[geos-commits] [SCM] GEOS branch master updated. 4466ee0e4e85f21ef362098f0d61db4222b831b7
git at osgeo.org
git at osgeo.org
Fri Dec 18 18:46:23 PST 2020
the project "GEOS".
via 4466ee0e4e85f21ef362098f0d61db4222b831b7 (commit)
via 929bbc425c0acb66e69c906c83c6310d1c146275 (commit)
via 445ac910bd989af718decdc0b87dc920cb0f8863 (commit)
via 03767e5c69c25155d96ebbb12cd9709abeb22d10 (commit)
from ba7a93fa8ebf5b083a96b80958843e7ae820a9b4 (commit)
revisions in full, below.
commit 4466ee0e4e85f21ef362098f0d61db4222b831b7
Author: Even Rouault <even.rouault at spatialys.com>
Date: Sat Dec 19 01:59:34 2020 +0100
Avoid shadowing of member variable pm
diff --git a/tests/unit/io/WKTWriterTest.cpp b/tests/unit/io/WKTWriterTest.cpp
index 1718fa5..3231cb5 100644
--- a/tests/unit/io/WKTWriterTest.cpp
+++ b/tests/unit/io/WKTWriterTest.cpp
@@ -195,8 +195,8 @@ void object::test<7>
using geos::geom::CoordinateArraySequence;
using geos::geom::Point;
- PrecisionModel pm;
- auto factory_ = GeometryFactory::create(&pm);
+ PrecisionModel pmLocal;
+ auto factory_ = GeometryFactory::create(&pmLocal);
CoordinateArraySequence* coords = new CoordinateArraySequence();
ensure(coords != nullptr);
commit 929bbc425c0acb66e69c906c83c6310d1c146275
Date: Sat Dec 19 01:59:16 2020 +0100
Fix wrong use of variable assingment instead of equality comparison
diff --git a/tests/unit/index/strtree/SimpleSTRtreeTest.cpp b/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
index 67735d6..380785f 100644
--- a/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
+++ b/tests/unit/index/strtree/SimpleSTRtreeTest.cpp
@@ -134,23 +134,23 @@ void object::test<3>
t.insert(g.get());
- std::size_t leaf_before = t.getRoot()->getNumLeafNodes();
+ const std::size_t leaf_before = t.getRoot()->getNumLeafNodes();
// std::cout << "leaf_before " << leaf_before << std::endl;
- std::size_t all_before = t.getRoot()->getNumNodes();
+ const std::size_t all_before = t.getRoot()->getNumNodes();
// std::cout << "all_before " << all_before << std::endl;
- ensure(leaf_before = 4u);
- ensure(all_before = 5u);
+ ensure_equals(leaf_before, 4u);
+ ensure_equals(all_before, 5u);
// std::cout << t << std::endl;
t.remove(geoms[3]->getEnvelopeInternal(), geoms[3].get());
- std::size_t leaf_after = t.getRoot()->getNumLeafNodes();
+ const std::size_t leaf_after = t.getRoot()->getNumLeafNodes();
// std::cout << "leaf_after " << leaf_after << std::endl;
- std::size_t all_after = t.getRoot()->getNumNodes();
+ const std::size_t all_after = t.getRoot()->getNumNodes();
// std::cout << "all_after " << all_after << std::endl;
- ensure(leaf_after = 3u);
- ensure(all_after = 4u);
+ ensure_equals(leaf_after, 3u);
+ ensure_equals(all_after, 4u);
commit 445ac910bd989af718decdc0b87dc920cb0f8863
Date: Sat Dec 19 01:58:44 2020 +0100
Fix warnings about implicit int->uint8_t casts
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index 0aeda7f..c823bfe 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -177,7 +177,7 @@ typedef struct GEOSContextHandle_HS {
GEOSMessageHandler errorMessageOld;
GEOSMessageHandler_r errorMessageNew;
void* errorData;
- int WKBOutputDims;
+ uint8_t WKBOutputDims;
int WKBByteOrder;
int initialized;
@@ -2108,7 +2108,7 @@ extern "C" {
const int olddims = handle->WKBOutputDims;
- handle->WKBOutputDims = newdims;
+ handle->WKBOutputDims = static_cast<uint8_t>(newdims);
return olddims;
@@ -2649,7 +2649,7 @@ extern "C" {
GEOSWKTWriter_setOutputDimension_r(GEOSContextHandle_t extHandle, WKTWriter* writer, int dim)
execute(extHandle, [&]() {
- writer->setOutputDimension(dim);
+ writer->setOutputDimension(static_cast<uint8_t>(dim));
@@ -2784,7 +2784,7 @@ extern "C" {
GEOSWKBWriter_setOutputDimension_r(GEOSContextHandle_t extHandle, GEOSWKBWriter* writer, int newDimension)
- writer->setOutputDimension(newDimension);
+ writer->setOutputDimension(static_cast<uint8_t>(newDimension));
commit 03767e5c69c25155d96ebbb12cd9709abeb22d10
Date: Sat Dec 19 01:58:23 2020 +0100
Fix warnings about signed vs unsigned comparisons
diff --git a/benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp b/benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp
index 46929ee..b3c6a22 100644
--- a/benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp
+++ b/benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp
@@ -65,7 +65,7 @@ int main(int argc, char** argv) {
auto num_lines = std::atol(argv[1]);
auto num_reps = argc > 2 ? std::atol(argv[2]) : 1;
- for (std::size_t i = 0; i < num_reps; i++) {
+ for (decltype(num_reps) i = 0; i < num_reps; i++) {
tester.test(num_lines);
diff --git a/src/util/GeometricShapeFactory.cpp b/src/util/GeometricShapeFactory.cpp
index af15880..6ac97dc 100644
--- a/src/util/GeometricShapeFactory.cpp
+++ b/src/util/GeometricShapeFactory.cpp
@@ -84,7 +84,7 @@ GeometricShapeFactory::setHeight(double height)
std::unique_ptr<Polygon>
GeometricShapeFactory::createRectangle()
- int i;
+ uint32_t i;
int ipt = 0;
uint32_t nSide = nPts / 4;
if(nSide < 1) {
@@ -136,7 +136,7 @@ GeometricShapeFactory::createCircle()
std::vector<Coordinate> pts(nPts + 1);
int iPt = 0;
- for(int i = 0; i < nPts; i++) {
+ for(uint32_t i = 0; i < nPts; i++) {
double ang = i * (2 * 3.14159265358979 / nPts);
double x = xRadius * cos(ang) + centreX;
double y = yRadius * sin(ang) + centreY;
@@ -168,7 +168,7 @@ GeometricShapeFactory::createArc(double startAng, double angExtent)
std::vector<Coordinate> pts(nPts);
int iPt = 0;
double ang = startAng + i * angInc;
@@ -199,7 +199,7 @@ GeometricShapeFactory::createArcPolygon(double startAng, double angExtent)
std::vector<Coordinate> pts(nPts + 2);
int iPt = 0;
pts[iPt++] = coord(centreX, centreY);
diff --git a/tests/bigtest/GeometryTestFactory.cpp b/tests/bigtest/GeometryTestFactory.cpp
index 56bccf0..997426d 100644
--- a/tests/bigtest/GeometryTestFactory.cpp
+++ b/tests/bigtest/GeometryTestFactory.cpp
@@ -75,7 +75,7 @@ GeometryTestFactory::createCircle(double basex, double basey, double size, uint3
CoordinateArraySequence* pts = new CoordinateArraySequence(nPts + 1);
double len = size / 2.0;
double ang = i * (2 * PI / nPts);
double x = len * cos(ang) + basex;
double y = len * sin(ang) + basey;
diff --git a/tests/unit/capi/GEOSSTRtreeTest.cpp b/tests/unit/capi/GEOSSTRtreeTest.cpp
index 8a3253e..5d9e757 100644
--- a/tests/unit/capi/GEOSSTRtreeTest.cpp
+++ b/tests/unit/capi/GEOSSTRtreeTest.cpp
@@ -274,7 +274,7 @@ void object::test<8>
typedef std::vector<int*> IList;
IList items;
- ensure_equals(items.size(), 0);
+ ensure_equals(items.size(), 0U);
GEOSSTRtree_query(
tree,
q,
@@ -284,7 +284,7 @@ void object::test<8>
&items);
- ensure_equals(items.size(), 1);
+ ensure_equals(items.size(), 1U);
ensure_equals(*(items[0]), payload);
@@ -309,7 +309,7 @@ void object::test<9>
IList items;
GEOSSTRtree_query(
tree,
q,
@@ -319,7 +319,7 @@ void object::test<9>
&items);
ensure_equals(items[0], (void*)0);
Summary of changes:
benchmarks/algorithm/UnaryUnionSegmentsPerfTest.cpp | 2 +-
capi/geos_ts_c.cpp | 8 ++++----
src/util/GeometricShapeFactory.cpp | 8 ++++----
tests/bigtest/GeometryTestFactory.cpp | 2 +-
tests/unit/capi/GEOSSTRtreeTest.cpp | 8 ++++----
tests/unit/index/strtree/SimpleSTRtreeTest.cpp | 16 ++++++++--------
tests/unit/io/WKTWriterTest.cpp | 4 ++--
7 files changed, 24 insertions(+), 24 deletions(-)
hooks/post-receive
More information about the geos-commits
