[geos-commits] [SCM] GEOS branch master updated. 2d2963299472013861e184ca94930b632903a849
git at osgeo.org
git at osgeo.org
Mon Dec 14 19:47:04 PST 2020
the project "GEOS".
via 2d2963299472013861e184ca94930b632903a849 (commit)
from 908b31cb15b8b3138dec2e2ef367330ddfbf7920 (commit)
revisions in full, below.
commit 2d2963299472013861e184ca94930b632903a849
Author: Daniel Baston <dbaston at gmail.com>
Date: Fri Dec 11 20:09:08 2020 -0500
Fix some typos
diff --git a/doc/example.cpp b/doc/example.cpp
index 46dc0d9..a011cfb 100644
--- a/doc/example.cpp
+++ b/doc/example.cpp
@@ -253,7 +253,7 @@ create_ushaped_linestring(double xoffset, double yoffset, double side)
// This function will create a LinearRing
-// geometry rapresenting a square with the given origin
+// geometry representing a square with the given origin
// and side
LinearRing*
create_square_linearring(double xoffset, double yoffset, double side)
@@ -281,7 +281,7 @@ create_square_linearring(double xoffset, double yoffset, double side)
// This function will create a Polygon
// and side and with a central hole 1/3 sided.
Polygon*
create_square_polygon(double xoffset, double yoffset, double side)
@@ -1001,7 +1001,7 @@ do_all()
// DIFFERENCE
- // Compute difference of adhiacent geometries
+ // Compute difference of adjacent geometries
newgeoms = new std::vector<const Geometry*>;
for(unsigned int i = 0; i < geoms->size() - 1; i++) {
const Geometry* g1 = (*geoms)[i];
@@ -1034,7 +1034,7 @@ do_all()
// SYMMETRIC DIFFERENCE
- // Compute symmetric difference of adhiacent geometries
+ // Compute symmetric difference of adjacent geometries
diff --git a/include/geos/algorithm/Angle.h b/include/geos/algorithm/Angle.h
index c8aec27..29e5e23 100644
--- a/include/geos/algorithm/Angle.h
+++ b/include/geos/algorithm/Angle.h
@@ -93,7 +93,7 @@ public:
/// An angle is acute if it is less than 90 degrees.
- /// Note: this implementation is not precise (determistic) for
+ /// Note: this implementation is not precise (deterministic) for
/// angles very close to 90 degrees.
/// @param p0 an endpoint of the angle
@@ -108,7 +108,7 @@ public:
/// An angle is obtuse if it is greater than 90 degrees.
diff --git a/include/geos/geomgraph/Depth.h b/include/geos/geomgraph/Depth.h
index 2e12545..736432f 100644
--- a/include/geos/geomgraph/Depth.h
+++ b/include/geos/geomgraph/Depth.h
@@ -43,7 +43,7 @@ class GEOS_DLL Depth {
public:
static int depthAtLocation(geom::Location location);
Depth();
- virtual ~Depth() = default; // FIXME: shoudn't be virtual!
+ virtual ~Depth() = default; // FIXME: shouldn't be virtual!
int getDepth(int geomIndex, int posIndex) const;
void setDepth(int geomIndex, int posIndex, int depthValue);
geom::Location getLocation(int geomIndex, int posIndex) const;
diff --git a/include/geos/geomgraph/EdgeIntersection.h b/include/geos/geomgraph/EdgeIntersection.h
index 7123c66..b215e84 100644
--- a/include/geos/geomgraph/EdgeIntersection.h
+++ b/include/geos/geomgraph/EdgeIntersection.h
@@ -116,7 +116,7 @@ operator< (const EdgeIntersection& ei1, const EdgeIntersection& ei2)
// TODO: check if the Coordinate matches, or this will
- // be a robustness issue in computin distance
+ // be a robustness issue in computing distance
// See http://trac.osgeo.org/geos/ticket/350
return false;
diff --git a/include/geos/noding/MCIndexNoder.inl b/include/geos/noding/MCIndexNoder.inl
index 5883c4f..0432777 100644
--- a/include/geos/noding/MCIndexNoder.inl
+++ b/include/geos/noding/MCIndexNoder.inl
@@ -37,7 +37,7 @@ MCIndexNoder::getIndex()
INLINE std::vector<SegmentString*>*
MCIndexNoder::getNodedSubstrings() const
- assert(nodedSegStrings); // must have colled computeNodes before!
+ assert(nodedSegStrings); // must have called computeNodes before!
return NodedSegmentString::getNodedSubstrings(*nodedSegStrings);
diff --git a/include/geos/noding/snapround/MCIndexSnapRounder.h b/include/geos/noding/snapround/MCIndexSnapRounder.h
index e8da0d8..8a55620 100644
--- a/include/geos/noding/snapround/MCIndexSnapRounder.h
+++ b/include/geos/noding/snapround/MCIndexSnapRounder.h
@@ -23,7 +23,7 @@
#include <geos/noding/Noder.h> // for inheritance
#include <geos/noding/NodedSegmentString.h> // for inlines
-#include <geos/noding/snapround/MCIndexPointSnapper.h> // for inines
+#include <geos/noding/snapround/MCIndexPointSnapper.h> // for inlines
#include <geos/algorithm/LineIntersector.h> // for composition
#include <geos/geom/Coordinate.h> // for use in vector
#include <geos/geom/PrecisionModel.h> // for inlines
@@ -71,7 +71,7 @@ namespace snapround { // geos::noding::snapround
* It will function with non-integer precision models, but the
* results are not 100% guaranteed to be correctly noded.
-class GEOS_DLL MCIndexSnapRounder: public Noder { // implments Noder
+class GEOS_DLL MCIndexSnapRounder: public Noder { // implements Noder
public:
diff --git a/include/geos/operation/buffer/BufferBuilder.h b/include/geos/operation/buffer/BufferBuilder.h
index ded0ba7..e1ffe36 100644
--- a/include/geos/operation/buffer/BufferBuilder.h
+++ b/include/geos/operation/buffer/BufferBuilder.h
@@ -198,7 +198,7 @@ private:
* If so, the edge is not inserted, but its label is merged
* with the existing edge.
- * The function takes responsability of releasing the Edge parameter
+ * The function takes responsibility of releasing the Edge parameter
* memory when appropriate.
void insertUniqueEdge(geomgraph::Edge* e);
diff --git a/include/geos/operation/buffer/BufferInputLineSimplifier.h b/include/geos/operation/buffer/BufferInputLineSimplifier.h
index 3c19047..f819292 100644
--- a/include/geos/operation/buffer/BufferInputLineSimplifier.h
+++ b/include/geos/operation/buffer/BufferInputLineSimplifier.h
@@ -134,7 +134,7 @@ private:
* Checks for shallowness over a sample of points in the given section.
- * This helps prevents the siplification from incrementally
+ * This helps prevents the simplification from incrementally
* "skipping" over points which are in fact non-shallow.
* @param p0 start coordinate of section
diff --git a/include/geos/operation/buffer/OffsetCurveSetBuilder.h b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
index abe99d3..40f497b 100644
--- a/include/geos/operation/buffer/OffsetCurveSetBuilder.h
+++ b/include/geos/operation/buffer/OffsetCurveSetBuilder.h
@@ -73,7 +73,7 @@ class GEOS_DLL OffsetCurveSetBuilder {
private:
// To keep track of newly-created Labels.
- // Labels will be relesed by object dtor
+ // Labels will be released by object dtor
std::vector<geomgraph::Label*> newLabels;
const geom::Geometry& inputGeom;
diff --git a/include/geos/operation/union/CascadedPolygonUnion.h b/include/geos/operation/union/CascadedPolygonUnion.h
index bb7db11..95e907e 100644
--- a/include/geos/operation/union/CascadedPolygonUnion.h
+++ b/include/geos/operation/union/CascadedPolygonUnion.h
@@ -154,7 +154,7 @@ public:
/** \brief
* Computes the union of a set of polygonal [Geometrys](@ref geom::Geometry).
- * @tparam T an iterator yelding something castable to const Polygon *
+ * @tparam T an iterator yielding something castable to const Polygon *
* @param start start iterator
* @param end end iterator
* @param unionStrategy strategy to apply
diff --git a/src/geom/Envelope.cpp b/src/geom/Envelope.cpp
index f5cd212..5c615fb 100644
--- a/src/geom/Envelope.cpp
+++ b/src/geom/Envelope.cpp
@@ -122,7 +122,7 @@ Envelope::Envelope(const std::string& str)
// now split apart the string on : and , characters
std::vector<std::string> values = split(coordString, ":,");
- // create a new envelopet
+ // create a new envelope
init(strtod(values[0].c_str(), nullptr),
strtod(values[1].c_str(), nullptr),
strtod(values[2].c_str(), nullptr),
diff --git a/src/geom/HeuristicOverlay.cpp b/src/geom/HeuristicOverlay.cpp
index 04c4041..10d5cc3 100644
--- a/src/geom/HeuristicOverlay.cpp
+++ b/src/geom/HeuristicOverlay.cpp
@@ -381,7 +381,7 @@ HeuristicOverlay(const Geometry* g0, const Geometry* g1, int opCode)
* other nodes and lines, leaving all the rest undisturbed, for a very
* clean result, if it manages to create one.
* If a result is found with no exception, return.
-* 3. Peform overlay operation using a PrecisionModel(scale), which
+* 3. Perform overlay operation using a PrecisionModel(scale), which
* uses a SnapRoundingNoder. Every vertex will be noded to the snapping
* grid, resulting in a modified geometry. The SnapRoundingNoder approach
* reliably produces results, assuming valid inputs.
diff --git a/src/geom/prep/AbstractPreparedPolygonContains.cpp b/src/geom/prep/AbstractPreparedPolygonContains.cpp
index 314a3bd..ef5537e 100644
--- a/src/geom/prep/AbstractPreparedPolygonContains.cpp
+++ b/src/geom/prep/AbstractPreparedPolygonContains.cpp
@@ -124,7 +124,7 @@ AbstractPreparedPolygonContains::eval(const geom::Geometry* geom)
// Check if there is any intersection between the line segments
// in target and test.
- // In some important cases, finding a proper interesection implies that the
+ // In some important cases, finding a proper intersection implies that the
// test geometry is NOT contained.
// These cases are:
// - If the test geometry is polygonal
@@ -152,7 +152,7 @@ AbstractPreparedPolygonContains::eval(const geom::Geometry* geom)
// (If non-proper (vertex) intersections ARE found, this may indicate
// a situation where two shells touch at a single vertex, which admits
- // the case where a line could cross between the shells and still be wholely contained in them.
+ // the case where a line could cross between the shells and still be wholly contained in them.
if(hasSegmentIntersection && !hasNonProperIntersection) {
return false;
@@ -182,7 +182,7 @@ AbstractPreparedPolygonContains::eval(const geom::Geometry* geom)
bool AbstractPreparedPolygonContains::evalPointTestGeom(const Geometry *geom, Location outermostLoc) {
- // If we had a point on the ourside of the polygon,
+ // If we had a point on the outside of the polygon,
// we aren't covered or contained.
if (outermostLoc == Location::EXTERIOR) {
return false;
diff --git a/src/geomgraph/Edge.cpp b/src/geomgraph/Edge.cpp
index 1638bf2..eff7ea7 100644
--- a/src/geomgraph/Edge.cpp
+++ b/src/geomgraph/Edge.cpp
@@ -269,8 +269,8 @@ Edge::print() const
return ss.str();
-// Dunno how to implemente this in terms of operator<<
std::string
+// Dunno how to implement this in terms of operator<<
Edge::printReverse() const
testInvariant();
diff --git a/src/geomgraph/GeometryGraph.cpp b/src/geomgraph/GeometryGraph.cpp
index 1d82492..2d7d824 100644
--- a/src/geomgraph/GeometryGraph.cpp
+++ b/src/geomgraph/GeometryGraph.cpp
@@ -130,7 +130,7 @@ GeometryGraph::getBoundaryPoints()
if(! boundaryPoints.get()) {
- // Collection will be destroied by GeometryGraph dtor
+ // Collection will be destroyed by GeometryGraph dtor
std::vector<Node*>* coll = getBoundaryNodes();
boundaryPoints.reset(new CoordinateArraySequence(coll->size()));
std::size_t i = 0;
diff --git a/src/geomgraph/index/MonotoneChainIndexer.cpp b/src/geomgraph/index/MonotoneChainIndexer.cpp
index d627d93..9cc48c7 100644
--- a/src/geomgraph/index/MonotoneChainIndexer.cpp
+++ b/src/geomgraph/index/MonotoneChainIndexer.cpp
@@ -69,4 +69,4 @@ MonotoneChainIndexer::findChainEnd(const CoordinateSequence* pts, std::size_t st
} // namespace geos.geomgraph.index
-} // namespage geos
+} // namespace geos
diff --git a/src/index/strtree/STRtree.cpp b/src/index/strtree/STRtree.cpp
index 5a6df0b..0043de5 100644
--- a/src/index/strtree/STRtree.cpp
+++ b/src/index/strtree/STRtree.cpp
@@ -374,7 +374,7 @@ STRtree::insert(const Envelope* itemEnv, void* item)
// then a is less than c,
// and so on.
-// For some very low values, this predicate does not fulfill this requiremnet,
+// For some very low values, this predicate does not fulfill this requirement,
// NOTE - strk:
// It seems that the '<' comparison here gives unstable results.
@@ -384,7 +384,7 @@ STRtree::insert(const Envelope* itemEnv, void* item)
// NOTE - mloskot:
// This comparison does not answer if a is "lower" than b
-// what is required for sorting. This comparison only answeres
+// what is required for sorting. This comparison only answers
// if a and b are "almost the same" or different
/*NOTE - cfis
diff --git a/src/noding/MCIndexNoder.cpp b/src/noding/MCIndexNoder.cpp
index 12a8a5c..7db17b0 100644
--- a/src/noding/MCIndexNoder.cpp
+++ b/src/noding/MCIndexNoder.cpp
@@ -102,7 +102,7 @@ MCIndexNoder::add(SegmentString* segStr)
std::vector<std::unique_ptr<MonotoneChain>> segChains;
- // segChains will contain nelwy allocated MonotoneChain objects
+ // segChains will contain newly allocated MonotoneChain objects
MonotoneChainBuilder::getChains(segStr->getCoordinates(),
segStr, segChains);
diff --git a/src/operation/buffer/BufferBuilder.cpp b/src/operation/buffer/BufferBuilder.cpp
index 514f219..404e5e2 100644
--- a/src/operation/buffer/BufferBuilder.cpp
+++ b/src/operation/buffer/BufferBuilder.cpp
@@ -161,7 +161,7 @@ BufferBuilder::bufferLineSingleSided(const Geometry* g, double distance,
std::unique_ptr<Geometry> buf;
// This is a (temp?) hack to workaround the fact that
- // BufferBuilder BufferParamaters are immutable after
+ // BufferBuilder BufferParameters are immutable after
// construction, while we want to force the end cap
// style to FLAT for single-sided buffering
@@ -268,7 +268,7 @@ BufferBuilder::bufferLineSingleSided(const Geometry* g, double distance,
// included.
// Let's try and estimate a more accurate bound instead of just assuming
- // 98%. With 98%, the episilon grows as the buffer distance grows,
+ // 98%. With 98%, the epsilon grows as the buffer distance grows,
// so that at large distance, artifacts may skip through this filter
// Let the length of the line play a factor in the distance, which is still
// going to be bounded by 98%. Take 10% of the length of the line from the buffer distance
@@ -448,7 +448,7 @@ BufferBuilder::buffer(const Geometry* g, double distance)
GEOS_CHECK_FOR_INTERRUPTS();
- // scope for earlier PolygonBuilder cleanupt
+ // scope for earlier PolygonBuilder cleanup
PolygonBuilder polyBuilder(geomFact);
buildSubgraphs(subgraphList, polyBuilder);
diff --git a/src/operation/buffer/SubgraphDepthLocater.cpp b/src/operation/buffer/SubgraphDepthLocater.cpp
index 3017a1a..bed29c6 100644
--- a/src/operation/buffer/SubgraphDepthLocater.cpp
+++ b/src/operation/buffer/SubgraphDepthLocater.cpp
@@ -238,7 +238,7 @@ SubgraphDepthLocater::findStabbedSegments(
// It seems that LineSegment is *very* slow... undef this
// to see yourself
// LineSegment has been refactored to be mostly inline, still
-// it makes copies of the given coordinates, while the 'non-LineSemgent'
+// it makes copies of the given coordinates, while the 'non-LineSegment'
// based code below uses pointers instead. I'll kip the SKIP_LS
// defined until LineSegment switches to Coordinate pointers instead.
diff --git a/src/operation/predicate/RectangleContains.cpp b/src/operation/predicate/RectangleContains.cpp
index 99310bd..47e4d48 100644
--- a/src/operation/predicate/RectangleContains.cpp
+++ b/src/operation/predicate/RectangleContains.cpp
@@ -50,7 +50,7 @@ RectangleContains::contains(const Geometry& geom)
bool
RectangleContains::isContainedInBoundary(const Geometry& geom)
- // polygons can never be wholely contained in the boundary
+ // polygons can never be wholly contained in the boundary
if(dynamic_cast<const geom::Polygon*>(&geom)) {
return false;
@@ -140,7 +140,7 @@ RectangleContains::isLineSegmentContainedInBoundary(const Coordinate& p0,
* one of x and y are the same, but the other ordinate
* is not the same as a boundary ordinate
- * In either case, the segment is not wholely in the boundary
+ * In either case, the segment is not wholly in the boundary
return false;
diff --git a/src/operation/sharedpaths/SharedPathsOp.cpp b/src/operation/sharedpaths/SharedPathsOp.cpp
index d254b19..606f67c 100644
--- a/src/operation/sharedpaths/SharedPathsOp.cpp
+++ b/src/operation/sharedpaths/SharedPathsOp.cpp
@@ -112,7 +112,7 @@ SharedPathsOp::findLinearIntersections(PathList& to)
std::unique_ptr<Geometry> full(OverlayOp::overlayOp(
&_g1, &_g2, OverlayOp::opINTERSECTION));
- // NOTE: intersection of equal lines yelds splitted lines,
+ // NOTE: intersection of equal lines yields splitted lines,
// should we sew them back ?
for(std::size_t i = 0, n = full->getNumGeometries(); i < n; ++i) {
diff --git a/src/operation/union/OverlapUnion.cpp b/src/operation/union/OverlapUnion.cpp
index 1272e0f..ea4fb8c 100644
--- a/src/operation/union/OverlapUnion.cpp
+++ b/src/operation/union/OverlapUnion.cpp
@@ -214,7 +214,7 @@ containsProperly(const Envelope& env, const Coordinate& p0, const Coordinate& p1
return containsProperly(env, p0) && containsProperly(env, p1);
-/* privatef */
+/* private */
void
OverlapUnion::extractBorderSegments(const Geometry* geom, const Envelope& penv, std::vector<LineSegment>& psegs)
diff --git a/src/operation/union/UnaryUnionOp.cpp b/src/operation/union/UnaryUnionOp.cpp
index 1ad44d7..ba2f4d0 100644
--- a/src/operation/union/UnaryUnionOp.cpp
+++ b/src/operation/union/UnaryUnionOp.cpp
@@ -74,7 +74,7 @@ UnaryUnionOp::Union()
* For points and lines, only a single union operation is
- * required, since the OGC model allowings self-intersecting
+ * required, since the OGC model allows self-intersecting
* MultiPoint and MultiLineStrings.
* This is not the case for polygons, so Cascaded Union is required.
diff --git a/src/operation/valid/MakeValid.cpp b/src/operation/valid/MakeValid.cpp
index afe29db..06f5de4 100644
--- a/src/operation/valid/MakeValid.cpp
+++ b/src/operation/valid/MakeValid.cpp
@@ -240,7 +240,7 @@ static std::unique_ptr<geom::Geometry> MakeValidPoly(const geom::Geometry* geom)
auto new_area = geos::operation::polygonize::BuildArea().build(cut_edges.get());
assert(new_area); // never return nullptr, but exception
if( new_area->isEmpty() ) {
- /* no more rings can be build with thes edges */
+ /* no more rings can be built with these edges */
break;
diff --git a/src/planargraph/DirectedEdgeStar.cpp b/src/planargraph/DirectedEdgeStar.cpp
index 5de7442..9ee1ad3 100644
--- a/src/planargraph/DirectedEdgeStar.cpp
+++ b/src/planargraph/DirectedEdgeStar.cpp
@@ -79,7 +79,7 @@ DirectedEdgeStar::end() const
- * Returns the coordinate for the node at wich this star is based
+ * Returns the coordinate for the node at which this star is based
Coordinate&
DirectedEdgeStar::getCoordinate() const
diff --git a/src/precision/EnhancedPrecisionOp.cpp b/src/precision/EnhancedPrecisionOp.cpp
index 740584f..e025148 100644
--- a/src/precision/EnhancedPrecisionOp.cpp
+++ b/src/precision/EnhancedPrecisionOp.cpp
@@ -61,7 +61,7 @@ EnhancedPrecisionOp::intersection(
auto resultEP = cbo.intersection(geom0, geom1);
// check that result is a valid geometry after
- // the reshift to orginal precision
+ // the reshift to original precision
if(! resultEP->isValid()) {
#if GEOS_DEBUG
std::cerr << "Reduced operation result is invalid"
@@ -106,7 +106,7 @@ EnhancedPrecisionOp::Union(
auto resultEP = cbo.Union(geom0, geom1);
throw originalEx;
@@ -142,7 +142,7 @@ EnhancedPrecisionOp::difference(
auto resultEP = cbo.difference(geom0, geom1);
throw originalEx;
@@ -177,7 +177,7 @@ EnhancedPrecisionOp::symDifference(
auto resultEP = cbo.symDifference(geom0, geom1);
throw originalEx;
@@ -210,7 +210,7 @@ EnhancedPrecisionOp::buffer(const Geometry* geom, double distance)
auto resultEP = cbo.buffer(geom, distance);
- // after the reshift to orginal precision
+ // after the reshift to original precision
throw originalEx;
diff --git a/tests/geostest/geostest.c b/tests/geostest/geostest.c
index 95db390..ff9bb1d 100644
--- a/tests/geostest/geostest.c
+++ b/tests/geostest/geostest.c
@@ -266,7 +266,7 @@ do_all(char *inputfile)
printf("Union: %s\n", ptr);
free(ptr);
- /* PointOnSurcace */
+ /* PointOnSurface */
g4 = GEOSPointOnSurface(g3);
ptr = GEOSGeomToWKT(g4);
printf("PointOnSurface: %s\n", ptr);
diff --git a/tests/unit/algorithm/RobustLineIntersectorTest.cpp b/tests/unit/algorithm/RobustLineIntersectorTest.cpp
index 3ea2bc1..3d673b6 100644
--- a/tests/unit/algorithm/RobustLineIntersectorTest.cpp
+++ b/tests/unit/algorithm/RobustLineIntersectorTest.cpp
@@ -262,7 +262,7 @@ void object::test<13>
// Test intersects: point on segment with FLOAT PM
-// X coordinate of 3rd and 4th vertises of the line are not
+// X coordinate of 3rd and 4th vertices of the line are not
// float-point exact with X coordinate of the point.
// The X values differ after 14th decimal place:
// POINT (-23.1094689600055080 50.5195368635957180)
@@ -294,7 +294,7 @@ void object::test<14>
// Test intersects: point on segment with FIXED PM
diff --git a/tests/unit/capi/GEOSContainsTest.cpp b/tests/unit/capi/GEOSContainsTest.cpp
index 558e61f..e557c6f 100644
--- a/tests/unit/capi/GEOSContainsTest.cpp
+++ b/tests/unit/capi/GEOSContainsTest.cpp
@@ -128,7 +128,7 @@ template<>
void object::test<4>
- // Coincident vertives of both polygons at
+ // Coincident vertices of both polygons at
// -700.67089999181 93743.4218587986, -713.450135807349 93754.1677576647,
std::string const
outer("01030000800100000009000000af9dd0005ee585c0f802efbff6e2f6400000000000000000955acde0994b86c039a922afa2e3f64000000000000000002af6fb4f5d1887c07adb1c4071e3f6400000000000000000e5962b388d4f87c0bd3aeda7bae2f640000000000000000087c61344030887c07d585e6ff6e1f6400000000000000000fc8a31b5166186c0230588b20ae1f640000000000000000034733daf050186c0ed9f3ac98ae1f6400000000000000000f190aef659b385c0df2876538ce2f6400000000000000000af9dd0005ee585c0f802efbff6e2f6400000000000000000");
diff --git a/tests/unit/capi/GEOSPreparedGeometryTest.cpp b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
index 040d0d1..0e49304 100644
--- a/tests/unit/capi/GEOSPreparedGeometryTest.cpp
+++ b/tests/unit/capi/GEOSPreparedGeometryTest.cpp
@@ -179,7 +179,7 @@ void object::test<6>
// Test PreparedIntersects: point on segment with FLOAT PM
@@ -276,7 +276,7 @@ template<>
void object::test<10>
std::string const
@@ -339,7 +339,7 @@ template<>
void object::test<11>
- // Coincident vertext at -753.167968418005 93709.4279185742
+ // Coincident vertex at -753.167968418005 93709.4279185742
//POLYGON ((-753.167968418005 93754.0955183194,-816.392328351464 93754.0955183194,-816.392328351464 93709.4279185742,-753.167968418005 93709.4279185742,-753.167968418005 93754.0955183194))
std::string const
outer("01030000800100000005000000bd70d3ff578987c09e373e87a1e3f6400000000000000000a9f60b7d238389c09e373e87a1e3f6400000000000000000a9f60b7d238389c09625c1d8d6e0f6400000000000000000bd70d3ff578987c09625c1d8d6e0f6400000000000000000bd70d3ff578987c09e373e87a1e3f6400000000000000000");
diff --git a/tests/unit/geom/CoordinateTest.cpp b/tests/unit/geom/CoordinateTest.cpp
index e0d64e2..7d21c46 100644
--- a/tests/unit/geom/CoordinateTest.cpp
+++ b/tests/unit/geom/CoordinateTest.cpp
@@ -47,7 +47,7 @@ void object::test<1>
ensure("NOTE: Coordinate has no default constructor.", true);
-// Test of overriden constructor
+// Test of overridden constructor
template<>
template<>
void object::test<2>
diff --git a/tests/unit/geom/GeometryCollectionTest.cpp b/tests/unit/geom/GeometryCollectionTest.cpp
index 5b25370..3ca8da0 100644
--- a/tests/unit/geom/GeometryCollectionTest.cpp
+++ b/tests/unit/geom/GeometryCollectionTest.cpp
@@ -135,7 +135,7 @@ template<>
- // Heterogenous GeometryCollection does not pass isDimensionString for any input
+ // Heterogeneous GeometryCollection does not pass isDimensionString for any input
auto gc = readWKT("GEOMETRYCOLLECTION(POINT (1 1), LINESTRING (1 1, 2 2))");
ensure(!gc->isDimensionStrict(geos::geom::Dimension::P));
diff --git a/tests/unit/geom/GeometryFactoryTest.cpp b/tests/unit/geom/GeometryFactoryTest.cpp
index bf74681..aee5451 100644
--- a/tests/unit/geom/GeometryFactoryTest.cpp
+++ b/tests/unit/geom/GeometryFactoryTest.cpp
@@ -655,7 +655,7 @@ void object::test<19>
using geos::geom::Coordinate;
const std::size_t size = 7;
- // Create sequence of coordiantes
+ // Create sequence of coordinates
CoordArrayPtr coords = new geos::geom::CoordinateArraySequence(size);
ensure(coords != nullptr);
coords->setAt(Coordinate(0, 10), 0);
@@ -705,7 +705,7 @@ void object::test<20>
const std::size_t exteriorSize = 7;
const std::size_t interiorSize = 5;
CoordArrayPtr coords = new geos::geom::CoordinateArraySequence(exteriorSize);
diff --git a/tests/unit/geom/IntersectionMatrixTest.cpp b/tests/unit/geom/IntersectionMatrixTest.cpp
index 1e52533..05c5372 100644
--- a/tests/unit/geom/IntersectionMatrixTest.cpp
+++ b/tests/unit/geom/IntersectionMatrixTest.cpp
@@ -291,7 +291,7 @@ void object::test<17>
using geos::geom::Location;
- // Test on the original p0attern 'FFFFFFFFF' of the 'im_' object
+ // Test on the original pattern 'FFFFFFFFF' of the 'im_' object
ensure_equals(im_.toString(), pattern_false_);
ensure_equals(im_.get(Location::INTERIOR, Location::INTERIOR), geos::geom::Dimension::False);
diff --git a/tests/unit/geom/LinearRingTest.cpp b/tests/unit/geom/LinearRingTest.cpp
index 031fc97..1178092 100644
--- a/tests/unit/geom/LinearRingTest.cpp
+++ b/tests/unit/geom/LinearRingTest.cpp
@@ -85,7 +85,7 @@ void object::test<1>
- // Non-empty sequence of coordiantes
+ // Non-empty sequence of coordinates
const std::size_t size7 = 7;
CoordArrayPtr coords = new geos::geom::CoordinateArraySequence();
ensure("sequence is null pointer.", coords != nullptr);
@@ -115,7 +115,7 @@ void object::test<1>
-// Test of copy contructor
+// Test of copy constructor
template<>
template<>
diff --git a/tests/unit/geom/PointTest.cpp b/tests/unit/geom/PointTest.cpp
index b296eb1..75ed262 100644
--- a/tests/unit/geom/PointTest.cpp
+++ b/tests/unit/geom/PointTest.cpp
@@ -482,7 +482,7 @@ void object::test<38>
ensure(!p1->equals(p2.get()));
-// Test of equals() for non-empty Points with negative coordiantes
+// Test of equals() for non-empty Points with negative coordinates
template<>
template<>
void object::test<39>
diff --git a/tests/unit/geom/PolygonTest.cpp b/tests/unit/geom/PolygonTest.cpp
index 9742415..cd62ae2 100644
--- a/tests/unit/geom/PolygonTest.cpp
+++ b/tests/unit/geom/PolygonTest.cpp
@@ -76,7 +76,7 @@ void object::test<1>
- // Create non-empty Coordiantes sequence for Exterior LinearRing
+ // Create non-empty Coordinate sequence for Exterior LinearRing
diff --git a/tests/unit/geom/TriangleTest.cpp b/tests/unit/geom/TriangleTest.cpp
index c375819..e5d0d93 100644
--- a/tests/unit/geom/TriangleTest.cpp
+++ b/tests/unit/geom/TriangleTest.cpp
@@ -18,7 +18,7 @@ namespace tut {
// Common data used by tests
struct test_triangle_data {
- // Coordiantes of simple triangle: ABC
+ // Coordinates of simple triangle: ABC
geos::geom::Coordinate a;
geos::geom::Coordinate b;
geos::geom::Coordinate c;
@@ -52,7 +52,7 @@ void object::test<1>
ensure("NOTE: Triangle has no default constructor.", true);
-// Test of overriden ctor
+// Test of overridden ctor
template<>
template<>
diff --git a/tests/unit/noding/SegmentNodeTest.cpp b/tests/unit/noding/SegmentNodeTest.cpp
index f95019b..50f2139 100644
--- a/tests/unit/noding/SegmentNodeTest.cpp
+++ b/tests/unit/noding/SegmentNodeTest.cpp
@@ -42,7 +42,7 @@ group test_segmentnode_group("geos::noding::SegmentNode");
// Test Cases
template<>
template<>
diff --git a/tests/unit/noding/snap/SnappingNoderTest.cpp b/tests/unit/noding/snap/SnappingNoderTest.cpp
index 6bad51a..2f2e8b1 100644
--- a/tests/unit/noding/snap/SnappingNoderTest.cpp
+++ b/tests/unit/noding/snap/SnappingNoderTest.cpp
@@ -102,7 +102,7 @@ void object::test<3> ()
checkRounding(wkt1, wkt2, 1, expected);
-// testLineCondensePointsp
+// testLineCondensePoints
template<>
template<>
void object::test<4> ()
diff --git a/tests/unit/noding/snapround/HotPixelTest.cpp b/tests/unit/noding/snapround/HotPixelTest.cpp
index e9f1fb0..a7cb0c1 100644
--- a/tests/unit/noding/snapround/HotPixelTest.cpp
+++ b/tests/unit/noding/snapround/HotPixelTest.cpp
@@ -269,7 +269,7 @@ void object::test<23>
-// Test segments entering through a corder and terminating inside pixel
+// Test segments entering through a corner and terminating inside pixel
// testCornerULEndInside
template<>
diff --git a/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp b/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
index 6e500f5..de93d1b 100644
--- a/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
+++ b/tests/unit/operation/distance/IndexedFacetDistanceTest.cpp
@@ -271,7 +271,7 @@ void object::test<10>
int npoints = 1000; // vertices in sinstar test shape
- int ncells = 100; // number of colums/rows in test grid square
+ int ncells = 100; // number of columns/rows in test grid square
double radius = 100.0;
double amplitude = 0.3; // how far the sin deviates from perfect circle (0.0)
diff --git a/tests/unit/operation/overlayng/OverlayNGZTest.cpp b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
index b83b49c..b19da3b 100644
--- a/tests/unit/operation/overlayng/OverlayNGZTest.cpp
+++ b/tests/unit/operation/overlayng/OverlayNGZTest.cpp
@@ -162,7 +162,7 @@ void object::test<9> ()
// XY Polygon gets Z value from Point
-// testPointPolygonXYUnionn
+// testPointPolygonXYUnion
template<>
template<>
void object::test<10> ()
diff --git a/tests/unit/triangulate/DelaunayTest.cpp b/tests/unit/triangulate/DelaunayTest.cpp
index 50ff9df..200b149 100644
--- a/tests/unit/triangulate/DelaunayTest.cpp
+++ b/tests/unit/triangulate/DelaunayTest.cpp
@@ -77,7 +77,7 @@ void object::test<1>
//Create a subdivision centered at (0,0)
QuadEdgeSubdivision sub(Envelope(-100, 100, -100, 100), .00001);
- //make a triagulaor to work on sub
+ //make a triangulator to work on sub
IncrementalDelaunayTriangulator triangulator(&sub);
triangulator.insertSite(Vertex(0, 0));
diff --git a/tests/unit/triangulate/VoronoiTest.cpp b/tests/unit/triangulate/VoronoiTest.cpp
index cdb0474..d764d69 100644
--- a/tests/unit/triangulate/VoronoiTest.cpp
+++ b/tests/unit/triangulate/VoronoiTest.cpp
@@ -56,7 +56,7 @@ readTextOrHex(const char* wkt)
return wktreader.read(wktstr);
-//helper function for funning triangulation
+//helper function for running triangulation
void
runVoronoi(const char* sitesWkt, const char* expectedWkt, const double tolerance)
diff --git a/tests/unit/util/NodingTestUtil.cpp b/tests/unit/util/NodingTestUtil.cpp
index df741f8..f59739b 100644
--- a/tests/unit/util/NodingTestUtil.cpp
+++ b/tests/unit/util/NodingTestUtil.cpp
@@ -76,7 +76,7 @@ NodingTestUtil::nodeValidated(const Geometry* geom1, const Geometry* geom2, Node
std::vector<SegmentString*> ssList = toSegmentStrings(lines);
ValidatingNoder noderValid(*noder);
- // computeNotes might alster ssList, but ssList still
+ // computeNotes might alter ssList, but ssList still
// holds all memory
noderValid.computeNodes(&ssList);
diff --git a/tests/unit/utility.h b/tests/unit/utility.h
index 08f14e1..1f9ea3f 100644
--- a/tests/unit/utility.h
+++ b/tests/unit/utility.h
@@ -69,7 +69,7 @@ typedef geos::geom::MultiLineString const* MultiLineStringCPtr;
typedef geos::geom::MultiPolygon* MultiPolygonPtr;
typedef geos::geom::MultiPolygon const* MultiPolygonCPtr;
-// prepared geometries always returend as const
+// prepared geometries always returned as const
typedef geos::geom::prep::PreparedGeometry const* PreparedGeometryPtr;
Summary of changes:
doc/example.cpp | 8 ++++----
include/geos/algorithm/Angle.h | 4 ++--
include/geos/geomgraph/Depth.h | 2 +-
include/geos/geomgraph/EdgeIntersection.h | 2 +-
include/geos/noding/MCIndexNoder.inl | 2 +-
include/geos/noding/snapround/MCIndexSnapRounder.h | 4 ++--
include/geos/operation/buffer/BufferBuilder.h | 2 +-
include/geos/operation/buffer/BufferInputLineSimplifier.h | 2 +-
include/geos/operation/buffer/OffsetCurveSetBuilder.h | 2 +-
include/geos/operation/union/CascadedPolygonUnion.h | 2 +-
src/geom/Envelope.cpp | 2 +-
src/geom/HeuristicOverlay.cpp | 2 +-
src/geom/prep/AbstractPreparedPolygonContains.cpp | 6 +++---
src/geomgraph/Edge.cpp | 2 +-
src/geomgraph/GeometryGraph.cpp | 2 +-
src/geomgraph/index/MonotoneChainIndexer.cpp | 2 +-
src/index/strtree/STRtree.cpp | 4 ++--
src/noding/MCIndexNoder.cpp | 2 +-
src/operation/buffer/BufferBuilder.cpp | 6 +++---
src/operation/buffer/SubgraphDepthLocater.cpp | 2 +-
src/operation/predicate/RectangleContains.cpp | 4 ++--
src/operation/sharedpaths/SharedPathsOp.cpp | 2 +-
src/operation/union/OverlapUnion.cpp | 2 +-
src/operation/union/UnaryUnionOp.cpp | 2 +-
src/operation/valid/MakeValid.cpp | 2 +-
src/planargraph/DirectedEdgeStar.cpp | 2 +-
src/precision/EnhancedPrecisionOp.cpp | 10 +++++-----
tests/geostest/geostest.c | 2 +-
tests/unit/algorithm/RobustLineIntersectorTest.cpp | 4 ++--
tests/unit/capi/GEOSContainsTest.cpp | 2 +-
tests/unit/capi/GEOSPreparedGeometryTest.cpp | 6 +++---
tests/unit/geom/CoordinateTest.cpp | 2 +-
tests/unit/geom/GeometryCollectionTest.cpp | 2 +-
tests/unit/geom/GeometryFactoryTest.cpp | 4 ++--
tests/unit/geom/IntersectionMatrixTest.cpp | 2 +-
tests/unit/geom/LinearRingTest.cpp | 4 ++--
tests/unit/geom/PointTest.cpp | 2 +-
tests/unit/geom/PolygonTest.cpp | 2 +-
tests/unit/geom/TriangleTest.cpp | 4 ++--
tests/unit/noding/SegmentNodeTest.cpp | 2 +-
tests/unit/noding/snap/SnappingNoderTest.cpp | 2 +-
tests/unit/noding/snapround/HotPixelTest.cpp | 2 +-
tests/unit/operation/distance/IndexedFacetDistanceTest.cpp | 2 +-
tests/unit/operation/overlayng/OverlayNGZTest.cpp | 2 +-
tests/unit/triangulate/DelaunayTest.cpp | 2 +-
tests/unit/triangulate/VoronoiTest.cpp | 2 +-
tests/unit/util/NodingTestUtil.cpp | 2 +-
tests/unit/utility.h | 2 +-
48 files changed, 69 insertions(+), 69 deletions(-)
hooks/post-receive
More information about the geos-commits
