[geos-commits] [SCM] GEOS branch master updated. 0d7d79361ce96e18b51c4ed49de6830f12574cea
git at osgeo.org
git at osgeo.org
Fri Jul 31 08:35:42 PDT 2020
the project "GEOS".
via 0d7d79361ce96e18b51c4ed49de6830f12574cea (commit)
from 4ef6f82756cfc3d6bf6a85c698b0bb01b2176fff (commit)
revisions in full, below.
commit 0d7d79361ce96e18b51c4ed49de6830f12574cea
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Fri Jul 31 08:34:49 2020 -0700
Use BinaryOp instead of OverlayOp in order to access old fall-back behaviour in overlay. References #1037
diff --git a/src/operation/valid/MakeValid.cpp b/src/operation/valid/MakeValid.cpp
index 865a11d..eaa10e9 100644
--- a/src/operation/valid/MakeValid.cpp
+++ b/src/operation/valid/MakeValid.cpp
@@ -24,6 +24,7 @@
#include <geos/operation/overlay/OverlayOp.h>
#include <geos/operation/polygonize/BuildArea.h>
#include <geos/operation/union/UnaryUnionOp.h>
+#include <geos/geom/BinaryOp.h>
#include <geos/geom/Geometry.h>
#include <geos/geom/GeometryCollection.h>
#include <geos/geom/GeometryFactory.h>
@@ -46,8 +47,7 @@
#endif
using namespace geos::geom;
-using geos::operation::overlay::OverlayOp;
-using geos::operation::geounion::UnaryUnionOp;
+using namespace geos::operation::overlay;
namespace geos {
namespace operation { // geos.operation
@@ -57,22 +57,19 @@ namespace valid { // geos.operation.valid
static std::unique_ptr<geom::Geometry>
makeValidSymDifference(const geom::Geometry* g0, const geom::Geometry* g1)
- std::unique_ptr<Geometry> r(OverlayOp::overlayOp(g0, g1, OverlayOp::opSYMDIFFERENCE));
- return r;
+ return BinaryOp(g0, g1, overlayOp(OverlayOp::opSYMDIFFERENCE));
makeValidDifference(const geom::Geometry* g0, const geom::Geometry* g1)
- std::unique_ptr<Geometry> r(OverlayOp::overlayOp(g0, g1, OverlayOp::opDIFFERENCE));
- return r;
+ return BinaryOp(g0, g1, overlayOp(OverlayOp::opDIFFERENCE));
makeValidUnion(const geom::Geometry* g0, const geom::Geometry* g1)
- std::unique_ptr<Geometry> r(OverlayOp::overlayOp(g0, g1, OverlayOp::opUNION));
- return r;
+ return BinaryOp(g0, g1, overlayOp(OverlayOp::opUNION));
diff --git a/tests/unit/capi/GEOSMakeValidTest.cpp b/tests/unit/capi/GEOSMakeValidTest.cpp
index 800da9e..319067a 100644
--- a/tests/unit/capi/GEOSMakeValidTest.cpp
+++ b/tests/unit/capi/GEOSMakeValidTest.cpp
@@ -53,8 +53,9 @@ struct test_capimakevalid_data {
~test_capimakevalid_data()
- GEOSGeom_destroy(geom1_);
- GEOSGeom_destroy(geom2_);
+ if (geom1_) GEOSGeom_destroy(geom1_);
+ if (geom2_) GEOSGeom_destroy(geom2_);
+ if (expect_) GEOSGeom_destroy(expect_);
GEOSWKTWriter_destroy(wktw_);
finishGEOS();
@@ -82,4 +83,23 @@ void object::test<1>
GEOSNormalize(expect_);
ensure(GEOSEqualsExact(geom2_, expect_, 0.01));
+template<>
+template<>
+void object::test<2>
+ const char* hex = "0103000000010000000900000062105839207df640378941e09d491c41ced67431387df640c667e7d398491c4179e92631387df640d9cef7d398491c41fa7e6abcf87df640cdcccc4c70491c41e3a59bc4527df64052b81e053f491c41cdcccccc5a7ef640e3a59bc407491c4104560e2da27df640aaf1d24dd3481c41e9263108c67bf64048e17a1437491c4162105839207df640378941e09d491c41";
+ geom1_ = GEOSGeomFromHEX_buf((uint8_t*)hex, std::strlen(hex));
+ geom2_ = GEOSMakeValid(geom1_);
+ expect_ = GEOSGeomFromWKT("GEOMETRYCOLLECTION(POLYGON((92114.014 463463.469,92115.5120743171 463462.206937429,92115.512 463462.207,92127.546 463452.075,92117.173 463439.755,92133.675 463425.942,92122.136 463412.826,92092.377 463437.77,92114.014 463463.469)),MULTIPOINT(92115.5120743171 463462.206937429,92122.136 463412.826))");
+ GEOSNormalize(geom2_);
+ GEOSNormalize(expect_);
+ ensure(GEOSEqualsExact(geom2_, expect_, 0.01));
} // namespace tut
Summary of changes:
src/operation/valid/MakeValid.cpp | 13 +++++--------
tests/unit/capi/GEOSMakeValidTest.cpp | 24 ++++++++++++++++++++++--
2 files changed, 27 insertions(+), 10 deletions(-)
hooks/post-receive
More information about the geos-commits
