[geos-commits] [SCM] GEOS branch 3.9 updated. a5890d8f9ee7737d697e23b19100a86333fcb665
git at osgeo.org
git at osgeo.org
Wed Dec 30 15:21:17 PST 2020
the project "GEOS".
The branch, 3.9 has been updated
via a5890d8f9ee7737d697e23b19100a86333fcb665 (commit)
from 97b6524a63306318ddb790b7b448a44f41e23f19 (commit)
revisions in full, below.
commit a5890d8f9ee7737d697e23b19100a86333fcb665
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Dec 30 15:12:03 2020 -0800
Port JTS https://github.com/locationtech/jts/pull/655, Fix buffer to use largest enclosed area for invalid rings
diff --git a/NEWS b/NEWS
index 00d8d4a..83c4e40 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,7 @@ Changes in 3.9.1
- Bug fixes / improvements:
- Windows memory management quirk in createPolygon CAPI (#1050, Paul Ramsey)
- Allow build on Apple ARM64 (Taras Zakharko)
+ - Fix buffer to use largest enclosed area for invalid rings (#732, Paul Ramsey)
diff --git a/include/geos/algorithm/Orientation.h b/include/geos/algorithm/Orientation.h
index 0ed4bba..cd6cd3c 100644
--- a/include/geos/algorithm/Orientation.h
+++ b/include/geos/algorithm/Orientation.h
@@ -89,6 +89,32 @@ public:
static bool isCCW(const geom::CoordinateSequence* ring);
+ * Tests if a ring defined by a CoordinateSequence is
+ * oriented counter-clockwise, using the signed area of the ring.
+ * * The list of points is assumed to have the first and last points equal.
+ * * This handles coordinate lists which contain repeated points.
+ * * This handles rings which contain collapsed segments
+ * (in particular, along the top of the ring).
+ * * This handles rings which are invalid due to self-intersection
+ * This algorithm is guaranteed to work with valid rings.
+ * For invalid rings (containing self-intersections),
+ * the algorithm determines the orientation of
+ * the largest enclosed area (including overlaps).
+ * This provides a more useful result in some situations, such as buffering.
+ * However, this approach may be less accurate in the case of
+ * rings with almost zero area.
+ * (Note that the orientation of rings with zero area is essentially
+ * undefined, and hence non-deterministic.)
+ * @param ring a CoordinateSequence forming a ring (with first and last point identical)
+ * @return true if the ring is oriented counter-clockwise.
+ static bool isCCWArea(const geom::CoordinateSequence* ring);
diff --git a/src/algorithm/Orientation.cpp b/src/algorithm/Orientation.cpp
index 383f36a..9eb04e2 100644
--- a/src/algorithm/Orientation.cpp
+++ b/src/algorithm/Orientation.cpp
@@ -20,6 +20,7 @@
#include <cmath>
#include <vector>
+#include <geos/algorithm/Area.h>
#include <geos/algorithm/Orientation.h>
#include <geos/algorithm/CGAlgorithmsDD.h>
#include <geos/geom/CoordinateSequence.h>
@@ -134,92 +135,12 @@ Orientation::isCCW(const geom::CoordinateSequence* ring)
-#if 0
/* public static */
bool
-Orientation::isCCW(const geom::CoordinateSequence* ring)
+Orientation::isCCWArea(const geom::CoordinateSequence* ring)
- // sanity check
- if(ring->getSize() < 4) {
- throw util::IllegalArgumentException("Ring has fewer than 4 points, so orientation cannot be determined");
- // # of points without closing endpoint
- const std::size_t nPts = ring->getSize() - 1;
- assert(nPts >= 3); // This is here for scan-build
- // find highest point
- const geom::Coordinate* hiPt = &ring->getAt(0);
- size_t hiIndex = 0;
- for(std::size_t i = 1; i <= nPts; ++i) {
- const geom::Coordinate* p = &ring->getAt(i);
- if(p->y > hiPt->y) {
- hiPt = p;
- hiIndex = i;
- // find distinct point before highest point
- auto iPrev = hiIndex;
- do {
- if(iPrev == 0) {
- iPrev = nPts;
- iPrev = iPrev - 1;
- while(ring->getAt(iPrev) == *hiPt && iPrev != hiIndex);
- // find distinct point after highest point
- auto iNext = hiIndex;
- do {
- iNext = (iNext + 1) % nPts;
- while(ring->getAt(iNext) == *hiPt && iNext != hiIndex);
- const geom::Coordinate* prev = &ring->getAt(iPrev);
- const geom::Coordinate* next = &ring->getAt(iNext);
- * This check catches cases where the ring contains an A-B-A
- * configuration of points.
- * This can happen if the ring does not contain 3 distinct points
- * (including the case where the input array has fewer than 4 elements),
- * or it contains coincident line segments.
- if(prev->equals2D(*hiPt) || next->equals2D(*hiPt) ||
- prev->equals2D(*next)) {
- return false;
- // MD - don't bother throwing exception,
- // since this isn't a complete check for ring validity
- //throw IllegalArgumentException("degenerate ring (does not contain 3 distinct points)");
- int disc = Orientation::index(*prev, *hiPt, *next);
- * If disc is exactly 0, lines are collinear.
- * There are two possible cases:
- * (1) the lines lie along the x axis in opposite directions
- * (2) the lines lie on top of one another
- * (1) is handled by checking if next is left of prev ==> CCW
- * (2) should never happen, so we're going to ignore it!
- * (Might want to assert this)
- bool isCCW = false;
- if(disc == 0) {
- // poly is CCW if prev x is right of next x
- isCCW = (prev->x > next->x);
- else {
- // if area is positive, points are ordered CCW
- isCCW = (disc > 0);
- return isCCW;
+ return algorithm::Area::ofRingSigned(ring) < 0;
-#endif
} // namespace geos.algorithm
diff --git a/src/operation/buffer/OffsetCurveSetBuilder.cpp b/src/operation/buffer/OffsetCurveSetBuilder.cpp
index 810bddf..ba07011 100644
--- a/src/operation/buffer/OffsetCurveSetBuilder.cpp
+++ b/src/operation/buffer/OffsetCurveSetBuilder.cpp
@@ -320,8 +320,9 @@ OffsetCurveSetBuilder::addRingSide(const CoordinateSequence* coord,
#if GEOS_DEBUG
std::cerr << "OffsetCurveSetBuilder::addPolygonRing: CCW: " << Orientation::isCCW(coord) << std::endl;
#endif
- if(coord->size() >= LinearRing::MINIMUM_VALID_SIZE
- && Orientation::isCCW(coord)) {
+ if(coord->size() >= LinearRing::MINIMUM_VALID_SIZE &&
+ Orientation::isCCWArea(coord))
leftLoc = cwRightLoc;
rightLoc = cwLeftLoc;
#if GEOS_DEBUG
diff --git a/tests/unit/Makefile.am b/tests/unit/Makefile.am
index 4aaffe2..9a6a818 100644
--- a/tests/unit/Makefile.am
+++ b/tests/unit/Makefile.am
@@ -44,7 +44,7 @@ geos_unit_SOURCES = \
algorithm/AngleTest.cpp \
algorithm/AreaTest.cpp \
algorithm/CGAlgorithms/computeOrientationTest.cpp \
- algorithm/CGAlgorithms/isCCWTest.cpp \
+ algorithm/CGAlgorithms/OrientationIsCCWTest.cpp \
algorithm/CGAlgorithms/isPointInRingTest.cpp \
algorithm/CGAlgorithms/signedAreaTest.cpp \
algorithm/ConvexHullTest.cpp \
diff --git a/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp b/tests/unit/algorithm/CGAlgorithms/OrientationIsCCWTest.cpp
similarity index 83%
rename from tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
rename to tests/unit/algorithm/CGAlgorithms/OrientationIsCCWTest.cpp
index f6acbae..b56e11c 100644
--- a/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
+++ b/tests/unit/algorithm/CGAlgorithms/OrientationIsCCWTest.cpp
@@ -40,7 +40,7 @@ struct test_isccw_data {
void
- checkOrientationCCW(bool expectedCCW, const std::string& wkt)
+ checkCCW(bool expectedCCW, const std::string& wkt)
GeometryPtr geom(reader_.read(wkt));
geos::geom::Polygon* poly = dynamic_cast<geos::geom::Polygon*>(geom.get());
@@ -51,6 +51,17 @@ struct test_isccw_data {
void
+ checkCCWArea(bool expectedCCWArea, const std::string& wkt)
+ GeometryPtr geom(reader_.read(wkt));
+ geos::geom::Polygon* poly = dynamic_cast<geos::geom::Polygon*>(geom.get());
+ ensure("WKT must be POLYGON)", poly != nullptr);
+ const geos::geom::CoordinateSequence* cs = poly->getExteriorRing()->getCoordinatesRO();
+ bool actualCCWArea = Orientation::isCCWArea(cs);
+ ensure_equals("CoordinateSequence isCCWArea", expectedCCWArea, actualCCWArea);
+ void
checkHexOrientationCCW(bool expectedCCW, std::istringstream& wkt)
GeometryPtr geom(breader_.readHEX(wkt));
@@ -64,7 +75,7 @@ struct test_isccw_data {
typedef test_group<test_isccw_data> group;
typedef group::object object;
-group test_isccw_group("geos::algorithm::CGAlgorithms::isCCW");
+group test_isccw_group("geos::algorithm::CGAlgorithms::OrientationIsCCW");
// Test Cases
@@ -77,7 +88,7 @@ void object::test<1>
const std::string wkt("POLYGON ((60 180, 140 240, 140 240, 140 240, 200 180, 120 120, 60 180))");
- checkOrientationCCW(false, wkt);
+ checkCCW(false, wkt);
// 2 - Test if coordinates of polygon are counter-clockwise oriented
@@ -87,7 +98,7 @@ void object::test<2>
const std::string wkt("POLYGON ((60 180, 140 120, 100 180, 140 240, 60 180))");
- checkOrientationCCW(true, wkt);
+ checkCCW(true, wkt);
// 3 - Test the same polygon as in test No 2 but with duplicated top point
@@ -97,7 +108,7 @@ void object::test<3>
const std::string wkt("POLYGON ((60 180, 140 120, 100 180, 140 240, 140 240, 60 180))");
// 4 - Test orientation the narrow (almost collapsed) ring
@@ -133,7 +144,7 @@ void object::test<6>
const std::string wkt("POLYGON ((1 1, 9 1, 5 9, 1 1))");
// testFlatTopSegment
@@ -143,7 +154,7 @@ void object::test<7>
const std::string wkt("POLYGON ((100 200, 200 200, 200 100, 100 100, 100 200))");
// testFlatMultipleTopSegment
@@ -153,7 +164,7 @@ void object::test<8>
const std::string wkt("POLYGON ((100 200, 127 200, 151 200, 173 200, 200 200, 100 100, 100 200))");
// testDegenerateRingHorizontal
@@ -163,7 +174,7 @@ void object::test<9>
const std::string wkt("POLYGON ((100 200, 100 200, 200 200, 100 200))");
// testDegenerateRingAngled
@@ -173,7 +184,7 @@ void object::test<10>
const std::string wkt("POLYGON ((100 100, 100 100, 200 200, 100 100))");
// testDegenerateRingVertical
@@ -183,7 +194,7 @@ void object::test<11>
const std::string wkt("POLYGON ((200 100, 200 100, 200 200, 200 100))");
@@ -196,7 +207,7 @@ void object::test<12>
const std::string wkt("POLYGON ((10 20, 61 20, 20 30, 50 60, 10 20))");
// testABATopFlatSegmentCollapse
@@ -206,7 +217,7 @@ void object::test<13>
const std::string wkt("POLYGON ((71 0, 40 40, 70 40, 40 40, 20 0, 71 0))");
// testABATopFlatSegmentCollapseMiddleStart
@@ -216,7 +227,7 @@ void object::test<14>
const std::string wkt("POLYGON ((90 90, 50 90, 10 10, 90 10, 50 90, 90 90))");
// testMultipleTopFlatSegmentCollapseSinglePoint
@@ -226,7 +237,7 @@ void object::test<15>
const std::string wkt("POLYGON ((100 100, 200 100, 150 200, 170 200, 200 200, 100 200, 150 200, 100 100))");
// testMultipleTopFlatSegmentCollapseFlatTop
@@ -236,7 +247,7 @@ void object::test<16>
const std::string wkt("POLYGON ((10 10, 90 10, 70 70, 90 70, 10 70, 30 70, 50 70, 10 10))");
diff --git a/tests/unit/operation/buffer/BufferOpTest.cpp b/tests/unit/operation/buffer/BufferOpTest.cpp
index ac05b9b..8fdd2fd 100644
--- a/tests/unit/operation/buffer/BufferOpTest.cpp
+++ b/tests/unit/operation/buffer/BufferOpTest.cpp
@@ -3,6 +3,7 @@
// tut
#include <tut/tut.hpp>
+#include <utility.h>
// geos
#include <geos/operation/buffer/BufferOp.h>
#include <geos/operation/buffer/BufferParameters.h>
@@ -447,5 +448,22 @@ void object::test<14>
ensure_equals(gBuffer->getGeometryTypeId(), geos::geom::GEOS_MULTIPOLYGON);
+// This now works since buffer ring orientation is changed to use signed-area test.
+// testBowtiePolygonLargestAreaRetained
+template<>
+template<>
+void object::test<15>
+ std::string wkt0("POLYGON ((10 10, 50 10, 25 35, 35 35, 10 10))");
+ GeomPtr g0(wktreader.read(wkt0));
+ GeomPtr gresult = g0->buffer(0.0);
+ std::string wkt1("POLYGON ((10 10, 30 30, 50 10, 10 10))");
+ GeomPtr gexpected(wktreader.read(wkt1));
+ ensure_equals_geometry(gresult.get(), gexpected.get());
} // namespace tut
diff --git a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
index b7e4cd6..3894b9c 100644
--- a/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
+++ b/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
@@ -2,6 +2,7 @@
// Test Suite for geos::simplify::DouglasPeuckerSimplifierTest
// geos
#include <geos/io/WKTReader.h>
#include <geos/io/WKTWriter.h>
@@ -353,7 +354,7 @@ void object::test<11>
// 13 - Polygon with inner ring whose extent is less than the simplify distance (#741)
template<>
template<>
-void object::test<13>
+void object::test<12>
std::string wkt_in("POLYGON ((0 0,0 1,1 1,0 0),(0.1 0.1,0.2 0.1,0.2 0.2,0.1 0.1))");
@@ -372,5 +373,27 @@ void object::test<13>
ensure(simplified->equalsExact(expected.get()));
+* Test that a polygon made invalid by simplification
+* is fixed in a sensible way.
+* Fixed by buffer(0) area-base orientation
+* See https://github.com/locationtech/jts/issues/498
+template<>
+template<>
+void object::test<13>
+ std::string wkt_in("POLYGON ((21.32686 47.78723, 21.32386 47.79023, 21.32186 47.80223, 21.31486 47.81023, 21.32786 47.81123, 21.33986 47.80223, 21.33886 47.81123, 21.32686 47.82023, 21.32586 47.82723, 21.32786 47.82323, 21.33886 47.82623, 21.34186 47.82123, 21.36386 47.82223, 21.40686 47.81723, 21.32686 47.78723))");
+ std::string wkt_ex("POLYGON ((21.32686 47.78723, 21.31486 47.81023, 21.32786 47.81123, 21.33986 47.80223, 21.328068201892744 47.823286782334385, 21.33886 47.82623, 21.34186 47.82123, 21.40686 47.81723, 21.32686 47.78723))");
+ GeomPtr g(wktreader.read(wkt_in));
+ GeomPtr expected(wktreader.read(wkt_ex));
+ GeomPtr simplified = DouglasPeuckerSimplifier::simplify(g.get(), 0.0036);
+ ensure(simplified->isValid());
+ ensure_equals_geometry(simplified.get(), expected.get());
} // namespace tut
Summary of changes:
NEWS | 1 +
include/geos/algorithm/Orientation.h | 26 +++++++
src/algorithm/Orientation.cpp | 85 +---------------------
src/operation/buffer/OffsetCurveSetBuilder.cpp | 5 +-
tests/unit/Makefile.am | 2 +-
.../{isCCWTest.cpp => OrientationIsCCWTest.cpp} | 43 +++++++----
tests/unit/operation/buffer/BufferOpTest.cpp | 18 +++++
.../unit/simplify/DouglasPeuckerSimplifierTest.cpp | 25 ++++++-
8 files changed, 103 insertions(+), 102 deletions(-)
rename tests/unit/algorithm/CGAlgorithms/{isCCWTest.cpp => OrientationIsCCWTest.cpp} (83%)
hooks/post-receive
More information about the geos-commits
