[geos-commits] [SCM] GEOS branch 3.8 updated. 459c10cf7ca0a115e85412c8e80a9e565b3db837
git at osgeo.org
git at osgeo.org
Thu Dec 10 13:36:28 PST 2020
the project "GEOS".
The branch, 3.8 has been updated
via 459c10cf7ca0a115e85412c8e80a9e565b3db837 (commit)
from 6c8b0ec44fb21237c18b895b45ccfb1f9e745ad3 (commit)
revisions in full, below.
commit 459c10cf7ca0a115e85412c8e80a9e565b3db837
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Dec 10 22:36:11 2020 +0100
Also add the MakeValidTest.cpp ...
diff --git a/tests/unit/operation/valid/MakeValidTest.cpp b/tests/unit/operation/valid/MakeValidTest.cpp
new file mode 100644
index 0000000..53bc8ec
--- /dev/null
+++ b/tests/unit/operation/valid/MakeValidTest.cpp
@@ -0,0 +1,108 @@
+#include <tut/tut.hpp>
+// geos
+#include <geos/constants.h> // for std::isnan
+#include <geos/geom/Coordinate.h>
+#include <geos/geom/CoordinateSequenceFactory.h>
+#include <geos/geom/Polygon.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/operation/valid/MakeValid.h>
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
+// std
+#include <cmath>
+#include <string>
+#include <vector>
+#include <fstream>
+using namespace geos::geom;
+using namespace geos::operation::valid;
+namespace tut {
+// Test Group
+struct test_makevalid_data {
+ test_makevalid_data() {}
+typedef test_group<test_makevalid_data> group;
+typedef group::object object;
+group test_makevalid_group("geos::operation::valid::MakeValid");
+// Test Cases
+// https://github.com/libgeos/geos/issues/265
+template<>
+template<>
+void object::test<1>
+ std::vector<Coordinate> v;
+ v.emplace_back(2.22, 2.28);
+ v.emplace_back(7.67, 2.06);
+ v.emplace_back(10.98, 7.70);
+ v.emplace_back(9.39, 5.00);
+ v.emplace_back(7.96, 7.12);
+ v.emplace_back(6.77, 5.16);
+ v.emplace_back(7.43, 6.24);
+ v.emplace_back(3.70, 7.22);
+ v.emplace_back(5.72, 5.77);
+ v.emplace_back(4.18, 10.74);
+ v.emplace_back(2.20, 6.83);
+ auto gf = GeometryFactory::getDefaultInstance();
+ auto cs = gf->getCoordinateSequenceFactory()->create(std::move(v));
+ auto lr = gf->createLinearRing(std::move(cs));
+ auto errplyg = gf->createPolygon(std::move(lr));
+ ensure(!errplyg->isValid());
+ MakeValid mkvalid;
+ auto validGeom = mkvalid.build(errplyg.get());
+ ensure(validGeom->isValid());
+// template<>
+// template<>
+// void object::test<2>
+// std::ifstream ifs("GoesBathymetryBug.txt");
+// std::string content((std::istreambuf_iterator<char>(ifs)),
+// (std::istreambuf_iterator<char>()));
+// geos::io::WKTReader reader;
+// auto geom(reader.read(content));
+// // auto gf = GeometryFactory::getDefaultInstance();
+// // auto cs = gf->getCoordinateSequenceFactory()->create(std::move(v));
+// // auto lr = gf->createLinearRing(std::move(cs));
+// // auto errplyg = gf->createPolygon(std::move(lr));
+// // ensure(!errplyg->isValid());
+// MakeValid mkvalid;
+// auto validGeom = mkvalid.build(geom.get());
+// ensure("MakeValid output is not valid", validGeom->isValid());
+// geos::io::WKTWriter writer;
+// writer.setOutputDimension(2);
+// writer.setTrim(true);
+// std::string result = writer.write(validGeom.get());
+// std::cout << result << std::endl;
+} // namespace tut
Summary of changes:
tests/unit/operation/valid/MakeValidTest.cpp | 108 +++++++++++++++++++++++++++
1 file changed, 108 insertions(+)
create mode 100644 tests/unit/operation/valid/MakeValidTest.cpp
hooks/post-receive
More information about the geos-commits
