[geos-commits] [SCM] GEOS branch master updated. 92ec0d5198a1ec3fd7afdfa5569b51f8ddd741af
git at osgeo.org
git at osgeo.org
Thu Feb 13 06:53:17 PST 2020
the project "GEOS".
via 92ec0d5198a1ec3fd7afdfa5569b51f8ddd741af (commit)
via 8ba2c1819504d6e9d30ee6400701952ca6955d98 (commit)
from c5b75f576a60cad8c7ae9fc48e90b22a783cad4c (commit)
revisions in full, below.
commit 92ec0d5198a1ec3fd7afdfa5569b51f8ddd741af
Merge: c5b75f5 8ba2c18
Author: Dan Baston <dbaston at gmail.com>
Date: Thu Feb 13 09:52:58 2020 -0500
Merge remote-tracking branch 'rouault/fix_mismatch_struct_class_variant2'
commit 8ba2c1819504d6e9d30ee6400701952ca6955d98
Author: Even Rouault <even.rouault at spatialys.com>
Date: Thu Feb 13 09:14:07 2020 +0100
Fix -Wmismatched-tags warning related to WK[T/B][Reader/Writer]
CLang 9 -Wextra warns about
./geos_c.h:1226:9: warning: struct 'WKTReader' was previously declared as a class; this is valid, but may result in linker errors under the Microsoft C++ ABI [-Wmismatched-tags]
typedef struct GEOSWKTReader_t GEOSWKTReader;
../../include/geos/io/WKTReader.h:58:16: note: previous use is here
class GEOS_DLL WKTReader {
./geos_c.h:1226:9: note: did you mean class here?
class
Similarly for WKTWriter, WKBReader and WKBWriter
This is due to capi/geos_c.cpp having a
#define GEOSWKTReader_t geos::io::WKTReader
Adopt the same solution as for GEOSGeom and other C++ classes
exposed in C API
diff --git a/capi/geos_c.cpp b/capi/geos_c.cpp
index ad8584f..acf5cb3 100644
--- a/capi/geos_c.cpp
+++ b/capi/geos_c.cpp
@@ -39,10 +39,10 @@
#define GEOSPreparedGeometry geos::geom::prep::PreparedGeometry
#define GEOSCoordSequence geos::geom::CoordinateSequence
#define GEOSSTRtree geos::index::strtree::STRtree
-#define GEOSWKTReader_t geos::io::WKTReader
-#define GEOSWKTWriter_t geos::io::WKTWriter
-#define GEOSWKBReader_t geos::io::WKBReader
-#define GEOSWKBWriter_t geos::io::WKBWriter
+#define GEOSWKTReader geos::io::WKTReader
+#define GEOSWKTWriter geos::io::WKTWriter
+#define GEOSWKBReader geos::io::WKBReader
+#define GEOSWKBWriter geos::io::WKBWriter
typedef struct GEOSBufParams_t GEOSBufferParams;
#include "geos_c.h"
diff --git a/capi/geos_c.h.in b/capi/geos_c.h.in
index 31da35e..0de0be1 100644
--- a/capi/geos_c.h.in
+++ b/capi/geos_c.h.in
@@ -1223,11 +1223,12 @@ extern int GEOS_DLL GEOSOrientationIndex_r(GEOSContextHandle_t handle,
+#ifndef GEOSWKTReader
typedef struct GEOSWKTWriter_t GEOSWKTWriter;
typedef struct GEOSWKBReader_t GEOSWKBReader;
typedef struct GEOSWKBWriter_t GEOSWKBWriter;
+#endif
/* WKT Reader */
extern GEOSWKTReader GEOS_DLL *GEOSWKTReader_create_r(
Summary of changes:
capi/geos_c.cpp | 8 ++++----
capi/geos_c.h.in | 3 ++-
2 files changed, 6 insertions(+), 5 deletions(-)
hooks/post-receive
More information about the geos-commits
