[geos-commits] [SCM] GEOS branch master updated. f8f42a730f709a144d6f3193e9aa319775f8d3dc
git at osgeo.org
git at osgeo.org
Tue Dec 8 16:07:30 PST 2020
the project "GEOS".
via f8f42a730f709a144d6f3193e9aa319775f8d3dc (commit)
via 4396072d882ad213048ee95f65b2c399b76dc6cf (commit)
via ca0f29afa0194d448f90a51e95e948d230890e4f (commit)
via b3f8ed5252241b335c60fc868553afa322aba5ce (commit)
via 29c6d4e1b374d200c9ab73c8d55ecfafe5135ce1 (commit)
from aceb9697b4a0d02a3f899eaf0346098c322932ef (commit)
revisions in full, below.
commit f8f42a730f709a144d6f3193e9aa319775f8d3dc
Author: EC2 Default User <ec2-user at ip-172-31-55-124.us-west-2.compute.internal>
Date: Tue Dec 8 23:14:28 2020 +0000
Add fp-contract=off flag to builds to avoid precision mistakes in the double-double code
diff --git a/CMakeLists.txt b/CMakeLists.txt
index b9e2e32..60cb109 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -154,6 +154,21 @@ add_library(geos_cxx_flags INTERFACE)
target_compile_features(geos_cxx_flags INTERFACE cxx_std_11)
+# Add flags to prevent 'fused multiply-add' operations on targets (ARM64)
+# that allow it, as it breaks calculations in DD.cpp.
+# TODO: Replace DD calculations with 'long float' where target supports
+# true long float, and remove other cases where FMA causes regression
+# failures.
+# https://gcc.gnu.org/bugzilla/show_bug.cgi?id=98207
+target_compile_options(geos_cxx_flags INTERFACE
+ "$<$<CXX_COMPILER_ID:Clang>:-ffp-contract=off>"
+ "$<$<CXX_COMPILER_ID:GNU>:-ffp-contract=off>"
+ "$<$<CXX_COMPILER_ID:MSVC>:/fp:precise>"
# Target geos_cxx_flags: common compilation flags
option(DISABLE_GEOS_INLINE "Disable inlining" OFF)
diff --git a/configure.ac b/configure.ac
index 472253b..9d0b772 100644
--- a/configure.ac
+++ b/configure.ac
@@ -195,22 +195,33 @@ dnl to AC_LANG(CXX) or AC_LANG_PUSH(CXX)/AC_LANG_POP()
dnl
AC_LIBTOOL_LANG_CXX_CONFIG
-# Set default AM_CXXFLAGS and AM_CFLAGS
-# -pedantic: ISO does not support long long
-# we add -Wno-long-long to avoid those messages
+dnl Set default AM_CXXFLAGS and AM_CFLAGS
+dnl -pedantic: ISO does not support long long
+dnl we add -Wno-long-long to avoid those messages
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -pedantic], [dummy_cv_pedantic], [-pedantic], [], [WARNFLAGS="$WARNFLAGS -pedantic"], [])
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [dummy_cv_wall], [-Wall], [], [WARNFLAGS="$WARNFLAGS -Wall"], [])
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wno-long-long], [dummy_cv_wno_long_long], [-Wno-long-long], [], [WARNFLAGS="$WARNFLAGS -Wno-long-long"], [])
-# To make numerical computation more stable, we use --ffloat-store
-# on 32-bit platforms
+dnl -----------------------------------------------------------------------------
+dnl To make numerical computation more stable, we use --ffloat-store
+dnl on 32-bit platforms
NUMERICFLAGS=""
-# 32-bit platforms have a 4-byte pointer
+dnl 32-bit platforms have a 4-byte pointer
AC_CHECK_SIZEOF([void *])
if test $ac_cv_sizeof_void_p -eq 4 ; then
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ffloat-store], [dummy_cv_ffloat_store], [-ffloat-store], [], [NUMERICFLAGS="$NUMERICFLAGS -ffloat-store"], [])
fi
+dnl Add flags to prevent 'fused multiply-add' operations on targets (ARM64)
+dnl that allow it, as it breaks calculations in math/DD.cpp.
+dnl TODO: Replace DD calculations with 'long float' where target supports
+dnl true long float, and remove other cases where FMA causes regression
+dnl failures.
+dnl https://gcc.gnu.org/bugzilla/show_bug.cgi?id=98207
+NUMERICFLAGS="$NUMERICFLAGS -ffp-contract=off"
HUSHWARNING="-DUSE_UNSTABLE_GEOS_CPP_API"
DEFAULTFLAGS="${WARNFLAGS} ${NUMERICFLAGS} ${HUSHWARNING} ${OVERLAYNG_FLAGS}"
commit 4396072d882ad213048ee95f65b2c399b76dc6cf
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Dec 8 14:26:59 2020 -0800
Quiet compiler warnings
diff --git a/include/geos/geomgraph/EdgeEndStar.h b/include/geos/geomgraph/EdgeEndStar.h
index 054ddc2..6aae885 100644
--- a/include/geos/geomgraph/EdgeEndStar.h
+++ b/include/geos/geomgraph/EdgeEndStar.h
@@ -123,7 +123,7 @@ public:
virtual bool isAreaLabelsConsistent(const GeometryGraph& geomGraph);
- virtual void propagateSideLabels(int geomIndex);
+ virtual void propagateSideLabels(uint32_t geomIndex);
// throw(TopologyException *);
//virtual int findIndex(EdgeEnd *eSearch);
@@ -150,7 +150,7 @@ protected:
private:
- virtual geom::Location getLocation(int geomIndex,
+ virtual geom::Location getLocation(uint32_t geomIndex,
const geom::Coordinate& p,
std::vector<GeometryGraph*>* geom);
@@ -162,7 +162,7 @@ private:
virtual void computeEdgeEndLabels(const algorithm::BoundaryNodeRule&);
- virtual bool checkAreaLabelsConsistent(int geomIndex);
+ virtual bool checkAreaLabelsConsistent(uint32_t geomIndex);
diff --git a/include/geos/util/GeometricShapeFactory.h b/include/geos/util/GeometricShapeFactory.h
index 776aa13..f87cf5d 100644
--- a/include/geos/util/GeometricShapeFactory.h
+++ b/include/geos/util/GeometricShapeFactory.h
@@ -85,7 +85,7 @@ protected:
const geom::GeometryFactory* geomFact; // externally owned
const geom::PrecisionModel* precModel; // externally owned
Dimensions dim;
- int nPts;
+ uint32_t nPts;
geom::Coordinate coord(double x, double y) const;
@@ -171,7 +171,7 @@ public:
* \brief Sets the total number of points in the created Geometry
- void setNumPoints(int nNPts);
+ void setNumPoints(uint32_t nNPts);
* \brief
diff --git a/src/algorithm/Orientation.cpp b/src/algorithm/Orientation.cpp
index e490e4b..383f36a 100644
--- a/src/algorithm/Orientation.cpp
+++ b/src/algorithm/Orientation.cpp
@@ -45,12 +45,13 @@ bool
Orientation::isCCW(const geom::CoordinateSequence* ring)
// # of points without closing endpoint
- int nPts = static_cast<int>(ring->size()) - 1;
+ int inPts = static_cast<int>(ring->size()) - 1;
// sanity check
- if (nPts < 3)
+ if (inPts < 3)
throw util::IllegalArgumentException(
"Ring has fewer than 4 points, so orientation cannot be determined");
+ uint32_t nPts = static_cast<uint32_t>(inPts);
* Find first highest point after a lower point, if one exists
* (e.g. a rising segment)
diff --git a/src/geom/Polygon.cpp b/src/geom/Polygon.cpp
index 9c3a300..903ef82 100644
--- a/src/geom/Polygon.cpp
+++ b/src/geom/Polygon.cpp
@@ -473,7 +473,7 @@ Polygon::isRectangle() const
// check vertices have correct values
const Envelope& env = *getEnvelopeInternal();
- for(int i = 0; i < 5; i++) {
+ for(uint32_t i = 0; i < 5; i++) {
double x = seq.getX(i);
if(!(x == env.getMinX() || x == env.getMaxX())) {
return false;
diff --git a/src/geomgraph/Depth.cpp b/src/geomgraph/Depth.cpp
index 4cfbed7..fe497fa 100644
--- a/src/geomgraph/Depth.cpp
+++ b/src/geomgraph/Depth.cpp
@@ -68,8 +68,8 @@ Depth::normalize()
void
Depth::add(const Label& lbl)
- for(int i = 0; i < 2; i++) {
- for(int j = 1; j < 3; j++) {
+ for(uint32_t i = 0; i < 2; i++) {
+ for(uint32_t j = 1; j < 3; j++) {
Location loc = lbl.getLocation(i, j);
if(loc == Location::EXTERIOR || loc == Location::INTERIOR) {
// initialize depth if it is null, otherwise
diff --git a/src/geomgraph/DirectedEdge.cpp b/src/geomgraph/DirectedEdge.cpp
index 295937b..1400a0a 100644
--- a/src/geomgraph/DirectedEdge.cpp
+++ b/src/geomgraph/DirectedEdge.cpp
@@ -151,7 +151,7 @@ bool
DirectedEdge::isInteriorAreaEdge()
bool p_isInteriorAreaEdge = true;
if(!(label.isArea(i)
&& label.getLocation(i, Position::LEFT) == Location::INTERIOR
&& label.getLocation(i, Position::RIGHT) == Location::INTERIOR)) {
diff --git a/src/geomgraph/DirectedEdgeStar.cpp b/src/geomgraph/DirectedEdgeStar.cpp
index 62326a7..41cc490 100644
--- a/src/geomgraph/DirectedEdgeStar.cpp
+++ b/src/geomgraph/DirectedEdgeStar.cpp
@@ -148,7 +148,7 @@ DirectedEdgeStar::computeLabelling(std::vector<GeometryGraph*>* geom)
Edge* e = ee->getEdge();
assert(e);
const Label& eLabel = e->getLabel();
- for(int i = 0; i < 2; ++i) {
+ for(uint32_t i = 0; i < 2; ++i) {
Location eLoc = eLabel.getLocation(i);
if(eLoc == Location::INTERIOR || eLoc == Location::BOUNDARY) {
label.setLocation(i, Location::INTERIOR);
diff --git a/src/geomgraph/EdgeEndStar.cpp b/src/geomgraph/EdgeEndStar.cpp
index f1c70f2..d1de587 100644
--- a/src/geomgraph/EdgeEndStar.cpp
+++ b/src/geomgraph/EdgeEndStar.cpp
@@ -161,7 +161,7 @@ EdgeEndStar::computeLabelling(std::vector<GeometryGraph*>* geomGraph)
EdgeEnd* e = *it;
assert(e);
Label& label = e->getLabel();
- for(int geomi = 0; geomi < 2; ++geomi) {
+ for(uint32_t geomi = 0; geomi < 2; ++geomi) {
if(label.isAnyNull(geomi)) {
Location loc = Location::NONE;
if(hasDimensionalCollapseEdge[geomi]) {
@@ -192,7 +192,7 @@ EdgeEndStar::computeEdgeEndLabels(
/*public*/
Location
-EdgeEndStar::getLocation(int geomIndex,
+EdgeEndStar::getLocation(uint32_t geomIndex,
const Coordinate& p, std::vector<GeometryGraph*>* geom)
// compute location only on demand
@@ -213,7 +213,7 @@ EdgeEndStar::isAreaLabelsConsistent(const GeometryGraph& geomGraph)
/*private*/
bool
-EdgeEndStar::checkAreaLabelsConsistent(int geomIndex)
+EdgeEndStar::checkAreaLabelsConsistent(uint32_t geomIndex)
// Since edges are stored in CCW order around the node,
// As we move around the ring we move from the right to
@@ -262,7 +262,7 @@ EdgeEndStar::checkAreaLabelsConsistent(int geomIndex)
/*public*/
void
-EdgeEndStar::propagateSideLabels(int geomIndex)
+EdgeEndStar::propagateSideLabels(uint32_t geomIndex)
//throw(TopologyException *)
diff --git a/src/util/GeometricShapeFactory.cpp b/src/util/GeometricShapeFactory.cpp
index 3d9b234..af15880 100644
--- a/src/util/GeometricShapeFactory.cpp
+++ b/src/util/GeometricShapeFactory.cpp
@@ -58,7 +58,7 @@ GeometricShapeFactory::setCentre(const Coordinate& centre)
void
-GeometricShapeFactory::setNumPoints(int nNPts)
+GeometricShapeFactory::setNumPoints(uint32_t nNPts)
nPts = nNPts;
@@ -86,7 +86,7 @@ GeometricShapeFactory::createRectangle()
int i;
int ipt = 0;
- int nSide = nPts / 4;
+ uint32_t nSide = nPts / 4;
if(nSide < 1) {
nSide = 1;
commit ca0f29afa0194d448f90a51e95e948d230890e4f
Date: Tue Dec 8 14:09:49 2020 -0800
Quite compiler warnings
diff --git a/benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp b/benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp
index f86f0c6..70b1a9f 100644
--- a/benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp
+++ b/benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp
@@ -65,7 +65,7 @@ int main(int argc, char** argv) {
auto num_lines = std::atol(argv[1]);
auto num_reps = argc > 2 ? std::atol(argv[2]) : 1;
- for (int i = 0; i < num_reps; i++) {
+ for (std::size_t i = 0; i < num_reps; i++) {
tester.test(num_lines);
\ No newline at end of file
diff --git a/benchmarks/capi/GEOSPreparedContainsPerfTest.cpp b/benchmarks/capi/GEOSPreparedContainsPerfTest.cpp
index f010948..4665748 100644
--- a/benchmarks/capi/GEOSPreparedContainsPerfTest.cpp
+++ b/benchmarks/capi/GEOSPreparedContainsPerfTest.cpp
@@ -87,7 +87,7 @@ int main(int argc, char** argv) {
GEOSPreparedContainsPerfTest tester;
- int n = std::atoi(argv[2]);
+ std::size_t n = static_cast<std::size_t>(std::atoi(argv[2]));
std::cout << "Performing " << n << " point-in-polygon tests." << std::endl;
std::string fname{argv[1]};
diff --git a/tests/bigtest/GeometryTestFactory.cpp b/tests/bigtest/GeometryTestFactory.cpp
index ca7f337..56bccf0 100644
--- a/tests/bigtest/GeometryTestFactory.cpp
+++ b/tests/bigtest/GeometryTestFactory.cpp
@@ -70,7 +70,7 @@ GeometryTestFactory::createBox(double minx, double miny, int nSide, double segLe
* @param nPts the number of points in the star
CoordinateSequence*
-GeometryTestFactory::createCircle(double basex, double basey, double size, int nPts)
+GeometryTestFactory::createCircle(double basex, double basey, double size, uint32_t nPts)
CoordinateArraySequence* pts = new CoordinateArraySequence(nPts + 1);
double len = size / 2.0;
@@ -86,7 +86,7 @@ GeometryTestFactory::createCircle(double basex, double basey, double size, int n
Polygon*
-GeometryTestFactory::createCircle(GeometryFactory* fact, double basex, double basey, double size, int nPts)
+GeometryTestFactory::createCircle(GeometryFactory* fact, double basex, double basey, double size, uint32_t nPts)
CoordinateSequence* pts = createCircle(basex, basey, size, nPts);
return fact->createPolygon(fact->createLinearRing(pts), nullptr);
diff --git a/tests/bigtest/bigtest.h b/tests/bigtest/bigtest.h
index dcc2924..b4e24af 100644
--- a/tests/bigtest/bigtest.h
+++ b/tests/bigtest/bigtest.h
@@ -35,8 +35,8 @@ class GeometryTestFactory {
public:
static geom::Polygon* createBox(geom::GeometryFactory* fact, double minx, double miny, int nSide, double segLen);
static geom::CoordinateSequence* createBox(double minx, double miny, int nSide, double segLen);
- static geom::CoordinateSequence* createCircle(double basex, double basey, double size, int nPts);
- static geom::Polygon* createCircle(geom::GeometryFactory* fact, double basex, double basey, double size, int nPts);
+ static geom::CoordinateSequence* createCircle(double basex, double basey, double size, uint32_t nPts);
+ static geom::Polygon* createCircle(geom::GeometryFactory* fact, double basex, double basey, double size, uint32_t nPts);
static geom::CoordinateSequence* createSineStar(double basex, double basey, double size, double armLen, int nArms,
int nPts);
static geom::Polygon* createSineStar(geom::GeometryFactory* fact, double basex, double basey, double size,
commit b3f8ed5252241b335c60fc868553afa322aba5ce
Date: Tue Dec 8 14:04:54 2020 -0800
Remove more CI warnings
diff --git a/include/geos/geomgraph/Label.h b/include/geos/geomgraph/Label.h
index c554a02..cda32dd 100644
--- a/include/geos/geomgraph/Label.h
+++ b/include/geos/geomgraph/Label.h
@@ -148,7 +148,7 @@ public:
bool isLine(uint32_t geomIndex) const;
- bool isEqualOnSide(const Label& lbl, int side) const;
+ bool isEqualOnSide(const Label& lbl, uint32_t side) const;
bool allPositionsEqual(uint32_t geomIndex, geom::Location loc) const;
diff --git a/include/geos/geomgraph/Label.inl b/include/geos/geomgraph/Label.inl
index 1cb7ad6..999f430 100644
--- a/include/geos/geomgraph/Label.inl
+++ b/include/geos/geomgraph/Label.inl
@@ -34,7 +34,7 @@ INLINE Label
Label::toLineLabel(const Label& label)
Label lineLabel(geom::Location::NONE);
lineLabel.setLocation(i, label.getLocation(i));
return lineLabel;
@@ -52,7 +52,7 @@ INLINE
Label::Label(uint32_t geomIndex, geom::Location onLoc) :
elt{TopologyLocation(geom::Location::NONE), TopologyLocation(geom::Location::NONE)}
- assert(geomIndex >= 0 && geomIndex < 2);
+ assert(geomIndex < 2);
elt[geomIndex].setLocation(onLoc);
@@ -230,7 +230,7 @@ Label::isLine(uint32_t geomIndex) const
/*public*/
INLINE bool
-Label::isEqualOnSide(const Label& lbl, int side) const
+Label::isEqualOnSide(const Label& lbl, uint32_t side) const
return elt[0].isEqualOnSide(lbl.elt[0], side)
&& elt[1].isEqualOnSide(lbl.elt[1], side);
diff --git a/include/geos/geomgraph/TopologyLocation.h b/include/geos/geomgraph/TopologyLocation.h
index f9e9664..4cbbacb 100644
--- a/include/geos/geomgraph/TopologyLocation.h
+++ b/include/geos/geomgraph/TopologyLocation.h
@@ -96,7 +96,7 @@ public:
bool isAnyNull() const;
- bool isEqualOnSide(const TopologyLocation& le, std::size_t locIndex) const;
+ bool isEqualOnSide(const TopologyLocation& le, uint32_t locIndex) const;
bool isArea() const;
diff --git a/include/geos/geomgraph/TopologyLocation.inl b/include/geos/geomgraph/TopologyLocation.inl
index 55af297..5852428 100644
--- a/include/geos/geomgraph/TopologyLocation.inl
+++ b/include/geos/geomgraph/TopologyLocation.inl
@@ -105,7 +105,7 @@ TopologyLocation::isAnyNull() const
/*public*/
INLINE bool
-TopologyLocation::isEqualOnSide(const TopologyLocation& le, std::size_t locIndex) const
+TopologyLocation::isEqualOnSide(const TopologyLocation& le, uint32_t locIndex) const
return location[locIndex] == le.location[locIndex];
commit 29c6d4e1b374d200c9ab73c8d55ecfafe5135ce1
Date: Tue Dec 8 13:49:12 2020 -0800
Quiet some compiler warnings
diff --git a/include/geos/algorithm/LineIntersector.h b/include/geos/algorithm/LineIntersector.h
index b9b9c03..b38c0a8 100644
--- a/include/geos/algorithm/LineIntersector.h
+++ b/include/geos/algorithm/LineIntersector.h
@@ -298,8 +298,8 @@ private:
void computeIntLineIndex(size_t segmentIndex);
- int computeCollinearIntersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
- const geom::Coordinate& q1, const geom::Coordinate& q2);
+ uint8_t computeCollinearIntersection(const geom::Coordinate& p1, const geom::Coordinate& p2,
+ const geom::Coordinate& q1, const geom::Coordinate& q2);
/** \brief
* This method computes the actual value of the intersection point.
index 065703a..c554a02 100644
@@ -81,7 +81,7 @@ public:
* Other geometry location will be set to
- Label(int geomIndex, geom::Location onLoc);
+ Label(uint32_t geomIndex, geom::Location onLoc);
/** \brief
* Construct a Label with On, Left and Right locations for both Geometries.
@@ -108,21 +108,21 @@ public:
* Initialize the locations for the other Geometry to
- Label(int geomIndex, geom::Location onLoc, geom::Location leftLoc, geom::Location rightLoc);
+ Label(uint32_t geomIndex, geom::Location onLoc, geom::Location leftLoc, geom::Location rightLoc);
void flip();
- geom::Location getLocation(int geomIndex, int posIndex) const;
+ geom::Location getLocation(uint32_t geomIndex, uint32_t posIndex) const;
- geom::Location getLocation(int geomIndex) const;
+ geom::Location getLocation(uint32_t geomIndex) const;
- void setLocation(int geomIndex, int posIndex, geom::Location location);
+ void setLocation(uint32_t geomIndex, uint32_t posIndex, geom::Location location);
- void setLocation(int geomIndex, geom::Location location);
+ void setLocation(uint32_t geomIndex, geom::Location location);
- void setAllLocations(int geomIndex, geom::Location location);
+ void setAllLocations(uint32_t geomIndex, geom::Location location);
- void setAllLocationsIfNull(int geomIndex, geom::Location location);
+ void setAllLocationsIfNull(uint32_t geomIndex, geom::Location location);
void setAllLocationsIfNull(geom::Location location);
@@ -138,24 +138,24 @@ public:
bool isNull() const;
- bool isNull(int geomIndex) const;
+ bool isNull(uint32_t geomIndex) const;
- bool isAnyNull(int geomIndex) const;
+ bool isAnyNull(uint32_t geomIndex) const;
- bool isArea(int geomIndex) const;
+ bool isArea(uint32_t geomIndex) const;
- bool isLine(int geomIndex) const;
+ bool isLine(uint32_t geomIndex) const;
- bool allPositionsEqual(int geomIndex, geom::Location loc) const;
+ bool allPositionsEqual(uint32_t geomIndex, geom::Location loc) const;
/** \brief
* Converts one GeometryLocation to a Line location
- void toLine(int geomIndex);
+ void toLine(uint32_t geomIndex);
std::string toString() const;
index eb1c614..1cb7ad6 100644
@@ -49,7 +49,7 @@ Label::Label(geom::Location onLoc) :
/*public*/
INLINE
-Label::Label(int geomIndex, geom::Location onLoc) :
+Label::Label(uint32_t geomIndex, geom::Location onLoc) :
@@ -88,7 +88,7 @@ Label::operator=(const Label& l)
/*public*/
INLINE
-Label::Label(int geomIndex, geom::Location onLoc, geom::Location leftLoc, geom::Location rightLoc)
+Label::Label(uint32_t geomIndex, geom::Location onLoc, geom::Location leftLoc, geom::Location rightLoc)
elt[0] = TopologyLocation(geom::Location::NONE, geom::Location::NONE, geom::Location::NONE);
elt[1] = TopologyLocation(geom::Location::NONE, geom::Location::NONE, geom::Location::NONE);
@@ -105,49 +105,49 @@ Label::flip()
/*public*/
INLINE geom::Location
-Label::getLocation(int geomIndex, int posIndex) const
+Label::getLocation(uint32_t geomIndex, uint32_t posIndex) const
return elt[geomIndex].get(posIndex);
/*public*/
-Label::getLocation(int geomIndex) const
+Label::getLocation(uint32_t geomIndex) const
return elt[geomIndex].get(Position::ON);
/*public*/
INLINE void
-Label::setLocation(int geomIndex, int posIndex, geom::Location location)
+Label::setLocation(uint32_t geomIndex, uint32_t posIndex, geom::Location location)
elt[geomIndex].setLocation(posIndex, location);
/*public*/
INLINE void
-Label::setLocation(int geomIndex, geom::Location location)
+Label::setLocation(uint32_t geomIndex, geom::Location location)
elt[geomIndex].setLocation(Position::ON, location);
/*public*/
INLINE void
-Label::setAllLocations(int geomIndex, geom::Location location)
+Label::setAllLocations(uint32_t geomIndex, geom::Location location)
elt[geomIndex].setAllLocations(location);
/*public*/
INLINE void
-Label::setAllLocationsIfNull(int geomIndex, geom::Location location)
+Label::setAllLocationsIfNull(uint32_t geomIndex, geom::Location location)
elt[geomIndex].setAllLocationsIfNull(location);
@@ -184,9 +184,9 @@ Label::getGeometryCount() const
/*public*/
INLINE bool
-Label::isNull(int geomIndex) const
+Label::isNull(uint32_t geomIndex) const
return elt[geomIndex].isNull();
@@ -199,9 +199,9 @@ Label::isNull() const
/*public*/
INLINE bool
-Label::isAnyNull(int geomIndex) const
+Label::isAnyNull(uint32_t geomIndex) const
return elt[geomIndex].isAnyNull();
@@ -214,17 +214,17 @@ Label::isArea() const
/*public*/
INLINE bool
-Label::isArea(int geomIndex) const
+Label::isArea(uint32_t geomIndex) const
return elt[geomIndex].isArea();
/*public*/
INLINE bool
-Label::isLine(int geomIndex) const
+Label::isLine(uint32_t geomIndex) const
return elt[geomIndex].isLine();
@@ -238,17 +238,17 @@ Label::isEqualOnSide(const Label& lbl, int side) const
/*public*/
INLINE bool
-Label::allPositionsEqual(int geomIndex, geom::Location loc) const
+Label::allPositionsEqual(uint32_t geomIndex, geom::Location loc) const
return elt[geomIndex].allPositionsEqual(loc);
/*public*/
INLINE void
-Label::toLine(int geomIndex)
+Label::toLine(uint32_t geomIndex)
if(elt[geomIndex].isArea()) {
elt[geomIndex] = TopologyLocation(elt[geomIndex].getLocations()[0]);
index 046f08f..f9e9664 100644
- bool isEqualOnSide(const TopologyLocation& le, int locIndex) const;
+ bool isEqualOnSide(const TopologyLocation& le, std::size_t locIndex) const;
index 2dd2677..55af297 100644
/*public*/
INLINE bool
-TopologyLocation::isEqualOnSide(const TopologyLocation& le, int locIndex) const
+TopologyLocation::isEqualOnSide(const TopologyLocation& le, std::size_t locIndex) const
diff --git a/src/algorithm/LineIntersector.cpp b/src/algorithm/LineIntersector.cpp
index 6f9d101..388431d 100644
--- a/src/algorithm/LineIntersector.cpp
+++ b/src/algorithm/LineIntersector.cpp
@@ -256,7 +256,7 @@ LineIntersector::interpolateZ(const Coordinate& p,
//double zgap = fabs(p2.z - p1.z);
double zgap = p2.z - p1.z;
- if(! zgap) {
+ if(zgap == 0.0) {
#if GEOS_DEBUG
cerr << " no zgap, returning " << p2.z << endl;
#endif
@@ -471,7 +471,7 @@ LineIntersector::computeIntersect(const Coordinate& p1, const Coordinate& p2,
/*private*/
-int
+uint8_t
LineIntersector::computeCollinearIntersection(const Coordinate& p1, const Coordinate& p2,
const Coordinate& q1, const Coordinate& q2)
index 6fc701c..e490e4b 100644
@@ -65,8 +65,8 @@ Orientation::isCCW(const geom::CoordinateSequence* ring)
geom::Coordinate upLowPt;
upLowPt.setNull();
// const geom::Coordinate& upLowPt = nullptr;
- int iUpHi = 0;
- for (int i = 1; i <= nPts; i++) {
+ uint32_t iUpHi = 0;
+ for (uint32_t i = 1; i <= nPts; i++) {
double py = ring->getY(i);
* If segment is upwards and endpoint is higher, record it
@@ -88,13 +88,13 @@ Orientation::isCCW(const geom::CoordinateSequence* ring)
* (e.g. a falling segment).
* This must exist since ring is not flat.
- int iDownLow = iUpHi;
+ uint32_t iDownLow = iUpHi;
do {
iDownLow = (iDownLow + 1) % nPts;
} while (iDownLow != iUpHi && ring->getY(iDownLow) == upHiPt.y );
const geom::Coordinate& downLowPt = ring->getAt(iDownLow);
- int iDownHi = iDownLow > 0 ? iDownLow - 1 : nPts - 1;
+ uint32_t iDownHi = iDownLow > 0 ? iDownLow - 1 : nPts - 1;
const geom::Coordinate& downHiPt = ring->getAt(iDownHi);
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index 7fa2ea2..08f14e1 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -121,8 +121,8 @@ ensure_equals_geometry(T1 const* lhs, T2 const* rhs)
assert(0 != lhs);
assert(0 != rhs);
assert(!"DIFFERENT TYPES ARE NOT OF THE SAME STRUCTURE");
+ ensure(lhs != 0 && rhs != 0 && lhs != rhs);
template <typename T>
@@ -265,7 +265,7 @@ ensure_equals_dims(const geos::geom::CoordinateSequence *seq1,
else
- if ( tolerance )
+ if ( tolerance > 0.0 )
ensure_distance( val1, val2, tolerance );
else
ensure_equals( val1, val2 );
Summary of changes:
CMakeLists.txt | 15 ++++++
.../algorithm/UnaryUnionSegmentsPerfTest.cpp | 4 +-
benchmarks/capi/GEOSPreparedContainsPerfTest.cpp | 2 +-
configure.ac | 23 ++++++---
include/geos/algorithm/LineIntersector.h | 4 +-
include/geos/geomgraph/EdgeEndStar.h | 6 +--
include/geos/geomgraph/Label.h | 30 +++++------
include/geos/geomgraph/Label.inl | 58 +++++++++++-----------
include/geos/geomgraph/TopologyLocation.h | 2 +-
include/geos/geomgraph/TopologyLocation.inl | 2 +-
include/geos/util/GeometricShapeFactory.h | 4 +-
src/algorithm/LineIntersector.cpp | 4 +-
src/algorithm/Orientation.cpp | 13 ++---
src/geom/Polygon.cpp | 2 +-
src/geomgraph/Depth.cpp | 4 +-
src/geomgraph/DirectedEdge.cpp | 2 +-
src/geomgraph/DirectedEdgeStar.cpp | 2 +-
src/geomgraph/EdgeEndStar.cpp | 8 +--
src/util/GeometricShapeFactory.cpp | 4 +-
tests/bigtest/GeometryTestFactory.cpp | 4 +-
tests/bigtest/bigtest.h | 4 +-
tests/unit/utility.h | 4 +-
22 files changed, 114 insertions(+), 87 deletions(-)
hooks/post-receive
More information about the geos-commits
