[geos-commits] [SCM] GEOS branch master updated. e37d04f8384b2e1fee83d64c6221adc3749a404a
git at osgeo.org
git at osgeo.org
Mon Mar 2 10:23:58 PST 2020
the project "GEOS".
via e37d04f8384b2e1fee83d64c6221adc3749a404a (commit)
via 4ca6d47ae271c5b38969fb60158f273a3e36700d (commit)
via dcfa3c3a6766172ab42db52517fab35fa0806d85 (commit)
via fc6dcdddb0426aefe8a72df44988d99e873f40a7 (commit)
via b1439de6bbeaa4c1a5458fb2f2c8e7bc2546ba66 (commit)
from 7ad488a7334552dae774d1130559c46a921efc02 (commit)
revisions in full, below.
commit e37d04f8384b2e1fee83d64c6221adc3749a404a
Author: Dan Baston <dbaston at gmail.com>
Date: Mon Mar 2 13:20:28 2020 -0500
Add test showing LineString vtable creation
References https://github.com/libgeos/geos/issues/285
References #1016
diff --git a/tests/unit/geom/LineStringTest.cpp b/tests/unit/geom/LineStringTest.cpp
index a31ef10..d7f0bb8 100644
--- a/tests/unit/geom/LineStringTest.cpp
+++ b/tests/unit/geom/LineStringTest.cpp
@@ -512,5 +512,20 @@ void object::test<28>
ensure(geo->isDimensionStrict(geos::geom::Dimension::L));
ensure(!geo->isDimensionStrict(geos::geom::Dimension::A));
+// test dynamic_cast for LineString (shows that vtable is created)
+// https://github.com/libgeos/geos/issues/285
+template<>
+template<>
+void object::test<29>
+ std::unique_ptr<geos::geom::LineString> a = geos::geom::GeometryFactory::getDefaultInstance()->createLineString();
+ geos::geom::Geometry *b = a.get(); // ok
+ geos::geom::LineString *c = dynamic_cast<geos::geom::LineString *>(b);
+ ensure(c != nullptr);
} // namespace tut
commit 4ca6d47ae271c5b38969fb60158f273a3e36700d
Date: Mon Mar 2 13:14:50 2020 -0500
Fix comment typos
index 2adffdb..a31ef10 100644
@@ -69,7 +69,7 @@ void object::test<1>
using geos::geom::Coordinate;
- // Empty sequence of coordiantes
+ // Empty sequence of coordinates
CoordArrayPtr pseq = new geos::geom::CoordinateArraySequence();
ensure("sequence is null pointer.", pseq != nullptr);
@@ -81,7 +81,7 @@ void object::test<1>
ensure(ls->isValid());
-// Test of non-tempty LineString created with user's constructor
+// Test of non-empty LineString created with user's constructor
template<>
template<>
void object::test<2>
@@ -89,7 +89,7 @@ void object::test<2>
- // Non-empty sequence of coordiantes
+ // Non-empty sequence of coordinates
const size_t size3 = 3;
@@ -101,7 +101,7 @@ void object::test<2>
ensure_equals(pseq->size(), size3);
- // Create non-empty linstring instance
+ // Create non-empty LineString instance
LineStringAutoPtr ls(factory_->createLineString(pseq));
ensure(!ls->isEmpty());
@@ -139,7 +139,7 @@ template<>
void object::test<3>
- // Single-element sequence of coordiantes
+ // Single-element sequence of coordinates
CoordArrayPtr pseq = nullptr;
try {
@@ -147,7 +147,7 @@ void object::test<3>
pseq->add(geos::geom::Coordinate(0, 0, 0));
ensure_equals(pseq->size(), 1u);
- // Create incomplete linstring
+ // Create incomplete LineString
fail("IllegalArgumentException expected.");
@@ -169,7 +169,7 @@ void object::test<4>
const size_t size = 3;
@@ -181,7 +181,7 @@ void object::test<4>
ensure_equals(pseq->size(), size);
- // Create examplar of linstring instance
+ // Create example of LineString instance
LineStringAutoPtr examplar(factory_->createLineString(pseq));
// Create copy
commit dcfa3c3a6766172ab42db52517fab35fa0806d85
Merge: b1439de fc6dcdd
Date: Mon Mar 2 13:11:46 2020 -0500
Merge remote-tracking branch 'rouault/add_deleted_copyconstructors'
commit fc6dcdddb0426aefe8a72df44988d99e873f40a7
Author: Even Rouault <even.rouault at spatialys.com>
Date: Fri Feb 28 14:53:52 2020 +0100
include/: add deleted copy constructors and assignment operators
cppcheck spots classes that have pointer member variables, but lack an
explicit copy constructor and assignment operator. The default behaviour
of bitwise copy is dangerous, so add explicit '= delete'
diff --git a/include/geos/geomgraph/PlanarGraph.h b/include/geos/geomgraph/PlanarGraph.h
index f22555b..374b7fa 100644
--- a/include/geos/geomgraph/PlanarGraph.h
+++ b/include/geos/geomgraph/PlanarGraph.h
@@ -194,6 +194,9 @@ private:
const geom::Coordinate& p1,
const geom::Coordinate& ep0,
const geom::Coordinate& ep1);
+ PlanarGraph(const PlanarGraph&) = delete;
+ PlanarGraph& operator=(const PlanarGraph&) = delete;
diff --git a/include/geos/index/bintree/Bintree.h b/include/geos/index/bintree/Bintree.h
index 3f776d2..f9e4321 100644
--- a/include/geos/index/bintree/Bintree.h
+++ b/include/geos/index/bintree/Bintree.h
@@ -115,6 +115,9 @@ private:
double minExtent;
void collectStats(Interval* interval);
+ Bintree(const Bintree&) = delete;
+ Bintree& operator=(const Bintree&) = delete;
} // namespace geos::index::bintree
diff --git a/include/geos/index/bintree/NodeBase.h b/include/geos/index/bintree/NodeBase.h
index b4f0d2b..e47dddb 100644
--- a/include/geos/index/bintree/NodeBase.h
+++ b/include/geos/index/bintree/NodeBase.h
@@ -70,6 +70,12 @@ protected:
Node* subnode[2];
virtual bool isSearchMatch(Interval* interval) = 0;
+private:
+ NodeBase(const NodeBase&) = delete;
+ NodeBase& operator=(const NodeBase&) = delete;
diff --git a/include/geos/index/strtree/AbstractSTRtree.h b/include/geos/index/strtree/AbstractSTRtree.h
index b2e10bc..6f0f18c 100644
--- a/include/geos/index/strtree/AbstractSTRtree.h
+++ b/include/geos/index/strtree/AbstractSTRtree.h
@@ -163,6 +163,9 @@ private:
ItemsList* itemsTree(AbstractNode* node);
+ AbstractSTRtree(const AbstractSTRtree&) = delete;
+ AbstractSTRtree& operator=(const AbstractSTRtree&) = delete;
protected:
/** \brief
diff --git a/include/geos/operation/buffer/OffsetSegmentString.h b/include/geos/operation/buffer/OffsetSegmentString.h
index b474703..2da1091 100644
--- a/include/geos/operation/buffer/OffsetSegmentString.h
+++ b/include/geos/operation/buffer/OffsetSegmentString.h
@@ -77,6 +77,8 @@ private:
return false;
+ OffsetSegmentString(const OffsetSegmentString&) = delete;
+ OffsetSegmentString& operator=(const OffsetSegmentString&) = delete;
public:
diff --git a/include/geos/operation/overlay/EdgeSetNoder.h b/include/geos/operation/overlay/EdgeSetNoder.h
index f61438c..b3f820c 100644
--- a/include/geos/operation/overlay/EdgeSetNoder.h
+++ b/include/geos/operation/overlay/EdgeSetNoder.h
@@ -48,6 +48,10 @@ class GEOS_DLL EdgeSetNoder {
private:
algorithm::LineIntersector* li;
std::vector<geomgraph::Edge*>* inputEdges;
+ EdgeSetNoder(const EdgeSetNoder&) = delete;
+ EdgeSetNoder& operator=(const EdgeSetNoder&) = delete;
public:
EdgeSetNoder(algorithm::LineIntersector* newLi)
diff --git a/include/geos/operation/overlay/PointBuilder.h b/include/geos/operation/overlay/PointBuilder.h
index 86a7765..a1867bb 100644
--- a/include/geos/operation/overlay/PointBuilder.h
+++ b/include/geos/operation/overlay/PointBuilder.h
@@ -78,6 +78,9 @@ private:
/// it from build()
std::vector<geom::Point*>* resultPointList;
+ PointBuilder(const PointBuilder&) = delete;
+ PointBuilder& operator=(const PointBuilder&) = delete;
public:
PointBuilder(OverlayOp* newOp,
diff --git a/include/geos/operation/relate/RelateNodeGraph.h b/include/geos/operation/relate/RelateNodeGraph.h
index 7f642ee..a6b92b7 100644
--- a/include/geos/operation/relate/RelateNodeGraph.h
+++ b/include/geos/operation/relate/RelateNodeGraph.h
@@ -87,6 +87,10 @@ public:
private:
geomgraph::NodeMap* nodes;
+ RelateNodeGraph(const RelateNodeGraph&) = delete;
+ RelateNodeGraph& operator=(const RelateNodeGraph&) = delete;
diff --git a/include/geos/operation/valid/SweeplineNestedRingTester.h b/include/geos/operation/valid/SweeplineNestedRingTester.h
index 8f9ac2d..b540dd7 100644
--- a/include/geos/operation/valid/SweeplineNestedRingTester.h
+++ b/include/geos/operation/valid/SweeplineNestedRingTester.h
@@ -69,6 +69,9 @@ private:
geom::Coordinate* nestedPt;
void buildIndex();
+ SweeplineNestedRingTester(const SweeplineNestedRingTester&) = delete;
+ SweeplineNestedRingTester& operator=(const SweeplineNestedRingTester&) = delete;
public:
SweeplineNestedRingTester(geomgraph::GeometryGraph* newGraph)
diff --git a/include/geos/planargraph/Node.h b/include/geos/planargraph/Node.h
index 721de4c..e29e4f8 100644
--- a/include/geos/planargraph/Node.h
+++ b/include/geos/planargraph/Node.h
@@ -143,6 +143,11 @@ public:
return deStar->getIndex(edge);
+private:
+ Node(const Node&) = delete;
+ Node& operator=(const Node&) = delete;
/// Print a Node
diff --git a/include/geos/precision/CommonBitsRemover.h b/include/geos/precision/CommonBitsRemover.h
index a493b93..0ffa086 100644
--- a/include/geos/precision/CommonBitsRemover.h
+++ b/include/geos/precision/CommonBitsRemover.h
@@ -45,6 +45,9 @@ private:
CommonCoordinateFilter* ccFilter;
+ CommonBitsRemover(const CommonBitsRemover&) = delete;
+ CommonBitsRemover& operator=(const CommonBitsRemover&) = delete;
public:
CommonBitsRemover();
commit b1439de6bbeaa4c1a5458fb2f2c8e7bc2546ba66
Author: Evgen Bodunov <evgen at getyourmap.com>
Date: Thu Feb 27 17:59:40 2020 +0300
Fixed https://trac.osgeo.org/geos/ticket/894 and https://github.com/libgeos/geos/issues/285
To have a vtable we should have explicit definition of key function. Details: https://lld.llvm.org/missingkeyfunction.html#missing-key-function
diff --git a/include/geos/geom/CoordinateArraySequenceFactory.inl b/include/geos/geom/CoordinateArraySequenceFactory.inl
index 761fdc6..e36a313 100644
--- a/include/geos/geom/CoordinateArraySequenceFactory.inl
+++ b/include/geos/geom/CoordinateArraySequenceFactory.inl
@@ -23,14 +23,6 @@ namespace geos {
namespace geom { // geos::geom
INLINE std::unique_ptr<CoordinateSequence>
-CoordinateArraySequenceFactory::create() const
- return std::unique_ptr<CoordinateSequence>(
- new CoordinateArraySequence(
- reinterpret_cast<std::vector<Coordinate>*>(0), 0));
-INLINE std::unique_ptr<CoordinateSequence>
CoordinateArraySequenceFactory::create(std::vector<Coordinate>* coords,
size_t dimension) const
diff --git a/include/geos/geom/LineString.h b/include/geos/geom/LineString.h
index 6ed0348..0316d62 100644
--- a/include/geos/geom/LineString.h
+++ b/include/geos/geom/LineString.h
@@ -74,7 +74,7 @@ public:
/// A vector of const LineString pointers
typedef std::vector<const LineString*> ConstVect;
- ~LineString() override = default;
+ ~LineString() override;
* \brief
diff --git a/src/geom/CoordinateArraySequenceFactory.cpp b/src/geom/CoordinateArraySequenceFactory.cpp
index decd6bd..ab0a6e8 100644
--- a/src/geom/CoordinateArraySequenceFactory.cpp
+++ b/src/geom/CoordinateArraySequenceFactory.cpp
@@ -25,6 +25,14 @@ namespace geom { // geos::geom
static CoordinateArraySequenceFactory defaultCoordinateSequenceFactory;
+std::unique_ptr<CoordinateSequence>
+CoordinateArraySequenceFactory::create() const
+ return std::unique_ptr<CoordinateSequence>(
+ new CoordinateArraySequence(
+ reinterpret_cast<std::vector<Coordinate>*>(0), 0));
const CoordinateSequenceFactory*
CoordinateArraySequenceFactory::instance()
diff --git a/src/geom/LineString.cpp b/src/geom/LineString.cpp
index cfcbb2b..65f86a0 100644
--- a/src/geom/LineString.cpp
+++ b/src/geom/LineString.cpp
@@ -45,6 +45,8 @@ using namespace geos::algorithm;
namespace geos {
+LineString::~LineString(){};
/*protected*/
LineString::LineString(const LineString& ls)
diff --git a/tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp b/tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp
index caea683..a69413c 100644
--- a/tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp
+++ b/tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp
@@ -52,10 +52,8 @@ void object::test<1>
ensure(nullptr != derived);
ensure(typeid(derived).name(), typeid(derived) == typeid(CoordinateArrayFactoryCPtr));
- catch(std::exception& /* e */) {
- /** ignore failure. TODO figure out why this fails on BSD/Clang
- * https://trac.osgeo.org/geos/ticket/894 and then put back**/
- //fail( e.what() );
+ catch(std::exception& e) {
+ fail( e.what() );
Summary of changes:
.../geos/geom/CoordinateArraySequenceFactory.inl | 8 ------
include/geos/geom/LineString.h | 2 +-
include/geos/geomgraph/PlanarGraph.h | 3 +++
include/geos/index/bintree/Bintree.h | 3 +++
include/geos/index/bintree/NodeBase.h | 6 +++++
include/geos/index/strtree/AbstractSTRtree.h | 3 +++
.../geos/operation/buffer/OffsetSegmentString.h | 2 ++
include/geos/operation/overlay/EdgeSetNoder.h | 4 +++
include/geos/operation/overlay/PointBuilder.h | 3 +++
include/geos/operation/relate/RelateNodeGraph.h | 4 +++
.../operation/valid/SweeplineNestedRingTester.h | 3 +++
include/geos/planargraph/Node.h | 5 ++++
include/geos/precision/CommonBitsRemover.h | 3 +++
src/geom/CoordinateArraySequenceFactory.cpp | 8 ++++++
src/geom/LineString.cpp | 2 ++
.../geom/CoordinateArraySequenceFactoryTest.cpp | 6 ++---
tests/unit/geom/LineStringTest.cpp | 31 ++++++++++++++++------
17 files changed, 75 insertions(+), 21 deletions(-)
hooks/post-receive
More information about the geos-commits
