[geos-commits] [SCM] GEOS branch 3.9 updated. cb92d99ca9dfc5400638b4029310b613c03949b1
git at osgeo.org
git at osgeo.org
Thu Dec 10 10:26:40 PST 2020
the project "GEOS".
The branch, 3.9 has been updated
via cb92d99ca9dfc5400638b4029310b613c03949b1 (commit)
from 5761324497a11456f69056eb08f782f02661a62c (commit)
revisions in full, below.
commit cb92d99ca9dfc5400638b4029310b613c03949b1
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Thu Dec 10 10:26:04 2020 -0800
Remove compile-time switches to disable OverlayNG, leaving the defines in place in case developers have a need to flip the switch
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 60cb109..ac53e3c 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -155,39 +155,44 @@ target_compile_features(geos_cxx_flags INTERFACE cxx_std_11)
# Add flags to prevent 'fused multiply-add' operations on targets (ARM64)
-# that allow it, as it breaks calculations in DD.cpp.
+# that allow it, as it breaks calculations in DD.cpp.
# TODO: Replace DD calculations with 'long float' where target supports
# true long float, and remove other cases where FMA causes regression
# failures.
# https://gcc.gnu.org/bugzilla/show_bug.cgi?id=98207
-target_compile_options(geos_cxx_flags INTERFACE
+target_compile_options(geos_cxx_flags INTERFACE
"$<$<CXX_COMPILER_ID:Clang>:-ffp-contract=off>"
"$<$<CXX_COMPILER_ID:GNU>:-ffp-contract=off>"
"$<$<CXX_COMPILER_ID:MSVC>:/fp:precise>"
# Target geos_cxx_flags: common compilation flags
option(DISABLE_GEOS_INLINE "Disable inlining" OFF)
if(NOT DISABLE_GEOS_INLINE)
target_compile_definitions(geos_cxx_flags INTERFACE GEOS_INLINE)
+ message(STATUS
+ "GEOS: Function inlining ENABLED")
else()
message(STATUS
- "GEOS: DISABLING inlining of small functions")
+ "GEOS: Function inlining DISABLED")
endif()
# Target geos_cxx_flags: overlayng code
-option(DISABLE_OVERLAYNG "Disable overlayng algorithms" OFF)
-if(DISABLE_OVERLAYNG)
- target_compile_definitions(geos_cxx_flags INTERFACE DISABLE_OVERLAYNG)
- message(STATUS
- "GEOS: DISABLING overlayng algorithms")
-endif()
+#option(DISABLE_OVERLAYNG "Disable overlayng algorithms" OFF)
+#if(DISABLE_OVERLAYNG)
+# target_compile_definitions(geos_cxx_flags INTERFACE DISABLE_OVERLAYNG)
+# message(STATUS
+# "GEOS: OverlayNG DISABLED")
+#else()
+# message(STATUS
+# "GEOS: OverlayNG ENABLED")
+#endif()
# Target geos_developer_cxx_flags: developer mode compilation flags
@@ -196,7 +201,7 @@ endif()
add_library(geos_developer_cxx_flags INTERFACE)
if(GEOS_BUILD_DEVELOPER)
- message(STATUS "GEOS: Developer mode enabled")
+ message(STATUS "GEOS: Developer mode ENABLED")
endif()
# geos_cxx_flags inherits properties from geos_developer_cxx_flags when
diff --git a/configure.ac b/configure.ac
index 9d0b772..1788345 100644
--- a/configure.ac
+++ b/configure.ac
@@ -156,22 +156,22 @@ fi
dnl --------------------------------------------------------------------
dnl - check whether user has requested overlayng
-AC_ARG_ENABLE([overlayng],
- [ --disable-overlayng Disable use of new overlay],
- [case "${enableval}" in
- yes) use_overlayng=true ;;
- no) use_overlayng=false ;;
- *) AC_MSG_ERROR(bad value ${enableval} for --disable-overlayng) ;;
- esac],
- [use_overlayng=true]
-if test x"$use_overlayng" = xtrue; then
- OVERLAYNG_FLAGS=""
-else
- OVERLAYNG_FLAGS="-DDISABLE_OVERLAYNG"
-fi
+dnl
+dnl AC_ARG_ENABLE([overlayng],
+dnl [ --disable-overlayng Disable use of new overlay],
+dnl [case "${enableval}" in
+dnl yes) use_overlayng=true ;;
+dnl no) use_overlayng=false ;;
+dnl *) AC_MSG_ERROR(bad value ${enableval} for --disable-overlayng) ;;
+dnl esac],
+dnl [use_overlayng=true]
+dnl )
+dnl
+dnl if test x"$use_overlayng" = xtrue; then
+dnl OVERLAYNG_FLAGS=""
+dnl else
+dnl OVERLAYNG_FLAGS="-DDISABLE_OVERLAYNG"
+dnl fi
dnl - Append default C++ and C flags
@@ -223,7 +223,7 @@ NUMERICFLAGS="$NUMERICFLAGS -ffp-contract=off"
dnl -----------------------------------------------------------------------------
HUSHWARNING="-DUSE_UNSTABLE_GEOS_CPP_API"
-DEFAULTFLAGS="${WARNFLAGS} ${NUMERICFLAGS} ${HUSHWARNING} ${OVERLAYNG_FLAGS}"
+DEFAULTFLAGS="${WARNFLAGS} ${NUMERICFLAGS} ${HUSHWARNING}"
AM_CXXFLAGS="${AM_CXXFLAGS} ${DEFAULTFLAGS}"
AM_CFLAGS="${AM_CFLAGS} ${DEFAULTFLAGS}"
@@ -283,17 +283,6 @@ dnl AM_CXXFLAGS="$AM_CXXFLAGS -Wnon-virtual-dtor -Woverloaded-virtual"
esac
-dnl --------------------------------------------------------------------
-dnl - check for boost
-dnl -- AX_BOOST(1.32)
-dnl -- if test "x$ax_cv_boost_unit_test_framework" = "xyes"; then
-dnl -- use_boost_utf=yes
-dnl -- else
-dnl -- use_boost_utf=no
-dnl -- fi
-dnl -- AM_CONDITIONAL(ENABLE_BOOST_UTF, [test "x$use_boost_utf" = "xyes"])
dnl things to substitute in output ----------------------------------------
AC_SUBST(VERSION)
@@ -435,7 +424,9 @@ AC_OUTPUT([
tools/astyle/Makefile
-dnl -- echo "---------------------------------------"
-dnl -- echo "Boost UTF: $use_boost_utf"
-dnl -- echo "OverlayNG: $use_overlayng"
+dnl AC_MSG_RESULT([ ------------ GEOS Build ------------ ])
+dnl AC_MSG_RESULT([ Version: ${VERSION}])
+dnl AC_MSG_RESULT([ Inlining: ${enable_inline}])
+dnl AC_MSG_RESULT([ ------------------------------------ ])
Summary of changes:
CMakeLists.txt | 27 ++++++++++++++++-----------
configure.ac | 55 +++++++++++++++++++++++--------------------------------
2 files changed, 39 insertions(+), 43 deletions(-)
hooks/post-receive
More information about the geos-commits
