[geos-commits] [SCM] GEOS branch master updated. 06b310ddf1948ebfe0048cd33b5687f6fa279475
git at osgeo.org
git at osgeo.org
Wed Aug 26 09:21:11 PDT 2020
the project "GEOS".
via 06b310ddf1948ebfe0048cd33b5687f6fa279475 (commit)
via 2c6e3bf0066f0f5a77da5752bc413d01c033e39a (commit)
via 45df395ee640f9ad556338da936c46b860072914 (commit)
from 7b5762bf4368f88d3276752f0541c571cef930f5 (commit)
revisions in full, below.
commit 06b310ddf1948ebfe0048cd33b5687f6fa279475
Merge: 45df395 2c6e3bf
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Aug 26 09:21:00 2020 -0700
Merge branch 'brm'
commit 2c6e3bf0066f0f5a77da5752bc413d01c033e39a
Date: Tue Aug 25 16:36:18 2020 -0700
Change BufferResultMatcher to static methods
diff --git a/tests/xmltester/BufferResultMatcher.cpp b/tests/xmltester/BufferResultMatcher.cpp
index 54570e3..8e17a56 100644
--- a/tests/xmltester/BufferResultMatcher.cpp
+++ b/tests/xmltester/BufferResultMatcher.cpp
@@ -28,10 +28,6 @@
namespace geos {
namespace xmltester {
-double BufferResultMatcher::MAX_RELATIVE_AREA_DIFFERENCE = 1.0E-3;
-double BufferResultMatcher::MIN_DISTANCE_TOLERANCE = 1.0e-8;
-double BufferResultMatcher::MAX_HAUSDORFF_DISTANCE_FACTOR = 100;
bool
BufferResultMatcher::isBufferResultMatch(const geom::Geometry& actualBuffer,
const geom::Geometry& expectedBuffer,
diff --git a/tests/xmltester/BufferResultMatcher.h b/tests/xmltester/BufferResultMatcher.h
index f12cc9e..dddeec0 100644
--- a/tests/xmltester/BufferResultMatcher.h
+++ b/tests/xmltester/BufferResultMatcher.h
@@ -31,27 +31,27 @@ namespace xmltester {
class BufferResultMatcher {
public:
- bool isBufferResultMatch(const geom::Geometry& actualBuffer,
+ static bool isBufferResultMatch(const geom::Geometry& actualBuffer,
double distance);
private:
- static double MAX_RELATIVE_AREA_DIFFERENCE;
- static double MAX_HAUSDORFF_DISTANCE_FACTOR;
+ static constexpr double MAX_RELATIVE_AREA_DIFFERENCE = 1.0E-3;
+ static constexpr double MAX_HAUSDORFF_DISTANCE_FACTOR = 100;
* The minimum distance tolerance which will be used.
* This is required because densified vertices do no lie
* precisely on their parent segment.
- static double MIN_DISTANCE_TOLERANCE;
+ static constexpr double MIN_DISTANCE_TOLERANCE = 1.0e-8;
- bool isSymDiffAreaInTolerance(const geom::Geometry& actualBuffer,
+ static bool isSymDiffAreaInTolerance(const geom::Geometry& actualBuffer,
const geom::Geometry& expectedBuffer);
- bool isBoundaryHausdorffDistanceInTolerance(
+ static bool isBoundaryHausdorffDistanceInTolerance(
double distance);
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index 596fc1a..8fcf23d 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -216,6 +216,9 @@ checkOverlaySuccess(geom::Geometry const& gRes, geom::Geometry const& gRealRes)
static int
checkBufferSuccess(geom::Geometry const& gRes, geom::Geometry const& gRealRes, double dist)
+ using geos::xmltester::BufferResultMatcher;
int success = 1;
do {
@@ -238,11 +241,7 @@ checkBufferSuccess(geom::Geometry const& gRes, geom::Geometry const& gRealRes, d
<< std::endl;
- geos::xmltester::BufferResultMatcher matcher;
- if(! matcher.isBufferResultMatch(gRealRes,
- gRes,
- dist)) {
+ if(!BufferResultMatcher::isBufferResultMatch(gRealRes, gRes, dist)) {
std::cerr << "BufferResultMatcher FAILED" << std::endl;
success = 0;
break;
commit 45df395ee640f9ad556338da936c46b860072914
Date: Tue Aug 25 16:23:08 2020 -0700
Remove unused CTS class file
diff --git a/tests/xmltester/CTS.cpp b/tests/xmltester/CTS.cpp
deleted file mode 100644
index c11a6c9..0000000
--- a/tests/xmltester/CTS.cpp
+++ /dev/null
@@ -1,52 +0,0 @@
- * GEOS - Geometry Engine Open Source
- * http://geos.osgeo.org
- * Copyright (C) 2001-2002 Vivid Solutions Inc.
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Public Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
-// CTS.cpp : Testing class
-#include <iostream>
-#include <geos/io/ByteOrderDataInStream.h>
-#include <geos/io/ByteOrderValues.h>
-#include <geos/io/ParseException.h>
-#include <geos/io/WKBConstants.h>
-#include <geos/io/WKBReader.h>
-#include <geos/io/WKBWriter.h>
-#include <geos/io/WKTReader.h>
-#include <geos/io/WKTWriter.h>
-#include <geos/io/CLocalizer.h>
-#include <geos/geom.h>
-using namespace std;
-using namespace geos;
-int
-main(int argc, char** argv)
- try {
- cout << "Start:" << endl;
- cout << "End" << endl;
- catch(const GEOSException& ge) {
- cout << ge->toString() << endl;
- return 0;
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index 242586d..999e2aa 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -189,14 +189,8 @@ XMLTESTS=$(SAFE_XMLTESTS) $(INVALID_OUTPUT_XMLTESTS) $(FAILING_XMLTESTS)
EXTRA_DIST += $(XMLTESTS)
noinst_PROGRAMS = SimpleWKTTester XMLTester
-#bin_PROGRAMS = XMLTester
-# CTS
LIBS = $(top_builddir)/src/libgeos.la
-# -lmpatrol -lbfd -lintl -liberty -limagehlp
-# CTS_SOURCES = CTS.cpp
-# CTS_LDADD = $(LIBS)
SimpleWKTTester_SOURCES = SimpleWKTTester.cpp
SimpleWKTTester_LDADD = $(LIBS)
diff --git a/tests/xmltester/SimpleWKTTester.cpp b/tests/xmltester/SimpleWKTTester.cpp
index bdecf6f..6125bda 100644
--- a/tests/xmltester/SimpleWKTTester.cpp
+++ b/tests/xmltester/SimpleWKTTester.cpp
@@ -13,8 +13,6 @@
#include <iostream>
#include <fstream>
Summary of changes:
tests/xmltester/BufferResultMatcher.cpp | 4 ---
tests/xmltester/BufferResultMatcher.h | 14 ++++-----
tests/xmltester/CTS.cpp | 52 ---------------------------------
tests/xmltester/Makefile.am | 6 ----
tests/xmltester/SimpleWKTTester.cpp | 2 --
tests/xmltester/XMLTester.cpp | 9 +++---
6 files changed, 11 insertions(+), 76 deletions(-)
delete mode 100644 tests/xmltester/CTS.cpp
hooks/post-receive
More information about the geos-commits
