[geos-commits] [SCM] GEOS branch master updated. c6774a6a48b2260a370844ffe2de13f69f6de282
git at osgeo.org
git at osgeo.org
Wed Jul 29 12:54:10 PDT 2020
the project "GEOS".
via c6774a6a48b2260a370844ffe2de13f69f6de282 (commit)
from a37514038231721381e57b07fcef383f09586a8d (commit)
revisions in full, below.
commit c6774a6a48b2260a370844ffe2de13f69f6de282
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Jul 29 12:44:42 2020 -0700
Add compile-time flags to turn on OverlayNG
In autoconf, --enable-overlayng
In cmake, use -DDISABLE_OVERLAYNG=OFF
diff --git a/CMakeLists.txt b/CMakeLists.txt
index f0f24ca..159f465 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -166,6 +166,17 @@ else()
endif()
+# Target geos_cxx_flags: overlayng code
+option(DISABLE_OVERLAYNG "Disable overlayng algorithms" ON)
+if(NOT DISABLE_OVERLAYNG)
+ target_compile_definitions(geos_cxx_flags INTERFACE USE_OVERLAYNG)
+else()
+ message(STATUS
+ "GEOS: DISABLING overlayng algorithms")
+endif()
# Target geos_developer_cxx_flags: developer mode compilation flags
# Do NOT install this target for end-users!
diff --git a/configure.ac b/configure.ac
index 3f73659..9386170 100644
--- a/configure.ac
+++ b/configure.ac
@@ -149,6 +149,26 @@ else
AC_MSG_RESULT([no])
fi
+dnl --------------------------------------------------------------------
+dnl - check whether user has requested overlayng
+AC_ARG_ENABLE([overlayng], [ --enable-overlayng Enable use of new overlay],
+ [case "${enableval}" in
+ yes) use_overlayng=true ;;
+ no) use_overlayng=false ;;
+ *) AC_MSG_ERROR(bad value ${enableval} for --enable-overlayng) ;;
+ esac],
+ [use_overlayng=false]
+if test x"$use_overlayng" = xtrue; then
+ OVERLAYNG_FLAGS="-DUSE_OVERLAYNG"
+else
+ OVERLAYNG_FLAGS=""
+fi
dnl - Append default C++ and C flags
@@ -183,7 +203,7 @@ NUMERICFLAGS=""
AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -ffloat-store], [dummy_cv_ffloat_store], [-ffloat-store], [], [NUMERICFLAGS="$NUMERICFLAGS -ffloat-store"], [])
HUSHWARNING="-DUSE_UNSTABLE_GEOS_CPP_API"
-DEFAULTFLAGS="${WARNFLAGS} ${NUMERICFLAGS} ${HUSHWARNING}"
+DEFAULTFLAGS="${WARNFLAGS} ${NUMERICFLAGS} ${HUSHWARNING} ${OVERLAYNG_FLAGS}"
AM_CXXFLAGS="${AM_CXXFLAGS} ${DEFAULTFLAGS}"
AM_CFLAGS="${AM_CFLAGS} ${DEFAULTFLAGS}"
@@ -294,6 +314,7 @@ if test x"$use_ruby" = xtrue; then
fi
AM_CONDITIONAL(ENABLE_RUBY, [ test x"$use_ruby" = xtrue ])
dnl - do operating-system specific things
@@ -482,5 +503,6 @@ dnl -- echo "Boost UTF: $use_boost_utf"
echo "Swig: $use_swig"
echo "Python bindings: $use_python"
echo "Ruby bindings: $use_ruby"
+echo "OverlayNG: $use_overlayng"
dnl -- echo "---------------------------------------"
diff --git a/src/geom/Geometry.cpp b/src/geom/Geometry.cpp
index b0f09be..93dcfaa 100644
--- a/src/geom/Geometry.cpp
+++ b/src/geom/Geometry.cpp
@@ -51,6 +51,7 @@
#include <geos/operation/buffer/BufferOp.h>
#include <geos/operation/distance/DistanceOp.h>
#include <geos/operation/IsSimpleOp.h>
+#include <geos/operation/overlayng/OverlayNGSnapIfNeeded.h>
#include <geos/io/WKBWriter.h>
#include <geos/io/WKTWriter.h>
#include <geos/version.h>
@@ -550,7 +551,11 @@ Geometry::intersection(const Geometry* other) const
#endif
+#ifdef USE_OVERLAYNG
+ return operation::overlayng::OverlayNGSnapIfNeeded::Intersection(this, other);
+#else
return BinaryOp(this, other, overlayOp(OverlayOp::opINTERSECTION));
+#endif
std::unique_ptr<Geometry>
@@ -602,7 +607,11 @@ Geometry::Union(const Geometry* other) const
#endif
+ return operation::overlayng::OverlayNGSnapIfNeeded::Union(this, other);
+#else
return BinaryOp(this, other, overlayOp(OverlayOp::opUNION));
+#endif
/* public */
@@ -610,7 +619,11 @@ Geometry::Ptr
Geometry::Union() const
using geos::operation::geounion::UnaryUnionOp;
+ return operation::overlayng::OverlayNGSnapIfNeeded::Union(this);
+#else
return UnaryUnionOp::Union(*this);
+#endif
@@ -625,7 +638,11 @@ Geometry::difference(const Geometry* other) const
return clone();
+ return operation::overlayng::OverlayNGSnapIfNeeded::Difference(this, other);
+#else
return BinaryOp(this, other, overlayOp(OverlayOp::opDIFFERENCE));
+#endif
@@ -673,7 +690,12 @@ Geometry::symDifference(const Geometry* other) const
return std::unique_ptr<Geometry>(_factory->buildGeometry(v));
+ return operation::overlayng::OverlayNGSnapIfNeeded::SymDifference(this, other);
+#else
return BinaryOp(this, other, overlayOp(OverlayOp::opSYMDIFFERENCE));
+#endif
int
Summary of changes:
CMakeLists.txt | 11 +++++++++++
configure.ac | 24 +++++++++++++++++++++++-
src/geom/Geometry.cpp | 22 ++++++++++++++++++++++
3 files changed, 56 insertions(+), 1 deletion(-)
hooks/post-receive
More information about the geos-commits
