[geos-commits] [SCM] GEOS branch master updated. fa27712c5fbe933c507a2652512b894820c0f290
git at osgeo.org
git at osgeo.org
Tue Feb 18 20:18:25 PST 2020
the project "GEOS".
via fa27712c5fbe933c507a2652512b894820c0f290 (commit)
via 31c395e0d6d8094e400b51621e631bad5a37d4ef (commit)
from 9a6279fda34feb2acde8650f14f9c051e9fec60e (commit)
revisions in full, below.
commit fa27712c5fbe933c507a2652512b894820c0f290
Merge: 9a6279f 31c395e
Author: Regina Obe <lr at pcorp.us>
Date: Tue Feb 18 20:18:23 2020 -0800
Merge branch 'posix' of mwtoews/geos into master
switch ci to sh from bash
commit 31c395e0d6d8094e400b51621e631bad5a37d4ef
Author: Mike Taves <mwtoews at gmail.com>
Date: Wed Feb 19 11:32:49 2020 +1300
Convert tools/ci to use POSIX Shell instead of Bash
diff --git a/tools/ci/bessie.sh b/tools/ci/bessie.sh
old mode 100644
new mode 100755
index 2ffe8cb..502f60f
--- a/tools/ci/bessie.sh
+++ b/tools/ci/bessie.sh
@@ -1,4 +1,4 @@
-#!/bin/bash -e
+#!/bin/sh
# FreeBSD 64 (bessie) CI script runner for GEOS
diff --git a/tools/ci/bessie32.sh b/tools/ci/bessie32.sh
old mode 100644
new mode 100755
index de70378..193034d
--- a/tools/ci/bessie32.sh
+++ b/tools/ci/bessie32.sh
@@ -1,4 +1,4 @@
-#!/bin/bash -e
+#!/bin/sh
# FreeBSD 32 (bessie32) CI script runner for GEOS
diff --git a/tools/ci/common.sh b/tools/ci/common.sh
old mode 100644
new mode 100755
index 91deae1..08c0651
--- a/tools/ci/common.sh
+++ b/tools/ci/common.sh
@@ -1,4 +1,4 @@
-#!/bin/bash -e
+#!/bin/sh
# Common utilities for Travis CI setup for GEOS
@@ -9,7 +9,7 @@
# by the Free Software Foundation.
# See the COPYING file for more information.
-if [[ "$TRAVIS" != "true" ]] ; then
+if [ "$TRAVIS" != "true" ] ; then
echo "Running this script makes no sense outside of travis-ci.org"
exit 1
fi
@@ -17,7 +17,7 @@ fi
# Environment
TCI_NUMTHREADS=2
-if [[ -f /sys/devices/system/cpu/online ]]; then
+if [ -f /sys/devices/system/cpu/online ]; then
# Calculates 1.5 times physical threads
TCI_NUMTHREADS=$(( ( $(cut -f 2 -d '-' /sys/devices/system/cpu/online) + 1 ) * 15 / 10 ))
fi
diff --git a/tools/ci/script.sh b/tools/ci/script.sh
index 2a18947..1e646ab 100755
--- a/tools/ci/script.sh
+++ b/tools/ci/script.sh
@@ -1,4 +1,4 @@
-#!/bin/bash -e
+#!/bin/sh
# Travis CI script runner for GEOS
@@ -9,10 +9,17 @@
-source ${TRAVIS_BUILD_DIR}/tools/ci/common.sh
+if [ -z "${TRAVIS_BUILD_DIR+x}" ]; then
+ echo TRAVIS_BUILD_DIR not defined
+ exit 1
+fi
+# source common functions
+. ${TRAVIS_BUILD_DIR}/tools/ci/common.sh
# prepare build directory
-builddir="${TRAVIS_BUILD_DIR}/_build"
+builddir=${TRAVIS_BUILD_DIR}/_build
mkdir -p ${builddir}
cd ${builddir}
diff --git a/tools/ci/script_autotools.sh b/tools/ci/script_autotools.sh
index 1cb8804..b8b1cd8 100755
--- a/tools/ci/script_autotools.sh
+++ b/tools/ci/script_autotools.sh
@@ -1,4 +1,4 @@
-#!/bin/bash -e
+#!/bin/sh
# Travis CI script for GEOS build with GNU Autotools
@@ -9,7 +9,14 @@
+ exit 1
+fi
cd ${TRAVIS_BUILD_DIR}
./autogen.sh
diff --git a/tools/ci/script_autotools_scanbuild.sh b/tools/ci/script_autotools_scanbuild.sh
index ffcec64..3cbb8bb 100755
--- a/tools/ci/script_autotools_scanbuild.sh
+++ b/tools/ci/script_autotools_scanbuild.sh
@@ -1,4 +1,4 @@
-#!/bin/bash -e
+#!/bin/sh
@@ -9,7 +9,14 @@
+ exit 1
+fi
./autogen.sh
diff --git a/tools/ci/script_cmake.sh b/tools/ci/script_cmake.sh
index 287abda..b812cb5 100755
--- a/tools/ci/script_cmake.sh
+++ b/tools/ci/script_cmake.sh
@@ -1,4 +1,4 @@
-#!/bin/bash -e
+#!/bin/sh
# Travis CI script for GEOS build with CMake
@@ -9,7 +9,14 @@
+ exit 1
+fi
cmake --version
@@ -19,5 +26,6 @@ cmake --build . --target docs
ctest --output-on-failure .
if [ "${BUILD_TYPE}" = "Coverage" ]; then
- bash <(curl -s https://codecov.io/bash)
+ curl -o codecov.sh https://codecov.io/bash
+ bash codecov.sh
fi
Summary of changes:
tools/ci/bessie.sh | 2 +-
tools/ci/bessie32.sh | 2 +-
tools/ci/common.sh | 6 +++---
tools/ci/script.sh | 13 ++++++++++---
tools/ci/script_autotools.sh | 11 +++++++++--
tools/ci/script_autotools_scanbuild.sh | 11 +++++++++--
tools/ci/script_cmake.sh | 14 +++++++++++---
7 files changed, 44 insertions(+), 15 deletions(-)
mode change 100644 => 100755 tools/ci/bessie.sh
mode change 100644 => 100755 tools/ci/bessie32.sh
mode change 100644 => 100755 tools/ci/common.sh
hooks/post-receive
More information about the geos-commits
