[geos-commits] [SCM] GEOS branch master updated. ec1419c821f3a2f2b92ab7de232f7e2ace3bdb06
git at osgeo.org
git at osgeo.org
Mon Mar 9 15:04:47 PDT 2020
the project "GEOS".
via ec1419c821f3a2f2b92ab7de232f7e2ace3bdb06 (commit)
via 33971c09a5b58b25853e76ff96932ece5cc3a0ff (commit)
from ba24e3e294f39414bdb0290d07f673443bfe4b37 (commit)
revisions in full, below.
commit ec1419c821f3a2f2b92ab7de232f7e2ace3bdb06
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Mar 9 14:48:47 2020 -0700
reorder tests for #1018
diff --git a/tests/unit/index/tests/unit/index/chain/MonotoneChainBuilder.cpp b/tests/unit/index/chain/MonotoneChainBuilderTest.cpp
similarity index 99%
rename from tests/unit/index/tests/unit/index/chain/MonotoneChainBuilder.cpp
rename to tests/unit/index/chain/MonotoneChainBuilderTest.cpp
index dcee194..08e5015 100644
--- a/tests/unit/index/tests/unit/index/chain/MonotoneChainBuilder.cpp
+++ b/tests/unit/index/chain/MonotoneChainBuilderTest.cpp
@@ -27,7 +27,7 @@ struct test_monotonechain_data {
typedef test_group<test_monotonechain_data> group;
typedef group::object object;
-group test_monotonechain_group("geos::index::chain::MonotoneChain");
+group test_monotonechain_group("geos::index::chain::MonotoneChainBuilder");
// Test Cases
diff --git a/tests/xmltester/Makefile.am b/tests/xmltester/Makefile.am
index 469a424..b20dafe 100644
--- a/tests/xmltester/Makefile.am
+++ b/tests/xmltester/Makefile.am
@@ -109,6 +109,7 @@ SAFE_XMLTESTS= \
$(srcdir)/tests/issue/issue-geos-838.xml \
$(srcdir)/tests/issue/issue-geos-990.xml \
$(srcdir)/tests/issue/issue-geos-994.xml \
+ $(srcdir)/tests/issue/issue-geos-1018.xml \
$(srcdir)/tests/validate/TestRelateAA-big.xml \
$(srcdir)/tests/validate/TestRelateAA.xml \
$(srcdir)/tests/validate/TestRelateAC.xml \
diff --git a/tests/xmltester/tests/issue/issue-geos-1018.xml b/tests/xmltester/tests/issue/issue-geos-1018.xml
new file mode 100644
index 0000000..9dc5c03
--- /dev/null
+++ b/tests/xmltester/tests/issue/issue-geos-1018.xml
@@ -0,0 +1,19 @@
+<run>
+<precisionModel type="FLOATING" />
+<case>
+<desc>
+Difference of two geometries
+</desc>
+<a>
+POLYGON((0.1 0.1, 4.0 0.1, 4.0 1.9, 0.1 1.9, 0.1 0.1))
+</a>
+<b>
+POLYGON((0 0, 0 2, 2 2, 2 0, 0 0))
+</b>
+<test>
+<op name="difference" arg1="a" arg2="b">
+POLYGON ((2.0 1.9, 4.0 1.9, 4.0 0.1, 2.0 0.1, 2.0 1.9))
+</op>
+</test>
+</case>
+</run>
commit 33971c09a5b58b25853e76ff96932ece5cc3a0ff
Date: Mon Mar 9 13:45:23 2020 -0700
add unit test for GH290
diff --git a/tests/unit/index/tests/unit/index/chain/MonotoneChainBuilder.cpp b/tests/unit/index/tests/unit/index/chain/MonotoneChainBuilder.cpp
index 0000000..dcee194
--- /dev/null
+++ b/tests/unit/index/tests/unit/index/chain/MonotoneChainBuilder.cpp
@@ -0,0 +1,73 @@
+// Test Suite for geos::index::chain::MonotoneChainBuilder class.
+#include <tut/tut.hpp>
+// geos
+#include <geos/io/WKTReader.h>
+#include <geos/io/WKTWriter.h>
+#include <geos/geom/PrecisionModel.h>
+#include <geos/geom/GeometryFactory.h>
+#include <geos/geom/Geometry.h>
+#include <geos/geom/Point.h>
+#include <geos/geom/LineString.h>
+#include <geos/util.h>
+namespace tut {
+// dummy data, not used
+struct test_monotonechain_data {
+ geos::io::WKTReader wktreader;
+ geos::io::WKTWriter wktwriter;
+ test_monotonechain_data()
+ wktreader()
+typedef test_group<test_monotonechain_data> group;
+typedef group::object object;
+group test_monotonechain_group("geos::index::chain::MonotoneChain");
+// Test Cases
+// This issue exercised a bug in MonotoneChainBuilder
+// https://github.com/libgeos/geos/issues/290
+template<>
+template<>
+void object::test<1>
+ std::string wkt1("POLYGON((0 0, 0 2, 2 2, 2 0, 0 0))");
+ std::unique_ptr<geos::geom::Geometry> g1(wktreader.read(wkt1));
+ std::string wkt2("POLYGON((0.1 0.1, 4.0 0.1, 4.0 1.9, 0.1 1.9, 0.1 0.1))");
+ std::unique_ptr<geos::geom::Geometry> g2(wktreader.read(wkt2));
+ // POLYGON ((2.0 1.9, 4.0 1.9, 4.0 0.1, 2.0 0.1, 2.0 1.9))
+ double x[5] = {2.0, 4.0, 4.0, 2.0, 2.0};
+ double y[5] = {1.9, 1.9, 0.1, 0.1, 1.9};
+ auto g3 = g2->difference(g1.get());
+ auto cs = g3->getCoordinates();
+ // std::string wkt3 = wktwriter.write(g3.get());
+ // std::cout << wkt3 << std::endl;
+ for (int i = 0; i < 5; ++i)
+ auto csx = cs->getOrdinate(i, 0);
+ auto csy = cs->getOrdinate(i, 1);
+ // std::cout << csx << ", " << csy << std::endl;
+ // std::cout << x[i] << ", " << y[i] << std::endl;
+ ensure_equals("x", csx, x[i], 0.01);
+ ensure_equals("y", csy, y[i], 0.01);
+} // namespace tut
Summary of changes:
.../unit/index/chain/MonotoneChainBuilderTest.cpp | 73 ++++++++++++++++++++++
tests/xmltester/Makefile.am | 1 +
tests/xmltester/tests/issue/issue-geos-1018.xml | 19 ++++++
3 files changed, 93 insertions(+)
create mode 100644 tests/unit/index/chain/MonotoneChainBuilderTest.cpp
create mode 100644 tests/xmltester/tests/issue/issue-geos-1018.xml
hooks/post-receive
More information about the geos-commits
