[geos-commits] [SCM] GEOS branch master updated.	19dc3b19338c2aded5197ca0e5a5456b028defbd
    git at osgeo.org
    git at osgeo.org
    Sat Jun 20 05:19:18 PDT 2020
the project "GEOS".
       via  19dc3b19338c2aded5197ca0e5a5456b028defbd (commit)
       via  bfa50020fdf725fd9e6b96278f3af645cda4769f (commit)
      from  099e74b3127348e1f8544ab279b609e2fdc6cc74 (commit)
revisions in full, below.
commit 19dc3b19338c2aded5197ca0e5a5456b028defbd
Merge: 099e74b bfa5002
Author: Daniel Baston <dbaston at gmail.com>
Date:   Sat Jun 20 08:18:58 2020 -0400
    Merge remote-tracking branch 'dbaston/capi-tests'
commit bfa50020fdf725fd9e6b96278f3af645cda4769f
Date:   Fri Jan 17 22:47:18 2020 -0500
    Add some CAPI tests
diff --git a/tests/unit/capi/GEOSBoundaryTest.cpp b/tests/unit/capi/GEOSBoundaryTest.cpp
new file mode 100644
index 0000000..1368155
--- /dev/null
+++ b/tests/unit/capi/GEOSBoundaryTest.cpp
@@ -0,0 +1,38 @@
+#include <tut/tut.hpp>
+// geos
+#include <geos_c.h>
+#include "capi_test_utils.h"
+namespace tut {
+// Test Group
+struct test_geosboundary_data : public capitest::test_handlers {};
+typedef test_group<test_geosboundary_data> group;
+typedef group::object object;
+group test_geosboundary("capi::GEOSBoundary");
+template<>
+template<>
+void object::test<1>()
+    GEOSGeometry* input = GEOSGeomFromWKT("POLYGON ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
+    GEOSSetSRID(input, 3857);
+    GEOSGeometry* result = GEOSBoundary(input);
+    GEOSGeometry* expected = GEOSGeomFromWKT("MULTILINESTRING ((0 0, 10 0, 10 10, 0 10, 0 0), (1 1, 1 2, 2 2, 2 1, 1 1))");
+    ensure_equals(GEOSEqualsExact(result, expected, 0), 1);
+    ensure_equals(GEOSGetSRID(input), GEOSGetSRID(result));
+    GEOSGeom_destroy(input);
+    GEOSGeom_destroy(result);
+    GEOSGeom_destroy(expected);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSEnvelopeTest.cpp b/tests/unit/capi/GEOSEnvelopeTest.cpp
index 0000000..bc1a635
--- /dev/null
+++ b/tests/unit/capi/GEOSEnvelopeTest.cpp
@@ -0,0 +1,36 @@
+// geos
+namespace tut {
+// Test Group
+struct test_geosenvelope_data : public capitest::test_handlers {};
+typedef test_group<test_geosenvelope_data> group;
+group test_geosenvelope("capi::GEOSEnvelope");
+template<>
+template<>
+    GEOSGeometry* input = GEOSGeomFromWKT("LINESTRING (1 2, 4 5, 9 -2)");
+    GEOSGeometry* result = GEOSEnvelope(input);
+    GEOSGeometry* expected = GEOSGeomFromWKT("POLYGON ((1 -2, 9 -2, 9 5, 1 5, 1 -2))");
+} // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_createLineStringTest.cpp b/tests/unit/capi/GEOSGeom_createLineStringTest.cpp
index 0000000..a9181bc
--- /dev/null
+++ b/tests/unit/capi/GEOSGeom_createLineStringTest.cpp
@@ -0,0 +1,40 @@
+// geos
+namespace tut {
+// Test Group
+struct test_geosgeom_createlinestring_data : public capitest::test_handlers {};
+typedef test_group<test_geosgeom_createlinestring_data> group;
+group test_geosgeom_createlinestring("capi::GEOSGeom_createLineString");
+template<>
+template<>
+    GEOSCoordSequence* seq = GEOSCoordSeq_create(3, 2);
+    GEOSCoordSeq_setXY(seq, 0, 1, 2);
+    GEOSCoordSeq_setXY(seq, 1, 4, 5);
+    GEOSCoordSeq_setXY(seq, 2, 9, -2);
+    GEOSGeometry* result = GEOSGeom_createLineString(seq);
+    GEOSGeometry* expected = GEOSGeomFromWKT("LINESTRING (1 2, 4 5, 9 -2)");
+} // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp b/tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp
index 0000000..62b12b3
--- /dev/null
+++ b/tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp
@@ -0,0 +1,50 @@
+// geos
+namespace tut {
+// Test Group
+struct test_geosgeom_getcoordseq_data : public capitest::test_handlers {};
+typedef test_group<test_geosgeom_getcoordseq_data> group;
+group test_geosgeom_getcoordseq("capi::GEOSGeom_getCoordSeq");
+template<>
+template<>
+    const GEOSCoordSequence* seq = GEOSGeom_getCoordSeq(input);
+    double x = -1;
+    double y = -1;
+    GEOSCoordSeq_getXY(seq,  2, &x, &y);
+    ensure_equals(x, 9);
+    ensure_equals(y, -2);
+template<>
+template<>
+void object::test<2>()
+    GEOSGeometry* input = GEOSGeomFromWKT("POLYGON ((1 1, 2 1, 2 2, 1 1))");
+    ensure(seq == nullptr); // can't get seq from Polygon
+} // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp b/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp
index 0000000..fa736e9
--- /dev/null
+++ b/tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp
@@ -0,0 +1,38 @@
+// geos
+namespace tut {
+// Test Group
+struct test_geosgeom_getcoordinatedimension_data : public capitest::test_handlers {};
+typedef test_group<test_geosgeom_getcoordinatedimension_data> group;
+group test_geosgeom_getcoordinatedimension("capi::GEOSGeom_getCoordinateDimension");
+template<>
+template<>
+    GEOSGeometry* point = GEOSGeomFromWKT("POINT (4 2 7)");
+    GEOSGeometry* line = GEOSGeomFromWKT("LINESTRING (4 2 7, 8 2 9)");
+    GEOSGeometry* poly = GEOSGeomFromWKT("POLYGON ((0 0, 1 0, 1 1, 0 0))");
+    ensure_equals(GEOSGeom_getCoordinateDimension(point), 3);
+    ensure_equals(GEOSGeom_getCoordinateDimension(line), 3);
+    ensure_equals(GEOSGeom_getCoordinateDimension(poly), 2);
+    GEOSGeom_destroy(point);
+    GEOSGeom_destroy(line);
+    GEOSGeom_destroy(poly);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp b/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp
index 0000000..f03296a
--- /dev/null
+++ b/tests/unit/capi/GEOSGeom_getDimensionsTest.cpp
@@ -0,0 +1,38 @@
+// geos
+namespace tut {
+// Test Group
+struct test_geosgeom_getdimensions_data : public capitest::test_handlers {};
+typedef test_group<test_geosgeom_getdimensions_data> group;
+group test_geosgeom_getdimensions("capi::GEOSGeom_getDimensions");
+template<>
+template<>
+    ensure_equals(GEOSGeom_getDimensions(point), 0);
+    ensure_equals(GEOSGeom_getDimensions(line), 1);
+    ensure_equals(GEOSGeom_getDimensions(poly), 2);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSGetNumInteriorRingsTest.cpp b/tests/unit/capi/GEOSGetNumInteriorRingsTest.cpp
index 0000000..ce9d96b
--- /dev/null
+++ b/tests/unit/capi/GEOSGetNumInteriorRingsTest.cpp
@@ -0,0 +1,42 @@
+// geos
+namespace tut {
+// Test Group
+struct test_geosgetnuminteriorrings_data : public capitest::test_handlers {};
+typedef test_group<test_geosgetnuminteriorrings_data> group;
+group test_getnuminteriorrings("capi::GEOSGetNumInteriorRings");
+template<>
+template<>
+    GEOSGeometry* input = GEOSGeomFromWKT("POLYGON ((1 -2, 9 -2, 9 5, 1 5, 1 -2))");
+    ensure_equals(GEOSGetNumInteriorRings(input), 0);
+template<>
+template<>
+    GEOSGeometry* input = GEOSGeomFromWKT("LINESTRING (3 8, 4 7)");
+    ensure_equals(GEOSGetNumInteriorRings(input), -1);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSLengthTest.cpp b/tests/unit/capi/GEOSLengthTest.cpp
index 0000000..9214e76
--- /dev/null
+++ b/tests/unit/capi/GEOSLengthTest.cpp
@@ -0,0 +1,36 @@
+// geos
+namespace tut {
+// Test Group
+struct test_geoslength_data : public capitest::test_handlers {};
+typedef test_group<test_geoslength_data> group;
+group test_geoslength("capi::GEOSLength");
+template<>
+template<>
+    GEOSGeometry* input = GEOSGeomFromWKT("LINESTRING (1 0, 5 0)");
+    double length = -1;
+    int ret = GEOSLength(input, &length);
+    ensure_equals(ret, 1);
+    ensure_equals(length, 4);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSSetSRIDTest.cpp b/tests/unit/capi/GEOSSetSRIDTest.cpp
index 0000000..13a7645
--- /dev/null
+++ b/tests/unit/capi/GEOSSetSRIDTest.cpp
@@ -0,0 +1,33 @@
+// geos
+namespace tut {
+// Test Group
+struct test_geossetsrid_data : public capitest::test_handlers {};
+typedef test_group<test_geossetsrid_data> group;
+group test_geossetsrid("capi::GEOSSetSRID");
+template<>
+template<>
+    GEOSSetSRID(input, 1234);
+    ensure_equals(GEOSGetSRID(input), 1234);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSUnionTest.cpp b/tests/unit/capi/GEOSUnionTest.cpp
index 0000000..ed962db
--- /dev/null
+++ b/tests/unit/capi/GEOSUnionTest.cpp
@@ -0,0 +1,47 @@
+// geos
+namespace tut {
+// Test Group
+struct test_geosunion_data : public capitest::test_handlers {};
+typedef test_group<test_geosunion_data> group;
+group test_geosunion("capi::GEOSUnion");
+template<>
+template<>
+    GEOSGeometry* a = GEOSGeomFromWKT("POINT (2 8)");
+    GEOSGeometry* b = GEOSGeomFromWKT("POINT (3 9)");
+    ensure(a);
+    ensure(b);
+    GEOSSetSRID(a, 4326);
+    GEOSGeometry* result = GEOSUnion(a, b);
+    GEOSGeometry* expected = GEOSGeomFromWKT("MULTIPOINT (2 8, 3 9)");
+    ensure(result);
+    ensure(expected);
+    ensure_equals(GEOSGetSRID(a), GEOSGetSRID(result));
+    GEOSGeom_destroy(a);
+    GEOSGeom_destroy(b);
+} // namespace tut
diff --git a/tests/unit/capi/GEOSisValidReasonTest.cpp b/tests/unit/capi/GEOSisValidReasonTest.cpp
index 0000000..4f4bfd7
--- /dev/null
+++ b/tests/unit/capi/GEOSisValidReasonTest.cpp
@@ -0,0 +1,43 @@
+// geos
+namespace tut {
+// Test Group
+struct test_geosisvalid_data : public capitest::test_handlers {};
+typedef test_group<test_geosisvalid_data> group;
+group test_geosisvalid("capi::GEOSisValid");
+template<>
+template<>
+    ensure_equals(1, GEOSisValid(input));
+template<>
+template<>
+    GEOSGeometry* input = GEOSGeomFromWKT("POLYGON ((0 0, 1 0, 0 1, 1 1, 0 0))");
+    ensure_equals(0, GEOSisValid(input));
+} // namespace tut
diff --git a/tests/unit/capi/GEOSisValidTest.cpp b/tests/unit/capi/GEOSisValidTest.cpp
index 0000000..b1aa68a
--- /dev/null
+++ b/tests/unit/capi/GEOSisValidTest.cpp
@@ -0,0 +1,49 @@
+// geos
+namespace tut {
+// Test Group
+struct test_geosisvalidreason_data : public capitest::test_handlers {};
+typedef test_group<test_geosisvalidreason_data> group;
+group test_geosisvalidreason("capi::GEOSisValidReason");
+template<>
+template<>
+    char* reason = GEOSisValidReason(input);
+    ensure_equals(std::string(reason), "Valid Geometry");
+    GEOSFree(reason);
+template<>
+template<>
+    ensure_equals(std::string(reason), "Self-intersection[0.5 0.5]");
+    GEOSFree(reason);
+} // namespace tut
diff --git a/tests/unit/capi/capi_test_utils.h b/tests/unit/capi/capi_test_utils.h
index 0000000..3a4a6e5
--- /dev/null
+++ b/tests/unit/capi/capi_test_utils.h
@@ -0,0 +1,42 @@
+#ifndef GEOS_CAPI_TEST_UTILS_H
+#define GEOS_CAPI_TEST_UTILS_H
+#include <cstdarg>
+#include <cstdio>
+#include <cstdlib>
+#include <cstring>
+namespace capitest {
+    struct test_handlers {
+        static void notice(const char* fmt, ...)
+            std::fprintf(stdout, "NOTICE: ");
+            va_list ap;
+            va_start(ap, fmt);
+            std::vfprintf(stdout, fmt, ap);
+            va_end(ap);
+            std::fprintf(stdout, "\n");
+        test_handlers()
+            initGEOS(notice, notice);
+        ~test_handlers()
+            finishGEOS();
+#endif
Summary of changes:
 tests/unit/capi/GEOSBoundaryTest.cpp               | 38 ++++++++++++++++
 tests/unit/capi/GEOSEnvelopeTest.cpp               | 36 ++++++++++++++++
 tests/unit/capi/GEOSGeom_createLineStringTest.cpp  | 40 +++++++++++++++++
 tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp       | 50 ++++++++++++++++++++++
 .../capi/GEOSGeom_getCoordinateDimensionTest.cpp   | 38 ++++++++++++++++
 tests/unit/capi/GEOSGeom_getDimensionsTest.cpp     | 38 ++++++++++++++++
 tests/unit/capi/GEOSGetNumInteriorRingsTest.cpp    | 42 ++++++++++++++++++
 tests/unit/capi/GEOSLengthTest.cpp                 | 36 ++++++++++++++++
 tests/unit/capi/GEOSSetSRIDTest.cpp                | 33 ++++++++++++++
 tests/unit/capi/GEOSUnionTest.cpp                  | 47 ++++++++++++++++++++
 tests/unit/capi/GEOSisValidReasonTest.cpp          | 43 +++++++++++++++++++
 tests/unit/capi/GEOSisValidTest.cpp                | 49 +++++++++++++++++++++
 tests/unit/capi/capi_test_utils.h                  | 42 ++++++++++++++++++
 13 files changed, 532 insertions(+)
 create mode 100644 tests/unit/capi/GEOSBoundaryTest.cpp
 create mode 100644 tests/unit/capi/GEOSEnvelopeTest.cpp
 create mode 100644 tests/unit/capi/GEOSGeom_createLineStringTest.cpp
 create mode 100644 tests/unit/capi/GEOSGeom_getCoordSeqTest.cpp
 create mode 100644 tests/unit/capi/GEOSGeom_getCoordinateDimensionTest.cpp
 create mode 100644 tests/unit/capi/GEOSGeom_getDimensionsTest.cpp
 create mode 100644 tests/unit/capi/GEOSGetNumInteriorRingsTest.cpp
 create mode 100644 tests/unit/capi/GEOSLengthTest.cpp
 create mode 100644 tests/unit/capi/GEOSSetSRIDTest.cpp
 create mode 100644 tests/unit/capi/GEOSUnionTest.cpp
 create mode 100644 tests/unit/capi/GEOSisValidReasonTest.cpp
 create mode 100644 tests/unit/capi/GEOSisValidTest.cpp
 create mode 100644 tests/unit/capi/capi_test_utils.h
hooks/post-receive
More information about the geos-commits
