unit/capi/GEOSSetSRIDTest.cpp | 2 +-
tests/unit/capi/GEOSUnionPrecTest.cpp | 2 +-
tests/unit/capi/GEOSUnionTest.cpp | 2 +-
tests/unit/capi/GEOSisValidReasonTest.cpp | 2 +-
tests/unit/capi/GEOSisValidTest.cpp | 2 +-
tests/unit/capi/capi_test_utils.h | 66 +++++++++++++++-------
17 files changed, 77 insertions(+), 90 deletions(-)
hooks/post-receive
More information about the geos-commits
