[geos-commits] [SCM] GEOS branch 3.9 updated. 56775452d0c802e2b2658940fee912cfb2d346e0
git at osgeo.org
git at osgeo.org
Sat Dec 19 18:57:21 PST 2020
the project "GEOS".
The branch, 3.9 has been updated
via 56775452d0c802e2b2658940fee912cfb2d346e0 (commit)
from 3caeaf132284ee0c5e0d5896ac105e47c1696937 (commit)
revisions in full, below.
commit 56775452d0c802e2b2658940fee912cfb2d346e0
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Sat Dec 19 17:56:27 2020 -0800
Clean up Win32 memory issue, references #1050
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index a65e260..188d100 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -2408,22 +2408,31 @@ extern "C" {
//assert(0 != holes);
return execute(extHandle, [&]() {
- auto vholes = geos::detail::make_unique<std::vector<LinearRing*>>(nholes);
+ std::vector<LinearRing*> tmpholes(nholes);
for (size_t i = 0; i < nholes; i++) {
- (*vholes)[i] = dynamic_cast<LinearRing*>(holes[i]);
- if ((*vholes)[i] == nullptr) {
+ LinearRing* lr = dynamic_cast<LinearRing*>(holes[i]);
+ if (! lr) {
throw IllegalArgumentException("Hole is not a LinearRing");
+ tmpholes[i] = lr;
LinearRing* nshell = dynamic_cast<LinearRing*>(shell);
if(! nshell) {
throw IllegalArgumentException("Shell is not a LinearRing");
- const GeometryFactory* gf = shell->getFactory();
+ GEOSContextHandleInternal_t* handle = reinterpret_cast<GEOSContextHandleInternal_t*>(extHandle);
+ const GeometryFactory* gf = handle->geomFactory;
+ /* Create unique_ptr version for constructor */
+ std::vector<std::unique_ptr<LinearRing>> vholes;
+ vholes.reserve(nholes);
+ for (LinearRing* lr: tmpholes) {
+ vholes.emplace_back(lr);
+ std::unique_ptr<LinearRing> shell(nshell);
- return gf->createPolygon(nshell, vholes.release());
+ return gf->createPolygon(std::move(shell), std::move(vholes)).release();
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 2bbd681..4aaffe2 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -78,6 +78,8 @@ geos_unit_SOURCES = \
capi/GEOSEqualsTest.cpp \
capi/GEOSFrechetDistanceTest.cpp \
capi/GEOSGeom_createCollectionTest.cpp \
+ capi/GEOSGeom_createPolygonTest.cpp \
+ capi/GEOSGeom_createLineStringTest.cpp \
capi/GEOSGeom_createTest.cpp \
capi/GEOSGeom_extentTest.cpp \
capi/GEOSGeom_extractUniquePointsTest.cpp \
diff --git a/tests/unit/capi/GEOSGeom_createPolygonTest.cpp b/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
new file mode 100644
index 0000000..b560975
--- /dev/null
+++ b/tests/unit/capi/GEOSGeom_createPolygonTest.cpp
@@ -0,0 +1,54 @@
+#include <tut/tut.hpp>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+struct test_geosgeom_createpolygon_data : public capitest::utility {};
+typedef test_group<test_geosgeom_createpolygon_data> group;
+typedef group::object object;
+group test_geosgeom_createpolygon("capi::GEOSGeom_createPolygon");
+template<>
+template<>
+void object::test<1>
+ GEOSCoordSequence* shell_seq = GEOSCoordSeq_create(5, 2);
+ GEOSCoordSequence* hole_seq = GEOSCoordSeq_create(5, 2);
+ double shell_coords[] = {0,0, 0,10, 10,10, 10,0, 0,0};
+ double hole_coords[] = {5,5, 5,6, 6,6, 6,5, 5,5};
+ for (int i = 0; i < 5; i++) {
+ GEOSCoordSeq_setXY(shell_seq, i, shell_coords[2*i], shell_coords[2*i+1]);
+ GEOSCoordSeq_setXY(hole_seq, i, hole_coords[2*i], hole_coords[2*i+1]);
+ GEOSGeometry* shell = GEOSGeom_createLinearRing(shell_seq);
+ GEOSGeometry* hole = GEOSGeom_createLinearRing(hole_seq);
+ GEOSGeometry** holes = (GEOSGeometry**)malloc(sizeof(GEOSGeometry *));
+ holes[0] = hole;
+ GEOSGeometry* polygon = GEOSGeom_createPolygon(shell, holes, 1);
+ GEOSGeometry* expected = GEOSGeomFromWKT("POLYGON((0 0, 0 10, 10 10, 10 0, 0 0),(5 5, 5 6, 6 6, 6 5, 5 5))");
+ // GEOSWKTWriter* w = GEOSWKTWriter_create();
+ // printf("%s\n", GEOSWKTWriter_write(w, polygon));
+ // printf("%s\n", GEOSWKTWriter_write(w, expected));
+ ensure_equals(GEOSEqualsExact(polygon, expected, 0), 1);
+ GEOSGeom_destroy(polygon);
+ GEOSGeom_destroy(expected);
+ // WARNING! The GEOSGeom_createPolygon takes ownership of the
+ // GEOSGeometry, but not the containing array!
+ // maybe this should be changed...
+ free(holes);
+} // namespace tut
Summary of changes:
capi/geos_ts_c.cpp | 21 +++++++---
tests/unit/Makefile.am | 2 +
tests/unit/capi/GEOSGeom_createPolygonTest.cpp | 54 ++++++++++++++++++++++++++
3 files changed, 71 insertions(+), 6 deletions(-)
create mode 100644 tests/unit/capi/GEOSGeom_createPolygonTest.cpp
hooks/post-receive
More information about the geos-commits
