[geos-commits] [SCM] GEOS branch master updated. 693c1aa855263198d42153da0d12f56b2b7a6991
git at osgeo.org
git at osgeo.org
Wed Dec 9 13:28:57 PST 2020
the project "GEOS".
via 693c1aa855263198d42153da0d12f56b2b7a6991 (commit)
from cb186cda2f802094d5656f467b86c2b50f357576 (commit)
revisions in full, below.
commit 693c1aa855263198d42153da0d12f56b2b7a6991
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Dec 9 13:28:46 2020 -0800
Correctly return isEmpty for hand-built empty points, closes #1049
diff --git a/src/geom/Point.cpp b/src/geom/Point.cpp
index 0b2e454..d439375 100644
--- a/src/geom/Point.cpp
+++ b/src/geom/Point.cpp
@@ -68,6 +68,8 @@ Point::Point(CoordinateSequence* newCoords, const GeometryFactory* factory)
} else {
empty2d = true;
Point::Point(const Coordinate & c, const GeometryFactory* factory) :
@@ -103,7 +105,12 @@ Point::getNumPoints() const
bool
Point::isEmpty() const
- return empty2d || empty3d;
+ if (empty2d || empty3d) return true;
+ const Coordinate& c = coordinates.getAt(0);
+ if (std::isnan(c.x) && std::isnan(c.y))
+ return true;
+ else
+ return false;
bool
diff --git a/tests/unit/geom/PointTest.cpp b/tests/unit/geom/PointTest.cpp
index 3880eb8..d473cb5 100644
--- a/tests/unit/geom/PointTest.cpp
+++ b/tests/unit/geom/PointTest.cpp
@@ -12,6 +12,7 @@
#include <geos/geom/PrecisionModel.h>
#include <geos/io/WKTReader.h>
#include <geos/util/IllegalArgumentException.h>
+#include <geos/constants.h>
// std
#include <memory>
#include <string>
@@ -579,5 +580,25 @@ void object::test<45>
ensure_equals(pt3->getCoordinateDimension(), 3);
+// Test hand-build POINT(NaN NaN)
+template<>
+template<>
+void object::test<46>
+ using geos::geom::Coordinate;
+ using geos::geom::CoordinateArraySequence;
+ CoordinateArraySequence* coords = new CoordinateArraySequence();
+ ensure(coords != nullptr);
+ coords->add(Coordinate(geos::DoubleNotANumber, geos::DoubleNotANumber));
+ PointAutoPtr point(factory_->createPoint(coords));
+ ensure("point->isEmpty()", point->isEmpty());
+ ensure("point->getCoordinateDimension() == 2", point->getCoordinateDimension() == 2);
} // namespace tut
diff --git a/tests/unit/io/WKTWriterTest.cpp b/tests/unit/io/WKTWriterTest.cpp
index db9d97d..1718fa5 100644
--- a/tests/unit/io/WKTWriterTest.cpp
+++ b/tests/unit/io/WKTWriterTest.cpp
@@ -8,8 +8,11 @@
#include <geos/io/WKTWriter.h>
#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Point.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/GeometryCollection.h>
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateArraySequence.h>
// std
#include <sstream>
#include <string>
@@ -182,5 +185,28 @@ void object::test<6>
ensure_equals(result, std::string("MULTIPOINT (EMPTY, 1 2)"));
+template<>
+template<>
+void object::test<7>
+ using geos::geom::Point;
+ PrecisionModel pm;
+ auto factory_ = GeometryFactory::create(&pm);
+ std::unique_ptr<Point> point(factory_->createPoint(coords));
+ std::string result = wktwriter.write(point.get());
+ ensure_equals(result, std::string("POINT EMPTY"));
} // namespace tut
Summary of changes:
src/geom/Point.cpp | 9 ++++++++-
tests/unit/geom/PointTest.cpp | 21 +++++++++++++++++++++
tests/unit/io/WKTWriterTest.cpp | 26 ++++++++++++++++++++++++++
3 files changed, 55 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
