[geos-commits] [SCM] GEOS branch master updated. d62686316e59f59e9f64814d3a769c736b27d885
Fri Jan 17 19:10:47 PST 2020
the project "GEOS".
       via  d62686316e59f59e9f64814d3a769c736b27d885 (commit)
       via  24f22e720ebcd3ed12d1651e539f44f774f3c5ef (commit)
      from  07254bfc260d0c106019d66b095d76410a7d4202 (commit)
revisions in full, below.
commit d62686316e59f59e9f64814d3a769c736b27d885
Merge: 07254bf 24f22e7
Author: Daniel Baston <dbaston at gmail.com>
Date:   Fri Jan 17 22:10:19 2020 -0500
    Merge branch 'trac-1010'
commit 24f22e720ebcd3ed12d1651e539f44f774f3c5ef
Date:   Wed Jan 15 16:24:46 2020 -0500
    Fix memory leak in GEOSLineMerge
    Fixes #1010
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index e60e1bd..e9bdffa 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1893,9 +1893,9 @@ extern "C" {
             LineMerger lmrgr;
             lmrgr.add(g);
-            std::vector<LineString*>* lines = lmrgr.getMergedLineStrings();
+            auto lines = lmrgr.getMergedLineStrings();
-            auto out = gf->buildGeometry(lines->begin(), lines->end());
+            auto out = gf->buildGeometry(std::move(lines));
             out->setSRID(g->getSRID());
             return out.release();
diff --git a/doc/example.cpp b/doc/example.cpp
index 678e821..31aa562 100644
--- a/doc/example.cpp
+++ b/doc/example.cpp
@@ -1073,12 +1073,11 @@ do_all()
     LineMerger lm;
     lm.add(geoms);
-    vector<LineString*>* mls = lm.getMergedLineStrings();
+    auto mls = lm.getMergedLineStrings();
     newgeoms = new vector<const Geometry*>;
-    for(unsigned int i = 0; i < mls->size(); i++) {
-        newgeoms->push_back((*mls)[i]);
+    for(unsigned int i = 0; i < mls.size(); i++) {
+        newgeoms->push_back(mls[i].release());
-    delete mls;
     cout << endl << "----- HERE IS THE LINEMERGE OUTPUT ------" << endl;
     wkt_print_geoms(newgeoms);
diff --git a/include/geos/geom/GeometryFactory.h b/include/geos/geom/GeometryFactory.h
index 10c90da..8bb99a3 100644
--- a/include/geos/geom/GeometryFactory.h
+++ b/include/geos/geom/GeometryFactory.h
@@ -334,6 +334,12 @@ public:
     std::unique_ptr<Geometry> buildGeometry(std::vector<std::unique_ptr<Geometry>> && geoms) const;
+    std::unique_ptr<Geometry> buildGeometry(std::vector<std::unique_ptr<Point>> && geoms) const;
+    std::unique_ptr<Geometry> buildGeometry(std::vector<std::unique_ptr<LineString>> && geoms) const;
+    std::unique_ptr<Geometry> buildGeometry(std::vector<std::unique_ptr<Polygon>> && geoms) const;
     /// See buildGeometry(std::vector<Geometry *>&) for semantics
     /// Will clone the geometries accessible trough the iterator.
diff --git a/include/geos/operation/linemerge/LineMerger.h b/include/geos/operation/linemerge/LineMerger.h
index d21465b..9ea6125 100644
--- a/include/geos/operation/linemerge/LineMerger.h
+++ b/include/geos/operation/linemerge/LineMerger.h
@@ -20,8 +20,10 @@
 #define GEOS_OP_LINEMERGE_LINEMERGER_H
 #include <geos/export.h>
+#include <geos/geom/LineString.h>
 #include <geos/operation/linemerge/LineMergeGraph.h> // for composition
+#include <memory>
 #include <vector>
 #ifdef _MSC_VER
@@ -32,7 +34,6 @@
 // Forward declarations
 namespace geos {
 namespace geom {
-class LineString;
 class GeometryFactory;
 class Geometry;
@@ -78,7 +79,7 @@ private:
     LineMergeGraph graph;
-    std::vector<geom::LineString*>* mergedLineStrings;
+    std::vector<std::unique_ptr<geom::LineString>> mergedLineStrings;
     std::vector<EdgeString*> edgeStrings;
@@ -128,7 +129,7 @@ public:
      * Ownership of vector _and_ its elements to caller.
-    std::vector<geom::LineString*>* getMergedLineStrings();
+    std::vector<std::unique_ptr<geom::LineString>> getMergedLineStrings();
     void add(const geom::LineString* lineString);
diff --git a/src/geom/GeometryFactory.cpp b/src/geom/GeometryFactory.cpp
index 6cfa396..2a0b968 100644
--- a/src/geom/GeometryFactory.cpp
+++ b/src/geom/GeometryFactory.cpp
@@ -255,7 +255,7 @@ GeometryFactory::toGeometry(const Envelope* envelope) const
     Coordinate coord;
     if(envelope->isNull()) {
-        return std::unique_ptr<Geometry>(createPoint());
+        return createPoint();
     if(envelope->getMinX() == envelope->getMaxX() && envelope->getMinY() == envelope->getMaxY()) {
         coord.x = envelope->getMinX();
@@ -714,6 +714,48 @@ GeometryFactory::buildGeometry(std::vector<std::unique_ptr<Geometry>> && geoms)
+std::unique_ptr<Geometry>
+GeometryFactory::buildGeometry(std::vector<std::unique_ptr<Point>> && geoms) const
+    if (geoms.empty()) {
+        return createGeometryCollection();
+    if (geoms.size() == 1) {
+        return std::move(geoms[0]);
+    return createMultiPoint(std::move(geoms));
+GeometryFactory::buildGeometry(std::vector<std::unique_ptr<LineString>> && geoms) const
+    return createMultiLineString(std::move(geoms));
+GeometryFactory::buildGeometry(std::vector<std::unique_ptr<Polygon>> && geoms) const
+    return createMultiPolygon(std::move(geoms));
 /*public*/
 Geometry*
 GeometryFactory::buildGeometry(const vector<const Geometry*>& fromGeoms) const
diff --git a/src/operation/buffer/BufferBuilder.cpp b/src/operation/buffer/BufferBuilder.cpp
index 2f84c51..8515918 100644
--- a/src/operation/buffer/BufferBuilder.cpp
+++ b/src/operation/buffer/BufferBuilder.cpp
@@ -252,17 +252,16 @@ BufferBuilder::bufferLineSingleSided(const Geometry* g, double distance,
     // Merge result lines together.
     LineMerger lineMerge;
     lineMerge.add(intersectedLines.get());
-    std::unique_ptr< std::vector< LineString* > > mergedLines(
-        lineMerge.getMergedLineStrings());
+    auto mergedLines = lineMerge.getMergedLineStrings();
     // Convert the result into a std::vector< Geometry* >.
     std::vector< Geometry* >* mergedLinesGeom = new std::vector< Geometry* >();
     const Coordinate& startPoint = l->getCoordinatesRO()->front();
     const Coordinate& endPoint = l->getCoordinatesRO()->back();
-    while(!mergedLines->empty()) {
+    while(!mergedLines.empty()) {
         // Remove end points if they are a part of the original line to be
         // buffered.
-        CoordinateSequence::Ptr coords(mergedLines->back()->getCoordinates());
+        CoordinateSequence::Ptr coords(mergedLines.back()->getCoordinates());
         if(nullptr != coords.get()) {
             // Use 98% of the buffer width as the point-distance requirement - this
             // is to ensure that the point that is "distance" +/- epsilon is not
@@ -349,8 +348,7 @@ BufferBuilder::bufferLineSingleSided(const Geometry* g, double distance,
-        geomFact->destroyGeometry(mergedLines->back());
-        mergedLines->pop_back();
+        mergedLines.pop_back();
     // Clean up.
diff --git a/src/operation/linemerge/LineMerger.cpp b/src/operation/linemerge/LineMerger.cpp
index a45d2f5..ec680f3 100644
--- a/src/operation/linemerge/LineMerger.cpp
+++ b/src/operation/linemerge/LineMerger.cpp
@@ -26,6 +26,7 @@
 //#include <geos/planargraph/GraphComponent.h>
 #include <geos/geom/GeometryComponentFilter.h>
+#include <geos/util.h>
 #include <cassert>
 #include <functional>
@@ -52,7 +53,6 @@ LineMerger::add(vector<const Geometry*>* geometries)
 LineMerger::LineMerger():
-    mergedLineStrings(nullptr),
     factory(nullptr)
@@ -105,7 +105,7 @@ LineMerger::add(const LineString* lineString)
 void
 LineMerger::merge()
-    if(mergedLineStrings != nullptr) {
+    if(!mergedLineStrings.empty()) {
         return;
@@ -124,10 +124,10 @@ LineMerger::merge()
     buildEdgeStringsForIsolatedLoops();
     auto numEdgeStrings = edgeStrings.size();
-    mergedLineStrings = new vector<LineString*>(numEdgeStrings);
+    mergedLineStrings.reserve(numEdgeStrings);
     for(size_t i = 0; i < numEdgeStrings; ++i) {
         EdgeString* edgeString = edgeStrings[i];
-        (*mergedLineStrings)[i] = edgeString->toLineString();
+        mergedLineStrings.emplace_back(edgeString->toLineString());
@@ -227,14 +227,14 @@ LineMerger::buildEdgeStringStartingWith(LineMergeDirectedEdge* start)
  * Returns the LineStrings built by the merging process.
-vector<LineString*>*
+std::vector<std::unique_ptr<LineString>>
 LineMerger::getMergedLineStrings()
     merge();
     // Explicitly give ownership to the caller.
-    vector<LineString*>* ret = mergedLineStrings;
-    mergedLineStrings = nullptr;
+    auto ret = std::move(mergedLineStrings);
+    mergedLineStrings.clear();
     return ret;
diff --git a/tests/unit/capi/GEOSLineMergeTest.cpp b/tests/unit/capi/GEOSLineMergeTest.cpp
new file mode 100644
index 0000000..59ae269
--- /dev/null
+++ b/tests/unit/capi/GEOSLineMergeTest.cpp
@@ -0,0 +1,70 @@
+// Test Suite for C-API GEOSLineMerge
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+// std
+#include <cstdarg>
+#include <cstdio>
+namespace tut {
+// Test Group
+// Common data used in test cases.
+struct test_capigeoslinemerge_data {
+    static void
+    notice(const char* fmt, ...)
+        std::fprintf(stdout, "NOTICE: ");
+        va_list ap;
+        va_start(ap, fmt);
+        std::vfprintf(stdout, fmt, ap);
+        va_end(ap);
+        std::fprintf(stdout, "\n");
+    test_capigeoslinemerge_data()
+        initGEOS(notice, notice);
+    ~test_capigeoslinemerge_data()
+        finishGEOS();
+typedef test_group<test_capigeoslinemerge_data> group;
+typedef group::object object;
+group test_capigeoslinemerge_group("capi::GEOSLineMerge");
+// Test Cases
+template<>
+template<>
+void object::test<1>
+    auto input = GEOSGeomFromWKT("MULTILINESTRING((0 0, 0 100),(0 -5, 0 0))");
+    auto result = GEOSLineMerge(input);
+    auto expected = GEOSGeomFromWKT("LINESTRING(0 -5,0 0,0 100)");
+    ensure(GEOSEqualsExact(result, expected, 0));
+    GEOSGeom_destroy(input);
+    GEOSGeom_destroy(result);
+    GEOSGeom_destroy(expected);
+} // namespace tut
diff --git a/tests/unit/operation/linemerge/LineMergerTest.cpp b/tests/unit/operation/linemerge/LineMergerTest.cpp
index 6ede138..19906c2 100644
--- a/tests/unit/operation/linemerge/LineMergerTest.cpp
+++ b/tests/unit/operation/linemerge/LineMergerTest.cpp
@@ -36,10 +36,9 @@ struct test_linemerger_data {
     std::vector<const geos::geom::Geometry*> inpGeoms;
     std::vector<const geos::geom::Geometry*> expGeoms;
-    LineVect* mrgGeoms;
     test_linemerger_data()
-        : wktreader(), wktwriter(), mrgGeoms(nullptr)
+        : wktreader(), wktwriter()
         wktwriter.setTrim(true);
@@ -48,10 +47,6 @@ struct test_linemerger_data {
         delAll(inpGeoms);
         delAll(expGeoms);
-        if(mrgGeoms) {
-            delAll(*mrgGeoms);
-            delete mrgGeoms;
     GeomPtr
@@ -79,8 +74,8 @@ struct test_linemerger_data {
         readWKT(expectedWKT, expGeoms);
         lineMerger.add(&inpGeoms);
-        mrgGeoms = lineMerger.getMergedLineStrings();
-        compare(expGeoms, *mrgGeoms, compareDirections);
+        auto mrgGeoms = lineMerger.getMergedLineStrings();
+        compare(expGeoms, mrgGeoms, compareDirections);
@@ -110,10 +105,8 @@ struct test_linemerger_data {
     contains(TargetContainer& actualGeometries,
              const Geom* g, bool exact)
-        for(typename TargetContainer::const_iterator
-                i = actualGeometries.begin(),
-                e = actualGeometries.end(); i != e; ++i) {
-            Geom* element = dynamic_cast<Geom*>(*i);
+        for(const auto& e : actualGeometries) {
+            Geom* element = dynamic_cast<Geom*>(e.get());
             if(exact && element->equalsExact(g)) {
                 return true;
@@ -288,10 +281,10 @@ void object::test<8>
     // Merge MultiLineString into LineString
     LineMerger lineMerger;
     lineMerger.add(lines1234.get());
     GeomPtr expected(readWKT("LINESTRING(0 0, 0 5, 5 5, 5 0, 0 0)"));
-    ensure(contains(*mrgGeoms, expected.get(), true));
+    ensure(contains(mrgGeoms, expected.get(), true));
 } // namespace tut
diff --git a/tests/xmltester/XMLTester.cpp b/tests/xmltester/XMLTester.cpp
index c133809..b44cf31 100644
--- a/tests/xmltester/XMLTester.cpp
+++ b/tests/xmltester/XMLTester.cpp
@@ -1544,11 +1544,9 @@ XMLTester::parseTest(const tinyxml2::XMLNode* node)
             LineMerger merger;
             merger.add(p_gT);
-            std::unique_ptr< std::vector<geom::LineString*> > lines(merger.getMergedLineStrings());
-            std::vector<geom::Geometry*>* newgeoms = new std::vector<geom::Geometry*>(lines->begin(),
-                    lines->end());
+            auto lines = merger.getMergedLineStrings();
-            GeomPtr gRealRes(factory->createGeometryCollection(newgeoms));
+            GeomPtr gRealRes(factory->createGeometryCollection(std::move(lines)));
             gRealRes->normalize();
             if(gRes->compareTo(gRealRes.get()) == 0) {
Summary of changes:
 capi/geos_ts_c.cpp                                 |  4 +-
 doc/example.cpp                                    |  7 ++--
 include/geos/geom/GeometryFactory.h                |  6 +++
 include/geos/operation/linemerge/LineMerger.h      |  7 ++--
 src/geom/GeometryFactory.cpp                       | 44 +++++++++++++++++++++-
 src/operation/buffer/BufferBuilder.cpp             | 10 ++---
 src/operation/linemerge/LineMerger.cpp             | 14 +++----
 ...OSInterpolateTest.cpp => GEOSLineMergeTest.cpp} | 34 +++++++++--------
 tests/unit/operation/linemerge/LineMergerTest.cpp  | 21 ++++-------
 tests/xmltester/XMLTester.cpp                      |  6 +--
 10 files changed, 96 insertions(+), 57 deletions(-)
 copy tests/unit/capi/{GEOSInterpolateTest.cpp => GEOSLineMergeTest.cpp} (51%)
hooks/post-receive
More information about the geos-commits mailing list
