[geos-commits] [SCM] GEOS branch master updated.	545f6452bd758fdbdc2e09bf2062da25c58b6462
    git at osgeo.org
    git at osgeo.org
    Wed Jan 22 09:17:57 PST 2020
the project "GEOS".
       via  545f6452bd758fdbdc2e09bf2062da25c58b6462 (commit)
       via  d0c4b936ff25a5cd6e35f836632ae2d02b6de581 (commit)
       via  4b902f01efadd214ffce8e14af5ba6fc871ac60b (commit)
       via  eda128a16d12df1aaf622463dcb1d4c7214980ab (commit)
      from  7d02cb4ab4bc1e62bb36c51a26511ba7a9697f28 (commit)
revisions in full, below.
commit 545f6452bd758fdbdc2e09bf2062da25c58b6462
Merge: 7d02cb4 d0c4b93
Author: Dan Baston <dbaston at gmail.com>
Date:   Wed Jan 22 12:17:32 2020 -0500
    Merge remote-tracking branch 'origin/msvc-warnings'
commit d0c4b936ff25a5cd6e35f836632ae2d02b6de581
Date:   Tue Jan 21 13:44:15 2020 -0500
    Declare nan as constexpr
diff --git a/tests/unit/capi/GEOSEqualsTest.cpp b/tests/unit/capi/GEOSEqualsTest.cpp
index b056240..36b1fe0 100644
--- a/tests/unit/capi/GEOSEqualsTest.cpp
+++ b/tests/unit/capi/GEOSEqualsTest.cpp
@@ -127,7 +127,7 @@ void object::test<4>
     GEOSCoordSequence* cs = GEOSCoordSeq_create(5, 2);
-    double nan = std::numeric_limits<double>::quiet_NaN();
+    constexpr double nan = std::numeric_limits<double>::quiet_NaN();
     GEOSCoordSeq_setX(cs, 0, 1);
     GEOSCoordSeq_setY(cs, 0, 1);
     for(unsigned int i = 1; i < 4; ++i) {
diff --git a/tests/unit/capi/GEOSIntersectsTest.cpp b/tests/unit/capi/GEOSIntersectsTest.cpp
index fa2a1b4..efcc3e5 100644
--- a/tests/unit/capi/GEOSIntersectsTest.cpp
+++ b/tests/unit/capi/GEOSIntersectsTest.cpp
commit 4b902f01efadd214ffce8e14af5ba6fc871ac60b
Date:   Tue Jan 21 13:30:50 2020 -0500
    Update deprecated throw() specifications
diff --git a/include/geos/algorithm/NotRepresentableException.h b/include/geos/algorithm/NotRepresentableException.h
index 47207be..f203b72 100644
--- a/include/geos/algorithm/NotRepresentableException.h
+++ b/include/geos/algorithm/NotRepresentableException.h
@@ -36,7 +36,7 @@ class GEOS_DLL NotRepresentableException: public util::GEOSException {
 public:
     NotRepresentableException();
     NotRepresentableException(std::string msg);
-    ~NotRepresentableException() throw() override {}
+    ~NotRepresentableException() noexcept override {}
 } // namespace geos::algorithm
diff --git a/include/geos/io/ParseException.h b/include/geos/io/ParseException.h
index b713b77..86e73c4 100644
--- a/include/geos/io/ParseException.h
+++ b/include/geos/io/ParseException.h
@@ -43,7 +43,7 @@ public:
     ParseException(const std::string& msg, double num);
-    ~ParseException() throw() override {}
+    ~ParseException() noexcept override {}
 private:
     static std::string stringify(double num);
diff --git a/include/geos/util/AssertionFailedException.h b/include/geos/util/AssertionFailedException.h
index a41c8d4..f4ca30c 100644
--- a/include/geos/util/AssertionFailedException.h
+++ b/include/geos/util/AssertionFailedException.h
@@ -41,7 +41,7 @@ public:
         GEOSException("AssertionFailedException", msg)
-    ~AssertionFailedException() throw() override {}
+    ~AssertionFailedException() noexcept override {}
 } // namespace geos.util
diff --git a/include/geos/util/IllegalArgumentException.h b/include/geos/util/IllegalArgumentException.h
index f47647d..6afdd3f 100644
--- a/include/geos/util/IllegalArgumentException.h
+++ b/include/geos/util/IllegalArgumentException.h
         GEOSException("IllegalArgumentException", msg)
-    ~IllegalArgumentException() throw() override {}
+    ~IllegalArgumentException() noexcept override {}
 } // namespace geos::util
diff --git a/include/geos/util/IllegalStateException.h b/include/geos/util/IllegalStateException.h
index 60f8ed3..55c23e5 100644
--- a/include/geos/util/IllegalStateException.h
+++ b/include/geos/util/IllegalStateException.h
@@ -36,7 +36,7 @@ public:
         GEOSException("IllegalStateException", msg)
-    ~IllegalStateException() throw() override {}
+    ~IllegalStateException() noexcept override {}
diff --git a/include/geos/util/TopologyException.h b/include/geos/util/TopologyException.h
index ed4d473..bf0c843 100644
--- a/include/geos/util/TopologyException.h
+++ b/include/geos/util/TopologyException.h
@@ -50,7 +50,7 @@ public:
         pt(newPt)
-    ~TopologyException() throw() override {}
+    ~TopologyException() noexcept override {}
     geom::Coordinate&
     getCoordinate()
diff --git a/include/geos/util/UnsupportedOperationException.h b/include/geos/util/UnsupportedOperationException.h
index e3939ca..8ac72bc 100644
--- a/include/geos/util/UnsupportedOperationException.h
+++ b/include/geos/util/UnsupportedOperationException.h
@@ -45,7 +45,7 @@ public:
         GEOSException("UnsupportedOperationException", msg)
-    ~UnsupportedOperationException() throw() override {}
+    ~UnsupportedOperationException() noexcept override {}
commit eda128a16d12df1aaf622463dcb1d4c7214980ab
Date:   Tue Jan 21 13:31:30 2020 -0500
    Remove unreachable code
diff --git a/capi/geos_ts_c.cpp b/capi/geos_ts_c.cpp
index e60e1bd..0dfdc6f 100644
--- a/capi/geos_ts_c.cpp
+++ b/capi/geos_ts_c.cpp
@@ -1367,7 +1367,6 @@ extern "C" {
             const Polygon* p = dynamic_cast<const Polygon*>(g1);
             if(!p) {
                 throw IllegalArgumentException("Argument is not a Polygon");
-                return -1;
             return static_cast<int>(p->getNumInteriorRing());
Summary of changes:
 capi/geos_ts_c.cpp                                 | 1 -
 include/geos/algorithm/NotRepresentableException.h | 2 +-
 include/geos/io/ParseException.h                   | 2 +-
 include/geos/util/AssertionFailedException.h       | 2 +-
 include/geos/util/IllegalArgumentException.h       | 2 +-
 include/geos/util/IllegalStateException.h          | 2 +-
 include/geos/util/TopologyException.h              | 2 +-
 include/geos/util/UnsupportedOperationException.h  | 2 +-
 tests/unit/capi/GEOSEqualsTest.cpp                 | 2 +-
 tests/unit/capi/GEOSIntersectsTest.cpp             | 2 +-
 10 files changed, 9 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits
