[geos-commits] [SCM] GEOS branch master updated. da2fb44ee0680811c971689ae0f60fe9187b42ae
Fri Aug 28 13:33:49 PDT 2020
the project "GEOS".
       via  da2fb44ee0680811c971689ae0f60fe9187b42ae (commit)
       via  acbe90de979f66994545ea3b9e18c9e8a8352776 (commit)
      from  dd5b572f414f26ef2c35cba9440ad25208952ed9 (commit)
revisions in full, below.
commit da2fb44ee0680811c971689ae0f60fe9187b42ae
Merge: acbe90d dd5b572
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Aug 28 13:33:42 2020 -0700
    Merge branch 'master' of https://git.osgeo.org/gitea/geos/geos
commit acbe90de979f66994545ea3b9e18c9e8a8352776
Date:   Fri Aug 28 13:33:32 2020 -0700
    Port JTS https://github.com/locationtech/jts/commit/be18a8a797763116346ca605f8d7aedc66153773 Improve Orientation isCCW to handle topology collapse
diff --git a/include/geos/algorithm/Orientation.h b/include/geos/algorithm/Orientation.h
index 168b0e4..0ed4bba 100644
--- a/include/geos/algorithm/Orientation.h
+++ b/include/geos/algorithm/Orientation.h
@@ -68,22 +68,25 @@ public:
     static int index(const geom::Coordinate& p1, const geom::Coordinate& p2,
                      const geom::Coordinate& q);
-    /** \brief
-     * Computes whether a ring defined by an array of
-     * [Coordinates](@ref geom::Coordinate) is oriented counter-clockwise.
-     * - The list of points is assumed to have the first and last points equal.
-     * - This will handle coordinate lists which contain repeated points.
-     * This algorithm is *only* guaranteed to work with valid rings. If the
-     * ring is invalid (e.g. self-crosses or touches), the computed result may not
-     * be correct.
-     * @param ring an array of Coordinates forming a ring
-     * @return `true` if the ring is oriented counter-clockwise.
-     * @throws IllegalArgumentException
-     *           if there are too few points to determine orientation (< 4)
+    * Computes whether a ring defined by a geom::CoordinateSequence is
+    * oriented counter-clockwise.
+    *  * The list of points is assumed to have the first and last points equal.
+    *  * This handles coordinate lists which contain repeated points.
+    *  * This handles rings which contain collapsed segments
+    *    (in particular, along the top of the ring).
+    * This algorithm is guaranteed to work with valid rings.
+    * It also works with "mildly invalid" rings
+    * which contain collapsed (coincident) flat segments along the top of the ring.
+    * If the ring is "more" invalid (e.g. self-crosses or touches),
+    * the computed result may not be correct.
+    * @param ring a CoordinateSequence forming a ring (with first and last point identical)
+    * @return true if the ring is oriented counter-clockwise.
+    * @throws IllegalArgumentException if there are too few points to determine orientation (< 4)
     static bool isCCW(const geom::CoordinateSequence* ring);
diff --git a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
index a29fb94..364ef34 100644
--- a/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
+++ b/include/geos/algorithm/locate/IndexedPointInAreaLocator.h
@@ -45,7 +45,7 @@ namespace locate { // geos::algorithm::locate
  * an areal geometry, using indexing for efficiency.
  * The Location is computed precisely, in that points located on the geometry boundary
- * or segments will return [Location::BOUNDARY](@ref geom::Location::BOUNDARY).
+ * or segments will return [geom::Location::BOUNDARY](@ref geom::Location).
  * Polygonal and [LinearRing](@ref geom::LinearRing) geometries are supported.
diff --git a/include/geos/algorithm/locate/SimplePointInAreaLocator.h b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
index 8f0bd04..4c1a678 100644
--- a/include/geos/algorithm/locate/SimplePointInAreaLocator.h
+++ b/include/geos/algorithm/locate/SimplePointInAreaLocator.h
@@ -56,14 +56,14 @@ public:
      * The return value is one of:
-     * - [Location::INTERIOR](@ref geom::Location::INTERIOR)
+     * - geom::Location::INTERIOR
      *   if the point is in the geometry interior
-     * - [Location::BOUNDARY](@ref geom::Location::BOUNDARY)
+     * - geom::Location::BOUNDARY
      *   if the point lies exactly on the boundary
-     * - [Location::EXTERIOR](@ref geom::Location::EXTERIOR)
+     * - geom::Location::EXTERIOR
      *   if the point is outside the geometry
-     * Computes `Location::BOUNDARY` if the point lies exactly
+     * Computes `geom::Location::BOUNDARY` if the point lies exactly
      * on the polygon boundary.
      * @param p the point to test
diff --git a/src/algorithm/Orientation.cpp b/src/algorithm/Orientation.cpp
index 009b97c..64d3c2a 100644
--- a/src/algorithm/Orientation.cpp
+++ b/src/algorithm/Orientation.cpp
@@ -23,6 +23,7 @@
 #include <geos/algorithm/Orientation.h>
 #include <geos/algorithm/CGAlgorithmsDD.h>
 #include <geos/geom/CoordinateSequence.h>
+#include <geos/geom/CoordinateArraySequence.h>
 #include <geos/geom/Coordinate.h>
 #include <geos/geom/Location.h>
 #include <geos/util/IllegalArgumentException.h>
@@ -38,6 +39,101 @@ Orientation::index(const geom::Coordinate& p1, const geom::Coordinate& p2,
     return CGAlgorithmsDD::orientationIndex(p1, p2, q);
+/* public static */
+bool
+Orientation::isCCW(const geom::CoordinateSequence* ring)
+    // # of points without closing endpoint
+    int nPts = ring->size() - 1;
+    // sanity check
+    if (nPts < 3)
+        throw util::IllegalArgumentException(
+            "Ring has fewer than 4 points, so orientation cannot be determined");
+     * Find first highest point after a lower point, if one exists
+     * (e.g. a rising segment)
+     * If one does not exist, hiIndex will remain 0
+     * and the ring must be flat.
+     * Note this relies on the convention that
+     * rings have the same start and end point.
+    geom::Coordinate upHiPt;
+    ring->getAt(0, upHiPt);
+    double prevY = upHiPt.y;
+    geom::Coordinate upLowPt;
+    upLowPt.setNull();
+    // const geom::Coordinate& upLowPt = nullptr;
+    int iUpHi = 0;
+    for (int i = 1; i <= nPts; i++) {
+        double py = ring->getY(i);
+        * If segment is upwards and endpoint is higher, record it
+        if (py > prevY && py >= upHiPt.y) {
+            ring->getAt(i, upHiPt);
+            iUpHi = i;
+            ring->getAt(i-1, upLowPt);
+        prevY = py;
+     * Check if ring is flat and return default value if so
+    if (iUpHi == 0) return false;
+     * Find the next lower point after the high point
+     * (e.g. a falling segment).
+     * This must exist since ring is not flat.
+    int iDownLow = iUpHi;
+    do {
+        iDownLow = (iDownLow + 1) % nPts;
+    } while (iDownLow != iUpHi && ring->getY(iDownLow) == upHiPt.y );
+    const geom::Coordinate& downLowPt = ring->getAt(iDownLow);
+    int iDownHi = iDownLow > 0 ? iDownLow - 1 : nPts - 1;
+    const geom::Coordinate& downHiPt = ring->getAt(iDownHi);
+     * Two cases can occur:
+     * 1) the hiPt and the downPrevPt are the same.
+     *    This is the general position case of a "pointed cap".
+     *    The ring orientation is determined by the orientation of the cap
+     * 2) The hiPt and the downPrevPt are different.
+     *    In this case the top of the cap is flat.
+     *    The ring orientation is given by the direction of the flat segment
+    if (upHiPt.equals2D(downHiPt)) {
+       * Check for the case where the cap has configuration A-B-A.
+       * This can happen if the ring does not contain 3 distinct points
+       * (including the case where the input array has fewer than 4 elements), or
+       * it contains coincident line segments.
+      if (upLowPt.equals2D(upHiPt) || downLowPt.equals2D(upHiPt) || upLowPt.equals2D(downLowPt))
+        return false;
+       * It can happen that the top segments are coincident.
+       * This is an invalid ring, which cannot be computed correctly.
+       * In this case the orientation is 0, and the result is false.
+      int orientationIndex = index(upLowPt, upHiPt, downLowPt);
+      return orientationIndex == COUNTERCLOCKWISE;
+    else {
+       * Flat cap - direction of flat top determines orientation
+      double delX = downHiPt.x - upHiPt.x;
+      return delX < 0;
+#if 0
 /* public static */
 bool
@@ -122,7 +218,7 @@ Orientation::isCCW(const geom::CoordinateSequence* ring)
     return isCCW;
+#endif
 } // namespace geos.algorithm
diff --git a/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp b/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
index e972776..f6acbae 100644
--- a/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
@@ -28,19 +28,37 @@ namespace tut {
 struct test_isccw_data {
     typedef std::unique_ptr<geos::geom::Geometry> GeometryPtr;
-    std::unique_ptr<geos::geom::CoordinateSequence> cs_;
     geos::io::WKTReader reader_;
     geos::io::WKBReader breader_;
     test_isccw_data()
-        : cs_(nullptr)
-        assert(nullptr == cs_);
     ~test_isccw_data()
+    void
+    checkOrientationCCW(bool expectedCCW, const std::string& wkt)
+        GeometryPtr geom(reader_.read(wkt));
+        geos::geom::Polygon* poly = dynamic_cast<geos::geom::Polygon*>(geom.get());
+        ensure("WKT must be POLYGON)", poly != nullptr);
+        const geos::geom::CoordinateSequence* cs = poly->getExteriorRing()->getCoordinatesRO();
+        bool actualCCW = Orientation::isCCW(cs);
+        ensure_equals("CoordinateSequence isCCW", expectedCCW, actualCCW);
+    void
+    checkHexOrientationCCW(bool expectedCCW, std::istringstream& wkt)
+        GeometryPtr geom(breader_.readHEX(wkt));
+        auto cs = geom->getCoordinates();
+        bool actualCCW = Orientation::isCCW(cs.get());
 typedef test_group<test_isccw_data> group;
@@ -59,12 +77,7 @@ void object::test<1>
     const std::string wkt("POLYGON ((60 180, 140 240, 140 240, 140 240, 200 180, 120 120, 60 180))");
-    GeometryPtr geom(reader_.read(wkt));
-    cs_ = geom->getCoordinates();
-    bool isCCW = Orientation::isCCW(cs_.get());
-    ensure_equals(false, isCCW);
+    checkOrientationCCW(false, wkt);
 // 2 - Test if coordinates of polygon are counter-clockwise oriented
@@ -74,12 +87,7 @@ void object::test<2>
     const std::string wkt("POLYGON ((60 180, 140 120, 100 180, 140 240, 60 180))");
-    ensure_equals(true, isCCW);
+    checkOrientationCCW(true, wkt);
 // 3 - Test the same polygon as in test No 2 but with duplicated top point
@@ -89,12 +97,7 @@ void object::test<3>
     const std::string wkt("POLYGON ((60 180, 140 120, 100 180, 140 240, 140 240, 60 180))");
 // 4 - Test orientation the narrow (almost collapsed) ring
@@ -107,10 +110,7 @@ void object::test<4>
     std::istringstream
     wkt("0102000000040000000000000000000000841D588465963540F56BFB214F0341408F26B714B2971B40F66BFB214F0341408C26B714B2971B400000000000000000841D588465963540");
-    GeometryPtr geom(breader_.readHEX(wkt));
-    ensure_equals(isCCW, true);
+    checkHexOrientationCCW(true, wkt);
 // 5 - Test orientation the narrow (almost collapsed) ring
@@ -123,11 +123,124 @@ void object::test<5>
     std::istringstream
     wkt("0102000000040000000000000000000000841D588465963540F56BFB214F0341408F26B714B2971B40F66BFB214F0341408E26B714B2971B400000000000000000841D588465963540");
+// testCCWSmall
+template<>
+template<>
+void object::test<6>
+    const std::string wkt("POLYGON ((1 1, 9 1, 5 9, 1 1))");
+// testFlatTopSegment
+template<>
+template<>
+void object::test<7>
+    const std::string wkt("POLYGON ((100 200, 200 200, 200 100, 100 100, 100 200))");
+// testFlatMultipleTopSegment
+template<>
+template<>
+void object::test<8>
+    const std::string wkt("POLYGON ((100 200, 127 200, 151 200, 173 200, 200 200, 100 100, 100 200))");
+// testDegenerateRingHorizontal
+template<>
+template<>
+void object::test<9>
+    const std::string wkt("POLYGON ((100 200, 100 200, 200 200, 100 200))");
+// testDegenerateRingAngled
+template<>
+template<>
+void object::test<10>
+    const std::string wkt("POLYGON ((100 100, 100 100, 200 200, 100 100))");
+// testDegenerateRingVertical
+template<>
+template<>
+void object::test<11>
+    const std::string wkt("POLYGON ((200 100, 200 100, 200 200, 200 100))");
+* This case is an invalid ring, so answer is a default value
+// testTopAngledSegmentCollapse
+template<>
+template<>
+void object::test<12>
+    const std::string wkt("POLYGON ((10 20, 61 20, 20 30, 50 60, 10 20))");
+// testABATopFlatSegmentCollapse
+template<>
+template<>
+void object::test<13>
+    const std::string wkt("POLYGON ((71 0, 40 40, 70 40, 40 40, 20 0, 71 0))");
+// testABATopFlatSegmentCollapseMiddleStart
+template<>
+template<>
+void object::test<14>
+    const std::string wkt("POLYGON ((90 90, 50 90, 10 10, 90 10, 50 90, 90 90))");
+// testMultipleTopFlatSegmentCollapseSinglePoint
+template<>
+template<>
+void object::test<15>
+    const std::string wkt("POLYGON ((100 100, 200 100, 150 200, 170 200, 200 200, 100 200, 150 200, 100 100))");
+// testMultipleTopFlatSegmentCollapseFlatTop
+template<>
+template<>
+void object::test<16>
+    const std::string wkt("POLYGON ((10 10, 90 10, 70 70, 90 70, 10 70, 30 70, 50 70, 10 10))");
 } // namespace tut
Summary of changes:
 include/geos/algorithm/Orientation.h               |  35 +++--
 .../algorithm/locate/IndexedPointInAreaLocator.h   |   2 +-
 .../algorithm/locate/SimplePointInAreaLocator.h    |   8 +-
 src/algorithm/Orientation.cpp                      |  98 +++++++++++-
 tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp    | 171 +++++++++++++++++----
 5 files changed, 263 insertions(+), 51 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
