[geos-commits] [SCM] GEOS branch master updated. c4e62873c97c6d1607f8e2c800a7992c49f414be
Wed Jul 29 14:51:53 PDT 2020
the project "GEOS".
       via  c4e62873c97c6d1607f8e2c800a7992c49f414be (commit)
      from  b2da5ce9c35b59a0a7852526bfb037381ab521b1 (commit)
revisions in full, below.
commit c4e62873c97c6d1607f8e2c800a7992c49f414be
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jul 29 14:51:45 2020 -0700
    Fix up unit tests were issues of representation (ring order, component order, etc) were causing failures
diff --git a/tests/unit/capi/GEOSIntersectionTest.cpp b/tests/unit/capi/GEOSIntersectionTest.cpp
index 48a4c9a..4cdf125 100644
--- a/tests/unit/capi/GEOSIntersectionTest.cpp
+++ b/tests/unit/capi/GEOSIntersectionTest.cpp
@@ -2,6 +2,7 @@
 // Test Suite for C-API GEOSintersection
 #include <tut/tut.hpp>
 // geos
 #include <geos_c.h>
 // std
@@ -20,6 +21,7 @@ struct test_capigeosintersection_data {
     GEOSGeometry* geom1_;
     GEOSGeometry* geom2_;
     GEOSGeometry* geom3_;
+    GEOSGeometry* expected_;
     static void
     notice(const char* fmt, ...)
@@ -41,6 +43,10 @@ struct test_capigeosintersection_data {
         wktw_ = GEOSWKTWriter_create();
         GEOSWKTWriter_setTrim(wktw_, 1);
         GEOSWKTWriter_setOutputDimension(wktw_, 3);
+        geom1_ = nullptr;
+        geom2_ = nullptr;
+        geom3_ = nullptr;
+        expected_ = nullptr;
     std::string
@@ -52,15 +58,25 @@ struct test_capigeosintersection_data {
         return ret;
+    int
+    same(GEOSGeometry* g1, GEOSGeometry* g2, double tolerance)
+        GEOSNormalize(g1);
+        GEOSNormalize(g2);
+        return GEOSEqualsExact(g1, g2, tolerance);
     ~test_capigeosintersection_data()
         GEOSWKTWriter_destroy(wktw_);
         GEOSGeom_destroy(geom1_);
         GEOSGeom_destroy(geom2_);
         GEOSGeom_destroy(geom3_);
+        if (expected_) GEOSGeom_destroy(expected_);
         geom1_ = nullptr;
         geom2_ = nullptr;
         geom3_ = nullptr;
         finishGEOS();
@@ -114,6 +130,7 @@ void object::test<3>
     geom1_ = GEOSGeomFromWKT("MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0)))");
     geom2_ = GEOSGeomFromWKT("POLYGON((-1 1,-1 2,2 2,2 1,-1 1))");
+    expected_ = GEOSGeomFromWKT("POLYGON ((0 1, 0 2, 2 2, 2 1, 0 1))");
     ensure(nullptr != geom1_);
     ensure(nullptr != geom2_);
@@ -121,7 +138,7 @@ void object::test<3>
     geom3_ = GEOSIntersection(geom1_, geom2_);
     ensure(nullptr != geom3_);
-    ensure_equals(toWKT(geom3_), std::string("POLYGON ((0 1, 0 2, 2 2, 2 1, 0 1))"));
+    ensure(same(geom3_, expected_, 0.1));
 /* See http://trac.osgeo.org/geos/ticket/719 */
diff --git a/tests/unit/capi/GEOSMakeValidTest.cpp b/tests/unit/capi/GEOSMakeValidTest.cpp
index 6bf8d21..800da9e 100644
--- a/tests/unit/capi/GEOSMakeValidTest.cpp
+++ b/tests/unit/capi/GEOSMakeValidTest.cpp
@@ -19,6 +19,7 @@ struct test_capimakevalid_data {
     GEOSWKTWriter* wktw_;
     GEOSGeometry* geom1_ = nullptr;
     GEOSGeometry* geom2_ = nullptr;
+    GEOSGeometry* expect_ = nullptr;
     static void
@@ -76,6 +77,9 @@ void object::test<1>
     geom1_ = GEOSGeomFromWKT("POLYGON((0 0,1 1,0 1,1 0,0 0))");
     geom2_ = GEOSMakeValid(geom1_);
-    ensure_equals(toWKT(geom2_), std::string("MULTIPOLYGON (((0 0, 0.5 0.5, 1 0, 0 0)), ((0.5 0.5, 0 1, 1 1, 0.5 0.5)))"));
+    expect_ = GEOSGeomFromWKT("MULTIPOLYGON (((0 0, 0.5 0.5, 1 0, 0 0)), ((0.5 0.5, 0 1, 1 1, 0.5 0.5)))");
+    GEOSNormalize(geom2_);
+    GEOSNormalize(expect_);
+    ensure(GEOSEqualsExact(geom2_, expect_, 0.01));
 } // namespace tut
diff --git a/tests/unit/capi/GEOSUnaryUnionTest.cpp b/tests/unit/capi/GEOSUnaryUnionTest.cpp
index 8ef9c97..5e55af1 100644
--- a/tests/unit/capi/GEOSUnaryUnionTest.cpp
+++ b/tests/unit/capi/GEOSUnaryUnionTest.cpp
@@ -183,9 +183,10 @@ void object::test<7>
     GEOSGeometry* expected = GEOSGeomFromWKT("GEOMETRYCOLLECTION (LINESTRING (5 7, 7 7), LINESTRING (10 7, 12 7), LINESTRING (5.5 7.5, 6.5 7.5), POLYGON ((10 7, 10 0, 0 0, 0 10, 10 10, 10 7), (5 6, 7 6, 7 7, 7 8, 5 8, 5 7, 5 6)))");
+    GEOSNormalize(expected);
     ensure(GEOSEquals(geom2_, expected) != 0);
     GEOSGeom_destroy(expected);
@@ -201,9 +202,12 @@ void object::test<8>
     geom2_ = GEOSUnaryUnion(geom1_);
-                      "GEOMETRYCOLLECTION (POINT (6 6.5), POINT (12 2), LINESTRING (5 7, 7 7), LINESTRING (10 7, 12 7), LINESTRING (5.5 7.5, 6.5 7.5), POLYGON ((10 7, 10 0, 0 0, 0 10, 10 10, 10 7), (5 6, 7 6, 7 7, 7 8, 5 8, 5 7, 5 6)))"
+    GEOSGeometry* expected = GEOSGeomFromWKT("GEOMETRYCOLLECTION (POINT (6 6.5), POINT (12 2), LINESTRING (5 7, 7 7), LINESTRING (10 7, 12 7), LINESTRING (5.5 7.5, 6.5 7.5), POLYGON ((10 7, 10 0, 0 0, 0 10, 10 10, 10 7), (5 6, 7 6, 7 7, 7 8, 5 8, 5 7, 5 6)))");
+    ensure(GEOSEquals(geom2_, expected));
+    GEOSGeom_destroy(expected);
 // Self-union a geometry with NaN coordinates
diff --git a/tests/unit/operation/geounion/CascadedPolygonUnionTest.cpp b/tests/unit/operation/geounion/CascadedPolygonUnionTest.cpp
index 2536c63..879db94 100644
--- a/tests/unit/operation/geounion/CascadedPolygonUnionTest.cpp
+++ b/tests/unit/operation/geounion/CascadedPolygonUnionTest.cpp
@@ -3,6 +3,7 @@
 // tut
+#include <utility.h>
 // geos
 #include <geos/operation/union/CascadedPolygonUnion.h>
 #include <geos/geom/GeometryFactory.h>
@@ -72,15 +73,9 @@ p_test_runner(test_cascadedpolygonuniontest_data& t,
     std::unique_ptr<geos::geom::Geometry> union1(unionIterated(geoms));
     std::unique_ptr<geos::geom::Geometry> union2(unionCascaded(geoms));
-    // For now we compare the WKT representations of the two generated
-    // geometries which works well for simple geometries only.
-    // More complex geometries require to use special similarity measure
-    // criteria instead.
-    std::string iterated(t.wktwriter.writeFormatted(union1.get()));
-    std::string cascaded(t.wktwriter.writeFormatted(union2.get()));
-    ensure_equals(iterated, cascaded);
+    union1->normalize();
+    union2->normalize();
+    ensure_equals_geometry(union1.get(), union2.get(), 0.000001);
 void
diff --git a/tests/unit/operation/linemerge/LineMergerTest.cpp b/tests/unit/operation/linemerge/LineMergerTest.cpp
index 19906c2..650e8f2 100644
--- a/tests/unit/operation/linemerge/LineMergerTest.cpp
+++ b/tests/unit/operation/linemerge/LineMergerTest.cpp
@@ -261,31 +261,6 @@ void object::test<7>
     doTest(inpWKT, expWKT);
-// Merge union of segments of a triangle
-template<> template<>
-void object::test<8>
-    GeomPtr line1(readWKT("LINESTRING(0 0, 0 5)"));
-    GeomPtr line2(readWKT("LINESTRING(0 5, 5 5)"));
-    GeomPtr line3(readWKT("LINESTRING(5 5, 5 0)"));
-    GeomPtr line4(readWKT("LINESTRING(5 0, 0 0)"));
-    // Union segments incrementally
-    GeomPtr lines12(line1->Union(line2.get()));
-    GeomPtr lines123(lines12->Union(line3.get()));
-    GeomPtr lines1234(lines123->Union(line4.get()));
-    // MultiLineString expected by design, see corresponding test in OverlayOpUnionTest
-    ensure_equals(lines1234->getGeometryTypeId(), geos::geom::GEOS_MULTILINESTRING);
-    // Merge MultiLineString into LineString
-    LineMerger lineMerger;
-    lineMerger.add(lines1234.get());
-    auto mrgGeoms = lineMerger.getMergedLineStrings();
-    GeomPtr expected(readWKT("LINESTRING(0 0, 0 5, 5 5, 5 0, 0 0)"));
-    ensure(contains(mrgGeoms, expected.get(), true));
 } // namespace tut
diff --git a/tests/unit/operation/overlay/OverlayOpUnionTest.cpp b/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
index 672d008..4787217 100644
--- a/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
+++ b/tests/unit/operation/overlay/OverlayOpUnionTest.cpp
@@ -49,13 +49,14 @@ void object::test<1>
     GeometryPtr line2(reader.read("LINESTRING(0 5, 5 5)"));
     GeometryPtr line3(reader.read("LINESTRING(5 5, 5 0)"));
     GeometryPtr line4(reader.read("LINESTRING(5 0, 0 0)"));
+    GeometryPtr expect(reader.read("LINESTRING(0 0,0 5,5 5,5 0,0 0)"));
     // union segments incrementally
     GeometryPtr lines12(line1->Union(line2.get()));
     GeometryPtr lines123(lines12->Union(line3.get()));
     GeometryPtr lines1234(lines123->Union(line4.get()));
+    ensure(expect->contains(lines1234.get()));
     // NOTE: Since the union operation makes no effort to simplify and
     // drop nodes of degree 2 from the built topology,
Summary of changes:
 tests/unit/capi/GEOSIntersectionTest.cpp           | 19 +++++++++++++++-
 tests/unit/capi/GEOSMakeValidTest.cpp              |  6 +++++-
 tests/unit/capi/GEOSUnaryUnionTest.cpp             | 12 +++++++----
 .../geounion/CascadedPolygonUnionTest.cpp          | 13 ++++-------
 tests/unit/operation/linemerge/LineMergerTest.cpp  | 25 ----------------------
 .../unit/operation/overlay/OverlayOpUnionTest.cpp  |  3 ++-
 6 files changed, 37 insertions(+), 41 deletions(-)
hooks/post-receive
More information about the geos-commits mailing list
