[geos-commits] [SCM] GEOS branch 3.9 updated. 5761324497a11456f69056eb08f782f02661a62c
git at osgeo.org
git at osgeo.org
Thu Dec 10 07:30:23 PST 2020
the project "GEOS".
The branch, 3.9 has been updated
via 5761324497a11456f69056eb08f782f02661a62c (commit)
from 0a17e663f526f79caa81b421911ce419729b68e8 (commit)
revisions in full, below.
commit 5761324497a11456f69056eb08f782f02661a62c
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Dec 10 16:25:34 2020 +0100
Add tests for relate with empty components (#1085)
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index d0ec2df..4a13513 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -166,6 +166,7 @@ SAFE_XMLTESTS= \
$(srcdir)/tests/issue/issue-geos-990.xml \
$(srcdir)/tests/issue/issue-geos-994.xml \
$(srcdir)/tests/issue/issue-geos-1018.xml \
+ $(srcdir)/tests/issue/issue-geos-1085.xml \
$(srcdir)/tests/validate/TestRelateAA-big.xml \
$(srcdir)/tests/validate/TestRelateAA.xml \
$(srcdir)/tests/validate/TestRelateAC.xml \
diff --git a/tests/xmltester/tests/issue/issue-geos-1085.xml b/tests/xmltester/tests/issue/issue-geos-1085.xml
new file mode 100644
index 0000000..00c180d
--- /dev/null
+++ b/tests/xmltester/tests/issue/issue-geos-1085.xml
@@ -0,0 +1,19 @@
+<run>
+ <precisionModel />
+<case>
+<desc>
+Empty component in multilinestring
+See https://trac.osgeo.org/geos/ticket/1085
+</desc>
+ <a>
+ LINESTRING(0 0, 10 0)
+ </a>
+ <b>
+ MULTILINESTRING((0 10,10 -10),EMPTY)
+ </b>
+<test><op name="relate" arg3="0F1FF0102" arg1="A" arg2="B">true </op> </test>
+</case>
+</run>
Summary of changes:
tests/xmltester/Makefile.am | 1 +
tests/xmltester/tests/issue/issue-geos-1085.xml | 19 +++++++++++++++++++
2 files changed, 20 insertions(+)
create mode 100644 tests/xmltester/tests/issue/issue-geos-1085.xml
hooks/post-receive
More information about the geos-commits
